  4. [Redesign] wioBrowser für Windows
689 Beiträge 33 Kommentatoren 207.9k Aufrufe 37 Beobachtet
  • BananaJoeB BananaJoe
    @wal also, heute ist er wieder mit Out of memory hängengeblieben, in error stand dazu nichts.
    Hier das Log:
    2022-01-12 18:06:05.792  - error: wiobrowser.0 (2718414) Client error:Error: read ECONNRESET
    2022-01-12 18:06:05.793  - info: wiobrowser.0 (2718414) Disconnected from 192.168.1.63
    2022-01-12 18:06:34.339  - error: wiobrowser.0 (2718414) Client error:Error: connect EHOSTUNREACH 192.168.1.63:5000
    2022-01-12 18:06:47.395  - error: wiobrowser.0 (2718414) Client error:Error: connect EHOSTUNREACH 192.168.1.63:5000
    2022-01-12 18:07:28.873  - info: wiobrowser.0 (2718414) Connected to 192.168.1.63
    2022-01-12 18:08:01.094  - info: host.iobroker "system.adapter.wiobrowser.0" disabled
    2022-01-12 18:08:01.097  - info: host.iobroker stopInstance system.adapter.wiobrowser.0 (force=false, process=true)
    2022-01-12 18:08:01.101  - info: wiobrowser.0 (2718414) Got terminate signal TERMINATE_YOURSELF
    2022-01-12 18:08:01.101  - info: host.iobroker stopInstance system.adapter.wiobrowser.0 send kill signal
    2022-01-12 18:08:01.103  - info: wiobrowser.0 (2718414) terminating
    2022-01-12 18:08:01.104  - info: wiobrowser.0 (2718414) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-01-12 18:08:01.104  - info: wiobrowser.0 (2718414) Disconnected from 192.168.1.63
    2022-01-12 18:08:01.725  - info: host.iobroker instance system.adapter.wiobrowser.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-01-12 18:08:14.312  - info: host.iobroker "system.adapter.wiobrowser.0" enabled
    2022-01-12 18:08:14.421  - info: host.iobroker instance system.adapter.wiobrowser.0 started with pid 3706262
    2022-01-12 18:08:15.855  - info: wiobrowser.0 (3706262) starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.wiobrowser, node: v14.18.2, js-controller: 3.3.22
    2022-01-12 18:08:15.896  - info: wiobrowser.0 (3706262) Connected to 192.168.1.63
    2022-01-12 18:08:46.495  - info: wiobrowser.0 (3706262) Disconnected from 192.168.1.63
    2022-01-12 18:09:27.921  - info: wiobrowser.0 (3706262) Connected to 192.168.1.63
    2022-01-12 18:09:55.134  - info: wiobrowser.0 (3706262) Disconnected from 192.168.1.63
    2022-01-12 18:11:40.887  - info: host.iobroker "system.adapter.wiobrowser.0" disabled
    2022-01-12 18:11:40.892  - info: host.iobroker stopInstance system.adapter.wiobrowser.0 (force=false, process=true)
    2022-01-12 18:11:40.903  - info: wiobrowser.0 (3706262) Got terminate signal TERMINATE_YOURSELF
    2022-01-12 18:11:40.909  - info: host.iobroker stopInstance system.adapter.wiobrowser.0 send kill signal
    2022-01-12 18:11:40.907  - info: wiobrowser.0 (3706262) terminating
    2022-01-12 18:11:40.908  - info: wiobrowser.0 (3706262) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-01-12 18:11:41.497  - info: host.iobroker instance system.adapter.wiobrowser.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-01-12 18:11:56.565  - info: host.iobroker "system.adapter.wiobrowser.0" enabled
    2022-01-12 18:11:56.738  - info: host.iobroker instance system.adapter.wiobrowser.0 started with pid 3709135
    2022-01-12 18:11:57.398  - debug: wiobrowser.0 (3709135) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2022-01-12 18:11:57.446  - debug: wiobrowser.0 (3709135) Objects client ready ... initialize now
    2022-01-12 18:11:57.462  - debug: wiobrowser.0 (3709135) Objects create System PubSub Client
    2022-01-12 18:11:57.463  - debug: wiobrowser.0 (3709135) Objects create User PubSub Client
    2022-01-12 18:11:57.464  - debug: wiobrowser.0 (3709135) Objects client initialize lua scripts
    2022-01-12 18:11:57.501  - debug: wiobrowser.0 (3709135) Objects connected to redis: 0.0.0.0:9001
    2022-01-12 18:11:57.509  - debug: wiobrowser.0 (3709135) objectDB connected
    2022-01-12 18:11:57.511  - debug: wiobrowser.0 (3709135) Redis States: Use Redis connection: 127.0.0.1:6379
    2022-01-12 18:11:57.525  - debug: wiobrowser.0 (3709135) States create System PubSub Client
    2022-01-12 18:11:57.526  - debug: wiobrowser.0 (3709135) States create User PubSub Client
    2022-01-12 18:11:57.535  - debug: wiobrowser.0 (3709135) States connected to redis: 127.0.0.1:6379
    2022-01-12 18:11:57.536  - debug: wiobrowser.0 (3709135) statesDB connected
    2022-01-12 18:11:57.838  - info: wiobrowser.0 (3709135) starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.wiobrowser, node: v14.18.2, js-controller: 3.3.22
    2022-01-12 18:12:13.285  - info: wiobrowser.0 (3709135) Connected to 192.168.1.63
    2022-01-12 18:12:13.295  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.info.connection: {"val":true,"ack":true,"ts":1642007533291,"q":0,"from":"system.adapter.wiobrowser.0","user":"system.user.admin","lc":1642007533291}
    2022-01-12 18:12:13.296  - debug: wiobrowser.0 (3709135) info -> true
    2022-01-12 18:12:15.163  - debug: wiobrowser.0 (3709135) Typ: URL
    2022-01-12 18:12:15.169  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.receiveURL: {"val":"http://192.168.1.8:60008/vis/index.html?WinPAD#000-Startpage","ack":true,"ts":1642007535167,"q":0,"from":"system.adapter.wiobrowser.0","user":"system.user.admin","lc":1642007371654}
    2022-01-12 18:12:15.169  - debug: wiobrowser.0 (3709135) receiveURL -> http://192.168.1.8:60008/vis/index.html?WinPAD#000-Startpage
    2022-01-12 18:12:53.443  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.sendURL: {"val":"https://forum.iobroker.net/","ack":false,"ts":1642007573441,"q":0,"from":"system.adapter.admin.1","user":"system.user.admin","lc":1642007295702}
    2022-01-12 18:12:53.443  - debug: wiobrowser.0 (3709135) sendURL -> https://forum.iobroker.net/
    2022-01-12 18:12:53.452  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.error: {"val":false,"ack":true,"ts":1642007573450,"q":0,"from":"system.adapter.wiobrowser.0","user":"system.user.admin","lc":1642007295808}
    2022-01-12 18:12:53.453  - debug: wiobrowser.0 (3709135) error -> false
    2022-01-12 18:12:57.196  - debug: wiobrowser.0 (3709135) Typ: URL
    2022-01-12 18:12:57.204  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.receiveURL: {"val":"https://forum.iobroker.net/","ack":true,"ts":1642007577201,"q":0,"from":"system.adapter wiobrowser.0","user":"system.user.admin","lc":1642007577201}
    2022-01-12 18:12:57.204  - debug: wiobrowser.0 (3709135) receiveURL -> https://forum.iobroker.net/
    2022-01-12 18:12:58.654  - debug: wiobrowser.0 (3709135) Typ: URL
    2022-01-12 18:12:58.659  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.receiveURL: {"val":"https://forum.iobroker.net/category/4/deutsch","ack":true,"ts":1642007578657,"q":0,"from":"system.adapter.wiobrowser.0","user":"system.user.admin","lc":1642007578657}
    2022-01-12 18:12:58.660  - debug: wiobrowser.0 (3709135) receiveURL -> https://forum.iobroker.net/category/4/deutsch
    2022-01-12 18:13:03.471  - debug: wiobrowser.0 (3709135) Typ: EVENT
    2022-01-12 18:13:10.482  - debug: wiobrowser.0 (3709135) Typ: BATTERY
    2022-01-12 18:13:10.490  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.battery: {"val":100,"ack":true,"ts":1642007590487,"q":0,"from":"system.adapter.wiobrowser.0","user":"system.user.admin","lc":1642007295769}
    2022-01-12 18:13:10.491  - debug: wiobrowser.0 (3709135) battery -> 100
    2022-01-12 18:13:16.519  - debug: wiobrowser.0 (3709135) Typ: EVENT
    2022-01-12 18:13:27.670  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.sendURL: {"val":"http://192.168.1.8:60008/vis/index.html?WinPAD#000-Startpage","ack":false,"ts":1642007607662,"q":0,"from":"system.adapter.admin.1","user":"system.user.admin","lc":1642007607662}
    2022-01-12 18:13:27.672  - debug: wiobrowser.0 (3709135) sendURL -> http://192.168.1.8:60008/vis/index.html?WinPAD#000-Startpage
    2022-01-12 18:13:27.681  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.error: {"val":false,"ack":true,"ts":1642007607677,"q":0,"from":"system.adapter.wiobrowser.0","user":"system.user.admin","lc":1642007295808}
    2022-01-12 18:13:27.681  - debug: wiobrowser.0 (3709135) error -> false
    2022-01-12 18:13:31.081  - debug: wiobrowser.0 (3709135) Typ: URL
    2022-01-12 18:13:31.088  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.receiveURL: {"val":"http://192.168.1.8:60008/vis/index.html?WinPAD#000-Startpage","ack":true,"ts":1642007611086,"q":0,"from":"system.adapter.wiobrowser.0","user":"system.user.admin","lc":1642007611086}
    2022-01-12 18:13:31.089  - debug: wiobrowser.0 (3709135) receiveURL -> http://192.168.1.8:60008/vis/index.html?WinPAD#000-Startpage
    2022-01-12 18:13:55.216  - debug: wiobrowser.0 (3709135) Typ: EVENT
    2022-01-12 18:14:10.303  - debug: wiobrowser.0 (3709135) Typ: BATTERY
    2022-01-12 18:14:10.309  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.battery: {"val":100,"ack":true,"ts":1642007650307,"q":0,"from":"system.adapter.wiobrowser.0","user":"system.user.admin","lc":1642007295769}
    2022-01-12 18:14:10.310  - debug: wiobrowser.0 (3709135) battery -> 100
    2022-01-12 18:14:16.869  - debug: wiobrowser.0 (3709135) Typ: EVENT
    2022-01-12 18:14:21.673  - debug: wiobrowser.0 (3709135) Typ: EVENT
    2022-01-12 18:15:10.327  - debug: wiobrowser.0 (3709135) Typ: BATTERY
    2022-01-12 18:15:10.348  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.battery: {"val":100,"ack":true,"ts":1642007710345,"q":0,"from":"system.adapter.wiobrowser.0","user":"system.user.admin","lc":1642007295769}
    2022-01-12 18:15:10.349  - debug: wiobrowser.0 (3709135) battery -> 100
    Ich kann sehen das EVENT erscheint wenn ich die Seite wechsle
    Irgendwie habe ich auch eine View in der VIS, wenn ich die einmal anklicke geht es nicht mehr weiter. Fehler gefunden.
    Event kommt wenn ich mit der Maus klicke. Ich nutze Input Director um vom PC aus das Tablet zu bedienen. Wenn ich mit dem Finger tippse kommt kein Event
    WalW Offline
    WalW Offline
    Wal
    #70
    @bananajoe ,
    Typ: EVENT kommt nur wenn die Batteriedaten übertragen werden, alle 60sec.
    Typ:URL wen eine neue Seite aufgebaut wurde, da sehe ich das receiveURL bei dir auch geht, obwohl du das Gegenteil gesagt hast. ;-)
    error -> true würde sagen das die angeforderte Webseite einen Fehler bringt, was ich aber in deinem Log nirgens sehe.
    Ich sehe nur das um 18:06:05 die Verbindung verloren wurde und um 18:12:13 die Verbindung hergestellt wurde, danach ist alles i.O.
    Walter
    DoorIO-Adapter
    • BananaJoeB Offline
      BananaJoeB Offline
      BananaJoe
      #71
      Gegenprobe gemacht: Auf anderen Rechnern bei mir im Netzwerk funktioniert es auch nicht. Hab extra mal eben meinen Hauptrechner genommen
      • WalW Wal
        @bananajoe ,
        BananaJoeB Offline
        BananaJoeB Offline
        BananaJoe
        #72
        @wal EVENT kommt jedes mal wenn ich mit der Maus klicke Unabhängig davon ob ich damit eine Seite wechsle oder ins Nichts klicke. Der Mausklick wird aber durch die Software Input Director erzeugt. Wenn ich mit dem Finger tippe kommt nichts in Log.
        Und da sind keine 60 Sekunden zwischen den EVENT Ereignissen.
        Beim Start oder wenn ich die URL setzte wird receiveURL einmalig aktualisiert. Wenn ich die ioBroker-Forumseite nehme kommt sogar noch der Wechsel zu Deutschen Seite. Danach ist dann aber schluss.
        Und genau: Da erscheint dann nichts im Log wenn ich die Seiten wechsle
        WalW 2 Antworten Letzte Antwort
          WalW Offline
          WalW Offline
          Wal
          #73
          @bananajoe ,
          du hast Recht mit der Maus. Typ: Battery ist die Battery.
          Walter
          DoorIO-Adapter
            WalW Offline
            WalW Offline
            Wal
            #74
            @bananajoe sagte in [Neuer Adapter] wioBrowser für Windows:
            Und das auch bei deinem Hauptrechner ?
            Walter
            DoorIO-Adapter
            • WalW Wal
              BananaJoeB Offline
              BananaJoeB Offline
              BananaJoe
              #75
              @wal jepp. Ich wollte gerade mal eine ältere Version probieren ... aber die sind nicht verfügbar :-(
                WalW Offline
                WalW Offline
                Wal
                #76
                @bananajoe ,
                Battery, Close, ScreenOn/Off gehen dann aber immernoch ?
                Walter
                DoorIO-Adapter
                  WalW Offline
                  WalW Offline
                  Wal
                  #77
                  Die alten Versionen kannst du auf Github runterladen.
                  Browser alt
                  Du gehst auf Commits danach auf <> und du bekommst die Dateien angezeigt. Du mußt aber danach auch die alten Adapter installieren, das funktioniert genauso. Commits danach <> und die Url kopieren und als InstallationsURL bei ioBroker eintragen.
                  Walter
                  DoorIO-Adapter
                  • WalW Wal
                    @bananajoe ,
                    BananaJoeB Offline
                    BananaJoeB Offline
                    BananaJoe
                    #78
                    @wal
                    • close geht
                    • message geht
                    • screenoff geht
                    • screenon geht
                    • slide geht. Aber die Seitenwechsel durch das sliden werden nicht empfangen. Sliden per Mausklick beenden funktioniert
                    • zoom geht
                    • sendURL geht, receiveURL wird dabei aber nicht aktualisiert
                    WalW 1 Antwort Letzte Antwort
                      @wal
                      • close geht
                      • message geht
                      • screenoff geht
                      • screenon geht
                      • zoom geht
                      WalW Offline
                      WalW Offline
                      Wal
                      schrieb am zuletzt editiert von Wal
                      #79
                      @bananajoe ,
                      das ist der Hammer, bei receiveUrl habe ich im Quellcode seit der ersten Version damit nichts verändert.
                      edit: Battery geht auch noch ? Bei Battery und receiveURL wird was empfangen, alles andere wird an den Browser gesendet.
                      Walter
                      DoorIO-Adapter
                      • WalW Wal
                        @bananajoe ,
                        BananaJoeB Offline
                        BananaJoeB Offline
                        BananaJoe
                        #80
                        @wal Testest du bei dir lokal oder auch über das Netzwerk?
                          WalW Offline
                          WalW Offline
                          Wal
                          #81
                          Beides, geht Battery auch noch ? lese oben.
                          Walter
                          DoorIO-Adapter
                          • WalW Wal
                            BananaJoeB Offline
                            BananaJoeB Offline
                            BananaJoe
                            #82
                            @wal jepp geht auch noch.
                            WalW 3 Antworten Letzte Antwort
                              WalW Offline
                              WalW Offline
                              Wal
                              #83
                              @bananajoe ,
                              ok teste mal die alten Versionen. Ich bin sprachlos.
                              Walter
                              DoorIO-Adapter
                                WalW Offline
                                WalW Offline
                                Wal
                                #84
                                @bananajoe ,
                                achso local muß ich aber die IP eingeben localhost funktioniert bei mir nicht.
                                Local läuft der ioBroker aber in der WSL von Windows, damit ich Visual Studio Code testen kann.
                                Mein normaler ioBroker läuft in einem Proxmoxcontainer.
                                Walter
                                DoorIO-Adapter
                                  WalW Offline
                                  WalW Offline
                                  Wal
                                  #85
                                  @bananajoe,
                                  mir fällt noch was ein, die Url wird erst übertragen wenn die Seite fertig geladen ist, wird sie bei dir evtl. nicht vollständig geladen ?
                                  Walter
                                  DoorIO-Adapter
                                  • WalW Wal
                                    @bananajoe ,
                                    BananaJoeB Offline
                                    BananaJoeB Offline
                                    BananaJoe
                                    #86
                                    @wal also, auf meinem Server funktioniert es mit der 1.3.0 (Ist erst nicht gestartet weil die Edge Runtime fehlte)
                                    Auf meinem Tablet funktioniert die auch ... mit meiner Homepage https://znil.net
                                    Wenn ich auf das Forum gehe wechselt er von https://forum.iobroker.net/ noch um auf https://forum.iobroker.net/category/4/deutsch und dann passiert nichts mehr wenn ich die Beiträge wechsle etc.
                                    Das habe ich auf meinem Server und auf dem Tablet schon bei der 1.3.0
                                    Ich teste jetzt noch mal die 1.5.0 auf die gleiche Weise
                                    • WalW Wal
                                      @bananajoe,
                                      BananaJoeB Offline
                                      BananaJoeB Offline
                                      BananaJoe
                                      #87
                                      @wal sagte in [Neuer Adapter] wioBrowser für Windows:
                                      @bananajoe,
                                      Interaktive Webseiten mit JavaScript ... sind die jemals fertig geladen?
                                        BananaJoeB Offline
                                        BananaJoeB Offline
                                        BananaJoe
                                        #88
                                        @Wal
                                        Also jupp, meiner PHP-Homepage geht es.
                                        Bei den JavaScript-Seiten wie z.B. dem Forum geht es nicht.
                                          @Wal
                                          WalW Offline
                                          WalW Offline
                                          Wal
                                          #89
                                          @bananajoe ,
                                          ja kann ich jetzt nachvollziehen. Im Forum bin ich noch nicht hin und her gewechselt.
                                          Da muss ich auch mal ältere Versionen testen, danke.
                                          Walter
                                          DoorIO-Adapter
