  4. Massive Probleme nach Austausch von Router und Mesh Repeater
154 Beiträge 8 Kommentatoren 22.3k Aufrufe 6 Beobachtet
  • wendy2702W wendy2702
    @invidianer sagte in Massive Probleme nach Austausch von Router und Mesh Repeater:
    http://download.iobroker.net/sources-dist.json
    ISt nicht normal.
    Kannst du mal auf dem PI das machen:
    ping repo.iobroker.live
    Mal so 10-15 Zeilen laufen lassen dann mit "STRG-C" abbrechen und hier posten.
    I Offline
    I Offline
    invidianer
    #67
    @wendy2702
    pi@raspberrypi:~ $ ping repo.iobroker.live
    PING repo.iobroker.live.cdn.cloudflare.net (104.21.88.137) 56(84) bytes of data.
    64 bytes from 104.21.88.137 (104.21.88.137): icmp_seq=1 ttl=56 time=22.9 ms
    64 bytes from 104.21.88.137 (104.21.88.137): icmp_seq=2 ttl=56 time=23.0 ms
    64 bytes from 104.21.88.137 (104.21.88.137): icmp_seq=3 ttl=56 time=21.7 ms
    64 bytes from 104.21.88.137 (104.21.88.137): icmp_seq=4 ttl=56 time=21.8 ms
    64 bytes from 104.21.88.137 (104.21.88.137): icmp_seq=5 ttl=56 time=21.5 ms
    64 bytes from 104.21.88.137 (104.21.88.137): icmp_seq=6 ttl=56 time=21.4 ms
    64 bytes from 104.21.88.137 (104.21.88.137): icmp_seq=7 ttl=56 time=22.8 ms
    64 bytes from 104.21.88.137 (104.21.88.137): icmp_seq=8 ttl=56 time=21.10 ms
    64 bytes from 104.21.88.137 (104.21.88.137): icmp_seq=9 ttl=56 time=21.6 ms
    64 bytes from 104.21.88.137 (104.21.88.137): icmp_seq=10 ttl=56 time=22.6 ms
    64 bytes from 104.21.88.137 (104.21.88.137): icmp_seq=11 ttl=56 time=21.0 ms
    64 bytes from 104.21.88.137 (104.21.88.137): icmp_seq=12 ttl=56 time=21.1 ms
    64 bytes from 104.21.88.137 (104.21.88.137): icmp_seq=13 ttl=56 time=22.2 ms
    64 bytes from 104.21.88.137 (104.21.88.137): icmp_seq=14 ttl=56 time=21.8 ms
    64 bytes from 104.21.88.137 (104.21.88.137): icmp_seq=15 ttl=56 time=22.2 ms
    ^C
    --- repo.iobroker.live.cdn.cloudflare.net ping statistics ---
    15 packets transmitted, 15 received, 0% packet loss, time 35ms
    rtt min/avg/max/mdev = 21.048/21.971/23.007/0.634 ms
    • I invidianer
      @wendy2702
      ^C
      wendy2702W Offline
      wendy2702W Offline
      #68
      @invidianer Die Antwort Zeiten vom Server sind schon relativ hoch. Liegt zu 99% am Netzwerk oder der Internet Verbindung.
      Meine Zeiten liegen deutlich unter 20ms.
      Kannst du das auch mal von einem anderen Rechner aus machen der per Kabel an der Fritzbox hängt?
      I 1 Antwort Letzte Antwort
      • da_WoodyD da_Woody
        @invidianer hehe, mut kann man nicht kaufen! ;)
        wie es bei dem fritten zeuch genau funktioniert, kann ich dir nicht sagen. aber im grunde musst du den aktuellen lease auflösen und die alte IP an die MAC des lan-anschlusses vergeben. nennt sich dann DHCP reservierung. ich habe für neue geräte nur einen kleine freie IPrange offen wo sich ein neues gerät anmelden kann. dort sage ich dann IP reservieren, weise dem gerät die gewünschte IP zu, neustart, das gerät nimmt an hand der MAC die neu IP an und gut ists.
        ist sowieso die bessere lösung, da auch nach einem stromausfall sicher gestellt ist, daß die selbe IP sicher vergeben wird.
        I Offline
        I Offline
        invidianer
        #69
        @da_woody
        Danke, aber ich habe allen Geräten, bei denen es möglich ist, sowieso eine feste IP gegeben, DHCP nutze ich nur, wenn es nicht anders geht.
        @wendy2702
        Wenn ich den Pi per LAN-Kabel anschließe und WLAN deaktiviere, ist es dann trotzdem sinnvoll, ihn paar Meter von der 7590 zu positionieren und ist das dann egal? Oder anders gefragt: Ist es das WLAN im Pi, welches das WLAN der FritzBox stört oder ist es ein anderes Bauteil des Pi, welches stört?
        Thomas BraunT da_WoodyD wendy2702W 3 Antworten Letzte Antwort
          I Offline
          I Offline
          invidianer
          #70
          @wendy2702
          Hmm, komisch.
          Ich mache das vom Mac aus, der hat ein LAN-Kabel zur FritzBox (allerdings ist an ihm auch WLAN aktiviert, z.B. um Airdrop usw. nutzen zu können).
          Meinst Du, die langen Antwortzeiten haben etwas mit der Meldung "... Updating repository stable ..." zu tun? Diese ist übrigens nach dem neu Positionieren des Pis (weit weg von der Fritte) um 09:38 Uhr nur noch ein einziges Mal aufgetaucht, nämlich um 10:19 Uhr.
          • I invidianer
            @da_woody
            @wendy2702
            #71
            @invidianer WLAN kann man nicht abstellen auf dem Pi, der funkt immer durch die Gegend. Auch wenn das WLAN nicht konfiguriert ist oder per overlay softwareseitig ausgeknipst ist.
            Updating repository stable kommt, wenn z.B. im Info-Adapter die Liste der Adapter neugeladen wird.
            I 2 Antworten Letzte Antwort
              I Offline
              I Offline
              invidianer
              #72
              Oh, okay! Dann also Kabel dran und zusätzlich weg von der Fritte lassen.
              • I invidianer
                @da_woody
                @wendy2702
                da_WoodyD Offline
                da_WoodyD Offline
                #73
                @invidianer said in Massive Probleme nach Austausch von Router und Mesh Repeater:
                @da_woody
                hatte ich anfangs auch, allerdings wurden die mir dann im router nicht mehr angezeigt. der übersicht etwas nicht zuträglich...
                und bei meinem netzwerk von 192.168.0.1-192.168.8.254 auch mühsam...
                klar, wäre über die reservierung gegangen. IPs fix eingetragen habe ich nur mehr bei batteriebetriebenen geräten, da die batterie geschont wird.
                  I Offline
                  I Offline
                  invidianer
                  #74
                  @thomas-braun said in Massive Probleme nach Austausch von Router und Mesh Repeater:
                  Yeah!! Gerade mal ausprobiert, auf "Info" geklickt und schon ist die Meldung im Log! Okay, danke, dann bin ich da beruhigt!
                  • I invidianer
                    @da_woody
                    @wendy2702
                    wendy2702W Offline
                    wendy2702W Offline
                    #75
                    Sowohl als auch.
                    Also PI wie du selber geschrieben hast besser Stück weg von der Fritte oder an eine Stelle wo er eh nicht stört.
                    In der Regel fummelt man an seinem Server ja eh nur per SSH rum.
                    Bei mir steht das Teil auf dem Speicher bzw. hängen hinter verschlossenen Türen in zwei Unterverteilungen.
                      Sowohl als auch.
                      I Offline
                      I Offline
                      invidianer
                      #76
                      @wendy2702
                      Gut, dann muß ich bisschen was basteln, denn LAN-Kabel habe ich nur dort liegen, wo er jetzt steht.
                      Danke nochmals!
                      Aber extrem krass: Da sucht man sich einen Wolf, hat ständig verschiedenste Fehlermeldungen der verschiedensten Adapter, wobei vorher alles topp war, und dann liegt es an einem störenden Gerät, das man schon lange problemlos im Einsatz hat, und gegen das aber ein neu gekauftes Gerät (FritzBox 7590) "allergisch" reagiert. Wie soll man da drauf kommen? ;)
                      • I invidianer
                        @wendy2702
                        Danke nochmals!
                        da_WoodyD Offline
                        da_WoodyD Offline
                        #77
                        hab ich auch gerade hinter mir. ewig keine probleme, plötzlich keine saubere retourmeldungen von den shelly's. nach adapterstart 5 minuten alles i.o., danach switchstate rot.
                        backup, synology-support, FW downgrade u.s.w. ich wollte ioBroker schon in die tonne treten. eindeutig ein IGMP snooping problem mit CoAP. weis nicht mehr wie, irgendwann ist mir eingefallen, daß ich 2 managed router im netz hängen habe. dort aber nie etwas eingestellt, oder upgedatet. netgear-tool geholt, config belinst, siehe da: IGMP snooping aktiv! wut.gif deaktiviert, gleich deutsche FW aufgespielt, keine probleme mehr!
                        gute 2 monate rumgeeiert... :D
                        du siehst, daß es immer überaschungen geben kann...
                          I Offline
                          I Offline
                          invidianer
                          #78
                          @da_woody
                          Ja, krasse Geschichte!
                          Dachte, sowas passiert nur (fast nur) mir :-D
                            Sowohl als auch.
                            I Offline
                            I Offline
                            invidianer
                            #79
                            @wendy2702
                            Hmm, wenn der Pi so "strahlt", macht es vermutlich auch keinen Sinn, ihn an die Steckdosenleiste für meine Hifi-Anlage zu hängen? Gerade die wären bestimmt "empfindlich" gegenüber so einem Störenfried, oder?
                            • I Offline
                              I Offline
                              invidianer
                              #80
                              Hier wieder etwas, das ein wenig "unschön" zu sein scheint, wenn auch "nur" eine Info:
                              2021-03-06 11:22:44.211 - info: mqtt.0 (1339) Client [shelly1-E098068D096C] connection closed: timeout
                              2021-03-06 11:22:53.778 - info: mqtt.0 (1339) Client [shelly1-E098068D096C] connected with secret 1615026173777_2189
                              2021-03-06 11:22:53.810 - info: mqtt.0 (1339) Client [shelly1-E098068D096C] subscribes on "mqtt.0.shellies.command"
                              2021-03-06 11:22:53.811 - info: mqtt.0 (1339) Client [shelly1-E098068D096C] subscribes on "mqtt.0.shellies.shelly1-E098068D096C.command"
                              2021-03-06 11:22:53.812 - info: mqtt.0 (1339) Client [shelly1-E098068D096C] subscribes on "mqtt.0.shellies.shelly1-E098068D096C.relay.0.command"
                              • I invidianer
                                wendy2702W Offline
                                wendy2702W Offline
                                #81
                                @invidianer nicht alle Geräte reagieren da empfindlich drauf. Muss man im Einzel Fall testen
                                  I Offline
                                  I Offline
                                  invidianer
                                  #82
                                  @wendy2702
                                  Okay!
                                  Sicherheitshalber lege ich den Pi aber vermutlich doch in den Kabelkanal unter meinen Schreibtisch. Dort könnte er höchstens das WLAN meines Macs stören, der aber zusätzlich per LAN-Kabel angeschlossen ist (WLAN nur, damit ich AirDrop und andere „Apple-Dinge“ nutzen kann).
                                  • I Offline
                                    I Offline
                                    invidianer
                                    #83
                                    Hmm, der hier will einfach nicht verschwinden:
                                    2021-03-06 13:55:55.234 - info: mqtt.0 (1339) Client [shelly1-E098068D096C] connection closed: timeout
                                    2021-03-06 13:56:04.519 - info: mqtt.0 (1339) Client [shelly1-E098068D096C] connected with secret 1615035364517_7910
                                    2021-03-06 13:56:04.556 - info: mqtt.0 (1339) Client [shelly1-E098068D096C] subscribes on "mqtt.0.shellies.command"
                                    2021-03-06 13:56:04.557 - info: mqtt.0 (1339) Client [shelly1-E098068D096C] subscribes on "mqtt.0.shellies.shelly1-E098068D096C.command"
                                    2021-03-06 13:56:04.562 - info: mqtt.0 (1339) Client [shelly1-E098068D096C] subscribes on "mqtt.0.shellies.shelly1-E098068D096C.relay.0.command"
                                    • I invidianer
                                      wendy2702W Offline
                                      wendy2702W Offline
                                      #84
                                      @invidianer Zu mqtt und Shelly kann ich leider nichts sagen.
                                      Aber sind die Shelly nicht auch per WLAN im Netz?
                                        I Offline
                                        I Offline
                                        invidianer
                                        #85
                                        @wendy2702
                                        Ja, sind sie. Aber außer dieser Meldung ist rein gar nichts in den Logs, nachdem ich Deinem Rat folgend den Pi weit weg von der FritzBox aufgestellt habe!
                                        Daher muß es sich wohl um ein anderes Problem handeln.
                                        Gut, die bekannten Meldungen vom DWD sind drin (kommen alle 5 Minuten), aber die sind wohl normal und nicht zu ändern (hatte ich schon immer):
                                        2021-03-06 15:05:00.063 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 14085
                                        2021-03-06 15:05:01.986 - info: dwd.0 (14085) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.21.0, js-controller: 3.2.16
                                        2021-03-06 15:05:06.859 - info: dwd.0 (14085) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2021-03-06 15:05:07.402 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        • I invidianer
                                          @wendy2702
                                          wendy2702W Offline
                                          wendy2702W Offline
                                          #86
                                          @invidianer Wenn du ja dein WLAN umgebaut hast. Kann es sinn machen den Shelly mal vom WLAN zu entfernen und neu anzumelden damit er einen Kanal und eine Quelle wählt die eventuell für ihn Empfangstechnisch besser ist.
