  4. Test Adapter doorio v2.1.2
    apollon77A
door intercomdoorpitürsprechstelle
590 Beiträge 36 Kommentatoren 227.2k Aufrufe 39 Beobachtet
  • R Renegade 0
    @wal
    Das Gerät gerade ist ein RPI 4 CM mit 8GB Ram und 32 MB eMMC.
    Ziel #1
            Status: SUSPENDED
            Beschreibung: Audio Adapter (Unitek Y-247A) Analog Stereo
            Treiber: module-alsa-card.c
            Abtastwert-Angabe: s16le 2ch 48000Hz
            Kanalzuordnung: front-left,front-right
            Besitzer-Modul: 14
            Stumm: nein
            Lautstärke: front-left: 30419 /  46% / -20,00 dB,   front-right: 30419 /  46% / -20,00 dB
                    Verteilung 0,00
            Basis-Lautstärke: 65536 / 100% / 0,00 dB
            Quellen-Monitor: alsa_output.usb-C-Media_Electronics_Inc._USB_Audio_Device-00.analog-stereo.monitor
            Latenz: 0 usec, eingestellt 0 usec
            Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
            Eigenschaften:
                    alsa.resolution_bits = "16"
                    device.api = "alsa"
                    device.class = "sound"
                    alsa.class = "generic"
                    alsa.subclass = "generic-mix"
                    alsa.name = "USB Audio"
                    alsa.id = "USB Audio"
                    alsa.subdevice = "0"
                    alsa.subdevice_name = "subdevice #0"
                    alsa.device = "0"
                    alsa.card = "1"
                    alsa.card_name = "USB Audio Device"
                    alsa.long_card_name = "C-Media Electronics Inc. USB Audio Device at usb-fe980000.usb-1.2.2, full speed"
                    alsa.driver_name = "snd_usb_audio"
                    device.bus_path = "platform-fe980000.usb-usb-0:1.2.2:1.0"
                    sysfs.path = "/devices/platform/soc/fe980000.usb/usb1/1-1/1-1.2/1-1.2.2/1-1.2.2:1.0/sound/card1"
                    udev.id = "usb-C-Media_Electronics_Inc._USB_Audio_Device-00"
                    device.bus = "usb"
                    device.vendor.id = "0d8c"
                    device.vendor.name = "C-Media Electronics, Inc."
                    device.product.id = "0014"
                    device.product.name = "Audio Adapter (Unitek Y-247A)"
                    device.serial = "C-Media_Electronics_Inc._USB_Audio_Device"
                    device.string = "front:1"
                    device.buffering.buffer_size = "352800"
                    device.buffering.fragment_size = "176400"
                    device.access_mode = "mmap+timer"
                    device.profile.name = "analog-stereo"
                    device.profile.description = "Analog Stereo"
                    device.description = "Audio Adapter (Unitek Y-247A) Analog Stereo"
                    alsa.mixer_name = "USB Mixer"
                    alsa.components = "USB0d8c:0014"
                    module-udev-detect.discovered = "1"
                    device.icon_name = "audio-card-usb"
            Ports:
                    analog-output: Analoge Ausgabe (priority: 9900)
            Aktiver Port: analog-output
            Formate:
                    pcm
    Quelle #1
            Status: SUSPENDED
            Name: alsa_output.usb-C-Media_Electronics_Inc._USB_Audio_Device-00.analog-stereo.monitor
            Beschreibung: Monitor of Audio Adapter (Unitek Y-247A) Analog Stereo
            Besitzer-Modul: 14
            Stumm: nein
            Lautstärke: front-left: 65536 / 100% / 0,00 dB,   front-right: 65536 / 100% / 0,00 dB
                    Verteilung 0,00
            Ziel-Monitor: alsa_output.usb-C-Media_Electronics_Inc._USB_Audio_Device-00.analog-stereo
            Flags: DECIBEL_VOLUME LATENCY
            Eigenschaften:
                    device.description = "Monitor of Audio Adapter (Unitek Y-247A) Analog Stereo"
                    device.class = "monitor"
                    alsa.card = "1"
                    device.bus = "usb"
                    device.string = "1"
            Formate:
                    pcm
    Quelle #2
            Status: SUSPENDED
            Beschreibung: Audio Adapter (Unitek Y-247A) Analog Mono
            Abtastwert-Angabe: s16le 1ch 44100Hz
            Kanalzuordnung: mono
            Besitzer-Modul: 14
            Stumm: nein
            Lautstärke: mono: 36854 /  56% / -15,00 dB
                    Verteilung 0,00
            Basis-Lautstärke: 27111 /  41% / -23,00 dB
            Ziel-Monitor: k. A.
            Eigenschaften:
                    device.api = "alsa"
                    alsa.device = "0"
                    alsa.card = "1"
                    device.bus = "usb"
                    device.string = "hw:1"
                    device.buffering.buffer_size = "176400"
                    device.buffering.fragment_size = "88200"
                    device.profile.name = "analog-mono"
                    device.profile.description = "Analog Mono"
                    device.description = "Audio Adapter (Unitek Y-247A) Analog Mono"
            Ports:
                    analog-input-mic: Mikrofon (priority: 8700)
            Aktiver Port: analog-input-mic
            Formate:
                    pcm
    WalW
    WalW
    Wal
    #439
    @renegade-0 ,
    load-module module-echo-cancel aec_method=webrtc format=s16le rate=16000 channels=1 source_name="noecho.mic_in" sink_name="noecho.sound_out" sink_master="alsa_output.usb-C-Media_Electronics_Inc._USB_Audio_Device-00.analog-stereo" source_master="alsa_input.usb-C-Media_Electronics_Inc._USB_Audio_Device-00.analog-mono"
    set-default-sink noecho.sound_out
    set-default-source noecho.mic_in
    Walter
    DoorIO-Adapter
    R 1 Antwort Letzte Antwort
    • M
      M
      MHeymann
      #440
      Moin Moin,
      ich hab da mal wieder ein Problem. Ich habe baresip mit meiner FritzBox 7590 als Türsprechanlage verbunden. Wenn ich einen Anruf von außerhalb bekomme nimmt sofort die Türsprechanlage das Gespräch an und meine beiden FritsFon´s machen keinen pip. Wenn ich in der account Datei von baresip den answermode entferne sagt eine nette Dame auf englisch das es klingelt wenn ein Gespräch eingeht. Die FritzFon´s klingeln dann aber ganz normal und ich kann das Gespräch entgegen nehmen. Bei der Konfiguration der Türsprechanlage in der FritzBox wird die Rufbehandlung für ankommende Anrufe auf alle gesetzt. Das kann ich da auch nicht ändern.
      Hat jemand ne Ahnung wie ich das beheben kann?
      lg Marko
      WalW 1 Antwort Letzte Antwort
      • M MHeymann
        Moin Moin,
        lg Marko
        WalW
        WalW
        Wal
        #441
        @mheymann,
        der Anruf von außerhalb ruft bewusst die Türsprechstelle an ?
        Walter
        DoorIO-Adapter
        • WalW Wal
          @mheymann,
          M
          M
          MHeymann
          #442
          @wal
          Nein. Ich habe nur eine Festnetznummer und wenn ich die z.B. mit meinem Handy anrufe geht automatisch die Türsprechstelle ran.
          • M MHeymann
            @wal
            WalW
            WalW
            Wal
            #443
            @mheymann,
            dann stelle das doch in der Fritzbox ab, einfach keine Nummer setzen.
            Walter
            DoorIO-Adapter
            • WalW Wal
              @mheymann,
              M
              M
              MHeymann
              #444
              @wal
              Jep. Würde ich ja gerne. Aber beim erstellen kann ich da nichts ändern und im nachhinein kann ich das auch nicht ändern. Die Fritte setzt automatisch "alle".
              WalW M 2 Antworten Letzte Antwort
              • M MHeymann
                @wal
                WalW
                WalW
                Wal
                #445
                @mheymann ,
                hast du die Sprechstelle als IP-Telefon oder als IP-Türsprechstelle konfiguriert ?
                Walter
                DoorIO-Adapter
                • M MHeymann
                  @wal
                  M
                  M
                  MHeymann
                  #446
                  OMG ich werd noch weich!!! Hab gerade zum x ten mal ne neue Türsprechanlage erstellt und plötzlich werden keine Nummern weder für eingehende noch für ausgehende Anrufe gesetzt.
                  Ich werde dann mal eben alles eintüdeln und berichten.
                  • WalW Wal
                    @mheymann ,
                    M
                    M
                    MHeymann
                    #447
                    @wal
                    Geht wieder alle. Keine Ahnung warum das auf einmal funktionierte beim erneuten erstellen der Türsprechanlage. Hatte das schon ein paar mal probiert. Das merkwürdige war auch das sich das mit den eingehenden Anrufen wohl irgendwie bei nem Update der Fritte geändert hat oder so. Ich habe da nie irgendwelche Einstellungen im nachhinein geändert und am Funktionierte alles ganz normal. Hatte mich nur irgendwann gefragt warum uns keiner mehr anruft. Bis meine Schwiegermutter irgendwann vor ein paar Tagen fragte was den mit unserem Telefon los ist. Jedes mal wenn sie uns anruft würde es nicht klingeln aber sie würde Vogelgezwitscher und Autos hören. :man-facepalming:
                    Naja nü geht ja wieder alles.
                    Danke für deine Hilfe
                    LG Marko
                    • WalW Wal
                      @renegade-0 ,
                      R
                      R
                      Renegade 0
                      #448
                      @wal
                      hab ich ausgetauscht, aber selber Fehler im Image.
                      Mär 07 19:53:56 raspberrypi pulseaudio[405]: Failed to open cookie file '/var/run/pulse/.config/pulse/cookie': Datei oder Verzeichnis nicht ge
                      Mär 07 19:53:56 raspberrypi pulseaudio[405]: Failed to load authentication key '/var/run/pulse/.config/pulse/cookie': Datei oder Verzeichnis n
                      Mär 07 19:53:56 raspberrypi pulseaudio[405]: Failed to open cookie file '/var/run/pulse/.pulse-cookie': Datei oder Verzeichnis nicht gefunden
                      Mär 07 19:53:56 raspberrypi pulseaudio[405]: Failed to load authentication key '/var/run/pulse/.pulse-cookie': Datei oder Verzeichnis nicht ge
                      Mär 07 19:53:56 raspberrypi pulseaudio[405]: socket(PF_INET6): Die Adressfamilie wird von der Protokollfamilie nicht unterstützt
                      Mär 07 19:53:56 raspberrypi pulseaudio[405]: Master source not found
                      Mär 07 19:53:56 raspberrypi pulseaudio[405]: Failed to load module "module-echo-cancel" (argument: "aec_method=webrtc format=s16le rate=16000
                      Mär 07 19:53:56 raspberrypi pulseaudio[405]: Sink noecho.sound_out does not exist.
                      Mär 07 19:53:56 raspberrypi pulseaudio[405]: Source noecho.mic_in does not exist.
                      Mär 07 19:53:56 raspberrypi systemd[1]: Started PulseAudio Sound System.
                      Hab mich genau an deine Anleitung gehalten. Nur, dass ich die IP-Adresse noch auf mein Netz angepasst hab.
                      • R Renegade 0
                        @wal
                        WalW
                        WalW
                        Wal
                        schrieb am zuletzt editiert von Wal
                        #449
                        @renegade-0 ,
                        habe jetzt alles mit dem aktuellen RPI-OS-Lite getestet und du hast recht, es funktioniert nicht mehr.
                        Jetzt habe ich nochmal alles mit dem RPI-OS Desktop versucht und den Desktop über "sudo raspi-config" abgeschaltet, danach nicht die system dot pa sondern die default dot pa editiert und da funktioniert es.
                        Hintergrund ist das im Desktop-Image Pulseaudio schon installiert ist.
                        Versuche es mal mit dem Desktop-Image und den XServer ausschalten und melde dich noch einmal.
                        Walter
                        DoorIO-Adapter
                        • WalW Wal
                          @renegade-0 ,
                          R
                          R
                          Renegade 0
                          #450
                          @wal
                          den xserver brauche ich ja für die vis. Habe dein img um mjpg und xserver (Kiosk-Modus) erweitert. Das war quasi die gewünschte Konfig. Also fehlt uns irgendein Paket vom pulse vermute ich mal.
                          Ich versteh gerade nur Zeile 5 nicht. Den socket(PF_INET6): error.
                          Bin auf der Suche nach einem kuriosen Fehler. auf dem Pi 4 CM klingelt es bei einem Anruf, aber wenn ich annehme, ist keine Sprache da. Mikro geht aber. WEnn ich den BT-Lautsprecher kopple, geht beides.
                          • R Renegade 0
                            @wal
                            WalW
                            WalW
                            Wal
                            #451
                            @renegade-0 ,
                            da legst du dich nieder.
                            Habe eben mit dem aktuellen lite getestet und das funzt auch.
                            Man muss nur pulseaudio installieren und die default dot pa ändern. Man braucht auch kein Service mehr installieren, der ist dann schon als User Service installiert.
                            Walter
                            DoorIO-Adapter
                            • WalW Wal
                              @renegade-0 ,
                              R
                              R
                              Renegade 0
                              schrieb am zuletzt editiert von Renegade 0
                              #452
                              @wal
                              wie jetzt? Buster-Lite drauf, dann apt update und dann nur apt install pulseaudio und läuft?
                              Hab ich vor 3 Tagen für den Versuchsaufbau gemacht, aber da war unter systemctl kein pulseaudio dann.
                              • R Renegade 0
                                @wal
                                WalW
                                WalW
                                Wal
                                #453
                                @renegade-0 ,
                                ja so ist es,mit dem neuen RPI-OS-Installer eine Lite SD-Karte erzeugen und pulseaudio installieren.
                                Ein Systemctl gibt es nicht, da pulseaudio im usermode nur geladen wird wenn es gebraucht wird. Versuch es mal und mach ein "pactl list" es funktioniert.
                                Walter
                                DoorIO-Adapter
                                • WalW Wal
                                  @renegade-0 ,
                                  R
                                  R
                                  Renegade 0
                                  #454
                                  @wal
                                  Stimmt. Pulseaudio ist da. Ton auch. Wohin geht dann das Journal? Pulse lief auch bei deinem Image, aber das AEC startete nicht.
                                  Hab nämlich immer noch das Problem, dass beim CM zwar "der ringtone" kommt, aber leider keine Sprachübertragung. Der PI4 und der Zero W laufen aber korrekt.
                                  • R Renegade 0
                                    @wal
                                    WalW
                                    WalW
                                    Wal
                                    #455
                                    @renegade-0 ,
                                    was sagt Baresip zum Problem ?
                                    Falls Baresip als Dienst läuft mit "sudo systemctl stop baresip" beenden und mit "baresip -vvv" starten, danach sehen was die Console nach dem abheben spricht.
                                    edit: falls du die default.pa von pulseaudio schon eingestellt hast, muss nach einem "pactl list" das noecho.sound_out als Ziel zu sehen sein.
                                    Walter
                                    DoorIO-Adapter
                                    • WalW Wal
                                      @renegade-0 ,
                                      R
                                      R
                                      Renegade 0
                                      #456
                                      @wal
                                      der TestPI (RPi 4)
                                      All 1 useragent registered successfully! (7 ms)
                                      sip:IP-TestPI@192.168.33.70: Incoming call from: Testphone sip:**610@fritz.box - (press 'a' to accept)
                                      sip:IP-TestPI@192.168.33.70: Answering incoming call
                                      answering call from sip:**610@fritz.box with 200
                                      audio: Set audio decoder: PCMA 8000Hz 1ch
                                      audio: player started with sample format S16LE
                                      audio: Set audio encoder: PCMA 8000Hz 1ch
                                      audio: source started with sample format S16LE
                                      audio tx pipeline:        alsa ---> vumeter ---> PCMA
                                      audio rx pipeline:        alsa <--- vumeter <--- PCMA
                                      IP-TestPI@192.168.33.70: Call established: sip:**610@fritz.box
                                      stream: incoming rtp for 'audio' established, receiving from 192.168.33.70:7082
                                      [0:00:00] audio=0/0 (bit/s)                                 [=               ]  [0:00:01] audio=0/0 (bit/s)                                 [                ]
                                      Die SmartBox ( RPi 4 CM auf IO Board)
                                      sip:IP-SmartBox@192.168.33.70: Incoming call from: Testphone sip:**610@fritz.box - (press 'a' to accept)
                                      sip:IP-SmartBox@192.168.33.70: Answering incoming call
                                      IP-SmartBox@192.168.33.70: Call established: sip:**610@fritz.box
                                      stream: incoming rtp for 'audio' established, receiving from 192.168.33.70:7086
                                      [0:00:00] audio=0/0 (bit/s)                                 [====            ]
                                      Mir fällt auf, dass die 2. [ ] bei der Smartbox fehlen. Das seltsame ist, Audio geht grundsätzlich.
                                      • R Renegade 0
                                        @wal
                                        der TestPI (RPi 4)
                                        WalW
                                        WalW
                                        Wal
                                        #457
                                        @renegade-0 ,
                                        mach mal den "alsamixer" auf, nicht das das Micro gemutet ist. Der Log sieht gut aus, aber bei mir steht immer was von pulse dabei.
                                        Ist in der Baresip-Konfig das Modul alsa.so ausgeblendet und pulse.so eingeblendet ?
                                        Und das so:
                                        audio_player		pulse,noecho.sound_out
                                        audio_source		pulse,noecho.mic_in
                                        audio_alert		pulse,noecho.sound_out
                                        Walter
                                        DoorIO-Adapter
                                        • WalW Wal
                                          @renegade-0 ,
                                          Und das so:
                                          R
                                          R
                                          Renegade 0
                                          #458
                                          @wal
                                          aucodec: PCMU/8000/1
                                          aucodec: PCMA/8000/1
                                          aufilt: vumeter
                                          dl: mod: /usr/lib/baresip/modules/pulse.so (/usr/lib/baresip/modules/pulse.so: cannot open shared object file: No such file or directory)
                                          module pulse.so: No such file or directory
                                          medianat: stun
                                          medianat: turn
                                          medianat: ice
                                          Hab auch das Verzeichnis geprüft. di Datei pulse.so ist nicht da. Bei mir war alsa,default eingestellt.
                                          Zudem, obwohl ich den RPi 4 und das CM gleich installiert habe, zeigt das CM bei "pactl list" nicht noecho.sound_out als Ziel vorhanden.
                                          83.9k
