  4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
    6.4k
bshbsh home connecthome connecthomeconnect adapter
1.4k Beiträge 202 Kommentatoren 688.6k Aufrufe 153 Beobachtet
  • oberfraggerO oberfragger
    @sigi234 @tombox Hatte bei der Initialisation der Instanz noch 2 Dinge. Lieber Github oder ist hier auch okay?
    homeconnect.0
    2021-08-13 23:11:55.954	warn	State value to set for "homeconnect.0.BOSCH-HSG636XS6-68A40E274810.programs.available.options.Cooking_Oven_Option_SetpointTemperature" has value "80" greater than max "70"
    homeconnect.0
    2021-08-13 23:11:42.450	warn	State value to set for "homeconnect.0.BOSCH-HSG636XS6-68A40E274810.programs.available.options.Cooking_Oven_Option_SetpointTemperature" has value "160" greater than max "120"
    sigi234S Online
    sigi234S Online
    #582
    @oberfragger
    Warte mal ab was @tombox sagt.
    oberfraggerO 1 Antwort Letzte Antwort
      homeconnect.0
      homeconnect.0
      Michi_Pi
      #583
      @oberfragger @tombox
      Ich habe diese Warnungen jetzt auch, nachdem ich alles upgedated habe auf Admin 5.
      homeconnect.0
      	2021-08-14 11:12:04.381	warn	State value to set for "homeconnect.0.SIEMENS-WM14VM40-68A40E370065.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "780" greater than max "null"
      homeconnect.0
      	2021-08-14 11:12:04.341	warn	State value to set for "homeconnect.0.SIEMENS-WM14VM40-68A40E370065.programs.active.options.BSH_Common_Option_ProgramProgress" has value "86" greater than max "null"
      homeconnect.0
      	2021-08-14 11:11:04.449	warn	State value to set for "homeconnect.0.SIEMENS-WM14VM40-68A40E370065.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "840" greater than max "null"
      homeconnect.0
      	2021-08-14 11:11:04.409	warn	State value to set for "homeconnect.0.SIEMENS-WM14VM40-68A40E370065.programs.active.options.BSH_Common_Option_ProgramProgress" has value "85" greater than max "null"
      homeconnect.0
      	2021-08-14 11:10:04.609	warn	State value to set for "homeconnect.0.SIEMENS-WM14VM40-68A40E370065.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "900" greater than max "null"
      homeconnect.0
      	2021-08-14 11:10:04.570	warn	State value to set for "homeconnect.0.SIEMENS-WM14VM40-68A40E370065.programs.active.options.BSH_Common_Option_ProgramProgress" has value "84" greater than max "null"
      homeconnect.0
      	2021-08-14 11:09:58.534	warn	State value to set for "homeconnect.0.SIEMENS-WM14VM40-68A40E370065.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "780" greater than max "null"
      homeconnect.0
      	2021-08-14 11:09:58.495	warn	State value to set for "homeconnect.0.SIEMENS-WM14VM40-68A40E370065.programs.active.options.BSH_Common_Option_ProgramProgress" has value "86" greater than max "null"
      homeconnect.0
      	2021-08-14 11:08:58.637	warn	State value to set for "homeconnect.0.SIEMENS-WM14VM40-68A40E370065.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "840" greater than max "null"
        tombox
        #584
        @michi_pi mal alle Objekte per Hand löschen und Adapter neustarten
        • T tombox
          Michi_Pi
          #585
          @tombox Danke, die Warnungen sind nun weg.
          • sigi234S sigi234
            @oberfragger
            oberfraggerO Offline
            oberfragger
            #586
            @sigi234 Er hat mich angeschrieben undich hab ihm mal das Log geliefert. Ich bin gespannt und hoffe da ist etwas sachdienliches dabei.
              dtp
              schrieb am zuletzt editiert von dtp
              #587
              Mal was anderes. Hat jemand von euch auch eine Waschmaschine von Siemens im Einsatz? Bei unserer iQ700 verabschiedet sich von Zeit zu Zeit die WLAN-Verbindung, so dass ich sie dann wieder per WPS-Taste an der FRITZ!Box neu einrichten muss. Es ist das einzige Gerät im gesamten WLAN, das ein Problem mit der dauerhaften WLAN-Verbindung hat. Kennt jemand das Problem?
              Unser Kaffeevollautomat und Geschirrspüler haben das Problem nicht.
              H 1 Antwort Letzte Antwort
              • D dtp
                holgerwolf
                #588
                @dtp Wir haben auch eine IQ700 (SN558S06TE) und da ist das WLAN stabil (eigentlich noch nie neu anlernen müssen). Ich habe da mal was mit Problemen bei Sonderzeichen bei der WLAN Anmeldung gehört...
                • H holgerwolf
                  dtp
                  #589
                  @holgerwolf Hm. Sonderzeichen habe ich weder in der SSID noch im WLAN-Passwort drin. Das kann's eigentlich nicht sein. Die Waschmaschine ist zusätzlich noch an einem HMIP Zwischenstecker mit Messfunktion angeschlossen. Eventuell liegt es daran. Allerdings schaltet der die Waschmaschine eigentlich nie aus.
                  • D dtp
                    Michi_Pi
                    #590
                    @dtp Hab auch eine IQ700 (WM14VM40) hatte da nur schwierigkeiten dass ich es überhaupt einmal ins Netz bekomme, weiß aber nicht mehr genau was das Problem war, glaub der konnte nicht nach Außen kommuniziern. Seither hatte ich keine Probleme mehr.
                      stenmic
                      #591
                      @tombox moin
                      ich hab jetzt mal den ioBroker frisch installiert, somit ist alles auf dem neusten Stand (node ist 12).
                      Der "stable" Adapter (0.0.36) bringt immer noch häufig Fehler:
                      Beim Systemstart kommt das:
                      Ich denke, die Probleme kommen mit dem Backofen, ist aber nur eine Vermutung.
                      Es werden wieder zwei Datenordner erstellt.
                      • D dtp
                        @Hiltex:
                        …aber was ich mit den Daten mache, weiß ich noch nicht. `
                        So geht's mir im Moment auch. Ich nutze die Home Connect App und IFTTT mit Siri zur Sprachsteuerung unseres Kaffeevollautomaten. Also, wenn ich z.B. sage "Hey Siri, mach Thorsten einen Cappuccino", dann macht mir die Maschine einen Cappuccino. Jetzt mag man sagen: "Wozu das Ganze? Man muss ja eh erst eine Tasse drunter stellen!". Ja, das ist korrekt, aber über Siri muss ich mich nicht mehr durch die Profile klicken. Ergo geht's schneller und die Taster halten länger. ;) Aber wie gesagt, das geht jetzt schon problemlos.
                        Aber vielleicht lasse ich das Licht über der Theke kurz blinken, wenn der Kaffee fertig ist. Denn die Home Connect App ist ein wenig nervig, wenn sie mir jedes Mal nach dem Kaffee ein simples "Bitteschön" schickt. Da könnte ich dann zusätzlich noch eine schönere Push-Nachricht per Pushover oder Telegram erzeugen. Für den Geschirrspüler entsprechend. Schaun mer mal.
                        Bis dann,
                        Thorsten
                        mctom
                        #592
                        @dtp
                        Welche Datenpunkte nutzt du für den Cappucino. Ich habe gefunden wie ich Menge, Temp und Stärke anpassen kann. Aber ich habe noch nicht den "Start" Datenpunkt gefunden.
                        Michael
                        • M mctom
                          @dtp
                          Michael
                          oberfragger
                          #593
                          @mctom Den hier einfach auf "true" setzen.
                          "_id": "homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.commands.BSH_Common_Command_ResumeProgram",
                          Gerade getestet.
                          Musst natürlich vorher hier
                          "_id": "homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.programs.selected.BSH_Common_Root_SelectedProgram",
                          deinen gewünschten Kaffee reinschreiben.
                          Würde ne Pause dazwischen setzen.
                          • Andreas WarschitzA Offline
                            Andreas Warschitz
                            #594
                            ich probiere schon seit Tagen den Adapter zum laufen bringen. Das Problem ist glaube ich das ich keine Aktivierung ULR bekomme. Die sollte sich laut Beschreibung ja selbst erstellen. Nur ich finde keine.
                            Andreas
                            • Andreas WarschitzA Andreas Warschitz
                              Andreas
                              tombox
                              #595
                              @andreas-warschitz zeit der log ein fehler?
                                Andreas Warschitz
                                #596
                                  tombox
                                  #597
                                  @andreas-warschitz Es könnte die client id falsch sein einfach nochmal erstellen
                                    Andreas Warschitz
                                    #598
                                    was Sollich hier für eine Url eingeben ?
                                    Gruß Andreas
                                      Gruß Andreas
                                      tombox
                                      #599
                                      @andreas-warschitz redirect url gibt es bei device flow nicht
                                        Andreas Warschitz
                                        #600
                                        Falsche Einstellungen jetzt funktioniert es Dankeschön
                                        Andreas
                                        • ? Offline
                                          #601
                                          Ich habe eine Siemens IQ300 Spülmaschine. Diese ist im BSH Adapter hinterlegt und es funktionierte bis heute einwandfrei. Nun habe ich das Problem das nachdem die Maschine gestartet wurde, der Adapter ca.7 min lang alle Daten vom Home Connect Server empfängt (Laut Zeitstempel) doch danach verändert sich kein Wert mehr. Aufgefallen ist mir das weil die Spülmaschine mit der App von Home Connect funktioniert und bescheid sagt wenn das Programm durch ist, aber unter dem DatenPunkt im Adapter immer 7% Programmfortschritt steht.( Hatte mich halt gewundert warum keine Benachrichtigung mehr über Alexa kam)
                                          • Ich habe kein Update durchgeführt
                                          • Der Iobroker hat Admin 5.1.23
                                          • BSH Adapter hat die Version 0.0.36
                                          • Im Log finde ich keine Warnungen
                                          • Den Adapter habe ich mehrfach neu gestartet.
                                          • Spülmaschine 3x durchlaufen lassen. Keine Änderungen.
                                          Hat jemand einen Tipp wo ich anfangen könnte zu suchen?
