  4. Material Design Widgets: Adapter Status
    6.6k
material design widgetsvisiconlistviewview adapteradapterstatusanzeige
144 Beiträge 48 Kommentatoren 48.9k Aufrufe 60 Beobachtet
  • WszeneW Wszene
    @glasfaser sagte in Material Design Widgets: Adapter Status:
    @Wszene
    Adapter starten und im Log schauen ob eine Fehlermeldung kommt .
    Ich meinte nicht das Script an sich , sondern was beim Hinzufügen des NPM Modul kommt .
    Achso
    also nochmal 😁
    javascript.0
    2022-01-28 20:37:13.301	info	State value to set for "0_userdata.0.001_Alexa.01_Stube.Lampen.Stehlampe" has to be type "boolean" but received type "string"
    javascript.0
    2022-01-28 20:37:13.247	warn	at processTimers (internal/timers.js:500:7)
    javascript.0
    2022-01-28 20:37:13.247	warn	at listOnTimeout (internal/timers.js:557:17)
    javascript.0
    2022-01-28 20:37:13.247	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2117:34)
    javascript.0
    2022-01-28 20:37:13.247	warn	at Object.<anonymous> (script.js.01-Stube.Lampen.Stehlampe_-_An_Aus:115:29)
    javascript.0
    2022-01-28 20:37:13.247	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1437:20)
    javascript.0
    2022-01-28 20:37:13.243	warn	You are assigning a string to the state "0_userdata.0.001_Alexa.01_Stube.Lampen.Stehlampe" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
    vw-connect.0
    2022-01-28 20:37:13.028	error	failed set state
    vw-connect.0
    2022-01-28 20:37:13.027	error	{"error":{"errorCode":"RS.security.9007","description":"The context has not gained a legitimation due to missing access rights."}}
    vw-connect.0
    2022-01-28 20:37:13.027	error	403
    javascript.0
    2022-01-28 20:37:12.276	info	script.js.001-VIS.Wetter.Wetter_DD_-_DWD-Regenradar: registered 0 subscriptions and 1 schedule
    javascript.0
    2022-01-28 20:37:12.267	info	Start javascript script.js.001-VIS.Wetter.Wetter_DD_-_DWD-Regenradar
    javascript.0
    2022-01-28 20:37:12.267	info	script.js.06-Autos.Scala_-_Tabelle-Status: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.266	info	Start javascript script.js.06-Autos.Scala_-_Tabelle-Status
    javascript.0
    2022-01-28 20:37:12.265	info	script.js.001-VIS.Wetter.Wetter_DD_-_Es_regnet_oder_schneit_oder_stürmt: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.264	info	Start javascript script.js.001-VIS.Wetter.Wetter_DD_-_Es_regnet_oder_schneit_oder_stürmt
    javascript.0
    2022-01-28 20:37:12.264	info	script.js.001-VIS.Wetter.Wetter_GRH_-_Überschriften: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.263	info	Start javascript script.js.001-VIS.Wetter.Wetter_GRH_-_Überschriften
    javascript.0
    2022-01-28 20:37:12.262	info	script.js.001-VIS.Wetter.Wetter_GRH_-_Werte: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.261	info	Start javascript script.js.001-VIS.Wetter.Wetter_GRH_-_Werte
    javascript.0
    2022-01-28 20:37:12.261	info	script.js.001-VIS.Wetter.Wetter_GRH_-_MinMax-Temp: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.260	info	Start javascript script.js.001-VIS.Wetter.Wetter_GRH_-_MinMax-Temp
    javascript.0
    2022-01-28 20:37:12.259	info	script.js.001-VIS.Wetter.Wetter_DD_-_Werte: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.258	info	Start javascript script.js.001-VIS.Wetter.Wetter_DD_-_Werte
    javascript.0
    2022-01-28 20:37:12.258	info	script.js.001-VIS.Wetter.Wetter_DD_-_MinMax-Temp: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.256	info	Start javascript script.js.001-VIS.Wetter.Wetter_DD_-_MinMax-Temp
    javascript.0
    2022-01-28 20:37:12.256	info	script.js.001-VIS.Wetter.Wetter_DD_-_Überschriften: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.255	info	Start javascript script.js.001-VIS.Wetter.Wetter_DD_-_Überschriften
    javascript.0
    2022-01-28 20:37:12.255	info	script.js.001-VIS.Welche_Steckdosen_sind_an: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.253	info	Start javascript script.js.001-VIS.Welche_Steckdosen_sind_an
    javascript.0
    2022-01-28 20:37:12.253	info	script.js.001-VIS.Welche_Lampen_sind_an: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.252	info	Start javascript script.js.001-VIS.Welche_Lampen_sind_an
    javascript.0
    2022-01-28 20:37:12.252	info	script.js.02-Schlafzimmer.Dosen.TV-Bett: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.250	info	Start javascript script.js.02-Schlafzimmer.Dosen.TV-Bett
    javascript.0
    2022-01-28 20:37:12.250	info	script.js.02-Schlafzimmer.Taster.Sleeptimer_-_Button: registered 1 subscription and 0 schedules
    javascript.0
    2022-01-28 20:37:12.249	info	Start javascript script.js.02-Schlafzimmer.Taster.Sleeptimer_-_Button
    javascript.0
    2022-01-28 20:37:12.249	info	script.js.01-Stube.Fernbedienungen.Kino_an_aus: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.247	info	Start javascript script.js.01-Stube.Fernbedienungen.Kino_an_aus
    javascript.0
    2022-01-28 20:37:12.247	info	script.js.01-Stube.Fernbedienungen.TV_Sender_schalten_-_Alexa: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.244	info	Start javascript script.js.01-Stube.Fernbedienungen.TV_Sender_schalten_-_Alexa
    javascript.0
    2022-01-28 20:37:12.231	info	script.js.01-Stube.Fernbedienungen.TV_Kanal_-_Hoch_Runter: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.230	info	Start javascript script.js.01-Stube.Fernbedienungen.TV_Kanal_-_Hoch_Runter
    javascript.0
    2022-01-28 20:37:12.230	info	script.js.01-Stube.Fernbedienungen.AV-Receiver_-_Lautstärke: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.228	info	Start javascript script.js.01-Stube.Fernbedienungen.AV-Receiver_-_Lautstärke
    javascript.0
    2022-01-28 20:37:12.228	info	script.js.02-Schlafzimmer.Schalter.Schlafzimmerlampe: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.227	info	Start javascript script.js.02-Schlafzimmer.Schalter.Schlafzimmerlampe
    javascript.0
    2022-01-28 20:37:12.227	info	script.js.01-Stube.Schalter.Lampe-Sofatisch: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.225	info	Start javascript script.js.01-Stube.Schalter.Lampe-Sofatisch
    javascript.0
    2022-01-28 20:37:12.121	info	script.js.01-Stube.Schalter.Lampe-Esstisch: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.120	info	Start javascript script.js.01-Stube.Schalter.Lampe-Esstisch
    javascript.0
    2022-01-28 20:37:12.120	info	script.js.01-Stube.Lampen.Stehlampe_-_An_Aus: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.118	info	Start javascript script.js.01-Stube.Lampen.Stehlampe_-_An_Aus
    javascript.0
    2022-01-28 20:37:12.118	info	script.js.06-Autos.Kodiaq_-_Tabelle_Türen-Fenster: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.115	info	Start javascript script.js.06-Autos.Kodiaq_-_Tabelle_Türen-Fenster
    javascript.0
    2022-01-28 20:37:12.112	info	script.js.06-Autos.Kodiaq_-_Tabelle-Status: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.111	info	Start javascript script.js.06-Autos.Kodiaq_-_Tabelle-Status
    javascript.0
    2022-01-28 20:37:12.111	info	script.js.001-VIS.Tankstellen_-_offen-geschlossen: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.109	info	Start javascript script.js.001-VIS.Tankstellen_-_offen-geschlossen
    javascript.0
    2022-01-28 20:37:12.109	info	script.js.06-Autos.Telegram_-_Tankerinnerung: registered 0 subscriptions and 1 schedule
    javascript.0
    2022-01-28 20:37:12.092	info	Start javascript script.js.06-Autos.Telegram_-_Tankerinnerung
    javascript.0
    2022-01-28 20:37:12.092	info	script.js.06-Autos.Telegram_-_Standortwechsel: registered 2 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.090	info	Start javascript script.js.06-Autos.Telegram_-_Standortwechsel
    javascript.0
    2022-01-28 20:37:12.090	info	script.js.06-Autos.Kodiaq_-_Datenpunkte_Tueren-Fenster: registered 8 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.088	info	Start javascript script.js.06-Autos.Kodiaq_-_Datenpunkte_Tueren-Fenster
    javascript.0
    2022-01-28 20:37:12.088	info	script.js.06-Autos.Kodiaq_-_Standheizung: registered 3 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.087	info	Start javascript script.js.06-Autos.Kodiaq_-_Standheizung
    javascript.0
    2022-01-28 20:37:12.086	info	script.js.06-Autos.Scala_-_Datenpunkte_anlegen: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.085	info	Start javascript script.js.06-Autos.Scala_-_Datenpunkte_anlegen
    javascript.0
    2022-01-28 20:37:12.085	info	script.js.06-Autos.Kodiaq_-_Datenpunkte_anlegen: registered 0 subscriptions and 0 schedules
    javascript.0
    2022-01-28 20:37:12.079	info	Start javascript script.js.06-Autos.Kodiaq_-_Datenpunkte_anlegen
    javascript.0
    2022-01-28 20:37:12.079	info	script.js.03-Flur-Kammer.Kammerlicht_schalten: registered 1 subscription and 0 schedules
    javascript.0
    2022-01-28 20:37:12.077	info	Start javascript script.js.03-Flur-Kammer.Kammerlicht_schalten
    javascript.0
    2022-01-28 20:37:12.077	info	script.js.01-Stube.Lampen.Zeitplan_-_Leuchtbaum: registered 0 subscriptions and 4 schedules
    javascript.0
    2022-01-28 20:37:12.054	info	Start javascript script.js.01-Stube.Lampen.Zeitplan_-_Leuchtbaum
    javascript.0
    2022-01-28 20:37:11.793	info	received all states
    javascript.0
    2022-01-28 20:37:11.343	info	received all objects
    javascript.0
    2022-01-28 20:37:10.139	info	requesting all objects
    javascript.0
    2022-01-28 20:37:10.138	info	requesting all states
    javascript.0
    2022-01-28 20:37:10.100	info	starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.18.3, js-controller: 3.3.22
    host.ioBroker02
    2022-01-28 20:37:09.239	info	instance system.adapter.javascript.0 started with pid 73225
    host.ioBroker02
    2022-01-28 20:37:06.743	info	instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    javascript.0
    2022-01-28 20:37:06.204	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    javascript.0
    2022-01-28 20:37:06.203	info	terminating
    javascript.0
    2022-01-28 20:37:06.200	info	Stop script script.js.001-VIS.Wetter.Wetter_DD_-_DWD-Regenradar
    javascript.0
    2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Wetter.Wetter_GRH_-_Überschriften
    javascript.0
    javascript.0
    2022-01-28 20:37:06.198	info	Stop script script.js.001-VIS.Welche_Lampen_sind_an
    javascript.0
    javascript.0
    2022-01-28 20:37:06.197	info	Stop script script.js.01-Stube.Fernbedienungen.AV-Receiver_-_Lautstärke
    javascript.0
    javascript.0
    javascript.0
    2022-01-28 20:37:06.196	info	Stop script script.js.01-Stube.Lampen.Stehlampe_-_An_Aus
    javascript.0
    javascript.0
    javascript.0
    2022-01-28 20:37:06.195	info	Stop script script.js.06-Autos.Telegram_-_Tankerinnerung
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    2022-01-28 20:37:06.200	info	Stop script script.js.06-Autos.Scala_-_Tabelle-Status
    javascript.0
    2022-01-28 20:37:06.200	info	Stop script script.js.001-VIS.Wetter.Wetter_DD_-_Es_regnet_oder_schneit_oder_stürmt
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Wetter.Wetter_GRH_-_Werte
    javascript.0
    2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Wetter.Wetter_GRH_-_MinMax-Temp
    javascript.0
    2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Wetter.Wetter_DD_-_Werte
    javascript.0
    2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Wetter.Wetter_DD_-_MinMax-Temp
    javascript.0
    2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Wetter.Wetter_DD_-_Überschriften
    javascript.0
    2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Welche_Steckdosen_sind_an
    javascript.0
    javascript.0
    javascript.0
    2022-01-28 20:37:06.198	info	Stop script script.js.02-Schlafzimmer.Dosen.TV-Bett
    javascript.0
    2022-01-28 20:37:06.198	info	Stop script script.js.02-Schlafzimmer.Taster.Sleeptimer_-_Button
    javascript.0
    2022-01-28 20:37:06.198	info	Stop script script.js.01-Stube.Fernbedienungen.Kino_an_aus
    javascript.0
    2022-01-28 20:37:06.198	info	Stop script script.js.01-Stube.Fernbedienungen.TV_Sender_schalten_-_Alexa
    javascript.0
    2022-01-28 20:37:06.198	info	Stop script script.js.01-Stube.Fernbedienungen.TV_Kanal_-_Hoch_Runter
    javascript.0
    javascript.0
    javascript.0
    2022-01-28 20:37:06.197	info	Stop script script.js.02-Schlafzimmer.Schalter.Schlafzimmerlampe
    javascript.0
    2022-01-28 20:37:06.197	info	Stop script script.js.01-Stube.Schalter.Lampe-Sofatisch
    javascript.0
    2022-01-28 20:37:06.197	info	Stop script script.js.01-Stube.Schalter.Lampe-Esstisch
    javascript.0
    javascript.0
    2022-01-28 20:37:06.196	info	Stop script script.js.06-Autos.Kodiaq_-_Tabelle_Türen-Fenster
    javascript.0
    2022-01-28 20:37:06.196	info	Stop script script.js.06-Autos.Kodiaq_-_Tabelle-Status
    javascript.0
    2022-01-28 20:37:06.196	info	Stop script script.js.001-VIS.Tankstellen_-_offen-geschlossen
    javascript.0
    javascript.0
    2022-01-28 20:37:06.195	info	Stop script script.js.06-Autos.Telegram_-_Standortwechsel
    javascript.0
    2022-01-28 20:37:06.195	info	Stop script script.js.06-Autos.Kodiaq_-_Datenpunkte_Tueren-Fenster
    javascript.0
    2022-01-28 20:37:06.194	info	Stop script script.js.06-Autos.Kodiaq_-_Standheizung
    javascript.0
    2022-01-28 20:37:06.194	info	Stop script script.js.06-Autos.Scala_-_Datenpunkte_anlegen
    javascript.0
    2022-01-28 20:37:06.194	info	Stop script script.js.06-Autos.Kodiaq_-_Datenpunkte_anlegen
    javascript.0
    2022-01-28 20:37:06.194	info	Stop script script.js.03-Flur-Kammer.Kammerlicht_schalten
    javascript.0
    2022-01-28 20:37:06.193	info	Stop script script.js.01-Stube.Lampen.Zeitplan_-_Leuchtbaum
    javascript.0
    2022-01-28 20:37:06.190	info	Got terminate signal TERMINATE_YOURSELF
    host.ioBroker02
    2022-01-28 20:37:06.197	info	stopInstance system.adapter.javascript.0 send kill signal
    host.ioBroker02
    2022-01-28 20:37:06.187	info	stopInstance system.adapter.javascript.0 (force=false, process=true)
    GlasfaserG Offline
    GlasfaserG Offline
    #99
    @wszene
    Fehler gefunden ... trage es oben ein :
    WszeneW 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      @wszene
      WszeneW Offline
      WszeneW Offline
      Wszene
      #100
      @wszene
      Sehr schön das scheint es gewesen zu sein
      Jetzt hat sich auch der Datenpunkt "jsonList" gefüllt
      Aber die anderen 3 bleiben leer
      Meine Hard- & Software:
      • CC2652P Zigbee Stick
      • Lichtschalter mit Tasmota
      • IKEA TRÅDFRI Glühbirnen
      • Aqara Sensoren
      • WszeneW Wszene
        @wszene
        GlasfaserG Offline
        GlasfaserG Offline
        #101
        @wszene sagte in Material Design Widgets: Adapter Status:
        Die werden erst mit dem View gefüllt ( Auswahl .... )
          WszeneW Offline
          WszeneW Offline
          Wszene
          #102
          OK ich habe die View mal importiert aber die DPs bleiben leer ich habe die View auch aufgerufen
          Muss ich irgendwo meine eigenen DPs angeben ich habe nur gefunden wo ich die JsonList einfügen muss
          • Aqara Sensoren
          • WszeneW Wszene
            GlasfaserG Offline
            GlasfaserG Offline
            #103
            @wszene
            hier bei den beiden Widgets
              @wszene
              WszeneW Offline
              WszeneW Offline
              Wszene
              schrieb am zuletzt editiert von Wszene
              #104
              @wszene
              Ja wenn ich da Filter oder Sortiere passiert leider nichts
              PS:
              Habe gerade im Log gesehen das er die falschen DPs ansprechen will
              web.0
              2022-01-28 21:03:14.802	warn	State "0_userdata.0.vis.AdapterStatus.filterMode" has no existing object, this might lead to an error in future versions
              web.0
              2022-01-28 21:02:49.672	warn	State "0_userdata.0.vis.AdapterStatus.sortMode" has no existing object, this might lead to an error in future versions
              • Aqara Sensoren
              • WszeneW Wszene
                @wszene
                PS:
                web.0
                web.0
                GlasfaserG Offline
                GlasfaserG Offline
                #105
                @wszene
                Hast du dort ... im Vis Editor bei den beiden Widgets deine Datenpunkte eingetragen !?
                • WszeneW Wszene
                  @wszene
                  PS:
                  web.0
                  web.0
                  GlasfaserG Offline
                  GlasfaserG Offline
                  #106
                  und genau das meinte ich !
                    WszeneW Offline
                    WszeneW Offline
                    Wszene
                    #107
                    Ja aber wo muss ich denn meinen DP im Widget einfügen
                    • Aqara Sensoren
                    • WszeneW Wszene
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #108
                      @wszene
                        @wszene
                        WszeneW Offline
                        WszeneW Offline
                        Wszene
                        #109
                        @glasfaser
                        Danke jetzt geht es
                        Ich sollte wohl doch ins Bett gehen und morgen weiter machen
                        Seid 2Uhr wach dann sollte man soetwas um diese Zeit nicht mehr machen
                        Aber nochmal 1000Dank für deine Geduld
                        • Aqara Sensoren
                        • O Offline
                          O Offline
                          ostseeskipper
                          schrieb am zuletzt editiert von ostseeskipper
                          #110
                          Für alle die am Anfang Probleme mit den nicht angelegten Datenpunkten haben, werden hier automatisch angelegt wenn sie noch nicht da sind. Zeilen 11 bis 17
                          // Skript Einstellungen *************************************************************************************************************************************************
                          // Imports -> müssen im Javascript Adapter unter 'Zusätzliche NPM-Module' eingetragen sein
                          const moment = require("moment");
                          const momentDurationFormatSetup = require("moment-duration-format");
                          // Datenpunkte anlegen falls nicht vorhanden ********************************
                          if ( !existsState("0_userdata.0.vis.AdapterStatus.jsonList")){createState("0_userdata.0.vis.AdapterStatus.jsonList", false, {type: 'string'})};
                          if ( !existsState("0_userdata.0.vis.AdapterStatus.restartTrigger")){createState("0_userdata.0.vis.AdapterStatus.restartTrigger", false, {type: 'string'})};
                          if ( !existsState("0_userdata.0.vis.AdapterStatus.sortMode")){createState("0_userdata.0.vis.AdapterStatus.sortMode", false, {type: 'string'})};
                          if ( !existsState("0_userdata.0.vis.AdapterStatus.filterMode")){createState("0_userdata.0.vis.AdapterStatus.filterMode", false, {type: 'string'})};
                          let dpList = '0_userdata.0.vis.AdapterStatus.jsonList';                     // Datenpunkt für IconList Widget (Typ: Zeichenkette (String))
                          let dpAdapterRestart = '0_userdata.0.vis.AdapterStatus.restartTrigger';     // Datenpunkt für Adapter restart (Typ: Zeichenkette (String))
                          let dpSortMode = '0_userdata.0.vis.AdapterStatus.sortMode';                 // Datenpunkt für Sortieren (Typ: Zeichenkette (String))
                          let dpFilterMode = '0_userdata.0.vis.AdapterStatus.filterMode';             // Datenpunkt für Filter (Typ: Zeichenkette (String))
                          let adminUpdatesList = 'admin.0.info.updatesList';                          // Datenpunkt Admin Adapter für verfübare Updates der Adapter
                          const checkInterval = 30;                                                   // Interval wie oft Status der Adapter aktualisiert werden soll (in Sekunden)
                          let sprache = 'de';                                                         // Sprache für formatierung Dauer
                          let formatierungDauer = "dd[T] hh[h] mm[m]";                                // Formatierung der Dauer -> siehe momentjs library
                          let neustarten = true;                                                      // true: Adapter wird neugestartet, false: Adapter wird gestoppt oder gestartet
                          let farbeAdapterAktiv = 'green';                                            // Status Bar Farbe wenn Adapter aktiv ist
                          let farbeAdapterNichtAktiv = 'FireBrick';                                   // Status Bar Farbe wenn Adapter nicht aktiv ist oder Fehler vorliegt
                          let farbeAdapterDeaktiviert = 'darkgrey';                                   // Status Bar Farbe wenn Adapter deaktiviert ist
                          let farbeAdapterNichtVerbunden = 'yellow';                                  // Status Bar Farbe wenn Adapter nicht verbunden ist
                          let farbeAdapterZeitgesteuert = 'lightgreen';                               // Status Bar Farbe wenn Adapter zeitgesteuert ist
                          let farbeAdapterErweiterung = '#44739e';                                    // Status Bar Farbe wenn Adapter Erweiterung ist
                          let farbeAdapterSystem = '#44739e';                                         // Status Bar Farbe wenn Adapter mit System gestartet wird
                          let sortResetAfter = 120;                                                   // Sortierung nach X Sekunden auf sortReset zurücksetzen (0=deaktiviert)
                          let sortReset = 'memHeapUsed'                                               // Sortierung auf die zurückgesetzt werden soll
                          let filterResetAfter = 120;                                                 // Filter nach X Sekunden zurücksetzen (0=deaktiviert)
                          // Fomate für moment Lib
                          moment.locale(sprache);
                          // auf .alive Änderungen hören
                          let aliveSelector = `[id=system.adapter.*.alive]`;
                          let adapterAliveList = $(aliveSelector);
                          if (adapterAliveList.length === 0) {
                              // Fehlermeldung ausgeben, wenn selector kein result liefert
                              console.error(`no result for selector '${aliveSelector}'`)
                          } else {
                              // listener nur für Änderung bei alive
                              adapterAliveList.on(adapterStatus);
                          // auf .connection Änderungen hören
                          let connectionSelector = `[id=*.info.connection]`;
                          let adapterConnectionList = $(connectionSelector);
                          if (adapterConnectionList.length === 0) {
                              console.error(`no result for selector '${connectionSelector}'`)
                          } else {
                              adapterConnectionList.on(adapterStatus);
                          // auf .connected Änderungen hören
                          let connectedSelector = `[id=system.adapter.*.connected]`;
                          let adapterConnectedList = $(connectedSelector);
                          if (adapterConnectedList.length === 0) {
                              console.error(`no result for selector '${connectedSelector}'`)
                          } else {
                              adapterConnectedList.on(adapterStatus);
                          // auf Änderungen der Sortieung hören
                          on({ id: dpSortMode, change: 'any' }, adapterStatus);
                          on({ id: dpSortMode, change: 'any' }, resetSort);
                          // auf Änderungen der Filter hören
                          on({ id: dpFilterMode, change: 'any' }, adapterStatus);
                          on({ id: dpFilterMode, change: 'any' }, resetFilter);
                          // Funktion adapterStatus alle x Sekunden ausführen
                          schedule('*/' + checkInterval + ' * * * * *', adapterStatus);
                          function adapterStatus() {
                              // Funktion um Status der Adapter abzurufen und als JSON String für das Material Design Widget IconList aufbereiten
                              try {
                                  let adapterList = [];
                                  let updateList = myHelper().getStateValueIfExist(adminUpdatesList);
                                  for (var i = 0; i <= adapterAliveList.length - 1; i++) {
                                      let id = adapterAliveList[i].replace('.alive', '');
                                      let obj = getObject(adapterAliveList[i].replace('.alive', ''));
                                      let nameArray = id.replace('system.adapter.', '').split(".");
                                      let name = nameArray[0];
                                      name = name.charAt(0).toUpperCase() + name.slice(1);
                                      let nameWithInstance = name;
                                      let adapterInstance = nameArray[1];
                                      if (parseInt(adapterInstance) > 0) {
                                          nameWithInstance = name + '.' + adapterInstance;
                                      let uptime = (existsState(id + '.uptime')) ? moment.duration(getState(id + '.uptime').val, 'seconds').format(formatierungDauer, 0) : '-';
                                      let image = (myHelper().checkCommonPropertyExist(obj, 'icon')) ? `/${nameArray[0]}.admin/${obj.common.icon}` : 'image-off-outline';
                                      let hasUpdates = updateList && updateList.includes(nameArray[0]);
                                      let newVersion = (hasUpdates) ? '<span class="mdi mdi-update" style="color: #ec0909;"></span>' : '';
                                      let text = `<div style="display: flex; flex-direction: row; line-height: 1.5; padding-right: 8px; align-items: center;">
                                                      <div style="flex: 1">${newVersion} ${nameWithInstance}</div>
                                                      <div style="color: grey; font-size: 12px; font-family: RobotoCondensed-LightItalic;">${myHelper().getCommonPropertyIfExist(obj, 'version', '-', 'v', '')}</div>
                                                  </div>`
                                      let subText = `<div style="display: flex; flex-direction: row; line-height: 1.3; padding-left: 1px; padding-right: 8px; align-items: center;">
                                                          <div style="flex: 1;">CPU</div>
                                                          <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic; text-align: right;">${myHelper().getStateValueIfExist(id + '.cpu', '-', '', ' %')}</div>
                                                      </div>
                                                          <div style="flex: 1;">RAM total</div>
                                                          <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic; text-align: right;">${myHelper().getStateValueIfExist(id + '.memHeapTotal', '-', '', ' MB')}</div>
                                                      </div>
                                                          <div style="flex: 1;">RAM verwendet</div>
                                                          <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic; text-align: right;">${myHelper().getStateValueIfExist(id + '.memHeapUsed', '-', '', ' MB')}</div>
                                                      </div>
                                                          <div style="flex: 1;">RAM reserviert</div>
                                                          <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic; text-align: right;">${myHelper().getStateValueIfExist(id + '.memRss', '-', '', ' MB')}</div>
                                                      </div>
                                                          <div style="flex: 1;">Betriebszeit</div>
                                                          <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic; text-align: right;">${uptime}</div>
                                                      </div>
                                                          <div style="flex: 1;">Modus</div>
                                                          <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic; text-align: right;">${myHelper().getCommonPropertyIfExist(obj, 'mode', '-')}</div>
                                                      </div>`
                                      let statusBarColor = farbeAdapterNichtAktiv;
                                      let status = 3;
                                      if (myHelper().getStateValueIfExist(adapterAliveList[i]) === 'true') {
                                          statusBarColor = farbeAdapterAktiv;
                                          status = 0;
                                          if (existsState(id.replace('system.adapter.', '') + '.info.connection')) {
                                              if (!getState(id.replace('system.adapter.', '') + '.info.connection').val) {
                                                  statusBarColor = farbeAdapterNichtVerbunden;
                                                  status = 4;
                                          } else {
                                              if (myHelper().getStateValueIfExist(adapterAliveList[i].replace('.alive', '.connected')) === 'false') {
                                                  status = 4;
                                      if (myHelper().getCommonPropertyIfExist(obj, 'mode') === 'schedule') {
                                          // Adapter ist zeitgesteuert
                                          statusBarColor = farbeAdapterZeitgesteuert;
                                          status = 1;
                                      if (myHelper().getCommonPropertyIfExist(obj, 'mode') === 'extension') {
                                          // Adapter ist Extension
                                          statusBarColor = farbeAdapterErweiterung;
                                          status = 1;
                                      if (myHelper().getCommonPropertyIfExist(obj, 'mode') === 'once') {
                                          // Adapter wird mit System gestartet
                                          statusBarColor = farbeAdapterSystem;
                                          status = 1;
                                      if (myHelper().getCommonPropertyIfExist(obj, 'enabled', false).toString() === 'false') {
                                          // Adapter ist deaktiviert
                                          statusBarColor = farbeAdapterDeaktiviert;
                                          status = 2;
                                      adapterList.push({
                                          text: text,
                                          subText: subText,
                                          image: image,
                                          listType: "buttonState",
                                          objectId: dpAdapterRestart,
                                          buttonStateValue: id,
                                          statusBarColor: statusBarColor,
                                          showValueLabel: false,
                                          mode: myHelper().getCommonPropertyIfExist(obj, 'mode'),
                                          hasUpdates: hasUpdates,
                                          cpu: parseFloat(myHelper().getStateValueIfExist(id + '.cpu', '0')),
                                          memHeapTotal: parseFloat(myHelper().getStateValueIfExist(id + '.memHeapTotal', '0')),
                                          memHeapUsed: parseFloat(myHelper().getStateValueIfExist(id + '.memHeapUsed', '0')),
                                          memRss: parseFloat(myHelper().getStateValueIfExist(id + '.memRss', '0')),
                                          uptime: parseFloat(myHelper().getStateValueIfExist(id + '.uptime', 0)),
                                          status: status,
                                          lockEnabled: true
                                  let sortMode = myHelper().getStateValueIfExist(dpSortMode, 'name');
                                  if (sortMode === 'name' || sortMode === 'mode') {
                                      adapterList.sort(function (a, b) {
                                          return a[sortMode].toLowerCase() == b[sortMode].toLowerCase() ? 0 : +(a[sortMode].toLowerCase() > b[sortMode].toLowerCase()) || -1;
                                  } else if (sortMode === 'hasUpdates' || sortMode === 'cpu' || sortMode === 'memHeapTotal' || sortMode === 'memHeapUsed' || sortMode === 'memRss' || sortMode === 'uptime' || sortMode === 'status') {
                                          return a[sortMode] == b[sortMode] ? 0 : +(a[sortMode] < b[sortMode]) || -1;
                                  } else {
                                      // default: nach name sortieren
                                      sortMode = 'name'
                                  // Filter: not connected, updates, deaktiviert, aktiviert
                                  let filterMode = myHelper().getStateValueIfExist(dpFilterMode, null);
                                  if (filterMode && filterMode !== null && filterMode !== '') {
                                      if (filterMode === 'hasUpdates') {
                                          adapterList = adapterList.filter(function (item) {
                                              return item.hasUpdates === true;
                                      } else if (filterMode === 'notConnected') {
                                              return item.status === 4;
                                      } else if (filterMode === 'deactivated') {
                                              return item.status === 2;
                                      } else if (filterMode === 'activated') {
                                              return item.status <= 1;
                                  let result = JSON.stringify(adapterList);
                                  if (existsState(dpList) && getState(dpList).val !== result) {
                                      setState(dpList, result, true);
                                  } else {
                              } catch (err) {
                                  console.error(`[adapterStatus] error: ${err.message}, stack: ${err.stack}`);
                          // Beim Staren des Skriptes Adapter Status abrufen
                          adapterStatus();
                          // Funktion um Adapter zu starten / neu starten
                          on({ id: dpAdapterRestart }, function (obj) {
                              var adapter = getObject(obj.state.val.toString());
                              if (neustarten) {
                                  if (adapter.common && adapter.common.enabled === false) {
                                      // Adapter deaktiviert -> starten
                                      adapter.common.enabled = true;
                              } else {
                                  if (adapter.common && adapter.common.enabled) {
                                      adapter.common.enabled = !adapter.common.enabled;
                                  } else {
                              setObject(obj.state.val, adapter);
                              console.log(`${obj.state.val.replace('system.adapter.', '')} neugestartet`);
                          function resetSort() {
                              let sortMode = myHelper().getStateValueIfExist(dpSortMode, null);
                              if (sortResetAfter > 0) {
                                  setTimeout(function () {
                                      if (sortMode !== null && sortMode === myHelper().getStateValueIfExist(dpSortMode, null)) {
                                          setState(dpSortMode, sortReset);
                                  }, sortResetAfter * 1000);
                          function resetFilter() {
                              if (filterResetAfter > 0) {
                                      if (filterMode !== null && filterMode === myHelper().getStateValueIfExist(dpFilterMode, null)) {
                                          setState(dpFilterMode, '');
                                  }, filterResetAfter * 1000);
                          function myHelper() {
                              return {
                                  getStateValueIfExist: function (id, nullValue = undefined, prepand = '', append = '') {
                                      if (existsState(id)) {
                                          return prepand + getState(id).val + append;
                                      } else {
                                          return nullValue;
                                  getCommonPropertyIfExist: function (object, prop, nullValue = undefined, prepand = '', append = '') {
                                      if (myHelper().checkCommonPropertyExist(object, prop)) {
                                          return prepand + object.common[prop] + append;
                                      } else {
                                          return nullValue;
                                  checkCommonPropertyExist: function (object, prop) {
                                      if (object && object.common && object.common[prop]) {
                                          return true;
                                      } else {
                                          return false;
                          • daes10D Offline
                            daes10D Offline
                            daes10
                            #111
                            @ostseeskipper Vielen Dank, hat bei mir auch gut funktioniert.
                            Kann mir aber jemand helfen, warum bei mir überall undefined angezeigt wird?
                            Hab ich eine Einstellung übersehen? Weil alle Daten werden korrekt abgefragt.
                            I M L 3 Antworten Letzte Antwort
                            • daes10D daes10
                              I Offline
                              I Offline
                              Idefix01
                              #112
                              Hallöchen, ein super Script.
                              Nur das mit der Farbe für die Werte funktioniert bei mir nicht, diese bleibt weiterhin grau
                              let dpList = 'javascript.0.vis.AdapterStatus.jsonList';                     // Datenpunkt für IconList Widget (Typ: Zeichenkette (String))
                              let dpAdapterRestart = 'javascript.0.vis.AdapterStatus.restartTrigger';     // Datenpunkt für Adapter restart (Typ: Zeichenkette (String))
                              let dpSortMode = 'javascript.0.vis.AdapterStatus.sortMode';                 // Datenpunkt für Sortieren (Typ: Zeichenkette (String))
                              let dpFilterMode = 'javascript.0.vis.AdapterStatus.filterMode';             // Datenpunkt für Filter (Typ: Zeichenkette (String))
                              let farbeAdapterWerte = '#ffffff';                                       // Sekundärfarbe Adapterwerte, einer muss auskommentiert sein !
                              • C Offline
                                cst9
                                #113
                                bei mir ist das Problem, das wenn ich die Filter über ein mobiles Gerät anwähle, wird das Bild vergrößert sprich herangezoomt. Dabei spielt es auch keine Rolle ob man es über die App oder den Browser benutzt, es wird immer komischerweise immer herangezoomt.
                                Hat jemand das gleiche Problem und wie kann ich das abschalten?
                                Schöne Grüße
                                • ScroungerS Scrounger
                                  Skript zur Anzeige des Adapter Status mit dem Material Design IconList Widget
                                  Mit diesem Skript wird ein json string erzeugt mit dem Status aller installierten Adapter. Diese Daten (Datenpunkt) kann dann im Material Design IconList Widget verwendet werden, um den Status der Adapter im VIS anzuzeigen.
                                  letzte Aktualierung: 04.03.2020
                                  Voraussetzung:
                                  • Material Design Widgets v0.2.62
                                  Funktionen:
                                  • Anzeige des Status aller Adapter (Aktiviert, Deakitivert, nicht verbunden, update verfügbar, etc.)
                                  • Anzeige von Werten der Adapter (Betriebszeit, Ram, etc.)
                                  • Neustarten / Starten / Stoppen von Adaptern
                                  • Sortier und Filter Funktion
                                  • Einstellungen, siehe im Skript Sektion Einstellungen, Funktion der Einstellungen ist dort als Kommentar beschrieben.
                                  Ist auch im Online Beispiel enthalten
                                  View zum importieren:
                                    "settings": {
                                      "style": {
                                        "background_class": ""
                                      "theme": "redmond",
                                      "sizex": "",
                                      "sizey": "",
                                      "gridSize": "",
                                      "snapType": null
                                    "widgets": {
                                      "e00001": {
                                        "tpl": "tplVis-materialdesign-Icon-List",
                                        "data": {
                                          "g_fixed": false,
                                          "g_visibility": false,
                                          "g_css_font_text": false,
                                          "g_css_background": false,
                                          "g_css_shadow_padding": false,
                                          "g_css_border": false,
                                          "g_gestures": false,
                                          "g_signals": false,
                                          "g_last_change": false,
                                          "visibility-cond": "==",
                                          "visibility-val": 1,
                                          "visibility-groups-action": "hide",
                                          "wrapItems": true,
                                          "listItemDataMethod": "jsonStringObject",
                                          "countListItems": "1",
                                          "vibrateOnMobilDevices": "50",
                                          "listLayout": "card",
                                          "itemLayout": "horizontal",
                                          "listType0": "text",
                                          "showValueLabel0": "true",
                                          "listType1": "text",
                                          "showValueLabel1": "true",
                                          "signals-cond-0": "==",
                                          "signals-val-0": true,
                                          "signals-icon-0": "/vis/signals/lowbattery.png",
                                          "signals-icon-size-0": 0,
                                          "signals-blink-0": false,
                                          "signals-horz-0": 0,
                                          "signals-vert-0": 0,
                                          "signals-hide-edit-0": false,
                                          "signals-cond-1": "==",
                                          "signals-val-1": true,
                                          "signals-icon-1": "/vis/signals/lowbattery.png",
                                          "signals-icon-size-1": 0,
                                          "signals-blink-1": false,
                                          "signals-horz-1": 0,
                                          "signals-vert-1": 0,
                                          "signals-hide-edit-1": false,
                                          "signals-cond-2": "==",
                                          "signals-val-2": true,
                                          "signals-icon-2": "/vis/signals/lowbattery.png",
                                          "signals-icon-size-2": 0,
                                          "signals-blink-2": false,
                                          "signals-horz-2": 0,
                                          "signals-vert-2": 0,
                                          "signals-hide-edit-2": false,
                                          "lc-type": "last-change",
                                          "lc-is-interval": true,
                                          "lc-is-moment": false,
                                          "lc-format": "",
                                          "lc-position-vert": "top",
                                          "lc-position-horz": "right",
                                          "lc-offset-vert": 0,
                                          "lc-offset-horz": 0,
                                          "lc-font-size": "12px",
                                          "lc-font-family": "",
                                          "lc-font-style": "",
                                          "lc-bkg-color": "",
                                          "lc-color": "",
                                          "lc-border-width": "0",
                                          "lc-border-style": "",
                                          "lc-border-color": "",
                                          "lc-border-radius": 10,
                                          "lc-zindex": 0,
                                          "json_string_oid": "0_userdata.0.vis.AdapterStatus.jsonList",
                                          "maxItemsperRow": "6",
                                          "iconItemMinWidth": "300",
                                          "iconHeight": "60",
                                          "buttonHeight": "100",
                                          "labelFontSize": "22",
                                          "subLabelFontSize": "14",
                                          "subLabelFontColor": "#000000",
                                          "labelFontFamily": "RobotoCondensed-Regular",
                                          "subLabelFontFamily": "RobotoCondensed-Light",
                                          "horizontalIconContainerWidth": "120"
                                        "style": {
                                          "left": "0px",
                                          "top": "50px",
                                          "width": "100%",
                                          "height": "calc(100% - 50px)",
                                          "overflow-x": "",
                                          "overflow-y": "auto",
                                          "z-index": "1"
                                        "widgetSet": "materialdesign"
                                      "e00002": {
                                        "tpl": "tplHtml",
                                        "data": {
                                          "g_fixed": false,
                                          "g_css_background": true,
                                          "g_signals": false,
                                          "refreshInterval": "0",
                                          "lc-format": "",
                                          "lc-bkg-color": "",
                                          "lc-color": "",
                                          "lc-zindex": 0
                                        "style": {
                                          "left": "0",
                                          "top": "0",
                                          "width": "100%",
                                          "height": "50px",
                                          "background-color": "#44739e"
                                        "widgetSet": "basic"
                                      "e00003": {
                                        "tpl": "tplVis-materialdesign-Select",
                                        "data": {
                                          "oid": "0_userdata.0.vis.AdapterStatus.sortMode",
                                          "g_fixed": false,
                                          "g_signals": false,
                                          "inputType": "text",
                                          "inputLayout": "regular",
                                          "showInputMessageAlways": "true",
                                          "showInputCounter": false,
                                          "clearIconShow": false,
                                          "listDataMethod": "jsonStringObject",
                                          "countSelectItems": "1",
                                          "listPosition": "bottom",
                                          "showSelectedIcon": "prepend-inner",
                                          "showValue": false,
                                          "lc-format": "",
                                          "lc-bkg-color": "",
                                          "lc-color": "",
                                          "lc-zindex": 0,
                                          "inputLabelText": "Sortieren nach",
                                          "inputLabelColor": "#ffffff",
                                          "inputLabelFontFamily": "RobotoCondensed-LightItalic",
                                          "collapseIconColor": "#ffffff",
                                          "collapseIconSize": "",
                                          "jsonStringObject": "[\n\t{\n\t\t\"text\": \"Adaptername\",\n\t\t\"value\": \"name\",\n\t\t\"icon\": \"sort-alphabetical\"\n\t},\n\t{\n\t\t\"text\": \"Status\",\n\t\t\"value\": \"status\",\n\t\t\"icon\": \"information-variant\"\n\t},\t\n\t{\n\t\t\"text\": \"Modus\",\n\t\t\"value\": \"mode\",\n\t\t\"icon\": \"view-dashboard\"\n\t},\n\t{\n\t\t\"text\": \"Updates verfügbar\",\n\t\t\"value\": \"hasUpdates\",\n\t\t\"icon\": \"package-down\"\n\t},\n\t{\n\t\t\"text\": \"CPU\",\n\t\t\"value\": \"cpu\",\n\t\t\"icon\": \"cpu-64-bit\"\n\t},\n\t{\n\t\t\"text\": \"RAM total\",\n\t\t\"value\": \"memHeapTotal\",\n\t\t\"icon\": \"memory\"\n\t},\n\t{\n\t\t\"text\": \"RAM verwendet\",\n\t\t\"value\": \"memHeapUsed\",\n\t\t\"icon\": \"memory\"\n\t},\n\t{\n\t\t\"text\": \"RAM reserviert\",\n\t\t\"value\": \"memRss\",\n\t\t\"icon\": \"memory\"\n\t},\n\t{\n\t\t\"text\": \"Betriebszeit\",\n\t\t\"value\": \"uptime\",\n\t\t\"icon\": \"clock-check-outline\"\n\t}\n]",
                                          "listPositionOffset": true,
                                          "inputLayoutBackgroundColor": "transparent",
                                          "inputLabelColorSelected": "#ffffff",
                                          "inputTranslateX": "-15",
                                          "clearIcon": "",
                                          "inputLayoutBorderColorHover": "#ffffff",
                                          "inputLayoutBorderColorSelected": "#ffffff",
                                          "inputLayoutBorderColor": "#a1a1a1",
                                          "listItemFontColor": "",
                                          "inputTextColor": "#ffffff",
                                          "inputTextFontFamily": "RobotoCondensed-LightItalic",
                                          "prepandIcon": "",
                                          "prepandIconColor": "",
                                          "prepandIconSize": "",
                                          "prepandInnerIcon": "",
                                          "prepandInnerIconColor": "#ffffff",
                                          "prepandInnerIconSize": "18",
                                          "collapseIcon": "",
                                          "inputTranslateY": "-12",
                                          "listIconSelectedColor": "#44739e",
                                          "listIconColor": "",
                                          "appendOuterIcon": "",
                                          "appendOuterIconSize": "2",
                                          "listItemFont": "RobotoCondensed-Regular",
                                          "listItemRippleEffectColor": "",
                                          "inputLayoutBackgroundColorSelected": "",
                                          "inputLayoutBackgroundColorHover": ""
                                        "style": {
                                          "left": "10px",
                                          "top": "0px",
                                          "z-index": "1",
                                          "width": "calc(50% - 20px)",
                                          "height": "40px"
                                      "e00004": {
                                        "data": {
                                          "oid": "0_userdata.0.vis.AdapterStatus.filterMode",
                                          "g_fixed": false,
                                          "g_signals": false,
                                          "clearIconShow": true,
                                          "showValue": false,
                                          "lc-format": "",
                                          "lc-bkg-color": "",
                                          "lc-color": "",
                                          "lc-zindex": 0,
                                          "inputLabelText": "Filtern nach",
                                          "jsonStringObject": "[\n\t{\n\t\t\"text\": \"nicht verbunden\",\n\t\t\"value\": \"notConnected\",\n\t\t\"icon\": \"network-off\"\n\t},\n\t{\n\t\t\"text\": \"deaktiviert\",\n\t\t\"value\": \"deactivated\",\n\t\t\"icon\": \"checkbox-blank-outline\"\n\t},\t\n\t{\n\t\t\"text\": \"aktiviert\",\n\t\t\"value\": \"activated\",\n\t\t\"icon\": \"checkbox-intermediate\"\n\t},\n\t{\n\t\t\"text\": \"Updates verfügbar\",\n\t\t\"value\": \"hasUpdates\",\n\t\t\"icon\": \"package-down\"\n\t}\n]",
                                          "clearIcon": "",
                                          "prepandIcon": "",
                                          "collapseIcon": "",
                                          "inputLayoutBackgroundColorHover": "",
                                          "clearIconColor": "#ffffff"
                                        "style": {
                                          "left": "calc(50% + 10px)",
                                          "top": "0px",
                                          "z-index": "1",
                                          "height": "40px"
                                    "name": "AdapterStatus",
                                    "filterList": []
                                  Hier hab ich beschrieben, wie man das layout am besten einstellt:
                                  https://forum.iobroker.net/topic/30661/material-design-widgets-adapter-status/5
                                  Skript
                                  } else {
                                  } else {
                                  } else {
                                      try {
                                                          </div>`
                                                              </div>
                                                              </div>
                                                              </div>
                                                              </div>
                                                              </div>
                                                              </div>`
                                              let status = 3;
                                                  status = 0;
                                                          status = 4;
                                                  } else {
                                                          status = 4;
                                                  status = 1;
                                                  status = 1;
                                                  status = 1;
                                                  status = 2;
                                              adapterList.push({
                                                  text: text,
                                                  subText: subText,
                                                  image: image,
                                                  status: status,
                                                  lockEnabled: true
                                          } else {
                                              sortMode = 'name'
                                          } else {
                                      } catch (err) {
                                  adapterStatus();
                                      if (neustarten) {
                                      } else {
                                          } else {
                                      return {
                                              } else {
                                                  return nullValue;
                                              } else {
                                                  return nullValue;
                                                  return true;
                                              } else {
                                                  return false;
                                  Benötigte libraries & Einstellungen im Javascript Adapter:
                                  Die Idee dazu kommt von @sigi234, seine Version findet ihr hier.
                                  Vielen Dank für die Inspiration 👍
                                  Frank579
                                  #114
                                  @scrounger Hallo ich nutze das skript jetzt schon etwas länger, echt klasse gemacht 👍 Habe kürzlich den Weatherunderground Adapter installiert, die Kachel von dem sieht irgendwiw komisch aus, Hast du oder wer anders eine Idee dazu.
                                  Gruß Frank
                                  O 1 Antwort Letzte Antwort
                                  • F Frank579
                                    Gruß Frank
                                    O Online
                                    O Online
                                    Oli
                                    #115
                                    @frank579
                                    Wenn es dir um die Größe geht, veringere einfach mal die Anzahl, der anzuzeigenten Kacheln in der Vis
                                    Oliver
                                    • daes10D daes10
                                      mdumbsky
                                      #116
                                      @daes10
                                      hast Du eine Lösung für das undefined-Problem gefunden?
                                      Ich habe das gleiche Problem hier, obwohl die Datenpunkte in Ordnung sind und die Daten korrekt abgefragt werden...
                                      Michael
                                      • H Offline
                                        Hausbaer
                                        #117
                                        Ich nutze die Ansicht über ein Pop-Up-View (vis-invetwo - Universal Switch).
                                        Leider verschwinden die Auswahllisten für die Sortierung und die Filter hier im HIntergrund.
                                        Lade ich die View direkt, funktionieren sie.
                                        Welche Einstellung muss ich verändern?
                                        • H Hausbaer
                                          sigi234S Online
                                          sigi234S Online
                                          #118
                                          @hausbaer
                                          Stell das Widget mal rein, ev. z-index verstellt?
