  4. (gelöst)USV
(gelöst)USV
135 Beiträge 9 Kommentatoren 17.2k Aufrufe 11 Beobachtet
  • ostseereiterO ostseereiter
    @homoran sagte in USV:
    Warning: The unit file, source configuration file or drop-ins of nut-server.service changed on disk. Run 'systemctl daemon-reload' to reload units. Job for nut-server.service failed because the control process exited with error code. See "systemctl status nut-server.service" and "journalctl -xe" for details.
    und behoben?
    wohl eher nicht!
    denn der Controller schgeint weiter nicht erreichbar zu sein
    @ostseereiter sagte in USV:
    jetzt habe ich versucht das zu beheben.
    andy@debian:~$ sudo systemctl daemon-reload
    [sudo] Passwort für andy:
    andy@debian:~$ sudo systemctl restart nut-server
    andy@debian:~$ ^C
    andy@debian:~$ sudo systemctl status nut-server.service
    ● nut-server.service - Network UPS Tools - power devices information server
       Loaded: loaded (/lib/systemd/system/nut-server.service; enabled; vendor prese
       Active: failed (Result: exit-code) since Fri 2021-05-21 12:11:20 CEST; 45s ag
      Process: 1409 ExecStartPre=/bin/sleep 30 (code=exited, status=0/SUCCESS)
      Process: 2130 ExecStart=/sbin/upsd (code=exited, status=1/FAILURE)
    Mai 21 12:10:50 debian systemd[1]: Starting Network UPS Tools - power devices in
    Mai 21 12:11:20 debian upsd[2130]: Network UPS Tools upsd 2.7.4
    Mai 21 12:11:20 debian upsd[2130]: Fatal error: A previous upsd instance is alre
    Mai 21 12:11:20 debian upsd[2130]: Either stop the previous instance first, or u
    Mai 21 12:11:20 debian systemd[1]: nut-server.service: Control process exited, c
    Mai 21 12:11:20 debian systemd[1]: nut-server.service: Failed with result 'exit-
    Mai 21 12:11:20 debian systemd[1]: Failed to start Network UPS Tools - power dev
    lines 1-13/13 (END)...skipping...
       Loaded: loaded (/lib/systemd/system/nut-server.service; enabled; vendor preset: enabled)
       Active: failed (Result: exit-code) since Fri 2021-05-21 12:11:20 CEST; 45s ago
    Mai 21 12:10:50 debian systemd[1]: Starting Network UPS Tools - power devices information server...
    Mai 21 12:11:20 debian upsd[2130]: Fatal error: A previous upsd instance is already running!
    Mai 21 12:11:20 debian upsd[2130]: Either stop the previous instance first, or use the 'reload' command.
    Mai 21 12:11:20 debian systemd[1]: nut-server.service: Control process exited, code=exited, status=1/FAILURE
    Mai 21 12:11:20 debian systemd[1]: nut-server.service: Failed with result 'exit-code'.
    Mai 21 12:11:20 debian systemd[1]: Failed to start Network UPS Tools - power devices information server.
    lines 1-13/13 (END)
    lines 1-13/13 (END)
    BBTownB Offline
    BBTownB Offline
    BBTown
    #83
    @ostseereiter
    gehört dort nicht ein Leerzeichen rein?
    • BBTownB BBTown
      @ostseereiter
      crunchipC Offline
      crunchipC Offline
      #84
      @bbtown deswegen schrieb ich, dieser Eintrag ist falsch, zum einen ein Leerzeichen und zum anderen muss das passwort übereinstimmen, zumal ich keine Ahnung hab ob er das secret bzw test wirklich so eingetragen hat.
        @ostseereiter
        andy@debian:~$ sudo upsd
        fopen /var/run/nut/upsd.pid: No such file or directory
        listening on 192.168.178.109 port 3493
        listening on 127.0.0.1 port 3493
        Can't connect to UPS [serverups] (usbhid-ups-serverups): No such file or directory
        andy@debian:~$
        crunchipC Offline
        crunchipC Offline
        #85
        @ostseereiter keine Ahnung wo du etwas veraemmelt hast, ich rate dir, wie bereits geschrieben, deinstalliere nochmal incl, config
        Und installiere dann neu, dann ist deine config wieder default und du kannst von neu nach Anleitung ansetzen, alles andere zieht sich nur ewig in die Länge
        sudo apt-get purge --auto-remove nut
        Danach nochmal nach Anleitung
        ostseereiterO 1 Antwort Letzte Antwort
          ostseereiterO Offline
          ostseereiter
          schrieb am zuletzt editiert von ostseereiter
          #86
          @crunchip sagte in USV:
          andy@debian:~$ sudo apt-get purge --auto-remove nut
          Paket »nut« ist nicht installiert, wird also auch nicht entfernt.
          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 1 nicht aktualisiert.
          andy@debian:~$
          das kommt dabei raus. jetzt habe ich bestimmt irgendwo was versaut wenn es sich nicht deinstallieren lässt
          Gruß OSR
          Plattform
          Thomas BraunT Meister MopperM 2 Antworten Letzte Antwort
            andy@debian:~$
            #87
            @ostseereiter
            Die Pakete heißen auch anders, wenn mich nicht alles täuscht.
            nut-server und nut-client vielleicht?
            TabCompletion macht dich schlauer, bzw. solltest du ja noch wissen was du da gestern installiert hast.
              @ostseereiter
              #88
              @thomas-braun sagte in USV:
              @ostseereiter
              Mit welchem Befehl hast du es denn installiert?
              sudo apt install nut usbutils?????
                andy@debian:~$
                Meister MopperM Online
                Meister Mopper
                #89
                @ostseereiter Installiert wird mit sudo apt-get install nut-client nut-server usbutils
                Proxmox und HA ...
                  @ostseereiter
                  ostseereiter
                  #90
                  nein mit
                  sudo apt install nut-server
                  Gruß OSR
                  Plattform
                    nein mit
                    #91
                    @ostseereiter
                    Dann musst du die Rolle rückwärts (deinstallieren) auch mit dem Paketnamen vornehmen.
                    Woher soll die Kiste auch wissen das du mit 'nut' den nut-server meinst?
                    (Jaaaaaaa, es gibt Meta-Pakete... Weiß ich auch...)
                      @ostseereiter
                      ostseereiter
                      #92
                      habe jetzt das deinstalliert
                      andy@debian:~$ sudo apt-get purge --auto-remove nut-server
                      Die folgenden Pakete werden ENTFERNT:
                        nut-server*
                      0 aktualisiert, 0 neu installiert, 1 zu entfernen und 1 nicht aktualisiert.
                      Nach dieser Operation werden 5.062 kB Plattenplatz freigegeben.
                      Möchten Sie fortfahren? [J/n] j
                      (Lese Datenbank ... 51406 Dateien und Verzeichnisse sind derzeit installiert.)
                      Entfernen von nut-server (2.7.4-8) ...
                      Failed to stop nut.service: Unit nut.service not loaded.
                      invoke-rc.d: initscript nut, action "stop" failed.
                      Trigger für man-db (2.8.5-2) werden verarbeitet ...
                      (Lese Datenbank ... 51282 Dateien und Verzeichnisse sind derzeit installiert.)
                      Löschen der Konfigurationsdateien von nut-server (2.7.4-8) ...
                      Trigger für systemd (241-7~deb10u7) werden verarbeitet ...
                      das sieht doch schon mal anders aus
                      Gruß OSR
                      Plattform
                        #93
                        @meister-mopper sagte in USV:
                        sicher?
                        ich habe mich damals nach der Anleitung von @klassisch langgehangelt. da wurde es (anschließend funktionierend!!) mit dem eben von mir geposteten Befehl installiert.
                        • ostseereiterO Offline
                          ostseereiter
                          #94
                          nun habe ich ja mehrere Vorschläge wie soll ich nun wieder installieren mit
                          Gruß OSR
                          Plattform
                            #95
                            server beim server und client beim client
                              ostseereiter
                              #96
                              ich möchte jetzt komplett sicher gehen also nicht diesen Befehl auf den Server
                              sondern
                              sudo apt-get install nut-server usbutils
                              ich bin wieder ein wenig durcheiander.
                              Gruß OSR
                              Plattform
                                sondern
                                ostseereiter
                                #97
                                @ostseereiter
                                es gibt unendlich viel Befehle wenn ich mich dort weiter einlese was dann noch verwirrender ist.
                                gefunden habe ich diese dann
                                sudo apt-get install nut usbutils
                                Da brate mir einer ein Storch
                                Gruß OSR
                                Plattform
                                  @ostseereiter
                                  #98
                                  @ostseereiter
                                  Das ist abhängig von der Distribution oder zusätzlich eingebundenen Paketquellen.
                                  Ich kann den ganzen nut-Kram auch in ein Paket namens 'nutcracker' packen (und wenn ich das in das Repo gelegt bekäme), dann wäre z. B.
                                  sudo apt install nutcracker
                                  das zu installierende Paket. Deswegen immer aufpassen auf welches 'Linux' bzw. welches Release einer Distribution sich eine Anleitung bezieht. Bei gescheiten steht das immer dabei.
                                  apt und apt-get kann man weitgehend gleich verwenden, apt ist sowas wie die Weiterentwicklung von apt-get und bedient sich zu 99% gleich.
                                    @ostseereiter
                                    ostseereiter
                                    #99
                                    die meisten die ich oder Ihr mir gesagt habt ist für ein raspi oder so und eine für Linux
                                    diese für Kleinrechner
                                    diese auch für Kleinrechner
                                    diese auch noch mal
                                    und die letzte Linux
                                    die Befehle unterscheiden sich fast nicht
                                    Gruß OSR
                                    Plattform
                                      diese auch noch mal
                                      #100
                                      Natürlich nicht. Wäre ja auch komplett doof, wenn man das Paket auf einmal 'kunigunde' nennen würde. Da käme ja nie jemand drauf.
                                        ostseereiter
                                        #101
                                        Lach ja die Antwort war jetzt gut tat jetzt gut ich bin total angespannt wenn ich nicht weiß wie es weiter geht. Ich würde ja sagen dann die vom L
                                        Linux nehmen da ich ja Debian habe . Die frage die ich mir jetzt wieder stelle den Befehl
                                        mit usbutils hinten dran
                                        oder ohne wie auf der Linuxseite beschrieben.
                                        und genau diese Kleinigkeiten machen ein fertig.
                                        Gruß OSR
                                        Plattform
                                          #102
                                          @ostseereiter
                                          Ich vermute mal ganz stark, dass usbutils ohnehin bereits installiert ist.
                                          apt policy usbutils
                                          macht dich schlauer.
