  4. Test Adapter Admin 5.0.x: Alpha der neuen UI
938 Beiträge 86 Kommentatoren 410.2k Aufrufe 77 Beobachtet
  • MichMeinM MichMein
    @sborg da scheint der Backitup Adapter wohl nachhaltig etwas „verändert“ zu haben.
    SBorgS
    SBorgS
    SBorg
    #528
    @michmein Ne, wohl eher der aktuelle Admin. Auch hier hilft ein Downgrade:
    iob upgrade iobroker.admin@5.0.22
    Mit der 5.0.23 habe ich noch nicht getestet ;)
    LG SBorg ( SBorg auf GitHub)
    MichMeinM 1 Antwort Letzte Antwort
    • SBorgS SBorg
      MichMeinM
      MichMeinM
      MichMein
      #529
      @sborg du hast vollkommen recht, mit 5.0.22 funktioniert es wieder. 5.0.23 kann ich nicht installieren, nur 22 klappt.
      pi@ioBroker:~ $ iob upgrade iobroker.admin@5.0.23
      This downgrade of "admin" will remove the following changes:
      -> 5.0.24
      Admin5: GUI fixes
      Would you like to downgrade admin from @5.0.24 to @5.0.23 now? [(y)es, (n)o]: y
      Update admin from @5.0.24 to @5.0.23
      host.ioBroker Adapter "system.adapter.admin.0" is stopped.
      NPM version: 6.14.12
      npm install iobroker.admin@5.0.23 --loglevel error --prefix "/opt/iobroker" (System call)
      npm ERR! code ETARGET
      npm ERR! notarget No matching version found for iobroker.admin@5.0.23.
      npm ERR! notarget In most cases you or one of your dependencies are requesting
      npm ERR! notarget a package version that doesn't exist.
      npm ERR!     /home/iobroker/.npm/_logs/2021-05-15T09_15_57_862Z-debug.log
      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
      Update "system.adapter.admin.0"
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      Adapter "admin" updated
      host.ioBroker Adapter "system.adapter.admin.0" is started
      pi@ioBroker:~ $ iob upgrade iobroker.admin@5.0.22
      -> 5.0.24
      Admin5: GUI fixes
      -> 5.0.23
      Admin5: GUI fixes
      Would you like to downgrade admin from @5.0.24 to @5.0.22 now? [(y)es, (n)o]: y
      Update admin from @5.0.24 to @5.0.22
      npm install iobroker.admin@5.0.22 --loglevel error --prefix "/opt/iobroker" (System call)
      pi@ioBroker:~ $
      Gruß Michael
      Sofern Beiträge hilfreich für Dich sind, nutze das Voting unten rechts.
      • M muckel
        Vielleicht noch ein nützlicher Hinweis zur Fehlersuche.
        All meine Passwörter und Zertifikate waren ungültig.
        Ich musste alle neu eintippen und abspeichern.
        Der IOT Adapter funktioniert noch immer nicht, trotz "Zertifikate Anfordern".
        Dr. BakteriusD
        Dr. BakteriusD
        Dr. Bakterius
        #530
        @muckel sagte in Test Adapter Admin 5.0.x: Alpha der neuen UI:
        Bei mir nicht alle, aber von vier Adaptern (Proxmox, Pushover, MQTT und sonoff). Dachte erst, das liegt am neuen Admin-Adapter oder Host, aber nachdem ein Downgrade nicht geholfen hatte, habe ich die Passworte untersucht und festgestellt, dass die falsch waren.
          M
          M
          muckel
          #531
          @dr-bakterius
          Mit "alle" meinte ich einige. ;-) Pushover, Shelly, Smartgarden, Octoprint und IOT.
          IOT funktioniert allerdings noch immer nicht.
          Das schau ich mir am Abend genauer an.
            simatecS
            simatecS
            simatec
            #532
            @michmein sagte in Test Adapter Admin 5.0.x: Alpha der neuen UI:
            Ja ich habe backitup an die Änderungen von admin 5.0.24 angepasst.
            Ich kann die Probleme leider nicht reproduzieren.
            Denke aber es hat was mit admin zu tun ...
            Backitup selber erstellt ja die Tableiste nicht, sondern hat darin nur einen Eintrag, der durch admin dort erstellt wird.
            https://github.com/ioBroker/ioBroker.admin/issues/879#issuecomment-841653854
            • Besuche meine Github Seite
            • HowTo Restore ioBroker
            • ChaotC Chaot
              @simatec Weiter getestet:
              Über Instanzen kann ich Backitup öffnen und auch Backups erzeugen die problemlos laufen.
              Nur wenn ich über den Reiter auf der linken Seite gehe kommt der Fehler.
              Also scheint es eventuell nur am Menueaufruf zu liegen.
              simatecS
              simatecS
              simatec
              #533
              @chaot sagte in Test Adapter Admin 5.0.x: Alpha der neuen UI:
              Das habe ich in Version 2.1.8 gefixt bzw. admin 5.0.24 angepasst
              • simatecS simatec
                Thomas BraunT
                Thomas BraunT
                #534
                @simatec
                Ich habe jetzt mal von einem Beta-Stage-System auf die neue Oberfläche umgestellt. Hier ist noch alles i. O.
                  @simatec
                  MichMeinM
                  MichMeinM
                  MichMein
                  #535
                  @thomas-braun welche Versionen nutzt du? Admin, backitup und js-controller?
                  Gruß Michael
                    Thomas BraunT
                    Thomas BraunT
                    #536
                    @michmein
                    echad@chet:/opt/iobroker $ iobroker update
                    Used repository: live-beta
                    hash unchanged, use cached sources
                    update done
                    Adapter    "admin"         : 5.0.24   , installed 5.0.24
                    Adapter    "alexa2"        : 3.9.0    , installed 3.9.0
                    Adapter    "backitup"      : 2.1.8    , installed 2.1.8
                    Adapter    "ble"           : 0.12.0   , installed 0.12.0
                    Adapter    "cec2"          : 0.1.0    , installed 0.1.0
                    Adapter    "cloud"         : 4.0.11   , installed 4.0.11
                    Adapter    "deconz"        : 1.3.15   , installed 1.3.15
                    Adapter    "devices"       : 0.3.16   , installed 0.3.16
                    Adapter    "echarts"       : 0.4.14   , installed 0.4.14
                    Adapter    "firetv"        : 1.0.0    , installed 1.0.0
                    Adapter    "history"       : 1.9.13   , installed 1.9.13
                    Adapter    "iot"           : 1.8.19   , installed 1.8.19
                    Adapter    "javascript"    : 5.1.3    , installed 5.1.3
                    Controller "js-controller" : 3.3.10   , installed 3.3.10
                    Adapter    "mihome"        : 1.3.7    , installed 1.3.7
                    Adapter    "mihome-vacuum" : 3.1.7    , installed 3.1.7
                    Adapter    "miio"          : 0.0.13   , installed 0.0.13
                    Adapter    "nuki"          : 1.4.4    , installed 1.4.4
                    Adapter    "nuki-extended" : 2.3.0    , installed 2.3.0
                    Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
                    Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                    Adapter    "tado"          : 0.2.7    , installed 0.2.7
                    Adapter    "tr-064"        : 4.2.12   , installed 4.2.12
                    Adapter    "tradfri"       : 2.7.3    , installed 2.7.3
                    Adapter    "vodafone-speedtest": 0.0.6   , installed 0.0.6
                    Adapter    "web"           : 3.4.1    , installed 3.4.1
                    Adapter    "whatsapp-cmb"  : 0.1.6    , installed 0.1.6
                    Adapter    "zigbee"        : 1.5.5    , installed 1.5.5
                    • simatecS simatec
                      ChaotC
                      ChaotC
                      Chaot
                      schrieb am zuletzt editiert von Chaot
                      #537
                      @simatec Bin jetzt auf 2.1.8 - immer noch so.
                      Edit: zusätzlich ist jetzt das ganze Menue verschwunden
                      Zurück auf 2.1.6 - alles wieder da. Eindeutig reproduzierbar.
                      amg_666A simatecS 2 Antworten Letzte Antwort
                      • Dr. BakteriusD
                        Dr. BakteriusD
                        Dr. Bakterius
                        #538
                        @simatec Auch bei mir verschwindet das Menü bei v2.1.8. Dort erhalte ich zuerst bei Aufruf über das Menü den 'null'-Error und nach Umschalt+F5 verschwindet das Menü. Zurück auf v2.1.7 und das Menü ist sofort wieder da, dafür lädt die Seite ewig wenn man backitup über das Menü aufruft. Auch nach Umschalt+F5 bleibt aber das Menü vorhanden.
                        Da spielt admin und backitup irgendwie nicht zusammen...
                        • Bass-TB
                          Bass-TB
                          Bass-T
                          schrieb am zuletzt editiert von Bass-T
                          #539
                          Hi zusammen,
                          habe heute auch mal mal auf admin 5.0.24 geupdated. neues UI ist an.
                          Habe gerade festgestellt dass die CPU last sich verdoppelt hat.
                          Nicht dramatisch, weil auf RasPi4 von rund 20% auf jetzt 40%
                          Ist das bei euch auch so, oder ist da bei mir ein Problem?
                          Proxmox Cluster
                          • NUC7i5 ioBroker Server (Proxmox)
                          • HP Elitedesk 800 G4 SSF (Proxmox)
                          • HP Elitedesk 800 G2 DM (Proxmox)
                            mein Proxmox-Updater für euch
                          KNX / Broadlink / Tasmota ESPs / Zigbee
                          Vis: 15" Touchmonitor mit Raspi4 / 10" Tablet (Dauerstrom umbau) / Sonoff NSPanel (alle)
                          • Bass-TB Bass-T
                            Hi zusammen,
                            Thomas BraunT
                            Thomas BraunT
                            #540
                            @bass-t
                            Nö.
                            top - 17:34:32 up 17:35,  2 users,  load average: 0,99, 0,69, 0,55
                            • gelberlemmyG gelberlemmy
                              @apollon77 Moin ich das Problem wie einige hier, das meine Seitenleiste verschwunden ist. Aber erst nach dem Update auf js controller auf 3.3.10.
                              gelberlemmyG
                              gelberlemmyG
                              gelberlemmy
                              schrieb am zuletzt editiert von gelberlemmy
                              #541
                              @gelberlemmy sagte in Test Adapter Admin 5.0.x: Alpha der neuen UI:
                              So ich habe einmal auf normale Ansicht umgestellt. also nicht die Alpha React UI. Da ist alles wieder in Funktion und die Seitennavigation vorhanden
                              • ChaotC Chaot
                                amg_666A
                                amg_666A
                                amg_666
                                #542
                                @chaot Gleiches Verhalten bei mir, Proxmox mit Debian10, getestet mit Firefox, Opera, Chrome und Edge.
                                Menuleiste links ist immer leer, FF Konsole sagt
                                [2021-05-15T18:09:51.307Z] ws connection error: CLOSE_GOING_AWAY instrument.ts:129:35
                                [2021-05-15T18:09:51.336Z] Start reconnect 0 instrument.ts:129:35
                                [2021-05-15T18:09:51.352Z] Try to connect instrument.ts:129:35
                                Diese Seite verwendet die nicht standardisierte Eigenschaft "zoom". Stattdessen sollte calc() in den entsprechenden Eigenschaftswerten oder "transform" zusammen mit "transform-origin: 0 0" verwendet werden. 192.168.2.23:8081
                                iobroker.admin@5.0.24 index.js:18:8
                                [2021-05-15T18:09:51.678Z] Try to connect instrument.ts:129:35
                                Die drawWindow-Methode von CanvasRenderingContext2D ist veraltet. Verwenden Sie stattdessen die Erweiterungs-API tabs.captureTab https://developer.mozilla.org/docs/Mozilla/Add-ons/WebExtensions/API/tabs/captureTab pagedata-script.js:1:5791
                                Uncaught (in promise) TypeError: o is undefined
                                • ChaotC Chaot
                                  simatecS
                                  simatecS
                                  simatec
                                  #543
                                  @chaot das mag sein, dass es vei dir so reproduzierbar ist, aber mir sind da aktuell die Hände gebunden.
                                  Backitup läuft ohne react und die Tableiste wird vom admin erzeugt und nicht von Backitup.
                                  Ich habe da keinen Ansatz und bisher leider auch keine Unterstützung zur Problemfindung im Zusammenspiel mit den Anforderungen oder letzten Änderungen im Admin bekommen.
                                  Laut dem Log im Issue würde ich mal folgendes versuchen.
                                  Gehe mal zurück auf 2.1.6 und nimm dann mal in der Tableiste den Hacken raus.
                                  Dann mach ein Update auf 2.1.8 und setze den Hacken wieder.
                                  Sollte danach die Leiste noch immer weg sein, starte den Admin mal neu
                                  ChaotC sigi234S E 4 Antworten Letzte Antwort
                                  • simatecS simatec
                                    ChaotC
                                    ChaotC
                                    Chaot
                                    #544
                                    @simatec Mach dir mal keinen Kopf drum. Ich nutze wie gesagt den Backitup Adapter nicht aktiv. Ich wollte dir mit der Fehlerbeschreibung nur helfen wo du eventuell suchen musst.
                                    Ich werde morgen mal deine Vorschlag testen und dir wieder melden was das bewirkt hat. Aber vollkommen ohne Stress.
                                    • simatecS simatec
                                      sigi234S
                                      sigi234S
                                      #545
                                      @simatec
                                      @Chaot
                                      Selbe Verhalten bei mir, gehe ich zurück auf Version 2.1.7 ist das Menü da, bei 2.1.8 nicht mehr.
                                      Bei 2.1.7 kommt keine Anzeige vom Adapter.
                                      • sigi234S sigi234
                                        @simatec
                                        @Chaot
                                        simatecS
                                        simatecS
                                        simatec
                                        #546
                                        @sigi234 sagte in Test Adapter Admin 5.0.x: Alpha der neuen UI:
                                        @simatec
                                        @Chaot
                                        Das wurde im 2.1.8 geändert.
                                        Kannst du mal mit 2.1.7 den Hacken für Backup in der Tableiste rausnehmen und dann auf 2.1.8 updaten?
                                        Dann in der Tableiste wieder den Hacken setzen.
                                        Und mal berichten, ob es dann läuft
                                        • simatecS simatec
                                          E
                                          E
                                          e-s
                                          schrieb am zuletzt editiert von e-s
                                          #547
                                          @simatec
                                          Habe jetzt auch mehrfach von 2.1.7 auf 2.1.8 gewechselt, dabei ist es völlig egal ob backitup in der linken Liste aktiviert wurde oder nicht. Mit 2.1.8 ist die Liste nicht da.
                                          Edit: also genau so wie du es getestet haben wolltest.
                                          83.9k
