  4. Test Adapter HeatingControl v3.xx
heating
3.3k Beiträge 240 Kommentatoren 2.8m Aufrufe 203 Beobachtet
  • sigi234S sigi234
    @rene_hm sagte in Test Adapter HeatingControl v2.7.x:
    @sigi234 Heizperiode aus?
    Ist auch bei an so.
    Rene_HMR
    Rene_HMR
    Rene_HM
    #2426
    @sigi234 sagt das log irgendetwas?
    • Rene_HMR Rene_HM
      sigi234S
      sigi234S
      #2427
      atingcontrol.0
      2021-10-22 09:09:57.473	info	statemachine started
      heatingcontrol.0
      2021-10-22 09:09:57.061	info	start calculate current profile point for profile type 1 (Mo - Su)
      heatingcontrol.0
      2021-10-22 09:09:56.758	info	start calculate current profile point for profile type 1 (Mo - Su)
      heatingcontrol.0
      2021-10-22 09:09:56.756	info	calculate current profile point for all rooms
      heatingcontrol.0
      2021-10-22 09:09:56.755	info	checking external states done
      heatingcontrol.0
      2021-10-22 09:09:53.536	info	checking external states
      heatingcontrol.0
      2021-10-22 09:09:53.441	info	check all active sensors
      heatingcontrol.0
      heatingcontrol.0
      heatingcontrol.0
      2021-10-22 09:09:52.724	info	start statemachine
      heatingcontrol.0
      2021-10-22 09:09:52.570	warn	profil parameter vis limits: for homematic devices minimum value is 4.5°C, current is 1°C, please change settings in admin
      heatingcontrol.0
      2021-10-22 09:09:52.541	info	5 cron job(s) created
      heatingcontrol.0
      2021-10-22 09:09:51.462	info	start create cron jobs for profile type 1 (Mo - Su)
      heatingcontrol.0
      2021-10-22 09:09:51.454	info	subscribe devices done
      heatingcontrol.0
      2021-10-22 09:09:51.454	info	subscribe thermostats target 0
      heatingcontrol.0
      2021-10-22 09:09:51.454	info	subscribe thermostats current 0
      heatingcontrol.0
      2021-10-22 09:09:51.452	info	subscribe devices start
      heatingcontrol.0
      2021-10-22 09:09:51.451	info	subscribe hm-rpc.1.000A1D8997CC3E.1.PARTY_MODE
      heatingcontrol.0
      2021-10-22 09:09:51.451	info	subscribe fb-checkpresence.0.guest.presence
      heatingcontrol.0
      2021-10-22 09:09:51.450	info	subscribe fb-checkpresence.0.familyMembers.Home.presence
      heatingcontrol.0
      2021-10-22 09:09:51.443	info	SetCurrent done
      heatingcontrol.0
      2021-10-22 09:09:51.415	info	start SetCurrent
      heatingcontrol.0
      2021-10-22 09:09:51.415	info	SetInfo done
      heatingcontrol.0
      2021-10-22 09:09:51.388	info	start SetInfo
      heatingcontrol.0
      2021-10-22 09:09:51.145	info	CreateDatapoints done
      heatingcontrol.0
      2021-10-22 09:09:50.185	info	start CreateDatapoints
      heatingcontrol.0
      2021-10-22 09:09:50.183	info	CreateDatabase done with 2 rooms
      heatingcontrol.0
      2021-10-22 09:09:50.180	info	start CreateDatabase
      heatingcontrol.0
      2021-10-22 09:09:49.574	info	starting. Version 2.7.1 in C:/Program Files/iobroker/Home/node_modules/iobroker.heatingcontrol, node: v12.22.7, js-controller: 3.3.18
      heatingcontrol.0
      2021-10-22 09:09:44.610	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      heatingcontrol.0
      2021-10-22 09:09:44.609	info	terminating
      heatingcontrol.0
      2021-10-22 09:09:44.609	info	cleaned everything up...
      heatingcontrol.0
      2021-10-22 09:09:44.608	info	Got terminate signal TERMINATE_YOURSELF
      heatingcontrol.0
      2021-10-22 09:02:00.000	info	Change Status HeatingPeriodActive in Esszimmer to true
      heatingcontrol.0
      2021-10-22 09:01:59.864	info	Change Status HeatingPeriodActive in Bad to true
      Rene_HMR 1 Antwort Letzte Antwort
      • sigi234S sigi234
        atingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        heatingcontrol.0
        Rene_HMR
        Rene_HMR
        Rene_HM
        schrieb am zuletzt editiert von Rene_HM
        #2428
        @sigi234 stimmt die Konfiguration noch? laut log werden keine aktiven Sensoren, Aktoren oder Thermostate gefunden...
        • Rene_HMR Rene_HM
          sigi234S
          sigi234S
          #2429
          Danke, das war es.
          • Rene_HMR Rene_HM
            inspiriert vom Heizungsthermostat-Script und weil meine homeputer-Lizenz abgelaufen ist, und ich meine Heizungssteuerung von dort nach iobroker portieren wollte, ist der Adapter HeatingControl entstanden.
            Features:
            • setzen der Zieltemperatur in verschiedenen Thermostaten
            • beliebige Anzahl von täglichen Zeitabschnitten mit unterschiedlichen Zieltemperaturen
            • Zeit und Zieltemperatur per Visualisierung konfigurierbar
            • automatische Suche nach vorhandenen Thermostaten im System (über Gewerk) und Zuordnung zu Räumen
            • Für den Fall, dass der Thermostat nur als Thermometer verwendet wird, behandelt der Adapter auch digitale Outputs zum Schalten der Ventile. Im Moment ist dafür nur eine einfache Ein/Aus-Regelung implementiert (die für meine Zwecke ausreichend ist). Weitere Regelungen sind aber als Idee bereits vorhanden und können implementiert werden. Es gibt nun auch einen linearen on/off mit Hysterese
            • es werden bis zu zwei Outputs für Ventile unterstützt
            • Outputs werden auch automatisch den Räumen zugeordnet. Dafür müssen diese dem gleichen Gewerk wie Thermostate zugeordnet sein.
            • im Admin des Adapters können Räume deaktiviert werden
            • Absenkung bei Abwesenheit
            • Ventile ein oder aus außerhalb der Heizperiode
            • Verbindung zu ical
            • Verbindung zu Feiertags-Adapter
            • Senden von Nachrichten per email, Signal, Telegram, discord, ...
            • Kamin-Modus
            • Wartungsmodus
            • mehrere Profile
            • Tages-Programme für
              - Montag - Sonntag
              - Montag - Freitag + Samstag - Samstag
              - jeden Tag separat
            Versionen:
            • 3.0.0
              Status: beta seit 29.12.2025
              NPM: ja
              github: ja
              weitere Informationen: github
            • 2.12.19
              Status: stable seit 26.10.2025
              NPM: ja
              github: ja
            sigi234S
            sigi234S
            #2430
            @rene_hm
            Hallo, wo finde ich diese Einstellung?
            heatingcontrol.0
            2021-10-23 14:46:45.136 warn profil parameter vis limits: for homematic devices minimum value is 4.5°C, current is 1°C, please change settings in admin
            • sigi234S sigi234
              @rene_hm
              heatingcontrol.0
              Rene_HMR
              Rene_HMR
              Rene_HM
              #2431
              @sigi234 siehe hier:
              • E
                E
                eviltrooper
                #2432
                eventuell bin ich zu blöd.. aber
                ich habe 3 Personen im Haushalt die ich mittels TR-064 abfrage.
                jetzt muss ich mir ein Script bauen der mir einen Datenpunkt erstellt für Abwesend, da ich will das alle 3 weg sein müssen damit wir abwesend sind.
                soweit so "keine ahnung von Scripten" aber das ist ein anderes Problem..
                aber wo gebe ich den an auf was die Temperatur abgesenkt werden soll ?
                wenn ich im iobroker über Profiles ->1 -> room -> absolute..
                da gebe ich das pro Raum an?
                mehr ist es nicht?
                M Rene_HMR 2 Antworten Letzte Antwort
                • E eviltrooper
                  mehr ist es nicht?
                  M
                  M
                  Michi_Pi
                  #2433
                  @eviltrooper
                  Ja genau, in den Einstellungen auf absolut einstellen und in jedem Raum die jeweilige Temp eintragen
                  Wegen dem Skript hier mal eine Anregung, das ist jetzt nur für eine Person, aber da musst ja nur den Trigger und die Logik um die beiden weiteren ändern. Hab hier noch ein Timeout von 1h drinnen, weil wenn ich nur kurz Spazieren oder zum einkaufen fahre, braucht er die Heizung nicht runter fahren.
                  z.b. so
                  • E eviltrooper
                    mehr ist es nicht?
                    Rene_HMR
                    Rene_HMR
                    Rene_HM
                    #2434
                    @eviltrooper sagte in Test Adapter HeatingControl v2.7.x:
                    Man kann auch einen Zähler nutzen, der die Anwesenheiten zählt, der Adapter kann dann mit einem limit vergleichen:
                    ja genau, in den Einstellungen auf absolut einstellen
                    oder natürlich relativ, wenn man das Profil weiter fahren möchte, nur eben um x Grad abgesenkt...
                    • M
                      M
                      Michi_Pi
                      #2435
                      @Rene_HM
                      Hallo Rene, ich wollte eben diese Funktion nutzen, Profil speichern (was genau wird denn hier gespeichert? hab da auf die schnelle nichts gefunden)
                      Dabei bekomme ich einen Fehler. An was kann das liegen?
                      heatingcontrol.0 	2021-10-27 23:17:45.128	error	exception in SaveProfile [TypeError: Cannot read property 'val' of null]
                      • M Michi_Pi
                        @Rene_HM
                        Rene_HMR
                        Rene_HMR
                        Rene_HM
                        #2436
                        @michi_pi Es werde die Profildaten aus den Datenpunkten (also Anzahl, Zeit, Temperatur) pro Raum in eine json gespeichert. Das kann man als backup nutzen, um nicht die ganzen Einstellungen manuell machen zu müssen, falls man mal etwas verstellt hat.
                        Die Fehlermeldung sagt, dass beim Speichern irgendein Datenpunkt nicht gelesen werden kann, weil er nicht verfügbar ist. Ist jetzt schwer zu sagen, was da fehlt. Vielleicht versuchen wir es mal so:
                        • wie sieht die Profilkonfiguration bei dir aus? (Profiltype, Anzahl Perioden usw.)
                        • hier mal ein Beispiel, was gespeichert wird, vielleicht findest du damit, welcher Datenpunkt bei dir im Datenbaum nicht vorhanden ist, oder keinen Wert (null) anzeigt...
                          "ProfileType": "1",
                          "NumberOfProfiles": 1,
                          "NumberOfPeriods": 5,
                          "Rooms": {
                            "Küche": {
                              "profiles": {
                                "1": {
                                  "Mo_Su": {
                                    "1": {
                                      "time": "05:00",
                                      "Temperature": 21
                                    "2": {
                                      "time": "08:00",
                                      "Temperature": 23
                                    "3": {
                                      "time": "12:00",
                                      "Temperature": 22
                                    "4": {
                                      "time": "16:00",
                                      "Temperature": 21
                                    "5": {
                                      "time": "21:00",
                                      "Temperature": 19
                                  "decrease": {
                                    "GuestIncrease": 0,
                                    "PartyDecrease": 0,
                                    "WindowOpenDecrease": 0,
                                    "AbsentDecrease": 0,
                                    "VacationAbsentDecrease": 0,
                                    "FireplaceModeDecrease": 0
                          "TemperatureDecrease": 1
                        • Rene_HMR Rene_HM
                            "ProfileType": "1",
                            "Rooms": {
                              "Küche": {
                                "profiles": {
                                  "1": {
                                    "Mo_Su": {
                                      "1": {
                                        "time": "05:00",
                                        "Temperature": 21
                                      "2": {
                                        "time": "08:00",
                                        "Temperature": 23
                                      "3": {
                                        "time": "12:00",
                                        "Temperature": 22
                                      "4": {
                                        "time": "16:00",
                                        "Temperature": 21
                                      "5": {
                                        "time": "21:00",
                                        "Temperature": 19
                                    "decrease": {
                                      "GuestIncrease": 0,
                                      "PartyDecrease": 0,
                          M
                          M
                          Michi_Pi
                          #2437
                          @rene_hm okay, ja so hab ich mir das schon gedacht.
                          Meine Profilkonfiguration sieht so aus. Ich nutz halt 4 Perioden statt 5. Sonst ist es ähnlich
                          den FireplaceModeDecrease Datenpunkt habe ich nicht, aber den hab ich auch nicht aktiviert.
                          Und einen Datenpunkt mit "null" habe ich auch keinen gefunden.
                          • M Michi_Pi
                            Rene_HMR
                            Rene_HMR
                            Rene_HM
                            #2438
                            @michi_pi mit den Einstellungen habe ich die exception auch... Schau ich mir an....
                            • Rene_HMR Rene_HM
                              M
                              M
                              Michi_Pi
                              #2439
                              @rene_hm alles klar, danke
                              • U
                                U
                                UncleB
                                #2440
                                Morgen zusammen.
                                Kann mir jemand sagen wieso der Adapter den Wert von 03:00 Uhr anstrebt?
                                Wir haben es jetzt 09:30 eigentlich sollte der erste Wert 07:00 Uhr ziehen?
                                • U UncleB
                                  Morgen zusammen.
                                  Rene_HMR
                                  Rene_HMR
                                  Rene_HM
                                  #2441
                                  @uncleb weil die Reihenfolge der Perioden nicht stimmt! Du müsstest eigentlich eine Warnung im log bekommen, dass der Adapter nur zeitlich geordnete Perioden möchte...
                                  Dominik F.D U 2 Antworten Letzte Antwort
                                  • Rene_HMR Rene_HM
                                    Dominik F.D
                                    Dominik F.D
                                    Dominik F.
                                    #2442
                                    @rene_hm
                                    Ich habe mal eine generelle Frage zum Kaminmodus. Für welche Anwendungsfälle ist dieser bestimmt?
                                    Wenn ich meinen Kamin anmache, dann steigt die Temperatur ja an und die Ventile drehen nach dem Überschreiten der Solltemperatur ja eh zu. Mir ist nicht klar, wann der Kaminmodus genutzt werden kann.
                                    • Dominik F.D Dominik F.
                                      @rene_hm
                                      Rene_HMR
                                      Rene_HMR
                                      Rene_HM
                                      #2443
                                      @dominik-f es gibt zwei Anwenundungsfälle aus meiner Sicht:
                                      a) man schaltet auf Kamin-Modus bevor die Soll-Temperatur erreicht ist. Damit schalten die Ventile sofort aus. Wenn der Kamin dann später aus ist, schaltet der Adapter wieder auf normal, und man vergisst nicht, die evtl. erfolgte manuelle Abschaltung rückgängig zu machen.
                                      b) man schaltet auf Kaminmodus, um zu verhindern, dass die Ventile schliessen. Damit nutzt man z.Bsp. die Fußbodenheizung zur Aufnahme der Wärme und transportiert sie damit in andere Räume...
                                      • Rene_HMR
                                        Rene_HMR
                                        Rene_HM
                                        #2444
                                        Im github und NPM liegt die 2.7.2 zum Testen bereit.
                                        siehe auch github
                                        Es gibt folgende Änderungen:
                                        • bug fix load / save profiles: Kaminmodus hinzugefügt
                                        • im Falle von "Änderungen vom Thermostat als override übernehmen": bug fix reset override und Fenster-offen-Handling
                                        • Offset von den externen Sensoren wird zurückgestzt, wenn man das Feature oder einzelne Sensoren ausschaltet
                                        Feedback ist wie immer willkommen...
                                        Übrigens: ich suche support bei der Erstellung bzw. Update der Dokumentation. Bei Interesse bitte melden...
                                        • Rene_HMR Rene_HM
                                          Dominik F.D
                                          Dominik F.D
                                          Dominik F.
                                          #2445
                                          @rene_hm
                                          Dank dir für deine Erklärung
                                          84.2k
