  4. [HowTo] InfluxDB 2.1 auf Debian 11 (proxmox CT) installieren
131 Beiträge 23 Kommentatoren 54.8k Aufrufe 29 Beobachtet
  • lobomauL lobomau
    @homoran also... direkt "apt install influxdb" ging auch. Dann ist erstmal nur 1.6.7. installiert. 1.8.10 ist aber die aktuellste 1.8.
    InfluxDBian login: root
    Password:
    Linux InfluxDBian 5.13.19-1-pve #1 SMP PVE 5.13.19-3 (Tue, 23 Nov 2021 13:31:19 +0100) x86_64
    permitted by applicable law.
    Last login: Fri Dec  3 10:39:39 CET 2021 on tty1
    root@InfluxDBian:~# apt install influxdb
    Reading package lists... Done
    The following NEW packages will be installed:
      influxdb
    0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
    Need to get 5010 kB of archives.
    After this operation, 19.0 MB of additional disk space will be used.
    Get:1 http://ftp.debian.org/debian bullseye/main amd64 influxdb amd64 1.6.7~rc0-1+b5 [5010 kB]
    Fetched 5010 kB in 0s (10.2 MB/s)
    Selecting previously unselected package influxdb.
    (Reading database ... 20396 files and directories currently installed.)
    Preparing to unpack .../influxdb_1.6.7~rc0-1+b5_amd64.deb ...
    Unpacking influxdb (1.6.7~rc0-1+b5) ...
    Setting up influxdb (1.6.7~rc0-1+b5) ...
    Adding system user `influxdb' (UID 107) ...
    Adding new user `influxdb' (UID 107) with group `nogroup' ...
    Not creating home directory `/var/lib/influxdb'.
    Adding group `influxdb' (GID 115) ...
    Done.
    Adding user `influxdb' to group `influxdb' ...
    Adding user influxdb to group influxdb
    Done.
    Created symlink /etc/systemd/system/influxd.service -> /lib/systemd/system/influxdb.service.
    Created symlink /etc/systemd/system/multi-user.target.wants/influxdb.service -> /lib/systemd/system/influxdb.service.
    Processing triggers for man-db (2.9.4-2) ...
    root@InfluxDBian:~# influx
    -bash: influx: command not found
    root@InfluxDBian:~# influxd
     8888888           .d888 888                   8888888b.  888888b.
       888            d88P"  888                   888  "Y88b 888  "88b
       888            888    888                   888    888 888  .88P
       888   88888b.  888888 888 888  888 888  888 888    888 8888888K.
       888   888 "88b 888    888 888  888  Y8bd8P' 888    888 888  "Y88b
       888   888  888 888    888 888  888   X88K   888    888 888    888
       888   888  888 888    888 Y88b 888 .d8""8b. 888  .d88P 888   d88P
     8888888 888  888 888    888  "Y88888 888  888 8888888P"  8888888P"
    2021-12-03T10:28:29.761197Z     info    InfluxDB starting       {"log_id": "0YByFwlG000", "version": "1.6.7~rc0", "branch": "unknown", "commit": "unknown"}
    2021-12-03T10:28:29.761262Z     info    Go runtime      {"log_id": "0YByFwlG000", "version": "go1.15.9", "maxprocs": 2}
    run: open server: listen: listen tcp 127.0.0.1:8088: bind: address already in use
    root@InfluxDBian:~#
    lobomauL
    lobomauL
    lobomau
    @lobomau ok... jetzt habe ich den korrekten Befehl gefunden für lsb_release:
    apt install -y lsb-release
    Ich fahre nochmal ein backup ein und fange von vorne an...
    Host: NUC8i3 mit Proxmox:
    • Slave: Pi4
    • lobomauL lobomau
      Password:
        influxdb
      Done.
      Done.
      root@InfluxDBian:~#
      @lobomau sagte in [HowTo?] InfluxDB 1.8.x auf Debian 11 (proxmox) installieren:
      es ging nicht um Influx - es geht um Proxmox Grundinstallation
        dslraserD
        dslraserD
        dslraser
        @homoran sagte in [HowTo?] InfluxDB 1.8.x auf Debian 11 (proxmox) installieren:
        Ich habe es damit gemacht.
        https://pve.proxmox.com/wiki/Package_Repositories
        und das sieht dann so aus
        • dslraserD dslraser
          lobomauL
          lobomauL
          lobomau
          schrieb am zuletzt editiert von lobomau
          @dslraser ja, das könnte es sein. Korrigiere ich mal und teste nochmal...
          Edit.: hab ich doch, oder?
          /etc/apt/sources.list:
          #deb http://ftp.de.debian.org/debian bullseye main contrib
          deb http://ftp.debian.org/debian bullseye main contrib
          deb http://ftp.debian.org/debian bullseye-updates main contrib
          #deb http://ftp.de.debian.org/debian bullseye-updates main contrib
          deb http://download.proxmox.com/debian/pve bullseye pve-no-subscription
          # security updates
          #deb http://security.debian.org bullseye-security main contrib
          deb http://security.debian.org/debian-security bullseye-security main contrib
          #deb http://deb.debian.org/debian-security bullseye-security main
          • Slave: Pi4
          lobomauL dslraserD 2 Antworten Letzte Antwort
          • lobomauL lobomau
            # security updates
            lobomauL
            lobomauL
            lobomau
            Edit.: ich habe die Installation für InfluxDB 1.8 verworfen und gleich 2.1. versucht. Ging dann auch ohne Schwierigkeiten. HowTo habe ich darauf hin angepasst.
            Bei Punkt 11 hänge ich nun :-(
            Last login: Fri Dec  3 11:58:39 CET 2021 on tty1
            root@InfluxDBian:~# systemctl status influxdb.service
            * influxdb.service - InfluxDB is an open-source, distributed, time series database
                 Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: e>
                 Active: activating (start) since Fri 2021-12-03 12:08:57 CET; 1min 16s ago
                   Docs: https://docs.influxdata.com/influxdb/
            Cntrl PID: 2406 (influxd-systemd)
                  Tasks: 2 (limit: 9300)
                 Memory: 1000.0K
                    CPU: 2.178s
                 CGroup: /system.slice/influxdb.service
                         |-2406 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.sh
                         `-2685 sleep 1
            Dec 03 12:10:04 InfluxDBian influxd-systemd-start.sh[2406]: InfluxDB API unavailable>
            Dec 03 12:10:05 InfluxDBian influxd-systemd-start.sh[2406]: InfluxDB API unavailable>
            Dec 03 12:10:06 InfluxDBian influxd-systemd-start.sh[2406]: InfluxDB API unavailable>
            Dec 03 12:10:07 InfluxDBian influxd-systemd-start.sh[2406]: InfluxDB API unavailable>
            Dec 03 12:10:08 InfluxDBian influxd-systemd-start.sh[2406]: InfluxDB API unavailable>
            Dec 03 12:10:09 InfluxDBian influxd-systemd-start.sh[2406]: InfluxDB API unavailable>
            Dec 03 12:10:10 InfluxDBian influxd-systemd-start.sh[2406]: InfluxDB API unavailable>
            Dec 03 12:10:11 InfluxDBian influxd-systemd-start.sh[2406]: InfluxDB API unavailable>
            Dec 03 12:10:12 InfluxDBian influxd-systemd-start.sh[2406]: InfluxDB API unavailable>
            Dec 03 12:10:13 InfluxDBian influxd-systemd-start.sh[2406]: InfluxDB API unavailable>
            lines 1-22/22 (END)...skipping...
                 Memory: 1000.0K
                    CPU: 2.178s
                         `-2685 sleep 1
            • Slave: Pi4
            • F ftd
              @lobomau zu 4) 2.1.1 ist aktuell .... https://portal.influxdata.com/downloads/
              lobomauL
              lobomauL
              lobomau
              @ftd so, habe das einfach mal nach deinem link gemacht. Ist dann nicht so schwierig. Ich werde sehen wie ich meine alte Datenbank aus 1.8 in 2.1 bekomme.
              Anleitung sollte so klappen. habe extra nochmal Backup eingespielt und meine Befehle oben genau so eingegeben.
              Installiert ist es schon mal. Fehlt noch die korrekte konfiguration. Im Augenblick ist der port :8086 anderweitig in Gebrauch weshalb es (noch) einen Fehler gibt.
              Edit: Ziel/Motivation bei mir ist, alles auf Debian 11 bullseye umzustellen. Bisher ist das nur beim Proxmox und bei einem Pi3-Slave der Fall.
              Die anderen Container sind Debian 10 und InfluxDB läuft auf Ubuntu 20:
              • Slave: Pi4
              • lobomauL lobomau
                # security updates
                dslraserD
                dslraserD
                dslraser
                @lobomau sagte in [HowTo] InfluxDB 2.1 auf Debian 11 (proxmox CT) installieren:
                Ich hatte @Homoran geantwortet, das war nur die Antwort auf seine Frage.
                • crunchipC
                  crunchipC
                  Developer Global Moderator Most Active Forum Testing
                  @homoran da hat sich nichts geändert, ausser das du in v7 das Repo nun direkt in der proxmox Gui bearbeiten kannst
                  • lobomauL lobomau
                    D
                    D
                    DocGame
                    @lobomau Ich hatte die 1.8 seit einem Jahr erfolgreich im einem Proxmox CT am laufen. Nach Update des Influx-Adapters von 1.9.5 auf 2.2.0 kam keine Verbindung zu InfluxDB zu stande (1.x war in den Adaptereinstellungen eingestellt). Nach einem Downgrade lief wieder alles.
                    Ich habe mich gestern mit deiner Anleitung an das Installieren einer InfluxDB 2.1 CT gemacht. Es hat alles soweit geklappt.
                    Nach dem Updaten des Adapters wollte ich meine Daten eintragen. Wo in aller Welt bekomme ich den Token her? Habe die ganze Nacht "gegoogelt", bin aber leider zu keinem Ergebnis gekommen.
                    Kannst du mir auf die Sprünge helfen?
                    F lobomauL 2 Antworten Letzte Antwort
                    • crunchipC
                      crunchipC
                      @docgame hab zwar die Version noch nicht, aber hier steht es
                      • D DocGame
                        F
                        F
                        ftd
                        @docgame über die GUI... IP-Adresse:8086 --> Data --> API Tokens
                        • Palm_ManiacP
                          Palm_ManiacP
                          Palm_Maniac
                          tolle Anleitung. Wie sieht es denn bei einem Upgrade von V1 auf V2 von influxdb aus, gibt es da einen Weg unter Mitnahme aller bereits vorhandenen Datenbanken? Ich würde gerne wechseln, würde aber ungern meine Daten verlieren, die ich nun schon seit über 1 Jahr aufzeichne.
                          F 1 Antwort Letzte Antwort
                          • Palm_ManiacP Palm_Maniac
                            F
                            F
                            ftd
                            @palm_maniac https://docs.influxdata.com/influxdb/v2.1/upgrade/v1-to-v2/
                            • F ftd
                              D
                              D
                              DocGame
                              @ftd @crunchip Über die GUI hat es geklappt. Habe ich heute nacht schon probiert (aber versehentlich die falsche IP erwischt und bin nicht drauf gekommen).
                              Grafana habe ich seinerzeit auf dem gleichen Container wie InfluxDB gehabt. Mal sehen ob ich es auch auf dem neuen Container wieder hinbekomme.
                              Wäre es nicht möglich InfluxDB auf dem alten Container zu löschen und diesen nur noch für Grafana zu nutzen?
                              Wie geht denn der uninstall? Bin unter Linux leider eine richtige Pfeife.....
                              • D DocGame
                                F
                                F
                                ftd
                                @docgame
                                sudo apt purge influxdb
                                ggf. noch Verzeichnisse löschen
                                /var/lib/influxdb/data
                                /var/lib/influxdb/wal
                                /var/lib/influxdb/meta
                                D crunchipC 2 Antworten Letzte Antwort
                                • F ftd
                                  @docgame
                                  D
                                  D
                                  DocGame
                                  @ftd Ich gebe es für heute auf...
                                  Mit dem eigentlichen Thema hat mein Problem auch nichts mehr zu tun (InfluxDB ist installiert und wird im Moment auch schn vom Adapter mit Daten gefüttert).
                                  Ich habe jetzt doch Grafana in den Container installiert. Das läuft auch....Nur bekomme ich die Datenbank nicht damit verknüpft.
                                  Vielleicht finde ich noch eine Anleitung für "Dummies"
                                  • F ftd
                                    @docgame
                                    crunchipC
                                    crunchipC
                                    @ftd
                                    sudo apt-get autoremove --purge influxdb
                                    sollte eigendlich Influx, alle Abhängigkeiten und Verzeichnisse löschen
                                    @docgame sagte in [HowTo] InfluxDB 2.1 auf Debian 11 (proxmox CT) installieren:
                                    wo ist jetzt das Problem, du hast jetzt 2 Container laufen?
                                    • D DocGame
                                      F
                                      F
                                      ftd
                                      @docgame Wir driften jetzt allerdings zu Grafana ab...
                                      Für Influx mit Flux:
                                      URL => localhost:8086, wenn Influx auf dem gleichen System läuft... wenn nicht, dann die IP-Adresse
                                      Auth => alles ausschalten
                                      Custom HTTP Headers
                                      Header: Authorization
                                      Value: Token DerTokenausderInfluxGUI
                                      Da muss das Wort Token stehen, danach ein Leerzeichen und dann der Token selbst... da kommen Sternchen... man sieht nicht, was man schreibt.
                                      InfluxDB Details
                                      Organsisation und Bucket und der Token (hier nur der Token, ohne dem Wort Token und ohne Leerzeichen)
                                      • D DocGame
                                        lobomauL
                                        lobomauL
                                        lobomau
                                        @docgame Sorry, soweit bin ich noch nicht gekommen. Bei mir läuft noch influxDB 1.8.x produktiv.
                                        • Slave: Pi4
                                          @ftd
                                          D
                                          D
                                          DocGame
                                          Sorry, wenn ich jetzt beim Thema abdrifte. Ich denke aber, dass ich kurz vor der Lösung bin.
                                          Im Übrigen denke ich, dass für die meisten die InfluxDB aufsetzen auch an Grafata interessiert sind und hier ist das anbinden definitiv anders als in den vorangegangenen Versionen.
                                          @crunchip Das Problem ist, das ich im neuen Container die InfluxDB noch nicht mit Grafana zusammenbekomme. Der alte Container kommt natürlich weg wen das geklappt hat.
                                          @ftd Das ich Auth abschalten muss wäre ich nie darauf gekommen. Wenn ich auf save gehe kommt jetzt rechts oben eine grüne Meldung: "Datasource update". Der erste Teil ist scheinbar richtig. Die "InfluxDB Details" sieht bei mir anders aus als bei dir. Hier kommt ein Fehler.(Bei Passwort habe ich den Token von oben drin). Sollte sich das Problem noch hinziehen mache ich natürlich ein neues Thema auf. Denke, es ist aber nur noch nee Kleinigkeit.
                                          84.2k
