  4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
    6.4k
bshbsh home connecthome connecthomeconnect adapter
1.4k Beiträge 202 Kommentatoren 688.7k Aufrufe 153 Beobachtet
  • sigi234S sigi234
    @oberfragger
    Das muss sich @tombox mal ansehen.
    oberfraggerO Offline
    oberfragger
    schrieb am zuletzt editiert von oberfragger
    #581
    @sigi234 @tombox Hatte bei der Initialisation der Instanz noch 2 Dinge. Lieber Github oder ist hier auch okay?
    homeconnect.0
    2021-08-13 23:11:55.954	warn	State value to set for "homeconnect.0.BOSCH-HSG636XS6-68A40E274810.programs.available.options.Cooking_Oven_Option_SetpointTemperature" has value "80" greater than max "70"
    homeconnect.0
    2021-08-13 23:11:42.450	warn	State value to set for "homeconnect.0.BOSCH-HSG636XS6-68A40E274810.programs.available.options.Cooking_Oven_Option_SetpointTemperature" has value "160" greater than max "120"
    sigi234S M 2 Antworten Letzte Antwort
    • oberfraggerO oberfragger
      homeconnect.0
      homeconnect.0
      sigi234S Online
      sigi234S Online
      #582
      @oberfragger
      Warte mal ab was @tombox sagt.
      oberfraggerO 1 Antwort Letzte Antwort
        homeconnect.0
        homeconnect.0
        Michi_Pi
        #583
        @oberfragger @tombox
        Ich habe diese Warnungen jetzt auch, nachdem ich alles upgedated habe auf Admin 5.
        homeconnect.0
        	2021-08-14 11:12:04.381	warn	State value to set for "homeconnect.0.SIEMENS-WM14VM40-68A40E370065.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "780" greater than max "null"
        homeconnect.0
        	2021-08-14 11:12:04.341	warn	State value to set for "homeconnect.0.SIEMENS-WM14VM40-68A40E370065.programs.active.options.BSH_Common_Option_ProgramProgress" has value "86" greater than max "null"
        homeconnect.0
        	2021-08-14 11:11:04.449	warn	State value to set for "homeconnect.0.SIEMENS-WM14VM40-68A40E370065.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "840" greater than max "null"
        homeconnect.0
        	2021-08-14 11:11:04.409	warn	State value to set for "homeconnect.0.SIEMENS-WM14VM40-68A40E370065.programs.active.options.BSH_Common_Option_ProgramProgress" has value "85" greater than max "null"
        homeconnect.0
        	2021-08-14 11:10:04.609	warn	State value to set for "homeconnect.0.SIEMENS-WM14VM40-68A40E370065.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "900" greater than max "null"
        homeconnect.0
        	2021-08-14 11:10:04.570	warn	State value to set for "homeconnect.0.SIEMENS-WM14VM40-68A40E370065.programs.active.options.BSH_Common_Option_ProgramProgress" has value "84" greater than max "null"
        homeconnect.0
        	2021-08-14 11:09:58.534	warn	State value to set for "homeconnect.0.SIEMENS-WM14VM40-68A40E370065.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "780" greater than max "null"
        homeconnect.0
        	2021-08-14 11:09:58.495	warn	State value to set for "homeconnect.0.SIEMENS-WM14VM40-68A40E370065.programs.active.options.BSH_Common_Option_ProgramProgress" has value "86" greater than max "null"
        homeconnect.0
        	2021-08-14 11:08:58.637	warn	State value to set for "homeconnect.0.SIEMENS-WM14VM40-68A40E370065.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "840" greater than max "null"
          tombox
          #584
          @michi_pi mal alle Objekte per Hand löschen und Adapter neustarten
          • T tombox
            Michi_Pi
            #585
            @tombox Danke, die Warnungen sind nun weg.
            • sigi234S sigi234
              @oberfragger
              oberfragger
              #586
              @sigi234 Er hat mich angeschrieben undich hab ihm mal das Log geliefert. Ich bin gespannt und hoffe da ist etwas sachdienliches dabei.
                dtp
                schrieb am zuletzt editiert von dtp
                #587
                Mal was anderes. Hat jemand von euch auch eine Waschmaschine von Siemens im Einsatz? Bei unserer iQ700 verabschiedet sich von Zeit zu Zeit die WLAN-Verbindung, so dass ich sie dann wieder per WPS-Taste an der FRITZ!Box neu einrichten muss. Es ist das einzige Gerät im gesamten WLAN, das ein Problem mit der dauerhaften WLAN-Verbindung hat. Kennt jemand das Problem?
                Unser Kaffeevollautomat und Geschirrspüler haben das Problem nicht.
                H 1 Antwort Letzte Antwort
                • D dtp
                  holgerwolf
                  #588
                  @dtp Wir haben auch eine IQ700 (SN558S06TE) und da ist das WLAN stabil (eigentlich noch nie neu anlernen müssen). Ich habe da mal was mit Problemen bei Sonderzeichen bei der WLAN Anmeldung gehört...
                  • H holgerwolf
                    dtp
                    #589
                    @holgerwolf Hm. Sonderzeichen habe ich weder in der SSID noch im WLAN-Passwort drin. Das kann's eigentlich nicht sein. Die Waschmaschine ist zusätzlich noch an einem HMIP Zwischenstecker mit Messfunktion angeschlossen. Eventuell liegt es daran. Allerdings schaltet der die Waschmaschine eigentlich nie aus.
                    • D dtp
                      Michi_Pi
                      #590
                      @dtp Hab auch eine IQ700 (WM14VM40) hatte da nur schwierigkeiten dass ich es überhaupt einmal ins Netz bekomme, weiß aber nicht mehr genau was das Problem war, glaub der konnte nicht nach Außen kommuniziern. Seither hatte ich keine Probleme mehr.
                        stenmic
                        #591
                        @tombox moin
                        ich hab jetzt mal den ioBroker frisch installiert, somit ist alles auf dem neusten Stand (node ist 12).
                        Der "stable" Adapter (0.0.36) bringt immer noch häufig Fehler:
                        Beim Systemstart kommt das:
                        Ich denke, die Probleme kommen mit dem Backofen, ist aber nur eine Vermutung.
                        Es werden wieder zwei Datenordner erstellt.
                        • D dtp
                          @Hiltex:
                          …aber was ich mit den Daten mache, weiß ich noch nicht. `
                          So geht's mir im Moment auch. Ich nutze die Home Connect App und IFTTT mit Siri zur Sprachsteuerung unseres Kaffeevollautomaten. Also, wenn ich z.B. sage "Hey Siri, mach Thorsten einen Cappuccino", dann macht mir die Maschine einen Cappuccino. Jetzt mag man sagen: "Wozu das Ganze? Man muss ja eh erst eine Tasse drunter stellen!". Ja, das ist korrekt, aber über Siri muss ich mich nicht mehr durch die Profile klicken. Ergo geht's schneller und die Taster halten länger. ;) Aber wie gesagt, das geht jetzt schon problemlos.
                          Aber vielleicht lasse ich das Licht über der Theke kurz blinken, wenn der Kaffee fertig ist. Denn die Home Connect App ist ein wenig nervig, wenn sie mir jedes Mal nach dem Kaffee ein simples "Bitteschön" schickt. Da könnte ich dann zusätzlich noch eine schönere Push-Nachricht per Pushover oder Telegram erzeugen. Für den Geschirrspüler entsprechend. Schaun mer mal.
                          Bis dann,
                          Thorsten
                          mctom
                          #592
                          @dtp
                          Welche Datenpunkte nutzt du für den Cappucino. Ich habe gefunden wie ich Menge, Temp und Stärke anpassen kann. Aber ich habe noch nicht den "Start" Datenpunkt gefunden.
                          Michael
                          • M mctom
                            @dtp
                            Michael
                            oberfragger
                            #593
                            @mctom Den hier einfach auf "true" setzen.
                            "_id": "homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.commands.BSH_Common_Command_ResumeProgram",
                            Gerade getestet.
                            Musst natürlich vorher hier
                            "_id": "homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.programs.selected.BSH_Common_Root_SelectedProgram",
                            deinen gewünschten Kaffee reinschreiben.
                            Würde ne Pause dazwischen setzen.
                            • Andreas WarschitzA Offline
                              Andreas Warschitz
                              #594
                              ich probiere schon seit Tagen den Adapter zum laufen bringen. Das Problem ist glaube ich das ich keine Aktivierung ULR bekomme. Die sollte sich laut Beschreibung ja selbst erstellen. Nur ich finde keine.
                              Andreas
                              • Andreas WarschitzA Andreas Warschitz
                                Andreas
                                tombox
                                #595
                                @andreas-warschitz zeit der log ein fehler?
                                  Andreas Warschitz
                                  #596
                                    tombox
                                    #597
                                    @andreas-warschitz Es könnte die client id falsch sein einfach nochmal erstellen
                                      Andreas Warschitz
                                      #598
                                      was Sollich hier für eine Url eingeben ?
                                      Gruß Andreas
                                        Gruß Andreas
                                        tombox
                                        #599
                                        @andreas-warschitz redirect url gibt es bei device flow nicht
                                          Andreas Warschitz
                                          #600
                                          Falsche Einstellungen jetzt funktioniert es Dankeschön
                                          Andreas
