  4. Test ViessmannAPI v2.0.0
    apollon77A
827 Beiträge 129 Kommentatoren 422.9k Aufrufe 125 Beobachtet
  • K
    K
    KeePon
    schrieb am zuletzt editiert von KeePon
    Hi, danke für deine Arbeit. Ich habe den alten Adapter deinstalliert und diesen hier installiert. Allerdings bekomme ich beim Installieren diese Fehlermeldung:
    $ iobroker url https://github.com/TA2k/ioBroker.viessmannapi --host iobroker --debug
    install TA2k/ioBroker.viessmannapi#b13be1884571d93ddbecb8cdf5b50c9a8e7e9c56
    NPM version: 6.14.13
    npm install TA2k/ioBroker.viessmannapi#b13be1884571d93ddbecb8cdf5b50c9a8e7e9c56 --prefix "/opt/iobroker" (System call)
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@^2.2.1 (node_modules/node-dtls-client/node_modules/node-aead-crypto):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported engine for node-aead-crypto@2.2.1: wanted: {"node":">4 <10"} (current: {"node":"14.17.2","npm":"6.14.13"})npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Not compatible with your version of node/npm: node-aead-crypto@2.2.1
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/node-aead-crypto/package.json'
    npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    + iobroker.viessmannapi@2.0.0updated 1 package in 15.941s
    66 packages are looking for funding run `npm fund` for details
    upload [4] viessmannapi.admin /opt/iobroker/node_modules/iobroker.viessmannapi/admin/words.js words.js application/javascript
    upload [3] viessmannapi.admin /opt/iobroker/node_modules/iobroker.viessmannapi/admin/viessmannapi.png viessmannapi.png image/png
    upload [2] viessmannapi.admin /opt/iobroker/node_modules/iobroker.viessmannapi/admin/style.css style.css text/css
    upload [1] viessmannapi.admin /opt/iobroker/node_modules/iobroker.viessmannapi/admin/index_m.html index_m.html text/html
    upload [0] viessmannapi.admin /opt/iobroker/node_modules/iobroker.viessmannapi/admin/admin.d.ts admin.d.ts video/mp2t
    Process exited with code 0
    Weis jemand wie und was ich hier nachinstallieren muss?
    Vielen Dank!
    T I 2 Antworten Letzte Antwort
    • K KeePon
      Vielen Dank!
      T
      T
      tombox
      @keepon Ich sehe keine Errors nur Warnungen die normal sind auf macos der Adapter müsste trotzdem installiert sein oder?
      M K 2 Antworten Letzte Antwort
      • T tombox
        M
        M
        MartyBr
        @tombox
        Hallo @tombox, ich habe keine VitoConnect100 sondern eine VitoComfort 200. Funktioniert der Adapter auch damit oder wird zwingend eine VitoConnect100 benötigt?
        Martin
        Homematic und Homematic IP
        A T 2 Antworten Letzte Antwort
        • L LaBamba
          @amgxda
          Erstmal danke für den Adapter.
          Grundsätzlich bekomme ich viele Datenpunkte über die Vitoconnect 100. Jedoch scheint die Struktur etwas anders zu sein als deine Datenpunkt für die Luftwärmepumpe.
          Für mich ist die vorgegebene Struktur von Viessmann eine Katastrophe.
          A
          A
          amgxda
          schrieb am zuletzt editiert von amgxda
          @labamba
          Bei mir unterscheidet sich die Struktur der Datenpunkte nicht groß vom alten Adapter. Es werden jetzt aber wesentlich mehr Informationen angezeigt, was sehr hilfreich ist, z.B. findet man jetzt auch in den Datenpunkten, welche Werte die API beim Setzen von Werten erwartet.
          Hier steht z.B. welche Werte beim Ändern des Heizungsmodus erwartet werden (bei mir unter circuits.1):
          viessmannapi.0.x.0.features.heating.circuits.1.operating.modes.active.commands.setMode.params.mode.constraints.enum
          ->dhw;dhwAndHeating;forcedNormal;forcedReduced;standby;normalStandby
          • M MartyBr
            @tombox
            A
            A
            Ahnungsbefreit
            @martybr Probier's aus...
            • M MartyBr
              @tombox
              T
              T
              tombox
              @martybr Einfach probieren und rückmeldung geben was passiert
              @amgxda ich werde das setzen heute noch verbessern
              M 2 Antworten Letzte Antwort
              • T tombox
                M
                M
                MartyBr
                @tombox Okay, das setze ich mal im Testsystem auf.
                Martin
                • T tombox
                  M
                  M
                  MartyBr
                  @tombox Ich scheitere schon beim Anmelden:
                  https://developer.viessmann.com/de/clients
                  Wo kann ich denn den Account anlegen?
                  Martin
                  • M MartyBr
                    A
                    A
                    Ahnungsbefreit
                    @tombox Gestern lief der Adapter bei mir noch, seit heute Nacht produziert er auch Neustart/Pause folgende Fehlermeldung:
                    viessmann.0
                    2021-08-06 09:02:38.892	error	Error: Request failed with status code 502
                    viessmann.0
                    2021-08-06 09:02:38.891	error	https://api.viessmann.com/iot/v1/equipment/installations/XXXXX/gateways/YYYYYYYYY/devices/$id/features
                    Ich habe mal die numerischen Werte rausgenommen, da mir nicht klar, was davon zu schützen ist.
                    T A 2 Antworten Letzte Antwort
                    • A Ahnungsbefreit
                      viessmann.0
                      viessmann.0
                      T
                      T
                      tombox
                      @ahnungsbefreit Alles was über 500 ist ein Fehler bei viessmann. Ich gehe davon aus das sie gerade daran arbeiten. Ich habe heute auch schon 500er gesehen. Es ist nur wichtig das der Adapter normal weiter macht
                      A A 2 Antworten Letzte Antwort
                      • T tombox
                        A
                        A
                        Ahnungsbefreit
                        @tombox Hab's gefunden. Mein Gateway hatte wegen eines Repeater-Neustarts die WLAN Verbindung verloren. Ein Neustart und dann ging es wieder.
                        • A Ahnungsbefreit
                          viessmann.0
                          viessmann.0
                          A
                          A
                          amgxda
                          @ahnungsbefreit
                          Du verwendet offenbar nicht die neueste Version. Am besten neu installieren: https://github.com/TA2k/ioBroker.viessmannapi
                          Funktioniert der Zugriff mit der ViCare-App?
                          • A amgxda
                            @ahnungsbefreit
                            A
                            A
                            Ahnungsbefreit
                            @amgxda Siehe oben, lag an der Vitoconnect
                            • T tombox
                              K
                              K
                              KeePon
                              @tombox
                              Ich habe ein MacBook, von dem ich aus auf der ioBroker Oberfläche arbeite.
                              ioBroker selber läuft auf ein NUC mit Linux.
                              Der Adapter ist nach der Installation nicht in den Instanzen zu sehen. Bei den Objekten wurde nur die Struktur "Viessmannapi" und darunter "admin" angelgt. Darunter ist alles leer…
                              • K KeePon
                                @tombox
                                T
                                T
                                tombox
                                @keepon Instanz muss wie in Beitrag 1 beschrieben selbst erstellt werden
                                • T tombox
                                  A
                                  A
                                  amgxda
                                  @tombox
                                  Eben im Protokoll, aber der Adapter lief weiter und hat beim nächsten Abrufintervall wieder Werte aktualisiert:
                                  viessmannapi.0
                                  	2021-08-06 09:44:35.055	info	features receive 401 error. Refresh Token in 30 seconds
                                  viessmannapi.0
                                  	2021-08-06 09:44:35.047	info	events receive 401 error. Refresh Token in 30 seconds
                                  • A amgxda
                                    @tombox
                                    viessmannapi.0
                                    viessmannapi.0
                                    T
                                    T
                                    tombox
                                    @amgxda
                                    Ich habe mal die erlaubten werte in den setValue state eingebaut.
                                    Damit setValue wieder funktioniert müssen vor dem update alle objekte gelöscht werden.
                                    • T tombox
                                      @amgxda
                                      A
                                      A
                                      amgxda
                                      @tombox
                                      Ich habe noch mit der Vorversion testweise die Zahl 47 hier gesetzt: viessmannapi.0.x.0.features.heating.dhw.temperature.commands.setTargetTemperature.setValue
                                      Es steht aber nach wie vor '49' unter:
                                      viessmannapi.0.x.0.features.heating.dhw.temperature.properties.value.value
                                      Edit: Hab den Fehler gefunden, der Wert wurde mit Javascript mit "ack: true" gesetzt, ohne den Zusatz funktionierts
                                      • T
                                        T
                                        tombox
                                        @amgxda Korrekt ack darf eigentlich nur von werten die vom system kommen gesetzt werden
                                        • S
                                          S
                                          Sprite01
                                          Ich habe mich auch ran getraut und den Adapter installiert. :-)
                                          Es funktioniert - ist ja cool - DANKE
                                          Das sind ja auch irre viele Datenpunkte, welche in den Objekten dann auftauchen.
                                          Ich habe meine bisher genutzten auch gefunden, einzig den KESSELDRUCK habe ich noch nicht rausfischen können.
                                          Gibt es diesen auch im Objektbaum ?
                                          Dirk
                                          http://www.DessauWetter.de
                                          (ioBroker auf IntelNuc und Proxmox)
                                          84.0k
