    6.5k
7.6k Beiträge 296 Kommentatoren 7.8m Aufrufe 201 Beobachtet
  • dslraserD dslraser
    @sandro_gera sagte in Test Adapter iQontrol 1.9.x Vis:
    Die Typen steht richtig als Schater oder Licht drin.
    Der Typ im RAW ist aber nicht Schalter oder Licht, sondern z.B. boolean oder sowas
    Beispiel einer meiner alias
      "type": "state",
      "common": {
        "name": "Badezimmer links",
        "read": true,
        "write": true,
        "type": "boolean",
        "role": "switch.light",
        "alias": {
          "id": "hue.0.Badezimmerlampe_links.on"
        "desc": "per Script erstellt",
        "states": {
          "false": "aus",
          "true": "an"
        "smartName": false
      "native": {},
      "from": "system.adapter.javascript.0",
      "user": "system.user.admin",
      "ts": 1607784693476,
      "_id": "alias.0.Licht.Badezimmer_Licht_links",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
    sandro_gera
    #5770
    @dslraser said in Test Adapter iQontrol 1.9.x Vis:
      "type": "state",
      "common": {
        "read": true,
        "write": true,
        "type": "boolean",
        "alias": {
        "states": {
          "false": "aus",
          "true": "an"
        "smartName": false
      "native": {},
      "acl": {
        "object": 1636,
        "state": 1636,
    So sieht das bei mir aus
      "type": "state",
      "common": {
        "name": "Wandlampe-Arbeitszimmer",
        "type": "boolean",
        "read": true,
        "write": true,
        "smartName": {
          "de": "Wandlampe Arbeitszimmer",
          "ghType": "action.devices.types.LIGHT",
          "ghTraits": [
            "action.devices.traits.OnOff"
          "ghAttributes": "{\n            \"commandOnlyOnOff\": false\n          }",
          "smartType": "LIGHT"
        "alias": {
          "id": "deconz.0.Lights.28.on"
        "states": {
          "false": "aus",
          "true": "an"
      "native": {},
      "from": "system.adapter.iot.0",
      "ts": 1622803724566,
      "_id": "alias.0.Licht.Arbeitszimmer.Wandlampe_Arbeitszimmer",
      "acl": {
        "object": 1636,
        "state": 1636,
    Master RPI4 8GB, Slave RPI3 1GB
    Node.js v18.17.1, npm: 9.6.7,
    JS-Controller: 5.0.16
    • S sandro_gera
        "type": "state",
        "common": {
          "read": true,
          "write": true,
          "type": "boolean",
          "alias": {
          "states": {
            "false": "aus",
            "true": "an"
          "smartName": false
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "type": "state",
        "common": {
          "type": "boolean",
          "read": true,
          "write": true,
          "smartName": {
            "ghTraits": [
          "alias": {
          "states": {
            "false": "aus",
            "true": "an"
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
      dslraserD Offline
      dslraserD Offline
      dslraser
      #5771
      @sandro_gera
      nach dem alias erstellen am Besten mal admin neu starten. Achtung: nicht stoppen, sondern nur neu starten !
      damit
      S 3 Antworten Letzte Antwort
        @sandro_gera
        damit
        sandro_gera
        #5772
        @sandro_gera
        damit
        Danke das versuche ich mal. Aber ich habe die Aliasse ja nicht neu erstellt.
        Ich habe nur von den Original Datenpunkten auf die aliasse umgestellt.
          @sandro_gera
          damit
          sandro_gera
          #5773
          @sandro_gera
          damit
          Der Neustart des Admin hat auch nicht gebracht. Ich versuche jetzt mal den kompletten Raspberry neu zu starten.
            @sandro_gera
            damit
            sandro_gera
            #5774
            @sandro_gera
            damit
            Neustart des Raspberry war auch erfolglos. Jetzt kann ich nur noch versuchen über backitup alles wieder zurück zu setzten, aber das ist ja eigentlich nicht ziehlführend.
                "type": "state",
                "common": {
                  "read": true,
                  "write": true,
                  "type": "boolean",
                  "alias": {
                  "states": {
                    "false": "aus",
                    "true": "an"
                  "smartName": false
                "native": {},
                "acl": {
                  "object": 1636,
                  "state": 1636,
              sandro_gera
              #5775
                "type": "state",
                "common": {
                  "read": true,
                  "write": true,
                  "type": "boolean",
                  "alias": {
                  "states": {
                    "false": "aus",
                    "true": "an"
                  "smartName": false
                "native": {},
                "acl": {
                  "object": 1636,
                  "state": 1636,
              Am Alias selbst kann es meiner Meinung nach nicht liegen, wenn ich den Wert im IO-broker unter objekten manuell ändere funktioniert alles wie immer auch Alexa funktioniert wie immer.
              • S sandro_gera
                  "type": "state",
                  "common": {
                    "read": true,
                    "write": true,
                    "type": "boolean",
                    "alias": {
                    "states": {
                      "false": "aus",
                      "true": "an"
                    "smartName": false
                  "native": {},
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                s.bormannS Offline
                s.bormannS Offline
                s.bormann
                #5776
                @sandro_gera Was sagt die Entwicklerkosole beim Schalten?
                Im zweiten Absatz wird beschrieben, wie man ein Log des Fehlers erzeugt und welche Screenshots für die weitere Analyse notwendig sind:
                https://github.com/sbormann/ioBroker.iqontrol#troubleshooting
                Vielen Dank!
                S 2 Antworten Letzte Antwort
                • s.bormannS s.bormann
                  Vielen Dank!
                  sandro_gera
                  #5777
                  @s-bormann said in Test Adapter iQontrol 1.9.x Vis:
                  Vielen Dank!
                  viewDeviceContextMenu start via TOUCHSTART/MOUSEDOWN
                  index.js:7236 viewDeviceContextMenu start function
                  index.js:4036 toolbarContextMenu end function
                  index.js:4041 toolbarContextMenu end function - find active Toolbar Index
                  index.js:7258 viewDeviceContextMenu level: -0.18750000000000003
                  index.js:7258 viewDeviceContextMenu level: -0.125
                  index.js:7258 viewDeviceContextMenu level: -0.062499999999999986
                  index.js:7245 viewDeviceContextMenu ignore click ended after 100ms
                  index.js:7258 viewDeviceContextMenu level: 0
                  index.js:3986 toolbarContextMenu end via TOUCHEND/MOUSEUP
                  index.js:7224 viewDeviceContextMenu end via TOUCHEND/MOUSEUP
                  index.js:7276 viewDeviceContextMenu end function
                  translate.js:24 "aus": {"en": "aus", "de": "aus", "ru": "aus", "pt": "aus", "nl": "aus", "fr": "aus"},
                  index.js:7208 viewDeviceContextMenu device CLICK TOGGLE
                  2index.js:4055 toolbarContextMenu end function - end ignoreStart
                  2index.js:7281 viewDeviceContextMenu end function - end ignoreStart
                  Hilft die das weiter oder hab ich da was falsch gemacht?
                    Vielen Dank!
                    sandro_gera
                    #5778
                    Vielen Dank!
                    	if (!dontEndIgnoreStart) setTimeout(function(){
                    		console.log("toolbarContextMenu end function - end ignoreStart");
                    		toolbarContextMenuIgnoreStart = false;
                    		toolbarContextMenuIgnoreClick = false;
                    function viewDeviceContextMenuEnd(dontEndIgnoreStart){
                    	console.log("viewDeviceContextMenu end function");
                    	viewDeviceContextMenuIgnoreStart = true;
                    	$('.iQontrolDevicePressureIndicator').css('box-shadow', '0px 0px 0px 0px rgba(175,175,175,0.85)');
                    	if(viewDeviceContextMenuInterval) clearInterval(viewDeviceContextMenuInterval);
                    		console.log("viewDeviceContextMenu end function - end ignoreStart");
                    		viewDeviceContextMenuIgnoreStart = false;
                    		viewDeviceContextMenuIgnoreClick = false;
                    	}, 300);
                      Auf Github gibt es eine neue Test-Version.
                      • @verkel @evolvo187 Es gibt jetzt endlich die Möglichkeit, bei den ADDITIONAL_CONTROLS die Steuerelemente auf die Hälfte der Breite zu verkleinern und sie damit nebeneinander anordnen zu können:
                        8314fa68-e203-4a1c-bbd5-21469444484f-image.png führt zu:
                      • @eMd Der Schrift-Upload wurde noch mal angepasst. Bitte teste mal, ob es jetzt geht (ehrlichgesagt habe ich den Fehler nicht ganz kapiert - habs einfach etwas umgeschrieben und hoffe, dass das besser funktioniert)
                      • @muuulle Widgets können jetzt auf den Dark-Mode zugreifen. Beim JSON-Table-Widget habe ich das implementiert. Im Wiki steht, wie es geht: https://github.com/sbormann/ioBroker.iqontrol/wiki/Übernehmen-der-Dark-Mode-Einstellungen-in-Widgets
                      Insgesamt viele Baustellen, Fehler sind also nicht ausgeschlossen - ich freue mich auf Rückmeldungen!
                      VG!
                      JLegJ Offline
                      JLegJ Offline
                      JLeg
                      #5779
                      @s-bormann sagte in Test Adapter iQontrol 1.9.x Vis:
                      Hm, bei mir tut sich da irgendwie nix (V1.9.3) - alle "additional controls" haben die Checkbox angekreuzt, aber "halbweit" wird's nicht (Typ "Popup"):
                      • JLegJ JLeg
                        s.bormannS Offline
                        s.bormannS Offline
                        s.bormann
                        #5780
                        @jleg sagte in Test Adapter iQontrol 1.9.x Vis:
                        Bei mir gings nach einem Hard-Reload (Cache löschen) :)
                        JLegJ 1 Antwort Letzte Antwort
                          JLegJ Offline
                          JLegJ Offline
                          JLeg
                          #5781
                          boa, wie "hard" muss der Reload denn sein? ;-) - yay, geht nun, aber erst nach Stop/Start von iqontrol- und web-Instanz (vorher shift-Reload, F5, Ctrl-F5 probiert, no avail)
                          Und jetzt hab' ich auch plötzlich "Dark mode" :) - aber ein "read-only"-Status-Bar sieht nun bissel verrutscht aus:
                          • JLegJ JLeg
                            s.bormannS Offline
                            s.bormannS Offline
                            s.bormann
                            #5782
                            Danke, Fix kommt :)
                            M JLegJ 2 Antworten Letzte Antwort
                              Danke, Fix kommt :)
                              muuulle
                              schrieb am zuletzt editiert von muuulle
                              #5783
                              @s-bormann
                              Kann man eigentlich Überschriften mittels Datenpunkten variabel füttern?! 🤔 Bei Gerätenamen geht es ja…
                              • M muuulle
                                @s-bormann
                                s.bormannS Offline
                                s.bormannS Offline
                                s.bormann
                                #5784
                                @muuulle Kannst Du Gedanken lesen? Ehrlich, genau darüber habe ich vorhin auch nachgedacht. Nein, geht derzeit ( :) ) nicht.
                                • evolvo187E evolvo187
                                  @beowolf said in Test Adapter iQontrol 1.9.x Vis:
                                  @evolvo187 sagte in Test Adapter iQontrol 1.9.x Vis:
                                  @evolvo187 ...ich versuchs noch mal :)
                                  Du kannst auch Unter-Überschriften vergeben und die als klappbare Sektionen machen.
                                  D.h. das, was immer offen sein soll, definierst Du ganz oben, ohne Überschrift.
                                  Und für jede zugeklappbare Überschriften-Sektion definierst Du eine Überschrift.
                                  Du kannst getrennt das Verhalten der ADD_C als Gesamtes und der einzelnen Überschriften einstellen.
                                  Eigentlich sollte damit - denke ich - alles gehen.
                                  Danke für die Erklärung.👍 Das habe ich so noch nicht gewusst!
                                  Habe es jetzt so gelöst.
                                  ist durch die Spielerein aber immer noch lang. (egal)
                                  Mal ne Frage, wie hast Du die Anzeige für die Empfangsqualität gemcht?
                                  Manfred
                                  Hallo Manfred,
                                  Mit dem beziehe den Datenpunkt vom fb-checkpresence Adapter (Fritz-Box)
                                  Beowolf
                                  #5785
                                  Manfred
                                  Hallo Manfred,
                                  Wenn das der Datenpunkt "Speed" ist, der ist bei mir hier immer Null. Muß da noch etwas anderes eingestellt werden?
                                    muuulle
                                    #5786
                                    @s-bormann
                                    Sehr lustig 😂
                                    Im Moment hast du wieder eine beachtenswerte Geschwindigkeit, wie du den Adapter weiterentwickelst! Respekt!
                                      Danke, Fix kommt :)
                                      JLegJ Offline
                                      JLegJ Offline
                                      JLeg
                                      #5787
                                      Und jetzt hab' ich auch plötzlich "Dark mode" - aber ein "read-only"-Status-Bar sieht nun bissel verrutscht aus:
                                      Danke, Fix kommt
                                      wenn du schonmal dabei bist 😁 - gibt es evtl. eine Möglichkeit, das Label (hier „Level“) irgendwo festzulegen/zu überschreiben? Derzeit wird das wohl 1:1 aus dem DP genommen…
                                      • M muuulle
                                        @s-bormann
                                        Sehr lustig 😂
                                        da_WoodyD Offline
                                        da_WoodyD Offline
                                        #5788
                                        @muuulle LOL, hab ich auch schon gemerkt. meine echos machen nicht mehr was sie sollen...
                                        dazu kommt noch, daß firefox und chrome bei dem albumcover als background-url komplett anders reagieren...
                                        senderumschaltung will auch nicht mehr...
                                        • da_WoodyD da_Woody
                                          muuulle
                                          #5789
                                          @da_woody
                                          @da_woody said in Test Adapter iQontrol 1.9.x Vis:
                                          …so habe ich das allerdings nicht gemeint. Bei mir läuft alles rund! Meine Fehler wurden sehr schnell behoben oder ein Lösungsansatz aufgezeigt!
