  4. Adapter "smartmeter"
3.6k Beiträge 281 Kommentatoren 3.9m Aufrufe 162 Beobachtet
  • MSalmiM MSalmi
    iobroker smartmeter adapter installation error
    Hallo, bin relativ neu und hoffe, dass ich hier richtig bin ?! Nach Rücksprache mit Apollon77 nachfolgend die Problembeschreibung bei der Neuinstallation des Smartmeter Adapters:
    • After upgrade of our rpi4b from buster to bullseye the update of the entire iobroker system went well ... except reactivating the smartmeter adapter installation, which operated successfully for more than a year. After several attempts of reactivating the instance the adapter was uninstalled and reinstallation does not seem to be possible anymore (always finishing with errors) ?!
    U.g. LogFile ist hochgeladen und nachfolgend noch die Fehlermeldungen mit denen der Installationsvorgang abgebrochen wird sowie Versionsinformationen.
    Installations-Fehlermeldungen:
    * $iobroker add smartmeter --host iobroker-master
    NPM version: 6.14.15
    npm install iobroker.smartmeter@3.2.1 --loglevel error --prefix "/opt/iobroker" (System call)
    make: g++: No such file or directory
    make: *** [bindings.target.mk:112: Release/obj.target/bindings/src/serialport.o] Error 127
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)gyp ERR! System Linux 5.10.87-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindingsgyp ERR! node -v v14.18.2gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! @serialport/bindings@9.2.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
    npm ERR! Exit status 1npm ERR! npm ERR! Failed at the @serialport/bindings@9.2.8 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-01-03T23_34_54_767Z-debug.log
    host.iobroker-master Cannot install iobroker.smartmeter@3.2.1: 1
    ERROR: Process exited with code 25
    MOD_Edit: Code in code-tags gesetzt!
    Zus. Versionsinformationen:
    * pi@iobroker-master:~ $ lsb_release -a
    No LSB modules are available.
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    pi@iobroker-master:~ $ nodejs -v && node -v && npm -v
    v14.18.2
    v14.18.2
    6.14.15
    2022-01-03T13_31_05_679Z-debug.log
    apollon77A
    apollon77A
    #2374
    @msalmi sagte in Adapter "smartmeter":
    Da fehlt der compiler
    "iobroker fix" macht welche ausgabe?
    • MSalmiM
      MSalmiM
      MSalmi
      #2375
      @apollon77 said in Adapter "smartmeter":
      iobroker fix
      Perfekt, nach Ausführung von "iobroker fix" hat die Installation nun funktioniert. 👍 Noch einmal recht vielen Dank !!!
      • loboL lobo
        Ich hab einen Wärmemengenzähler Siemens Uh 50 bzw. baugleich mit Landis+Gyr ULTRAHEAT T550 und bekomme ihn einfach nicht ausgelesen. Kann mir jemand helfen?
        Ich kenne zum Thema diese beiden Infoquellen.
        http://www.sedelmaier.at/node/112
        http://www.sedelmaier.at/content/siemens-uh50-landisgyr-ultraheat-t550-mit-openhab
        https://gathering-tweakers-net.translate.goog/forum/list_messages/1535019?_x_tr_sl=nl&_x_tr_tl=de&_x_tr_hl=de
        Anscheinend muss man den Zähler mit 40 NUL erst aufwecken. Aber meine x hundert unterschiedlichen Versuche blieben bisher erfolglos. Ich bekomme einfach keine Antwort.
        smartmeter.1	2021-12-26 21:35:09.786	debug	SCHEDULE NEXT RUN IN 60000s
        smartmeter.1	2021-12-26 21:35:09.786	debug	DELETE rest of data (0) because new Message start with a new Request Message
        smartmeter.1	2021-12-26 21:35:09.786	debug	CURRENT SIGNON MESSAGE COUNTER 1 OF 1
        smartmeter.1	2021-12-26 21:35:09.785	debug	SERIALPORT REMOVE LISTENERS
        smartmeter.1	2021-12-26 21:35:09.785	debug	SERIALPORT CLOSE
        smartmeter.1	2021-12-26 21:35:09.782	debug	CLEAR MESSAGE TIMEOUT TIMER
        smartmeter.1	2021-12-26 21:35:09.781	debug	STOP
        smartmeter.1	2021-12-26 21:35:09.781	debug	Transport Reset!! Restart = true
        smartmeter.1	2021-12-26 21:35:09.781	debug	Error: No or too long answer from Serial Device after last request.
        smartmeter.1	2021-12-26 21:35:09.781	warn	No or too long answer from Serial Device after last request.
        smartmeter.1	2021-12-26 21:35:09.780	debug	MESSAGE TIMEOUT TRIGGERED
        smartmeter.1	2021-12-26 21:34:54.780	debug	SET MESSAGE TIMEOUT TIMER2: 15000
        smartmeter.1	2021-12-26 21:34:54.780	debug	DONE SEND 0
        smartmeter.1	2021-12-26 21:34:54.529	debug	DONE SEND 1
        smartmeter.1	2021-12-26 21:34:54.050	debug	TO SEND 1: /?!\x0D\x0A!
        smartmeter.1	2021-12-26 21:34:54.050	debug	CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
        smartmeter.1	2021-12-26 21:34:53.798	debug	DONE SEND 2
        smartmeter.1	2021-12-26 21:34:52.368	debug	TO SEND 2:
        smartmeter.1	2021-12-26 21:34:52.368	debug	CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
        smartmeter.1	2021-12-26 21:34:52.368	debug	INITIAL MESSAGES TO SEND: 2
        smartmeter.1	2021-12-26 21:34:52.368	debug	SERIALPORT RESET BAUDRATE TO 300
        smartmeter.1	2021-12-26 21:34:52.367	debug	SERIALPORT OPEN
        smartmeter.1	2021-12-26 21:34:52.365	debug	CREATE SERIALPORT: 300 7 2 even
        smartmeter.1	2021-12-26 21:33:52.364	debug	SCHEDULE NEXT RUN IN 60000s
        smartmeter.1	2021-12-26 21:33:52.364	debug	DELETE rest of data (0) because new Message start with a new Request Message
        smartmeter.1	2021-12-26 21:33:52.364	debug	CURRENT SIGNON MESSAGE COUNTER 1 OF 1
        smartmeter.1	2021-12-26 21:33:52.363	debug	SERIALPORT REMOVE LISTENERS
        smartmeter.1	2021-12-26 21:33:52.363	debug	SERIALPORT CLOSE
        smartmeter.1	2021-12-26 21:33:52.359	debug	CLEAR MESSAGE TIMEOUT TIMER
        smartmeter.1	2021-12-26 21:33:52.358	debug	STOP
        smartmeter.1	2021-12-26 21:33:52.358	debug	Transport Reset!! Restart = true
        smartmeter.1	2021-12-26 21:33:52.358	debug	Error: No or too long answer from Serial Device after last request.
        smartmeter.1	2021-12-26 21:33:52.358	warn	No or too long answer from Serial Device after last request.
        smartmeter.1	2021-12-26 21:33:52.357	debug	Error: No or too long answer from Serial Device after last request.
        smartmeter.1	2021-12-26 21:33:52.357	debug	MESSAGE TIMEOUT TRIGGERED
        smartmeter.1	2021-12-26 21:33:37.356	debug	SET MESSAGE TIMEOUT TIMER2: 15000
        smartmeter.1	2021-12-26 21:33:37.355	debug	DONE SEND 0
        smartmeter.1	2021-12-26 21:33:37.105	debug	DONE SEND 1
        smartmeter.1	2021-12-26 21:33:36.628	debug	TO SEND 1: /?!\x0D\x0A!
        smartmeter.1	2021-12-26 21:33:36.628	debug	CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
        smartmeter.1	2021-12-26 21:33:36.377	debug	DONE SEND 2
        smartmeter.1	2021-12-26 21:33:34.945	debug	TO SEND 2:
        smartmeter.1	2021-12-26 21:33:34.945	debug	CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
        smartmeter.1	2021-12-26 21:33:34.945	debug	INITIAL MESSAGES TO SEND: 2
        smartmeter.1	2021-12-26 21:33:34.945	debug	SERIALPORT RESET BAUDRATE TO 300
        smartmeter.1	2021-12-26 21:33:34.944	debug	SERIALPORT OPEN
        smartmeter.1	2021-12-26 21:33:34.941	debug	CREATE SERIALPORT: 300 7 2 even
        Meine zuletzt versuchten Einstellungen:
        @apollon77 @rossi73 Ich glaube ihr habt beide ähliche Zähler, aber nie eure Konfig hier gepostet?!
        B
        B
        Bombel
        #2376
        @lobo @apollon77 Ich schlage mich auch gerade mit dem Wärmemengenzähler T230 von Landis+Gyr rum. Bekomme ihn mit dem Standard nach EN 62056-21:2002 nicht ausgelesen. Habe mir kürzlich mal die App UltraAssist von Landis+Gyr auf mein Smartphone geladen und den Lesekopf mittels OTG-Adapter angeschlossen. Die App schafft es dem Zähler Daten zu entlocken und diese in eine schöne Excel-Datei zu packen. Daraufhin habe ich mir einen zweiten Lesekopf beschafft und diesen dann an den PC angeschlossen. Die beiden Leseköpfe habe ich aneinandergehalten und mittels HTerm ausgelesen, was die App von Landis+Gyr zu Begrüßung sendet. Herausgekommen ist folgendes:
        Leider weiß ich nicht wie ich die SignOn-Nachricht in diesem Fall zusammenbauen muss. Habe es mit 30 WakeUp-Zeichen und "@p" als SignOn-Nachricht versucht, aber da tut sich leider gar nichts.
        Habe mich schon durch die schöne Google-Welt gekämpft aber keinerlei Dokumentationen zur optischen Schnittstelle diese Zählers gefunden. Vielleicht habt ihr noch einen heißen Typ für mich....Ich wäre euch sehr dankbar.
        Gruß Florian
        Log:
        smartmeter.1    2022-01-06 20:49:43.384	warn	No or too long answer from Serial Device after last request.
        smartmeter.1    2022-01-06 20:49:43.383	debug	Error: No or too long answer from Serial Device after last request.
        smartmeter.1    2022-01-06 20:49:43.382	debug	MESSAGE TIMEOUT TRIGGERED
        smartmeter.1    2022-01-06 20:49:13.380	debug	SET MESSAGE TIMEOUT TIMER2: 30000
        smartmeter.1    2022-01-06 20:49:13.379	debug	DONE SEND 0
        smartmeter.1    2022-01-06 20:49:13.127	debug	DONE SEND 1
        smartmeter.1    2022-01-06 20:49:12.996	debug	TO SEND 1: /@p!
        smartmeter.1    2022-01-06 20:49:12.994	debug	CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
        smartmeter.1    2022-01-06 20:49:12.743	debug	DONE SEND 2
        smartmeter.1    2022-01-06 20:49:11.805	debug	TO SEND 2: 000000000000000000000000000000
        smartmeter.1    2022-01-06 20:49:11.804	debug	CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
        smartmeter.1    2022-01-06 20:49:11.801	debug	INITIAL MESSAGES TO SEND: 2
        smartmeter.1    2022-01-06 20:49:11.796	debug	SERIALPORT RESET BAUDRATE TO 300
        smartmeter.1    2022-01-06 20:49:11.793	debug	SERIALPORT OPEN
        smartmeter.1    2022-01-06 20:49:11.778	debug	CREATE SERIALPORT: 300 7 1 even
        PanicManP 1 Antwort Letzte Antwort
        • A
          A
          AndieKiste
          schrieb am zuletzt editiert von AndieKiste
          #2377
          erst mal vielen Dank für die super Arbeit mit dem Adapter. Leider verzweifle ich gerade an ihm.
          Ich bekomme ihn erst garnicht ans Laufen, sobald er gestartet wird, kommen folgende Fehler im Log:
          2022-01-06 21:30:37.347 - error: host.iobroker Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
          2022-01-06 21:30:37.364 - error: host.iobroker Caught by controller[0]: throw e;
          2022-01-06 21:30:37.364 - error: host.iobroker Caught by controller[0]: ^
          2022-01-06 21:30:37.364 - error: host.iobroker Caught by controller[0]: Error: libnode.so.72: cannot open shared object file: No such file or directory
          2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
          2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
          2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
          2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
          2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
          2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
          2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
          2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
          2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
          2022-01-06 21:30:37.365 - error: host.iobroker Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32) {
          2022-01-06 21:30:37.366 - error: host.iobroker Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
          2022-01-06 21:30:37.366 - error: host.iobroker Caught by controller[0]: }
          2022-01-06 21:30:37.366 - error: host.iobroker instance system.adapter.smartmeter.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2022-01-06 21:30:37.366 - info: host.iobroker Restart adapter system.adapter.smartmeter.1 because enabled
          Das Problem besteht seit der Installation. Hier ein paar Daten zum System:
          smartmeter v.3.2.1
          iobroker v.3.3.22
          System läuft unter Proxmox VE 6.4 auf einem Ubuntu 21.04
          Node.Js 14.18.2
          NPM v6.14.15
          Abgesehen von den Fehlern ist bei Instanzen jeder Status rot.
          In den Einstellungen der Instanz kann die Liste der Adapter auch nicht angezeigt werden.
          Als Leseköpfe kommen 2 Stück von Hichi IR USB zum Einsatz. Diese werden auf Proxmox-Ebene als auch nach Durchschleifen an die VM auf dem iobroker erkannt und als Device im Terminal gefunden.
          Jemand eine Idee, wie ich den Adapter ans Laufen bekomme? Vielen Dank schon mal im Voraus.
          Ich hab den Adapter schon de- und wieder installiert als auch iobroker fix duchgeführt, leider ohne Erfolg.
          Andi
          HomoranH Thomas BraunT 3 Antworten Letzte Antwort
          • A AndieKiste
            smartmeter v.3.2.1
            iobroker v.3.3.22
            Node.Js 14.18.2
            NPM v6.14.15
            Andi
            #2378
            @andiekiste sagte in Adapter "smartmeter":
            Node.Js 14.18.2
            NPM v6.14.15
            sicher?
            laut doku
            gibt es den erst ab v15
            • A AndieKiste
              smartmeter v.3.2.1
              iobroker v.3.3.22
              Node.Js 14.18.2
              NPM v6.14.15
              Andi
              Thomas BraunT
              Thomas BraunT
              Most Active Developer
              #2379
              Das irritiert mich. Diese Datei kommt eigentlich aus der Debian-Ecke, also deren hauseigener Version von nodejs:
              apt policy libnode72
              libnode72:
                Installed: (none)
                Candidate: 12.22.5~dfsg-2~11u1
                Version table:
                   12.22.5~dfsg-2~11u1 500
                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
              Die ist aber in der Form bei einer nodesource-Installation nicht vorhanden. Und auch nicht erforderlich, denn:
              2022-01-06 21:53:22.784  - info: smartmeter.0 (137513) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v17.3.0, js-controller: 3.3.22
              2022-01-06 21:53:22.819  - error: smartmeter.0 (137513) Serial port device is undefined, check your configuration!
              Startet bei mir auch ohne libnode.so.72
              • A AndieKiste
                smartmeter v.3.2.1
                iobroker v.3.3.22
                Node.Js 14.18.2
                NPM v6.14.15
                Andi
                Thomas BraunT
                Thomas BraunT
                #2380
                @andiekiste
                Was sagt:
                which nodejs node npm && nodejs -v && node -v && npm -v && whoami && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  Node.Js 14.18.2
                  NPM v6.14.15
                  sicher?
                  laut doku
                  A
                  A
                  AndieKiste
                  #2381
                  Eigentlich schon, ja, es wird mir zumindest so angezeigt. Ich bin aber selbst gerade maximal verwirrt, weil wenn ich in der Konsole nodejs -v eingebe, sagt er mir dass nodejs nicht vorhanden ist und ich es installieren soll. Bin leider kein Linux-Fachmann aber werde es jetzt mal installieren.
                  Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                  • A AndieKiste
                    Thomas BraunT
                    Thomas BraunT
                    #2382
                    @andiekiste NEIN!
                    Das Kommando nodejs ist in aktuellen Versionen nicht mehr drin. Das ist also i. O.
                    Du kannst es aber mit
                    'nachbauen'.
                    • A AndieKiste
                      Thomas BraunT
                      Thomas BraunT
                      #2383
                      @andiekiste
                      Was liefert
                      denn nu?
                      • A AndieKiste
                        #2384
                        dann wären zwei Szenarien denkbar (oder mehr)
                        • es kam später in eine höhere 14.x mit rein
                        • du hattest zwischendrin mal eine höhere node-Version als 14 installiert und wieder downgegradet
                          @andiekiste
                          Was sagt:
                          A
                          A
                          AndieKiste
                          #2385
                          Ich bin maximal verwirrt. Wenn ich richtig verstehe was du gerne hättest sind das ja verschiedene Befehle hintereinander. Einzeln nacheinander sieht es so aus:
                          root@iobroker:~# which nodejs node npm
                          /usr/bin/node
                          /usr/bin/npm
                          root@iobroker:~# nodejs -v
                          Command 'nodejs' not found, but can be installed with:
                          apt install nodejs
                          root@iobroker:~# node -v
                          v14.18.2
                          root@iobroker:~# npm -v
                          6.14.15
                          root@iobroker:~# whoami
                          root
                          root@iobroker:~# apt update &> /dev/null      "Der Befehl gibt garnichts zurück bei mir"
                          Hit:1 http://archive.ubuntu.com/ubuntu hirsute InRelease
                          Hit:2 http://archive.ubuntu.com/ubuntu hirsute-updates InRelease
                          Hit:3 http://archive.ubuntu.com/ubuntu hirsute-security InRelease
                          Hit:4 https://deb.nodesource.com/node_14.x groovy InRelease
                          Reading package lists... Done
                          3 packages can be upgraded. Run 'apt list --upgradable' to see them.
                          root@iobroker:~# apt policy nodejs
                          nodejs:
                            Installed: 14.18.2-deb-1nodesource1
                            Candidate: 14.18.2-deb-1nodesource1
                            Version table:
                           *** 14.18.2-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_14.x groovy/main amd64 Packages
                               12.21.0~dfsg-3ubuntu1 500
                                  500 http://archive.ubuntu.com/ubuntu hirsute/universe amd64 Packages
                          Was ich auch nicht verstehe, er zeigt mir ja von nodejs was an. Umgekehrt über die Konsole dachte ich mir, wenn er nodejs installiert haben will, versuche ich es einfach, aber dann kommt folgendes:
                          root@iobroker:~# apt install nodejs
                          nodejs is already the newest version (14.18.2-deb-1nodesource1).
                          0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
                          Ich weiß leider dass ich als root angemeldet bin, was nicht gut ist. aber als iobroker kann ich mich nicht einloggen, dann sagt er mir "User account currently not available."
                          Erkennst du da was?
                          Danke und Gruß
                          Andi
                          HomoranH Thomas BraunT 4 Antworten Letzte Antwort
                          • A AndieKiste
                            /usr/bin/node
                            /usr/bin/npm
                            apt install nodejs
                            v14.18.2
                            6.14.15
                            root
                            nodejs:
                              Version table:
                            Erkennst du da was?
                            Danke und Gruß
                            Andi
                            #2386
                            nodejs ist node
                            Hieß früher nur auch nodejs. Uralte Programme erwarten das noch. Dafür wurde früher einfach ein Link gesetzt, der bei Aufruf von nodejs auf node verlinkt hatte.
                            Das kann man immer noch machen, ist aber standardmäßig nur noch selten der Fall
                            Nix neu installieren!
                            Das geht dann wieder schief
                              A
                              A
                              AndieKiste
                              #2387
                              @homoran Bei node Updates halte ich mich meist an Anleitungen sobald sie verfügbar sind und an die Versionen, wie sie hier im Forum vorgeschlagen werden, da ich wie gesagt nicht der Linux-Fachmann bin. Ich möchte es natürlich nicht ausschließen, aber "aus Versehen" ein Up- und wieder Downgrade zu machen würde mich selbst überraschen. :-)
                              • A AndieKiste
                                /usr/bin/node
                                /usr/bin/npm
                                apt install nodejs
                                v14.18.2
                                6.14.15
                                root
                                nodejs:
                                  Version table:
                                Erkennst du da was?
                                Danke und Gruß
                                Andi
                                Thomas BraunT
                                Thomas BraunT
                                #2388
                                @andiekiste
                                Und dann in einer Tour durch:
                                Nix rauspflücken, alles so in die Konsole klatschen.
                                • A AndieKiste
                                  /usr/bin/node
                                  /usr/bin/npm
                                  apt install nodejs
                                  v14.18.2
                                  6.14.15
                                  root
                                  nodejs:
                                    Version table:
                                  Erkennst du da was?
                                  Danke und Gruß
                                  Andi
                                  #2389
                                  das ist auch richtig so, aber du solltest einen normalen user, z.B. andi haben unter dem du arbeitest
                                  • A AndieKiste
                                    /usr/bin/node
                                    /usr/bin/npm
                                    apt install nodejs
                                    v14.18.2
                                    6.14.15
                                    root
                                    nodejs:
                                      Version table:
                                    Erkennst du da was?
                                    Danke und Gruß
                                    Andi
                                    Thomas BraunT
                                    Thomas BraunT
                                    #2390
                                    Dann leg dir einen andi user an.
                                      nodejs ist node
                                      A
                                      A
                                      AndieKiste
                                      #2391
                                      @homoran ahh oke, danke. Dann bleibt nur leider die Frage warum der Adapter nicht will.
                                      Macht es Sinn, unter Proxmox einfach mal eine neue VM anzulegen, iobroker neu zu installieren und dort ein Backup zu laden? Oder sind da andere Probleme zu erwarten?
                                      • A AndieKiste
                                        #2392
                                        nur die Üblichen ;-)
                                        anderer Hostname und andere IP
                                        ersteres sollte eigentlich mit dem Restore über Backitup geregelt sein, bei manuellem Restore geht das über 'iobroker host this' bevor iobroker wieder gestartet wird
                                        Letzteres ist nicht unbedingt wild, nur die IPs in diversen Adaptern müssten angepasst werden
                                          @andiekiste
                                          A
                                          A
                                          AndieKiste
                                          #2393
                                          root@iobroker:~# which nodejs node npm && nodejs -v && node -v && npm -v && whoami && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs& sudo apt update && apt policy nodejsv && npm -v && whoami && sudo apt
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          v14.18.2
                                          v14.18.2
                                          6.14.15
                                          root
                                          Get:2 http://archive.ubuntu.com/ubuntu hirsute-updates InRelease [115 kB]
                                          Hit:3 https://deb.nodesource.com/node_14.x groovy InRelease
                                          Get:4 http://archive.ubuntu.com/ubuntu hirsute-security InRelease [110 kB]
                                          Fetched 225 kB in 1s (249 kB/s)
                                          nodejs:
                                            Version table:
                                          33.2k
                                          84.3k
