  4. Adapter "smartmeter"
    1.0k
3.6k Beiträge 281 Kommentatoren 3.1m Aufrufe 162 Beobachtet
    AndieKiste
    schrieb am zuletzt editiert von AndieKiste
    #2377
    erst mal vielen Dank für die super Arbeit mit dem Adapter. Leider verzweifle ich gerade an ihm.
    Ich bekomme ihn erst garnicht ans Laufen, sobald er gestartet wird, kommen folgende Fehler im Log:
    2022-01-06 21:30:37.347 - error: host.iobroker Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
    2022-01-06 21:30:37.364 - error: host.iobroker Caught by controller[0]: throw e;
    2022-01-06 21:30:37.364 - error: host.iobroker Caught by controller[0]: ^
    2022-01-06 21:30:37.364 - error: host.iobroker Caught by controller[0]: Error: libnode.so.72: cannot open shared object file: No such file or directory
    2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
    2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
    2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
    2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
    2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32) {
    2022-01-06 21:30:37.366 - error: host.iobroker Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    2022-01-06 21:30:37.366 - error: host.iobroker Caught by controller[0]: }
    2022-01-06 21:30:37.366 - error: host.iobroker instance system.adapter.smartmeter.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2022-01-06 21:30:37.366 - info: host.iobroker Restart adapter system.adapter.smartmeter.1 because enabled
    Das Problem besteht seit der Installation. Hier ein paar Daten zum System:
    smartmeter v.3.2.1
    iobroker v.3.3.22
    System läuft unter Proxmox VE 6.4 auf einem Ubuntu 21.04
    Node.Js 14.18.2
    NPM v6.14.15
    Abgesehen von den Fehlern ist bei Instanzen jeder Status rot.
    In den Einstellungen der Instanz kann die Liste der Adapter auch nicht angezeigt werden.
    Als Leseköpfe kommen 2 Stück von Hichi IR USB zum Einsatz. Diese werden auf Proxmox-Ebene als auch nach Durchschleifen an die VM auf dem iobroker erkannt und als Device im Terminal gefunden.
    Jemand eine Idee, wie ich den Adapter ans Laufen bekomme? Vielen Dank schon mal im Voraus.
    Ich hab den Adapter schon de- und wieder installiert als auch iobroker fix duchgeführt, leider ohne Erfolg.
    Andi
    HomoranH Thomas BraunT 3 Antworten Letzte Antwort
    • A AndieKiste
      smartmeter v.3.2.1
      iobroker v.3.3.22
      Node.Js 14.18.2
      NPM v6.14.15
      Andi
      #2378
      @andiekiste sagte in Adapter "smartmeter":
      Node.Js 14.18.2
      NPM v6.14.15
      sicher?
      laut doku
      gibt es den erst ab v15
      • A AndieKiste
        smartmeter v.3.2.1
        iobroker v.3.3.22
        Node.Js 14.18.2
        NPM v6.14.15
        Andi
        #2379
        Das irritiert mich. Diese Datei kommt eigentlich aus der Debian-Ecke, also deren hauseigener Version von nodejs:
        apt policy libnode72
        libnode72:
          Installed: (none)
          Candidate: 12.22.5~dfsg-2~11u1
          Version table:
             12.22.5~dfsg-2~11u1 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
        Die ist aber in der Form bei einer nodesource-Installation nicht vorhanden. Und auch nicht erforderlich, denn:
        2022-01-06 21:53:22.784  - info: smartmeter.0 (137513) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v17.3.0, js-controller: 3.3.22
        2022-01-06 21:53:22.819  - error: smartmeter.0 (137513) Serial port device is undefined, check your configuration!
        Startet bei mir auch ohne libnode.so.72
        • A AndieKiste
          smartmeter v.3.2.1
          iobroker v.3.3.22
          Node.Js 14.18.2
          NPM v6.14.15
          Andi
          #2380
          @andiekiste
          Was sagt:
          which nodejs node npm && nodejs -v && node -v && npm -v && whoami && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            Node.Js 14.18.2
            NPM v6.14.15
            sicher?
            laut doku
            AndieKiste
            #2381
            Eigentlich schon, ja, es wird mir zumindest so angezeigt. Ich bin aber selbst gerade maximal verwirrt, weil wenn ich in der Konsole nodejs -v eingebe, sagt er mir dass nodejs nicht vorhanden ist und ich es installieren soll. Bin leider kein Linux-Fachmann aber werde es jetzt mal installieren.
            Thomas BraunT HomoranH 3 Antworten Letzte Antwort
            • A AndieKiste
              #2382
              @andiekiste NEIN!
              Das Kommando nodejs ist in aktuellen Versionen nicht mehr drin. Das ist also i. O.
              Du kannst es aber mit
              'nachbauen'.
              • A AndieKiste
                #2383
                @andiekiste
                Was liefert
                denn nu?
                • A AndieKiste
                  #2384
                  dann wären zwei Szenarien denkbar (oder mehr)
                  • es kam später in eine höhere 14.x mit rein
                  • du hattest zwischendrin mal eine höhere node-Version als 14 installiert und wieder downgegradet
                    @andiekiste
                    Was sagt:
                    AndieKiste
                    #2385
                    Ich bin maximal verwirrt. Wenn ich richtig verstehe was du gerne hättest sind das ja verschiedene Befehle hintereinander. Einzeln nacheinander sieht es so aus:
                    root@iobroker:~# which nodejs node npm
                    /usr/bin/node
                    /usr/bin/npm
                    root@iobroker:~# nodejs -v
                    Command 'nodejs' not found, but can be installed with:
                    apt install nodejs
                    root@iobroker:~# node -v
                    v14.18.2
                    root@iobroker:~# npm -v
                    6.14.15
                    root@iobroker:~# whoami
                    root
                    root@iobroker:~# apt update &> /dev/null      "Der Befehl gibt garnichts zurück bei mir"
                    Hit:1 http://archive.ubuntu.com/ubuntu hirsute InRelease
                    Hit:2 http://archive.ubuntu.com/ubuntu hirsute-updates InRelease
                    Hit:3 http://archive.ubuntu.com/ubuntu hirsute-security InRelease
                    Hit:4 https://deb.nodesource.com/node_14.x groovy InRelease
                    Reading package lists... Done
                    3 packages can be upgraded. Run 'apt list --upgradable' to see them.
                    root@iobroker:~# apt policy nodejs
                    nodejs:
                      Installed: 14.18.2-deb-1nodesource1
                      Candidate: 14.18.2-deb-1nodesource1
                      Version table:
                     *** 14.18.2-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_14.x groovy/main amd64 Packages
                         12.21.0~dfsg-3ubuntu1 500
                            500 http://archive.ubuntu.com/ubuntu hirsute/universe amd64 Packages
                    Was ich auch nicht verstehe, er zeigt mir ja von nodejs was an. Umgekehrt über die Konsole dachte ich mir, wenn er nodejs installiert haben will, versuche ich es einfach, aber dann kommt folgendes:
                    root@iobroker:~# apt install nodejs
                    nodejs is already the newest version (14.18.2-deb-1nodesource1).
                    0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
                    Ich weiß leider dass ich als root angemeldet bin, was nicht gut ist. aber als iobroker kann ich mich nicht einloggen, dann sagt er mir "User account currently not available."
                    Erkennst du da was?
                    Danke und Gruß
                    Andi
                    HomoranH Thomas BraunT 4 Antworten Letzte Antwort
                    • A AndieKiste
                      /usr/bin/node
                      /usr/bin/npm
                      apt install nodejs
                      v14.18.2
                      6.14.15
                      root
                      nodejs:
                        Version table:
                      Erkennst du da was?
                      Danke und Gruß
                      Andi
                      #2386
                      nodejs ist node
                      Hieß früher nur auch nodejs. Uralte Programme erwarten das noch. Dafür wurde früher einfach ein Link gesetzt, der bei Aufruf von nodejs auf node verlinkt hatte.
                      Das kann man immer noch machen, ist aber standardmäßig nur noch selten der Fall
                      Nix neu installieren!
                      Das geht dann wieder schief
                        AndieKiste
                        #2387
                        @homoran Bei node Updates halte ich mich meist an Anleitungen sobald sie verfügbar sind und an die Versionen, wie sie hier im Forum vorgeschlagen werden, da ich wie gesagt nicht der Linux-Fachmann bin. Ich möchte es natürlich nicht ausschließen, aber "aus Versehen" ein Up- und wieder Downgrade zu machen würde mich selbst überraschen. :-)
                        • A AndieKiste
                          /usr/bin/node
                          /usr/bin/npm
                          apt install nodejs
                          v14.18.2
                          6.14.15
                          root
                          nodejs:
                            Version table:
                          Erkennst du da was?
                          Danke und Gruß
                          Andi
                          #2388
                          @andiekiste
                          Und dann in einer Tour durch:
                          Nix rauspflücken, alles so in die Konsole klatschen.
                          • A AndieKiste
                            /usr/bin/node
                            /usr/bin/npm
                            apt install nodejs
                            v14.18.2
                            6.14.15
                            root
                            nodejs:
                              Version table:
                            Erkennst du da was?
                            Danke und Gruß
                            Andi
                            #2389
                            das ist auch richtig so, aber du solltest einen normalen user, z.B. andi haben unter dem du arbeitest
                            • A AndieKiste
                              /usr/bin/node
                              /usr/bin/npm
                              apt install nodejs
                              v14.18.2
                              6.14.15
                              root
                              nodejs:
                                Version table:
                              Erkennst du da was?
                              Danke und Gruß
                              Andi
                              #2390
                              Dann leg dir einen andi user an.
                                nodejs ist node
                                AndieKiste
                                #2391
                                @homoran ahh oke, danke. Dann bleibt nur leider die Frage warum der Adapter nicht will.
                                Macht es Sinn, unter Proxmox einfach mal eine neue VM anzulegen, iobroker neu zu installieren und dort ein Backup zu laden? Oder sind da andere Probleme zu erwarten?
                                • A AndieKiste
                                  #2392
                                  nur die Üblichen ;-)
                                  anderer Hostname und andere IP
                                  ersteres sollte eigentlich mit dem Restore über Backitup geregelt sein, bei manuellem Restore geht das über 'iobroker host this' bevor iobroker wieder gestartet wird
                                  Letzteres ist nicht unbedingt wild, nur die IPs in diversen Adaptern müssten angepasst werden
                                    @andiekiste
                                    AndieKiste
                                    #2393
                                    root@iobroker:~# which nodejs node npm && nodejs -v && node -v && npm -v && whoami && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs& sudo apt update && apt policy nodejsv && npm -v && whoami && sudo apt
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    v14.18.2
                                    v14.18.2
                                    6.14.15
                                    root
                                    Get:2 http://archive.ubuntu.com/ubuntu hirsute-updates InRelease [115 kB]
                                    Hit:3 https://deb.nodesource.com/node_14.x groovy InRelease
                                    Get:4 http://archive.ubuntu.com/ubuntu hirsute-security InRelease [110 kB]
                                    Fetched 225 kB in 1s (249 kB/s)
                                    nodejs:
                                      Version table:
                                      AndieKiste
                                      #2394
                                      @thomas-braun @Homoran
                                      Also wenn zwei exakt das gleiche in einer Minute empfehlen, dann war der User andi jetzt gerade als allererstes erstellt :-D
                                      • A AndieKiste
                                        #2395
                                        Super!
                                        Auch in die Sudoers eingetragen?
                                          Super!
                                          AndieKiste
                                          #2396
                                          Jep, wieder ne gute kurze Forumanleitung inkl. Test gefunden. :-)
