  4. (gelöst)USV
(gelöst)USV
135 Beiträge 9 Kommentatoren 17.2k Aufrufe 11 Beobachtet
  • ostseereiterO ostseereiter
    @crunchip sagte in USV:
    sudo systemctl status nut-client
    Ja nun habe ich auf den Client das installiert und natürlich eingetragen in den beiden Dateien
    dann gestartet. und geschaut ob es läuft dabei kam das raus.
    pi@SVPi-hole:~ $ sudo systemctl restart nut-client
    Job for nut-monitor.service failed because the control process exited with error        code.
    See "systemctl status nut-monitor.service" and "journalctl -xe" for details.
    pi@SVPi-hole:~ $ sudo systemctl status nut-client
    ● nut-monitor.service - Network UPS Tools - power device monitor and shutdown co
       Loaded: loaded (/lib/systemd/system/nut-monitor.service; enabled; vendor pres
       Active: failed (Result: exit-code) since Fri 2021-05-21 09:30:38 CEST; 17s ag
      Process: 9283 ExecStart=/sbin/upsmon (code=exited, status=1/FAILURE)
    May 21 09:30:38 SVPi-hole systemd[1]: Starting Network UPS Tools - power device
    May 21 09:30:38 SVPi-hole upsmon[9283]: fopen /var/run/nut/upsmon.pid: No such f
    May 21 09:30:38 SVPi-hole upsmon[9283]: Using power down flag file /etc/killpowe
    May 21 09:30:38 SVPi-hole upsmon[9283]: Unable to use old-style MONITOR line wit
    May 21 09:30:38 SVPi-hole upsmon[9283]: Convert it and add a username to upsd.us
    May 21 09:30:38 SVPi-hole upsmon[9283]: Fatal error: unusable configuration
    May 21 09:30:38 SVPi-hole upsmon[9283]: Network UPS Tools upsmon 2.7.4
    May 21 09:30:38 SVPi-hole systemd[1]: nut-monitor.service: Control process exite
    May 21 09:30:38 SVPi-hole systemd[1]: nut-monitor.service: Failed with result 'e
    May 21 09:30:38 SVPi-hole systemd[1]: Failed to start Network UPS Tools - power
    lines 1-15/15 (END)...skipping...
    ● nut-monitor.service - Network UPS Tools - power device monitor and shutdown controller
       Loaded: loaded (/lib/systemd/system/nut-monitor.service; enabled; vendor preset: enabled)
       Active: failed (Result: exit-code) since Fri 2021-05-21 09:30:38 CEST; 17s ago
    May 21 09:30:38 SVPi-hole systemd[1]: Starting Network UPS Tools - power device monitor and shutdown controller...
    May 21 09:30:38 SVPi-hole upsmon[9283]: fopen /var/run/nut/upsmon.pid: No such file or directory
    May 21 09:30:38 SVPi-hole upsmon[9283]: Using power down flag file /etc/killpower
    May 21 09:30:38 SVPi-hole upsmon[9283]: Unable to use old-style MONITOR line without a username
    May 21 09:30:38 SVPi-hole upsmon[9283]: Convert it and add a username to upsd.users - see the documentation
    May 21 09:30:38 SVPi-hole systemd[1]: nut-monitor.service: Control process exited, code=exited, status=1/FAILURE
    May 21 09:30:38 SVPi-hole systemd[1]: nut-monitor.service: Failed with result 'exit-code'.
    May 21 09:30:38 SVPi-hole systemd[1]: Failed to start Network UPS Tools - power device monitor and shutdown controller.
    lines 1-15/15 (END)
    crunchipC Offline
    crunchipC Offline
    #67
    @ostseereiter irgendwo hast du etwas falsch eingetragen und daher läuft dein service nicht
    prüfe doch mal da(Server), wo deine USV dran hängt, das muss erst mal korrekt laufen
    sudo systemctl status nut-server
    danach an deinem Client(SLave) die config überprüfen, ob alles richtig eingetragen ist, danach
    was mir noch aufgefallen ist, deine 3 user,
    upsmaster]
            password = xxxxxxx
            actions = SET
            instcmds = ALL
            upsmon master
    [raspiuser]
    	password = xxxxx
    	upsmon slave
    [upskino]
            password  = xxxx
            upsmon slave
    reichen eigentlich 2, einmal master, einmal slave, diese musst du ja in der jeweiligen .conf hinterlegen
    ostseereiterO 1 Antwort Letzte Antwort
      upsmaster]
              password = xxxxxxx
              actions = SET
              instcmds = ALL
              upsmon master
      [raspiuser]
      	password = xxxxx
      	upsmon slave
      [upskino]
              password  = xxxx
              upsmon slave
      ostseereiterO Offline
      ostseereiter
      #68
      @crunchip OK ich kontrolliere noch mal alles und dokumentiere das dann hier.
      Gruß OSR
      Plattform
        lines 1-15/15 (END)
        #69
        @ostseereiter sagte in USV:
        was installiert und was eingetragen?
        In den Clients muss natürlich was anderes in den config-Dateien stehen, als im Server
          ostseereiter
          #70
          @homoran ja ich dokumentiere noch mal alles schritt für Schritt melde mich dann wieder.
          Gruß OSR
          Plattform
          • ostseereiterO Offline
            ostseereiter
            #71
            So hier nochmal die einzelnen Schritte.
            In der sudo nano /etc/nut/ups.conf
            habe ich das eingetragen außer den pollinterval nicht.
            # The general form is:
             [serverups]
                   driver = usbhid-ups
                     port = auto
                    desc = "Eeaton UPS"
            # The section header ([upsname]) can be just about anything as long as
            # it is a single word inside brackets.  upsd uses this to uniquely
            # identify a UPS on this system.
            in der sudo nano /etc/nut/nut.conf das
            # IMPORTANT NOTE:
            #  This file is intended to be sourced by shell scripts.
            #  You MUST NOT use spaces around the equal sign!
            MODE=netserver
            nun kommt sudo nano /etc/nut/upsd.conf da habe ich das drin
            # you can specify if upsd requests or requires client's' certificates.
            # Possible values are :
            #  - 0 to not request to clients to provide any certificate
            #  - 1 to require to all clients a certificate
            #  - 2 to require to all clients a valid certificate
            # See 'docs/security.txt' or the Security chapter of NUT user manual
            # for more information on the SSL support in NUT.
            LISTEN 127.0.0.1 3493
            LISTEN 192.168.178.109 3493
            nun die Benutzerkonten ich nehme gleich den 3 raus.sudo nano /etc/nut/upsd.users
            # MONITOR myups@localhost 1 upsmon pass master  (or slave)
            [upsmaster]
             password = test
             actions = SET
             instcmds = ALL
             upsmon master
            [raspiuser]
             password = secret
             upsmon slave
            in der sudo nano /etc/systemd/system/multi-user.target.wants/nut-server.service steht das:
            Wants=nut-driver.service
            Before=nut-monitor.service
            [Service]
            ExecStartPre=/bin/sleep 30
            ExecStart=/sbin/upsd
            Type=forking
            [Install]
            WantedBy=multi-user.target
            Jetzt das Monitoring sudo nano /etc/nut/upsmon.conf
            da habe ich diese Zeile hinzugefügt:
            MONITOR serverups@localhost 1 upsmaster test master
            Dann habe ich den dienst neugestartet mit sudo systemctl restart nut-server
            mit
            andy@debian:~$ sudo systemctl restart nut-server
            Dann kam dieses bei raus
            Warning: The unit file, source configuration file or drop-ins of nut-server.service changed on disk. Run 'systemctl daemon-reload' to reload units.
            Job for nut-server.service failed because the control process exited with error code.
            See "systemctl status nut-server.service" and "journalctl -xe" for details.
            Nun sollte der Server eingerichtet sein
            Jetzt gehen wir zu den Client der Raspi
            dort habe ich erst mal installiert mit sudo apt install nut-client
            jetzt editiert mit sudo nano /etc/nut/nut.conf
            dort steht drin
            # - netserver: same as for the standalone configuration, but also need
            #   some more network access controls (firewall, tcp-wrappers) and possibly a
            #   specific LISTEN directive in upsd.conf.
            #   Since this MODE is opened to the network, a special care should be applied
            #   to security concerns.
            # - netclient: this mode only requires upsmon.
            # IMPORTANT NOTE:
            MODE=netclient
            jetzt diese Datei sudo nano /etc/nut/upsmon.conf
            When compiled with SSL, specify that a secured connection must be used
            # to communicate with upsd.
            # If you don't use 'CERTVERIFY 1', then this will at least make sure
            # that nobody can sniff your sessions without a large effort.  Setting
            # this will make upsmon drop connections if the remote upsd doesn't
            # support SSL, so don't use it unless all of them have it running.
            # When compiled with NSS support of SSL, can be overriden for host
            # specified with a CERTHOST directive.
            MONITOR serverups@192.168.178.109 1 raspiuser testslave
            nun den Clientserver neu starten mit sudo systemctl restart nut-client
            jetzt kommt diese Ausgabe.
            Broadcast message from nut@SVPi-hole (somewhere) (Fri May 21 11:03:50 2021):
            Communications with UPS serverups@192.168.178.109 lost
            Broadcast message from nut@SVPi-hole (somewhere) (Fri May 21 11:03:55 2021):
            UPS serverups@192.168.178.109 is unavailable
            und nach einer gewissen Zeit diese Ausgabe
            pi@SVPi-hole:~ $ ^C
            Broadcast message from nut@SVPi-hole (somewhere) (Fri May 21 11:09:00 2021):
            Gruß OSR
            Plattform
            HomoranH crunchipC 3 Antworten Letzte Antwort
               [serverups]
                     driver = usbhid-ups
                       port = auto
                      desc = "Eeaton UPS"
              # IMPORTANT NOTE:
              MODE=netserver
              [upsmaster]
               password = test
               actions = SET
               instcmds = ALL
               upsmon master
              [raspiuser]
               password = secret
               upsmon slave
              [Service]
              Type=forking
              [Install]
              mit
              dort steht drin
              # IMPORTANT NOTE:
              MODE=netclient
              pi@SVPi-hole:~ $ ^C
              #72
              Beim Server oder bei den Clients?
                 [serverups]
                       driver = usbhid-ups
                         port = auto
                        desc = "Eeaton UPS"
                # IMPORTANT NOTE:
                MODE=netserver
                [upsmaster]
                 password = test
                 actions = SET
                 instcmds = ALL
                 upsmon master
                [raspiuser]
                 password = secret
                 upsmon slave
                [Service]
                Type=forking
                [Install]
                mit
                dort steht drin
                # IMPORTANT NOTE:
                MODE=netclient
                pi@SVPi-hole:~ $ ^C
                #73
                aber das davor hast du schon gelesen?
                Warning: The unit file, source configuration file or drop-ins of nut-server.service changed on disk. Run 'systemctl daemon-reload' to reload units. Job for nut-server.service failed because the control process exited with error code. See "systemctl status nut-server.service" and "journalctl -xe" for details.
                und behoben?
                wohl eher nicht!
                denn der Controller schgeint weiter nicht erreichbar zu sein
                  ostseereiter
                  #74
                  im Server
                  Gruß OSR
                  Plattform
                    im Server
                    #75
                    @ostseereiter
                    Ich lese da wieder pihole. Muss da ggf. auch noch was eingestellt werden?
                      und behoben?
                      wohl eher nicht!
                      ostseereiter
                      #76
                      @homoran sagte in USV:
                      und behoben?
                      wohl eher nicht!
                      jetzt habe ich versucht das zu beheben.
                      andy@debian:~$ sudo systemctl daemon-reload
                      [sudo] Passwort für andy:
                      andy@debian:~$ ^C
                      andy@debian:~$ sudo systemctl status nut-server.service
                      ● nut-server.service - Network UPS Tools - power devices information server
                         Loaded: loaded (/lib/systemd/system/nut-server.service; enabled; vendor prese
                         Active: failed (Result: exit-code) since Fri 2021-05-21 12:11:20 CEST; 45s ag
                        Process: 1409 ExecStartPre=/bin/sleep 30 (code=exited, status=0/SUCCESS)
                        Process: 2130 ExecStart=/sbin/upsd (code=exited, status=1/FAILURE)
                      Mai 21 12:10:50 debian systemd[1]: Starting Network UPS Tools - power devices in
                      Mai 21 12:11:20 debian upsd[2130]: Network UPS Tools upsd 2.7.4
                      Mai 21 12:11:20 debian upsd[2130]: Fatal error: A previous upsd instance is alre
                      Mai 21 12:11:20 debian upsd[2130]: Either stop the previous instance first, or u
                      Mai 21 12:11:20 debian systemd[1]: nut-server.service: Control process exited, c
                      Mai 21 12:11:20 debian systemd[1]: nut-server.service: Failed with result 'exit-
                      Mai 21 12:11:20 debian systemd[1]: Failed to start Network UPS Tools - power dev
                      lines 1-13/13 (END)...skipping...
                         Loaded: loaded (/lib/systemd/system/nut-server.service; enabled; vendor preset: enabled)
                         Active: failed (Result: exit-code) since Fri 2021-05-21 12:11:20 CEST; 45s ago
                      Mai 21 12:10:50 debian systemd[1]: Starting Network UPS Tools - power devices information server...
                      Mai 21 12:11:20 debian upsd[2130]: Fatal error: A previous upsd instance is already running!
                      Mai 21 12:11:20 debian upsd[2130]: Either stop the previous instance first, or use the 'reload' command.
                      Mai 21 12:11:20 debian systemd[1]: nut-server.service: Control process exited, code=exited, status=1/FAILURE
                      Mai 21 12:11:20 debian systemd[1]: nut-server.service: Failed with result 'exit-code'.
                      Mai 21 12:11:20 debian systemd[1]: Failed to start Network UPS Tools - power devices information server.
                      lines 1-13/13 (END)
                      lines 1-13/13 (END)
                      Gruß OSR
                      Plattform
                      HomoranH BBTownB 2 Antworten Letzte Antwort
                        und behoben?
                        wohl eher nicht!
                        andy@debian:~$ ^C
                        lines 1-13/13 (END)
                        lines 1-13/13 (END)
                        #77
                        entscheidend ist vielmehr die Frage was du gemacht hast bevor/so dass es zu dieser Fehlermeldung kam:
                        was hast du da im System verstellt?
                          ostseereiter
                          #78
                          eigentlich nichts
                          Gruß OSR
                          Plattform
                            eigentlich nichts
                            #79
                            @ostseereiter
                            Da läuft schon ein daemon.
                               [serverups]
                                     driver = usbhid-ups
                                       port = auto
                                      desc = "Eeaton UPS"
                              # IMPORTANT NOTE:
                              MODE=netserver
                              [upsmaster]
                               password = test
                               actions = SET
                               instcmds = ALL
                               upsmon master
                              [raspiuser]
                               password = secret
                               upsmon slave
                              [Service]
                              Type=forking
                              [Install]
                              mit
                              dort steht drin
                              # IMPORTANT NOTE:
                              MODE=netclient
                              pi@SVPi-hole:~ $ ^C
                              crunchipC Offline
                              crunchipC Offline
                              #80
                              [raspiuser]
                              password = secret
                              upsmon slave
                              nano /etc/nut/upsmon.conf, der Eintrag ist ebenfalls falsch
                              du bekommst deinen service nicht zum laufen, hatte ich damals auch diese Meldung, als ich beim ersten mal die config falsch eingestellt hatte. Selbst als die Config dann richtig war, kam diese Meldung.
                              Lösung war bei mir letztendlich, das ich den (Nut- server und nut - client) nochmal de/installiert habe, anschliessend die config der Reihe nach eingestellt habe und lief dann.
                                @ostseereiter
                                ostseereiter
                                #81
                                ja und das heißt ? Ich bin total überfordert im moment.Nicht böse sein wegen meiner Dummheit
                                Gruß OSR
                                Plattform
                                  ostseereiter
                                  #82
                                  @ostseereiter
                                  andy@debian:~$ sudo upsd
                                  fopen /var/run/nut/upsd.pid: No such file or directory
                                  listening on 192.168.178.109 port 3493
                                  listening on 127.0.0.1 port 3493
                                  Can't connect to UPS [serverups] (usbhid-ups-serverups): No such file or directory
                                  andy@debian:~$
                                  Gruß OSR
                                  Plattform
                                    und behoben?
                                    wohl eher nicht!
                                    andy@debian:~$ ^C
                                    lines 1-13/13 (END)
                                    lines 1-13/13 (END)
                                    BBTownB Offline
                                    BBTownB Offline
                                    BBTown
                                    #83
                                    @ostseereiter
                                    gehört dort nicht ein Leerzeichen rein?
                                    • BBTownB BBTown
                                      @ostseereiter
                                      crunchipC Offline
                                      crunchipC Offline
                                      #84
                                      @bbtown deswegen schrieb ich, dieser Eintrag ist falsch, zum einen ein Leerzeichen und zum anderen muss das passwort übereinstimmen, zumal ich keine Ahnung hab ob er das secret bzw test wirklich so eingetragen hat.
                                        @ostseereiter
                                        andy@debian:~$
                                        crunchipC Offline
                                        crunchipC Offline
                                        #85
                                        @ostseereiter keine Ahnung wo du etwas veraemmelt hast, ich rate dir, wie bereits geschrieben, deinstalliere nochmal incl, config
                                        Und installiere dann neu, dann ist deine config wieder default und du kannst von neu nach Anleitung ansetzen, alles andere zieht sich nur ewig in die Länge
                                        sudo apt-get purge --auto-remove nut
                                        Danach nochmal nach Anleitung
                                          ostseereiter
                                          schrieb am zuletzt editiert von ostseereiter
                                          #86
                                          andy@debian:~$ sudo apt-get purge --auto-remove nut
                                          Paket »nut« ist nicht installiert, wird also auch nicht entfernt.
                                          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 1 nicht aktualisiert.
                                          andy@debian:~$
                                          das kommt dabei raus. jetzt habe ich bestimmt irgendwo was versaut wenn es sich nicht deinstallieren lässt
                                          Gruß OSR
                                          Plattform
                                          Thomas BraunT Meister MopperM 2 Antworten Letzte Antwort
