  4. BLE Adapter beleibt gelb
    apollon77A
123 Beiträge 6 Kommentatoren 21.6k Aufrufe 5 Beobachtet
  • S
    S
    SmartVerwalter
    #75
    pi@raspberrypi:~ $ dmesg -t
    Booting Linux on physical CPU 0x0
    Linux version 5.10.17-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:29:51 GMT 2021
    CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
    CPU: div instructions available: patching division code
    CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
    Memory policy: Data cache writealloc
    Reserved memory: created CMA memory pool at 0x37400000, size 64 MiB
    OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    Zone ranges:
      DMA      [mem 0x0000000000000000-0x000000003b3fffff]
      Normal   empty
    Movable zone start for each node
    Early memory node ranges
      node   0: [mem 0x0000000000000000-0x000000003b3fffff]
    Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
    On node 0 totalpages: 242688
      DMA zone: 2133 pages used for memmap
      DMA zone: 0 pages reserved
      DMA zone: 242688 pages, LIFO batch:63
    percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
    pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
    pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    Built 1 zonelists, mobility grouping on.  Total pages: 240555
    Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=daa6e722-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    Kernel parameter elevator= does not have any effect anymore.
    Please use sysfs to set IO scheduler for individual devices.
    Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    mem auto-init: stack:off, heap alloc:off, heap free:off
    Memory: 879832K/970752K available (9216K kernel code, 1311K rwdata, 2940K rodata, 1024K init, 860K bss, 25384K reserved, 65536K cma-reserved)
    SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    ftrace: allocating 31910 entries in 63 pages
    ftrace: allocated 63 pages with 6 groups
    rcu: Hierarchical RCU implementation.
            Rude variant of Tasks RCU enabled.
            Tracing variant of Tasks RCU enabled.
    rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    random: get_random_bytes called from start_kernel+0x3ac/0x580 with crng_init=0
    arch_timer: cp15 timer(s) running at 19.20MHz (phys).
    clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
    sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
    Switching to timer-based delay loop, resolution 52ns
    Console: colour dummy device 80x30
    printk: console [tty1] enabled
    Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
    pid_max: default: 32768 minimum: 301
    LSM: Security Framework initializing
    Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    Disabling memory control group subsystem
    CPU: Testing write buffer coherency: ok
    CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    Setting up static identity map for 0x100000 - 0x10003c
    rcu: Hierarchical SRCU implementation.
    smp: Bringing up secondary CPUs ...
    CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    smp: Brought up 1 node, 4 CPUs
    SMP: Total of 4 processors activated (153.60 BogoMIPS).
    CPU: All CPU(s) started in HYP mode.
    CPU: Virtualization extensions available.
    devtmpfs: initialized
    VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
    clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    pinctrl core: initialized pinctrl subsystem
    NET: Registered protocol family 16
    DMA: preallocated 1024 KiB pool for atomic coherent allocations
    audit: initializing netlink subsys (disabled)
    audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
    thermal_sys: Registered thermal governor 'step_wise'
    hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    hw-breakpoint: maximum watchpoint size is 8 bytes.
    Serial: AMBA PL011 UART driver
    bcm2835-mbox 3f00b880.mailbox: mailbox enabled
    raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:12:09, variant start
    raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
    bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
    SCSI subsystem initialized
    usbcore: registered new interface driver usbfs
    usbcore: registered new interface driver hub
    usbcore: registered new device driver usb
    clocksource: Switched to clocksource arch_sys_counter
    VFS: Disk quotas dquot_6.6.0
    VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    FS-Cache: Loaded
    CacheFiles: Loaded
    NET: Registered protocol family 2
    tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
    TCP: Hash tables configured (established 8192 bind 8192)
    UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    RPC: Registered named UNIX socket transport module.
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    RPC: Registered tcp NFSv4.1 backchannel transport module.
    hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
    Initialise system trusted keyrings
    workingset: timestamp_bits=14 max_order=18 bucket_order=4
    zbud: loaded
    FS-Cache: Netfs 'nfs' registered for caching
    NFS: Registering the id_resolver key type
    Key type id_resolver registered
    Key type id_legacy registered
    nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    Key type asymmetric registered
    Asymmetric key parser 'x509' registered
    Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
    io scheduler mq-deadline registered
    io scheduler kyber registered
    bcm2708_fb soc:fb: FB found 1 display(s)
    Console: switching to colour frame buffer device 82x26
    bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
    bcm2835-rng 3f104000.rng: hwrng registered
    vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
    gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
    brd: module loaded
    loop: module loaded
    Loading iSCSI transport class v2.0-870.
    libphy: Fixed MDIO Bus: probed
    usbcore: registered new interface driver lan78xx
    usbcore: registered new interface driver smsc95xx
    dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    Core Release: 2.80a
    Setting default values for core params
    Finished setting default values for core params
    Using Buffer DMA mode
    Periodic Transfer Interrupt Enhancement - disabled
    Multiprocessor Interrupt Enhancement - disabled
    OTG VER PARAM: 0, OTG VER FLAG: 0
    Dedicated Tx FIFOs mode
    WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b7514000 dma = 0xf7514000 len=9024
    FIQ FSM acceleration enabled for :
    Non-periodic Split Transactions
    Periodic Split Transactions
    High-Speed Isochronous Endpoints
    Interrupt/Control Split Transaction hack enabled
    dwc_otg: Microframe scheduler enabled
    WARN::hcd_init_fiq:457: FIQ on core 1
    WARN::hcd_init_fiq:458: FIQ ASM at 807be568 length 36
    WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
    dwc_otg 3f980000.usb: DWC OTG Controller
    dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
    dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
    Init: Port Power? op_state=1
    Init: Power Port (0)
    usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    usb usb1: Product: DWC OTG Controller
    usb usb1: Manufacturer: Linux 5.10.17-v7+ dwc_otg_hcd
    usb usb1: SerialNumber: 3f980000.usb
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    dwc_otg: FIQ enabled
    dwc_otg: NAK holdoff enabled
    dwc_otg: FIQ split-transaction FSM enabled
    Module dwc_common_port init
    usbcore: registered new interface driver usb-storage
    mousedev: PS/2 mouse device common for all mice
    bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    sdhci: Secure Digital Host Controller Interface driver
    sdhci: Copyright(c) Pierre Ossman
    mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
    sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
    sdhci-pltfm: SDHCI platform and OF driver helper
    ledtrig-cpu: registered to indicate activity on CPUs
    hid: raw HID events driver (C) Jiri Kosina
    usbcore: registered new interface driver usbhid
    usbhid: USB HID core driver
    Initializing XFRM netlink socket
    NET: Registered protocol family 17
    Key type dns_resolver registered
    Registering SWP/SWPB emulation handler
    registered taskstats version 1
    Loading compiled-in X.509 certificates
    Key type ._fscrypt registered
    Key type .fscrypt registered
    Key type fscrypt-provisioning registered
    uart-pl011 3f201000.serial: cts_event_workaround enabled
    3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
    bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
    mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
    mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
    sdhost: log_buf @ (ptrval) (f7513000)
    mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
    of_cfs_init
    of_cfs_init: OK
    Waiting for root device PARTUUID=daa6e722-02...
    Indeed it is in host mode hprt0 = 00021501
    random: fast init done
    mmc0: host does not support reading read-only switch, assuming write-enable
    mmc1: new high speed SDIO card at address 0001
    mmc0: new high speed SDHC card at address aaaa
    mmcblk0: mmc0:aaaa SB32G 29.7 GiB
     mmcblk0: p1 p2
    EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    usb 1-1: new high-speed USB device number 2 using dwc_otg
    Indeed it is in host mode hprt0 = 00001101
    usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
    usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    hub 1-1:1.0: USB hub found
    hub 1-1:1.0: 4 ports detected
    usb 1-1.1: new high-speed USB device number 3 using dwc_otg
    usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
    usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    hub 1-1.1:1.0: USB hub found
    hub 1-1.1:1.0: 3 ports detected
    usb 1-1.2: new full-speed USB device number 4 using dwc_otg
    usb 1-1.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
    usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    usb 1-1.2: Product: ConBee II
    usb 1-1.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
    usb 1-1.2: SerialNumber: DE2413713
    EXT4-fs (mmcblk0p2): recovery complete
    EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    devtmpfs: mounted
    Freeing unused kernel memory: 1024K
    Run /sbin/init as init process
      with arguments:
        /sbin/init
      with environment:
        HOME=/
        TERM=linux
    usb 1-1.1.1: new high-speed USB device number 5 using dwc_otg
    usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
    usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
    libphy: lan78xx-mdiobus: probed
    systemd[1]: System time before build time, advancing clock.
    lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
    NET: Registered protocol family 10
    Segment Routing with IPv6
    systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
    systemd[1]: Detected architecture arm.
    systemd[1]: Set hostname to <raspberrypi>.
    random: systemd: uninitialized urandom read (16 bytes read)
    systemd[1]: Reached target Swap.
    systemd[1]: Listening on udev Kernel Socket.
    systemd[1]: Listening on udev Control Socket.
    systemd[1]: Listening on initctl Compatibility Named Pipe.
    systemd[1]: Listening on Journal Socket.
    systemd[1]: Starting Set the console keyboard layout...
    systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
    EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    usb 1-1.2: USB disconnect, device number 4
    systemd-journald[121]: Received request to flush runtime journal from PID 1
    usb 1-1.2: new full-speed USB device number 6 using dwc_otg
    vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [vc_sm_connected_init]: start
    [vc_sm_connected_init]: installed successfully
    mc: Linux media interface: v0.10
    snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    videodev: Linux video capture interface: v2.00
    bcm2835_audio bcm2835_audio: card created with 8 channels
    bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
    bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
    bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
    bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
    bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
    bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
    usbcore: registered new interface driver cdc_acm
    cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
    cfg80211: Loading compiled-in X.509 certificates for regulatory database
    cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    brcmfmac: F1 signature read @0x18000000=0x15264345
    brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    usbcore: registered new interface driver brcmfmac
    brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,3-model-b-plus.txt failed with error -2
    brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
    Under-voltage detected! (0x00050005)
    uart-pl011 3f201000.serial: no DMA platform data
    random: crng init done
    random: 7 urandom warning(s) missed due to ratelimiting
    Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
    8021q: 802.1Q VLAN Support v1.8
    brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
    8021q: adding VLAN 0 to HW filter on device eth0
    IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
    Bluetooth: Core ver 2.22
    NET: Registered protocol family 31
    Bluetooth: HCI device and connection manager initialized
    Bluetooth: HCI socket layer initialized
    Bluetooth: L2CAP socket layer initialized
    Bluetooth: SCO socket layer initialized
    pi@raspberrypi:~ $
    • S SmartVerwalter
      Zone ranges:
        Normal   empty
      FS-Cache: Loaded
      CacheFiles: Loaded
      zbud: loaded
      brd: module loaded
      loop: module loaded
      Core Release: 2.80a
      of_cfs_init
      of_cfs_init: OK
       mmcblk0: p1 p2
      devtmpfs: mounted
        with arguments:
          /sbin/init
        with environment:
          HOME=/
          TERM=linux
      pi@raspberrypi:~ $
      wendy2702W
      wendy2702W
      #76
      @smartverwalter
      systemctl status bluetooth
      systemctl status hciuart.service
      • S
        S
        SmartVerwalter
        #77
        ● bluetooth.service - Bluetooth service
           Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset
           Active: inactive (dead)
             Docs: man:bluetoothd(8)
        ...skipping...
        • S
          S
          SmartVerwalter
          #78
          @wendy2702 said in BLE Adapter beleibt gelb:
          pi@raspberrypi:~ $
          pi@raspberrypi:~ $ systemctl status hciuart.service
          ● hciuart.service - Configure Bluetooth Modems connected by UART
             Loaded: loaded (/lib/systemd/system/hciuart.service; enabled; vendor preset:
             Active: failed (Result: exit-code) since Sun 2021-03-07 17:20:59 CET; 57min a
            Process: 328 ExecStart=/usr/bin/btuart (code=exited, status=1/FAILURE)
          Mar 07 17:20:59 raspberrypi btuart[328]: Failed to set bdaddr, command failure
          Mar 07 17:20:59 raspberrypi btuart[328]: Failed to update baudrate, invalid HCI
          Mar 07 17:20:59 raspberrypi btuart[328]: Can't initialize device: Success
          Mar 07 17:20:59 raspberrypi btuart[328]: bcm43xx_init
          Mar 07 17:20:59 raspberrypi btuart[328]: Flash firmware /lib/firmware/brcm/BCM43
          Mar 07 17:20:59 raspberrypi btuart[328]: Set BDADDR UART: b8:27:eb:33:de:ec
          Mar 07 17:20:59 raspberrypi btuart[328]: Set Controller UART speed to 3000000 bi
          Mar 07 17:20:59 raspberrypi systemd[1]: hciuart.service: Control process exited,
          Mar 07 17:20:59 raspberrypi systemd[1]: hciuart.service: Failed with result 'exi
          Mar 07 17:20:59 raspberrypi systemd[1]: Failed to start Configure Bluetooth Mode
          lines 1-15/15 (END)
          • S SmartVerwalter
            pi@raspberrypi:~ $
            lines 1-15/15 (END)
            wendy2702W
            wendy2702W
            #79
            @smartverwalter Leider ist rechts das Log abgeschnitten.
            sudo systemctl start bluetooth
            sudo systemctl status bluetooth
            sudo systemctl status hciuart
            • S
              S
              SmartVerwalter
              #80
              upps
              hatte die letze Nachricht gar nicht mehr gesehen.
              Jetzt hab ich glaub ich noch grösseren Mist gebaut.
              Habe für ein zweites Projekt noch einen pi gekauft,
              eigentlich identisch.
              Seitdem ich die SD Karte mal in den anderen PI getan habe
              läßt sich Io Broker nicht mehr über html starten.
              In beiden PI s nicht.
              Die Karte scheint aber okay zu sein, auf die Dekonz Adapter sSoftware
              kann ich zugreifen.
              • S SmartVerwalter
                upps
                kann ich zugreifen.
                Thomas BraunT
                Thomas BraunT
                Most Active Developer
                #81
                @smartverwalter
                iobroker status
                iobroker list adapters
                iobroker list instances
                • S
                  S
                  SmartVerwalter
                  #82
                  pi@raspberrypi:~ $ iobroker status
                   Cannot read system.config: null (OK when migrating or restoring)
                   Cannot find view "system" for search "host"
                  Objects type: file
                  States  type: file
                  pi@raspberrypi:~ $ iobroker list adapters
                  pi@raspberrypi:~ $ iobropker list instances
                  -bash: iobropker: command not found
                  pi@raspberrypi:~ $ pi@raspberrypi:~ $ iobroker status
                  -bash: pi@raspberrypi:~: command not found
                  pi@raspberrypi:~ $  Cannot read system.config: null (OK when migrating or restor                                                      ing)
                  -bash: syntax error near unexpected token `('
                  pi@raspberrypi:~ $  Cannot find view "system" for search "host"
                  -bash: Cannot: command not found
                  pi@raspberrypi:~ $ iobroker is running on this host.
                  iobroker [command]
                  • S SmartVerwalter
                    Objects type: file
                    States  type: file
                    iobroker [command]
                    Thomas BraunT
                    Thomas BraunT
                    #83
                    @smartverwalter
                    Aktuelles Backup zur Hand?
                    • S
                      S
                      SmartVerwalter
                      #84
                      pi@raspberrypi:~ $ iobroker list instances
                      + instance is alive
                      pi@raspberrypi:~ $
                      • S
                        S
                        SmartVerwalter
                        #85
                        wenn er es nicht automatisch macht, dann leider nicht
                        • S SmartVerwalter
                          Thomas BraunT
                          Thomas BraunT
                          #86
                          @smartverwalter
                          Das ist ganz schlecht.
                          Und du hast nur die Karte von einem zum anderen System getragen?
                          • S
                            S
                            SmartVerwalter
                            #87
                            ich hatte vorher vergeblich versucht die android vis app zu installieren, aber danach lief er eigentlich noch
                            • S SmartVerwalter
                              Thomas BraunT
                              Thomas BraunT
                              #88
                              @smartverwalter
                              Immer ganz sauber herunter gefahren oder hart vom Strom genommen, die Kisten? (Oder noch schlimmer die Karte im laufenden System rausgerupft?)
                              • S
                                S
                                SmartVerwalter
                                #89
                                wenn dann nicht bewusst.
                                • S
                                  S
                                  SmartVerwalter
                                  #90
                                  d.h neu installieren?
                                  • S SmartVerwalter
                                    J
                                    J
                                    Jan1
                                    #91
                                    @smartverwalter sagte in BLE Adapter beleibt gelb:
                                    Wenn man das schon nicht sicher ausschließen kann, dann wirds wohl das Beste sein Du machst das Ding neue und verwendest mal den Backitup Adapter, da der bei so was in ca. 30 Minuten alles wieder hat wie vorher. So lange gilt, kein Backup, kein Mitleid.
                                    • S
                                      S
                                      SmartVerwalter
                                      #92
                                      ich freu mich
                                      okay vorher deinstallieren, oder einfach neu installieren?
                                      J Thomas BraunT 2 Antworten Letzte Antwort
                                      • S SmartVerwalter
                                        ich freu mich
                                        J
                                        J
                                        Jan1
                                        #93
                                        @smartverwalter
                                        Was ist denn bei "neu machen" nicht verständlich?
                                        • S SmartVerwalter
                                          ich freu mich
                                          Thomas BraunT
                                          Thomas BraunT
                                          #94
                                          @smartverwalter Eins können wir noch probieren:
                                          ls -la /opt/iobroker/iobroker-data/backup-objects/
                                          84.1k
