7.6k Beiträge 296 Kommentatoren 9.0m Aufrufe 201 Beobachtet
  • B BenGreenHigh
    @s-bormann Danke für Deine schnelle Antwort. Ich nutze alle Geräte über Alias, daher die Datenpunkte vom Original und vom Alias:
    Und die Raws:
      "type": "state",
      "common": {
        "role": "level",
        "read": true,
        "write": true,
        "name": "Thermostat mode",
        "type": "number",
        "min": 0,
        "max": 255,
        "states": {
          "0": "Off",
          "1": "Heat",
          "2": "Cool",
          "3": "Auto",
          "4": "Auxiliary",
          "5": "Resume (on)",
          "6": "Fan",
          "7": "Furnace",
          "8": "Dry",
          "9": "Moist",
          "10": "Auto changeover",
          "11": "Energy heat",
          "12": "Energy cool",
          "13": "Away",
          "15": "Full power",
          "31": "Manufacturer specific"
        "custom": {
          "iqontrol.0": {
            "enabled": true,
            "readonly": false,
            "invert": false,
            "confirm": false,
            "pincode": "",
            "unit": "",
            "unit_zero": "",
            "unit_one": "",
            "min": 0,
            "max": 15,
            "step": "",
            "type": "number",
            "role": "level",
            "targetValueId": "",
            "states": {
              "0": "Off",
              "1": "Heat",
              "15": "Full power"
            "statesAddInput": false,
            "statesAddInputCaption": "Enter other value...",
            "showOnlyTargetValues": false,
            "roundDigits": 2,
            "timeFormat": "x",
            "timeDisplayFormat": "dddd, DD.MM.YYYY HH:mm:ss",
            "targetValues": ""
      "native": {
        "nodeId": 184,
        "valueId": {
          "commandClass": 64,
          "endpoint": 0,
          "property": "mode"
      "_id": "zwave2.0.Node_184.Thermostat_Mode.mode",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
      "from": "system.adapter.zwave2.0",
      "user": "system.user.admin",
      "ts": 1629217985759
      "type": "state",
      "common": {
        "role": "level",
        "type": "number",
        "max": 255,
        "read": true,
        "write": true,
        "alias": {
          "id": "zwave2.0.Node_184.Thermostat_Mode.mode"
        "custom": {
          "iqontrol.0": {
            "0": "",
            "1": "",
            "2": "",
            "enabled": true,
            "invert": false,
            "confirm": false,
            "pincode": "",
            "step": "",
            "roundDigits": 2,
            "timeFormat": "x",
            "readonly": false,
            "unit": "",
            "unit_zero": "",
            "unit_one": "",
            "min": "",
            "max": 15,
            "type": "number",
            "role": "level",
            "targetValues": "",
            "states": {
              "0": "Aus",
              "1": "Heizen",
              "11": "Absenkung",
              "15": "Boost"
      "_id": "alias.0.DG.Thermostat_Büro.mode",
      "native": {},
      "acl": {
        "object": 1636,
        "state": 1636,
      "ts": 1627836377756
    Genutzt wind in iQontrol und Skripten nur der Alias.
    LG
    s.bormannS
    s.bormannS
    s.bormann
    #5764
    @bengreenhigh sagte in Test Adapter iQontrol 1.9.x Vis:
    Und die Raws:
      "type": "state",
      "common": {
        "role": "level",
        "read": true,
        "write": true,
        "type": "number",
        "min": 0,
        "max": 255,
        "states": {
          "0": "Off",
          "1": "Heat",
          "2": "Cool",
          "3": "Auto",
          "4": "Auxiliary",
          "5": "Resume (on)",
          "6": "Fan",
          "7": "Furnace",
          "8": "Dry",
          "9": "Moist",
          "13": "Away",
          "15": "Full power",
        "custom": {
          "iqontrol.0": {
            "enabled": true,
            "readonly": false,
            "invert": false,
            "confirm": false,
            "pincode": "",
            "unit": "",
            "unit_zero": "",
            "unit_one": "",
            "min": 0,
            "max": 15,
            "step": "",
            "type": "number",
            "role": "level",
            "states": {
              "0": "Off",
              "1": "Heat",
              "15": "Full power"
            "roundDigits": 2,
            "timeFormat": "x",
            "targetValues": ""
      "native": {
        "nodeId": 184,
        "valueId": {
          "commandClass": 64,
          "endpoint": 0,
          "property": "mode"
      "acl": {
        "object": 1636,
        "state": 1636,
      "ts": 1629217985759
      "type": "state",
      "common": {
        "role": "level",
        "type": "number",
        "max": 255,
        "read": true,
        "write": true,
        "alias": {
        "custom": {
          "iqontrol.0": {
            "0": "",
            "1": "",
            "2": "",
            "enabled": true,
            "invert": false,
            "confirm": false,
            "pincode": "",
            "step": "",
            "roundDigits": 2,
            "timeFormat": "x",
            "readonly": false,
            "unit": "",
            "unit_zero": "",
            "unit_one": "",
            "min": "",
            "max": 15,
            "type": "number",
            "role": "level",
            "targetValues": "",
            "states": {
              "0": "Aus",
              "1": "Heizen",
              "11": "Absenkung",
              "15": "Boost"
      "native": {},
      "acl": {
        "object": 1636,
        "state": 1636,
      "ts": 1627836377756
    LG
    Probier mal diese custom-settings im RAW des Alias. Damit hats bei mir funktioniert (als Thermostat, nicht als Homematic-Thermostat).
        "custom": {
          "iqontrol.0": {
            "0": "",
            "1": "",
            "2": "",
            "enabled": true,
            "invert": false,
            "confirm": false,
            "pincode": "",
            "step": "",
            "roundDigits": 2,
            "timeFormat": "x",
            "timeDisplayDontShowDistance": false,
            "readonly": false,
            "unit": "",
            "unit_zero": "",
            "unit_one": "",
            "min": 0,
            "max": 255,
            "type": "string",
            "role": "state",
            "targetValues": "",
            "states": {
              "0": "Aus",
              "1": "Heizen",
              "11": "Absenkung",
              "15": "Boost"
    • C
      C
      Cino
      #5765
      Ich versuche gerade meine Visu gegen aussen abzudichten. Gibt es eine elegante Lösung für einen Anmeldebildschirm?
      IOB@RPI4
      Shelly, Zigbee, ebus
      • S
        S
        sandro_gera
        #5766
        Hallo an alle,
        ich habe gerade all meine Datenpunkte in iQontrol auf Alias umgestellt.
        Seitdem wird mir zwar der Status aller Geräte richtig angezeigt, aber ich kann die Geräte nicht mehr aus oder einschaten.
        Auch wenn ich wieder zurück auf die Originalen Datenpunkte gehe funktioniert es nicht.
        Den Adapter habe ich schon neu gestartet.
        Hat jeman eine Idee was ich noch machen kann?
        Master RPI4 8GB, Slave RPI3 1GB
        Node.js v18.17.1, npm: 9.6.7,
        JS-Controller: 5.0.16
        • S sandro_gera
          Hallo an alle,
          dslraserD
          dslraserD
          dslraser
          #5767
          @sandro_gera
          Vielleicht das hier
          https://forum.iobroker.net/post/665313
          • dslraserD dslraser
            @sandro_gera
            Vielleicht das hier
            S
            S
            sandro_gera
            schrieb am zuletzt editiert von sandro_gera
            #5768
            @dslraser said in Test Adapter iQontrol 1.9.x Vis:
            @sandro_gera
            Vielleicht das hier
            Die Typen steht richtig als Schater oder Licht drin.
            Es ist ja auch nicht nur ein oder 2 Geräte. Es betrifft alle.
            • S sandro_gera
              @sandro_gera
              Vielleicht das hier
              dslraserD
              dslraserD
              dslraser
              #5769
              @sandro_gera sagte in Test Adapter iQontrol 1.9.x Vis:
              Der Typ im RAW ist aber nicht Schalter oder Licht, sondern z.B. boolean oder sowas
              Beispiel einer meiner alias
                "type": "state",
                "common": {
                  "name": "Badezimmer links",
                  "read": true,
                  "write": true,
                  "type": "boolean",
                  "role": "switch.light",
                  "alias": {
                    "id": "hue.0.Badezimmerlampe_links.on"
                  "desc": "per Script erstellt",
                  "states": {
                    "false": "aus",
                    "true": "an"
                  "smartName": false
                "native": {},
                "from": "system.adapter.javascript.0",
                "ts": 1607784693476,
                "_id": "alias.0.Licht.Badezimmer_Licht_links",
                "acl": {
                  "object": 1636,
                  "state": 1636,
              S 2 Antworten Letzte Antwort
                  "type": "state",
                  "common": {
                    "read": true,
                    "write": true,
                    "type": "boolean",
                    "alias": {
                    "states": {
                      "false": "aus",
                      "true": "an"
                    "smartName": false
                  "native": {},
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                S
                S
                sandro_gera
                #5770
                  "type": "state",
                  "common": {
                    "read": true,
                    "write": true,
                    "type": "boolean",
                    "alias": {
                    "states": {
                      "false": "aus",
                      "true": "an"
                    "smartName": false
                  "native": {},
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                So sieht das bei mir aus
                  "type": "state",
                  "common": {
                    "name": "Wandlampe-Arbeitszimmer",
                    "type": "boolean",
                    "read": true,
                    "write": true,
                    "smartName": {
                      "de": "Wandlampe Arbeitszimmer",
                      "ghType": "action.devices.types.LIGHT",
                      "ghTraits": [
                        "action.devices.traits.OnOff"
                      "ghAttributes": "{\n            \"commandOnlyOnOff\": false\n          }",
                      "smartType": "LIGHT"
                    "alias": {
                      "id": "deconz.0.Lights.28.on"
                    "states": {
                      "false": "aus",
                      "true": "an"
                  "native": {},
                  "from": "system.adapter.iot.0",
                  "ts": 1622803724566,
                  "_id": "alias.0.Licht.Arbeitszimmer.Wandlampe_Arbeitszimmer",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                • S sandro_gera
                    "type": "state",
                    "common": {
                      "read": true,
                      "write": true,
                      "type": "boolean",
                      "alias": {
                      "states": {
                        "false": "aus",
                        "true": "an"
                      "smartName": false
                    "native": {},
                    "acl": {
                      "object": 1636,
                      "state": 1636,
                    "type": "state",
                    "common": {
                      "type": "boolean",
                      "read": true,
                      "write": true,
                      "smartName": {
                        "ghTraits": [
                      "alias": {
                      "states": {
                        "false": "aus",
                        "true": "an"
                    "native": {},
                    "acl": {
                      "object": 1636,
                      "state": 1636,
                  dslraserD
                  dslraserD
                  dslraser
                  #5771
                  @sandro_gera
                  nach dem alias erstellen am Besten mal admin neu starten. Achtung: nicht stoppen, sondern nur neu starten !
                  damit
                  S 3 Antworten Letzte Antwort
                    @sandro_gera
                    damit
                    S
                    S
                    sandro_gera
                    #5772
                    @sandro_gera
                    damit
                    Danke das versuche ich mal. Aber ich habe die Aliasse ja nicht neu erstellt.
                    Ich habe nur von den Original Datenpunkten auf die aliasse umgestellt.
                      @sandro_gera
                      damit
                      S
                      S
                      sandro_gera
                      #5773
                      @sandro_gera
                      damit
                      Der Neustart des Admin hat auch nicht gebracht. Ich versuche jetzt mal den kompletten Raspberry neu zu starten.
                        @sandro_gera
                        damit
                        S
                        S
                        sandro_gera
                        #5774
                        @sandro_gera
                        damit
                        Neustart des Raspberry war auch erfolglos. Jetzt kann ich nur noch versuchen über backitup alles wieder zurück zu setzten, aber das ist ja eigentlich nicht ziehlführend.
                            "type": "state",
                            "common": {
                              "read": true,
                              "write": true,
                              "type": "boolean",
                              "alias": {
                              "states": {
                                "false": "aus",
                                "true": "an"
                              "smartName": false
                            "native": {},
                            "acl": {
                              "object": 1636,
                              "state": 1636,
                          S
                          S
                          sandro_gera
                          #5775
                            "type": "state",
                            "common": {
                              "read": true,
                              "write": true,
                              "type": "boolean",
                              "alias": {
                              "states": {
                                "false": "aus",
                                "true": "an"
                              "smartName": false
                            "native": {},
                            "acl": {
                              "object": 1636,
                              "state": 1636,
                          Am Alias selbst kann es meiner Meinung nach nicht liegen, wenn ich den Wert im IO-broker unter objekten manuell ändere funktioniert alles wie immer auch Alexa funktioniert wie immer.
                          • S sandro_gera
                              "type": "state",
                              "common": {
                                "read": true,
                                "write": true,
                                "type": "boolean",
                                "alias": {
                                "states": {
                                  "false": "aus",
                                  "true": "an"
                                "smartName": false
                              "native": {},
                              "acl": {
                                "object": 1636,
                                "state": 1636,
                            s.bormannS
                            s.bormannS
                            s.bormann
                            #5776
                            @sandro_gera Was sagt die Entwicklerkosole beim Schalten?
                            Im zweiten Absatz wird beschrieben, wie man ein Log des Fehlers erzeugt und welche Screenshots für die weitere Analyse notwendig sind:
                            https://github.com/sbormann/ioBroker.iqontrol#troubleshooting
                            Vielen Dank!
                            • s.bormannS s.bormann
                              Vielen Dank!
                              S
                              S
                              sandro_gera
                              #5777
                              @s-bormann said in Test Adapter iQontrol 1.9.x Vis:
                              Vielen Dank!
                              viewDeviceContextMenu start via TOUCHSTART/MOUSEDOWN
                              index.js:7236 viewDeviceContextMenu start function
                              index.js:4036 toolbarContextMenu end function
                              index.js:4041 toolbarContextMenu end function - find active Toolbar Index
                              index.js:7258 viewDeviceContextMenu level: -0.18750000000000003
                              index.js:7258 viewDeviceContextMenu level: -0.125
                              index.js:7258 viewDeviceContextMenu level: -0.062499999999999986
                              index.js:7245 viewDeviceContextMenu ignore click ended after 100ms
                              index.js:7258 viewDeviceContextMenu level: 0
                              index.js:3986 toolbarContextMenu end via TOUCHEND/MOUSEUP
                              index.js:7224 viewDeviceContextMenu end via TOUCHEND/MOUSEUP
                              index.js:7276 viewDeviceContextMenu end function
                              translate.js:24 "aus": {"en": "aus", "de": "aus", "ru": "aus", "pt": "aus", "nl": "aus", "fr": "aus"},
                              index.js:7208 viewDeviceContextMenu device CLICK TOGGLE
                              2index.js:4055 toolbarContextMenu end function - end ignoreStart
                              2index.js:7281 viewDeviceContextMenu end function - end ignoreStart
                              Hilft die das weiter oder hab ich da was falsch gemacht?
                                Vielen Dank!
                                S
                                S
                                sandro_gera
                                #5778
                                Vielen Dank!
                                	if (!dontEndIgnoreStart) setTimeout(function(){
                                		console.log("toolbarContextMenu end function - end ignoreStart");
                                		toolbarContextMenuIgnoreStart = false;
                                		toolbarContextMenuIgnoreClick = false;
                                function viewDeviceContextMenuEnd(dontEndIgnoreStart){
                                	console.log("viewDeviceContextMenu end function");
                                	viewDeviceContextMenuIgnoreStart = true;
                                	$('.iQontrolDevicePressureIndicator').css('box-shadow', '0px 0px 0px 0px rgba(175,175,175,0.85)');
                                	if(viewDeviceContextMenuInterval) clearInterval(viewDeviceContextMenuInterval);
                                		console.log("viewDeviceContextMenu end function - end ignoreStart");
                                		viewDeviceContextMenuIgnoreStart = false;
                                		viewDeviceContextMenuIgnoreClick = false;
                                	}, 300);
                                  Auf Github gibt es eine neue Test-Version.
                                  • @verkel @evolvo187 Es gibt jetzt endlich die Möglichkeit, bei den ADDITIONAL_CONTROLS die Steuerelemente auf die Hälfte der Breite zu verkleinern und sie damit nebeneinander anordnen zu können:
                                    8314fa68-e203-4a1c-bbd5-21469444484f-image.png führt zu:
                                  • @eMd Der Schrift-Upload wurde noch mal angepasst. Bitte teste mal, ob es jetzt geht (ehrlichgesagt habe ich den Fehler nicht ganz kapiert - habs einfach etwas umgeschrieben und hoffe, dass das besser funktioniert)
                                  • @muuulle Widgets können jetzt auf den Dark-Mode zugreifen. Beim JSON-Table-Widget habe ich das implementiert. Im Wiki steht, wie es geht: https://github.com/sbormann/ioBroker.iqontrol/wiki/Übernehmen-der-Dark-Mode-Einstellungen-in-Widgets
                                  Insgesamt viele Baustellen, Fehler sind also nicht ausgeschlossen - ich freue mich auf Rückmeldungen!
                                  VG!
                                  JLegJ
                                  JLegJ
                                  JLeg
                                  #5779
                                  @s-bormann sagte in Test Adapter iQontrol 1.9.x Vis:
                                  Hm, bei mir tut sich da irgendwie nix (V1.9.3) - alle "additional controls" haben die Checkbox angekreuzt, aber "halbweit" wird's nicht (Typ "Popup"):
                                  • JLegJ JLeg
                                    s.bormannS
                                    s.bormannS
                                    s.bormann
                                    #5780
                                    @jleg sagte in Test Adapter iQontrol 1.9.x Vis:
                                    Bei mir gings nach einem Hard-Reload (Cache löschen) :)
                                    JLegJ 1 Antwort Letzte Antwort
                                      JLegJ
                                      JLegJ
                                      JLeg
                                      #5781
                                      boa, wie "hard" muss der Reload denn sein? ;-) - yay, geht nun, aber erst nach Stop/Start von iqontrol- und web-Instanz (vorher shift-Reload, F5, Ctrl-F5 probiert, no avail)
                                      Und jetzt hab' ich auch plötzlich "Dark mode" :) - aber ein "read-only"-Status-Bar sieht nun bissel verrutscht aus:
                                      • JLegJ JLeg
                                        s.bormannS
                                        s.bormannS
                                        s.bormann
                                        #5782
                                        Danke, Fix kommt :)
                                        M JLegJ 2 Antworten Letzte Antwort
                                          Danke, Fix kommt :)
                                          M
                                          M
                                          muuulle
                                          schrieb am zuletzt editiert von muuulle
                                          #5783
                                          @s-bormann
                                          Kann man eigentlich Überschriften mittels Datenpunkten variabel füttern?! 🤔 Bei Gerätenamen geht es ja…
                                          33.2k
                                          84.3k
