  4. js-controller läuft auf Volllast
42 Beiträge 6 Kommentatoren 5.4k Aufrufe 2 Beobachtet
  • T Th3RockYeah
    @apollon77
    Ich habe mir die Logs gerade noch mal genauer angeschaut. Es beginnt nachdem Reboot hier:
    2022-03-20 18:47:33.802 - error: radar2.0 (2151) uncaught exception: Cannot read property 'init' of null
    2022-03-20 18:47:33.804 - warn: shelly.0 (2054) get state error: Connection is closed.
    2022-03-20 18:47:33.807 - error: shelly.0 (2054) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-03-20 18:47:33.803 - error: radar2.0 (2151) TypeError: Cannot read property 'init' of null
    at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.radar2/myNetworks.js:964:82)
    at listOnTimeout (internal/timers.js:557:17)
    at processTimers (internal/timers.js:500:7)
    2022-03-20 18:47:33.804 - error: radar2.0 (2151) Cannot read property 'init' of null
    2022-03-20 18:47:33.809 - warn: radar2.0 (2151) Uncaught Exception: Cannot read property 'init' of null
    2022-03-20 18:47:34.084 - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-03-20 18:47:33.808 - error: shelly.0 (2054) unhandled promise rejection: DB closed
    2022-03-20 18:47:34.282 - error: shelly.0 (2054) Error: DB closed
    at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
    at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:657:40)
    at Shelly.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:6485:35)
    2022-03-20 18:47:34.283 - error: shelly.0 (2054) DB closed
    2022-03-20 18:47:34.320 - warn: shelly.0 (2054) redis get shelly.0.SHPLG-S#DE15FC#1.Relay0.Timer, error - Connection is closed.
    2022-03-20 18:47:34.340 - warn: shelly.0 (2054) Could not perform strict object check of state shelly.0.SHPLG-S#B4B41F#1.Relay0.Power: DB closed
    2022-03-20 18:47:34.340 - warn: shelly.0 (2054) get state error: Connection is closed.
    2022-03-20 18:47:34.341 - warn: shelly.0 (2054) Could not perform strict object check of state shelly.0.SHPLG-S#B4B41F#1.temperatureC: DB closed
    2022-03-20 18:47:34.342 - warn: shelly.0 (2054) get state error: Connection is closed.
    2022-03-20 18:47:34.342 - warn: shelly.0 (2054) Could not perform strict object check of state shelly.0.SHPLG-S#B4B41F#1.temperatureF: DB closed
    2022-03-20 18:47:34.343 - warn: shelly.0 (2054) get state error: Connection is closed.
    2022-03-20 18:47:34.344 - warn: shelly.0 (2054) Could not perform strict object check of state shelly.0.SHPLG-S#E435C4#1.Relay0.Power: DB closed
    2022-03-20 18:47:34.344 - warn: shelly.0 (2054) get state error: Connection is closed.
    2022-03-20 18:47:34.345 - warn: shelly.0 (2054) Could not perform strict object check of state shelly.0.SHPLG-S#E435C4#1.temperatureC: DB closed
    2022-03-20 18:47:34.345 - warn: shelly.0 (2054) get state error: Connection is closed.
    2022-03-20 18:47:34.346 - warn: shelly.0 (2054) Could not perform strict object check of state shelly.0.SHPLG-S#E435C4#1.temperatureF: DB closed
    2022-03-20 18:47:34.347 - warn: shelly.0 (2054) get state error: Connection is closed.
    2022-03-20 18:47:34.347 - warn: shelly.0 (2054) Could not perform strict object check of state shelly.0.SHDM-1#D463D3#1.lights.Power: DB closed
    2022-03-20 18:47:34.348 - warn: shelly.0 (2054) get state error: Connection is closed.
    2022-03-20 18:47:34.349 - warn: shelly.0 (2054) Could not perform strict object check of state shelly.0.SHDM-1#D463D3#1.temperatureC: DB closed
    2022-03-20 18:47:34.350 - warn: shelly.0 (2054) get state error: Connection is closed.
    2022-03-20 18:47:34.350 - warn: shelly.0 (2054) Could not perform strict object check of state shelly.0.SHDM-1#D463D3#1.temperatureF: DB closed
    2022-03-20 18:47:34.351 - warn: shelly.0 (2054) get state error: Connection is closed.
    ein paar unauffällige Zeilen weiter kommt das hier:
    2022-03-20 18:54:02.954 - warn: weatherunderground.0 (735) get state error: DB closed
    2022-03-20 18:54:02.955 - warn: weatherunderground.0 (735) get state error: DB closed
    2022-03-20 18:54:02.956 - warn: weatherunderground.0 (735) get state error: DB closed
    2022-03-20 18:54:02.957 - warn: weatherunderground.0 (735) get state error: DB closed
    2022-03-20 18:54:02.960 - error: weatherunderground.0 (735) Could not parse Conditions-Data: Error: DB closed
    2022-03-20 18:54:25.464 - info: cloud.0 (845) Trying to connect as system.user.admin
    2022-03-20 18:54:25.469 - info: cloud.0 (845) Trying to connect as system.user.admin
    2022-03-20 18:54:25.470 - info: cloud.0 (845) Trying to connect as system.user.admin
    2022-03-20 18:54:25.472 - info: cloud.0 (845) Trying to connect as system.user.admin
    2022-03-20 18:54:25.473 - info: cloud.0 (845) Trying to connect as system.user.admin
    2022-03-20 18:54:25.532 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:25.533 - error: weatherunderground.0 (735) exception in : body.daily_forecastError: DB closed
    2022-03-20 18:54:26.239 - info: cloud.0 (845) Trying to connect as system.user.admin
    2022-03-20 18:54:26.967 - info: cloud.0 (845) Trying to connect as system.user.admin
    2022-03-20 18:54:26.993 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:26.995 - error: weatherunderground.0 (735) exception in : body.daily_forecastError: DB closed
    2022-03-20 18:54:27.387 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastPeriod.2p.date: DB closed
    2022-03-20 18:54:27.388 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.390 - error: weatherunderground.0 (735) exception in : body.daily_forecastError: DB closed
    2022-03-20 18:54:27.392 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastPeriod.3p.date: DB closed
    2022-03-20 18:54:27.393 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.395 - error: weatherunderground.0 (735) exception in : body.daily_forecastError: DB closed
    2022-03-20 18:54:27.400 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastPeriod.4p.date: DB closed
    2022-03-20 18:54:27.401 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.403 - error: weatherunderground.0 (735) exception in : body.daily_forecastError: DB closed
    2022-03-20 18:54:27.405 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastPeriod.5p.date: DB closed
    2022-03-20 18:54:27.406 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.407 - error: weatherunderground.0 (735) exception in : body.daily_forecastError: DB closed
    2022-03-20 18:54:27.409 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastPeriod.6p.date: DB closed
    2022-03-20 18:54:27.410 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.412 - error: weatherunderground.0 (735) exception in : body.daily_forecastError: DB closed
    2022-03-20 18:54:27.415 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastPeriod.7p.date: DB closed
    2022-03-20 18:54:27.416 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.417 - error: weatherunderground.0 (735) exception in : body.daily_forecastError: DB closed
    2022-03-20 18:54:27.422 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecast.0d.date: DB closed
    2022-03-20 18:54:27.423 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.425 - error: weatherunderground.0 (735) exception in daily forecast data Error: DB closed
    2022-03-20 18:54:27.427 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecast.1d.date: DB closed
    2022-03-20 18:54:27.428 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.434 - error: weatherunderground.0 (735) exception in daily forecast data Error: DB closed
    2022-03-20 18:54:27.436 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecast.2d.date: DB closed
    2022-03-20 18:54:27.437 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.439 - error: weatherunderground.0 (735) exception in daily forecast data Error: DB closed
    2022-03-20 18:54:27.441 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecast.3d.date: DB closed
    2022-03-20 18:54:27.442 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.443 - error: weatherunderground.0 (735) exception in daily forecast data Error: DB closed
    2022-03-20 18:54:27.448 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.0h.time: DB closed
    2022-03-20 18:54:27.449 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.451 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.453 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.1h.time: DB closed
    2022-03-20 18:54:27.454 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.456 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.460 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.2h.time: DB closed
    2022-03-20 18:54:27.461 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.463 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.466 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.3h.time: DB closed
    2022-03-20 18:54:27.467 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.469 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.471 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.4h.time: DB closed
    2022-03-20 18:54:27.472 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.474 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.476 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.5h.time: DB closed
    2022-03-20 18:54:27.477 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.479 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.481 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.6h.time: DB closed
    2022-03-20 18:54:27.482 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.483 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.486 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.7h.time: DB closed
    2022-03-20 18:54:27.487 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.488 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.490 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.8h.time: DB closed
    2022-03-20 18:54:27.491 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.493 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.495 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.9h.time: DB closed
    2022-03-20 18:54:27.496 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.498 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.500 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.10h.time: DB closed
    2022-03-20 18:54:27.501 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.503 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.506 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.11h.time: DB closed
    2022-03-20 18:54:27.507 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.509 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.511 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.12h.time: DB closed
    2022-03-20 18:54:27.512 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.514 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.516 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.13h.time: DB closed
    2022-03-20 18:54:27.517 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.518 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.520 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.14h.time: DB closed
    2022-03-20 18:54:27.521 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.523 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.525 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.15h.time: DB closed
    2022-03-20 18:54:27.525 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.527 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.529 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.16h.time: DB closed
    2022-03-20 18:54:27.529 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.531 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.533 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.17h.time: DB closed
    2022-03-20 18:54:27.534 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.536 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.538 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.18h.time: DB closed
    2022-03-20 18:54:27.539 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.540 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.544 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.19h.time: DB closed
    2022-03-20 18:54:27.550 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.551 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.553 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.20h.time: DB closed
    2022-03-20 18:54:27.554 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.556 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.559 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.21h.time: DB closed
    2022-03-20 18:54:27.560 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.562 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.564 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.22h.time: DB closed
    2022-03-20 18:54:27.565 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.567 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.569 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.23h.time: DB closed
    2022-03-20 18:54:27.570 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.571 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.573 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.24h.time: DB closed
    2022-03-20 18:54:27.574 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.576 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.578 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.25h.time: DB closed
    2022-03-20 18:54:27.579 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.580 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.595 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.26h.time: DB closed
    2022-03-20 18:54:27.599 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.600 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.603 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.27h.time: DB closed
    2022-03-20 18:54:27.603 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.605 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.607 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.28h.time: DB closed
    2022-03-20 18:54:27.608 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.610 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.612 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.29h.time: DB closed
    2022-03-20 18:54:27.613 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.614 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.616 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.30h.time: DB closed
    2022-03-20 18:54:27.631 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.634 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.638 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.31h.time: DB closed
    2022-03-20 18:54:27.641 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.646 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.648 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.32h.time: DB closed
    2022-03-20 18:54:27.649 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.650 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.652 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.33h.time: DB closed
    2022-03-20 18:54:27.653 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.655 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.657 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.34h.time: DB closed
    2022-03-20 18:54:27.658 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.659 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    2022-03-20 18:54:27.661 - warn: weatherunderground.0 (735) Could not perform strict object check of state weatherunderground.0.forecastHourly.35h.time: DB closed
    2022-03-20 18:54:27.662 - warn: weatherunderground.0 (735) get state error: Connection is closed.
    2022-03-20 18:54:27.664 - error: weatherunderground.0 (735) Could not parse hourly Forecast-Data: Error: DB closed
    danach läuft es aktuell durch.
    apollon77A
    apollon77A
    @th3rockyeah Und das war VOR dem reboot oder wie? Also ja beim beenden kann es mal vorkommen (da wurde in aktuellen Adapter versionen viel optimiert teilweise) dann ein adapte noch dinge tun will nachdem die DB (also controller schon weg ist). Das ist dann vor allem bei einem "iob restart" ggf blöd weil dann Prozesse hängen bleiben.
    Aber bei nem Reboot sollte das egal sein ... da ist die Frage wo das im Log exakt los geht ... am besten nochmal "iob stop" machen und schauen das alles beendet ist oder manuell killen. Dann iob start ... läuft dann alles sauber?
    Mich wundert nur das der js.controller 100% CPU hatte ... hätten die adapterprozesse sein müssen
    • apollon77A apollon77
      T
      T
      Th3RockYeah
      @apollon77 Ich habe "iob stop" gecheckt, ob ein Prozess läuft (top) und dann "iob start" gemacht.
      Folgende Logs sind dabei entstanden. Ich habe es leicht modifiziert, sry long read
      Teil 1
      2022-03-21 09:45:09.742 - info: host.raspberrypi All instances are stopped.
      2022-03-21 09:45:09.822 - info: host.raspberrypi terminated
      2022-03-21 09:46:22.398 - info: host.raspberrypi iobroker.js-controller version 4.0.19 js-controller starting
      2022-03-21 09:46:22.406 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-03-21 09:46:22.407 - info: host.raspberrypi hostname: raspberrypi, node: v14.19.1
      2022-03-21 09:46:22.407 - info: host.raspberrypi ip addresses: Y.X.C.V.31 IPV6Adree
      2022-03-21 09:46:24.089 - info: host.raspberrypi connected to Objects and States
      2022-03-21 09:46:24.142 - info: host.raspberrypi added notifications configuration of host
      2022-03-21 09:46:24.829 - info: host.raspberrypi 32 instances found
      2022-03-21 09:46:24.910 - info: host.raspberrypi starting 21 instances
      2022-03-21 09:46:25.101 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 11936
      2022-03-21 09:46:27.499 - info: admin.0 (11936) starting. Version 5.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 09:46:27.551 - info: admin.0 (11936) requesting all states
      2022-03-21 09:46:27.551 - info: admin.0 (11936) requesting all objects
      2022-03-21 09:46:29.062 - info: host.raspberrypi instance system.adapter.email.0 started with pid 11952
      2022-03-21 09:46:29.687 - info: admin.0 (11936) received all objects
      2022-03-21 09:46:30.072 - info: admin.0 (11936) Request actual repository...
      2022-03-21 09:46:30.119 - info: admin.0 (11936) http server listening on port 8081
      2022-03-21 09:46:30.120 - info: admin.0 (11936) Use link "http://localhost:8081" to configure.
      2022-03-21 09:46:31.362 - info: host.raspberrypi Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
      2022-03-21 09:46:32.537 - info: email.0 (11952) starting. Version 1.0.10 (non-npm: iobroker-community-adapters/ioBroker.email) in /opt/iobroker/node_modules/iobroker.email, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 09:46:33.032 - info: host.raspberrypi instance system.adapter.history.0 started with pid 11967
      2022-03-21 09:46:34.715 - info: admin.0 (11936) Repository received successfully.
      2022-03-21 09:46:37.145 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 11978
      2022-03-21 09:46:38.026 - info: history.0 (11967) starting. Version 1.11.0 in /opt/iobroker/node_modules/iobroker.history, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 09:46:38.196 - info: history.0 (11967) enabled logging of zigbee.0.00158d000464c66d.humidity (Count=1), Alias=false
      2022-03-21 09:46:38.197 - info: history.0 (11967) enabled logging of zigbee.0.00158d000464c66d.pressure (Count=2), Alias=false
      2022-03-21 09:46:38.198 - info: history.0 (11967) enabled logging of zigbee.0.00158d000464c66d.temperature (Count=3), Alias=false
      2022-03-21 09:46:38.199 - info: history.0 (11967) enabled logging of zigbee.0.00158d00046611c0.humidity (Count=4), Alias=false
      2022-03-21 09:46:38.200 - info: history.0 (11967) enabled logging of zigbee.0.00158d00046611c0.pressure (Count=5), Alias=false
      2022-03-21 09:46:38.201 - info: history.0 (11967) enabled logging of zigbee.0.00158d00046611c0.temperature (Count=6), Alias=false
      2022-03-21 09:46:49.318 - info: host.raspberrypi instance system.adapter.pushover.0 started with pid 11993
      2022-03-21 09:46:49.399 - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 11999
      2022-03-21 09:46:49.458 - info: host.raspberrypi instance system.adapter.hue.0 started with pid 12002
      2022-03-21 09:46:59.263 - info: host.raspberrypi instance system.adapter.shelly.0 started with pid 12026
      2022-03-21 09:46:59.304 - info: host.raspberrypi instance system.adapter.shelly.1 started with pid 12028
      2022-03-21 09:47:00.880 - info: javascript.0 (11978) starting. Version 5.4.5 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 09:47:01.255 - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 12044
      2022-03-21 09:47:02.757 - info: pushover.0 (11993) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.pushover, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 09:47:02.893 - info: alexa2.0 (11999) starting. Version 3.12.0 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 09:47:03.931 - info: javascript.0 (11978) requesting all states
      2022-03-21 09:47:03.933 - info: javascript.0 (11978) requesting all objects
      2022-03-21 09:47:06.148 - info: host.raspberrypi instance scheduled system.adapter.weatherunderground.0 6 * * * *
      2022-03-21 09:47:06.186 - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 12075
      2022-03-21 09:47:06.353 - info: javascript.0 (11978) received all objects
      2022-03-21 09:47:06.572 - info: javascript.0 (11978) received all states
      2022-03-21 09:47:07.197 - info: alexa2.0 (11999) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2022-03-21 09:47:07.227 - info: javascript.0 (11978) Start javascript script.js.common.BatteryCheck
      2022-03-21 09:47:07.400 - info: javascript.0 (11978) script.js.common.BatteryCheck: starting Batterieüberwachung V.1.8.5
      2022-03-21 09:47:07.417 - info: javascript.0 (11978) script.js.common.BatteryCheck: registered 0 subscriptions and 0 schedules
      2022-03-21 09:47:07.450 - info: javascript.0 (11978) Start javascript script.js.common.BewegungsmelderV2
      2022-03-21 09:47:07.476 - info: javascript.0 (11978) script.js.common.BewegungsmelderV2: *** Bewegungsmelder-Script gestartet *** Folgende Bewegungsmelder werden überwacht: BadGaeste, SchlafzimmerNew, Laundry, BadFirstFloor, FirstFloorLightNew, FirstFloorLightTom, StairsToFirstFloor, BeerCellar, ToolCellar, CellarFloor, StepToCellarFloor, AlarmTest3
      2022-03-21 09:47:07.481 - info: javascript.0 (11978) script.js.common.BewegungsmelderV2: registered 12 subscriptions and 0 schedules
      2022-03-21 09:47:07.482 - info: javascript.0 (11978) Start javascript script.js.common.CommonMix
      2022-03-21 09:47:07.502 - info: javascript.0 (11978) script.js.common.CommonMix: registered 8 subscriptions and 0 schedules
      2022-03-21 09:47:07.503 - info: javascript.0 (11978) Start javascript script.js.common.FritzBox
      2022-03-21 09:47:07.521 - info: javascript.0 (11978) script.js.common.FritzBox: registered 1 subscription and 0 schedules
      2022-03-21 09:47:07.523 - info: javascript.0 (11978) Start javascript script.js.common.LeavingHouse
      2022-03-21 09:47:07.547 - info: javascript.0 (11978) script.js.common.LeavingHouse: registered 2 subscriptions and 0 schedules
      2022-03-21 09:47:07.548 - info: javascript.0 (11978) Start javascript script.js.common.OpenDoorsWindows
      2022-03-21 09:47:07.582 - info: javascript.0 (11978) script.js.common.OpenDoorsWindows: registered 0 subscriptions and 0 schedules
      2022-03-21 09:47:07.583 - info: javascript.0 (11978) Start javascript script.js.common.Shellys
      2022-03-21 09:47:07.603 - info: javascript.0 (11978) script.js.common.Shellys: registered 9 subscriptions and 0 schedules
      2022-03-21 09:47:08.418 - info: javascript.0 (11978) script.js.common.OpenDoorsWindows: Alle Fenster geschlossen.
      2022-03-21 09:47:09.123 - info: shelly.0 (12026) starting. Version 5.3.2 in /opt/iobroker/node_modules/iobroker.shelly, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 09:47:09.170 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 12087
      2022-03-21 09:47:10.585 - info: tr-064.0 (12044) starting. Version 4.2.15 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 09:47:10.654 - info: shelly.1 (12028) starting. Version 5.3.2 in /opt/iobroker/node_modules/iobroker.shelly, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 09:47:11.513 - info: weatherunderground.0 (12075) starting. Version 3.4.1 (non-npm: iobroker-community-adapters/ioBroker.weatherunderground) in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 09:47:11.974 - info: shelly.0 (12026) Starting in CoAP mode.
      2022-03-21 09:47:12.209 - info: shelly.0 (12026) [CoAP] Listening for packets in the network
      2022-03-21 09:47:12.765 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shellyplug-s / shellyplug-s-E435C4 / SHPLG-S#E435C4#1) connected! Polltime set to 5 sec.
      2022-03-21 09:47:12.999 - info: shelly.1 (12028) Starting in MQTT mode. Listening on Y.X.C.V.31:1882
      2022-03-21 09:47:13.110 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shellydimmer / shellydimmer-D463D3 / SHDM-1#D463D3#1) connected! Polltime set to 5 sec.
      2022-03-21 09:47:13.388 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shellyplug-s / shellyplug-s-4BA36E / SHPLG2-1#4BA36E#1) connected! Polltime set to 5 sec.
      2022-03-21 09:47:13.681 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 12109
      2022-03-21 09:47:13.808 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shelly1 / shelly1-767AC8 / SHSW-1#767AC8#1) connected! Polltime set to 5 sec.
      2022-03-21 09:47:14.090 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shellyplug-s / shellyplug-s-80116A / SHPLG-S#80116A#1) connected! Polltime set to 5 sec.
      2022-03-21 09:47:15.629 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shelly1pm / shelly1pm-F27119 / SHSW-PM#F27119#1) connected! Polltime set to 5 sec.
      2022-03-21 09:47:17.290 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 12124
      2022-03-21 09:47:17.389 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shelly1pm / shelly1pm-F27634 / SHSW-PM#F27634#1) connected! Polltime set to 5 sec.
      2022-03-21 09:47:17.814 - info: shelly.1 (12028) [MQTT] Device Y.X.C.V (shellyplus1 / shellyplus1-a8032abeb1e4 / shellyplus1#a8032abeb1e4#1) connected! Polltime set to 5 sec.
      2022-03-21 09:47:18.224 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shellyplug-s / shellyplug-s-577BFA / SHPLG-S#577BFA#1) connected! Polltime set to 5 sec.
      2022-03-21 09:47:19.695 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shellydimmer2 / shellydimmer2-D8BFC019EECE / SHDM-2#D8BFC019EECE#1) connected! Polltime set to 5 sec.
      2022-03-21 09:47:20.044 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shellyplug-s / shellyplug-s-B4B41F / SHPLG-S#B4B41F#1) connected! Polltime set to 5 sec.
      2022-03-21 09:47:21.240 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shellyplug-s / shellyplug-s-8D010E / SHPLG-S#8D010E#1) connected! Polltime set to 5 sec.
      2022-03-21 09:47:23.103 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shellyplug-s / shellyplug-s-DE15FC / SHPLG-S#DE15FC#1) connected! Polltime set to 5 sec.
      2022-03-21 09:47:24.815 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shellydimmer / shellydimmer-D3E31B / SHDM-1#D3E31B#1) connected! Polltime set to 5 sec.
      2022-03-21 09:47:25.268 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shelly1 / shelly1-98F4ABF3CF6C / SHSW-1#98F4ABF3CF6C#1) connected! Polltime set to 5 sec.
      2022-03-21 09:47:29.331 - warn: backitup.0 (12124) slow connection to objects DB. Still waiting ...
      2022-03-21 09:52:24.306 - info: host.raspberrypi instance scheduled system.adapter.feiertage.0 0 0 * * *
      2022-03-21 09:52:24.345 - info: host.raspberrypi instance system.adapter.feiertage.0 started with pid 12147
      2022-03-21 09:52:36.215 - warn: feiertage.0 (12147) slow connection to objects DB. Still waiting ...
      2022-03-21 09:52:43.062 - info: host.raspberrypi instance scheduled system.adapter.schoolfree.0 1 0 * * *
      2022-03-21 09:52:43.140 - info: host.raspberrypi instance system.adapter.schoolfree.0 started with pid 12158
      2022-03-21 09:52:43.236 - info: host.raspberrypi instance system.adapter.radar2.0 started with pid 12164
      2022-03-21 09:52:43.660 - info: host.raspberrypi instance system.adapter.info.0 started with pid 12172
      2022-03-21 09:52:43.736 - info: host.raspberrypi instance system.adapter.cloud.0 started with pid 12173
      2022-03-21 09:52:44.165 - info: host.raspberrypi instance system.adapter.text2command.0 started with pid 12186
      2022-03-21 09:52:44.283 - info: host.raspberrypi instance system.adapter.iot.0 started with pid 12188
      2022-03-21 09:52:56.402 - warn: schoolfree.0 (12158) slow connection to objects DB. Still waiting ...
      2022-03-21 09:52:56.710 - warn: feiertage.0 (12147) slow connection to states DB. Still waiting ...
      2022-03-21 09:52:56.713 - warn: radar2.0 (12164) slow connection to objects DB. Still waiting ...
      2022-03-21 09:52:57.417 - warn: cloud.0 (12173) slow connection to objects DB. Still waiting ...
      2022-03-21 09:52:57.723 - warn: text2command.0 (12186) slow connection to objects DB. Still waiting ...
      2022-03-21 09:52:58.256 - warn: iot.0 (12188) slow connection to objects DB. Still waiting ...
      2022-03-21 09:52:59.031 - warn: info.0 (12172) slow connection to objects DB. Still waiting ...
      2022-03-21 09:55:35.146 - warn: schoolfree.0 (12158) slow connection to states DB. Still waiting ...
      2022-03-21 09:55:35.148 - warn: radar2.0 (12164) slow connection to states DB. Still waiting ...
      2022-03-21 09:55:35.150 - warn: cloud.0 (12173) slow connection to states DB. Still waiting ...
      2022-03-21 09:55:35.158 - warn: text2command.0 (12186) slow connection to states DB. Still waiting ...
      2022-03-21 09:55:35.293 - warn: iot.0 (12188) slow connection to states DB. Still waiting ...
      2022-03-21 09:55:35.298 - warn: info.0 (12172) slow connection to states DB. Still waiting ...
      2022-03-21 09:58:39.627 - info: zigbee.0 (12087) starting. Version 1.6.16 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 09:58:40.024 - info: discovery.0 (12109) starting. Version 2.8.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 09:58:40.015 - info: zigbee.0 (12087) Starting Zigbee npm ...
      2022-03-21 09:58:41.540 - info: radar2.0 (12164) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.radar2, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 09:58:41.651 - info: zigbee.0 (12087) Installed Version: ioBroker/ioBroker.zigbee
      2022-03-21 09:58:42.142 - info: zigbee.0 (12087) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20211217}}
      2022-03-21 09:58:42.152 - info: zigbee.0 (12087) Unable to disable LED, unsupported function.
      2022-03-21 09:58:42.180 - info: radar2.0 (12164) radar2 initialization started...
      2022-03-21 09:58:42.182 - info: zigbee.0 (12087) --> transmitPower : normal
      2022-03-21 09:58:42.215 - info: zigbee.0 (12087) Currently 53 devices are joined:
      2022-03-21 09:58:42.212 - info: radar2.0 (12164) Will use l2Ping for BT scans.
      2022-03-21 09:58:42.396 - info: radar2.0 (12164) Will run hcitool-mode and not noble on device []!
      2022-03-21 09:58:42.762 - info: radar2.0 (12164) arp-scan will use the following interfaces: [ 'eth0' ]
      2022-03-21 09:58:42.777 - info: text2command.0 (12186) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.text2command, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 09:58:42.865 - info: radar2.0 (12164) Connected with '0.0.0.0' for DHCP Scan
      2022-03-21 09:58:42.677 - info: zigbee.0 (12087) 0x00158d00044520d0 (addr 53360): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2022-03-21 09:58:42.692 - info: zigbee.0 (12087) 0xccccccfffea9c795 (addr 48051): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
      2022-03-21 09:58:42.918 - info: zigbee.0 (12087) 0x000d6ffffea61fe1 (addr 8521): E1746 - IKEA TRADFRI signal repeater (Router)
      2022-03-21 09:58:42.919 - info: zigbee.0 (12087) Zigbee started
      2022-03-21 09:58:43.334 - info: cloud.0 (12173) starting. Version 4.1.1 in /opt/iobroker/node_modules/iobroker.cloud, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 09:58:44.332 - info: cloud.0 (12173) Connecting with https://iobroker.pro:10555 with "@pro_lars@lars-keller.net_a56c8fe0-59a6-11ea-bbb9-a3d45e2d176f"
      2022-03-21 09:58:44.550 - warn: zigbee.0 (12087) DeviceAvailability:Failed to ping 0x000d6ffffe2e4a54 TRADFRI signal repeater
      2022-03-21 09:58:44.744 - info: backitup.0 (12124) starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 09:58:44.848 - info: feiertage.0 (12147) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 09:58:44.551 - warn: zigbee.0 (12087) DeviceAvailability:Failed to ping 0x680ae2fffe9c8577 TRADFRI Signal Repeater
      2022-03-21 09:58:45.143 - info: cloud.0 (12173) Trying to connect as system.user.admin
      2022-03-21 09:58:45.270 - info: backitup.0 (12124) [iobroker] backup was activated at 02:53 every 1 day(s)
      2022-03-21 09:58:45.503 - info: schoolfree.0 (12158) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.schoolfree, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 09:58:45.880 - warn: schoolfree.0 (12158) schoolfree set state error: TypeError: Cannot read property 'name' of undefined
      2022-03-21 09:58:46.765 - info: schoolfree.0 (12158) schoolfree request done
      2022-03-21 09:58:47.101 - info: iot.0 (12188) starting. Version 1.11.2 in /opt/iobroker/node_modules/iobroker.iot, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 09:58:47.359 - info: feiertage.0 (12147) Next holiday: Karfreitag is in 25 days on 15.04.2022
      2022-03-21 09:58:47.355 - info: iot.0 (12188) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2022-03-21 09:58:48.667 - info: feiertage.0 (12147) adapter feiertage objects written
      2022-03-21 09:58:49.283 - info: feiertage.0 (12147) Terminated (NO_ERROR): Without reason
      2022-03-21 09:58:49.971 - info: iot.0 (12188) Connection changed: connect
      2022-03-21 09:58:50.051 - error: cloud.0 (12173) Cloud says: timeout
      2022-03-21 09:58:50.437 - info: host.raspberrypi instance system.adapter.feiertage.0 terminated with code 0 (NO_ERROR)
      2022-03-21 09:58:50.509 - info: radar2.0 (12164) Init item YYYY with {name: 'YYYY',bluetooth: [],enabled: -1,id: 'YYYY',type: 'IP',hasMAC: [ 'XXXX' ],ipVendor: 'N/A',rip: [ '192.168.xxx.yyy' ],lasthere: '2022-03-21T05:14:19.102Z'}
      2022-03-21 09:58:51.060 - info: cloud.0 (12173) Connection changed: io server disconnect
      2022-03-21 09:58:52.403 - info: info.0 (12172) starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 09:58:52.691 - info: info.0 (12172) Reading/updating systemdata.
      2022-03-21 09:58:54.318 - info: info.0 (12172) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
      2022-03-21 09:58:54.560 - info: info.0 (12172) State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
      2022-03-21 09:58:54.618 - info: info.0 (12172) State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
      2022-03-21 09:58:54.644 - info: info.0 (12172) State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
      2022-03-21 09:58:54.706 - info: info.0 (12172) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
      2022-03-21 09:58:55.350 - info: info.0 (12172) cpu Temp res = {"main":74.984,"cores":[],"max":74.984,"socket":[],"chipset":null}
      2022-03-21 09:58:56.197 - info: info.0 (12172) State value to set for "info.0.sysinfo.memory.memLayout.ram0.ecc" has to be stringified but received type "boolean"
      2022-03-21 09:58:56.763 - info: radar2.0 (12164) Init item XXXXX with {name: 'XXXXX',bluetooth: [],enabled: -1,id: 'XXXXX',type: 'IP',hasMAC: [ 'xxx' ],ipVendor: 'N/A',rip: [ '192.168.xxx.yyy' ],lasthere: '2021-12-14T03:02:35.263Z'}
      2022-03-21 09:58:56.989 - info: radar2.0 (12164) Init item XXXYYY with {name: 'XXXYYY',bluetooth: [],enabled: -1,id: 'XXXYYY',type: 'IP',hasMAC: [ 'xxx' ],ipVendor: 'N/A',rip: [ '192.168.xxx.yyy' ],lasthere: '2022-03-21T08:44:50.501Z'}
      2022-03-21 09:58:56.990 - info: radar2.0 (12164) Adapter identified macs: (XXX,YYY,CCC),
      ips: (xxx.xxx.xxx.yyy,xxx.xxx.xxx.yyy,xxx.xxx.xxx.yyy),
      bts LE: (),
      bts norm: ()
      2022-03-21 09:58:57.272 - info: radar2.0 (12164) radar2 found 3 devices in config (YYYY,XXXXX,XXXYYY) and 3 enabled.
      2022-03-21 09:58:57.273 - info: radar2.0 (12164) radar2 set use of noble(false), doArp("-lgq --retry=5 --timeout=400" on eth0), btid(-1) and doUwz(undefined,30,0,de,true).
      2022-03-21 09:59:14.958 - info: cloud.0 (12173) Trying to connect as system.user.admin
      2022-03-21 09:59:15.281 - info: cloud.0 (12173) Connection changed: connect
      2022-03-21 09:59:15.327 - info: cloud.0 (12173) Adapter redirected temporally to "https://iobroker.pro:10556" in 30 seconds. Reason: command from server
      2022-03-21 09:59:16.788 - info: schoolfree.0 (12158) Terminated (NO_ERROR): Without reason
      2022-03-21 09:59:17.807 - info: host.raspberrypi instance system.adapter.schoolfree.0 terminated with code 0 (NO_ERROR)
      2022-03-21 09:59:18.058 - info: weatherunderground.0 (12075) Terminated (NO_ERROR): Without reason
      2022-03-21 09:59:19.030 - info: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
      2022-03-21 09:59:53.061 - error: radar2.0 (12164) States database error: write EPIPE
      2022-03-21 09:59:53.064 - info: shelly.1 (12028) Closing Adapter
      2022-03-21 09:59:53.364 - info: radar2.0 (12164) Unload adapter now with null
      2022-03-21 09:59:53.366 - info: radar2.0 (12164) Adapter disconnected and stopped with dostop(null) and callback(true)
      2022-03-21 09:59:53.360 - error: shelly.0 (12026) Objects database error: write EPIPE
      2022-03-21 09:59:54.120 - error: radar2.0 (12164) uncaught exception: Cannot read property 'init' of null
      2022-03-21 09:59:54.122 - error: radar2.0 (12164) TypeError: Cannot read property 'init' of null
      2022-03-21 09:59:54.123 - error: radar2.0 (12164) Cannot read property 'init' of null
      2022-03-21 09:59:54.125 - warn: radar2.0 (12164) Uncaught Exception: Cannot read property 'init' of null
      2022-03-21 09:59:54.236 - error: iot.0 (12188) States database error: write ECONNRESET
      2022-03-21 09:59:54.419 - info: iot.0 (12188) Connection changed: disconnect
      2022-03-21 09:59:54.420 - info: iot.0 (12188) Connection lost
      2022-03-21 09:59:54.472 - error: backitup.0 (12124) States database error: write ECONNRESET
      2022-03-21 09:59:54.478 - info: backitup.0 (12124) cleaned everything up...
      2022-03-21 09:59:54.489 - error: tr-064.0 (12044) States database error: write EPIPE
      2022-03-21 09:59:54.569 - info: shelly.1 (12028) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-03-21 09:59:54.544 - error: hue.0 (12002) States database error: write ECONNRESET
      2022-03-21 09:59:54.738 - error: history.0 (11967) States database error: write ECONNRESET
      2022-03-21 09:59:54.808 - error: pushover.0 (11993) States database error: write EPIPE
      2022-03-21 09:59:54.865 - info: radar2.0 (12164) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-03-21 09:59:54.861 - error: text2command.0 (12186) States database error: write ECONNRESET
      2022-03-21 09:59:54.888 - error: zigbee.0 (12087) States database error: write ECONNRESET
      2022-03-21 09:59:54.897 - error: javascript.0 (11978) States database error: write ECONNRESET
      2022-03-21 09:59:54.905 - info: zigbee.0 (12087) cleaned everything up...
      2022-03-21 09:59:54.910 - error: discovery.0 (12109) States database error: write ECONNRESET
      2022-03-21 09:59:54.948 - info: javascript.0 (11978) Stop script script.js.common.BatteryCheck
      2022-03-21 09:59:54.959 - error: cloud.0 (12173) States database error: write ECONNRESET
      2022-03-21 09:59:54.943 - error: email.0 (11952) States database error: write ECONNRESET
      2022-03-21 09:59:54.839 - error: shelly.0 (12026) States database error: write EPIPE
      2022-03-21 09:59:55.071 - error: alexa2.0 (11999) States database error: write EPIPE
      2022-03-21 09:59:54.965 - info: javascript.0 (11978) Stop script script.js.common.BewegungsmelderV2
      2022-03-21 09:59:54.981 - info: javascript.0 (11978) Stop script script.js.common.CommonMix
      2022-03-21 09:59:54.983 - info: javascript.0 (11978) Stop script script.js.common.FritzBox
      2022-03-21 09:59:54.984 - info: javascript.0 (11978) Stop script script.js.common.LeavingHouse
      2022-03-21 09:59:55.022 - info: javascript.0 (11978) Stop script script.js.common.OpenDoorsWindows
      2022-03-21 09:59:55.026 - info: javascript.0 (11978) Stop script script.js.common.Shellys
      2022-03-21 09:59:55.105 - error: info.0 (12172) States database error: write ECONNRESET
      2022-03-21 09:59:55.113 - info: info.0 (12172) cleaned everything up...
      2022-03-21 09:59:55.187 - info: shelly.0 (12026) Closing Adapter
      2022-03-21 09:59:55.234 - error: admin.0 (11936) States database error: write EPIPE
      2022-03-21 09:59:55.325 - info: zigbee.0 (12087) Zigbee: disabling joining new devices.
      2022-03-21 09:59:55.358 - info: admin.0 (11936) terminating http server on port 8081
      2022-03-21 09:59:55.793 - info: iot.0 (12188) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-03-21 09:59:55.983 - info: backitup.0 (12124) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-03-21 09:59:56.013 - info: tr-064.0 (12044) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-03-21 09:59:56.367 - info: pushover.0 (11993) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-03-21 09:59:56.409 - info: zigbee.0 (12087) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-03-21 09:59:56.417 - info: text2command.0 (12186) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-03-21 09:59:56.430 - info: discovery.0 (12109) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-03-21 09:59:56.453 - info: javascript.0 (11978) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-03-21 09:59:56.486 - info: email.0 (11952) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-03-21 09:59:56.498 - info: cloud.0 (12173) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-03-21 09:59:56.638 - info: alexa2.0 (11999) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-03-21 09:59:56.640 - info: info.0 (12172) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-03-21 09:59:56.691 - info: shelly.0 (12026) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-03-21 09:59:56.865 - info: admin.0 (11936) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-03-21 09:59:57.825 - error: shelly.1 (12028) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2022-03-21 09:59:57.836 - warn: shelly.1 (12028) get state error: Connection is closed.
      2022-03-21 09:59:57.837 - warn: shelly.1 (12028) get state error: DB closed
      2022-03-21 09:59:57.838 - warn: shelly.1 (12028) get state error: DB closed
      2022-03-21 09:59:57.839 - warn: shelly.1 (12028) get state error: DB closed
      2022-03-21 09:59:57.840 - warn: shelly.1 (12028) get state error: DB closed
      2022-03-21 09:59:57.841 - warn: shelly.1 (12028) get state error: DB closed
      2022-03-21 09:59:57.842 - warn: shelly.1 (12028) get state error: DB closed
      2022-03-21 09:59:57.843 - warn: shelly.1 (12028) get state error: DB closed
      2022-03-21 09:59:58.396 - warn: radar2.0 (12164) get state error: Connection is closed.
      2022-03-21 09:59:58.397 - warn: radar2.0 (12164) get state error: DB closed
      2022-03-21 09:59:58.398 - warn: radar2.0 (12164) get state error: DB closed
      2022-03-21 09:59:58.399 - warn: radar2.0 (12164) get state error: DB closed
      2022-03-21 09:59:58.400 - warn: radar2.0 (12164) get state error: DB closed
      2022-03-21 09:59:58.401 - warn: radar2.0 (12164) get state error: DB closed
      2022-03-21 09:59:58.401 - warn: radar2.0 (12164) redis get radar2.0.info.connection, error - DB closed
      2022-03-21 09:59:58.402 - warn: radar2.0 (12164) get state error: DB closed
      2022-03-21 09:59:58.403 - warn: radar2.0 (12164) get state error: DB closed
      2022-03-21 09:59:58.404 - warn: radar2.0 (12164) get state error: DB closed
      2022-03-21 09:59:58.406 - warn: radar2.0 (12164) get state error: DB closed
      2022-03-21 09:59:58.407 - warn: radar2.0 (12164) get state error: DB closed
      2022-03-21 09:59:58.504 - error: shelly.0 (12026) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2022-03-21 09:59:59.316 - error: iot.0 (12188) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2022-03-21 09:59:59.326 - warn: iot.0 (12188) get state error: Connection is closed.
      2022-03-21 09:59:59.327 - warn: iot.0 (12188) get state error: DB closed
      2022-03-21 09:59:59.328 - warn: iot.0 (12188) get state error: DB closed
      2022-03-21 09:59:59.329 - warn: iot.0 (12188) get state error: DB closed
      2022-03-21 09:59:59.330 - warn: iot.0 (12188) get state error: DB closed
      2022-03-21 09:59:59.331 - warn: iot.0 (12188) get state error: DB closed
      2022-03-21 09:59:59.332 - warn: iot.0 (12188) get state error: DB closed
      2022-03-21 09:59:59.333 - warn: iot.0 (12188) get state error: DB closed
      2022-03-21 09:59:59.334 - warn: iot.0 (12188) get state error: DB closed
      2022-03-21 09:59:59.486 - warn: backitup.0 (12124) get state error: Connection is closed.
      2022-03-21 09:59:59.524 - warn: tr-064.0 (12044) get state error: Connection is closed.
      2022-03-21 09:59:59.800 - error: history.0 (11967) States database error: connect ECONNREFUSED 127.0.0.1:9000
      2022-03-21 09:59:59.805 - error: history.0 (11967) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2022-03-21 09:59:59.899 - warn: pushover.0 (11993) get state error: Connection is closed.
      2022-03-21 09:59:59.936 - warn: text2command.0 (12186) get state error: Connection is closed.
      2022-03-21 09:59:59.952 - warn: discovery.0 (12109) get state error: Connection is closed.
      2022-03-21 09:59:59.997 - warn: email.0 (11952) get state error: Connection is closed.
      2022-03-21 10:00:00.014 - warn: cloud.0 (12173) get state error: Connection is closed.
      2022-03-21 10:00:00.073 - warn: javascript.0 (11978) get state error: Connection is closed.
      2022-03-21 10:00:00.075 - warn: javascript.0 (11978) get state error: DB closed
      2022-03-21 10:00:00.090 - warn: javascript.0 (11978) get state error: DB closed
      2022-03-21 10:00:00.091 - warn: javascript.0 (11978) get state error: DB closed
      2022-03-21 10:00:00.144 - warn: alexa2.0 (11999) get state error: Connection is closed.
      2022-03-21 10:00:00.145 - warn: info.0 (12172) get state error: Connection is closed.
      2022-03-21 10:00:00.145 - warn: alexa2.0 (11999) get state error: DB closed
      2022-03-21 10:00:00.146 - warn: alexa2.0 (11999) get state error: DB closed
      2022-03-21 10:00:00.147 - warn: alexa2.0 (11999) get state error: DB closed
      2022-03-21 10:00:00.148 - warn: alexa2.0 (11999) get state error: DB closed
      2022-03-21 10:00:00.149 - warn: alexa2.0 (11999) get state error: DB closed
      2022-03-21 10:00:00.150 - warn: alexa2.0 (11999) get state error: DB closed
      2022-03-21 10:00:00.151 - warn: alexa2.0 (11999) get state error: DB closed
      2022-03-21 10:00:00.152 - warn: alexa2.0 (11999) get state error: DB closed
      2022-03-21 10:00:00.157 - warn: alexa2.0 (11999) redis get alexa2.0.History.creationTime, error - DB closed
      2022-03-21 10:00:00.157 - warn: alexa2.0 (11999) get state error: DB closed
      2022-03-21 10:00:00.158 - warn: alexa2.0 (11999) get state error: DB closed
      2022-03-21 10:00:00.146 - warn: info.0 (12172) get state error: DB closed
      2022-03-21 10:00:00.147 - warn: info.0 (12172) get state error: DB closed
      2022-03-21 10:00:00.148 - warn: info.0 (12172) get state error: DB closed
      2022-03-21 10:00:00.149 - warn: info.0 (12172) get state error: DB closed
      2022-03-21 10:00:00.155 - warn: info.0 (12172) get state error: DB closed
      2022-03-21 10:00:00.156 - warn: info.0 (12172) get state error: DB closed
      2022-03-21 10:00:00.157 - warn: info.0 (12172) get state error: DB closed
      2022-03-21 10:00:00.158 - warn: info.0 (12172) get state error: DB closed
      2022-03-21 10:00:00.159 - warn: info.0 (12172) get state error: DB closed
      2022-03-21 10:00:00.199 - warn: shelly.0 (12026) get state error: Connection is closed.
      2022-03-21 10:00:00.200 - warn: shelly.0 (12026) get state error: DB closed
      2022-03-21 10:00:00.201 - warn: shelly.0 (12026) get state error: DB closed
      2022-03-21 10:00:00.202 - warn: shelly.0 (12026) get state error: DB closed
      2022-03-21 10:00:00.203 - warn: shelly.0 (12026) get state error: DB closed
      2022-03-21 10:00:00.204 - warn: shelly.0 (12026) get state error: DB closed
      2022-03-21 10:00:00.205 - warn: shelly.0 (12026) get state error: DB closed
      2022-03-21 10:00:00.212 - warn: shelly.0 (12026) get state error: DB closed
      2022-03-21 10:00:00.355 - warn: zigbee.0 (12087) get state error: Connection is closed.
      2022-03-21 10:00:00.356 - warn: zigbee.0 (12087) get state error: DB closed
      2022-03-21 10:00:00.357 - warn: zigbee.0 (12087) get state error: DB closed
      2022-03-21 10:00:00.360 - warn: zigbee.0 (12087) get state error: DB closed
      2022-03-21 10:00:00.361 - warn: zigbee.0 (12087) get state error: DB closed
      2022-03-21 10:00:00.362 - warn: zigbee.0 (12087) get state error: DB closed
      2022-03-21 10:00:00.363 - warn: zigbee.0 (12087) get state error: DB closed
      2022-03-21 10:00:00.436 - warn: admin.0 (11936) get state error: Connection is closed.
      2022-03-21 10:00:00.440 - warn: admin.0 (11936) get state error: DB closed
      2022-03-21 10:00:00.448 - warn: admin.0 (11936) get state error: DB closed
      2022-03-21 10:00:00.449 - warn: admin.0 (11936) get state error: DB closed
      2022-03-21 10:00:00.784 - warn: admin.0 (11936) Cannot get view: Connection is closed.
      2022-03-21 10:00:02.833 - error: shelly.1 (12028) Cannot find view "system" for search "device" : Connection is closed.
      2022-03-21 10:00:03.511 - error: shelly.0 (12026) Cannot find view "system" for search "device" : DB closed
      2022-03-21 10:00:04.803 - error: history.0 (11967) States database error: connect ECONNREFUSED 127.0.0.1:9000
      2022-03-21 10:00:04.807 - error: history.0 (11967) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2022-03-21 10:00:05.796 - info: history.0 (11967) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-03-21 10:00:09.810 - warn: history.0 (11967) get state error: Connection is closed.
      2022-03-21 10:00:09.812 - warn: history.0 (11967) get state error: DB closed
      2022-03-21 10:00:09.829 - warn: history.0 (11967) get state error: DB closed
      2022-03-21 10:00:09.830 - warn: history.0 (11967) get state error: DB closed
      2022-03-21 10:00:09.831 - warn: history.0 (11967) get state error: DB closed
      2022-03-21 10:00:15.504 - info: host.raspberrypi iobroker.js-controller version 4.0.19 js-controller starting
      2022-03-21 10:00:15.512 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-03-21 10:00:15.513 - info: host.raspberrypi hostname: raspberrypi, node: v14.19.1
      2022-03-21 10:00:15.513 - info: host.raspberrypi ip addresses: Y.X.C.V.31 fd01::dea6:32ff:fe4f:dd06 2a02:810d:29bf:fe29:dea6:32ff:fe4f:dd06 fe80::dea6:32ff:fe4f:dd06
      2022-03-21 10:00:17.401 - info: host.raspberrypi connected to Objects and States
      2022-03-21 10:00:17.461 - info: host.raspberrypi added notifications configuration of host
      2022-03-21 10:00:18.336 - info: host.raspberrypi 32 instances found
      2022-03-21 10:00:18.397 - info: host.raspberrypi starting 21 instances
      2022-03-21 10:00:18.643 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 12522
      2022-03-21 10:00:20.608 - error: admin.0 (12522) admin.0 already running
      2022-03-21 10:00:20.612 - warn: admin.0 (12522) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-03-21 10:00:21.247 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-03-21 10:00:21.249 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
      2022-03-21 10:00:22.436 - info: host.raspberrypi instance system.adapter.email.0 started with pid 12533
      2022-03-21 10:00:23.953 - error: email.0 (12533) email.0 already running
      2022-03-21 10:00:23.957 - warn: email.0 (12533) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-03-21 10:00:24.578 - error: host.raspberrypi instance system.adapter.email.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-03-21 10:00:24.579 - info: host.raspberrypi Restart adapter system.adapter.email.0 because enabled
      2022-03-21 10:00:26.568 - info: host.raspberrypi instance system.adapter.history.0 started with pid 12544
      2022-03-21 10:00:28.117 - error: history.0 (12544) history.0 already running
      2022-03-21 10:00:28.122 - warn: history.0 (12544) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-03-21 10:00:28.757 - error: host.raspberrypi instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-03-21 10:00:28.758 - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
      2022-03-21 10:00:30.514 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 12555
      2022-03-21 10:00:33.965 - error: javascript.0 (12555) javascript.0 already running
      2022-03-21 10:00:33.969 - warn: javascript.0 (12555) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-03-21 10:00:34.523 - info: host.raspberrypi instance system.adapter.pushover.0 started with pid 12566
      2022-03-21 10:00:34.641 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-03-21 10:00:34.642 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
      2022-03-21 10:00:36.117 - error: pushover.0 (12566) pushover.0 already running
      2022-03-21 10:00:36.120 - warn: pushover.0 (12566) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-03-21 10:00:36.770 - error: host.raspberrypi instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-03-21 10:00:36.771 - info: host.raspberrypi Restart adapter system.adapter.pushover.0 because enabled
      2022-03-21 10:00:38.513 - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 12577
      2022-03-21 10:00:40.157 - error: alexa2.0 (12577) alexa2.0 already running
      2022-03-21 10:00:40.161 - warn: alexa2.0 (12577) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-03-21 10:00:40.784 - error: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-03-21 10:00:40.785 - info: host.raspberrypi Restart adapter system.adapter.alexa2.0 because enabled
      2022-03-21 10:00:42.543 - info: host.raspberrypi instance system.adapter.hue.0 started with pid 12588
      2022-03-21 10:00:44.440 - error: hue.0 (12588) hue.0 already running
      2022-03-21 10:00:45.064 - error: host.raspberrypi instance system.adapter.hue.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-03-21 10:00:45.065 - info: host.raspberrypi Restart adapter system.adapter.hue.0 because enabled
      2022-03-21 10:00:46.536 - info: host.raspberrypi instance system.adapter.shelly.0 started with pid 12599
      2022-03-21 10:00:48.877 - error: shelly.0 (12599) shelly.0 already running
      2022-03-21 10:00:48.881 - warn: shelly.0 (12599) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-03-21 10:00:49.500 - error: host.raspberrypi instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-03-21 10:00:49.501 - info: host.raspberrypi Restart adapter system.adapter.shelly.0 because enabled
      2022-03-21 10:00:50.522 - info: host.raspberrypi instance system.adapter.shelly.1 started with pid 12610
      2022-03-21 10:00:51.381 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 12617
      2022-03-21 10:00:52.767 - error: shelly.1 (12610) shelly.1 already running
      2022-03-21 10:00:52.771 - warn: shelly.1 (12610) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-03-21 10:00:53.546 - error: host.raspberrypi instance system.adapter.shelly.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-03-21 10:00:53.547 - info: host.raspberrypi Restart adapter system.adapter.shelly.1 because enabled
      2022-03-21 10:00:53.864 - info: admin.0 (12617) starting. Version 5.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 10:00:53.913 - info: admin.0 (12617) requesting all states
      2022-03-21 10:00:53.914 - info: admin.0 (12617) requesting all objects
      2022-03-21 10:00:55.451 - info: host.raspberrypi instance system.adapter.email.0 started with pid 12636
      2022-03-21 10:00:55.491 - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 12642
      2022-03-21 10:00:55.958 - info: admin.0 (12617) received all objects
      2022-03-21 10:00:56.469 - info: admin.0 (12617) Request actual repository...
      2022-03-21 10:00:56.513 - info: admin.0 (12617) http server listening on port 8081
      2022-03-21 10:00:56.514 - info: admin.0 (12617) Use link "http://localhost:8081" to configure.
      2022-03-21 10:01:05.113 - info: host.raspberrypi instance scheduled system.adapter.weatherunderground.0 6 * * * *
      2022-03-21 10:01:05.140 - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 12658
      2022-03-21 10:01:05.367 - info: host.raspberrypi Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
      2022-03-21 10:01:07.096 - info: host.raspberrypi instance system.adapter.history.0 started with pid 12669
      2022-03-21 10:01:07.531 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 12676
      2022-03-21 10:01:07.635 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 12683
      2022-03-21 10:01:07.653 - error: tr-064.0 (12642) tr-064.0 already running
      2022-03-21 10:01:07.659 - warn: tr-064.0 (12642) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-03-21 10:01:07.894 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 12690
      2022-03-21 10:01:08.304 - info: host.raspberrypi instance system.adapter.pushover.0 started with pid 12697
      2022-03-21 10:01:11.047 - info: admin.0 (12617) Repository received successfully.
      2022-03-21 10:01:11.046 - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-03-21 10:01:11.059 - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
      2022-03-21 10:01:11.275 - error: weatherunderground.0 (12658) weatherunderground.0 already running
      2022-03-21 10:01:11.282 - warn: weatherunderground.0 (12658) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-03-21 10:01:11.401 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 12716
      2022-03-21 10:01:11.511 - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 12723
      2022-03-21 10:01:12.711 - error: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-03-21 10:01:17.801 - warn: discovery.0 (12690) slow connection to states DB. Still waiting ...
      2022-03-21 10:01:24.047 - warn: alexa2.0 (12723) slow connection to objects DB. Still waiting ...
      2022-03-21 10:01:24.287 - warn: javascript.0 (12683) slow connection to objects DB. Still waiting ...
      2022-03-21 10:01:24.555 - warn: backitup.0 (12716) slow connection to objects DB. Still waiting ...
      2022-03-21 10:01:24.847 - warn: zigbee.0 (12676) slow connection to objects DB. Still waiting ...
      2022-03-21 10:01:27.165 - info: host.raspberrypi instance scheduled system.adapter.feiertage.0 0 0 * * *
      2022-03-21 10:01:27.197 - info: host.raspberrypi instance system.adapter.feiertage.0 started with pid 12747
      2022-03-21 10:01:27.515 - error: discovery.0 (12690) discovery.0 already running
      2022-03-21 10:01:27.519 - warn: discovery.0 (12690) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-03-21 10:01:27.973 - info: host.raspberrypi instance system.adapter.cloud.0 started with pid 12754
      2022-03-21 10:01:28.006 - info: host.raspberrypi instance system.adapter.hue.0 started with pid 12760
      2022-03-21 10:01:28.256 - info: host.raspberrypi instance system.adapter.shelly.0 started with pid 12768
      2022-03-21 10:01:28.597 - info: host.raspberrypi instance system.adapter.info.0 started with pid 12775
      2022-03-21 10:01:28.646 - info: host.raspberrypi instance system.adapter.shelly.1 started with pid 12777
      2022-03-21 10:01:28.706 - info: host.raspberrypi instance system.adapter.iot.0 started with pid 12782
      2022-03-21 10:01:29.662 - error: backitup.0 (12716) backitup.0 already running
      2022-03-21 10:01:29.667 - warn: backitup.0 (12716) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-03-21 10:01:29.779 - error: host.raspberrypi instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-03-21 10:01:29.780 - info: host.raspberrypi Restart adapter system.adapter.discovery.0 because enabled
      2022-03-21 10:01:29.989 - error: zigbee.0 (12676) zigbee.0 already running
      2022-03-21 10:01:29.992 - warn: zigbee.0 (12676) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-03-21 10:01:34.664 - info: host.raspberrypi instance system.adapter.radar2.0 started with pid 12836
      2022-03-21 10:01:34.790 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-03-21 10:01:34.791 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
      2022-03-21 10:01:34.792 - error: host.raspberrypi instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-03-21 10:01:34.793 - info: host.raspberrypi Restart adapter system.adapter.backitup.0 because enabled
      2022-03-21 10:01:35.339 - info: email.0 (12636) starting. Version 1.0.10 (non-npm: iobroker-community-adapters/ioBroker.email) in /opt/iobroker/node_modules/iobroker.email, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 10:01:36.547 - info: host.raspberrypi instance system.adapter.text2command.0 started with pid 12859
      2022-03-21 10:01:37.012 - error: iot.0 (12782) iot.0 already running
      2022-03-21 10:01:37.018 - warn: iot.0 (12782) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-03-21 10:01:37.231 - error: cloud.0 (12754) cloud.0 already running
      2022-03-21 10:01:37.237 - warn: cloud.0 (12754) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-03-21 10:01:38.041 - info: history.0 (12669) starting. Version 1.11.0 in /opt/iobroker/node_modules/iobroker.history, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 10:01:38.247 - error: host.raspberrypi instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-03-21 10:01:38.248 - info: host.raspberrypi Restart adapter system.adapter.iot.0 because enabled
      2022-03-21 10:01:38.302 - error: info.0 (12775) info.0 already running
      2022-03-21 10:01:38.309 - warn: info.0 (12775) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-03-21 10:01:38.319 - info: history.0 (12669) enabled logging of zigbee.0.00158d000464c66d.humidity (Count=1), Alias=false
      2022-03-21 10:01:38.321 - info: history.0 (12669) enabled logging of zigbee.0.00158d000464c66d.pressure (Count=2), Alias=false
      2022-03-21 10:01:38.322 - info: history.0 (12669) enabled logging of zigbee.0.00158d000464c66d.temperature (Count=3), Alias=false
      2022-03-21 10:01:38.323 - info: history.0 (12669) enabled logging of zigbee.0.00158d00046611c0.humidity (Count=4), Alias=false
      2022-03-21 10:01:38.324 - info: history.0 (12669) enabled logging of zigbee.0.00158d00046611c0.pressure (Count=5), Alias=false
      2022-03-21 10:01:38.325 - info: history.0 (12669) enabled logging of zigbee.0.00158d00046611c0.temperature (Count=6), Alias=false
      2022-03-21 10:01:38.517 - error: host.raspberrypi instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-03-21 10:01:38.519 - info: host.raspberrypi Restart adapter system.adapter.cloud.0 because enabled
      2022-03-21 10:01:39.307 - info: host.raspberrypi instance scheduled system.adapter.schoolfree.0 1 0 * * *
      2022-03-21 10:01:39.337 - info: host.raspberrypi instance system.adapter.schoolfree.0 started with pid 12878
      2022-03-21 10:01:39.478 - error: host.raspberrypi instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-03-21 10:01:39.479 - info: host.raspberrypi Restart adapter system.adapter.info.0 because enabled
      2022-03-21 10:01:39.503 - error: radar2.0 (12836) radar2.0 already running
      2022-03-21 10:01:39.508 - warn: radar2.0 (12836) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-03-21 10:01:42.734 - info: host.raspberrypi Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
      2022-03-21 10:01:42.870 - error: host.raspberrypi instance system.adapter.radar2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-03-21 10:01:42.871 - info: host.raspberrypi Restart adapter system.adapter.radar2.0 because enabled
      2022-03-21 10:01:42.890 - error: text2command.0 (12859) text2command.0 already running
      2022-03-21 10:01:42.900 - warn: text2command.0 (12859) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-03-21 10:01:42.971 - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 12889
      2022-03-21 10:01:42.981 - info: pushover.0 (12697) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.pushover, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 10:01:43.568 - info: alexa2.0 (12723) starting. Version 3.12.0 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 10:01:44.384 - error: host.raspberrypi instance system.adapter.text2command.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-03-21 10:01:44.385 - info: host.raspberrypi Restart adapter system.adapter.text2command.0 because enabled
      2022-03-21 10:01:45.107 - info: javascript.0 (12683) starting. Version 5.4.5 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 10:01:47.024 - info: shelly.1 (12777) starting. Version 5.3.2 in /opt/iobroker/node_modules/iobroker.shelly, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 10:01:47.041 - info: shelly.0 (12768) starting. Version 5.3.2 in /opt/iobroker/node_modules/iobroker.shelly, node: v14.19.1, js-controller: 4.0.19
      2022-03-21 10:01:48.630 - info: alexa2.0 (12723) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2022-03-21 10:01:50.281 - info: javascript.0 (12683) requesting all states
      2022-03-21 10:01:50.283 - info: javascript.0 (12683) requesting all objects
      Aktuell läuft die CPU Last immer noch bei >100% und die Webseite vom IoBroker geht mal und mal nicht...
      T apollon77A 2 Antworten Letzte Antwort
      • T Th3RockYeah
        Teil 1
        bts LE: (),
        bts norm: ()
        at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.radar2/myNetworks.js:964:82)
        at listOnTimeout (internal/timers.js:557:17)
        at processTimers (internal/timers.js:500:7)
        T
        T
        Th3RockYeah
        @th3rockyeah
        Teil 2
        es ist fortführend...
        2022-03-21 10:03:43.856 - info: javascript.0 (12683) received all objects
        2022-03-21 10:03:45.047 - info: javascript.0 (12683) received all states
        2022-03-21 10:03:45.386 - info: javascript.0 (12683) Start javascript script.js.common.BatteryCheck
        2022-03-21 10:03:45.451 - info: host.raspberrypi instance system.adapter.radar2.0 started with pid 12924
        2022-03-21 10:03:45.514 - info: javascript.0 (12683) script.js.common.BatteryCheck: starting Batterieüberwachung V.1.8.5
        2022-03-21 10:03:45.520 - info: javascript.0 (12683) script.js.common.BatteryCheck: registered 0 subscriptions and 0 schedules
        2022-03-21 10:03:45.603 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 12930
        2022-03-21 10:03:45.683 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 12937
        2022-03-21 10:03:45.533 - info: javascript.0 (12683) Start javascript script.js.common.BewegungsmelderV2
        2022-03-21 10:03:45.561 - info: javascript.0 (12683) script.js.common.BewegungsmelderV2: *** Bewegungsmelder-Script gestartet *** Folgende Bewegungsmelder werden überwacht: BadGaeste, SchlafzimmerNew, Laundry, BadFirstFloor, FirstFloorLightNew, FirstFloorLightTom, StairsToFirstFloor, BeerCellar, ToolCellar, CellarFloor, StepToCellarFloor, AlarmTest3
        2022-03-21 10:03:45.567 - info: javascript.0 (12683) script.js.common.BewegungsmelderV2: registered 12 subscriptions and 0 schedules
        2022-03-21 10:03:45.569 - info: javascript.0 (12683) Start javascript script.js.common.CommonMix
        2022-03-21 10:03:45.577 - info: javascript.0 (12683) script.js.common.CommonMix: registered 8 subscriptions and 0 schedules
        2022-03-21 10:03:45.578 - info: javascript.0 (12683) Start javascript script.js.common.FritzBox
        2022-03-21 10:03:45.584 - info: javascript.0 (12683) script.js.common.FritzBox: registered 1 subscription and 0 schedules
        2022-03-21 10:03:45.585 - info: javascript.0 (12683) Start javascript script.js.common.LeavingHouse
        2022-03-21 10:03:45.608 - info: javascript.0 (12683) script.js.common.LeavingHouse: registered 2 subscriptions and 0 schedules
        2022-03-21 10:03:45.610 - info: javascript.0 (12683) Start javascript script.js.common.OpenDoorsWindows
        2022-03-21 10:03:45.659 - info: javascript.0 (12683) script.js.common.OpenDoorsWindows: registered 0 subscriptions and 0 schedules
        2022-03-21 10:03:45.660 - info: javascript.0 (12683) Start javascript script.js.common.Shellys
        2022-03-21 10:03:45.680 - info: javascript.0 (12683) script.js.common.Shellys: registered 9 subscriptions and 0 schedules
        2022-03-21 10:03:45.807 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 12944
        2022-03-21 10:03:45.872 - info: host.raspberrypi instance system.adapter.iot.0 started with pid 12946
        2022-03-21 10:03:45.979 - info: host.raspberrypi instance system.adapter.cloud.0 started with pid 12957
        2022-03-21 10:03:46.064 - info: host.raspberrypi instance system.adapter.info.0 started with pid 12961
        2022-03-21 10:03:46.120 - info: host.raspberrypi instance system.adapter.text2command.0 started with pid 12966
        2022-03-21 10:03:46.357 - info: javascript.0 (12683) script.js.common.OpenDoorsWindows: Alle Fenster geschlossen.
        2022-03-21 10:03:59.998 - warn: discovery.0 (12937) slow connection to objects DB. Still waiting ...
        2022-03-21 10:04:00.427 - warn: text2command.0 (12966) slow connection to objects DB. Still waiting ...
        2022-03-21 10:04:00.527 - warn: radar2.0 (12924) slow connection to objects DB. Still waiting ...
        2022-03-21 10:04:00.805 - warn: iot.0 (12946) slow connection to objects DB. Still waiting ...
        2022-03-21 10:04:00.827 - warn: backitup.0 (12944) slow connection to objects DB. Still waiting ...
        2022-03-21 10:04:00.965 - warn: cloud.0 (12957) slow connection to objects DB. Still waiting ...
        2022-03-21 10:04:02.625 - warn: info.0 (12961) slow connection to objects DB. Still waiting ...
        2022-03-21 10:04:02.633 - warn: zigbee.0 (12930) slow connection to objects DB. Still waiting ...
        2022-03-21 10:04:54.290 - info: feiertage.0 (12747) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v14.19.1, js-controller: 4.0.19
        2022-03-21 10:04:58.146 - info: feiertage.0 (12747) Next holiday: Karfreitag is in 25 days on 15.04.2022
        2022-03-21 10:04:58.476 - info: tr-064.0 (12889) starting. Version 4.2.15 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.19.1, js-controller: 4.0.19
        2022-03-21 10:04:58.744 - info: feiertage.0 (12747) adapter feiertage objects written
        2022-03-21 10:04:59.180 - info: schoolfree.0 (12878) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.schoolfree, node: v14.19.1, js-controller: 4.0.19
        2022-03-21 10:04:59.320 - info: feiertage.0 (12747) Terminated (NO_ERROR): Without reason
        2022-03-21 10:04:59.385 - info: shelly.0 (12768) Starting in CoAP mode.
        2022-03-21 10:04:59.630 - info: shelly.0 (12768) [CoAP] Listening for packets in the network
        2022-03-21 10:04:59.709 - info: shelly.1 (12777) Starting in MQTT mode. Listening on Y.X.C..31:1882
        2022-03-21 10:04:59.767 - info: radar2.0 (12924) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.radar2, node: v14.19.1, js-controller: 4.0.19
        2022-03-21 10:04:59.713 - warn: schoolfree.0 (12878) schoolfree set state error: TypeError: Cannot read property 'name' of undefined
        2022-03-21 10:05:00.167 - info: shelly.0 (12768) [CoAP] Device Y.X.C..28 (shelly1pm / shelly1pm-F27634 / SHSW-PM#F27634#1) connected! Polltime set to 5 sec.
        2022-03-21 10:05:00.437 - info: schoolfree.0 (12878) schoolfree request done
        2022-03-21 10:05:00.485 - info: shelly.0 (12768) [CoAP] Device Y.X.C..47 (shellydimmer / shellydimmer-D463D3 / SHDM-1#D463D3#1) connected! Polltime set to 5 sec.
        2022-03-21 10:05:00.754 - info: radar2.0 (12924) radar2 initialization started...
        2022-03-21 10:05:00.800 - info: radar2.0 (12924) Will use l2Ping for BT scans.
        2022-03-21 10:05:00.893 - info: radar2.0 (12924) Will run hcitool-mode and not noble on device []!
        2022-03-21 10:05:01.103 - info: host.raspberrypi instance system.adapter.feiertage.0 terminated with code 0 (NO_ERROR)
        2022-03-21 10:05:01.190 - info: radar2.0 (12924) arp-scan will use the following interfaces: [ 'eth0' ]
        2022-03-21 10:05:01.217 - info: radar2.0 (12924) Connected with '0.0.0.0' for DHCP Scan
        2022-03-21 10:05:02.201 - info: text2command.0 (12966) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.text2command, node: v14.19.1, js-controller: 4.0.19
        2022-03-21 10:05:02.412 - info: discovery.0 (12937) starting. Version 2.8.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.19.1, js-controller: 4.0.19
        2022-03-21 10:05:02.476 - info: cloud.0 (12957) starting. Version 4.1.1 in /opt/iobroker/node_modules/iobroker.cloud, node: v14.19.1, js-controller: 4.0.19
        2022-03-21 10:05:02.660 - info: zigbee.0 (12930) starting. Version 1.6.16 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.19
        2022-03-21 10:05:03.212 - info: backitup.0 (12944) starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.1, js-controller: 4.0.19
        2022-03-21 10:05:03.240 - info: cloud.0 (12957) Connecting with https://iobroker.pro:10555 with "@pro_lars@lars-keller.net_a56c8fe0-59a6-11ea-bbb9-a3d45e2d176f"
        2022-03-21 10:05:03.339 - info: iot.0 (12946) starting. Version 1.11.2 in /opt/iobroker/node_modules/iobroker.iot, node: v14.19.1, js-controller: 4.0.19
        2022-03-21 10:05:03.452 - info: backitup.0 (12944) [iobroker] backup was activated at 02:53 every 1 day(s)
        2022-03-21 10:05:03.517 - info: iot.0 (12946) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
        2022-03-21 10:05:02.984 - info: zigbee.0 (12930) Starting Zigbee npm ...
        2022-03-21 10:05:03.929 - info: shelly.0 (12768) [CoAP] Device Y.X.C..36 (shelly1 / shelly1-98F4ABF3CF6C / SHSW-1#98F4ABF3CF6C#1) connected! Polltime set to 5 sec.
        2022-03-21 10:05:04.474 - info: iot.0 (12946) Connection changed: connect
        2022-03-21 10:05:04.982 - info: zigbee.0 (12930) Installed Version: ioBroker/ioBroker.zigbee
        2022-03-21 10:05:05.086 - info: shelly.0 (12768) [CoAP] Device Y.X.C..67 (shellydimmer / shellydimmer-D3E31B / SHDM-1#D3E31B#1) connected! Polltime set to 5 sec.
        2022-03-21 10:05:05.100 - info: cloud.0 (12957) Trying to connect as system.user.admin
        2022-03-21 10:05:05.152 - info: zigbee.0 (12930) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20211217}}
        2022-03-21 10:05:05.171 - info: zigbee.0 (12930) Unable to disable LED, unsupported function.
        2022-03-21 10:05:05.181 - info: shelly.0 (12768) [CoAP] Device Y.X.C..44 (shellyplug-s / shellyplug-s-DE15FC / SHPLG-S#DE15FC#1) connected! Polltime set to 5 sec.
        2022-03-21 10:05:05.224 - info: zigbee.0 (12930) --> transmitPower : normal
        2022-03-21 10:05:05.254 - info: zigbee.0 (12930) Currently 53 devices are joined:
        2022-03-21 10:05:05.568 - error: backitup.0 (12944) Error: Command failed: sudo mount -t cifs -o username=iobrokerUser,password=****,rw,file_mode=0777,dir_mode=0777 //Y.X.C..109/ioBrokerBackup/ioBroker /opt/iobroker/backups
        mount error(16): Device or resource busy
        Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
        2022-03-21 10:05:05.619 - info: shelly.0 (12768) [CoAP] Device Y.X.C..32 (shellyplug-s / shellyplug-s-8D010E / SHPLG-S#8D010E#1) connected! Polltime set to 5 sec.
        2022-03-21 10:05:05.977 - info: zigbee.0 (12930) 0x00158d0007b7ddc0 (addr 51404): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
        2022-03-21 10:05:05.979 - info: zigbee.0 (12930) 0x000d6ffffea61fe1 (addr 8521): E1746 - IKEA TRADFRI signal repeater (Router)
        2022-03-21 10:05:05.980 - info: zigbee.0 (12930) Zigbee started
        2022-03-21 10:05:06.418 - info: shelly.0 (12768) [CoAP] Device Y.X.C..30 (shelly1 / shelly1-767AC8 / SHSW-1#767AC8#1) connected! Polltime set to 5 sec.
        2022-03-21 10:05:07.055 - info: shelly.0 (12768) [CoAP] Device Y.X.C..33 (shellyplug-s / shellyplug-s-80116A / SHPLG-S#80116A#1) connected! Polltime set to 5 sec.
        2022-03-21 10:05:07.606 - warn: zigbee.0 (12930) DeviceAvailability:Failed to ping 0x680ae2fffe9c8577 TRADFRI Signal Repeater
        2022-03-21 10:05:07.612 - warn: zigbee.0 (12930) DeviceAvailability:Failed to ping 0x000d6ffffe2e4a54 TRADFRI signal repeater
        2022-03-21 10:05:08.159 - info: shelly.1 (12777) [MQTT] Device Y.X.C..104 (shellyplus1 / shellyplus1-a8032abeb1e4 / shellyplus1#a8032abeb1e4#1) connected! Polltime set to 5 sec.
        2022-03-21 10:05:08.487 - info: shelly.0 (12768) [CoAP] Device Y.X.C..110 (shellyplug-s / shellyplug-s-4BA36E / SHPLG2-1#4BA36E#1) connected! Polltime set to 5 sec.
        2022-03-21 10:05:08.734 - info: radar2.0 (12924) Init item YYYY with {name: 'YYYY',bluetooth: [],enabled: -1,id: 'YYYY',type: 'IP',hasMAC: [ '9a:ce:10:0a:71:2e' ],ipVendor: 'N/A',rip: [ 'Y.X.C..114' ],lasthere: '2022-03-21T05:14:19.102Z'}
        2022-03-21 10:05:08.998 - error: cloud.0 (12957) Cloud says: timeout
        2022-03-21 10:05:09.496 - info: shelly.0 (12768) [CoAP] Device Y.X.C..38 (shellydimmer2 / shellydimmer2-D8BFC019EECE / SHDM-2#D8BFC019EECE#1) connected! Polltime set to 5 sec.
        2022-03-21 10:05:10.005 - info: cloud.0 (12957) Connection changed: io server disconnect
        2022-03-21 10:05:10.505 - info: shelly.0 (12768) [CoAP] Device Y.X.C..29 (shelly1pm / shelly1pm-F27119 / SHSW-PM#F27119#1) connected! Polltime set to 5 sec.
        2022-03-21 10:05:10.772 - info: info.0 (12961) starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v14.19.1, js-controller: 4.0.19
        2022-03-21 10:05:11.032 - info: info.0 (12961) Reading/updating systemdata.
        2022-03-21 10:05:13.277 - info: shelly.0 (12768) [CoAP] Device Y.X.C..98 (shellyplug-s / shellyplug-s-E435C4 / SHPLG-S#E435C4#1) connected! Polltime set to 5 sec.
        2022-03-21 10:05:13.542 - info: shelly.0 (12768) [CoAP] Device Y.X.C..39 (shellyplug-s / shellyplug-s-B4B41F / SHPLG-S#B4B41F#1) connected! Polltime set to 5 sec.
        2022-03-21 10:05:14.158 - info: shelly.0 (12768) [CoAP] Device Y.X.C..24 (shellyplug-s / shellyplug-s-577BFA / SHPLG-S#577BFA#1) connected! Polltime set to 5 sec.
        2022-03-21 10:05:14.529 - info: info.0 (12961) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
        2022-03-21 10:05:15.380 - info: info.0 (12961) State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
        2022-03-21 10:05:15.533 - info: info.0 (12961) State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
        2022-03-21 10:05:15.621 - info: info.0 (12961) State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
        2022-03-21 10:05:15.725 - info: info.0 (12961) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
        2022-03-21 10:05:16.578 - info: info.0 (12961) cpu Temp res = {"main":75.471,"cores":[],"max":75.471,"socket":[],"chipset":null}
        2022-03-21 10:05:17.656 - info: info.0 (12961) State value to set for "info.0.sysinfo.memory.memLayout.ram0.ecc" has to be stringified but received type "boolean"
        2022-03-21 10:05:18.108 - info: radar2.0 (12924) Init item XXX with {name: 'XXX',bluetooth: [],enabled: -1,id: 'XXX',type: 'IP',hasMAC: [ 'IPV6' ],ipVendor: 'N/A',rip: [ 'Y.X.C.V' ],lasthere: '2021-12-14T03:02:35.263Z'}
        2022-03-21 10:05:18.497 - info: radar2.0 (12924) Init item CCC with {name: 'CCC',bluetooth: [],enabled: -1,id: 'CCC',type: 'IP',hasMAC: [ 'IPV6' ],ipVendor: 'N/A',rip: [ 'Y.X.C.V' ],lasthere: '2022-03-21T08:59:12.329Z'}
        2022-03-21 10:05:18.501 - info: radar2.0 (12924) Adapter identified macs: (IPV6),
        ips: (Y.X.C.V,Y.X.C.V,Y.X.C.V),
        bts LE: (),
        bts norm: ()
        2022-03-21 10:05:18.828 - info: radar2.0 (12924) radar2 found 3 devices in config (XXX,YYY,CCC) and 3 enabled.
        2022-03-21 10:05:18.830 - info: radar2.0 (12924) radar2 set use of noble(false), doArp("-lgq --retry=5 --timeout=400" on eth0), btid(-1) and doUwz(undefined,30,0,de,true).
        2022-03-21 10:05:31.945 - info: schoolfree.0 (12878) Terminated (NO_ERROR): Without reason
        2022-03-21 10:05:38.446 - error: cloud.0 (12957) Cloud says: timeout
        2022-03-21 10:06:08.453 - error: cloud.0 (12957) Cloud says: timeout
        2022-03-21 10:06:38.469 - error: cloud.0 (12957) Cloud says: timeout
        2022-03-21 10:06:41.946 - warn: schoolfree.0 (12878) get state error: Connection is closed.
        2022-03-21 10:06:41.948 - warn: schoolfree.0 (12878) get state error: DB closed
        2022-03-21 10:06:41.949 - warn: schoolfree.0 (12878) get state error: DB closed
        2022-03-21 10:06:41.950 - warn: schoolfree.0 (12878) get state error: DB closed
        2022-03-21 10:06:41.951 - warn: schoolfree.0 (12878) get state error: DB closed
        2022-03-21 10:06:41.952 - warn: schoolfree.0 (12878) get state error: DB closed
        2022-03-21 10:06:41.953 - warn: schoolfree.0 (12878) get state error: DB closed
        2022-03-21 10:06:41.954 - warn: schoolfree.0 (12878) get state error: DB closed
        2022-03-21 10:06:41.955 - warn: schoolfree.0 (12878) get state error: DB closed
        2022-03-21 10:06:41.956 - warn: schoolfree.0 (12878) get state error: DB closed
        2022-03-21 10:06:43.427 - info: cloud.0 (12957) Trying to connect as system.user.admin
        2022-03-21 10:06:43.429 - info: cloud.0 (12957) Trying to connect as system.user.admin
        2022-03-21 10:06:43.431 - info: cloud.0 (12957) Trying to connect as system.user.admin
        2022-03-21 10:06:43.874 - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 13310
        2022-03-21 10:06:44.533 - info: host.raspberrypi instance system.adapter.schoolfree.0 terminated with code 0 (NO_ERROR)
        2022-03-21 10:06:47.598 - info: radar2.0 (12924) first scan took 88.765 seconds
        2022-03-21 10:06:47.601 - warn: radar2.0 (12924) scanDelay increased to 90.765 seconds, delayAway to 4 minutes!
        2022-03-21 10:06:48.192 - info: weatherunderground.0 (13310) starting. Version 3.4.1 (non-npm: iobroker-community-adapters/ioBroker.weatherunderground) in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v14.19.1, js-controller: 4.0.19
        2022-03-21 10:06:48.209 - info: radar2.0 (12924) Adapter initialization finished!
        2022-03-21 10:07:03.303 - info: cloud.0 (12957) Trying to connect as system.user.admin
        2022-03-21 10:07:03.460 - info: cloud.0 (12957) Connection changed: connect
        2022-03-21 10:07:03.494 - info: cloud.0 (12957) Adapter redirected temporally to "https://iobroker.pro:10556" in 30 seconds. Reason: command from server
        2022-03-21 10:07:05.559 - error: backitup.0 (12944) umount: /opt/iobroker/backups: not mounted.
        2022-03-21 10:10:20.992 - info: cloud.0 (12957) Trying to connect as system.user.admin
        2022-03-21 10:10:20.994 - info: cloud.0 (12957) Trying to connect as system.user.admin
        2022-03-21 10:10:20.995 - info: cloud.0 (12957) Trying to connect as system.user.admin
        2022-03-21 10:27:49.612 - info: cloud.0 (12957) Trying to connect as system.user.admin
        2022-03-21 10:27:49.615 - info: cloud.0 (12957) Trying to connect as system.user.admin
        2022-03-21 10:27:49.616 - info: cloud.0 (12957) Trying to connect as system.user.admin
        2022-03-21 10:29:04.597 - info: cloud.0 (12957) Trying to connect as system.user.admin
        2022-03-21 10:29:05.276 - info: cloud.0 (12957) Connection changed: connect
        2022-03-21 10:29:15.627 - error: info.0 (12961) States database error: read ECONNRESET
        2022-03-21 10:29:15.609 - error: alexa2.0 (12723) States database error: read ECONNRESET
        2022-03-21 10:29:15.625 - error: weatherunderground.0 (13310) States database error: read ECONNRESET
        2022-03-21 10:29:15.630 - error: discovery.0 (12937) States database error: read ECONNRESET
        2022-03-21 10:29:15.628 - error: shelly.1 (12777) States database error: read ECONNRESET
        2022-03-21 10:29:15.629 - error: text2command.0 (12966) States database error: read ECONNRESET
        2022-03-21 10:29:15.609 - error: zigbee.0 (12930) States database error: read ECONNRESET
        2022-03-21 10:29:15.632 - error: email.0 (12636) States database error: read ECONNRESET
        2022-03-21 10:29:15.640 - error: history.0 (12669) States database error: read ECONNRESET
        2022-03-21 10:29:15.624 - error: pushover.0 (12697) States database error: read ECONNRESET
        2022-03-21 10:29:15.631 - error: tr-064.0 (12889) States database error: read ECONNRESET
        2022-03-21 10:29:15.633 - error: cloud.0 (12957) States database error: read ECONNRESET
        2022-03-21 10:29:15.684 - error: alexa2.0 (12723) Objects database error: read ECONNRESET
        2022-03-21 10:29:15.684 - error: shelly.1 (12777) Objects database error: read ECONNRESET
        2022-03-21 10:29:15.633 - error: backitup.0 (12944) States database error: read ECONNRESET
        2022-03-21 10:29:15.693 - error: zigbee.0 (12930) Objects database error: read ECONNRESET
        2022-03-21 10:29:15.644 - error: radar2.0 (12924) States database error: write ECONNRESET
        2022-03-21 10:29:15.697 - error: weatherunderground.0 (13310) Objects database error: read ECONNRESET
        2022-03-21 10:29:15.634 - error: hue.0 (12760) States database error: read ECONNRESET
        2022-03-21 10:29:15.714 - error: cloud.0 (12957) Objects database error: read ECONNRESET
        2022-03-21 10:29:15.640 - error: iot.0 (12946) States database error: read ECONNRESET
        2022-03-21 10:29:15.913 - info: zigbee.0 (12930) cleaned everything up...
        2022-03-21 10:29:15.910 - info: info.0 (12961) cleaned everything up...
        2022-03-21 10:29:15.912 - info: backitup.0 (12944) cleaned everything up...
        2022-03-21 10:29:15.914 - info: shelly.1 (12777) Closing Adapter
        2022-03-21 10:29:15.923 - error: shelly.0 (12768) Objects database error: write ECONNRESET
        2022-03-21 10:29:15.942 - error: shelly.0 (12768) States database error: read ECONNRESET
        2022-03-21 10:29:15.957 - info: cloud.0 (12957) Connection changed: io client disconnect
        2022-03-21 10:29:15.958 - info: cloud.0 (12957) Connection lost
        2022-03-21 10:29:15.953 - info: shelly.0 (12768) Closing Adapter
        2022-03-21 10:29:16.073 - info: iot.0 (12946) Connection changed: disconnect
        2022-03-21 10:29:16.075 - info: iot.0 (12946) Connection lost
        2022-03-21 10:29:16.089 - info: radar2.0 (12924) Unload adapter now with null
        2022-03-21 10:29:16.091 - info: radar2.0 (12924) Adapter disconnected and stopped with dostop(null) and callback(true)
        2022-03-21 10:29:16.163 - info: zigbee.0 (12930) Zigbee: disabling joining new devices.
        2022-03-21 10:29:16.134 - error: admin.0 (12617) States database error: read ECONNRESET
        2022-03-21 10:29:16.269 - error: javascript.0 (12683) States database error: write ECONNRESET
        2022-03-21 10:29:16.274 - error: javascript.0 (12683) Objects database error: read ECONNRESET
        2022-03-21 10:29:16.280 - info: javascript.0 (12683) Stop script script.js.common.BatteryCheck
        2022-03-21 10:29:16.284 - info: javascript.0 (12683) Stop script script.js.common.BewegungsmelderV2
        2022-03-21 10:29:16.286 - info: javascript.0 (12683) Stop script script.js.common.CommonMix
        2022-03-21 10:29:16.287 - info: javascript.0 (12683) Stop script script.js.common.FritzBox
        2022-03-21 10:29:16.287 - info: javascript.0 (12683) Stop script script.js.common.LeavingHouse
        2022-03-21 10:29:16.288 - info: javascript.0 (12683) Stop script script.js.common.OpenDoorsWindows
        2022-03-21 10:29:16.290 - info: javascript.0 (12683) Stop script script.js.common.Shellys
        2022-03-21 10:29:16.230 - error: admin.0 (12617) Objects database error: read ECONNRESET
        2022-03-21 10:29:16.334 - info: admin.0 (12617) terminating http server on port 8081
        2022-03-21 10:29:16.928 - error: radar2.0 (12924) uncaught exception: Cannot read property 'init' of null
        2022-03-21 10:29:16.929 - error: radar2.0 (12924) TypeError: Cannot read property 'init' of null
        2022-03-21 10:29:16.930 - error: radar2.0 (12924) Cannot read property 'init' of null
        2022-03-21 10:29:16.931 - warn: radar2.0 (12924) Uncaught Exception: Cannot read property 'init' of null
        2022-03-21 10:29:17.409 - info: email.0 (12636) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-21 10:29:17.412 - info: discovery.0 (12937) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-21 10:29:17.414 - info: weatherunderground.0 (13310) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-21 10:29:17.414 - info: pushover.0 (12697) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-21 10:29:17.415 - info: text2command.0 (12966) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-21 10:29:17.418 - info: info.0 (12961) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-21 10:29:17.418 - info: zigbee.0 (12930) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-21 10:29:17.420 - info: backitup.0 (12944) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-21 10:29:17.423 - info: tr-064.0 (12889) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-21 10:29:17.423 - info: shelly.1 (12777) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-21 10:29:17.433 - info: iot.0 (12946) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-21 10:29:17.457 - info: shelly.0 (12768) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-21 10:29:17.462 - info: cloud.0 (12957) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-21 10:29:17.463 - info: alexa2.0 (12723) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-21 10:29:17.589 - info: radar2.0 (12924) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-21 10:29:17.780 - info: javascript.0 (12683) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-21 10:29:17.847 - info: admin.0 (12617) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-21 10:29:20.699 - error: shelly.1 (12777) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
        2022-03-21 10:29:20.702 - warn: info.0 (12961) get state error: DB closed
        2022-03-21 10:29:20.717 - error: discovery.0 (12937) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
        2022-03-21 10:29:20.724 - error: alexa2.0 (12723) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
        2022-03-21 10:29:20.751 - error: weatherunderground.0 (13310) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
        2022-03-21 10:29:20.753 - error: backitup.0 (12944) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
        2022-03-21 10:29:20.767 - error: zigbee.0 (12930) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
        2022-03-21 10:29:20.749 - warn: radar2.0 (12924) get state error: Connection is closed.
        2022-03-21 10:29:20.753 - error: hue.0 (12760) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
        2022-03-21 10:29:20.763 - error: cloud.0 (12957) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
        2022-03-21 10:29:20.775 - warn: tr-064.0 (12889) get state error: DB closed
        2022-03-21 10:29:20.797 - warn: email.0 (12636) get state error: DB closed
        2022-03-21 10:29:20.710 - warn: shelly.1 (12777) get state error: DB closed
        2022-03-21 10:29:20.807 - warn: pushover.0 (12697) get state error: DB closed
        2022-03-21 10:29:20.816 - error: text2command.0 (12966) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
        2022-03-21 10:29:20.849 - error: history.0 (12669) States database error: connect ECONNREFUSED 127.0.0.1:9000
        2022-03-21 10:29:20.884 - warn: weatherunderground.0 (13310) get state error: DB closed
        2022-03-21 10:29:20.887 - error: history.0 (12669) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
        2022-03-21 10:29:20.920 - error: iot.0 (12946) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
        2022-03-21 10:29:20.947 - error: shelly.0 (12768) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
        2022-03-21 10:29:20.992 - warn: shelly.0 (12768) get state error: Connection is closed.
        2022-03-21 10:29:20.798 - warn: shelly.1 (12777) get state error: DB closed
        2022-03-21 10:29:20.845 - warn: shelly.1 (12777) redis get shelly.1.SHPLG-S#C383EB#1.online, error - DB closed
        2022-03-21 10:29:20.846 - warn: shelly.1 (12777) get state error: DB closed
        2022-03-21 10:29:20.847 - warn: shelly.1 (12777) get state error: DB closed
        2022-03-21 10:29:20.961 - warn: shelly.1 (12777) get state error: DB closed
        2022-03-21 10:29:20.962 - warn: shelly.1 (12777) get state error: DB closed
        2022-03-21 10:29:20.982 - warn: shelly.1 (12777) redis get shelly.1.SHSW-1#98F4ABF3CF6C#1.hostname, error - DB closed
        2022-03-21 10:29:20.983 - warn: shelly.1 (12777) redis get shelly.1.SHPLG-S#DE15FC#1.online, error - DB closed
        2022-03-21 10:29:20.984 - warn: shelly.1 (12777) get state error: DB closed
        2022-03-21 10:29:20.985 - warn: shelly.1 (12777) get state error: DB closed
        2022-03-21 10:29:20.986 - warn: shelly.1 (12777) get state error: DB closed
        2022-03-21 10:29:20.987 - warn: shelly.1 (12777) get state error: DB closed
        2022-03-21 10:29:20.988 - warn: shelly.1 (12777) get state error: DB closed
        2022-03-21 10:29:20.989 - warn: shelly.1 (12777) get state error: DB closed
        2022-03-21 10:29:21.085 - warn: shelly.1 (12777) redis get shelly.1.SHSW-PM#F27119#1.hostname, error - Connection is closed.
        2022-03-21 10:29:21.125 - warn: shelly.1 (12777) redis get shelly.1.SHSW-PM#F27634#1.hostname, error - Connection is closed.
        2022-03-21 10:29:21.127 - warn: shelly.1 (12777) redis get shelly.1.shellyplus1#a8032abeb1e4#1.hostname, error - Connection is closed.
        2022-03-21 10:29:21.140 - warn: shelly.1 (12777) redis get shelly.1.undefined#undefined#1.hostname, error - Connection is closed.
        2022-03-21 10:29:21.151 - warn: shelly.1 (12777) setTimeout called, but adapter is shutting down
        2022-03-21 10:29:20.969 - warn: iot.0 (12946) get state error: DB closed
        2022-03-21 10:29:20.970 - warn: iot.0 (12946) get state error: DB closed
        2022-03-21 10:29:20.972 - warn: iot.0 (12946) get state error: DB closed
        2022-03-21 10:29:21.263 - warn: iot.0 (12946) get state error: DB closed
        2022-03-21 10:29:21.264 - warn: iot.0 (12946) get state error: DB closed
        2022-03-21 10:29:21.265 - warn: iot.0 (12946) get state error: DB closed
        2022-03-21 10:29:21.266 - warn: iot.0 (12946) get state error: DB closed
        2022-03-21 10:29:21.367 - error: javascript.0 (12683) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
        2022-03-21 10:29:21.417 - error: admin.0 (12617) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
        2022-03-21 10:29:20.993 - warn: shelly.0 (12768) get state error: DB closed
        2022-03-21 10:29:21.687 - warn: shelly.0 (12768) redis get shelly.0.SHPLG-S#DE15FC#1.online, error - DB closed
        2022-03-21 10:29:21.688 - warn: shelly.0 (12768) get state error: DB closed
        2022-03-21 10:29:21.689 - warn: shelly.0 (12768) get state error: DB closed
        2022-03-21 10:29:21.690 - warn: shelly.0 (12768) get state error: DB closed
        2022-03-21 10:29:21.690 - warn: shelly.0 (12768) redis get shelly.0.SHPLG-S#C383EB#1.online, error - DB closed
        2022-03-21 10:29:21.691 - warn: shelly.0 (12768) get state error: DB closed
        2022-03-21 10:29:21.715 - warn: shelly.0 (12768) get state error: DB closed
        2022-03-21 10:29:21.717 - warn: shelly.0 (12768) redis get shelly.0.SHSW-1#767AC8#1.hostname, error - DB closed
        2022-03-21 10:29:21.720 - warn: shelly.0 (12768) get state error: DB closed
        2022-03-21 10:29:21.721 - warn: shelly.0 (12768) get state error: DB closed
        2022-03-21 10:29:21.914 - warn: shelly.0 (12768) get state error: DB closed
        2022-03-21 10:29:21.915 - warn: shelly.0 (12768) get state error: DB closed
        2022-03-21 10:29:22.093 - warn: shelly.0 (12768) redis get shelly.0.SHSW-1#98F4ABF3CF6C#1.hostname, error - Connection is closed.
        2022-03-21 10:29:22.115 - warn: shelly.0 (12768) redis get shelly.0.SHSW-PM#F27119#1.hostname, error - Connection is closed.
        2022-03-21 10:29:22.117 - warn: shelly.0 (12768) redis get shelly.0.SHSW-PM#F27634#1.hostname, error - Connection is closed.
        2022-03-21 10:29:22.119 - warn: shelly.0 (12768) setTimeout called, but adapter is shutting down
        2022-03-21 10:29:25.704 - error: shelly.1 (12777) Cannot find view "system" for search "device" : Connection is closed.
        2022-03-21 10:29:25.911 - error: history.0 (12669) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
        2022-03-21 10:29:25.915 - error: history.0 (12669) States database error: connect ECONNREFUSED 127.0.0.1:9000
        2022-03-21 10:29:25.952 - error: shelly.0 (12768) Cannot find view "system" for search "device" : DB closed
        2022-03-21 10:29:27.034 - info: history.0 (12669) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-21 10:29:30.927 - error: history.0 (12669) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
        2022-03-21 10:29:36.867 - info: host.raspberrypi iobroker.js-controller version 4.0.19 js-controller starting
        2022-03-21 10:29:36.875 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2022-03-21 10:29:36.876 - info: host.raspberrypi hostname: raspberrypi, node: v14.19.1
        2022-03-21 10:29:36.876 - info: host.raspberrypi ip addresses: Y.X.C.V IPV6
        2022-03-21 10:29:38.900 - info: host.raspberrypi connected to Objects and States
        2022-03-21 10:29:38.972 - info: host.raspberrypi added notifications configuration of host
        2022-03-21 10:29:39.802 - info: host.raspberrypi 32 instances found
        2022-03-21 10:29:39.863 - info: host.raspberrypi starting 21 instances
        2022-03-21 10:29:40.093 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 13720
        2022-03-21 10:29:42.077 - error: admin.0 (13720) admin.0 already running
        2022-03-21 10:29:42.081 - warn: admin.0 (13720) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2022-03-21 10:29:42.717 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2022-03-21 10:29:42.718 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
        2022-03-21 10:29:43.901 - info: host.raspberrypi instance system.adapter.email.0 started with pid 13731
        2022-03-21 10:29:45.441 - error: email.0 (13731) email.0 already running
        2022-03-21 10:29:45.445 - warn: email.0 (13731) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2022-03-21 10:29:46.064 - error: host.raspberrypi instance system.adapter.email.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2022-03-21 10:29:46.065 - info: host.raspberrypi Restart adapter system.adapter.email.0 because enabled
        2022-03-21 10:29:48.020 - info: host.raspberrypi instance system.adapter.history.0 started with pid 13743
        2022-03-21 10:29:49.579 - error: history.0 (13743) history.0 already running
        2022-03-21 10:29:49.583 - warn: history.0 (13743) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2022-03-21 10:29:50.203 - error: host.raspberrypi instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2022-03-21 10:29:50.205 - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
        2022-03-21 10:29:51.992 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 13755
        2022-03-21 10:29:55.495 - error: javascript.0 (13755) javascript.0 already running
        2022-03-21 10:29:55.499 - warn: javascript.0 (13755) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2022-03-21 10:29:55.983 - info: host.raspberrypi instance system.adapter.pushover.0 started with pid 13766
        2022-03-21 10:29:56.133 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2022-03-21 10:29:56.134 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
        2022-03-21 10:29:57.600 - error: pushover.0 (13766) pushover.0 already running
        2022-03-21 10:29:57.604 - warn: pushover.0 (13766) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2022-03-21 10:29:58.272 - error: host.raspberrypi instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2022-03-21 10:29:58.273 - info: host.raspberrypi Restart adapter system.adapter.pushover.0 because enabled
        2022-03-21 10:29:59.978 - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 13777
        2022-03-21 10:30:01.640 - error: alexa2.0 (13777) alexa2.0 already running
        2022-03-21 10:30:01.644 - warn: alexa2.0 (13777) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2022-03-21 10:30:02.263 - error: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2022-03-21 10:30:02.264 - info: host.raspberrypi Restart adapter system.adapter.alexa2.0 because enabled
        2022-03-21 10:30:04.036 - info: host.raspberrypi instance system.adapter.hue.0 started with pid 13788
        2022-03-21 10:30:05.962 - error: hue.0 (13788) hue.0 already running
        2022-03-21 10:30:06.590 - error: host.raspberrypi instance system.adapter.hue.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2022-03-21 10:30:06.590 - info: host.raspberrypi Restart adapter system.adapter.hue.0 because enabled
        2022-03-21 10:30:08.001 - info: host.raspberrypi instance system.adapter.shelly.0 started with pid 13799
        2022-03-21 10:30:10.386 - error: shelly.0 (13799) shelly.0 already running
        2022-03-21 10:30:10.390 - warn: shelly.0 (13799) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2022-03-21 10:30:11.012 - error: host.raspberrypi instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2022-03-21 10:30:11.012 - info: host.raspberrypi Restart adapter system.adapter.shelly.0 because enabled
        2022-03-21 10:30:11.987 - info: host.raspberrypi instance system.adapter.shelly.1 started with pid 13810
        2022-03-21 10:30:12.836 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 13817
        2022-03-21 10:30:14.257 - error: shelly.1 (13810) shelly.1 already running
        2022-03-21 10:30:14.262 - warn: shelly.1 (13810) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2022-03-21 10:30:15.043 - error: host.raspberrypi instance system.adapter.shelly.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2022-03-21 10:30:15.044 - info: host.raspberrypi Restart adapter system.adapter.shelly.1 because enabled
        2022-03-21 10:30:15.288 - info: admin.0 (13817) starting. Version 5.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.1, js-controller: 4.0.19
        2022-03-21 10:30:15.336 - info: admin.0 (13817) requesting all states
        2022-03-21 10:30:15.337 - info: admin.0 (13817) requesting all objects
        2022-03-21 10:30:16.895 - info: host.raspberrypi instance system.adapter.email.0 started with pid 13836
        2022-03-21 10:30:16.978 - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 13843
        2022-03-21 10:30:17.468 - info: admin.0 (13817) received all objects
        2022-03-21 10:30:18.021 - info: admin.0 (13817) Request actual repository...
        2022-03-21 10:30:18.051 - info: admin.0 (13817) http server listening on port 8081
        2022-03-21 10:30:18.053 - info: admin.0 (13817) Use link "http://localhost:8081" to configure.
        2022-03-21 10:30:18.927 - info: host.raspberrypi Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
        2022-03-21 10:30:19.880 - error: tr-064.0 (13843) tr-064.0 already running
        2022-03-21 10:30:19.884 - warn: tr-064.0 (13843) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2022-03-21 10:30:20.369 - info: host.raspberrypi instance scheduled system.adapter.weatherunderground.0 6 * * * *
        2022-03-21 10:30:20.399 - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 13858
        2022-03-21 10:30:23.820 - info: admin.0 (13817) Repository received successfully.
        2022-03-21 10:30:24.716 - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2022-03-21 10:30:24.717 - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
        2022-03-21 10:30:24.752 - info: host.raspberrypi instance system.adapter.history.0 started with pid 13869
        2022-03-21 10:30:24.849 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 13875
        2022-03-21 10:30:24.969 - error: weatherunderground.0 (13858) weatherunderground.0 already running
        2022-03-21 10:30:24.974 - warn: weatherunderground.0 (13858) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2022-03-21 10:30:25.084 - info: email.0 (13836) starting. Version 1.0.10 (non-npm: iobroker-community-adapters/ioBroker.email) in /opt/iobroker/node_modules/iobroker.email, node: v14.19.1, js-controller: 4.0.19
        2022-03-21 10:30:25.651 - error: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2022-03-21 10:30:26.272 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 13891
        • T Th3RockYeah
          @apollon77 Ich habe "iob stop" gecheckt, ob ein Prozess läuft (top) und dann "iob start" gemacht.
          Folgende Logs sind dabei entstanden. Ich habe es leicht modifiziert, sry long read
          Teil 1
          2022-03-21 09:45:09.742 - info: host.raspberrypi All instances are stopped.
          2022-03-21 09:45:09.822 - info: host.raspberrypi terminated
          2022-03-21 09:46:22.398 - info: host.raspberrypi iobroker.js-controller version 4.0.19 js-controller starting
          2022-03-21 09:46:22.406 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
          2022-03-21 09:46:22.407 - info: host.raspberrypi hostname: raspberrypi, node: v14.19.1
          2022-03-21 09:46:22.407 - info: host.raspberrypi ip addresses: Y.X.C.V.31 IPV6Adree
          2022-03-21 09:46:24.089 - info: host.raspberrypi connected to Objects and States
          2022-03-21 09:46:24.142 - info: host.raspberrypi added notifications configuration of host
          2022-03-21 09:46:24.829 - info: host.raspberrypi 32 instances found
          2022-03-21 09:46:24.910 - info: host.raspberrypi starting 21 instances
          2022-03-21 09:46:25.101 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 11936
          2022-03-21 09:46:27.499 - info: admin.0 (11936) starting. Version 5.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 09:46:27.551 - info: admin.0 (11936) requesting all states
          2022-03-21 09:46:27.551 - info: admin.0 (11936) requesting all objects
          2022-03-21 09:46:29.062 - info: host.raspberrypi instance system.adapter.email.0 started with pid 11952
          2022-03-21 09:46:29.687 - info: admin.0 (11936) received all objects
          2022-03-21 09:46:30.072 - info: admin.0 (11936) Request actual repository...
          2022-03-21 09:46:30.119 - info: admin.0 (11936) http server listening on port 8081
          2022-03-21 09:46:30.120 - info: admin.0 (11936) Use link "http://localhost:8081" to configure.
          2022-03-21 09:46:31.362 - info: host.raspberrypi Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
          2022-03-21 09:46:32.537 - info: email.0 (11952) starting. Version 1.0.10 (non-npm: iobroker-community-adapters/ioBroker.email) in /opt/iobroker/node_modules/iobroker.email, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 09:46:33.032 - info: host.raspberrypi instance system.adapter.history.0 started with pid 11967
          2022-03-21 09:46:34.715 - info: admin.0 (11936) Repository received successfully.
          2022-03-21 09:46:37.145 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 11978
          2022-03-21 09:46:38.026 - info: history.0 (11967) starting. Version 1.11.0 in /opt/iobroker/node_modules/iobroker.history, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 09:46:38.196 - info: history.0 (11967) enabled logging of zigbee.0.00158d000464c66d.humidity (Count=1), Alias=false
          2022-03-21 09:46:38.197 - info: history.0 (11967) enabled logging of zigbee.0.00158d000464c66d.pressure (Count=2), Alias=false
          2022-03-21 09:46:38.198 - info: history.0 (11967) enabled logging of zigbee.0.00158d000464c66d.temperature (Count=3), Alias=false
          2022-03-21 09:46:38.199 - info: history.0 (11967) enabled logging of zigbee.0.00158d00046611c0.humidity (Count=4), Alias=false
          2022-03-21 09:46:38.200 - info: history.0 (11967) enabled logging of zigbee.0.00158d00046611c0.pressure (Count=5), Alias=false
          2022-03-21 09:46:38.201 - info: history.0 (11967) enabled logging of zigbee.0.00158d00046611c0.temperature (Count=6), Alias=false
          2022-03-21 09:46:49.318 - info: host.raspberrypi instance system.adapter.pushover.0 started with pid 11993
          2022-03-21 09:46:49.399 - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 11999
          2022-03-21 09:46:49.458 - info: host.raspberrypi instance system.adapter.hue.0 started with pid 12002
          2022-03-21 09:46:59.263 - info: host.raspberrypi instance system.adapter.shelly.0 started with pid 12026
          2022-03-21 09:46:59.304 - info: host.raspberrypi instance system.adapter.shelly.1 started with pid 12028
          2022-03-21 09:47:00.880 - info: javascript.0 (11978) starting. Version 5.4.5 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 09:47:01.255 - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 12044
          2022-03-21 09:47:02.757 - info: pushover.0 (11993) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.pushover, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 09:47:02.893 - info: alexa2.0 (11999) starting. Version 3.12.0 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 09:47:03.931 - info: javascript.0 (11978) requesting all states
          2022-03-21 09:47:03.933 - info: javascript.0 (11978) requesting all objects
          2022-03-21 09:47:06.148 - info: host.raspberrypi instance scheduled system.adapter.weatherunderground.0 6 * * * *
          2022-03-21 09:47:06.186 - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 12075
          2022-03-21 09:47:06.353 - info: javascript.0 (11978) received all objects
          2022-03-21 09:47:06.572 - info: javascript.0 (11978) received all states
          2022-03-21 09:47:07.197 - info: alexa2.0 (11999) Alexa-Push-Connection (macDms = true) established. Disable Polling
          2022-03-21 09:47:07.227 - info: javascript.0 (11978) Start javascript script.js.common.BatteryCheck
          2022-03-21 09:47:07.400 - info: javascript.0 (11978) script.js.common.BatteryCheck: starting Batterieüberwachung V.1.8.5
          2022-03-21 09:47:07.417 - info: javascript.0 (11978) script.js.common.BatteryCheck: registered 0 subscriptions and 0 schedules
          2022-03-21 09:47:07.450 - info: javascript.0 (11978) Start javascript script.js.common.BewegungsmelderV2
          2022-03-21 09:47:07.476 - info: javascript.0 (11978) script.js.common.BewegungsmelderV2: *** Bewegungsmelder-Script gestartet *** Folgende Bewegungsmelder werden überwacht: BadGaeste, SchlafzimmerNew, Laundry, BadFirstFloor, FirstFloorLightNew, FirstFloorLightTom, StairsToFirstFloor, BeerCellar, ToolCellar, CellarFloor, StepToCellarFloor, AlarmTest3
          2022-03-21 09:47:07.481 - info: javascript.0 (11978) script.js.common.BewegungsmelderV2: registered 12 subscriptions and 0 schedules
          2022-03-21 09:47:07.482 - info: javascript.0 (11978) Start javascript script.js.common.CommonMix
          2022-03-21 09:47:07.502 - info: javascript.0 (11978) script.js.common.CommonMix: registered 8 subscriptions and 0 schedules
          2022-03-21 09:47:07.503 - info: javascript.0 (11978) Start javascript script.js.common.FritzBox
          2022-03-21 09:47:07.521 - info: javascript.0 (11978) script.js.common.FritzBox: registered 1 subscription and 0 schedules
          2022-03-21 09:47:07.523 - info: javascript.0 (11978) Start javascript script.js.common.LeavingHouse
          2022-03-21 09:47:07.547 - info: javascript.0 (11978) script.js.common.LeavingHouse: registered 2 subscriptions and 0 schedules
          2022-03-21 09:47:07.548 - info: javascript.0 (11978) Start javascript script.js.common.OpenDoorsWindows
          2022-03-21 09:47:07.582 - info: javascript.0 (11978) script.js.common.OpenDoorsWindows: registered 0 subscriptions and 0 schedules
          2022-03-21 09:47:07.583 - info: javascript.0 (11978) Start javascript script.js.common.Shellys
          2022-03-21 09:47:07.603 - info: javascript.0 (11978) script.js.common.Shellys: registered 9 subscriptions and 0 schedules
          2022-03-21 09:47:08.418 - info: javascript.0 (11978) script.js.common.OpenDoorsWindows: Alle Fenster geschlossen.
          2022-03-21 09:47:09.123 - info: shelly.0 (12026) starting. Version 5.3.2 in /opt/iobroker/node_modules/iobroker.shelly, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 09:47:09.170 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 12087
          2022-03-21 09:47:10.585 - info: tr-064.0 (12044) starting. Version 4.2.15 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 09:47:10.654 - info: shelly.1 (12028) starting. Version 5.3.2 in /opt/iobroker/node_modules/iobroker.shelly, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 09:47:11.513 - info: weatherunderground.0 (12075) starting. Version 3.4.1 (non-npm: iobroker-community-adapters/ioBroker.weatherunderground) in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 09:47:11.974 - info: shelly.0 (12026) Starting in CoAP mode.
          2022-03-21 09:47:12.209 - info: shelly.0 (12026) [CoAP] Listening for packets in the network
          2022-03-21 09:47:12.765 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shellyplug-s / shellyplug-s-E435C4 / SHPLG-S#E435C4#1) connected! Polltime set to 5 sec.
          2022-03-21 09:47:12.999 - info: shelly.1 (12028) Starting in MQTT mode. Listening on Y.X.C.V.31:1882
          2022-03-21 09:47:13.110 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shellydimmer / shellydimmer-D463D3 / SHDM-1#D463D3#1) connected! Polltime set to 5 sec.
          2022-03-21 09:47:13.388 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shellyplug-s / shellyplug-s-4BA36E / SHPLG2-1#4BA36E#1) connected! Polltime set to 5 sec.
          2022-03-21 09:47:13.681 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 12109
          2022-03-21 09:47:13.808 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shelly1 / shelly1-767AC8 / SHSW-1#767AC8#1) connected! Polltime set to 5 sec.
          2022-03-21 09:47:14.090 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shellyplug-s / shellyplug-s-80116A / SHPLG-S#80116A#1) connected! Polltime set to 5 sec.
          2022-03-21 09:47:15.629 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shelly1pm / shelly1pm-F27119 / SHSW-PM#F27119#1) connected! Polltime set to 5 sec.
          2022-03-21 09:47:17.290 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 12124
          2022-03-21 09:47:17.389 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shelly1pm / shelly1pm-F27634 / SHSW-PM#F27634#1) connected! Polltime set to 5 sec.
          2022-03-21 09:47:17.814 - info: shelly.1 (12028) [MQTT] Device Y.X.C.V (shellyplus1 / shellyplus1-a8032abeb1e4 / shellyplus1#a8032abeb1e4#1) connected! Polltime set to 5 sec.
          2022-03-21 09:47:18.224 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shellyplug-s / shellyplug-s-577BFA / SHPLG-S#577BFA#1) connected! Polltime set to 5 sec.
          2022-03-21 09:47:19.695 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shellydimmer2 / shellydimmer2-D8BFC019EECE / SHDM-2#D8BFC019EECE#1) connected! Polltime set to 5 sec.
          2022-03-21 09:47:20.044 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shellyplug-s / shellyplug-s-B4B41F / SHPLG-S#B4B41F#1) connected! Polltime set to 5 sec.
          2022-03-21 09:47:21.240 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shellyplug-s / shellyplug-s-8D010E / SHPLG-S#8D010E#1) connected! Polltime set to 5 sec.
          2022-03-21 09:47:23.103 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shellyplug-s / shellyplug-s-DE15FC / SHPLG-S#DE15FC#1) connected! Polltime set to 5 sec.
          2022-03-21 09:47:24.815 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shellydimmer / shellydimmer-D3E31B / SHDM-1#D3E31B#1) connected! Polltime set to 5 sec.
          2022-03-21 09:47:25.268 - info: shelly.0 (12026) [CoAP] Device Y.X.C.V (shelly1 / shelly1-98F4ABF3CF6C / SHSW-1#98F4ABF3CF6C#1) connected! Polltime set to 5 sec.
          2022-03-21 09:47:29.331 - warn: backitup.0 (12124) slow connection to objects DB. Still waiting ...
          2022-03-21 09:52:24.306 - info: host.raspberrypi instance scheduled system.adapter.feiertage.0 0 0 * * *
          2022-03-21 09:52:24.345 - info: host.raspberrypi instance system.adapter.feiertage.0 started with pid 12147
          2022-03-21 09:52:36.215 - warn: feiertage.0 (12147) slow connection to objects DB. Still waiting ...
          2022-03-21 09:52:43.062 - info: host.raspberrypi instance scheduled system.adapter.schoolfree.0 1 0 * * *
          2022-03-21 09:52:43.140 - info: host.raspberrypi instance system.adapter.schoolfree.0 started with pid 12158
          2022-03-21 09:52:43.236 - info: host.raspberrypi instance system.adapter.radar2.0 started with pid 12164
          2022-03-21 09:52:43.660 - info: host.raspberrypi instance system.adapter.info.0 started with pid 12172
          2022-03-21 09:52:43.736 - info: host.raspberrypi instance system.adapter.cloud.0 started with pid 12173
          2022-03-21 09:52:44.165 - info: host.raspberrypi instance system.adapter.text2command.0 started with pid 12186
          2022-03-21 09:52:44.283 - info: host.raspberrypi instance system.adapter.iot.0 started with pid 12188
          2022-03-21 09:52:56.402 - warn: schoolfree.0 (12158) slow connection to objects DB. Still waiting ...
          2022-03-21 09:52:56.710 - warn: feiertage.0 (12147) slow connection to states DB. Still waiting ...
          2022-03-21 09:52:56.713 - warn: radar2.0 (12164) slow connection to objects DB. Still waiting ...
          2022-03-21 09:52:57.417 - warn: cloud.0 (12173) slow connection to objects DB. Still waiting ...
          2022-03-21 09:52:57.723 - warn: text2command.0 (12186) slow connection to objects DB. Still waiting ...
          2022-03-21 09:52:58.256 - warn: iot.0 (12188) slow connection to objects DB. Still waiting ...
          2022-03-21 09:52:59.031 - warn: info.0 (12172) slow connection to objects DB. Still waiting ...
          2022-03-21 09:55:35.146 - warn: schoolfree.0 (12158) slow connection to states DB. Still waiting ...
          2022-03-21 09:55:35.148 - warn: radar2.0 (12164) slow connection to states DB. Still waiting ...
          2022-03-21 09:55:35.150 - warn: cloud.0 (12173) slow connection to states DB. Still waiting ...
          2022-03-21 09:55:35.158 - warn: text2command.0 (12186) slow connection to states DB. Still waiting ...
          2022-03-21 09:55:35.293 - warn: iot.0 (12188) slow connection to states DB. Still waiting ...
          2022-03-21 09:55:35.298 - warn: info.0 (12172) slow connection to states DB. Still waiting ...
          2022-03-21 09:58:39.627 - info: zigbee.0 (12087) starting. Version 1.6.16 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 09:58:40.024 - info: discovery.0 (12109) starting. Version 2.8.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 09:58:40.015 - info: zigbee.0 (12087) Starting Zigbee npm ...
          2022-03-21 09:58:41.540 - info: radar2.0 (12164) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.radar2, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 09:58:41.651 - info: zigbee.0 (12087) Installed Version: ioBroker/ioBroker.zigbee
          2022-03-21 09:58:42.142 - info: zigbee.0 (12087) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20211217}}
          2022-03-21 09:58:42.152 - info: zigbee.0 (12087) Unable to disable LED, unsupported function.
          2022-03-21 09:58:42.180 - info: radar2.0 (12164) radar2 initialization started...
          2022-03-21 09:58:42.182 - info: zigbee.0 (12087) --> transmitPower : normal
          2022-03-21 09:58:42.215 - info: zigbee.0 (12087) Currently 53 devices are joined:
          2022-03-21 09:58:42.212 - info: radar2.0 (12164) Will use l2Ping for BT scans.
          2022-03-21 09:58:42.396 - info: radar2.0 (12164) Will run hcitool-mode and not noble on device []!
          2022-03-21 09:58:42.762 - info: radar2.0 (12164) arp-scan will use the following interfaces: [ 'eth0' ]
          2022-03-21 09:58:42.777 - info: text2command.0 (12186) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.text2command, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 09:58:42.865 - info: radar2.0 (12164) Connected with '0.0.0.0' for DHCP Scan
          2022-03-21 09:58:42.677 - info: zigbee.0 (12087) 0x00158d00044520d0 (addr 53360): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
          2022-03-21 09:58:42.692 - info: zigbee.0 (12087) 0xccccccfffea9c795 (addr 48051): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
          2022-03-21 09:58:42.918 - info: zigbee.0 (12087) 0x000d6ffffea61fe1 (addr 8521): E1746 - IKEA TRADFRI signal repeater (Router)
          2022-03-21 09:58:42.919 - info: zigbee.0 (12087) Zigbee started
          2022-03-21 09:58:43.334 - info: cloud.0 (12173) starting. Version 4.1.1 in /opt/iobroker/node_modules/iobroker.cloud, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 09:58:44.332 - info: cloud.0 (12173) Connecting with https://iobroker.pro:10555 with "@pro_lars@lars-keller.net_a56c8fe0-59a6-11ea-bbb9-a3d45e2d176f"
          2022-03-21 09:58:44.550 - warn: zigbee.0 (12087) DeviceAvailability:Failed to ping 0x000d6ffffe2e4a54 TRADFRI signal repeater
          2022-03-21 09:58:44.744 - info: backitup.0 (12124) starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 09:58:44.848 - info: feiertage.0 (12147) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 09:58:44.551 - warn: zigbee.0 (12087) DeviceAvailability:Failed to ping 0x680ae2fffe9c8577 TRADFRI Signal Repeater
          2022-03-21 09:58:45.143 - info: cloud.0 (12173) Trying to connect as system.user.admin
          2022-03-21 09:58:45.270 - info: backitup.0 (12124) [iobroker] backup was activated at 02:53 every 1 day(s)
          2022-03-21 09:58:45.503 - info: schoolfree.0 (12158) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.schoolfree, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 09:58:45.880 - warn: schoolfree.0 (12158) schoolfree set state error: TypeError: Cannot read property 'name' of undefined
          2022-03-21 09:58:46.765 - info: schoolfree.0 (12158) schoolfree request done
          2022-03-21 09:58:47.101 - info: iot.0 (12188) starting. Version 1.11.2 in /opt/iobroker/node_modules/iobroker.iot, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 09:58:47.359 - info: feiertage.0 (12147) Next holiday: Karfreitag is in 25 days on 15.04.2022
          2022-03-21 09:58:47.355 - info: iot.0 (12188) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
          2022-03-21 09:58:48.667 - info: feiertage.0 (12147) adapter feiertage objects written
          2022-03-21 09:58:49.283 - info: feiertage.0 (12147) Terminated (NO_ERROR): Without reason
          2022-03-21 09:58:49.971 - info: iot.0 (12188) Connection changed: connect
          2022-03-21 09:58:50.051 - error: cloud.0 (12173) Cloud says: timeout
          2022-03-21 09:58:50.437 - info: host.raspberrypi instance system.adapter.feiertage.0 terminated with code 0 (NO_ERROR)
          2022-03-21 09:58:50.509 - info: radar2.0 (12164) Init item YYYY with {name: 'YYYY',bluetooth: [],enabled: -1,id: 'YYYY',type: 'IP',hasMAC: [ 'XXXX' ],ipVendor: 'N/A',rip: [ '192.168.xxx.yyy' ],lasthere: '2022-03-21T05:14:19.102Z'}
          2022-03-21 09:58:51.060 - info: cloud.0 (12173) Connection changed: io server disconnect
          2022-03-21 09:58:52.403 - info: info.0 (12172) starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 09:58:52.691 - info: info.0 (12172) Reading/updating systemdata.
          2022-03-21 09:58:54.318 - info: info.0 (12172) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
          2022-03-21 09:58:54.560 - info: info.0 (12172) State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
          2022-03-21 09:58:54.618 - info: info.0 (12172) State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
          2022-03-21 09:58:54.644 - info: info.0 (12172) State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
          2022-03-21 09:58:54.706 - info: info.0 (12172) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
          2022-03-21 09:58:55.350 - info: info.0 (12172) cpu Temp res = {"main":74.984,"cores":[],"max":74.984,"socket":[],"chipset":null}
          2022-03-21 09:58:56.197 - info: info.0 (12172) State value to set for "info.0.sysinfo.memory.memLayout.ram0.ecc" has to be stringified but received type "boolean"
          2022-03-21 09:58:56.763 - info: radar2.0 (12164) Init item XXXXX with {name: 'XXXXX',bluetooth: [],enabled: -1,id: 'XXXXX',type: 'IP',hasMAC: [ 'xxx' ],ipVendor: 'N/A',rip: [ '192.168.xxx.yyy' ],lasthere: '2021-12-14T03:02:35.263Z'}
          2022-03-21 09:58:56.989 - info: radar2.0 (12164) Init item XXXYYY with {name: 'XXXYYY',bluetooth: [],enabled: -1,id: 'XXXYYY',type: 'IP',hasMAC: [ 'xxx' ],ipVendor: 'N/A',rip: [ '192.168.xxx.yyy' ],lasthere: '2022-03-21T08:44:50.501Z'}
          2022-03-21 09:58:56.990 - info: radar2.0 (12164) Adapter identified macs: (XXX,YYY,CCC),
          ips: (xxx.xxx.xxx.yyy,xxx.xxx.xxx.yyy,xxx.xxx.xxx.yyy),
          bts LE: (),
          bts norm: ()
          2022-03-21 09:58:57.272 - info: radar2.0 (12164) radar2 found 3 devices in config (YYYY,XXXXX,XXXYYY) and 3 enabled.
          2022-03-21 09:58:57.273 - info: radar2.0 (12164) radar2 set use of noble(false), doArp("-lgq --retry=5 --timeout=400" on eth0), btid(-1) and doUwz(undefined,30,0,de,true).
          2022-03-21 09:59:14.958 - info: cloud.0 (12173) Trying to connect as system.user.admin
          2022-03-21 09:59:15.281 - info: cloud.0 (12173) Connection changed: connect
          2022-03-21 09:59:15.327 - info: cloud.0 (12173) Adapter redirected temporally to "https://iobroker.pro:10556" in 30 seconds. Reason: command from server
          2022-03-21 09:59:16.788 - info: schoolfree.0 (12158) Terminated (NO_ERROR): Without reason
          2022-03-21 09:59:17.807 - info: host.raspberrypi instance system.adapter.schoolfree.0 terminated with code 0 (NO_ERROR)
          2022-03-21 09:59:18.058 - info: weatherunderground.0 (12075) Terminated (NO_ERROR): Without reason
          2022-03-21 09:59:19.030 - info: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
          2022-03-21 09:59:53.061 - error: radar2.0 (12164) States database error: write EPIPE
          2022-03-21 09:59:53.064 - info: shelly.1 (12028) Closing Adapter
          2022-03-21 09:59:53.364 - info: radar2.0 (12164) Unload adapter now with null
          2022-03-21 09:59:53.366 - info: radar2.0 (12164) Adapter disconnected and stopped with dostop(null) and callback(true)
          2022-03-21 09:59:53.360 - error: shelly.0 (12026) Objects database error: write EPIPE
          2022-03-21 09:59:54.120 - error: radar2.0 (12164) uncaught exception: Cannot read property 'init' of null
          2022-03-21 09:59:54.122 - error: radar2.0 (12164) TypeError: Cannot read property 'init' of null
          at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.radar2/myNetworks.js:964:82)
          at listOnTimeout (internal/timers.js:557:17)
          at processTimers (internal/timers.js:500:7)
          2022-03-21 09:59:54.123 - error: radar2.0 (12164) Cannot read property 'init' of null
          2022-03-21 09:59:54.125 - warn: radar2.0 (12164) Uncaught Exception: Cannot read property 'init' of null
          2022-03-21 09:59:54.236 - error: iot.0 (12188) States database error: write ECONNRESET
          2022-03-21 09:59:54.419 - info: iot.0 (12188) Connection changed: disconnect
          2022-03-21 09:59:54.420 - info: iot.0 (12188) Connection lost
          2022-03-21 09:59:54.472 - error: backitup.0 (12124) States database error: write ECONNRESET
          2022-03-21 09:59:54.478 - info: backitup.0 (12124) cleaned everything up...
          2022-03-21 09:59:54.489 - error: tr-064.0 (12044) States database error: write EPIPE
          2022-03-21 09:59:54.569 - info: shelly.1 (12028) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2022-03-21 09:59:54.544 - error: hue.0 (12002) States database error: write ECONNRESET
          2022-03-21 09:59:54.738 - error: history.0 (11967) States database error: write ECONNRESET
          2022-03-21 09:59:54.808 - error: pushover.0 (11993) States database error: write EPIPE
          2022-03-21 09:59:54.865 - info: radar2.0 (12164) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2022-03-21 09:59:54.861 - error: text2command.0 (12186) States database error: write ECONNRESET
          2022-03-21 09:59:54.888 - error: zigbee.0 (12087) States database error: write ECONNRESET
          2022-03-21 09:59:54.897 - error: javascript.0 (11978) States database error: write ECONNRESET
          2022-03-21 09:59:54.905 - info: zigbee.0 (12087) cleaned everything up...
          2022-03-21 09:59:54.910 - error: discovery.0 (12109) States database error: write ECONNRESET
          2022-03-21 09:59:54.948 - info: javascript.0 (11978) Stop script script.js.common.BatteryCheck
          2022-03-21 09:59:54.959 - error: cloud.0 (12173) States database error: write ECONNRESET
          2022-03-21 09:59:54.943 - error: email.0 (11952) States database error: write ECONNRESET
          2022-03-21 09:59:54.839 - error: shelly.0 (12026) States database error: write EPIPE
          2022-03-21 09:59:55.071 - error: alexa2.0 (11999) States database error: write EPIPE
          2022-03-21 09:59:54.965 - info: javascript.0 (11978) Stop script script.js.common.BewegungsmelderV2
          2022-03-21 09:59:54.981 - info: javascript.0 (11978) Stop script script.js.common.CommonMix
          2022-03-21 09:59:54.983 - info: javascript.0 (11978) Stop script script.js.common.FritzBox
          2022-03-21 09:59:54.984 - info: javascript.0 (11978) Stop script script.js.common.LeavingHouse
          2022-03-21 09:59:55.022 - info: javascript.0 (11978) Stop script script.js.common.OpenDoorsWindows
          2022-03-21 09:59:55.026 - info: javascript.0 (11978) Stop script script.js.common.Shellys
          2022-03-21 09:59:55.105 - error: info.0 (12172) States database error: write ECONNRESET
          2022-03-21 09:59:55.113 - info: info.0 (12172) cleaned everything up...
          2022-03-21 09:59:55.187 - info: shelly.0 (12026) Closing Adapter
          2022-03-21 09:59:55.234 - error: admin.0 (11936) States database error: write EPIPE
          2022-03-21 09:59:55.325 - info: zigbee.0 (12087) Zigbee: disabling joining new devices.
          2022-03-21 09:59:55.358 - info: admin.0 (11936) terminating http server on port 8081
          2022-03-21 09:59:55.793 - info: iot.0 (12188) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2022-03-21 09:59:55.983 - info: backitup.0 (12124) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2022-03-21 09:59:56.013 - info: tr-064.0 (12044) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2022-03-21 09:59:56.367 - info: pushover.0 (11993) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2022-03-21 09:59:56.409 - info: zigbee.0 (12087) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2022-03-21 09:59:56.417 - info: text2command.0 (12186) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2022-03-21 09:59:56.430 - info: discovery.0 (12109) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2022-03-21 09:59:56.453 - info: javascript.0 (11978) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2022-03-21 09:59:56.486 - info: email.0 (11952) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2022-03-21 09:59:56.498 - info: cloud.0 (12173) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2022-03-21 09:59:56.638 - info: alexa2.0 (11999) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2022-03-21 09:59:56.640 - info: info.0 (12172) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2022-03-21 09:59:56.691 - info: shelly.0 (12026) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2022-03-21 09:59:56.865 - info: admin.0 (11936) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2022-03-21 09:59:57.825 - error: shelly.1 (12028) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
          2022-03-21 09:59:57.836 - warn: shelly.1 (12028) get state error: Connection is closed.
          2022-03-21 09:59:57.837 - warn: shelly.1 (12028) get state error: DB closed
          2022-03-21 09:59:57.838 - warn: shelly.1 (12028) get state error: DB closed
          2022-03-21 09:59:57.839 - warn: shelly.1 (12028) get state error: DB closed
          2022-03-21 09:59:57.840 - warn: shelly.1 (12028) get state error: DB closed
          2022-03-21 09:59:57.841 - warn: shelly.1 (12028) get state error: DB closed
          2022-03-21 09:59:57.842 - warn: shelly.1 (12028) get state error: DB closed
          2022-03-21 09:59:57.843 - warn: shelly.1 (12028) get state error: DB closed
          2022-03-21 09:59:58.396 - warn: radar2.0 (12164) get state error: Connection is closed.
          2022-03-21 09:59:58.397 - warn: radar2.0 (12164) get state error: DB closed
          2022-03-21 09:59:58.398 - warn: radar2.0 (12164) get state error: DB closed
          2022-03-21 09:59:58.399 - warn: radar2.0 (12164) get state error: DB closed
          2022-03-21 09:59:58.400 - warn: radar2.0 (12164) get state error: DB closed
          2022-03-21 09:59:58.401 - warn: radar2.0 (12164) get state error: DB closed
          2022-03-21 09:59:58.401 - warn: radar2.0 (12164) redis get radar2.0.info.connection, error - DB closed
          2022-03-21 09:59:58.402 - warn: radar2.0 (12164) get state error: DB closed
          2022-03-21 09:59:58.403 - warn: radar2.0 (12164) get state error: DB closed
          2022-03-21 09:59:58.404 - warn: radar2.0 (12164) get state error: DB closed
          2022-03-21 09:59:58.406 - warn: radar2.0 (12164) get state error: DB closed
          2022-03-21 09:59:58.407 - warn: radar2.0 (12164) get state error: DB closed
          2022-03-21 09:59:58.504 - error: shelly.0 (12026) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
          2022-03-21 09:59:59.316 - error: iot.0 (12188) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
          2022-03-21 09:59:59.326 - warn: iot.0 (12188) get state error: Connection is closed.
          2022-03-21 09:59:59.327 - warn: iot.0 (12188) get state error: DB closed
          2022-03-21 09:59:59.328 - warn: iot.0 (12188) get state error: DB closed
          2022-03-21 09:59:59.329 - warn: iot.0 (12188) get state error: DB closed
          2022-03-21 09:59:59.330 - warn: iot.0 (12188) get state error: DB closed
          2022-03-21 09:59:59.331 - warn: iot.0 (12188) get state error: DB closed
          2022-03-21 09:59:59.332 - warn: iot.0 (12188) get state error: DB closed
          2022-03-21 09:59:59.333 - warn: iot.0 (12188) get state error: DB closed
          2022-03-21 09:59:59.334 - warn: iot.0 (12188) get state error: DB closed
          2022-03-21 09:59:59.486 - warn: backitup.0 (12124) get state error: Connection is closed.
          2022-03-21 09:59:59.524 - warn: tr-064.0 (12044) get state error: Connection is closed.
          2022-03-21 09:59:59.800 - error: history.0 (11967) States database error: connect ECONNREFUSED 127.0.0.1:9000
          2022-03-21 09:59:59.805 - error: history.0 (11967) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
          2022-03-21 09:59:59.899 - warn: pushover.0 (11993) get state error: Connection is closed.
          2022-03-21 09:59:59.936 - warn: text2command.0 (12186) get state error: Connection is closed.
          2022-03-21 09:59:59.952 - warn: discovery.0 (12109) get state error: Connection is closed.
          2022-03-21 09:59:59.997 - warn: email.0 (11952) get state error: Connection is closed.
          2022-03-21 10:00:00.014 - warn: cloud.0 (12173) get state error: Connection is closed.
          2022-03-21 10:00:00.073 - warn: javascript.0 (11978) get state error: Connection is closed.
          2022-03-21 10:00:00.075 - warn: javascript.0 (11978) get state error: DB closed
          2022-03-21 10:00:00.090 - warn: javascript.0 (11978) get state error: DB closed
          2022-03-21 10:00:00.091 - warn: javascript.0 (11978) get state error: DB closed
          2022-03-21 10:00:00.144 - warn: alexa2.0 (11999) get state error: Connection is closed.
          2022-03-21 10:00:00.145 - warn: info.0 (12172) get state error: Connection is closed.
          2022-03-21 10:00:00.145 - warn: alexa2.0 (11999) get state error: DB closed
          2022-03-21 10:00:00.146 - warn: alexa2.0 (11999) get state error: DB closed
          2022-03-21 10:00:00.147 - warn: alexa2.0 (11999) get state error: DB closed
          2022-03-21 10:00:00.148 - warn: alexa2.0 (11999) get state error: DB closed
          2022-03-21 10:00:00.149 - warn: alexa2.0 (11999) get state error: DB closed
          2022-03-21 10:00:00.150 - warn: alexa2.0 (11999) get state error: DB closed
          2022-03-21 10:00:00.151 - warn: alexa2.0 (11999) get state error: DB closed
          2022-03-21 10:00:00.152 - warn: alexa2.0 (11999) get state error: DB closed
          2022-03-21 10:00:00.157 - warn: alexa2.0 (11999) redis get alexa2.0.History.creationTime, error - DB closed
          2022-03-21 10:00:00.157 - warn: alexa2.0 (11999) get state error: DB closed
          2022-03-21 10:00:00.158 - warn: alexa2.0 (11999) get state error: DB closed
          2022-03-21 10:00:00.146 - warn: info.0 (12172) get state error: DB closed
          2022-03-21 10:00:00.147 - warn: info.0 (12172) get state error: DB closed
          2022-03-21 10:00:00.148 - warn: info.0 (12172) get state error: DB closed
          2022-03-21 10:00:00.149 - warn: info.0 (12172) get state error: DB closed
          2022-03-21 10:00:00.155 - warn: info.0 (12172) get state error: DB closed
          2022-03-21 10:00:00.156 - warn: info.0 (12172) get state error: DB closed
          2022-03-21 10:00:00.157 - warn: info.0 (12172) get state error: DB closed
          2022-03-21 10:00:00.158 - warn: info.0 (12172) get state error: DB closed
          2022-03-21 10:00:00.159 - warn: info.0 (12172) get state error: DB closed
          2022-03-21 10:00:00.199 - warn: shelly.0 (12026) get state error: Connection is closed.
          2022-03-21 10:00:00.200 - warn: shelly.0 (12026) get state error: DB closed
          2022-03-21 10:00:00.201 - warn: shelly.0 (12026) get state error: DB closed
          2022-03-21 10:00:00.202 - warn: shelly.0 (12026) get state error: DB closed
          2022-03-21 10:00:00.203 - warn: shelly.0 (12026) get state error: DB closed
          2022-03-21 10:00:00.204 - warn: shelly.0 (12026) get state error: DB closed
          2022-03-21 10:00:00.205 - warn: shelly.0 (12026) get state error: DB closed
          2022-03-21 10:00:00.212 - warn: shelly.0 (12026) get state error: DB closed
          2022-03-21 10:00:00.355 - warn: zigbee.0 (12087) get state error: Connection is closed.
          2022-03-21 10:00:00.356 - warn: zigbee.0 (12087) get state error: DB closed
          2022-03-21 10:00:00.357 - warn: zigbee.0 (12087) get state error: DB closed
          2022-03-21 10:00:00.360 - warn: zigbee.0 (12087) get state error: DB closed
          2022-03-21 10:00:00.361 - warn: zigbee.0 (12087) get state error: DB closed
          2022-03-21 10:00:00.362 - warn: zigbee.0 (12087) get state error: DB closed
          2022-03-21 10:00:00.363 - warn: zigbee.0 (12087) get state error: DB closed
          2022-03-21 10:00:00.436 - warn: admin.0 (11936) get state error: Connection is closed.
          2022-03-21 10:00:00.440 - warn: admin.0 (11936) get state error: DB closed
          2022-03-21 10:00:00.448 - warn: admin.0 (11936) get state error: DB closed
          2022-03-21 10:00:00.449 - warn: admin.0 (11936) get state error: DB closed
          2022-03-21 10:00:00.784 - warn: admin.0 (11936) Cannot get view: Connection is closed.
          2022-03-21 10:00:02.833 - error: shelly.1 (12028) Cannot find view "system" for search "device" : Connection is closed.
          2022-03-21 10:00:03.511 - error: shelly.0 (12026) Cannot find view "system" for search "device" : DB closed
          2022-03-21 10:00:04.803 - error: history.0 (11967) States database error: connect ECONNREFUSED 127.0.0.1:9000
          2022-03-21 10:00:04.807 - error: history.0 (11967) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
          2022-03-21 10:00:05.796 - info: history.0 (11967) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2022-03-21 10:00:09.810 - warn: history.0 (11967) get state error: Connection is closed.
          2022-03-21 10:00:09.812 - warn: history.0 (11967) get state error: DB closed
          2022-03-21 10:00:09.829 - warn: history.0 (11967) get state error: DB closed
          2022-03-21 10:00:09.830 - warn: history.0 (11967) get state error: DB closed
          2022-03-21 10:00:09.831 - warn: history.0 (11967) get state error: DB closed
          2022-03-21 10:00:15.504 - info: host.raspberrypi iobroker.js-controller version 4.0.19 js-controller starting
          2022-03-21 10:00:15.512 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
          2022-03-21 10:00:15.513 - info: host.raspberrypi hostname: raspberrypi, node: v14.19.1
          2022-03-21 10:00:15.513 - info: host.raspberrypi ip addresses: Y.X.C.V.31 fd01::dea6:32ff:fe4f:dd06 2a02:810d:29bf:fe29:dea6:32ff:fe4f:dd06 fe80::dea6:32ff:fe4f:dd06
          2022-03-21 10:00:17.401 - info: host.raspberrypi connected to Objects and States
          2022-03-21 10:00:17.461 - info: host.raspberrypi added notifications configuration of host
          2022-03-21 10:00:18.336 - info: host.raspberrypi 32 instances found
          2022-03-21 10:00:18.397 - info: host.raspberrypi starting 21 instances
          2022-03-21 10:00:18.643 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 12522
          2022-03-21 10:00:20.608 - error: admin.0 (12522) admin.0 already running
          2022-03-21 10:00:20.612 - warn: admin.0 (12522) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2022-03-21 10:00:21.247 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2022-03-21 10:00:21.249 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
          2022-03-21 10:00:22.436 - info: host.raspberrypi instance system.adapter.email.0 started with pid 12533
          2022-03-21 10:00:23.953 - error: email.0 (12533) email.0 already running
          2022-03-21 10:00:23.957 - warn: email.0 (12533) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2022-03-21 10:00:24.578 - error: host.raspberrypi instance system.adapter.email.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2022-03-21 10:00:24.579 - info: host.raspberrypi Restart adapter system.adapter.email.0 because enabled
          2022-03-21 10:00:26.568 - info: host.raspberrypi instance system.adapter.history.0 started with pid 12544
          2022-03-21 10:00:28.117 - error: history.0 (12544) history.0 already running
          2022-03-21 10:00:28.122 - warn: history.0 (12544) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2022-03-21 10:00:28.757 - error: host.raspberrypi instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2022-03-21 10:00:28.758 - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
          2022-03-21 10:00:30.514 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 12555
          2022-03-21 10:00:33.965 - error: javascript.0 (12555) javascript.0 already running
          2022-03-21 10:00:33.969 - warn: javascript.0 (12555) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2022-03-21 10:00:34.523 - info: host.raspberrypi instance system.adapter.pushover.0 started with pid 12566
          2022-03-21 10:00:34.641 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2022-03-21 10:00:34.642 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
          2022-03-21 10:00:36.117 - error: pushover.0 (12566) pushover.0 already running
          2022-03-21 10:00:36.120 - warn: pushover.0 (12566) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2022-03-21 10:00:36.770 - error: host.raspberrypi instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2022-03-21 10:00:36.771 - info: host.raspberrypi Restart adapter system.adapter.pushover.0 because enabled
          2022-03-21 10:00:38.513 - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 12577
          2022-03-21 10:00:40.157 - error: alexa2.0 (12577) alexa2.0 already running
          2022-03-21 10:00:40.161 - warn: alexa2.0 (12577) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2022-03-21 10:00:40.784 - error: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2022-03-21 10:00:40.785 - info: host.raspberrypi Restart adapter system.adapter.alexa2.0 because enabled
          2022-03-21 10:00:42.543 - info: host.raspberrypi instance system.adapter.hue.0 started with pid 12588
          2022-03-21 10:00:44.440 - error: hue.0 (12588) hue.0 already running
          2022-03-21 10:00:45.064 - error: host.raspberrypi instance system.adapter.hue.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2022-03-21 10:00:45.065 - info: host.raspberrypi Restart adapter system.adapter.hue.0 because enabled
          2022-03-21 10:00:46.536 - info: host.raspberrypi instance system.adapter.shelly.0 started with pid 12599
          2022-03-21 10:00:48.877 - error: shelly.0 (12599) shelly.0 already running
          2022-03-21 10:00:48.881 - warn: shelly.0 (12599) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2022-03-21 10:00:49.500 - error: host.raspberrypi instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2022-03-21 10:00:49.501 - info: host.raspberrypi Restart adapter system.adapter.shelly.0 because enabled
          2022-03-21 10:00:50.522 - info: host.raspberrypi instance system.adapter.shelly.1 started with pid 12610
          2022-03-21 10:00:51.381 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 12617
          2022-03-21 10:00:52.767 - error: shelly.1 (12610) shelly.1 already running
          2022-03-21 10:00:52.771 - warn: shelly.1 (12610) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2022-03-21 10:00:53.546 - error: host.raspberrypi instance system.adapter.shelly.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2022-03-21 10:00:53.547 - info: host.raspberrypi Restart adapter system.adapter.shelly.1 because enabled
          2022-03-21 10:00:53.864 - info: admin.0 (12617) starting. Version 5.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 10:00:53.913 - info: admin.0 (12617) requesting all states
          2022-03-21 10:00:53.914 - info: admin.0 (12617) requesting all objects
          2022-03-21 10:00:55.451 - info: host.raspberrypi instance system.adapter.email.0 started with pid 12636
          2022-03-21 10:00:55.491 - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 12642
          2022-03-21 10:00:55.958 - info: admin.0 (12617) received all objects
          2022-03-21 10:00:56.469 - info: admin.0 (12617) Request actual repository...
          2022-03-21 10:00:56.513 - info: admin.0 (12617) http server listening on port 8081
          2022-03-21 10:00:56.514 - info: admin.0 (12617) Use link "http://localhost:8081" to configure.
          2022-03-21 10:01:05.113 - info: host.raspberrypi instance scheduled system.adapter.weatherunderground.0 6 * * * *
          2022-03-21 10:01:05.140 - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 12658
          2022-03-21 10:01:05.367 - info: host.raspberrypi Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
          2022-03-21 10:01:07.096 - info: host.raspberrypi instance system.adapter.history.0 started with pid 12669
          2022-03-21 10:01:07.531 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 12676
          2022-03-21 10:01:07.635 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 12683
          2022-03-21 10:01:07.653 - error: tr-064.0 (12642) tr-064.0 already running
          2022-03-21 10:01:07.659 - warn: tr-064.0 (12642) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2022-03-21 10:01:07.894 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 12690
          2022-03-21 10:01:08.304 - info: host.raspberrypi instance system.adapter.pushover.0 started with pid 12697
          2022-03-21 10:01:11.047 - info: admin.0 (12617) Repository received successfully.
          2022-03-21 10:01:11.046 - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2022-03-21 10:01:11.059 - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
          2022-03-21 10:01:11.275 - error: weatherunderground.0 (12658) weatherunderground.0 already running
          2022-03-21 10:01:11.282 - warn: weatherunderground.0 (12658) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2022-03-21 10:01:11.401 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 12716
          2022-03-21 10:01:11.511 - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 12723
          2022-03-21 10:01:12.711 - error: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2022-03-21 10:01:17.801 - warn: discovery.0 (12690) slow connection to states DB. Still waiting ...
          2022-03-21 10:01:24.047 - warn: alexa2.0 (12723) slow connection to objects DB. Still waiting ...
          2022-03-21 10:01:24.287 - warn: javascript.0 (12683) slow connection to objects DB. Still waiting ...
          2022-03-21 10:01:24.555 - warn: backitup.0 (12716) slow connection to objects DB. Still waiting ...
          2022-03-21 10:01:24.847 - warn: zigbee.0 (12676) slow connection to objects DB. Still waiting ...
          2022-03-21 10:01:27.165 - info: host.raspberrypi instance scheduled system.adapter.feiertage.0 0 0 * * *
          2022-03-21 10:01:27.197 - info: host.raspberrypi instance system.adapter.feiertage.0 started with pid 12747
          2022-03-21 10:01:27.515 - error: discovery.0 (12690) discovery.0 already running
          2022-03-21 10:01:27.519 - warn: discovery.0 (12690) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2022-03-21 10:01:27.973 - info: host.raspberrypi instance system.adapter.cloud.0 started with pid 12754
          2022-03-21 10:01:28.006 - info: host.raspberrypi instance system.adapter.hue.0 started with pid 12760
          2022-03-21 10:01:28.256 - info: host.raspberrypi instance system.adapter.shelly.0 started with pid 12768
          2022-03-21 10:01:28.597 - info: host.raspberrypi instance system.adapter.info.0 started with pid 12775
          2022-03-21 10:01:28.646 - info: host.raspberrypi instance system.adapter.shelly.1 started with pid 12777
          2022-03-21 10:01:28.706 - info: host.raspberrypi instance system.adapter.iot.0 started with pid 12782
          2022-03-21 10:01:29.662 - error: backitup.0 (12716) backitup.0 already running
          2022-03-21 10:01:29.667 - warn: backitup.0 (12716) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2022-03-21 10:01:29.779 - error: host.raspberrypi instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2022-03-21 10:01:29.780 - info: host.raspberrypi Restart adapter system.adapter.discovery.0 because enabled
          2022-03-21 10:01:29.989 - error: zigbee.0 (12676) zigbee.0 already running
          2022-03-21 10:01:29.992 - warn: zigbee.0 (12676) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2022-03-21 10:01:34.664 - info: host.raspberrypi instance system.adapter.radar2.0 started with pid 12836
          2022-03-21 10:01:34.790 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2022-03-21 10:01:34.791 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
          2022-03-21 10:01:34.792 - error: host.raspberrypi instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2022-03-21 10:01:34.793 - info: host.raspberrypi Restart adapter system.adapter.backitup.0 because enabled
          2022-03-21 10:01:35.339 - info: email.0 (12636) starting. Version 1.0.10 (non-npm: iobroker-community-adapters/ioBroker.email) in /opt/iobroker/node_modules/iobroker.email, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 10:01:36.547 - info: host.raspberrypi instance system.adapter.text2command.0 started with pid 12859
          2022-03-21 10:01:37.012 - error: iot.0 (12782) iot.0 already running
          2022-03-21 10:01:37.018 - warn: iot.0 (12782) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2022-03-21 10:01:37.231 - error: cloud.0 (12754) cloud.0 already running
          2022-03-21 10:01:37.237 - warn: cloud.0 (12754) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2022-03-21 10:01:38.041 - info: history.0 (12669) starting. Version 1.11.0 in /opt/iobroker/node_modules/iobroker.history, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 10:01:38.247 - error: host.raspberrypi instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2022-03-21 10:01:38.248 - info: host.raspberrypi Restart adapter system.adapter.iot.0 because enabled
          2022-03-21 10:01:38.302 - error: info.0 (12775) info.0 already running
          2022-03-21 10:01:38.309 - warn: info.0 (12775) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2022-03-21 10:01:38.319 - info: history.0 (12669) enabled logging of zigbee.0.00158d000464c66d.humidity (Count=1), Alias=false
          2022-03-21 10:01:38.321 - info: history.0 (12669) enabled logging of zigbee.0.00158d000464c66d.pressure (Count=2), Alias=false
          2022-03-21 10:01:38.322 - info: history.0 (12669) enabled logging of zigbee.0.00158d000464c66d.temperature (Count=3), Alias=false
          2022-03-21 10:01:38.323 - info: history.0 (12669) enabled logging of zigbee.0.00158d00046611c0.humidity (Count=4), Alias=false
          2022-03-21 10:01:38.324 - info: history.0 (12669) enabled logging of zigbee.0.00158d00046611c0.pressure (Count=5), Alias=false
          2022-03-21 10:01:38.325 - info: history.0 (12669) enabled logging of zigbee.0.00158d00046611c0.temperature (Count=6), Alias=false
          2022-03-21 10:01:38.517 - error: host.raspberrypi instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2022-03-21 10:01:38.519 - info: host.raspberrypi Restart adapter system.adapter.cloud.0 because enabled
          2022-03-21 10:01:39.307 - info: host.raspberrypi instance scheduled system.adapter.schoolfree.0 1 0 * * *
          2022-03-21 10:01:39.337 - info: host.raspberrypi instance system.adapter.schoolfree.0 started with pid 12878
          2022-03-21 10:01:39.478 - error: host.raspberrypi instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2022-03-21 10:01:39.479 - info: host.raspberrypi Restart adapter system.adapter.info.0 because enabled
          2022-03-21 10:01:39.503 - error: radar2.0 (12836) radar2.0 already running
          2022-03-21 10:01:39.508 - warn: radar2.0 (12836) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2022-03-21 10:01:42.734 - info: host.raspberrypi Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
          2022-03-21 10:01:42.870 - error: host.raspberrypi instance system.adapter.radar2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2022-03-21 10:01:42.871 - info: host.raspberrypi Restart adapter system.adapter.radar2.0 because enabled
          2022-03-21 10:01:42.890 - error: text2command.0 (12859) text2command.0 already running
          2022-03-21 10:01:42.900 - warn: text2command.0 (12859) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2022-03-21 10:01:42.971 - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 12889
          2022-03-21 10:01:42.981 - info: pushover.0 (12697) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.pushover, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 10:01:43.568 - info: alexa2.0 (12723) starting. Version 3.12.0 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 10:01:44.384 - error: host.raspberrypi instance system.adapter.text2command.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2022-03-21 10:01:44.385 - info: host.raspberrypi Restart adapter system.adapter.text2command.0 because enabled
          2022-03-21 10:01:45.107 - info: javascript.0 (12683) starting. Version 5.4.5 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 10:01:47.024 - info: shelly.1 (12777) starting. Version 5.3.2 in /opt/iobroker/node_modules/iobroker.shelly, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 10:01:47.041 - info: shelly.0 (12768) starting. Version 5.3.2 in /opt/iobroker/node_modules/iobroker.shelly, node: v14.19.1, js-controller: 4.0.19
          2022-03-21 10:01:48.630 - info: alexa2.0 (12723) Alexa-Push-Connection (macDms = true) established. Disable Polling
          2022-03-21 10:01:50.281 - info: javascript.0 (12683) requesting all states
          2022-03-21 10:01:50.283 - info: javascript.0 (12683) requesting all objects
          Aktuell läuft die CPU Last immer noch bei >100% und die Webseite vom IoBroker geht mal und mal nicht...
          apollon77A
          apollon77A
          @th3rockyeah sagte in js-controller 4.0 jetzt im BETA/LATEST!:
          Da "geht es los" ... zuerst EPIPE ... danach ECONNRESET ...
          Was steht zu dem Zeitpunkt in /var/log/syslog ??
          • apollon77A apollon77
            T
            T
            Th3RockYeah
            schrieb am zuletzt editiert von Th3RockYeah
            @apollon77 Hier ein Auszug aus dem Syslog
            Mar 21 09:44:04 raspberrypi bash[511]: Send diag info: {"uuid":"dbe50d02-68fa-f6f2-71c6-83f4ae4fc370","language":"de","country":"Germany","hosts":[{"version":"4.0.19","platform":"Javascript/Node.js","type":"linux"}],"node":"v14.19.1","arch":"arm","docker":false,"adapters":{"admin":{"version":"5.3.3","platform":"Javascript/Node.js"},"discovery":{"version":"2.8.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.3.5","platform":"Javascript/Node.js"},"alexa2":{"version":"3.12.0","platform":"Javascript/Node.js"},"cloud":{"version":"4.1.1","platform":"Javascript/Node.js"},"email":{"version":"1.0.10","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.0","platform":"Javascript/Node.js"},"flot":{"version":"1.10.7","platform":"javascript/Node.js"},"history":{"version":"1.11.0","platform":"Javascript/Node.js"},"hue":{"version":"3.6.5","platform":"Javascript/Node.js"},"info":{"version":"1.9.19","platform":"Javascript/Node.js"},"iot":{"version":"1.11.2","platform":"Javascript/Node.js"},"iqontrol":{"version":"2.0.1","platform":"Javascript/Node.js"},"jarvis":{"version":"3.0.11","platform":"Javascript/Node.js"},"javascript":{"version":"5.4.5","platform":"Javascript/Node.js"},"lgtv":{"version":"1.1.10","platform":"Javascript/Node.js"},"mercedesme":{"version":"0.0.56","platform":"Javascript/Node.js"},"nina":{"version":"0.0.25","platform":"Javascript/Node.js"},"owntracks":{"version":"1.0.1","platform":"Javascript/Node.js"},"pi-hole":{"version":"1.3.4","platform":"Javascript/Node.js"},"ping":{"version":"1.5.3","platform":"Javascript/Node.js"},"pushover":{"version":"2.1.0","platform":"Javascript/Node.js"},"radar2":{"version":"2.0.3","platform":"Javascript/Node.js"},"shelly":{"version":"5.3.2","platform":"Javascript/Node.js"},"simple-api":{"version":"2.6.3","platform":"Javascript/Node.js"},"socketio":{"version":"4.1.4","platform":"Javascript/Node.js"},"systeminfo":{"version":"0.3.1","platform":"Javascript/Node.js"},"tado":{"version":"0.3.15","platform":"Javascript/Node.js"},"text2command":{"version":"2.2.1","platform":"Javascript/Node.js"},"tr-064":{"version":"4.2.15","platform":"Javascript/Node.js"},"vis":{"version":"1.4.12","platform":"Javascript/Node.js"},"weatherunderground":{"version":"3.4.1","platform":"Javascript/Node.js"},"web":{"version":"4.2.1","platform":"Javascript/Node.js"},"ws":{"version":"1.2.0","platform":"Javascript/Node.js"},"zigbee":{"version":"1.6.16","platform":"Javascript/Node.js"},"schoolfree":{"version":"1.0.1","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":32,"compactMode":false,"noCompactInstances":0,"model":"unknown","cpus":4,"mem":3979370496,"ostype":"Linux","vis":12}
            Mar 21 09:44:19 raspberrypi kernel: [53765.769082] device eth0 entered promiscuous mode
            Mar 21 09:44:25 raspberrypi kernel: [53771.614524] device eth0 left promiscuous mode
            Mar 21 09:44:44 raspberrypi kernel: [53790.761404] device eth0 entered promiscuous mode
            Mar 21 09:44:50 raspberrypi kernel: [53796.609895] device eth0 left promiscuous mode
            Mar 21 09:45:06 raspberrypi systemd[1]: Stopping ioBroker Server...
            Mar 21 09:45:08 raspberrypi bash[511]: ================================== > LOG REDIRECT system.adapter.iot.0 => false [Process stopped]
            Mar 21 09:45:08 raspberrypi bash[511]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            Mar 21 09:45:08 raspberrypi bash[511]: Error: DB closed
            Mar 21 09:45:08 raspberrypi bash[511]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
            Mar 21 09:45:08 raspberrypi bash[511]:     at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
            Mar 21 09:45:08 raspberrypi bash[511]:     at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:657:40)
            Mar 21 09:45:08 raspberrypi bash[511]:     at Shelly.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:6485:35)
            Mar 21 09:45:08 raspberrypi bash[511]: ================================== > LOG REDIRECT system.adapter.cloud.0 => false [Process stopped]
            Mar 21 09:45:08 raspberrypi bash[511]: ================================== > LOG REDIRECT system.adapter.iot.0 => false [system.adapter.iot.0.logging]
            Mar 21 09:45:09 raspberrypi bash[511]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
            Mar 21 09:45:09 raspberrypi bash[511]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
            Mar 21 09:45:09 raspberrypi bash[511]: ================================== > LOG REDIRECT system.adapter.cloud.0 => false [system.adapter.cloud.0.logging]
            Mar 21 09:45:09 raspberrypi bash[511]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
            Mar 21 09:45:09 raspberrypi bash[511]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
            Mar 21 09:45:11 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
            Mar 21 09:45:11 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
            Mar 21 09:45:11 raspberrypi systemd[1]: Stopped ioBroker Server.
            Mar 21 09:46:08 raspberrypi systemd[1]: Starting Daily apt download activities...
            Mar 21 09:46:09 raspberrypi systemd[1]: apt-daily.service: Succeeded.
            Mar 21 09:46:09 raspberrypi systemd[1]: Started Daily apt download activities.
            Mar 21 09:46:21 raspberrypi systemd[1]: Started ioBroker Server.
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.email.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.history.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.javascript.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.pushover.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.alexa2.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.hue.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.owntracks.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.ping.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.shelly.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.shelly.1" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.tr-064.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.weatherunderground.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.zigbee.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.backitup.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.cloud.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.feiertage.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.info.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.iot.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.iqontrol.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.jarvis.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.lgtv.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.mercedesme.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.nina.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.pi-hole.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.radar2.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.tado.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.text2command.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.vis.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
            Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.schoolfree.0" for host "raspberrypi"
            Mar 21 09:46:30 raspberrypi bash[11917]: Send diag info: {"uuid":"dbe50d02-68fa-f6f2-71c6-83f4ae4fc370","language":"de","country":"Germany","hosts":[{"version":"4.0.19","platform":"Javascript/Node.js","type":"linux"}],"node":"v14.19.1","arch":"arm","docker":false,"adapters":{"admin":{"version":"5.3.3","platform":"Javascript/Node.js"},"discovery":{"version":"2.8.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.3.5","platform":"Javascript/Node.js"},"alexa2":{"version":"3.12.0","platform":"Javascript/Node.js"},"cloud":{"version":"4.1.1","platform":"Javascript/Node.js"},"email":{"version":"1.0.10","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.0","platform":"Javascript/Node.js"},"flot":{"version":"1.10.7","platform":"javascript/Node.js"},"history":{"version":"1.11.0","platform":"Javascript/Node.js"},"hue":{"version":"3.6.5","platform":"Javascript/Node.js"},"info":{"version":"1.9.19","platform":"Javascript/Node.js"},"iot":{"version":"1.11.2","platform":"Javascript/Node.js"},"iqontrol":{"version":"2.0.1","platform":"Javascript/Node.js"},"jarvis":{"version":"3.0.11","platform":"Javascript/Node.js"},"javascript":{"version":"5.4.5","platform":"Javascript/Node.js"},"lgtv":{"version":"1.1.10","platform":"Javascript/Node.js"},"mercedesme":{"version":"0.0.56","platform":"Javascript/Node.js"},"nina":{"version":"0.0.25","platform":"Javascript/Node.js"},"owntracks":{"version":"1.0.1","platform":"Javascript/Node.js"},"pi-hole":{"version":"1.3.4","platform":"Javascript/Node.js"},"ping":{"version":"1.5.3","platform":"Javascript/Node.js"},"pushover":{"version":"2.1.0","platform":"Javascript/Node.js"},"radar2":{"version":"2.0.3","platform":"Javascript/Node.js"},"shelly":{"version":"5.3.2","platform":"Javascript/Node.js"},"simple-api":{"version":"2.6.3","platform":"Javascript/Node.js"},"socketio":{"version":"4.1.4","platform":"Javascript/Node.js"},"systeminfo":{"version":"0.3.1","platform":"Javascript/Node.js"},"tado":{"version":"0.3.15","platform":"Javascript/Node.js"},"text2command":{"version":"2.2.1","platform":"Javascript/Node.js"},"tr-064":{"version":"4.2.15","platform":"Javascript/Node.js"},"vis":{"version":"1.4.12","platform":"Javascript/Node.js"},"weatherunderground":{"version":"3.4.1","platform":"Javascript/Node.js"},"web":{"version":"4.2.1","platform":"Javascript/Node.js"},"ws":{"version":"1.2.0","platform":"Javascript/Node.js"},"zigbee":{"version":"1.6.16","platform":"Javascript/Node.js"},"schoolfree":{"version":"1.0.1","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":32,"compactMode":false,"noCompactInstances":0,"model":"unknown","cpus":4,"mem":3979370496,"ostype":"Linux","vis":12}
            Mar 21 09:46:31 raspberrypi bash[11917]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
            Mar 21 09:48:22 raspberrypi rngd[452]: stats: bits received from HRNG source: 500064
            Mar 21 09:48:22 raspberrypi rngd[452]: stats: bits sent to kernel pool: 453824
            Mar 21 09:48:22 raspberrypi rngd[452]: stats: entropy added to kernel pool: 453824
            Mar 21 09:48:22 raspberrypi rngd[452]: stats: FIPS 140-2 successes: 25
            Mar 21 09:48:22 raspberrypi rngd[452]: stats: FIPS 140-2 failures: 0
            Mar 21 09:48:22 raspberrypi rngd[452]: stats: FIPS 140-2(2001-10-10) Monobit: 0
            Mar 21 09:48:22 raspberrypi rngd[452]: stats: FIPS 140-2(2001-10-10) Poker: 0
            Mar 21 09:48:22 raspberrypi rngd[452]: stats: FIPS 140-2(2001-10-10) Runs: 0
            Mar 21 09:48:22 raspberrypi rngd[452]: stats: FIPS 140-2(2001-10-10) Long run: 0
            Mar 21 09:48:22 raspberrypi rngd[452]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
            Mar 21 09:48:22 raspberrypi rngd[452]: stats: HRNG source speed: (min=486.239; avg=517.092; max=525.910)Kibits/s
            Mar 21 09:48:22 raspberrypi rngd[452]: stats: FIPS tests speed: (min=10.782; avg=19.883; max=31.423)Mibits/s
            Mar 21 09:48:22 raspberrypi rngd[452]: stats: Lowest ready-buffers level: 2
            Mar 21 09:48:22 raspberrypi rngd[452]: stats: Entropy starvations: 0
            Mar 21 09:48:22 raspberrypi rngd[452]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
            Mar 21 09:58:43 raspberrypi kernel: [54629.900292] device eth0 entered promiscuous mode
            Mar 21 09:58:43 raspberrypi kernel: [54629.925672] device eth0 left promiscuous mode
            Mar 21 09:58:45 raspberrypi kernel: [54631.777967] CIFS: Attempting to mount //192.168.170.109/ioBrokerBackup/ioBroker
            Mar 21 09:58:57 raspberrypi kernel: [54643.888861] device eth0 entered promiscuous mode
            Mar 21 09:59:03 raspberrypi kernel: [54649.763197] device eth0 left promiscuous mode
            Mar 21 09:59:52 raspberrypi kernel: [54692.150897] ping invoked oom-killer: gfp_mask=0x400dc0(GFP_KERNEL_ACCOUNT|__GFP_ZERO), order=0, oom_score_adj=0
            Mar 21 09:59:52 raspberrypi kernel: [54692.150921] CPU: 2 PID: 12502 Comm: ping Tainted: G         C        5.10.103-v8+ #1529
            Mar 21 09:59:52 raspberrypi kernel: [54692.150927] Hardware name: Raspberry Pi 4 Model B Rev 1.2 (DT)
            Mar 21 09:59:52 raspberrypi kernel: [54692.150934] Call trace:
            Mar 21 09:59:52 raspberrypi kernel: [54692.150954]  dump_backtrace+0x0/0x1b8
            Mar 21 09:59:52 raspberrypi kernel: [54692.150963]  show_stack+0x20/0x30
            Mar 21 09:59:52 raspberrypi kernel: [54692.150974]  dump_stack+0xf0/0x158
            Mar 21 09:59:52 raspberrypi kernel: [54692.150981]  dump_header+0x4c/0x204
            Mar 21 09:59:52 raspberrypi kernel: [54692.150993]  oom_kill_process+0x1f8/0x200
            Mar 21 09:59:52 raspberrypi kernel: [54692.150999]  out_of_memory+0xf0/0x330
            Mar 21 09:59:52 raspberrypi kernel: [54692.151010]  __alloc_pages_slowpath.constprop.134+0x820/0xb80
            Mar 21 09:59:52 raspberrypi kernel: [54692.151017]  __alloc_pages_nodemask+0x2bc/0x330
            Mar 21 09:59:52 raspberrypi kernel: [54692.151025]  handle_mm_fault+0xbc8/0xcb8
            Mar 21 09:59:52 raspberrypi kernel: [54692.151035]  do_page_fault+0x148/0x3e8
            Mar 21 09:59:52 raspberrypi kernel: [54692.151043]  do_translation_fault+0x58/0x70
            Mar 21 09:59:52 raspberrypi kernel: [54692.151053]  do_mem_abort+0x48/0xa8
            Mar 21 09:59:52 raspberrypi kernel: [54692.151059]  el0_da+0x40/0x58
            Mar 21 09:59:52 raspberrypi kernel: [54692.151066]  el0_sync_compat_handler+0xfc/0x110
            Mar 21 09:59:52 raspberrypi kernel: [54692.151072]  el0_sync_compat+0x184/0x1c0
            Mar 21 09:59:52 raspberrypi kernel: [54692.151079] Mem-Info:
            Mar 21 09:59:52 raspberrypi kernel: [54692.151098] active_anon:372700 inactive_anon:560327 isolated_anon:0
            Mar 21 09:59:52 raspberrypi kernel: [54692.151098]  active_file:899 inactive_file:1086 isolated_file:0
            Mar 21 09:59:52 raspberrypi kernel: [54692.151098]  unevictable:4 dirty:1 writeback:0
            Mar 21 09:59:52 raspberrypi kernel: [54692.151098]  slab_reclaimable:4848 slab_unreclaimable:6882
            Mar 21 09:59:52 raspberrypi kernel: [54692.151098]  mapped:1447 shmem:646 pagetables:5758 bounce:0
            Mar 21 09:59:52 raspberrypi kernel: [54692.151098]  free:8689 free_pcp:11 free_cma:389
            Mar 21 09:59:52 raspberrypi kernel: [54692.151113] Node 0 active_anon:1490800kB inactive_anon:2241308kB active_file:3596kB inactive_file:4344kB unevictable:16kB isolated(anon):0kB isolated(file):0kB mapped:5788kB dirty:4kB writeback:0kB shmem:2584kB writeback_tmp:0kB kernel_stack:5920kB all_unreclaimable? no
            Mar 21 09:59:52 raspberrypi kernel: [54692.151132] DMA free:15940kB min:3736kB low:4668kB high:5600kB reserved_highatomic:0KB active_anon:928kB inactive_anon:855204kB active_file:168kB inactive_file:376kB unevictable:0kB writepending:0kB present:970752kB managed:886672kB mlocked:0kB pagetables:1792kB bounce:0kB free_pcp:8kB local_pcp:0kB free_cma:1556kB
            Mar 21 09:59:52 raspberrypi kernel: [54692.151139] lowmem_reserve[]: 0 2929 2929 2929
            Mar 21 09:59:52 raspberrypi kernel: [54692.151189] DMA32 free:18816kB min:41088kB low:44248kB high:47408kB reserved_highatomic:0KB active_anon:1489872kB inactive_anon:1386104kB active_file:3692kB inactive_file:4316kB unevictable:16kB writepending:4kB present:3080192kB managed:2999432kB mlocked:16kB pagetables:21240kB bounce:0kB free_pcp:36kB local_pcp:0kB free_cma:0kB
            Mar 21 09:59:52 raspberrypi kernel: [54692.151196] lowmem_reserve[]: 0 0 0 0
            Mar 21 09:59:52 raspberrypi kernel: [54692.151235] DMA: 83*4kB (UMEC) 46*8kB (UMEC) 36*16kB (UEC) 49*32kB (UEC) 20*64kB (UEC) 11*128kB (UEC) 9*256kB (UEC) 4*512kB (UC) 2*1024kB (U) 2*2048kB (UE) 0*4096kB = 16028kB
            Mar 21 09:59:52 raspberrypi kernel: [54692.151391] DMA32: 1466*4kB (UME) 647*8kB (UME) 265*16kB (UME) 39*32kB (UME) 38*64kB (UE) 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 18960kB
            Mar 21 09:59:52 raspberrypi kernel: [54692.151514] 3025 total pagecache pages
            Mar 21 09:59:52 raspberrypi kernel: [54692.151524] 365 pages in swap cache
            Mar 21 09:59:52 raspberrypi kernel: [54692.151533] Swap cache stats: add 27088, delete 26764, find 597/1024
            Mar 21 09:59:52 raspberrypi kernel: [54692.151541] Free swap  = 0kB
            Mar 21 09:59:52 raspberrypi kernel: [54692.151548] Total swap = 102396kB
            Mar 21 09:59:52 raspberrypi kernel: [54692.151556] 1012736 pages RAM
            Mar 21 09:59:52 raspberrypi kernel: [54692.151564] 0 pages HighMem/MovableOnly
            Mar 21 09:59:52 raspberrypi kernel: [54692.151571] 41210 pages reserved
            Mar 21 09:59:52 raspberrypi kernel: [54692.151578] 81920 pages cma reserved
            Mar 21 09:59:52 raspberrypi kernel: [54692.151586] Tasks state (memory values in pages):
            Mar 21 09:59:52 raspberrypi kernel: [54692.151594] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
            Mar 21 09:59:52 raspberrypi kernel: [54692.151621] [    138]     0   138     5310      224   143360      160             0 systemd-journal
            Mar 21 09:59:52 raspberrypi kernel: [54692.151632] [    160]     0   160     4657       51    49152      172         -1000 systemd-udevd
            Mar 21 09:59:52 raspberrypi kernel: [54692.151648] [    349]   100   349     5603       11    53248      157             0 systemd-timesyn
            Mar 21 09:59:52 raspberrypi kernel: [54692.151658] [    407]     0   407     3260       21    57344      150             0 systemd-logind
            Mar 21 09:59:52 raspberrypi kernel: [54692.151669] [    412]   104   412     1680       68    40960       73          -900 dbus-daemon
            Mar 21 09:59:52 raspberrypi kernel: [54692.151679] [    423]   108   423     1506      122    40960       46             0 avahi-daemon
            Mar 21 09:59:52 raspberrypi kernel: [54692.151691] [    430]     0   430     1986       11    40960       35             0 cron
            Mar 21 09:59:52 raspberrypi kernel: [54692.151701] [    433] 65534   433     1079        5    40960       40             0 thd
            Mar 21 09:59:52 raspberrypi kernel: [54692.151711] [    439]     0   439     2685       13    49152       89             0 wpa_supplicant
            Mar 21 09:59:52 raspberrypi kernel: [54692.151722] [    444]     0   444     6377       72    61440      159             0 rsyslogd
            Mar 21 09:59:52 raspberrypi kernel: [54692.151732] [    452]     0   452     6913        0    40960       30             0 rngd
            Mar 21 09:59:52 raspberrypi kernel: [54692.151742] [    460]   108   460     1441        6    36864       57             0 avahi-daemon
            Mar 21 09:59:52 raspberrypi kernel: [54692.151753] [    508]     0   508     2156        0    40960       57             0 vncserver-x11-s
            Mar 21 09:59:52 raspberrypi kernel: [54692.151764] [    525]     0   525     8825       34    90112      402             0 vncserver-x11-c
            Mar 21 09:59:52 raspberrypi kernel: [54692.151774] [    526]     0   526     1076        0    36864       25             0 agetty
            Mar 21 09:59:52 raspberrypi kernel: [54692.151784] [    527]     0   527     2681        2    49152      143         -1000 sshd
            Mar 21 09:59:52 raspberrypi kernel: [54692.151795] [    628]     0   628      534        1    28672       32             0 hciattach
            Mar 21 09:59:52 raspberrypi kernel: [54692.152590] [   4782]     0  4782     7351        1    73728      667             0 cupsd
            Mar 21 09:59:52 raspberrypi kernel: [54692.152610] [   4783]     0  4783    10123        0    77824      279             0 cups-browsed
            Mar 21 09:59:52 raspberrypi kernel: [54692.152623] [   4791]   114  4791    11944        0    86016      718             0 colord
            Mar 21 09:59:52 raspberrypi kernel: [54692.152637] [  11639]     0 11639     3059       22    49152      178             0 sshd
            Mar 21 09:59:52 raspberrypi kernel: [54692.152649] [  11642]  1000 11642     3682       92    57344      158             0 systemd
            Mar 21 09:59:52 raspberrypi kernel: [54692.152661] [  11643]  1000 11643     8842       76    73728      379             0 (sd-pam)
            Mar 21 09:59:52 raspberrypi kernel: [54692.152672] [  11657]  1000 11657     3092       48    53248      188             0 sshd
            Mar 21 09:59:52 raspberrypi kernel: [54692.152683] [  11658]  1000 11658      513        0    24576       49             0 sftp-server
            Mar 21 09:59:52 raspberrypi kernel: [54692.152694] [  11691]     0 11691     3059       25    49152      175             0 sshd
            Mar 21 09:59:52 raspberrypi kernel: [54692.152705] [  11697]  1000 11697     3059       55    49152      148             0 sshd
            Mar 21 09:59:52 raspberrypi kernel: [54692.152715] [  11698]  1000 11698     2119        2    40960      228             0 bash
            Mar 21 09:59:52 raspberrypi kernel: [54692.152728] [  11917]  1001 11917   669273   617733  6283264    14411             0 iobroker.js-con
            Mar 21 09:59:52 raspberrypi kernel: [54692.152739] [  11929]  1000 11929     2606       93    49152       43             0 top
            Mar 21 09:59:52 raspberrypi kernel: [54692.152750] [  11936]  1001 11936   216603   178212  3272704     1752             0 io.admin.0
            Mar 21 09:59:52 raspberrypi kernel: [54692.152761] [  11952]  1001 11952    43552     1956   585728     2594             0 io.email.0
            Mar 21 09:59:52 raspberrypi kernel: [54692.152771] [  11967]  1001 11967    44603     5406   610304       25             0 io.history.0
            Mar 21 09:59:52 raspberrypi kernel: [54692.152782] [  11978]  1001 11978    63452    21823  1044480       78             0 io.javascript.0
            Mar 21 09:59:52 raspberrypi kernel: [54692.152792] [  11993]  1001 11993    43540     4191   573440        1             0 io.pushover.0
            Mar 21 09:59:52 raspberrypi kernel: [54692.152803] [  11999]  1001 11999    45959     6225   651264       40             0 io.alexa2.0
            Mar 21 09:59:52 raspberrypi kernel: [54692.152814] [  12002]  1001 12002    44289     5382   593920       16             0 io.hue.0
            Mar 21 09:59:52 raspberrypi kernel: [54692.152825] [  12026]  1001 12026    47897     9516   749568       36             0 io.shelly.0
            Mar 21 09:59:52 raspberrypi kernel: [54692.152835] [  12028]  1001 12028    45810     6998   704512       31             0 io.shelly.1
            Mar 21 09:59:52 raspberrypi kernel: [54692.152845] [  12044]  1001 12044    45985     6906   696320       54             0 io.tr-064.0
            Mar 21 09:59:52 raspberrypi kernel: [54692.152856] [  12087]  1001 12087    49303    10040   815104       25             0 io.zigbee.0
            Mar 21 09:59:52 raspberrypi kernel: [54692.152866] [  12109]  1001 12109    43212     3952   577536        6             0 io.discovery.0
            Mar 21 09:59:52 raspberrypi kernel: [54692.152877] [  12124]  1001 12124    45483     6747   696320        8             0 io.backitup.0
            Mar 21 09:59:52 raspberrypi kernel: [54692.152889] [  12164]  1001 12164    44765     5353   667648       75             0 io.radar2.0
            Mar 21 09:59:52 raspberrypi kernel: [54692.152899] [  12172]  1001 12172    44677     5863   638976        8             0 io.info.0
            Mar 21 09:59:52 raspberrypi kernel: [54692.152968] [  12173]  1001 12173    45035     5408   655360      120             0 io.cloud.0
            Mar 21 09:59:52 raspberrypi kernel: [54692.152980] [  12186]  1001 12186    43349     4531   573440       16             0 io.text2command
            Mar 21 09:59:52 raspberrypi kernel: [54692.152998] [  12188]  1001 12188    51190    15675   880640       23             0 io.iot.0
            Mar 21 09:59:52 raspberrypi kernel: [54692.153015] [  12430]  1001 12430      484       14    28672        0             0 sh
            Mar 21 09:59:52 raspberrypi kernel: [54692.153027] [  12436]  1001 12436    30552     2832   352256        0             0 npm
            Mar 21 09:59:52 raspberrypi kernel: [54692.153038] [  12462]  1001 12462      484       13    32768        0             0 sh
            Mar 21 09:59:52 raspberrypi kernel: [54692.153052] [  12463]  1001 12463     7979     4260    90112        0             0 pip
            Mar 21 09:59:52 raspberrypi kernel: [54692.153065] [  12465]  1001 12465      484       14    32768        0             0 sh
            Mar 21 09:59:52 raspberrypi kernel: [54692.153076] [  12466]  1001 12466     7240     3047    86016        0             0 pip3
            Mar 21 09:59:52 raspberrypi kernel: [54692.153087] [  12502]  1001 12502     1026       72    32768        0             0 ping
            Mar 21 09:59:52 raspberrypi kernel: [54692.153100] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/,task=iobroker.js-con,pid=11917,uid=1001
            Mar 21 09:59:52 raspberrypi kernel: [54692.153207] Out of memory: Killed process 11917 (iobroker.js-con) total-vm:2677092kB, anon-rss:2470216kB, file-rss:716kB, shmem-rss:0kB, UID:1001 pgtables:6136kB oom_score_adj:0
            Mar 21 09:59:52 raspberrypi kernel: [54692.532210] oom_reaper: reaped process 11917 (iobroker.js-con), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
            Mar 21 09:59:53 raspberrypi systemd[1]: iobroker.service: Main process exited, code=killed, status=9/KILL
            Mar 21 10:00:09 raspberrypi systemd[1]: iobroker.service: Failed with result 'signal'.
            Mar 21 10:00:13 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
            Mar 21 10:00:13 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 1.
            Mar 21 10:00:13 raspberrypi systemd[1]: Stopped ioBroker Server.
            Mar 21 10:00:13 raspberrypi systemd[1]: Started ioBroker Server.
            Mar 21 10:00:17 raspberrypi bash[12504]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [starting]
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.email.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.history.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.javascript.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.pushover.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.alexa2.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.hue.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.owntracks.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.ping.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.shelly.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.shelly.1" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.tr-064.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.weatherunderground.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.zigbee.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.backitup.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.cloud.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.feiertage.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.info.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.iot.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.iqontrol.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.jarvis.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.lgtv.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.mercedesme.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.nina.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.pi-hole.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.radar2.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.tado.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.text2command.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.vis.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
            Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.schoolfree.0" for host "raspberrypi"
            Mar 21 10:00:21 raspberrypi bash[12504]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
            Mar 21 10:00:21 raspberrypi bash[12504]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
            Mar 21 10:00:34 raspberrypi bash[12504]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
            Mar 21 10:00:34 raspberrypi bash[12504]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
            Mar 21 10:01:00 raspberrypi bash[12504]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
            Mar 21 10:01:01 raspberrypi bash[12504]: Send diag info: {"uuid":"dbe50d02-68fa-f6f2-71c6-83f4ae4fc370","language":"de","country":"Germany","hosts":[{"version":"4.0.19","platform":"Javascript/Node.js","type":"linux"}],"node":"v14.19.1","arch":"arm","docker":false,"adapters":{"admin":{"version":"5.3.3","platform":"Javascript/Node.js"},"discovery":{"version":"2.8.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.3.5","platform":"Javascript/Node.js"},"alexa2":{"version":"3.12.0","platform":"Javascript/Node.js"},"cloud":{"version":"4.1.1","platform":"Javascript/Node.js"},"email":{"version":"1.0.10","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.0","platform":"Javascript/Node.js"},"flot":{"version":"1.10.7","platform":"javascript/Node.js"},"history":{"version":"1.11.0","platform":"Javascript/Node.js"},"hue":{"version":"3.6.5","platform":"Javascript/Node.js"},"info":{"version":"1.9.19","platform":"Javascript/Node.js"},"iot":{"version":"1.11.2","platform":"Javascript/Node.js"},"iqontrol":{"version":"2.0.1","platform":"Javascript/Node.js"},"jarvis":{"version":"3.0.11","platform":"Javascript/Node.js"},"javascript":{"version":"5.4.5","platform":"Javascript/Node.js"},"lgtv":{"version":"1.1.10","platform":"Javascript/Node.js"},"mercedesme":{"version":"0.0.56","platform":"Javascript/Node.js"},"nina":{"version":"0.0.25","platform":"Javascript/Node.js"},"owntracks":{"version":"1.0.1","platform":"Javascript/Node.js"},"pi-hole":{"version":"1.3.4","platform":"Javascript/Node.js"},"ping":{"version":"1.5.3","platform":"Javascript/Node.js"},"pushover":{"version":"2.1.0","platform":"Javascript/Node.js"},"radar2":{"version":"2.0.3","platform":"Javascript/Node.js"},"shelly":{"version":"5.3.2","platform":"Javascript/Node.js"},"simple-api":{"version":"2.6.3","platform":"Javascript/Node.js"},"socketio":{"version":"4.1.4","platform":"Javascript/Node.js"},"systeminfo":{"version":"0.3.1","platform":"Javascript/Node.js"},"tado":{"version":"0.3.15","platform":"Javascript/Node.js"},"text2command":{"version":"2.2.1","platform":"Javascript/Node.js"},"tr-064":{"version":"4.2.15","platform":"Javascript/Node.js"},"vis":{"version":"1.4.12","platform":"Javascript/Node.js"},"weatherunderground":{"version":"3.4.1","platform":"Javascript/Node.js"},"web":{"version":"4.2.1","platform":"Javascript/Node.js"},"ws":{"version":"1.2.0","platform":"Javascript/Node.js"},"zigbee":{"version":"1.6.16","platform":"Javascript/Node.js"},"schoolfree":{"version":"1.0.1","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":32,"compactMode":false,"noCompactInstances":0,"model":"unknown","cpus":4,"mem":3979370496,"ostype":"Linux","vis":12}
            Mar 21 10:01:38 raspberrypi bash[12504]: ================================== > LOG REDIRECT system.adapter.iot.0 => false [Process stopped]
            Mar 21 10:01:38 raspberrypi bash[12504]: ================================== > LOG REDIRECT system.adapter.cloud.0 => false [Process stopped]
            Mar 21 10:01:38 raspberrypi bash[12504]: ================================== > LOG REDIRECT system.adapter.iot.0 => false [system.adapter.iot.0.logging]
            Mar 21 10:01:39 raspberrypi bash[12504]: ================================== > LOG REDIRECT system.adapter.cloud.0 => false [system.adapter.cloud.0.logging]
            Mar 21 10:01:42 raspberrypi bash[12504]: Send diag info: {"uuid":"dbe50d02-68fa-f6f2-71c6-83f4ae4fc370","language":"de","country":"Germany","hosts":[{"version":"4.0.19","platform":"Javascript/Node.js","type":"linux"}],"node":"v14.19.1","arch":"arm","docker":false,"adapters":{"admin":{"version":"5.3.3","platform":"Javascript/Node.js"},"discovery":{"version":"2.8.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.3.5","platform":"Javascript/Node.js"},"alexa2":{"version":"3.12.0","platform":"Javascript/Node.js"},"cloud":{"version":"4.1.1","platform":"Javascript/Node.js"},"email":{"version":"1.0.10","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.0","platform":"Javascript/Node.js"},"flot":{"version":"1.10.7","platform":"javascript/Node.js"},"history":{"version":"1.11.0","platform":"Javascript/Node.js"},"hue":{"version":"3.6.5","platform":"Javascript/Node.js"},"info":{"version":"1.9.19","platform":"Javascript/Node.js"},"iot":{"version":"1.11.2","platform":"Javascript/Node.js"},"iqontrol":{"version":"2.0.1","platform":"Javascript/Node.js"},"jarvis":{"version":"3.0.11","platform":"Javascript/Node.js"},"javascript":{"version":"5.4.5","platform":"Javascript/Node.js"},"lgtv":{"version":"1.1.10","platform":"Javascript/Node.js"},"mercedesme":{"version":"0.0.56","platform":"Javascript/Node.js"},"nina":{"version":"0.0.25","platform":"Javascript/Node.js"},"owntracks":{"version":"1.0.1","platform":"Javascript/Node.js"},"pi-hole":{"version":"1.3.4","platform":"Javascript/Node.js"},"ping":{"version":"1.5.3","platform":"Javascript/Node.js"},"pushover":{"version":"2.1.0","platform":"Javascript/Node.js"},"radar2":{"version":"2.0.3","platform":"Javascript/Node.js"},"shelly":{"version":"5.3.2","platform":"Javascript/Node.js"},"simple-api":{"version":"2.6.3","platform":"Javascript/Node.js"},"socketio":{"version":"4.1.4","platform":"Javascript/Node.js"},"systeminfo":{"version":"0.3.1","platform":"Javascript/Node.js"},"tado":{"version":"0.3.15","platform":"Javascript/Node.js"},"text2command":{"version":"2.2.1","platform":"Javascript/Node.js"},"tr-064":{"version":"4.2.15","platform":"Javascript/Node.js"},"vis":{"version":"1.4.12","platform":"Javascript/Node.js"},"weatherunderground":{"version":"3.4.1","platform":"Javascript/Node.js"},"web":{"version":"4.2.1","platform":"Javascript/Node.js"},"ws":{"version":"1.2.0","platform":"Javascript/Node.js"},"zigbee":{"version":"1.6.16","platform":"Javascript/Node.js"},"schoolfree":{"version":"1.0.1","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":32,"compactMode":false,"noCompactInstances":0,"model":"unknown","cpus":4,"mem":3979370496,"ostype":"Linux","vis":12}
            Mar 21 10:05:01 raspberrypi kernel: [55008.133171] device eth0 entered promiscuous mode
            Mar 21 10:05:01 raspberrypi kernel: [55008.150810] device eth0 left promiscuous mode
            Mar 21 10:05:04 raspberrypi kernel: [55010.224024] CIFS: Attempting to mount //xxx.xxx.xxx.xxx/ioBrokerBackup/ioBroker
            Mar 21 10:05:05 raspberrypi kernel: [55011.621251] CIFS: Attempting to mount //xxx.xxx.xxx.xxx/ioBrokerBackup/ioBroker
            Mar 21 10:05:05 raspberrypi kernel: [55011.621322] CIFS: No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3.1.1), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3.1.1 (or even SMB3 or SMB2.1) specify vers=1.0 on mount.
            Mar 21 10:05:15 raspberrypi systemd[1]: opt-iobroker-backups.mount: Succeeded.
            Mar 21 10:05:15 raspberrypi systemd[11642]: opt-iobroker-backups.mount: Succeeded.
            jfyi: Der js-controller läuft immer noch auf 100%
            • T Th3RockYeah
              DiginixD
              DiginixD
              Diginix
              Dem geht der RAM aus.
              ..:: So long! Tom ::..
              • DiginixD Diginix
                T
                T
                Th3RockYeah
                @diginix Aktuell "frisst" der JS-Controller auch permanent. zB 58,7% MEM
                • apollon77A
                  apollon77A
                  Genau wie @Diginix schreibt ... irgendwas ist passiert und der js-controller
                  wurde wegen RAM issues vom System gekillt.
                  Welche mqtt Version hast Du drauf? Beta oder Stable?
                  Bei javsscript habe ich oben gesehen das eine Logzeile doppelt kam ... was auch nicht sein sollte
                  Ich schlage Dir folgendes vor.
                  • Stoppe iobroker
                  • schau das wirklich alles weg ist
                  • setze (falls nicht geschehen) die connectTimeout hoch das idealerweise CLI wieder tut. Hattest Du gesagt wie groß die jsonl Files sind?
                  • dann per cli mit "iob stop adapter.X" alle instanzen stoppen, ausser admin.0
                  • Dann iobroker starten ... wie geht es ihm dann? Schauen das Admin wieder lädt und mal durch die objekte schauen wo vlt diese massen herkommen
                  • Dann einen adapter nach dem anderen starten und immer schauen was passiert. sobald es wieder anfängt den Adapter stoppen und schauen ob dann ruhiger wird.
                  • T Th3RockYeah
                    @th3rockyeah
                    Teil 2
                    es ist fortführend...
                    2022-03-21 10:03:43.856 - info: javascript.0 (12683) received all objects
                    2022-03-21 10:03:45.047 - info: javascript.0 (12683) received all states
                    2022-03-21 10:03:45.386 - info: javascript.0 (12683) Start javascript script.js.common.BatteryCheck
                    2022-03-21 10:03:45.451 - info: host.raspberrypi instance system.adapter.radar2.0 started with pid 12924
                    2022-03-21 10:03:45.514 - info: javascript.0 (12683) script.js.common.BatteryCheck: starting Batterieüberwachung V.1.8.5
                    2022-03-21 10:03:45.520 - info: javascript.0 (12683) script.js.common.BatteryCheck: registered 0 subscriptions and 0 schedules
                    2022-03-21 10:03:45.603 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 12930
                    2022-03-21 10:03:45.683 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 12937
                    2022-03-21 10:03:45.533 - info: javascript.0 (12683) Start javascript script.js.common.BewegungsmelderV2
                    2022-03-21 10:03:45.561 - info: javascript.0 (12683) script.js.common.BewegungsmelderV2: *** Bewegungsmelder-Script gestartet *** Folgende Bewegungsmelder werden überwacht: BadGaeste, SchlafzimmerNew, Laundry, BadFirstFloor, FirstFloorLightNew, FirstFloorLightTom, StairsToFirstFloor, BeerCellar, ToolCellar, CellarFloor, StepToCellarFloor, AlarmTest3
                    2022-03-21 10:03:45.567 - info: javascript.0 (12683) script.js.common.BewegungsmelderV2: registered 12 subscriptions and 0 schedules
                    2022-03-21 10:03:45.569 - info: javascript.0 (12683) Start javascript script.js.common.CommonMix
                    2022-03-21 10:03:45.577 - info: javascript.0 (12683) script.js.common.CommonMix: registered 8 subscriptions and 0 schedules
                    2022-03-21 10:03:45.578 - info: javascript.0 (12683) Start javascript script.js.common.FritzBox
                    2022-03-21 10:03:45.584 - info: javascript.0 (12683) script.js.common.FritzBox: registered 1 subscription and 0 schedules
                    2022-03-21 10:03:45.585 - info: javascript.0 (12683) Start javascript script.js.common.LeavingHouse
                    2022-03-21 10:03:45.608 - info: javascript.0 (12683) script.js.common.LeavingHouse: registered 2 subscriptions and 0 schedules
                    2022-03-21 10:03:45.610 - info: javascript.0 (12683) Start javascript script.js.common.OpenDoorsWindows
                    2022-03-21 10:03:45.659 - info: javascript.0 (12683) script.js.common.OpenDoorsWindows: registered 0 subscriptions and 0 schedules
                    2022-03-21 10:03:45.660 - info: javascript.0 (12683) Start javascript script.js.common.Shellys
                    2022-03-21 10:03:45.680 - info: javascript.0 (12683) script.js.common.Shellys: registered 9 subscriptions and 0 schedules
                    2022-03-21 10:03:45.807 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 12944
                    2022-03-21 10:03:45.872 - info: host.raspberrypi instance system.adapter.iot.0 started with pid 12946
                    2022-03-21 10:03:45.979 - info: host.raspberrypi instance system.adapter.cloud.0 started with pid 12957
                    2022-03-21 10:03:46.064 - info: host.raspberrypi instance system.adapter.info.0 started with pid 12961
                    2022-03-21 10:03:46.120 - info: host.raspberrypi instance system.adapter.text2command.0 started with pid 12966
                    2022-03-21 10:03:46.357 - info: javascript.0 (12683) script.js.common.OpenDoorsWindows: Alle Fenster geschlossen.
                    2022-03-21 10:03:59.998 - warn: discovery.0 (12937) slow connection to objects DB. Still waiting ...
                    2022-03-21 10:04:00.427 - warn: text2command.0 (12966) slow connection to objects DB. Still waiting ...
                    2022-03-21 10:04:00.527 - warn: radar2.0 (12924) slow connection to objects DB. Still waiting ...
                    2022-03-21 10:04:00.805 - warn: iot.0 (12946) slow connection to objects DB. Still waiting ...
                    2022-03-21 10:04:00.827 - warn: backitup.0 (12944) slow connection to objects DB. Still waiting ...
                    2022-03-21 10:04:00.965 - warn: cloud.0 (12957) slow connection to objects DB. Still waiting ...
                    2022-03-21 10:04:02.625 - warn: info.0 (12961) slow connection to objects DB. Still waiting ...
                    2022-03-21 10:04:02.633 - warn: zigbee.0 (12930) slow connection to objects DB. Still waiting ...
                    2022-03-21 10:04:54.290 - info: feiertage.0 (12747) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v14.19.1, js-controller: 4.0.19
                    2022-03-21 10:04:58.146 - info: feiertage.0 (12747) Next holiday: Karfreitag is in 25 days on 15.04.2022
                    2022-03-21 10:04:58.476 - info: tr-064.0 (12889) starting. Version 4.2.15 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.19.1, js-controller: 4.0.19
                    2022-03-21 10:04:58.744 - info: feiertage.0 (12747) adapter feiertage objects written
                    2022-03-21 10:04:59.180 - info: schoolfree.0 (12878) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.schoolfree, node: v14.19.1, js-controller: 4.0.19
                    2022-03-21 10:04:59.320 - info: feiertage.0 (12747) Terminated (NO_ERROR): Without reason
                    2022-03-21 10:04:59.385 - info: shelly.0 (12768) Starting in CoAP mode.
                    2022-03-21 10:04:59.630 - info: shelly.0 (12768) [CoAP] Listening for packets in the network
                    2022-03-21 10:04:59.709 - info: shelly.1 (12777) Starting in MQTT mode. Listening on Y.X.C..31:1882
                    2022-03-21 10:04:59.767 - info: radar2.0 (12924) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.radar2, node: v14.19.1, js-controller: 4.0.19
                    2022-03-21 10:04:59.713 - warn: schoolfree.0 (12878) schoolfree set state error: TypeError: Cannot read property 'name' of undefined
                    2022-03-21 10:05:00.167 - info: shelly.0 (12768) [CoAP] Device Y.X.C..28 (shelly1pm / shelly1pm-F27634 / SHSW-PM#F27634#1) connected! Polltime set to 5 sec.
                    2022-03-21 10:05:00.437 - info: schoolfree.0 (12878) schoolfree request done
                    2022-03-21 10:05:00.485 - info: shelly.0 (12768) [CoAP] Device Y.X.C..47 (shellydimmer / shellydimmer-D463D3 / SHDM-1#D463D3#1) connected! Polltime set to 5 sec.
                    2022-03-21 10:05:00.754 - info: radar2.0 (12924) radar2 initialization started...
                    2022-03-21 10:05:00.800 - info: radar2.0 (12924) Will use l2Ping for BT scans.
                    2022-03-21 10:05:00.893 - info: radar2.0 (12924) Will run hcitool-mode and not noble on device []!
                    2022-03-21 10:05:01.103 - info: host.raspberrypi instance system.adapter.feiertage.0 terminated with code 0 (NO_ERROR)
                    2022-03-21 10:05:01.190 - info: radar2.0 (12924) arp-scan will use the following interfaces: [ 'eth0' ]
                    2022-03-21 10:05:01.217 - info: radar2.0 (12924) Connected with '0.0.0.0' for DHCP Scan
                    2022-03-21 10:05:02.201 - info: text2command.0 (12966) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.text2command, node: v14.19.1, js-controller: 4.0.19
                    2022-03-21 10:05:02.412 - info: discovery.0 (12937) starting. Version 2.8.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.19.1, js-controller: 4.0.19
                    2022-03-21 10:05:02.476 - info: cloud.0 (12957) starting. Version 4.1.1 in /opt/iobroker/node_modules/iobroker.cloud, node: v14.19.1, js-controller: 4.0.19
                    2022-03-21 10:05:02.660 - info: zigbee.0 (12930) starting. Version 1.6.16 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.19
                    2022-03-21 10:05:03.212 - info: backitup.0 (12944) starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.1, js-controller: 4.0.19
                    2022-03-21 10:05:03.240 - info: cloud.0 (12957) Connecting with https://iobroker.pro:10555 with "@pro_lars@lars-keller.net_a56c8fe0-59a6-11ea-bbb9-a3d45e2d176f"
                    2022-03-21 10:05:03.339 - info: iot.0 (12946) starting. Version 1.11.2 in /opt/iobroker/node_modules/iobroker.iot, node: v14.19.1, js-controller: 4.0.19
                    2022-03-21 10:05:03.452 - info: backitup.0 (12944) [iobroker] backup was activated at 02:53 every 1 day(s)
                    2022-03-21 10:05:03.517 - info: iot.0 (12946) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                    2022-03-21 10:05:02.984 - info: zigbee.0 (12930) Starting Zigbee npm ...
                    2022-03-21 10:05:03.929 - info: shelly.0 (12768) [CoAP] Device Y.X.C..36 (shelly1 / shelly1-98F4ABF3CF6C / SHSW-1#98F4ABF3CF6C#1) connected! Polltime set to 5 sec.
                    2022-03-21 10:05:04.474 - info: iot.0 (12946) Connection changed: connect
                    2022-03-21 10:05:04.982 - info: zigbee.0 (12930) Installed Version: ioBroker/ioBroker.zigbee
                    2022-03-21 10:05:05.086 - info: shelly.0 (12768) [CoAP] Device Y.X.C..67 (shellydimmer / shellydimmer-D3E31B / SHDM-1#D3E31B#1) connected! Polltime set to 5 sec.
                    2022-03-21 10:05:05.100 - info: cloud.0 (12957) Trying to connect as system.user.admin
                    2022-03-21 10:05:05.152 - info: zigbee.0 (12930) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20211217}}
                    2022-03-21 10:05:05.171 - info: zigbee.0 (12930) Unable to disable LED, unsupported function.
                    2022-03-21 10:05:05.181 - info: shelly.0 (12768) [CoAP] Device Y.X.C..44 (shellyplug-s / shellyplug-s-DE15FC / SHPLG-S#DE15FC#1) connected! Polltime set to 5 sec.
                    2022-03-21 10:05:05.224 - info: zigbee.0 (12930) --> transmitPower : normal
                    2022-03-21 10:05:05.254 - info: zigbee.0 (12930) Currently 53 devices are joined:
                    2022-03-21 10:05:05.568 - error: backitup.0 (12944) Error: Command failed: sudo mount -t cifs -o username=iobrokerUser,password=****,rw,file_mode=0777,dir_mode=0777 //Y.X.C..109/ioBrokerBackup/ioBroker /opt/iobroker/backups
                    mount error(16): Device or resource busy
                    Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                    2022-03-21 10:05:05.619 - info: shelly.0 (12768) [CoAP] Device Y.X.C..32 (shellyplug-s / shellyplug-s-8D010E / SHPLG-S#8D010E#1) connected! Polltime set to 5 sec.
                    2022-03-21 10:05:05.977 - info: zigbee.0 (12930) 0x00158d0007b7ddc0 (addr 51404): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                    2022-03-21 10:05:05.979 - info: zigbee.0 (12930) 0x000d6ffffea61fe1 (addr 8521): E1746 - IKEA TRADFRI signal repeater (Router)
                    2022-03-21 10:05:05.980 - info: zigbee.0 (12930) Zigbee started
                    2022-03-21 10:05:06.418 - info: shelly.0 (12768) [CoAP] Device Y.X.C..30 (shelly1 / shelly1-767AC8 / SHSW-1#767AC8#1) connected! Polltime set to 5 sec.
                    2022-03-21 10:05:07.055 - info: shelly.0 (12768) [CoAP] Device Y.X.C..33 (shellyplug-s / shellyplug-s-80116A / SHPLG-S#80116A#1) connected! Polltime set to 5 sec.
                    2022-03-21 10:05:07.606 - warn: zigbee.0 (12930) DeviceAvailability:Failed to ping 0x680ae2fffe9c8577 TRADFRI Signal Repeater
                    2022-03-21 10:05:07.612 - warn: zigbee.0 (12930) DeviceAvailability:Failed to ping 0x000d6ffffe2e4a54 TRADFRI signal repeater
                    2022-03-21 10:05:08.159 - info: shelly.1 (12777) [MQTT] Device Y.X.C..104 (shellyplus1 / shellyplus1-a8032abeb1e4 / shellyplus1#a8032abeb1e4#1) connected! Polltime set to 5 sec.
                    2022-03-21 10:05:08.487 - info: shelly.0 (12768) [CoAP] Device Y.X.C..110 (shellyplug-s / shellyplug-s-4BA36E / SHPLG2-1#4BA36E#1) connected! Polltime set to 5 sec.
                    2022-03-21 10:05:08.734 - info: radar2.0 (12924) Init item YYYY with {name: 'YYYY',bluetooth: [],enabled: -1,id: 'YYYY',type: 'IP',hasMAC: [ '9a:ce:10:0a:71:2e' ],ipVendor: 'N/A',rip: [ 'Y.X.C..114' ],lasthere: '2022-03-21T05:14:19.102Z'}
                    2022-03-21 10:05:08.998 - error: cloud.0 (12957) Cloud says: timeout
                    2022-03-21 10:05:09.496 - info: shelly.0 (12768) [CoAP] Device Y.X.C..38 (shellydimmer2 / shellydimmer2-D8BFC019EECE / SHDM-2#D8BFC019EECE#1) connected! Polltime set to 5 sec.
                    2022-03-21 10:05:10.005 - info: cloud.0 (12957) Connection changed: io server disconnect
                    2022-03-21 10:05:10.505 - info: shelly.0 (12768) [CoAP] Device Y.X.C..29 (shelly1pm / shelly1pm-F27119 / SHSW-PM#F27119#1) connected! Polltime set to 5 sec.
                    2022-03-21 10:05:10.772 - info: info.0 (12961) starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v14.19.1, js-controller: 4.0.19
                    2022-03-21 10:05:11.032 - info: info.0 (12961) Reading/updating systemdata.
                    2022-03-21 10:05:13.277 - info: shelly.0 (12768) [CoAP] Device Y.X.C..98 (shellyplug-s / shellyplug-s-E435C4 / SHPLG-S#E435C4#1) connected! Polltime set to 5 sec.
                    2022-03-21 10:05:13.542 - info: shelly.0 (12768) [CoAP] Device Y.X.C..39 (shellyplug-s / shellyplug-s-B4B41F / SHPLG-S#B4B41F#1) connected! Polltime set to 5 sec.
                    2022-03-21 10:05:14.158 - info: shelly.0 (12768) [CoAP] Device Y.X.C..24 (shellyplug-s / shellyplug-s-577BFA / SHPLG-S#577BFA#1) connected! Polltime set to 5 sec.
                    2022-03-21 10:05:14.529 - info: info.0 (12961) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
                    2022-03-21 10:05:15.380 - info: info.0 (12961) State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
                    2022-03-21 10:05:15.533 - info: info.0 (12961) State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
                    2022-03-21 10:05:15.621 - info: info.0 (12961) State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
                    2022-03-21 10:05:15.725 - info: info.0 (12961) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
                    2022-03-21 10:05:16.578 - info: info.0 (12961) cpu Temp res = {"main":75.471,"cores":[],"max":75.471,"socket":[],"chipset":null}
                    2022-03-21 10:05:17.656 - info: info.0 (12961) State value to set for "info.0.sysinfo.memory.memLayout.ram0.ecc" has to be stringified but received type "boolean"
                    2022-03-21 10:05:18.108 - info: radar2.0 (12924) Init item XXX with {name: 'XXX',bluetooth: [],enabled: -1,id: 'XXX',type: 'IP',hasMAC: [ 'IPV6' ],ipVendor: 'N/A',rip: [ 'Y.X.C.V' ],lasthere: '2021-12-14T03:02:35.263Z'}
                    2022-03-21 10:05:18.497 - info: radar2.0 (12924) Init item CCC with {name: 'CCC',bluetooth: [],enabled: -1,id: 'CCC',type: 'IP',hasMAC: [ 'IPV6' ],ipVendor: 'N/A',rip: [ 'Y.X.C.V' ],lasthere: '2022-03-21T08:59:12.329Z'}
                    2022-03-21 10:05:18.501 - info: radar2.0 (12924) Adapter identified macs: (IPV6),
                    ips: (Y.X.C.V,Y.X.C.V,Y.X.C.V),
                    bts LE: (),
                    bts norm: ()
                    2022-03-21 10:05:18.828 - info: radar2.0 (12924) radar2 found 3 devices in config (XXX,YYY,CCC) and 3 enabled.
                    2022-03-21 10:05:18.830 - info: radar2.0 (12924) radar2 set use of noble(false), doArp("-lgq --retry=5 --timeout=400" on eth0), btid(-1) and doUwz(undefined,30,0,de,true).
                    2022-03-21 10:05:31.945 - info: schoolfree.0 (12878) Terminated (NO_ERROR): Without reason
                    2022-03-21 10:05:38.446 - error: cloud.0 (12957) Cloud says: timeout
                    2022-03-21 10:06:08.453 - error: cloud.0 (12957) Cloud says: timeout
                    2022-03-21 10:06:38.469 - error: cloud.0 (12957) Cloud says: timeout
                    2022-03-21 10:06:41.946 - warn: schoolfree.0 (12878) get state error: Connection is closed.
                    2022-03-21 10:06:41.948 - warn: schoolfree.0 (12878) get state error: DB closed
                    2022-03-21 10:06:41.949 - warn: schoolfree.0 (12878) get state error: DB closed
                    2022-03-21 10:06:41.950 - warn: schoolfree.0 (12878) get state error: DB closed
                    2022-03-21 10:06:41.951 - warn: schoolfree.0 (12878) get state error: DB closed
                    2022-03-21 10:06:41.952 - warn: schoolfree.0 (12878) get state error: DB closed
                    2022-03-21 10:06:41.953 - warn: schoolfree.0 (12878) get state error: DB closed
                    2022-03-21 10:06:41.954 - warn: schoolfree.0 (12878) get state error: DB closed
                    2022-03-21 10:06:41.955 - warn: schoolfree.0 (12878) get state error: DB closed
                    2022-03-21 10:06:41.956 - warn: schoolfree.0 (12878) get state error: DB closed
                    2022-03-21 10:06:43.427 - info: cloud.0 (12957) Trying to connect as system.user.admin
                    2022-03-21 10:06:43.429 - info: cloud.0 (12957) Trying to connect as system.user.admin
                    2022-03-21 10:06:43.431 - info: cloud.0 (12957) Trying to connect as system.user.admin
                    2022-03-21 10:06:43.874 - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 13310
                    2022-03-21 10:06:44.533 - info: host.raspberrypi instance system.adapter.schoolfree.0 terminated with code 0 (NO_ERROR)
                    2022-03-21 10:06:47.598 - info: radar2.0 (12924) first scan took 88.765 seconds
                    2022-03-21 10:06:47.601 - warn: radar2.0 (12924) scanDelay increased to 90.765 seconds, delayAway to 4 minutes!
                    2022-03-21 10:06:48.192 - info: weatherunderground.0 (13310) starting. Version 3.4.1 (non-npm: iobroker-community-adapters/ioBroker.weatherunderground) in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v14.19.1, js-controller: 4.0.19
                    2022-03-21 10:06:48.209 - info: radar2.0 (12924) Adapter initialization finished!
                    2022-03-21 10:07:03.303 - info: cloud.0 (12957) Trying to connect as system.user.admin
                    2022-03-21 10:07:03.460 - info: cloud.0 (12957) Connection changed: connect
                    2022-03-21 10:07:03.494 - info: cloud.0 (12957) Adapter redirected temporally to "https://iobroker.pro:10556" in 30 seconds. Reason: command from server
                    2022-03-21 10:07:05.559 - error: backitup.0 (12944) umount: /opt/iobroker/backups: not mounted.
                    2022-03-21 10:10:20.992 - info: cloud.0 (12957) Trying to connect as system.user.admin
                    2022-03-21 10:10:20.994 - info: cloud.0 (12957) Trying to connect as system.user.admin
                    2022-03-21 10:10:20.995 - info: cloud.0 (12957) Trying to connect as system.user.admin
                    2022-03-21 10:27:49.612 - info: cloud.0 (12957) Trying to connect as system.user.admin
                    2022-03-21 10:27:49.615 - info: cloud.0 (12957) Trying to connect as system.user.admin
                    2022-03-21 10:27:49.616 - info: cloud.0 (12957) Trying to connect as system.user.admin
                    2022-03-21 10:29:04.597 - info: cloud.0 (12957) Trying to connect as system.user.admin
                    2022-03-21 10:29:05.276 - info: cloud.0 (12957) Connection changed: connect
                    2022-03-21 10:29:15.627 - error: info.0 (12961) States database error: read ECONNRESET
                    2022-03-21 10:29:15.609 - error: alexa2.0 (12723) States database error: read ECONNRESET
                    2022-03-21 10:29:15.625 - error: weatherunderground.0 (13310) States database error: read ECONNRESET
                    2022-03-21 10:29:15.630 - error: discovery.0 (12937) States database error: read ECONNRESET
                    2022-03-21 10:29:15.628 - error: shelly.1 (12777) States database error: read ECONNRESET
                    2022-03-21 10:29:15.629 - error: text2command.0 (12966) States database error: read ECONNRESET
                    2022-03-21 10:29:15.609 - error: zigbee.0 (12930) States database error: read ECONNRESET
                    2022-03-21 10:29:15.632 - error: email.0 (12636) States database error: read ECONNRESET
                    2022-03-21 10:29:15.640 - error: history.0 (12669) States database error: read ECONNRESET
                    2022-03-21 10:29:15.624 - error: pushover.0 (12697) States database error: read ECONNRESET
                    2022-03-21 10:29:15.631 - error: tr-064.0 (12889) States database error: read ECONNRESET
                    2022-03-21 10:29:15.633 - error: cloud.0 (12957) States database error: read ECONNRESET
                    2022-03-21 10:29:15.684 - error: alexa2.0 (12723) Objects database error: read ECONNRESET
                    2022-03-21 10:29:15.684 - error: shelly.1 (12777) Objects database error: read ECONNRESET
                    2022-03-21 10:29:15.633 - error: backitup.0 (12944) States database error: read ECONNRESET
                    2022-03-21 10:29:15.693 - error: zigbee.0 (12930) Objects database error: read ECONNRESET
                    2022-03-21 10:29:15.644 - error: radar2.0 (12924) States database error: write ECONNRESET
                    2022-03-21 10:29:15.697 - error: weatherunderground.0 (13310) Objects database error: read ECONNRESET
                    2022-03-21 10:29:15.634 - error: hue.0 (12760) States database error: read ECONNRESET
                    2022-03-21 10:29:15.714 - error: cloud.0 (12957) Objects database error: read ECONNRESET
                    2022-03-21 10:29:15.640 - error: iot.0 (12946) States database error: read ECONNRESET
                    2022-03-21 10:29:15.913 - info: zigbee.0 (12930) cleaned everything up...
                    2022-03-21 10:29:15.910 - info: info.0 (12961) cleaned everything up...
                    2022-03-21 10:29:15.912 - info: backitup.0 (12944) cleaned everything up...
                    2022-03-21 10:29:15.914 - info: shelly.1 (12777) Closing Adapter
                    2022-03-21 10:29:15.923 - error: shelly.0 (12768) Objects database error: write ECONNRESET
                    2022-03-21 10:29:15.942 - error: shelly.0 (12768) States database error: read ECONNRESET
                    2022-03-21 10:29:15.957 - info: cloud.0 (12957) Connection changed: io client disconnect
                    2022-03-21 10:29:15.958 - info: cloud.0 (12957) Connection lost
                    2022-03-21 10:29:15.953 - info: shelly.0 (12768) Closing Adapter
                    2022-03-21 10:29:16.073 - info: iot.0 (12946) Connection changed: disconnect
                    2022-03-21 10:29:16.075 - info: iot.0 (12946) Connection lost
                    2022-03-21 10:29:16.089 - info: radar2.0 (12924) Unload adapter now with null
                    2022-03-21 10:29:16.091 - info: radar2.0 (12924) Adapter disconnected and stopped with dostop(null) and callback(true)
                    2022-03-21 10:29:16.163 - info: zigbee.0 (12930) Zigbee: disabling joining new devices.
                    2022-03-21 10:29:16.134 - error: admin.0 (12617) States database error: read ECONNRESET
                    2022-03-21 10:29:16.269 - error: javascript.0 (12683) States database error: write ECONNRESET
                    2022-03-21 10:29:16.274 - error: javascript.0 (12683) Objects database error: read ECONNRESET
                    2022-03-21 10:29:16.280 - info: javascript.0 (12683) Stop script script.js.common.BatteryCheck
                    2022-03-21 10:29:16.284 - info: javascript.0 (12683) Stop script script.js.common.BewegungsmelderV2
                    2022-03-21 10:29:16.286 - info: javascript.0 (12683) Stop script script.js.common.CommonMix
                    2022-03-21 10:29:16.287 - info: javascript.0 (12683) Stop script script.js.common.FritzBox
                    2022-03-21 10:29:16.287 - info: javascript.0 (12683) Stop script script.js.common.LeavingHouse
                    2022-03-21 10:29:16.288 - info: javascript.0 (12683) Stop script script.js.common.OpenDoorsWindows
                    2022-03-21 10:29:16.290 - info: javascript.0 (12683) Stop script script.js.common.Shellys
                    2022-03-21 10:29:16.230 - error: admin.0 (12617) Objects database error: read ECONNRESET
                    2022-03-21 10:29:16.334 - info: admin.0 (12617) terminating http server on port 8081
                    2022-03-21 10:29:16.928 - error: radar2.0 (12924) uncaught exception: Cannot read property 'init' of null
                    2022-03-21 10:29:16.929 - error: radar2.0 (12924) TypeError: Cannot read property 'init' of null
                    at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.radar2/myNetworks.js:964:82)
                    at listOnTimeout (internal/timers.js:557:17)
                    at processTimers (internal/timers.js:500:7)
                    2022-03-21 10:29:16.930 - error: radar2.0 (12924) Cannot read property 'init' of null
                    2022-03-21 10:29:16.931 - warn: radar2.0 (12924) Uncaught Exception: Cannot read property 'init' of null
                    2022-03-21 10:29:17.409 - info: email.0 (12636) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2022-03-21 10:29:17.412 - info: discovery.0 (12937) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2022-03-21 10:29:17.414 - info: weatherunderground.0 (13310) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2022-03-21 10:29:17.414 - info: pushover.0 (12697) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2022-03-21 10:29:17.415 - info: text2command.0 (12966) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2022-03-21 10:29:17.418 - info: info.0 (12961) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2022-03-21 10:29:17.418 - info: zigbee.0 (12930) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2022-03-21 10:29:17.420 - info: backitup.0 (12944) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2022-03-21 10:29:17.423 - info: tr-064.0 (12889) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2022-03-21 10:29:17.423 - info: shelly.1 (12777) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2022-03-21 10:29:17.433 - info: iot.0 (12946) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2022-03-21 10:29:17.457 - info: shelly.0 (12768) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2022-03-21 10:29:17.462 - info: cloud.0 (12957) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2022-03-21 10:29:17.463 - info: alexa2.0 (12723) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2022-03-21 10:29:17.589 - info: radar2.0 (12924) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2022-03-21 10:29:17.780 - info: javascript.0 (12683) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2022-03-21 10:29:17.847 - info: admin.0 (12617) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2022-03-21 10:29:20.699 - error: shelly.1 (12777) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2022-03-21 10:29:20.702 - warn: info.0 (12961) get state error: DB closed
                    2022-03-21 10:29:20.717 - error: discovery.0 (12937) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2022-03-21 10:29:20.724 - error: alexa2.0 (12723) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2022-03-21 10:29:20.751 - error: weatherunderground.0 (13310) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2022-03-21 10:29:20.753 - error: backitup.0 (12944) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2022-03-21 10:29:20.767 - error: zigbee.0 (12930) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2022-03-21 10:29:20.749 - warn: radar2.0 (12924) get state error: Connection is closed.
                    2022-03-21 10:29:20.753 - error: hue.0 (12760) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2022-03-21 10:29:20.763 - error: cloud.0 (12957) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2022-03-21 10:29:20.775 - warn: tr-064.0 (12889) get state error: DB closed
                    2022-03-21 10:29:20.797 - warn: email.0 (12636) get state error: DB closed
                    2022-03-21 10:29:20.710 - warn: shelly.1 (12777) get state error: DB closed
                    2022-03-21 10:29:20.807 - warn: pushover.0 (12697) get state error: DB closed
                    2022-03-21 10:29:20.816 - error: text2command.0 (12966) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2022-03-21 10:29:20.849 - error: history.0 (12669) States database error: connect ECONNREFUSED 127.0.0.1:9000
                    2022-03-21 10:29:20.884 - warn: weatherunderground.0 (13310) get state error: DB closed
                    2022-03-21 10:29:20.887 - error: history.0 (12669) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2022-03-21 10:29:20.920 - error: iot.0 (12946) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2022-03-21 10:29:20.947 - error: shelly.0 (12768) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2022-03-21 10:29:20.992 - warn: shelly.0 (12768) get state error: Connection is closed.
                    2022-03-21 10:29:20.798 - warn: shelly.1 (12777) get state error: DB closed
                    2022-03-21 10:29:20.845 - warn: shelly.1 (12777) redis get shelly.1.SHPLG-S#C383EB#1.online, error - DB closed
                    2022-03-21 10:29:20.846 - warn: shelly.1 (12777) get state error: DB closed
                    2022-03-21 10:29:20.847 - warn: shelly.1 (12777) get state error: DB closed
                    2022-03-21 10:29:20.961 - warn: shelly.1 (12777) get state error: DB closed
                    2022-03-21 10:29:20.962 - warn: shelly.1 (12777) get state error: DB closed
                    2022-03-21 10:29:20.982 - warn: shelly.1 (12777) redis get shelly.1.SHSW-1#98F4ABF3CF6C#1.hostname, error - DB closed
                    2022-03-21 10:29:20.983 - warn: shelly.1 (12777) redis get shelly.1.SHPLG-S#DE15FC#1.online, error - DB closed
                    2022-03-21 10:29:20.984 - warn: shelly.1 (12777) get state error: DB closed
                    2022-03-21 10:29:20.985 - warn: shelly.1 (12777) get state error: DB closed
                    2022-03-21 10:29:20.986 - warn: shelly.1 (12777) get state error: DB closed
                    2022-03-21 10:29:20.987 - warn: shelly.1 (12777) get state error: DB closed
                    2022-03-21 10:29:20.988 - warn: shelly.1 (12777) get state error: DB closed
                    2022-03-21 10:29:20.989 - warn: shelly.1 (12777) get state error: DB closed
                    2022-03-21 10:29:21.085 - warn: shelly.1 (12777) redis get shelly.1.SHSW-PM#F27119#1.hostname, error - Connection is closed.
                    2022-03-21 10:29:21.125 - warn: shelly.1 (12777) redis get shelly.1.SHSW-PM#F27634#1.hostname, error - Connection is closed.
                    2022-03-21 10:29:21.127 - warn: shelly.1 (12777) redis get shelly.1.shellyplus1#a8032abeb1e4#1.hostname, error - Connection is closed.
                    2022-03-21 10:29:21.140 - warn: shelly.1 (12777) redis get shelly.1.undefined#undefined#1.hostname, error - Connection is closed.
                    2022-03-21 10:29:21.151 - warn: shelly.1 (12777) setTimeout called, but adapter is shutting down
                    2022-03-21 10:29:20.969 - warn: iot.0 (12946) get state error: DB closed
                    2022-03-21 10:29:20.970 - warn: iot.0 (12946) get state error: DB closed
                    2022-03-21 10:29:20.972 - warn: iot.0 (12946) get state error: DB closed
                    2022-03-21 10:29:21.263 - warn: iot.0 (12946) get state error: DB closed
                    2022-03-21 10:29:21.264 - warn: iot.0 (12946) get state error: DB closed
                    2022-03-21 10:29:21.265 - warn: iot.0 (12946) get state error: DB closed
                    2022-03-21 10:29:21.266 - warn: iot.0 (12946) get state error: DB closed
                    2022-03-21 10:29:21.367 - error: javascript.0 (12683) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2022-03-21 10:29:21.417 - error: admin.0 (12617) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2022-03-21 10:29:20.993 - warn: shelly.0 (12768) get state error: DB closed
                    2022-03-21 10:29:21.687 - warn: shelly.0 (12768) redis get shelly.0.SHPLG-S#DE15FC#1.online, error - DB closed
                    2022-03-21 10:29:21.688 - warn: shelly.0 (12768) get state error: DB closed
                    2022-03-21 10:29:21.689 - warn: shelly.0 (12768) get state error: DB closed
                    2022-03-21 10:29:21.690 - warn: shelly.0 (12768) get state error: DB closed
                    2022-03-21 10:29:21.690 - warn: shelly.0 (12768) redis get shelly.0.SHPLG-S#C383EB#1.online, error - DB closed
                    2022-03-21 10:29:21.691 - warn: shelly.0 (12768) get state error: DB closed
                    2022-03-21 10:29:21.715 - warn: shelly.0 (12768) get state error: DB closed
                    2022-03-21 10:29:21.717 - warn: shelly.0 (12768) redis get shelly.0.SHSW-1#767AC8#1.hostname, error - DB closed
                    2022-03-21 10:29:21.720 - warn: shelly.0 (12768) get state error: DB closed
                    2022-03-21 10:29:21.721 - warn: shelly.0 (12768) get state error: DB closed
                    2022-03-21 10:29:21.914 - warn: shelly.0 (12768) get state error: DB closed
                    2022-03-21 10:29:21.915 - warn: shelly.0 (12768) get state error: DB closed
                    2022-03-21 10:29:22.093 - warn: shelly.0 (12768) redis get shelly.0.SHSW-1#98F4ABF3CF6C#1.hostname, error - Connection is closed.
                    2022-03-21 10:29:22.115 - warn: shelly.0 (12768) redis get shelly.0.SHSW-PM#F27119#1.hostname, error - Connection is closed.
                    2022-03-21 10:29:22.117 - warn: shelly.0 (12768) redis get shelly.0.SHSW-PM#F27634#1.hostname, error - Connection is closed.
                    2022-03-21 10:29:22.119 - warn: shelly.0 (12768) setTimeout called, but adapter is shutting down
                    2022-03-21 10:29:25.704 - error: shelly.1 (12777) Cannot find view "system" for search "device" : Connection is closed.
                    2022-03-21 10:29:25.911 - error: history.0 (12669) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2022-03-21 10:29:25.915 - error: history.0 (12669) States database error: connect ECONNREFUSED 127.0.0.1:9000
                    2022-03-21 10:29:25.952 - error: shelly.0 (12768) Cannot find view "system" for search "device" : DB closed
                    2022-03-21 10:29:27.034 - info: history.0 (12669) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2022-03-21 10:29:30.927 - error: history.0 (12669) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2022-03-21 10:29:36.867 - info: host.raspberrypi iobroker.js-controller version 4.0.19 js-controller starting
                    2022-03-21 10:29:36.875 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                    2022-03-21 10:29:36.876 - info: host.raspberrypi hostname: raspberrypi, node: v14.19.1
                    2022-03-21 10:29:36.876 - info: host.raspberrypi ip addresses: Y.X.C.V IPV6
                    2022-03-21 10:29:38.900 - info: host.raspberrypi connected to Objects and States
                    2022-03-21 10:29:38.972 - info: host.raspberrypi added notifications configuration of host
                    2022-03-21 10:29:39.802 - info: host.raspberrypi 32 instances found
                    2022-03-21 10:29:39.863 - info: host.raspberrypi starting 21 instances
                    2022-03-21 10:29:40.093 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 13720
                    2022-03-21 10:29:42.077 - error: admin.0 (13720) admin.0 already running
                    2022-03-21 10:29:42.081 - warn: admin.0 (13720) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2022-03-21 10:29:42.717 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2022-03-21 10:29:42.718 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
                    2022-03-21 10:29:43.901 - info: host.raspberrypi instance system.adapter.email.0 started with pid 13731
                    2022-03-21 10:29:45.441 - error: email.0 (13731) email.0 already running
                    2022-03-21 10:29:45.445 - warn: email.0 (13731) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2022-03-21 10:29:46.064 - error: host.raspberrypi instance system.adapter.email.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2022-03-21 10:29:46.065 - info: host.raspberrypi Restart adapter system.adapter.email.0 because enabled
                    2022-03-21 10:29:48.020 - info: host.raspberrypi instance system.adapter.history.0 started with pid 13743
                    2022-03-21 10:29:49.579 - error: history.0 (13743) history.0 already running
                    2022-03-21 10:29:49.583 - warn: history.0 (13743) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2022-03-21 10:29:50.203 - error: host.raspberrypi instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2022-03-21 10:29:50.205 - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
                    2022-03-21 10:29:51.992 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 13755
                    2022-03-21 10:29:55.495 - error: javascript.0 (13755) javascript.0 already running
                    2022-03-21 10:29:55.499 - warn: javascript.0 (13755) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2022-03-21 10:29:55.983 - info: host.raspberrypi instance system.adapter.pushover.0 started with pid 13766
                    2022-03-21 10:29:56.133 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2022-03-21 10:29:56.134 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
                    2022-03-21 10:29:57.600 - error: pushover.0 (13766) pushover.0 already running
                    2022-03-21 10:29:57.604 - warn: pushover.0 (13766) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2022-03-21 10:29:58.272 - error: host.raspberrypi instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2022-03-21 10:29:58.273 - info: host.raspberrypi Restart adapter system.adapter.pushover.0 because enabled
                    2022-03-21 10:29:59.978 - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 13777
                    2022-03-21 10:30:01.640 - error: alexa2.0 (13777) alexa2.0 already running
                    2022-03-21 10:30:01.644 - warn: alexa2.0 (13777) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2022-03-21 10:30:02.263 - error: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2022-03-21 10:30:02.264 - info: host.raspberrypi Restart adapter system.adapter.alexa2.0 because enabled
                    2022-03-21 10:30:04.036 - info: host.raspberrypi instance system.adapter.hue.0 started with pid 13788
                    2022-03-21 10:30:05.962 - error: hue.0 (13788) hue.0 already running
                    2022-03-21 10:30:06.590 - error: host.raspberrypi instance system.adapter.hue.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2022-03-21 10:30:06.590 - info: host.raspberrypi Restart adapter system.adapter.hue.0 because enabled
                    2022-03-21 10:30:08.001 - info: host.raspberrypi instance system.adapter.shelly.0 started with pid 13799
                    2022-03-21 10:30:10.386 - error: shelly.0 (13799) shelly.0 already running
                    2022-03-21 10:30:10.390 - warn: shelly.0 (13799) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2022-03-21 10:30:11.012 - error: host.raspberrypi instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2022-03-21 10:30:11.012 - info: host.raspberrypi Restart adapter system.adapter.shelly.0 because enabled
                    2022-03-21 10:30:11.987 - info: host.raspberrypi instance system.adapter.shelly.1 started with pid 13810
                    2022-03-21 10:30:12.836 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 13817
                    2022-03-21 10:30:14.257 - error: shelly.1 (13810) shelly.1 already running
                    2022-03-21 10:30:14.262 - warn: shelly.1 (13810) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2022-03-21 10:30:15.043 - error: host.raspberrypi instance system.adapter.shelly.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2022-03-21 10:30:15.044 - info: host.raspberrypi Restart adapter system.adapter.shelly.1 because enabled
                    2022-03-21 10:30:15.288 - info: admin.0 (13817) starting. Version 5.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.1, js-controller: 4.0.19
                    2022-03-21 10:30:15.336 - info: admin.0 (13817) requesting all states
                    2022-03-21 10:30:15.337 - info: admin.0 (13817) requesting all objects
                    2022-03-21 10:30:16.895 - info: host.raspberrypi instance system.adapter.email.0 started with pid 13836
                    2022-03-21 10:30:16.978 - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 13843
                    2022-03-21 10:30:17.468 - info: admin.0 (13817) received all objects
                    2022-03-21 10:30:18.021 - info: admin.0 (13817) Request actual repository...
                    2022-03-21 10:30:18.051 - info: admin.0 (13817) http server listening on port 8081
                    2022-03-21 10:30:18.053 - info: admin.0 (13817) Use link "http://localhost:8081" to configure.
                    2022-03-21 10:30:18.927 - info: host.raspberrypi Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
                    2022-03-21 10:30:19.880 - error: tr-064.0 (13843) tr-064.0 already running
                    2022-03-21 10:30:19.884 - warn: tr-064.0 (13843) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2022-03-21 10:30:20.369 - info: host.raspberrypi instance scheduled system.adapter.weatherunderground.0 6 * * * *
                    2022-03-21 10:30:20.399 - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 13858
                    2022-03-21 10:30:23.820 - info: admin.0 (13817) Repository received successfully.
                    2022-03-21 10:30:24.716 - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2022-03-21 10:30:24.717 - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                    2022-03-21 10:30:24.752 - info: host.raspberrypi instance system.adapter.history.0 started with pid 13869
                    2022-03-21 10:30:24.849 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 13875
                    2022-03-21 10:30:24.969 - error: weatherunderground.0 (13858) weatherunderground.0 already running
                    2022-03-21 10:30:24.974 - warn: weatherunderground.0 (13858) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2022-03-21 10:30:25.084 - info: email.0 (13836) starting. Version 1.0.10 (non-npm: iobroker-community-adapters/ioBroker.email) in /opt/iobroker/node_modules/iobroker.email, node: v14.19.1, js-controller: 4.0.19
                    2022-03-21 10:30:25.651 - error: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2022-03-21 10:30:26.272 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 13891
                    crunchipC
                    crunchipC
                    Developer Global Moderator Most Active Forum Testing
                    @th3rockyeah sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                    non-npm
                    @apollon77 kann es sein das da mit npm etwas nicht passt?
                      non-npm
                      apollon77A
                      apollon77A
                      @crunchip Ne das sind GitHub installs ... aber habs nur für email und weatherunderground gesehen, da sollte es eher irrelevant sein ... Javascript 5.4 wäre eher ein Kandidat weil der Ordner anlegt, aber bei den 5 Skripten sollte das fast egal sein
                      Denke man muss jetzt mal strukturiert rangehen weil ausser dem controller nichts irklich auffällig ist
                      • apollon77A apollon77
                        • Stoppe iobroker
                        T
                        T
                        Th3RockYeah
                        @apollon77
                        Ok, mach ich. ich starte nach und nach die Adapter und schaue, ob etwas auffällig ist.
                        Den MQTT Adapter nutze ich nicht, nur Shelly.
                        Nun hat sich der JS-Controller beruhigt und ich kann den IOBroker wieder normal nutzen. Das hier waren die letzten Fehler im Log:
                        	Zeit
                        warn
                        Nachricht
                        zigbee.0
                        2022-03-21 11:49:59.635	warn	DeviceAvailability:Failed to ping 0x000d6ffffe2e4a54 TRADFRI signal repeater
                        zigbee.0
                        2022-03-21 11:45:23.370	warn	State value to set for "zigbee.0.00158d00042176ed.pressure" has value "95992" greater than max "10000"
                        radar2.0
                        2022-03-21 11:34:11.290	warn	State "radar2.0._uIPs.SonosZP_xxx-xxx-xxx-xxx" has no existing object, this might lead to an error in future versions
                        radar2.0
                        2022-03-21 11:34:11.273	warn	State "radar2.0._uIPs.SonosZP_xxx-xxx-xxx-xxx" has no existing object, this might lead to an error in future versions
                        radar2.0
                        2022-03-21 11:34:11.119	warn	State "radar2.0._uIPs.shellyplug-s-DE15FC_xxx-xxx--xxx-xx" has no existing object, this might lead to an error in future versions
                        radar2.0
                        2022-03-21 11:34:11.040	warn	State "radar2.0._uIPs.shellyplug-s-DE15FC_xxx-xxx-xxx-xxx" has no existing object, this might lead to an error in future versions
                        radar2.0
                        2022-03-21 11:34:10.070	warn	State "radar2.0._uIPs.HDot_xxx-xxx-xxx-xxx" has no existing object, this might lead to an error in future versions
                        radar2.0
                        2022-03-21 11:34:10.034	warn	State "radar2.0._uIPs.HDot_xxx-xxx-xxx-xxx" has no existing object, this might lead to an error in future versions
                        radar2.0
                        2022-03-21 11:34:10.032	warn	State "radar2.0._uIPs.HDot_xxx-xxx-xxx-xxx" has no existing object, this might lead to an error in future versions
                        zigbee.0
                        2022-03-21 11:25:12.257	warn	DeviceAvailability:Stopping to ping 0x680ae2fffe9c8577 TRADFRI Signal Repeater after 4 ping attempts
                        zigbee.0
                        2022-03-21 11:19:39.577	warn	State value to set for "zigbee.0.00158d000464c66d.pressure" has value "96079" greater than max "10000"
                        radar2.0
                        2022-03-21 11:12:30.875	warn	scanDelay increased to 71.119 seconds, delayAway to 2 minutes!
                        host.raspberrypi
                        2022-03-21 11:07:54.826	error	instance system.adapter.radar2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        radar2.0
                        2022-03-21 11:07:54.333	warn	Error {} is setState for _uIPs with {"val":"[]","ack":true,"from":"system.adapter.radar2.0","user":"system.user.admin"}
                        radar2.0
                        2022-03-21 11:07:54.330	warn	get state error: Connection is closed.
                        radar2.0
                        2022-03-21 11:07:54.329	warn	Could not perform strict object check of state radar2.0._uIPs: DB closed
                        radar2.0
                        2022-03-21 11:07:53.861	warn	Unhandled rejection at
                        radar2.0
                        2022-03-21 11:07:53.860	error	Cannot read property 'hosts' of undefined
                        radar2.0
                        2022-03-21 11:07:53.859	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62)
                        radar2.0
                        2022-03-21 11:07:53.858	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
                        radar2.0
                        2022-03-21 11:07:53.857	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        radar2.0
                        2022-03-21 11:07:53.854	warn	redis get radar2.0._uIPs.192-168-170-210, error - Connection is closed.
                        radar2.0
                        2022-03-21 11:07:53.853	warn	Error {} is setState for radar2.0._uIPs.xxx-xxx-xxx-xxx with {"val":"{ ipAddress: 'xxx.xxx.xxxx.xxxx', macAddress: '8:33:4d:ca', by: 'arp', hosts: [], getMacVendor: 'N/A'\n}","ack":true,"from":"system.adapter.radar2.0","user":"system.user.admin"}
                        radar2.0
                        2022-03-21 11:07:53.852	warn	get state error: Connection is closed.
                        radar2.0
                        2022-03-21 11:07:53.851	warn	Error {} is setState for info.connection with {"val":false,"ack":true,"from":"system.adapter.radar2.0","user":"system.user.admin"}
                        radar2.0
                        2022-03-21 11:07:53.850	warn	get state error: Connection is closed.
                        radar2.0
                        2022-03-21 11:07:53.652	warn	Unhandled rejection at
                        radar2.0
                        2022-03-21 11:07:53.651	error	Cannot read property 'hosts' of undefined
                        radar2.0
                        2022-03-21 11:07:53.650	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62)
                        radar2.0
                        2022-03-21 11:07:53.650	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
                        radar2.0
                        2022-03-21 11:07:53.649	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        radar2.0
                        2022-03-21 11:07:53.647	warn	redis get radar2.0._uIPs.xxx-xxx-xxx-xxx, error - Connection is closed.
                        radar2.0
                        2022-03-21 11:07:53.646	warn	Error {} is setState for _uIPs.xxx-xxx-xxx-xxx with {"val":"{ ipAddress: 'xxx.xxx.xxx.xxx', macAddress: '33:4d:ca', by: 'arp', hosts: [], getMacVendor: 'N/A'\n}","ack":true,"from":"system.adapter.radar2.0","user":"system.user.admin"}
                        radar2.0
                        2022-03-21 11:07:53.645	warn	get state error: Connection is closed.
                        radar2.0
                        2022-03-21 11:07:53.332	warn	Unhandled rejection at
                        radar2.0
                        2022-03-21 11:07:53.331	error	Cannot read property 'hosts' of undefined
                        radar2.0
                        2022-03-21 11:07:53.331	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62)
                        radar2.0
                        2022-03-21 11:07:53.330	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
                        radar2.0
                        2022-03-21 11:07:53.329	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        radar2.0
                        2022-03-21 11:07:53.320	warn	Unhandled rejection at
                        radar2.0
                        2022-03-21 11:07:53.320	error	Cannot read property 'hosts' of undefined
                        radar2.0
                        2022-03-21 11:07:53.319	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62) at runNextTicks (internal/process/task_queues.js:60:5) at processImmediate (internal/timers.js:437:9)
                        radar2.0
                        2022-03-21 11:07:53.319	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
                        radar2.0
                        2022-03-21 11:07:53.318	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        radar2.0
                        2022-03-21 11:07:53.316	warn	Unhandled rejection at
                        radar2.0
                        2022-03-21 11:07:53.315	error	Cannot read property 'hosts' of undefined
                        radar2.0
                        2022-03-21 11:07:53.315	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62) at runNextTicks (internal/process/task_queues.js:60:5) at processImmediate (internal/timers.js:437:9)
                        radar2.0
                        2022-03-21 11:07:53.314	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
                        radar2.0
                        2022-03-21 11:07:53.313	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        radar2.0
                        2022-03-21 11:07:53.311	warn	Unhandled rejection at
                        radar2.0
                        2022-03-21 11:07:53.289	error	Cannot read property 'hosts' of undefined
                        radar2.0
                        2022-03-21 11:07:53.288	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62) at runNextTicks (internal/process/task_queues.js:60:5) at processImmediate (internal/timers.js:437:9)
                        radar2.0
                        2022-03-21 11:07:53.287	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
                        radar2.0
                        2022-03-21 11:07:53.286	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        radar2.0
                        2022-03-21 11:07:53.283	warn	Unhandled rejection at
                        radar2.0
                        2022-03-21 11:07:53.281	error	Cannot read property 'hosts' of undefined
                        radar2.0
                        2022-03-21 11:07:53.279	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62) at runNextTicks (internal/process/task_queues.js:60:5) at processImmediate (internal/timers.js:437:9)
                        radar2.0
                        2022-03-21 11:07:53.278	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
                        radar2.0
                        2022-03-21 11:07:53.277	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        radar2.0
                        2022-03-21 11:07:53.275	warn	Unhandled rejection at
                        radar2.0
                        2022-03-21 11:07:53.275	error	Cannot read property 'hosts' of undefined
                        radar2.0
                        2022-03-21 11:07:53.274	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62) at runNextTicks (internal/process/task_queues.js:60:5) at processImmediate (internal/timers.js:437:9)
                        radar2.0
                        2022-03-21 11:07:53.273	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
                        radar2.0
                        2022-03-21 11:07:53.272	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        radar2.0
                        2022-03-21 11:07:53.270	warn	Unhandled rejection at
                        radar2.0
                        2022-03-21 11:07:53.269	error	Cannot read property 'hosts' of undefined
                        radar2.0
                        2022-03-21 11:07:53.268	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62) at runNextTicks (internal/process/task_queues.js:60:5) at processImmediate (internal/timers.js:437:9)
                        radar2.0
                        2022-03-21 11:07:53.268	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
                        radar2.0
                        2022-03-21 11:07:53.267	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        radar2.0
                        2022-03-21 11:07:53.264	warn	redis get radar2.0._uIPs.XXX-XXX-XXX-XXX, error - Connection is closed.
                        Nur damit ich es gefragt habe, weil es mich nicht "loslässt". Kann die SD-Card kaputt sein?
                        • T Th3RockYeah
                          @apollon77
                          	Zeit
                          warn
                          Nachricht
                          zigbee.0
                          zigbee.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          zigbee.0
                          zigbee.0
                          radar2.0
                          host.raspberrypi
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          radar2.0
                          Thomas BraunT
                          Thomas BraunT
                          Most Active Developer
                          Möglich. Die eine Karte, die mir mal verreckt ist hat sich in den Logfiles sang- und klanglos verabschiedet.
                          Schau mal mit
                          dmesg -T | grep -i ext4
                          danach.
                            Schau mal mit
                            danach.
                            T
                            T
                            Th3RockYeah
                            Das kommt als Antwort. Was bedeutet das?
                            [Mo Mär 21 10:52:17 2022]  ext4_filemap_fault+0x3c/0x818
                            • T Th3RockYeah
                              Thomas BraunT
                              Thomas BraunT
                              @th3rockyeah
                              Nur die eine Zeile?
                              Da muss mehr kommen.
                              Aber ext4_filemap_fault ist schon mal schlecht, das sollte nicht kommen.
                                @th3rockyeah
                                Nur die eine Zeile?
                                T
                                T
                                Th3RockYeah
                                Ja nur die eine Zeile:
                                • T Th3RockYeah
                                  Thomas BraunT
                                  Thomas BraunT
                                  @th3rockyeah
                                  Dann würde ich sagen, die Karte/das Dateisystem ist fehlerhaft.
                                    @th3rockyeah
                                    T
                                    T
                                    Th3RockYeah
                                    @thomas-braun Ok, dann setze ich hier einmal ebenfalls an.
                                    Was müsste denn dort normalerweise stehen, wenn die SD-Card OK wäre?
                                    • T Th3RockYeah
                                      Thomas BraunT
                                      Thomas BraunT
                                      @th3rockyeah
                                      Da tauchen dann 4 Zeilen auf.
                                      Ich komme gerade an mein System nicht ran, sonst hätte ich es gezeigt.
                                      Aus deinem obigen Log:
                                      ping invoked oom-killer: gfp_mask=0x400dc0(GFP_KERNEL_ACCOUNT|__GFP_ZERO), order=0, oom_score_adj=0
                                      gfp_mask ist auch nah am System/RAM/Dateisystem. Ich würde sagen, das Ding schwimmt schon nicht mehr, das ist abgesoffen.
                                        @th3rockyeah
                                        T
                                        T
                                        Th3RockYeah
                                        schrieb am zuletzt editiert von Th3RockYeah
                                        @thomas-braun ok, danke dir! Ich habe jetzt auch mehrere Zeilen bei dem Aufruf in der Console.
                                        Ich habe nun den IoBroker auf einem USB Stick neu aufgesetzt und aktuell läuft er total smooth. Ich beobachte es noch eine Weile, aber nach einem Iobroker restart ist das Verhalten normal, der js-controller läuft ohne starke CPU oder Memory last.
                                        Es scheint die SD-Card gewesen zu sein #fingercrossed.
                                        @apollon77 , @thomas-braun, @Diginix , @crunchip: DANKE für euren Support!!! Kudos to you all! :-)
                                        Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                                        • T Th3RockYeah
                                          Thomas BraunT
                                          Thomas BraunT
                                          Welche?
                                          33.2k
                                          84.3k
