  4. Adapter "smartmeter"
3.6k Beiträge 281 Kommentatoren 3.9m Aufrufe 162 Beobachtet
  • A AndieKiste
    erst mal vielen Dank für die super Arbeit mit dem Adapter. Leider verzweifle ich gerade an ihm.
    Ich bekomme ihn erst garnicht ans Laufen, sobald er gestartet wird, kommen folgende Fehler im Log:
    2022-01-06 21:30:37.347 - error: host.iobroker Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
    2022-01-06 21:30:37.364 - error: host.iobroker Caught by controller[0]: throw e;
    2022-01-06 21:30:37.364 - error: host.iobroker Caught by controller[0]: ^
    2022-01-06 21:30:37.364 - error: host.iobroker Caught by controller[0]: Error: libnode.so.72: cannot open shared object file: No such file or directory
    2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
    2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
    2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
    2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
    2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32) {
    2022-01-06 21:30:37.366 - error: host.iobroker Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    2022-01-06 21:30:37.366 - error: host.iobroker Caught by controller[0]: }
    2022-01-06 21:30:37.366 - error: host.iobroker instance system.adapter.smartmeter.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2022-01-06 21:30:37.366 - info: host.iobroker Restart adapter system.adapter.smartmeter.1 because enabled
    Das Problem besteht seit der Installation. Hier ein paar Daten zum System:
    smartmeter v.3.2.1
    iobroker v.3.3.22
    System läuft unter Proxmox VE 6.4 auf einem Ubuntu 21.04
    Node.Js 14.18.2
    NPM v6.14.15
    Abgesehen von den Fehlern ist bei Instanzen jeder Status rot.
    In den Einstellungen der Instanz kann die Liste der Adapter auch nicht angezeigt werden.
    Als Leseköpfe kommen 2 Stück von Hichi IR USB zum Einsatz. Diese werden auf Proxmox-Ebene als auch nach Durchschleifen an die VM auf dem iobroker erkannt und als Device im Terminal gefunden.
    Jemand eine Idee, wie ich den Adapter ans Laufen bekomme? Vielen Dank schon mal im Voraus.
    Ich hab den Adapter schon de- und wieder installiert als auch iobroker fix duchgeführt, leider ohne Erfolg.
    Andi
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    #2380
    @andiekiste
    Was sagt:
    which nodejs node npm && nodejs -v && node -v && npm -v && whoami && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      @andiekiste sagte in Adapter "smartmeter":
      Node.Js 14.18.2
      NPM v6.14.15
      sicher?
      laut doku
      gibt es den erst ab v15
      A
      A
      AndieKiste
      #2381
      Eigentlich schon, ja, es wird mir zumindest so angezeigt. Ich bin aber selbst gerade maximal verwirrt, weil wenn ich in der Konsole nodejs -v eingebe, sagt er mir dass nodejs nicht vorhanden ist und ich es installieren soll. Bin leider kein Linux-Fachmann aber werde es jetzt mal installieren.
      Thomas BraunT HomoranH 3 Antworten Letzte Antwort
      • A AndieKiste
        Thomas BraunT
        Thomas BraunT
        #2382
        @andiekiste NEIN!
        Das Kommando nodejs ist in aktuellen Versionen nicht mehr drin. Das ist also i. O.
        Du kannst es aber mit
        'nachbauen'.
        • A AndieKiste
          Thomas BraunT
          Thomas BraunT
          #2383
          @andiekiste
          Was liefert
          denn nu?
          • A AndieKiste
            #2384
            dann wären zwei Szenarien denkbar (oder mehr)
            • es kam später in eine höhere 14.x mit rein
            • du hattest zwischendrin mal eine höhere node-Version als 14 installiert und wieder downgegradet
              @andiekiste
              Was sagt:
              A
              A
              AndieKiste
              #2385
              Ich bin maximal verwirrt. Wenn ich richtig verstehe was du gerne hättest sind das ja verschiedene Befehle hintereinander. Einzeln nacheinander sieht es so aus:
              root@iobroker:~# which nodejs node npm
              /usr/bin/node
              /usr/bin/npm
              root@iobroker:~# nodejs -v
              Command 'nodejs' not found, but can be installed with:
              apt install nodejs
              root@iobroker:~# node -v
              v14.18.2
              root@iobroker:~# npm -v
              6.14.15
              root@iobroker:~# whoami
              root
              root@iobroker:~# apt update &> /dev/null      "Der Befehl gibt garnichts zurück bei mir"
              Hit:1 http://archive.ubuntu.com/ubuntu hirsute InRelease
              Hit:2 http://archive.ubuntu.com/ubuntu hirsute-updates InRelease
              Hit:3 http://archive.ubuntu.com/ubuntu hirsute-security InRelease
              Hit:4 https://deb.nodesource.com/node_14.x groovy InRelease
              Reading package lists... Done
              3 packages can be upgraded. Run 'apt list --upgradable' to see them.
              root@iobroker:~# apt policy nodejs
              nodejs:
                Installed: 14.18.2-deb-1nodesource1
                Candidate: 14.18.2-deb-1nodesource1
                Version table:
               *** 14.18.2-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_14.x groovy/main amd64 Packages
                   12.21.0~dfsg-3ubuntu1 500
                      500 http://archive.ubuntu.com/ubuntu hirsute/universe amd64 Packages
              Was ich auch nicht verstehe, er zeigt mir ja von nodejs was an. Umgekehrt über die Konsole dachte ich mir, wenn er nodejs installiert haben will, versuche ich es einfach, aber dann kommt folgendes:
              root@iobroker:~# apt install nodejs
              nodejs is already the newest version (14.18.2-deb-1nodesource1).
              0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
              Ich weiß leider dass ich als root angemeldet bin, was nicht gut ist. aber als iobroker kann ich mich nicht einloggen, dann sagt er mir "User account currently not available."
              Erkennst du da was?
              Danke und Gruß
              Andi
              HomoranH Thomas BraunT 4 Antworten Letzte Antwort
              • A AndieKiste
                /usr/bin/node
                /usr/bin/npm
                apt install nodejs
                v14.18.2
                6.14.15
                root
                nodejs:
                  Version table:
                Erkennst du da was?
                Danke und Gruß
                Andi
                #2386
                nodejs ist node
                Hieß früher nur auch nodejs. Uralte Programme erwarten das noch. Dafür wurde früher einfach ein Link gesetzt, der bei Aufruf von nodejs auf node verlinkt hatte.
                Das kann man immer noch machen, ist aber standardmäßig nur noch selten der Fall
                Nix neu installieren!
                Das geht dann wieder schief
                  A
                  A
                  AndieKiste
                  #2387
                  @homoran Bei node Updates halte ich mich meist an Anleitungen sobald sie verfügbar sind und an die Versionen, wie sie hier im Forum vorgeschlagen werden, da ich wie gesagt nicht der Linux-Fachmann bin. Ich möchte es natürlich nicht ausschließen, aber "aus Versehen" ein Up- und wieder Downgrade zu machen würde mich selbst überraschen. :-)
                  • A AndieKiste
                    /usr/bin/node
                    /usr/bin/npm
                    apt install nodejs
                    v14.18.2
                    6.14.15
                    root
                    nodejs:
                      Version table:
                    Erkennst du da was?
                    Danke und Gruß
                    Andi
                    Thomas BraunT
                    Thomas BraunT
                    #2388
                    @andiekiste
                    Und dann in einer Tour durch:
                    Nix rauspflücken, alles so in die Konsole klatschen.
                    • A AndieKiste
                      /usr/bin/node
                      /usr/bin/npm
                      apt install nodejs
                      v14.18.2
                      6.14.15
                      root
                      nodejs:
                        Version table:
                      Erkennst du da was?
                      Danke und Gruß
                      Andi
                      #2389
                      das ist auch richtig so, aber du solltest einen normalen user, z.B. andi haben unter dem du arbeitest
                      • A AndieKiste
                        /usr/bin/node
                        /usr/bin/npm
                        apt install nodejs
                        v14.18.2
                        6.14.15
                        root
                        nodejs:
                          Version table:
                        Erkennst du da was?
                        Danke und Gruß
                        Andi
                        Thomas BraunT
                        Thomas BraunT
                        #2390
                        Dann leg dir einen andi user an.
                          nodejs ist node
                          A
                          A
                          AndieKiste
                          #2391
                          @homoran ahh oke, danke. Dann bleibt nur leider die Frage warum der Adapter nicht will.
                          Macht es Sinn, unter Proxmox einfach mal eine neue VM anzulegen, iobroker neu zu installieren und dort ein Backup zu laden? Oder sind da andere Probleme zu erwarten?
                          • A AndieKiste
                            #2392
                            nur die Üblichen ;-)
                            anderer Hostname und andere IP
                            ersteres sollte eigentlich mit dem Restore über Backitup geregelt sein, bei manuellem Restore geht das über 'iobroker host this' bevor iobroker wieder gestartet wird
                            Letzteres ist nicht unbedingt wild, nur die IPs in diversen Adaptern müssten angepasst werden
                              @andiekiste
                              A
                              A
                              AndieKiste
                              #2393
                              root@iobroker:~# which nodejs node npm && nodejs -v && node -v && npm -v && whoami && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs& sudo apt update && apt policy nodejsv && npm -v && whoami && sudo apt
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v14.18.2
                              v14.18.2
                              6.14.15
                              root
                              Get:2 http://archive.ubuntu.com/ubuntu hirsute-updates InRelease [115 kB]
                              Hit:3 https://deb.nodesource.com/node_14.x groovy InRelease
                              Get:4 http://archive.ubuntu.com/ubuntu hirsute-security InRelease [110 kB]
                              Fetched 225 kB in 1s (249 kB/s)
                              nodejs:
                                Version table:
                                A
                                A
                                AndieKiste
                                #2394
                                @thomas-braun @Homoran
                                Also wenn zwei exakt das gleiche in einer Minute empfehlen, dann war der User andi jetzt gerade als allererstes erstellt :-D
                                • A AndieKiste
                                  #2395
                                  Super!
                                  Auch in die Sudoers eingetragen?
                                    Super!
                                    A
                                    A
                                    AndieKiste
                                    #2396
                                    Jep, wieder ne gute kurze Forumanleitung inkl. Test gefunden. :-)
                                    • A AndieKiste
                                      #2397
                                      Wo?
                                        Wo?
                                        A
                                        A
                                        AndieKiste
                                        #2398
                                        meistens im wiki.ubuntuusers.de, aber es gab dann noch ne gute Ergänzung hier.
                                        • A AndieKiste
                                          #2399
                                          ok, das passt meistens ganz gut, auch wenn Ubuntu (auch was die Pfade angeht) oft einen eigenen Weg geht
                                          33.2k
                                          84.3k
