  4. Material Design Widgets: Adapter Status
material design widgetsvisiconlistviewview adapteradapterstatusanzeige
144 Beiträge 48 Kommentatoren 55.2k Aufrufe 60 Beobachtet
  • WszeneW Wszene
    @oli
    Das habe ich auch noch oben drüber stehen
    @Glasfaser
    Ich habe die Datenpunkte angelegt und das Modul raus gelöscht und wieder eingefügt
    Aber leider ohne Erfolg
    javascript.0
    2022-01-28 20:24:30.004	error	script.js.001-VIS.Status.Adapterstatus: [adapterStatus] error: moment.duration(...).format is not a function, stack: TypeError: moment.duration(...).format is not a function at Object.adapterStatus (script.js.001-VIS.Status.Adapterstatus:110:115) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1316:34) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:168:15) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28 at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7)
    javascript.0
    2022-01-28 20:24:15.293	error	script.js.001-VIS.Status.Adapterstatus: [adapterStatus] error: moment.duration(...).format is not a function, stack: TypeError: moment.duration(...).format is not a function at Object.adapterStatus (script.js.001-VIS.Status.Adapterstatus:110:115) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1082:38) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5708:41) at processImmediate (internal/timers.js:464:21)
    javascript.0
    2022-01-28 20:24:07.055	info	script.js.001-VIS.Status.Adapterstatus: registered 73 subscriptions and 1 schedule
    javascript.0
    2022-01-28 20:24:07.055	error	script.js.001-VIS.Status.Adapterstatus: [adapterStatus] error: moment.duration(...).format is not a function, stack: TypeError: moment.duration(...).format is not a function at adapterStatus (script.js.001-VIS.Status.Adapterstatus:110:115) at script.js.001-VIS.Status.Adapterstatus:267:1 at script.js.001-VIS.Status.Adapterstatus:341:3 at Script.runInContext (vm.js:144:12) at Script.runInNewContext (vm.js:149:17) at execute (/opt/iobroker/node_modules/iobroker.javascript/main.js:1526:27) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1736:38) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1836:17 at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1311:17) at processImmediate (internal/timers.js:466:21)
    javascript.0
    2022-01-28 20:24:06.950	error	at Script.runInContext (vm.js:144:12)
    javascript.0
    2022-01-28 20:24:06.950	error	at script.js.001-VIS.Status.Adapterstatus:340:3
    javascript.0
    2022-01-28 20:24:06.950	error	at script.js.001-VIS.Status.Adapterstatus:5:35
    javascript.0
    2022-01-28 20:24:06.949	error	at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:412:32)
    javascript.0
    2022-01-28 20:24:06.949	error	at require (internal/modules/cjs/helpers.js:93:18)
    javascript.0
    2022-01-28 20:24:06.949	error	at Module.require (internal/modules/cjs/loader.js:974:19)
    javascript.0
    2022-01-28 20:24:06.949	error	script.js.001-VIS.Status.Adapterstatus: Error: Cannot find module 'moment-duration-format'
    sigi234S
    sigi234S
    #95
    @wszene
    Welche Version von javascript hast du?
    WszeneW 1 Antwort Letzte Antwort
    • sigi234S sigi234
      @wszene
      WszeneW
      WszeneW
      Wszene
      #96
      @sigi234 sagte in Material Design Widgets: Adapter Status:
      @wszene
      Ich habe die Version 5.2.2.1
      System ist:
      Debian 11 LXC
      Node.js: v14.18.3
      NPM: 6.14.15
      Meine Hard- & Software:
      • CC2652P Zigbee Stick
      • Lichtschalter mit Tasmota
      • IKEA TRÅDFRI Glühbirnen
      • Aqara Sensoren
      • GlasfaserG Glasfaser
        @wszene sagte in Material Design Widgets: Adapter Status:
        und die Datenpunkte angepasst
        es werden auch keine Datenpunkte angelegt
        (Typ: Zeichenkette (String))
        Hast du den eigenen Datenpunkt erstellt , denn er wird nicht vom Skript selber erstellt .
        Mhh ,
        lösche die Eintragung , Adapter neu starten ,
        wieder eintragen , Adapter starten und im Log schauen ob eine Fehlermeldung kommt .
        GlasfaserG
        GlasfaserG
        #97
        @Wszene
        @glasfaser sagte in Material Design Widgets: Adapter Status:
        Ich meinte nicht das Script an sich , sondern was beim Hinzufügen des NPM Modul kommt .
          @Wszene
          WszeneW
          WszeneW
          Wszene
          #98
          @Wszene
          Achso
          also nochmal 😁
          javascript.0
          2022-01-28 20:37:13.301	info	State value to set for "0_userdata.0.001_Alexa.01_Stube.Lampen.Stehlampe" has to be type "boolean" but received type "string"
          javascript.0
          2022-01-28 20:37:13.247	warn	at processTimers (internal/timers.js:500:7)
          javascript.0
          2022-01-28 20:37:13.247	warn	at listOnTimeout (internal/timers.js:557:17)
          javascript.0
          2022-01-28 20:37:13.247	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2117:34)
          javascript.0
          2022-01-28 20:37:13.247	warn	at Object.<anonymous> (script.js.01-Stube.Lampen.Stehlampe_-_An_Aus:115:29)
          javascript.0
          2022-01-28 20:37:13.247	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1437:20)
          javascript.0
          2022-01-28 20:37:13.243	warn	You are assigning a string to the state "0_userdata.0.001_Alexa.01_Stube.Lampen.Stehlampe" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
          vw-connect.0
          2022-01-28 20:37:13.028	error	failed set state
          vw-connect.0
          2022-01-28 20:37:13.027	error	{"error":{"errorCode":"RS.security.9007","description":"The context has not gained a legitimation due to missing access rights."}}
          vw-connect.0
          2022-01-28 20:37:13.027	error	403
          javascript.0
          2022-01-28 20:37:12.276	info	script.js.001-VIS.Wetter.Wetter_DD_-_DWD-Regenradar: registered 0 subscriptions and 1 schedule
          javascript.0
          2022-01-28 20:37:12.267	info	Start javascript script.js.001-VIS.Wetter.Wetter_DD_-_DWD-Regenradar
          javascript.0
          2022-01-28 20:37:12.267	info	script.js.06-Autos.Scala_-_Tabelle-Status: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.266	info	Start javascript script.js.06-Autos.Scala_-_Tabelle-Status
          javascript.0
          2022-01-28 20:37:12.265	info	script.js.001-VIS.Wetter.Wetter_DD_-_Es_regnet_oder_schneit_oder_stürmt: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.264	info	Start javascript script.js.001-VIS.Wetter.Wetter_DD_-_Es_regnet_oder_schneit_oder_stürmt
          javascript.0
          2022-01-28 20:37:12.264	info	script.js.001-VIS.Wetter.Wetter_GRH_-_Überschriften: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.263	info	Start javascript script.js.001-VIS.Wetter.Wetter_GRH_-_Überschriften
          javascript.0
          2022-01-28 20:37:12.262	info	script.js.001-VIS.Wetter.Wetter_GRH_-_Werte: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.261	info	Start javascript script.js.001-VIS.Wetter.Wetter_GRH_-_Werte
          javascript.0
          2022-01-28 20:37:12.261	info	script.js.001-VIS.Wetter.Wetter_GRH_-_MinMax-Temp: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.260	info	Start javascript script.js.001-VIS.Wetter.Wetter_GRH_-_MinMax-Temp
          javascript.0
          2022-01-28 20:37:12.259	info	script.js.001-VIS.Wetter.Wetter_DD_-_Werte: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.258	info	Start javascript script.js.001-VIS.Wetter.Wetter_DD_-_Werte
          javascript.0
          2022-01-28 20:37:12.258	info	script.js.001-VIS.Wetter.Wetter_DD_-_MinMax-Temp: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.256	info	Start javascript script.js.001-VIS.Wetter.Wetter_DD_-_MinMax-Temp
          javascript.0
          2022-01-28 20:37:12.256	info	script.js.001-VIS.Wetter.Wetter_DD_-_Überschriften: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.255	info	Start javascript script.js.001-VIS.Wetter.Wetter_DD_-_Überschriften
          javascript.0
          2022-01-28 20:37:12.255	info	script.js.001-VIS.Welche_Steckdosen_sind_an: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.253	info	Start javascript script.js.001-VIS.Welche_Steckdosen_sind_an
          javascript.0
          2022-01-28 20:37:12.253	info	script.js.001-VIS.Welche_Lampen_sind_an: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.252	info	Start javascript script.js.001-VIS.Welche_Lampen_sind_an
          javascript.0
          2022-01-28 20:37:12.252	info	script.js.02-Schlafzimmer.Dosen.TV-Bett: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.250	info	Start javascript script.js.02-Schlafzimmer.Dosen.TV-Bett
          javascript.0
          2022-01-28 20:37:12.250	info	script.js.02-Schlafzimmer.Taster.Sleeptimer_-_Button: registered 1 subscription and 0 schedules
          javascript.0
          2022-01-28 20:37:12.249	info	Start javascript script.js.02-Schlafzimmer.Taster.Sleeptimer_-_Button
          javascript.0
          2022-01-28 20:37:12.249	info	script.js.01-Stube.Fernbedienungen.Kino_an_aus: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.247	info	Start javascript script.js.01-Stube.Fernbedienungen.Kino_an_aus
          javascript.0
          2022-01-28 20:37:12.247	info	script.js.01-Stube.Fernbedienungen.TV_Sender_schalten_-_Alexa: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.244	info	Start javascript script.js.01-Stube.Fernbedienungen.TV_Sender_schalten_-_Alexa
          javascript.0
          2022-01-28 20:37:12.231	info	script.js.01-Stube.Fernbedienungen.TV_Kanal_-_Hoch_Runter: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.230	info	Start javascript script.js.01-Stube.Fernbedienungen.TV_Kanal_-_Hoch_Runter
          javascript.0
          2022-01-28 20:37:12.230	info	script.js.01-Stube.Fernbedienungen.AV-Receiver_-_Lautstärke: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.228	info	Start javascript script.js.01-Stube.Fernbedienungen.AV-Receiver_-_Lautstärke
          javascript.0
          2022-01-28 20:37:12.228	info	script.js.02-Schlafzimmer.Schalter.Schlafzimmerlampe: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.227	info	Start javascript script.js.02-Schlafzimmer.Schalter.Schlafzimmerlampe
          javascript.0
          2022-01-28 20:37:12.227	info	script.js.01-Stube.Schalter.Lampe-Sofatisch: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.225	info	Start javascript script.js.01-Stube.Schalter.Lampe-Sofatisch
          javascript.0
          2022-01-28 20:37:12.121	info	script.js.01-Stube.Schalter.Lampe-Esstisch: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.120	info	Start javascript script.js.01-Stube.Schalter.Lampe-Esstisch
          javascript.0
          2022-01-28 20:37:12.120	info	script.js.01-Stube.Lampen.Stehlampe_-_An_Aus: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.118	info	Start javascript script.js.01-Stube.Lampen.Stehlampe_-_An_Aus
          javascript.0
          2022-01-28 20:37:12.118	info	script.js.06-Autos.Kodiaq_-_Tabelle_Türen-Fenster: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.115	info	Start javascript script.js.06-Autos.Kodiaq_-_Tabelle_Türen-Fenster
          javascript.0
          2022-01-28 20:37:12.112	info	script.js.06-Autos.Kodiaq_-_Tabelle-Status: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.111	info	Start javascript script.js.06-Autos.Kodiaq_-_Tabelle-Status
          javascript.0
          2022-01-28 20:37:12.111	info	script.js.001-VIS.Tankstellen_-_offen-geschlossen: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.109	info	Start javascript script.js.001-VIS.Tankstellen_-_offen-geschlossen
          javascript.0
          2022-01-28 20:37:12.109	info	script.js.06-Autos.Telegram_-_Tankerinnerung: registered 0 subscriptions and 1 schedule
          javascript.0
          2022-01-28 20:37:12.092	info	Start javascript script.js.06-Autos.Telegram_-_Tankerinnerung
          javascript.0
          2022-01-28 20:37:12.092	info	script.js.06-Autos.Telegram_-_Standortwechsel: registered 2 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.090	info	Start javascript script.js.06-Autos.Telegram_-_Standortwechsel
          javascript.0
          2022-01-28 20:37:12.090	info	script.js.06-Autos.Kodiaq_-_Datenpunkte_Tueren-Fenster: registered 8 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.088	info	Start javascript script.js.06-Autos.Kodiaq_-_Datenpunkte_Tueren-Fenster
          javascript.0
          2022-01-28 20:37:12.088	info	script.js.06-Autos.Kodiaq_-_Standheizung: registered 3 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.087	info	Start javascript script.js.06-Autos.Kodiaq_-_Standheizung
          javascript.0
          2022-01-28 20:37:12.086	info	script.js.06-Autos.Scala_-_Datenpunkte_anlegen: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.085	info	Start javascript script.js.06-Autos.Scala_-_Datenpunkte_anlegen
          javascript.0
          2022-01-28 20:37:12.085	info	script.js.06-Autos.Kodiaq_-_Datenpunkte_anlegen: registered 0 subscriptions and 0 schedules
          javascript.0
          2022-01-28 20:37:12.079	info	Start javascript script.js.06-Autos.Kodiaq_-_Datenpunkte_anlegen
          javascript.0
          2022-01-28 20:37:12.079	info	script.js.03-Flur-Kammer.Kammerlicht_schalten: registered 1 subscription and 0 schedules
          javascript.0
          2022-01-28 20:37:12.077	info	Start javascript script.js.03-Flur-Kammer.Kammerlicht_schalten
          javascript.0
          2022-01-28 20:37:12.077	info	script.js.01-Stube.Lampen.Zeitplan_-_Leuchtbaum: registered 0 subscriptions and 4 schedules
          javascript.0
          2022-01-28 20:37:12.054	info	Start javascript script.js.01-Stube.Lampen.Zeitplan_-_Leuchtbaum
          javascript.0
          2022-01-28 20:37:11.793	info	received all states
          javascript.0
          2022-01-28 20:37:11.343	info	received all objects
          javascript.0
          2022-01-28 20:37:10.139	info	requesting all objects
          javascript.0
          2022-01-28 20:37:10.138	info	requesting all states
          javascript.0
          2022-01-28 20:37:10.100	info	starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.18.3, js-controller: 3.3.22
          host.ioBroker02
          2022-01-28 20:37:09.239	info	instance system.adapter.javascript.0 started with pid 73225
          host.ioBroker02
          2022-01-28 20:37:06.743	info	instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          javascript.0
          2022-01-28 20:37:06.204	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          javascript.0
          2022-01-28 20:37:06.203	info	terminating
          javascript.0
          2022-01-28 20:37:06.200	info	Stop script script.js.001-VIS.Wetter.Wetter_DD_-_DWD-Regenradar
          javascript.0
          2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Wetter.Wetter_GRH_-_Überschriften
          javascript.0
          javascript.0
          2022-01-28 20:37:06.198	info	Stop script script.js.001-VIS.Welche_Lampen_sind_an
          javascript.0
          javascript.0
          2022-01-28 20:37:06.197	info	Stop script script.js.01-Stube.Fernbedienungen.AV-Receiver_-_Lautstärke
          javascript.0
          javascript.0
          javascript.0
          2022-01-28 20:37:06.196	info	Stop script script.js.01-Stube.Lampen.Stehlampe_-_An_Aus
          javascript.0
          javascript.0
          javascript.0
          2022-01-28 20:37:06.195	info	Stop script script.js.06-Autos.Telegram_-_Tankerinnerung
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          2022-01-28 20:37:06.200	info	Stop script script.js.06-Autos.Scala_-_Tabelle-Status
          javascript.0
          2022-01-28 20:37:06.200	info	Stop script script.js.001-VIS.Wetter.Wetter_DD_-_Es_regnet_oder_schneit_oder_stürmt
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Wetter.Wetter_GRH_-_Werte
          javascript.0
          2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Wetter.Wetter_GRH_-_MinMax-Temp
          javascript.0
          2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Wetter.Wetter_DD_-_Werte
          javascript.0
          2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Wetter.Wetter_DD_-_MinMax-Temp
          javascript.0
          2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Wetter.Wetter_DD_-_Überschriften
          javascript.0
          2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Welche_Steckdosen_sind_an
          javascript.0
          javascript.0
          javascript.0
          2022-01-28 20:37:06.198	info	Stop script script.js.02-Schlafzimmer.Dosen.TV-Bett
          javascript.0
          2022-01-28 20:37:06.198	info	Stop script script.js.02-Schlafzimmer.Taster.Sleeptimer_-_Button
          javascript.0
          2022-01-28 20:37:06.198	info	Stop script script.js.01-Stube.Fernbedienungen.Kino_an_aus
          javascript.0
          2022-01-28 20:37:06.198	info	Stop script script.js.01-Stube.Fernbedienungen.TV_Sender_schalten_-_Alexa
          javascript.0
          2022-01-28 20:37:06.198	info	Stop script script.js.01-Stube.Fernbedienungen.TV_Kanal_-_Hoch_Runter
          javascript.0
          javascript.0
          javascript.0
          2022-01-28 20:37:06.197	info	Stop script script.js.02-Schlafzimmer.Schalter.Schlafzimmerlampe
          javascript.0
          2022-01-28 20:37:06.197	info	Stop script script.js.01-Stube.Schalter.Lampe-Sofatisch
          javascript.0
          2022-01-28 20:37:06.197	info	Stop script script.js.01-Stube.Schalter.Lampe-Esstisch
          javascript.0
          javascript.0
          2022-01-28 20:37:06.196	info	Stop script script.js.06-Autos.Kodiaq_-_Tabelle_Türen-Fenster
          javascript.0
          2022-01-28 20:37:06.196	info	Stop script script.js.06-Autos.Kodiaq_-_Tabelle-Status
          javascript.0
          2022-01-28 20:37:06.196	info	Stop script script.js.001-VIS.Tankstellen_-_offen-geschlossen
          javascript.0
          javascript.0
          2022-01-28 20:37:06.195	info	Stop script script.js.06-Autos.Telegram_-_Standortwechsel
          javascript.0
          2022-01-28 20:37:06.195	info	Stop script script.js.06-Autos.Kodiaq_-_Datenpunkte_Tueren-Fenster
          javascript.0
          2022-01-28 20:37:06.194	info	Stop script script.js.06-Autos.Kodiaq_-_Standheizung
          javascript.0
          2022-01-28 20:37:06.194	info	Stop script script.js.06-Autos.Scala_-_Datenpunkte_anlegen
          javascript.0
          2022-01-28 20:37:06.194	info	Stop script script.js.06-Autos.Kodiaq_-_Datenpunkte_anlegen
          javascript.0
          2022-01-28 20:37:06.194	info	Stop script script.js.03-Flur-Kammer.Kammerlicht_schalten
          javascript.0
          2022-01-28 20:37:06.193	info	Stop script script.js.01-Stube.Lampen.Zeitplan_-_Leuchtbaum
          javascript.0
          2022-01-28 20:37:06.190	info	Got terminate signal TERMINATE_YOURSELF
          host.ioBroker02
          2022-01-28 20:37:06.197	info	stopInstance system.adapter.javascript.0 send kill signal
          host.ioBroker02
          2022-01-28 20:37:06.187	info	stopInstance system.adapter.javascript.0 (force=false, process=true)
          • Aqara Sensoren
          • WszeneW Wszene
            @Wszene
            Achso
            also nochmal 😁
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            vw-connect.0
            vw-connect.0
            vw-connect.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            host.ioBroker02
            host.ioBroker02
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            host.ioBroker02
            host.ioBroker02
            GlasfaserG
            GlasfaserG
            #99
            @wszene
            Fehler gefunden ... trage es oben ein :
              @wszene
              WszeneW
              WszeneW
              Wszene
              #100
              @wszene
              Sehr schön das scheint es gewesen zu sein
              Jetzt hat sich auch der Datenpunkt "jsonList" gefüllt
              Aber die anderen 3 bleiben leer
              • Aqara Sensoren
              • WszeneW Wszene
                @wszene
                GlasfaserG
                GlasfaserG
                #101
                Die werden erst mit dem View gefüllt ( Auswahl .... )
                  WszeneW
                  WszeneW
                  Wszene
                  #102
                  OK ich habe die View mal importiert aber die DPs bleiben leer ich habe die View auch aufgerufen
                  Muss ich irgendwo meine eigenen DPs angeben ich habe nur gefunden wo ich die JsonList einfügen muss
                  • Aqara Sensoren
                  • WszeneW Wszene
                    GlasfaserG
                    GlasfaserG
                    #103
                    @wszene
                    hier bei den beiden Widgets
                      @wszene
                      WszeneW
                      WszeneW
                      Wszene
                      schrieb am zuletzt editiert von Wszene
                      #104
                      @wszene
                      Ja wenn ich da Filter oder Sortiere passiert leider nichts
                      PS:
                      Habe gerade im Log gesehen das er die falschen DPs ansprechen will
                      web.0
                      2022-01-28 21:03:14.802	warn	State "0_userdata.0.vis.AdapterStatus.filterMode" has no existing object, this might lead to an error in future versions
                      web.0
                      2022-01-28 21:02:49.672	warn	State "0_userdata.0.vis.AdapterStatus.sortMode" has no existing object, this might lead to an error in future versions
                      • Aqara Sensoren
                      • WszeneW Wszene
                        @wszene
                        PS:
                        web.0
                        web.0
                        GlasfaserG
                        GlasfaserG
                        #105
                        @wszene
                        Hast du dort ... im Vis Editor bei den beiden Widgets deine Datenpunkte eingetragen !?
                        • WszeneW Wszene
                          @wszene
                          PS:
                          web.0
                          web.0
                          GlasfaserG
                          GlasfaserG
                          #106
                          und genau das meinte ich !
                            WszeneW
                            WszeneW
                            Wszene
                            #107
                            Ja aber wo muss ich denn meinen DP im Widget einfügen
                            • Aqara Sensoren
                            • WszeneW Wszene
                              GlasfaserG
                              GlasfaserG
                              #108
                              @wszene
                                @wszene
                                WszeneW
                                WszeneW
                                Wszene
                                #109
                                @glasfaser
                                Danke jetzt geht es
                                Ich sollte wohl doch ins Bett gehen und morgen weiter machen
                                Seid 2Uhr wach dann sollte man soetwas um diese Zeit nicht mehr machen
                                Aber nochmal 1000Dank für deine Geduld
                                • Aqara Sensoren
                                • O
                                  O
                                  ostseeskipper
                                  schrieb am zuletzt editiert von ostseeskipper
                                  #110
                                  Für alle die am Anfang Probleme mit den nicht angelegten Datenpunkten haben, werden hier automatisch angelegt wenn sie noch nicht da sind. Zeilen 11 bis 17
                                  // Skript Einstellungen *************************************************************************************************************************************************
                                  // Imports -> müssen im Javascript Adapter unter 'Zusätzliche NPM-Module' eingetragen sein
                                  const moment = require("moment");
                                  const momentDurationFormatSetup = require("moment-duration-format");
                                  // Datenpunkte anlegen falls nicht vorhanden ********************************
                                  if ( !existsState("0_userdata.0.vis.AdapterStatus.jsonList")){createState("0_userdata.0.vis.AdapterStatus.jsonList", false, {type: 'string'})};
                                  if ( !existsState("0_userdata.0.vis.AdapterStatus.restartTrigger")){createState("0_userdata.0.vis.AdapterStatus.restartTrigger", false, {type: 'string'})};
                                  if ( !existsState("0_userdata.0.vis.AdapterStatus.sortMode")){createState("0_userdata.0.vis.AdapterStatus.sortMode", false, {type: 'string'})};
                                  if ( !existsState("0_userdata.0.vis.AdapterStatus.filterMode")){createState("0_userdata.0.vis.AdapterStatus.filterMode", false, {type: 'string'})};
                                  let dpList = '0_userdata.0.vis.AdapterStatus.jsonList';                     // Datenpunkt für IconList Widget (Typ: Zeichenkette (String))
                                  let dpAdapterRestart = '0_userdata.0.vis.AdapterStatus.restartTrigger';     // Datenpunkt für Adapter restart (Typ: Zeichenkette (String))
                                  let dpSortMode = '0_userdata.0.vis.AdapterStatus.sortMode';                 // Datenpunkt für Sortieren (Typ: Zeichenkette (String))
                                  let dpFilterMode = '0_userdata.0.vis.AdapterStatus.filterMode';             // Datenpunkt für Filter (Typ: Zeichenkette (String))
                                  let adminUpdatesList = 'admin.0.info.updatesList';                          // Datenpunkt Admin Adapter für verfübare Updates der Adapter
                                  const checkInterval = 30;                                                   // Interval wie oft Status der Adapter aktualisiert werden soll (in Sekunden)
                                  let sprache = 'de';                                                         // Sprache für formatierung Dauer
                                  let formatierungDauer = "dd[T] hh[h] mm[m]";                                // Formatierung der Dauer -> siehe momentjs library
                                  let neustarten = true;                                                      // true: Adapter wird neugestartet, false: Adapter wird gestoppt oder gestartet
                                  let farbeAdapterAktiv = 'green';                                            // Status Bar Farbe wenn Adapter aktiv ist
                                  let farbeAdapterNichtAktiv = 'FireBrick';                                   // Status Bar Farbe wenn Adapter nicht aktiv ist oder Fehler vorliegt
                                  let farbeAdapterDeaktiviert = 'darkgrey';                                   // Status Bar Farbe wenn Adapter deaktiviert ist
                                  let farbeAdapterNichtVerbunden = 'yellow';                                  // Status Bar Farbe wenn Adapter nicht verbunden ist
                                  let farbeAdapterZeitgesteuert = 'lightgreen';                               // Status Bar Farbe wenn Adapter zeitgesteuert ist
                                  let farbeAdapterErweiterung = '#44739e';                                    // Status Bar Farbe wenn Adapter Erweiterung ist
                                  let farbeAdapterSystem = '#44739e';                                         // Status Bar Farbe wenn Adapter mit System gestartet wird
                                  let sortResetAfter = 120;                                                   // Sortierung nach X Sekunden auf sortReset zurücksetzen (0=deaktiviert)
                                  let sortReset = 'memHeapUsed'                                               // Sortierung auf die zurückgesetzt werden soll
                                  let filterResetAfter = 120;                                                 // Filter nach X Sekunden zurücksetzen (0=deaktiviert)
                                  // Fomate für moment Lib
                                  moment.locale(sprache);
                                  // auf .alive Änderungen hören
                                  let aliveSelector = `[id=system.adapter.*.alive]`;
                                  let adapterAliveList = $(aliveSelector);
                                  if (adapterAliveList.length === 0) {
                                      // Fehlermeldung ausgeben, wenn selector kein result liefert
                                      console.error(`no result for selector '${aliveSelector}'`)
                                  } else {
                                      // listener nur für Änderung bei alive
                                      adapterAliveList.on(adapterStatus);
                                  // auf .connection Änderungen hören
                                  let connectionSelector = `[id=*.info.connection]`;
                                  let adapterConnectionList = $(connectionSelector);
                                  if (adapterConnectionList.length === 0) {
                                      console.error(`no result for selector '${connectionSelector}'`)
                                  } else {
                                      adapterConnectionList.on(adapterStatus);
                                  // auf .connected Änderungen hören
                                  let connectedSelector = `[id=system.adapter.*.connected]`;
                                  let adapterConnectedList = $(connectedSelector);
                                  if (adapterConnectedList.length === 0) {
                                      console.error(`no result for selector '${connectedSelector}'`)
                                  } else {
                                      adapterConnectedList.on(adapterStatus);
                                  // auf Änderungen der Sortieung hören
                                  on({ id: dpSortMode, change: 'any' }, adapterStatus);
                                  on({ id: dpSortMode, change: 'any' }, resetSort);
                                  // auf Änderungen der Filter hören
                                  on({ id: dpFilterMode, change: 'any' }, adapterStatus);
                                  on({ id: dpFilterMode, change: 'any' }, resetFilter);
                                  // Funktion adapterStatus alle x Sekunden ausführen
                                  schedule('*/' + checkInterval + ' * * * * *', adapterStatus);
                                  function adapterStatus() {
                                      // Funktion um Status der Adapter abzurufen und als JSON String für das Material Design Widget IconList aufbereiten
                                      try {
                                          let adapterList = [];
                                          let updateList = myHelper().getStateValueIfExist(adminUpdatesList);
                                          for (var i = 0; i <= adapterAliveList.length - 1; i++) {
                                              let id = adapterAliveList[i].replace('.alive', '');
                                              let obj = getObject(adapterAliveList[i].replace('.alive', ''));
                                              let nameArray = id.replace('system.adapter.', '').split(".");
                                              let name = nameArray[0];
                                              name = name.charAt(0).toUpperCase() + name.slice(1);
                                              let nameWithInstance = name;
                                              let adapterInstance = nameArray[1];
                                              if (parseInt(adapterInstance) > 0) {
                                                  nameWithInstance = name + '.' + adapterInstance;
                                              let uptime = (existsState(id + '.uptime')) ? moment.duration(getState(id + '.uptime').val, 'seconds').format(formatierungDauer, 0) : '-';
                                              let image = (myHelper().checkCommonPropertyExist(obj, 'icon')) ? `/${nameArray[0]}.admin/${obj.common.icon}` : 'image-off-outline';
                                              let hasUpdates = updateList && updateList.includes(nameArray[0]);
                                              let newVersion = (hasUpdates) ? '<span class="mdi mdi-update" style="color: #ec0909;"></span>' : '';
                                              let text = `<div style="display: flex; flex-direction: row; line-height: 1.5; padding-right: 8px; align-items: center;">
                                                              <div style="flex: 1">${newVersion} ${nameWithInstance}</div>
                                                              <div style="color: grey; font-size: 12px; font-family: RobotoCondensed-LightItalic;">${myHelper().getCommonPropertyIfExist(obj, 'version', '-', 'v', '')}</div>
                                                          </div>`
                                              let subText = `<div style="display: flex; flex-direction: row; line-height: 1.3; padding-left: 1px; padding-right: 8px; align-items: center;">
        <div style="flex: 1;">CPU</div>
        <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic; text-align: right;">${myHelper().getStateValueIfExist(id + '.cpu', '-', '', ' %')}</div>
                                                              </div>
        <div style="flex: 1;">RAM total</div>
        <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic; text-align: right;">${myHelper().getStateValueIfExist(id + '.memHeapTotal', '-', '', ' MB')}</div>
                                                              </div>
        <div style="flex: 1;">RAM verwendet</div>
        <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic; text-align: right;">${myHelper().getStateValueIfExist(id + '.memHeapUsed', '-', '', ' MB')}</div>
                                                              </div>
        <div style="flex: 1;">RAM reserviert</div>
        <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic; text-align: right;">${myHelper().getStateValueIfExist(id + '.memRss', '-', '', ' MB')}</div>
                                                              </div>
        <div style="flex: 1;">Betriebszeit</div>
        <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic; text-align: right;">${uptime}</div>
                                                              </div>
        <div style="flex: 1;">Modus</div>
        <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic; text-align: right;">${myHelper().getCommonPropertyIfExist(obj, 'mode', '-')}</div>
                                                              </div>`
                                              let statusBarColor = farbeAdapterNichtAktiv;
                                              let status = 3;
                                              if (myHelper().getStateValueIfExist(adapterAliveList[i]) === 'true') {
                                                  statusBarColor = farbeAdapterAktiv;
                                                  status = 0;
                                                  if (existsState(id.replace('system.adapter.', '') + '.info.connection')) {
                                                      if (!getState(id.replace('system.adapter.', '') + '.info.connection').val) {
                                                          statusBarColor = farbeAdapterNichtVerbunden;
                                                          status = 4;
                                                  } else {
                                                      if (myHelper().getStateValueIfExist(adapterAliveList[i].replace('.alive', '.connected')) === 'false') {
                                                          status = 4;
                                              if (myHelper().getCommonPropertyIfExist(obj, 'mode') === 'schedule') {
                                                  // Adapter ist zeitgesteuert
                                                  statusBarColor = farbeAdapterZeitgesteuert;
                                                  status = 1;
                                              if (myHelper().getCommonPropertyIfExist(obj, 'mode') === 'extension') {
                                                  // Adapter ist Extension
                                                  statusBarColor = farbeAdapterErweiterung;
                                                  status = 1;
                                              if (myHelper().getCommonPropertyIfExist(obj, 'mode') === 'once') {
                                                  // Adapter wird mit System gestartet
                                                  statusBarColor = farbeAdapterSystem;
                                                  status = 1;
                                              if (myHelper().getCommonPropertyIfExist(obj, 'enabled', false).toString() === 'false') {
                                                  // Adapter ist deaktiviert
                                                  statusBarColor = farbeAdapterDeaktiviert;
                                                  status = 2;
                                              adapterList.push({
                                                  text: text,
                                                  subText: subText,
                                                  image: image,
                                                  listType: "buttonState",
                                                  objectId: dpAdapterRestart,
                                                  buttonStateValue: id,
                                                  statusBarColor: statusBarColor,
                                                  showValueLabel: false,
                                                  mode: myHelper().getCommonPropertyIfExist(obj, 'mode'),
                                                  hasUpdates: hasUpdates,
                                                  cpu: parseFloat(myHelper().getStateValueIfExist(id + '.cpu', '0')),
                                                  memHeapTotal: parseFloat(myHelper().getStateValueIfExist(id + '.memHeapTotal', '0')),
                                                  memHeapUsed: parseFloat(myHelper().getStateValueIfExist(id + '.memHeapUsed', '0')),
                                                  memRss: parseFloat(myHelper().getStateValueIfExist(id + '.memRss', '0')),
                                                  uptime: parseFloat(myHelper().getStateValueIfExist(id + '.uptime', 0)),
                                                  status: status,
                                                  lockEnabled: true
                                          let sortMode = myHelper().getStateValueIfExist(dpSortMode, 'name');
                                          if (sortMode === 'name' || sortMode === 'mode') {
                                              adapterList.sort(function (a, b) {
                                                  return a[sortMode].toLowerCase() == b[sortMode].toLowerCase() ? 0 : +(a[sortMode].toLowerCase() > b[sortMode].toLowerCase()) || -1;
                                          } else if (sortMode === 'hasUpdates' || sortMode === 'cpu' || sortMode === 'memHeapTotal' || sortMode === 'memHeapUsed' || sortMode === 'memRss' || sortMode === 'uptime' || sortMode === 'status') {
                                                  return a[sortMode] == b[sortMode] ? 0 : +(a[sortMode] < b[sortMode]) || -1;
                                          } else {
                                              // default: nach name sortieren
                                              sortMode = 'name'
                                          // Filter: not connected, updates, deaktiviert, aktiviert
                                          let filterMode = myHelper().getStateValueIfExist(dpFilterMode, null);
                                          if (filterMode && filterMode !== null && filterMode !== '') {
                                              if (filterMode === 'hasUpdates') {
                                                  adapterList = adapterList.filter(function (item) {
                                                      return item.hasUpdates === true;
                                              } else if (filterMode === 'notConnected') {
                                                      return item.status === 4;
                                              } else if (filterMode === 'deactivated') {
                                                      return item.status === 2;
                                              } else if (filterMode === 'activated') {
                                                      return item.status <= 1;
                                          let result = JSON.stringify(adapterList);
                                          if (existsState(dpList) && getState(dpList).val !== result) {
                                              setState(dpList, result, true);
                                          } else {
                                      } catch (err) {
                                          console.error(`[adapterStatus] error: ${err.message}, stack: ${err.stack}`);
                                  // Beim Staren des Skriptes Adapter Status abrufen
                                  adapterStatus();
                                  // Funktion um Adapter zu starten / neu starten
                                  on({ id: dpAdapterRestart }, function (obj) {
                                      var adapter = getObject(obj.state.val.toString());
                                      if (neustarten) {
                                          if (adapter.common && adapter.common.enabled === false) {
                                              // Adapter deaktiviert -> starten
                                              adapter.common.enabled = true;
                                      } else {
                                          if (adapter.common && adapter.common.enabled) {
                                              adapter.common.enabled = !adapter.common.enabled;
                                          } else {
                                      setObject(obj.state.val, adapter);
                                      console.log(`${obj.state.val.replace('system.adapter.', '')} neugestartet`);
                                  function resetSort() {
                                      let sortMode = myHelper().getStateValueIfExist(dpSortMode, null);
                                      if (sortResetAfter > 0) {
                                          setTimeout(function () {
                                              if (sortMode !== null && sortMode === myHelper().getStateValueIfExist(dpSortMode, null)) {
                                                  setState(dpSortMode, sortReset);
                                          }, sortResetAfter * 1000);
                                  function resetFilter() {
                                      if (filterResetAfter > 0) {
                                              if (filterMode !== null && filterMode === myHelper().getStateValueIfExist(dpFilterMode, null)) {
                                                  setState(dpFilterMode, '');
                                          }, filterResetAfter * 1000);
                                  function myHelper() {
                                      return {
                                          getStateValueIfExist: function (id, nullValue = undefined, prepand = '', append = '') {
                                              if (existsState(id)) {
                                                  return prepand + getState(id).val + append;
                                              } else {
                                                  return nullValue;
                                          getCommonPropertyIfExist: function (object, prop, nullValue = undefined, prepand = '', append = '') {
                                              if (myHelper().checkCommonPropertyExist(object, prop)) {
                                                  return prepand + object.common[prop] + append;
                                              } else {
                                                  return nullValue;
                                          checkCommonPropertyExist: function (object, prop) {
                                              if (object && object.common && object.common[prop]) {
                                                  return true;
                                              } else {
                                                  return false;
                                  • daes10D
                                    daes10D
                                    daes10
                                    #111
                                    @ostseeskipper Vielen Dank, hat bei mir auch gut funktioniert.
                                    Kann mir aber jemand helfen, warum bei mir überall undefined angezeigt wird?
                                    Hab ich eine Einstellung übersehen? Weil alle Daten werden korrekt abgefragt.
                                    I M L 3 Antworten Letzte Antwort
                                    • daes10D daes10
                                      I
                                      I
                                      Idefix01
                                      #112
                                      Hallöchen, ein super Script.
                                      Nur das mit der Farbe für die Werte funktioniert bei mir nicht, diese bleibt weiterhin grau
                                      let dpList = 'javascript.0.vis.AdapterStatus.jsonList';                     // Datenpunkt für IconList Widget (Typ: Zeichenkette (String))
                                      let dpAdapterRestart = 'javascript.0.vis.AdapterStatus.restartTrigger';     // Datenpunkt für Adapter restart (Typ: Zeichenkette (String))
                                      let dpSortMode = 'javascript.0.vis.AdapterStatus.sortMode';                 // Datenpunkt für Sortieren (Typ: Zeichenkette (String))
                                      let dpFilterMode = 'javascript.0.vis.AdapterStatus.filterMode';             // Datenpunkt für Filter (Typ: Zeichenkette (String))
                                      let farbeAdapterWerte = '#ffffff';                                       // Sekundärfarbe Adapterwerte, einer muss auskommentiert sein !
                                      • C
                                        C
                                        cst9
                                        #113
                                        bei mir ist das Problem, das wenn ich die Filter über ein mobiles Gerät anwähle, wird das Bild vergrößert sprich herangezoomt. Dabei spielt es auch keine Rolle ob man es über die App oder den Browser benutzt, es wird immer komischerweise immer herangezoomt.
                                        Hat jemand das gleiche Problem und wie kann ich das abschalten?
                                        Schöne Grüße
                                        • ScroungerS Scrounger
                                          Skript zur Anzeige des Adapter Status mit dem Material Design IconList Widget
                                          Mit diesem Skript wird ein json string erzeugt mit dem Status aller installierten Adapter. Diese Daten (Datenpunkt) kann dann im Material Design IconList Widget verwendet werden, um den Status der Adapter im VIS anzuzeigen.
                                          letzte Aktualierung: 04.03.2020
                                          Voraussetzung:
                                          • Material Design Widgets v0.2.62
                                          Funktionen:
                                          • Anzeige des Status aller Adapter (Aktiviert, Deakitivert, nicht verbunden, update verfügbar, etc.)
                                          • Anzeige von Werten der Adapter (Betriebszeit, Ram, etc.)
                                          • Neustarten / Starten / Stoppen von Adaptern
                                          • Sortier und Filter Funktion
                                          • Einstellungen, siehe im Skript Sektion Einstellungen, Funktion der Einstellungen ist dort als Kommentar beschrieben.
                                          Ist auch im Online Beispiel enthalten
                                          View zum importieren:
                                            "settings": {
                                              "style": {
                                                "background_class": ""
                                              "theme": "redmond",
                                              "sizex": "",
                                              "sizey": "",
                                              "gridSize": "",
                                              "snapType": null
                                            "widgets": {
                                              "e00001": {
                                                "tpl": "tplVis-materialdesign-Icon-List",
                                                "data": {
                                                  "g_fixed": false,
                                                  "g_visibility": false,
                                                  "g_css_font_text": false,
                                                  "g_css_background": false,
                                                  "g_css_shadow_padding": false,
                                                  "g_css_border": false,
                                                  "g_gestures": false,
                                                  "g_signals": false,
                                                  "g_last_change": false,
                                                  "visibility-cond": "==",
                                                  "visibility-val": 1,
                                                  "visibility-groups-action": "hide",
                                                  "wrapItems": true,
                                                  "listItemDataMethod": "jsonStringObject",
                                                  "countListItems": "1",
                                                  "vibrateOnMobilDevices": "50",
                                                  "listLayout": "card",
                                                  "itemLayout": "horizontal",
                                                  "listType0": "text",
                                                  "showValueLabel0": "true",
                                                  "listType1": "text",
                                                  "showValueLabel1": "true",
                                                  "signals-cond-0": "==",
                                                  "signals-val-0": true,
                                                  "signals-icon-0": "/vis/signals/lowbattery.png",
                                                  "signals-icon-size-0": 0,
                                                  "signals-blink-0": false,
                                                  "signals-horz-0": 0,
                                                  "signals-vert-0": 0,
                                                  "signals-hide-edit-0": false,
                                                  "signals-cond-1": "==",
                                                  "signals-val-1": true,
                                                  "signals-icon-1": "/vis/signals/lowbattery.png",
                                                  "signals-icon-size-1": 0,
                                                  "signals-blink-1": false,
                                                  "signals-horz-1": 0,
                                                  "signals-vert-1": 0,
                                                  "signals-hide-edit-1": false,
                                                  "signals-cond-2": "==",
                                                  "signals-val-2": true,
                                                  "signals-icon-2": "/vis/signals/lowbattery.png",
                                                  "signals-icon-size-2": 0,
                                                  "signals-blink-2": false,
                                                  "signals-horz-2": 0,
                                                  "signals-vert-2": 0,
                                                  "signals-hide-edit-2": false,
                                                  "lc-type": "last-change",
                                                  "lc-is-interval": true,
                                                  "lc-is-moment": false,
                                                  "lc-format": "",
                                                  "lc-position-vert": "top",
                                                  "lc-position-horz": "right",
                                                  "lc-offset-vert": 0,
                                                  "lc-offset-horz": 0,
                                                  "lc-font-size": "12px",
                                                  "lc-font-family": "",
                                                  "lc-font-style": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-border-width": "0",
                                                  "lc-border-style": "",
                                                  "lc-border-color": "",
                                                  "lc-border-radius": 10,
                                                  "lc-zindex": 0,
                                                  "json_string_oid": "0_userdata.0.vis.AdapterStatus.jsonList",
                                                  "maxItemsperRow": "6",
                                                  "iconItemMinWidth": "300",
                                                  "iconHeight": "60",
                                                  "buttonHeight": "100",
                                                  "labelFontSize": "22",
                                                  "subLabelFontSize": "14",
                                                  "subLabelFontColor": "#000000",
                                                  "labelFontFamily": "RobotoCondensed-Regular",
                                                  "subLabelFontFamily": "RobotoCondensed-Light",
                                                  "horizontalIconContainerWidth": "120"
                                                "style": {
                                                  "left": "0px",
                                                  "top": "50px",
                                                  "width": "100%",
                                                  "height": "calc(100% - 50px)",
                                                  "overflow-x": "",
                                                  "overflow-y": "auto",
                                                  "z-index": "1"
                                                "widgetSet": "materialdesign"
                                              "e00002": {
                                                "tpl": "tplHtml",
                                                "data": {
                                                  "g_fixed": false,
                                                  "g_css_background": true,
                                                  "g_signals": false,
                                                  "refreshInterval": "0",
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0
                                                "style": {
                                                  "left": "0",
                                                  "top": "0",
                                                  "width": "100%",
                                                  "height": "50px",
                                                  "background-color": "#44739e"
                                                "widgetSet": "basic"
                                              "e00003": {
                                                "tpl": "tplVis-materialdesign-Select",
                                                "data": {
                                                  "oid": "0_userdata.0.vis.AdapterStatus.sortMode",
                                                  "g_fixed": false,
                                                  "g_signals": false,
                                                  "inputType": "text",
                                                  "inputLayout": "regular",
                                                  "showInputMessageAlways": "true",
                                                  "showInputCounter": false,
                                                  "clearIconShow": false,
                                                  "listDataMethod": "jsonStringObject",
                                                  "countSelectItems": "1",
                                                  "listPosition": "bottom",
                                                  "showSelectedIcon": "prepend-inner",
                                                  "showValue": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                  "inputLabelText": "Sortieren nach",
                                                  "inputLabelColor": "#ffffff",
                                                  "inputLabelFontFamily": "RobotoCondensed-LightItalic",
                                                  "collapseIconColor": "#ffffff",
                                                  "collapseIconSize": "",
                                                  "jsonStringObject": "[\n\t{\n\t\t\"text\": \"Adaptername\",\n\t\t\"value\": \"name\",\n\t\t\"icon\": \"sort-alphabetical\"\n\t},\n\t{\n\t\t\"text\": \"Status\",\n\t\t\"value\": \"status\",\n\t\t\"icon\": \"information-variant\"\n\t},\t\n\t{\n\t\t\"text\": \"Modus\",\n\t\t\"value\": \"mode\",\n\t\t\"icon\": \"view-dashboard\"\n\t},\n\t{\n\t\t\"text\": \"Updates verfügbar\",\n\t\t\"value\": \"hasUpdates\",\n\t\t\"icon\": \"package-down\"\n\t},\n\t{\n\t\t\"text\": \"CPU\",\n\t\t\"value\": \"cpu\",\n\t\t\"icon\": \"cpu-64-bit\"\n\t},\n\t{\n\t\t\"text\": \"RAM total\",\n\t\t\"value\": \"memHeapTotal\",\n\t\t\"icon\": \"memory\"\n\t},\n\t{\n\t\t\"text\": \"RAM verwendet\",\n\t\t\"value\": \"memHeapUsed\",\n\t\t\"icon\": \"memory\"\n\t},\n\t{\n\t\t\"text\": \"RAM reserviert\",\n\t\t\"value\": \"memRss\",\n\t\t\"icon\": \"memory\"\n\t},\n\t{\n\t\t\"text\": \"Betriebszeit\",\n\t\t\"value\": \"uptime\",\n\t\t\"icon\": \"clock-check-outline\"\n\t}\n]",
                                                  "listPositionOffset": true,
                                                  "inputLayoutBackgroundColor": "transparent",
                                                  "inputLabelColorSelected": "#ffffff",
                                                  "inputTranslateX": "-15",
                                                  "clearIcon": "",
                                                  "inputLayoutBorderColorHover": "#ffffff",
                                                  "inputLayoutBorderColorSelected": "#ffffff",
                                                  "inputLayoutBorderColor": "#a1a1a1",
                                                  "listItemFontColor": "",
                                                  "inputTextColor": "#ffffff",
                                                  "inputTextFontFamily": "RobotoCondensed-LightItalic",
                                                  "prepandIcon": "",
                                                  "prepandIconColor": "",
                                                  "prepandIconSize": "",
                                                  "prepandInnerIcon": "",
                                                  "prepandInnerIconColor": "#ffffff",
                                                  "prepandInnerIconSize": "18",
                                                  "collapseIcon": "",
                                                  "inputTranslateY": "-12",
                                                  "listIconSelectedColor": "#44739e",
                                                  "listIconColor": "",
                                                  "appendOuterIcon": "",
                                                  "appendOuterIconSize": "2",
                                                  "listItemFont": "RobotoCondensed-Regular",
                                                  "listItemRippleEffectColor": "",
                                                  "inputLayoutBackgroundColorSelected": "",
                                                  "inputLayoutBackgroundColorHover": ""
                                                "style": {
                                                  "left": "10px",
                                                  "top": "0px",
                                                  "z-index": "1",
                                                  "width": "calc(50% - 20px)",
                                                  "height": "40px"
                                              "e00004": {
                                                "data": {
                                                  "oid": "0_userdata.0.vis.AdapterStatus.filterMode",
                                                  "g_fixed": false,
                                                  "g_signals": false,
                                                  "clearIconShow": true,
                                                  "showValue": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                  "inputLabelText": "Filtern nach",
                                                  "jsonStringObject": "[\n\t{\n\t\t\"text\": \"nicht verbunden\",\n\t\t\"value\": \"notConnected\",\n\t\t\"icon\": \"network-off\"\n\t},\n\t{\n\t\t\"text\": \"deaktiviert\",\n\t\t\"value\": \"deactivated\",\n\t\t\"icon\": \"checkbox-blank-outline\"\n\t},\t\n\t{\n\t\t\"text\": \"aktiviert\",\n\t\t\"value\": \"activated\",\n\t\t\"icon\": \"checkbox-intermediate\"\n\t},\n\t{\n\t\t\"text\": \"Updates verfügbar\",\n\t\t\"value\": \"hasUpdates\",\n\t\t\"icon\": \"package-down\"\n\t}\n]",
                                                  "clearIcon": "",
                                                  "prepandIcon": "",
                                                  "collapseIcon": "",
                                                  "inputLayoutBackgroundColorHover": "",
                                                  "clearIconColor": "#ffffff"
                                                "style": {
                                                  "left": "calc(50% + 10px)",
                                                  "top": "0px",
                                                  "z-index": "1",
                                                  "height": "40px"
                                            "name": "AdapterStatus",
                                            "filterList": []
                                          Hier hab ich beschrieben, wie man das layout am besten einstellt:
                                          https://forum.iobroker.net/topic/30661/material-design-widgets-adapter-status/5
                                          Skript
                                          } else {
                                          } else {
                                          } else {
                                              try {
        </div>`
        </div>
        </div>
        </div>
        </div>
        </div>
        </div>`
                                                      let status = 3;
                                                          status = 0;
        status = 4;
                                                          } else {
        status = 4;
                                                          status = 1;
                                                          status = 1;
                                                          status = 1;
                                                          status = 2;
                                                      adapterList.push({
                                                          text: text,
                                                          subText: subText,
                                                          image: image,
                                                          status: status,
                                                          lockEnabled: true
                                                  } else {
                                                      sortMode = 'name'
                                                  } else {
                                              } catch (err) {
                                          adapterStatus();
                                              if (neustarten) {
                                              } else {
                                                  } else {
                                              return {
                                                      } else {
                                                          return nullValue;
                                                      } else {
                                                          return nullValue;
                                                          return true;
                                                      } else {
                                                          return false;
                                          Benötigte libraries & Einstellungen im Javascript Adapter:
                                          Die Idee dazu kommt von @sigi234, seine Version findet ihr hier.
                                          Vielen Dank für die Inspiration 👍
                                          F
                                          F
                                          Frank579
                                          #114
                                          @scrounger Hallo ich nutze das skript jetzt schon etwas länger, echt klasse gemacht 👍 Habe kürzlich den Weatherunderground Adapter installiert, die Kachel von dem sieht irgendwiw komisch aus, Hast du oder wer anders eine Idee dazu.
                                          Gruß Frank
                                          O 1 Antwort Letzte Antwort
                                          84.1k
