  4. [Anleitung] WireGuard mit WireGuard-UI auf Proxmox
portforwardingportfreigabeportfreischaltungproxmoxvpnwireguardwireguard ios app
603 Beiträge 64 Kommentatoren 271.0k Aufrufe 47 Beobachtet
  • NegaleinN Negalein
    @crunkfx sagte in [Anleitung] WireGuard mit WireGuard-UI auf Proxmox:
    wget https://raw.githubusercontent.com/KleSecGmbH/ioBroker/main/wireguard/installer-pve.sh -O installer-pve.sh && bash installer-pve.sh
    das passt so?
    WireGuard is already installed.
    Select an option:
       1) Add a new client
       2) Remove an existing client
       3) Remove WireGuard
       4) Exit
    Option: 4
    und dann
    root@Wireguard-VPN:~# cd /root/wireguard-ui
    root@Wireguard-VPN:~/wireguard-ui# docker-compose up
    Creating wgui ... error
    ERROR: for wgui  Cannot create container for service wg: Conflict. The container name "/wgui" is already in use by container "e0fec4ebac7cc702789c13850ce574d71ac7641eef0822170a0ef8e640fdd36d". You have to remove (or rename) that container to be able to reuse that name.
    ERROR: for wg  Cannot create container for service wg: Conflict. The container name "/wgui" is already in use by container "e0fec4ebac7cc702789c13850ce574d71ac7641eef0822170a0ef8e640fdd36d". You have to remove (or rename) that container to be able to reuse that name.
    ERROR: Encountered errors while bringing up the project.
    root@Wireguard-VPN:~/wireguard-ui# docker stop e0fec4ebac7cc702789c13850ce574d71ac7641eef0822170a0ef8e640fdd36d
    root@Wireguard-VPN:~/wireguard-ui# docker system prune -a
    WARNING! This will remove:
      - all stopped containers
      - all networks not used by at least one container
      - all images without at least one container associated to them
      - all build cache
    Are you sure you want to continue? [y/N] y
    Deleted Containers:
    Deleted Networks:
    root_default
    Deleted Images:
    untagged: ngoduykhanh/wireguard-ui:latest
    untagged: ngoduykhanh/wireguard-ui@sha256:6f9a448d59a8d1caa73d3f4285ed8d257e1e55e179167e8ed630aea57592ad33
    deleted: sha256:4db588911bec98259b309558c77f106992814e6c2025d3ef4f7651a93e124008
    deleted: sha256:ce0601e1deda628bdbd314b66f98988398e206859d36237e10b9086cfaa31d3d
    deleted: sha256:6e4d16753cb5c6debe89482b1dd5f60eb3c8b4f09ffadb39b9a0a69e99b0cd25
    deleted: sha256:a364fcb7bc7d58162843c941803d87acc3571b038c1faef7431e6055741511bb
    deleted: sha256:4d93b92cf1a9a6f74075fe749df60271bd6b71fe991b6df6ca22e984a9244d5a
    deleted: sha256:14d0173ae5d18cffb7f01aab806a6edfbdf7b22a75b8a77f68db0ca6e84d4d23
    deleted: sha256:7e630ca8e05efa3aeae00e8fd435735fa62e8992d8ee3d2ca793468e2f36fd28
    deleted: sha256:9a5d14f9f5503e55088666beef7e85a8d9625d4fa7418e2fe269e9c54bcb853c
    Total reclaimed space: 48.83MB
    root@Wireguard-VPN:~/wireguard-ui# docker-compose up -d
    Pulling wg (ngoduykhanh/wireguard-ui:latest)...
    latest: Pulling from ngoduykhanh/wireguard-ui
    ddad3d7c1e96: Pull complete
    6469142f90ff: Pull complete
    700aafca4b83: Pull complete
    6849e6313309: Pull complete
    11e88fa8b517: Pull complete
    0353d820a55a: Pull complete
    3af261a56413: Pull complete
    Digest: sha256:6f9a448d59a8d1caa73d3f4285ed8d257e1e55e179167e8ed630aea57592ad33
    Status: Downloaded newer image for ngoduykhanh/wireguard-ui:latest
    Creating wgui ... done
    CrunkFXC
    CrunkFXC
    CrunkFX
    Forum Testing
    @negalein Jawoll
      das passt so?
      Select an option:
         1) Add a new client
         3) Remove WireGuard
         4) Exit
      Option: 4
      und dann
        - all build cache
      Deleted Containers:
      Deleted Networks:
      root_default
      Deleted Images:
      CrunkFXC
      CrunkFXC
      CrunkFX
      Forum Testing
      @negalein Dann müsste bei connected peers was drin stehen f605fe0a-5c63-4902-a61b-0b9f1b02e39e-image.png
        @CrunkFX
        beim Import am Handy (oder auch QR-Scan) schreibt er ungültiger Name.
        Wäre hier IP 10.0.1.1/24 richtig?
        10.0.1.x ist mein internes Netz.
        Ist aber bis auf Name & IP (hier soll der gesamte IP-Bereich gelten) alles gleich.
        NegaleinN
        NegaleinN
        Negalein
        @CrunkFX
        @negalein sagte in [Anleitung] WireGuard mit WireGuard-UI auf Proxmox:
        @CrunkFX
        ° Fixer ---> iob fix
        CrunkFXC 1 Antwort Letzte Antwort
        • CrunkFXC CrunkFX
          NegaleinN
          NegaleinN
          Negalein
          kann ich morgen sagen. Komm gerade nicht auf die Fritz zwecks Weiterleitung
            @CrunkFX
            @CrunkFX
            CrunkFXC
            CrunkFXC
            CrunkFX
            Forum Testing
            @negalein Nicht ganz
            cc106bc5-b492-4032-8295-1f17ad5c62b1-image.png so z.B. hat der Client nur Zugriff auf die IP´s 192.168.1.1-192.168.1.254
            Also
            x.x.x.0/24 für alle
            x.x.x.0/32 für 1
            • CrunkFXC CrunkFX
              Also
              x.x.x.0/24 für alle
              x.x.x.0/32 für 1
              NegaleinN
              NegaleinN
              Negalein
              ah, gecheckt
              und was bedeutet 0.0.0.0/0
              das finde ich bei Tante Goggerle nicht
                ah, gecheckt
                CrunkFXC
                CrunkFXC
                CrunkFX
                Forum Testing
                @negalein AllowedIPs = 0.0.0.0/0
                dadurch weist du den Wireguard-Client an, sämtlichen Verkehr über die VPN-Verbindung zu schicken. Wenn du nur den Zugriff zu einem Gerät zulassen möchtest, dann musst du dort nur die jeweiligen IP-Adressen eintragen, die über die Verbindung getunnelt werden sollen.
                Möglich ich m.E auch 192.168.1.2/32, das sollte auch gehen. Da beim 32er Subnet ohnehin nur ein Gerät angesprochen werden kann.
                • CrunkFXC CrunkFX
                  NegaleinN
                  NegaleinN
                  Negalein
                  ok, aber mit 0.0.0.0/0 hat er immer "schreibt er ungültiger Name" beim Import der .conf oder dem QR geschrieben.
                  Erst mit 10.0.1.0/24 gings.
                  Oder ist das mit "sämtlichen Verkehr über die VPN-Verbindung zu schicken" anders gemeint?
                    CrunkFXC
                    CrunkFXC
                    CrunkFX
                    Forum Testing
                    @negalein Ne eig. nicht, ich kann den Fehler auch nicht nachstellen
                    • CrunkFXC CrunkFX
                      @crunchip Ich habe einen Fehler in der Konfiguration entdeckt und in v1.0.1 behoben.
                      !!!AN ALLE DIE BEREITS EINEN CONTAINER NACH DIESER ANLEITUNG INSTALLIERT HABEN!!!
                      es hat sich leider natürlich ein Fehler in die Konfig geschlichen. Um nicht alles neu machen zu müssen führt bitte die Befehle nacheinander aus:
                      rm /root/50-unattended-upgrades && rm /root/docker-compose.yml && rm /root/wgui.path && rm /root/wgui.service && wg-quick down wg0 && wg-quick up wg0
                      Der Installer wird beim Update einen Error raushauen. Das ist OK
                      Ab hier könnt ihr alles nutzen. Wer den Fehler mit den verbundenen Sitzungen weghaben möchte, muss noch folgendes tun:
                      docker-compose up
                      und in der folgenden Error Nachricht die Container ID kopieren. (ohne "")
                      Und in dem nachfolgenden Befehl CONTAINERID durch die eben kopierte ID ersetzen
                      docker stop CONTAINERID
                      Sorry für den extraaufwand😰
                      crunchipC
                      crunchipC
                      Developer Global Moderator Most Active Forum Testing
                      docker-compose up
                      nachdem ich nun nochmals ab da probiert habe, kam nur noch error Meldung bzw hat ewig geladen.
                      Letztendlich habe ich nun den LXC neu aufgesetzt, mit der neuen Version, habe den CT wie beschrieben neu gestartet, trotzdem habe ich wieder einen leeren Status.
                        docker-compose up
                        CrunkFXC
                        CrunkFXC
                        CrunkFX
                        Forum Testing
                        @crunchip Was sagt der Befehl
                        wg
                        • CrunkFXC CrunkFX
                          wg
                          crunchipC
                          crunchipC
                          @crunkfx
                          interface: wg0
                            public key: kPKZIn5yubBiweatmmNo5mWhVhBFIVrA3Ko2ZQUY0Fk=
                            private key: (hidden)
                            listening port: 51820
                            @crunkfx
                            interface: wg0
                            CrunkFXC
                            CrunkFXC
                            CrunkFX
                            Forum Testing
                            @crunchip OK sehr gut. Zeig mal bitte den Output von
                            nano /root/wireguard-ui/docker-compose.yml
                            • CrunkFXC CrunkFX
                              crunchipC
                              crunchipC
                              @crunkfx ich bekomm aktuell aber auch keine Verbindung mehr zu stand, am Handy baut sich keine Seite mehr auf
                              version: '3'
                              services:
                                wg:
                                  image: ngoduykhanh/wireguard-ui:latest
                                  container_name: wgui
                                  ports:
                                    - 5000:5000
                                  logging:
                                    driver: json-file
                                    options:
                                      max-size: 50m
                                  volumes:
                                    - ./db:/app/db
                                    - /etc/wireguard:/etc/wireguard
                                  restart: always
                                  cap_add:
                                      - NET_ADMIN
                                  network_mode: host
                                version: '3'
                                services:
                                  wg:
                                    ports:
                                      - 5000:5000
                                    logging:
                                      driver: json-file
                                      options:
                                        max-size: 50m
                                    volumes:
                                      - ./db:/app/db
                                    restart: always
                                    cap_add:
                                        - NET_ADMIN
                                    network_mode: host
                                CrunkFXC
                                CrunkFXC
                                CrunkFX
                                Forum Testing
                                @crunchip Hast du daran gedacht?
                                Dazu im Fenster WireGuard Server unter dem Punkt Post Up Script folgendes eintragen:
                                iptables -A FORWARD -i %i -j ACCEPT; iptables -A FORWARD -o %i -j ACCEPT; iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
                                und um Feld Post Down Script folgendes eintragen:
                                iptables -D FORWARD -i %i -j ACCEPT; iptables -D FORWARD -o %i -j ACCEPT; iptables -t nat -D POSTROUTING -o eth0 -j MASQUERADE
                                • CrunkFXC CrunkFX
                                  crunchipC
                                  crunchipC
                                  @crunkfx ja die sind eingetragen
                                    CrunkFXC
                                    CrunkFXC
                                    CrunkFX
                                    Forum Testing
                                    @crunchip
                                    Nach der neuinstallation rebootet?
                                    Neuen Client angelegt und Apply Config gedrückt?
                                    Wenn ja zeig mal bitte
                                    ip a
                                    • CrunkFXC CrunkFX
                                      @crunchip
                                      ip a
                                      crunchipC
                                      crunchipC
                                      @crunkfx ja hatte ich
                                      1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                                          link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                                          inet 127.0.0.1/8 scope host lo
                                             valid_lft forever preferred_lft forever
                                          inet6 ::1/128 scope host
                                      2: eth0@if43: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
                                          link/ether fe:8b:dc:86:6e:51 brd ff:ff:ff:ff:ff:ff link-netnsid 0
                                          inet 10.1.1.21/24 brd 10.1.1.255 scope global eth0
                                          inet6 fe80::fc8b:dcff:fe86:6e51/64 scope link
                                      3: wg0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1450 qdisc mq state UNKNOWN group default qlen 500
                                          link/none
                                          inet 10.252.1.0/24 scope global wg0
                                          inet6 fe80::e128:9915:e0b1:325d/64 scope link stable-privacy
                                      4: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
                                          link/ether 02:42:e4:53:d0:58 brd ff:ff:ff:ff:ff:ff
                                          inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
                                      ich setz ihn einfach nochmal neu auf
                                      edit, hab ein zweites handy hinzugefügt, CT nochmal neu gestartet, Verbindung funktioniert wieder, Status bleibt aber dennoch leer
                                            link/none
                                        CrunkFXC
                                        CrunkFXC
                                        CrunkFX
                                        Forum Testing
                                        @crunchip Denk an Nesting und keyctl für Docker. Bevor du neuinstalliert versuch nochmal
                                        • CrunkFXC CrunkFX
                                          crunchipC
                                          crunchipC
                                          root@Wireguard:~# wg-quick down wg0 && wg-quick up wg0
                                          [#] ip link delete dev wg0
                                          [#] iptables -D FORWARD -i wg0 -j ACCEPT; iptables -D FORWARD -o wg0 -j ACCEPT; iptables -t nat -D POSTROUTING -o eth0 -j MASQUERADE
                                          [#] ip link add wg0 type wireguard
                                          Error: Unknown device type.
                                          Cannot find device "wg0"
                                          84.2k
