  4. [ESPHome] Beta release
    6.8k
591 Beiträge 48 Kommentatoren 234.0k Aufrufe 39 Beobachtet
  • M mtaxer
    @dutchman ... hier der Auszug aus dem Log für RGBW
    2021-03-01 15:53:06.241 - warn: esphome.0 (11603) DeviceType Light not yet supported
    2021-03-01 15:53:06.241 - warn: esphome.0 (11603) Please submit git issue with all information from next line
    2021-03-01 15:53:06.241 - warn: esphome.0 (11603) DeviceType Light | State-Keys {"key":3048698813,"state":false,"brightness":1,"red":1,"green":1,"blue":1,"white":1,"colorTemperature":0,"effect":"None"} | [entityStateConfig] {"config":{"objectId":"quinled_quad","key":3048698813,"name":"QuinLED_Quad","uniqueId":"esphome_developer_qlquad_dev4lightquinled_quad","supportsBrightness":true,"supportsRgb":true,"supportsWhiteValue":true,"supportsColorTemperature":false,"minMireds":0,"maxMireds":0,"effectsList":["None","My Slow Random Effect","My Fast Random Effect","My Insane Random Effect","Totally loco","Strobe Effect With Custom Values"]},"name":"Light","type":"Light","unit":""}
    SG
    Mario
    DutchmanD Offline
    DutchmanD Offline
    Dutchman
    @bigd-73 sagte in [ESPHome] Beta release:
    SG
    Mario
    danke fuer die Details und git issue :), na dan probier mal 0.1.1
    0.1.1 (2021-03-02)
    • (DutchmanNL) Type Fan added
    • (DutchmanNL) Type Light added
    • (DutchmanNL) Error messages optimized
    • (DutchmanNL) Device reconnect handling improved
    • (DutchmanNL) [Breaking!] Change state name to default "state" for type BinarySensor / Climate / Sensor / TextSensor & Switch
    • (DutchmanNL) Autodiscovery improved, non-ESPHome devices excluded
    • DutchmanD Dutchman
      SG
      Mario
      0.1.1 (2021-03-02)
      mtaxer
      @dutchman Danke für die Einbindung. Die Licht Komponente konnte ich schon mal testen.
      In den Objekten erscheint ein "state". Dieser nimmt den richtigen Wert des Stripes an, true oder false (ein/aus).
      Allerdings nur wenn ich den Stripes von der ESPHome Weboberfläche schalte. Der State selber ist in den Objekten
      nicht "setzbar/schreibbar". Einen State für die Farbe, Helligkeit und Farbtemperatur konnte ich noch nicht finden.
      SG
      Mario
      • M mtaxer
        SG
        Mario
        DutchmanD Offline
        DutchmanD Offline
        Dutchman
        danke ! Tippfehler, bitte nochmal neu von git ziehen jetzt sollte alles kommen :)
          @markus_ sagte in [ESPHome] Beta release:
          Ich kann das Problem Bestätigen. Bei mir werden auch 2 Amazon Geräte gefunden
          ok thanks kan es reproduzieren und beheben
          DutchmanD Offline
          DutchmanD Offline
          Dutchman
          @dutchman sagte in [ESPHome] Beta release:
          ist jetzt auch behoben ;)
            mtaxer
            schrieb am zuletzt editiert von mtaxer
            @dutchman Alle States erscheinen jetzt in den Objekten, sehr gut.
            Kurz zusammengefasst:
            • state (true/false - Ein/Aus) - funktioniert
            • brightness - es kann nur der Wert 0 und 1 eingegeben werden, sollte aber 0 bis 255 sein
            • blue - es kann nur der Wert 0 und 1 eingegeben werden, sollte aber 0 bis 255 sein
            • green - es kann nur der Wert 0 und 1 eingegeben werden, sollte aber 0 bis 255 sein
            • red - es kann nur der Wert 0 und 1 eingegeben werden, sollte aber 0 bis 255 sein
            • colorTemperature - es kann nur der Wert 0 und 1 eingegeben werden, sollte aber 153 bis 500 sein (Mired)
            Ich sehe gerade Kommawerte funktionieren (0 bis 0.99). Allerdings ist diese Eingabe eher untypisch bei Helligkeits- und Farbangaben, denke ich zumindest.
            Optimal wäre noch ein zusätzlicher State der Hex Werte entgegen nimmt, also z.B. #00ff00. Eine Funktion im Adapter zerlegt den Wert in die RGB Werte und gibt es an ESPHome weiter. Ich habe das bis jetzt immer extern mit einem Skript gelöst.
            function hexToRgb(hex) {
              // Expand shorthand form (e.g. "03F") to full form (e.g. "0033FF")
              var shorthandRegex = /^#?([a-f\d])([a-f\d])([a-f\d])$/i;
              hex = hex.replace(shorthandRegex, function(m, r, g, b) {
                return r + r + g + g + b + b;
              var result = /^#?([a-f\d]{2})([a-f\d]{2})([a-f\d]{2})$/i.exec(hex);
              return result ? {
                r: parseInt(result[1], 16),
                g: parseInt(result[2], 16),
                b: parseInt(result[3], 16)
              } : null;
            return (hexToRgb(hex).r) + "," + (hexToRgb(hex).g) + "," + (hexToRgb(hex).b);
            Vielen Dank nochmal ...
            SG
            Mario
            DutchmanD 3 Antworten Letzte Antwort
            • M mtaxer
                return result ? {
                } : null;
              SG
              Mario
              DutchmanD Offline
              DutchmanD Offline
              Dutchman
              schrieb am zuletzt editiert von Dutchman
              cool ! dan hab ich ja doch nicht al zuviel mist gebaut im framework :)
              hmm ok ich muss mal sehe wie das reinkommt, kannste mal bitte den adapter auf debug stellen.
              Ich brauche dan fuer die device alles hinter log Eintrag "entityStateData".
              Vermute mal muss einfach die Sachen * 100 machen, wen du 0.5 einstellst geht zb die brightness auch auf 50% ?
              Ich habe etwas vergleichbares im WLED adapter drin, ist bissl komplizierte dafuer bitte git issue :)
              M 2 Antworten Letzte Antwort
              • M mtaxer
                  return result ? {
                  } : null;
                SG
                Mario
                DutchmanD Offline
                DutchmanD Offline
                Dutchman
                hast du die function zufällig auch andersrum, RGB to hex ?
                Edit : hab schon das war ja noch einfacher :/, baue ich heut abend ein :)
                function rgbToHex(r, g, b) {
                  return "#" + componentToHex(r) + componentToHex(g) + componentToHex(b);
                  mtaxer
                  @dutchman jetzt warst du schneller 😁
                  das hätte ich gefunden ...
                  function componentToHex(c) {
                  var hex = c.toString(16);
                  return hex.length == 1 ? "0" + hex : hex;
                  SG
                  Mario
                    mtaxer
                    Diesen Befehl sende ich via mqtt (so löste/löse ich die Sache bevor du begonnen hast den Adapter zu entwickeln)
                    Stripe ein, Helligkeit 100% (255), Farbe grün, kein Effekt
                    {"effect":"None","state":"ON","brightness":255,"color":{"r":0,"g":255,"b":0},"white_value":0}
                    Das kommt im Log rein
                    [entityStateData] {"key":801952849,"state":true,"brightness":1,"red":0,"green":1,"blue":0,"white":0,"colorTemperature":0,"effect":"None"}
                    weiteres Beispiel (mqtt):
                    Stripe ein, Helligkeit ca. 50% (127), Farbe lila, kein Effekt
                    {"effect":"None","state":"ON","brightness":127,"color":{"r":136,"g":0,"b":255},"white_value":0}
                    [entityStateData] {"key":801952849,"state":true,"brightness":0.49803921580314636,"red":0.5333333611488342,"green":0,"blue":1,"white":0,"colorTemperature":0,"effect":"None"}
                    SG
                    Mario
                      mtaxer
                      genau ...
                      EDIT:
                      ich denke die Umrechnung lautet so: Value (Dezimalwert für ESPHome = x (Hex Value für eine Grundfarbe)/255 ---> zB.: 136/255 = 0.5333333611488342 (für obiges Beispiel aus dem Log)
                      Gilt natürlich auch für die Helligkeit ...
                      SG
                      Mario
                        mtaxer
                        @dutchman ... weil ich gerade beim Wünschen bin 😀
                        Optimal wäre dann noch eine weitere Funktion bzw. Abfrage im Adapter. Falls via Hex Value #ffffff (weiss) bzw. RGB Value jeweils 255 (weiss) eingegeben wird, automatisch der White Channel (State "white" in den Objekten) auf 1 geht und RGB jeweils auf 0. Das ganze natürlich auch umgekehrt. Wird eine Farbe eingegeben (nicht weiss), soll der White Channel wieder auf 0 und die RGB bzw. Hex Werte gesetzt werden.
                        Hintergrund ---> Ein "weiss" mit den drei Grundfarben gemischt ist nie ein richtig sauberes "weiss", sondern eher blaustichig. Diese Funktion sollte vielleicht über einen State in den Objekten Ein/Aus geschaltet werden können. Dann kann jeder die Farbmischung lösen wie er möchte. Hab das bisher extern über ein Script gelöst.
                        So jetzt ist schluss, zumindest vorerst ... 😇
                        SG
                        Mario
                        DutchmanD 2 Antworten Letzte Antwort
                        • M mtaxer
                          SG
                          Mario
                          DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          Sollte möglich sein auch dafür bitte ein GIT issue
                            @fredf sagte in [ESPHome] Beta release:
                            @dutchman Nope, gleiches Verhalten/Fehlermeldung
                            @apollon77 hast du eventuell ne idee ?
                            FredFF Online
                            FredFF Online
                            FredF
                            Most Active Forum Testing
                            @dutchman Die aktuellste Version 0.1.2 gerade nochmal probiert und siehe da, nun ging es. Das soll einer verstehen...
                            • M mtaxer
                                return result ? {
                                } : null;
                              SG
                              Mario
                              DutchmanD Offline
                              DutchmanD Offline
                              Dutchman
                              probier mal 0.1.3 bitte
                              • M mtaxer
                                SG
                                Mario
                                DutchmanD Offline
                                DutchmanD Offline
                                Dutchman
                                hmm ja kan man machen, aber was wuerde passieren wen man nur RGB hat geht ESPHome da dan richtig mit um ?
                                Den wen ich bei RGB (nicht RGBW) den RGB auf 0 mache geht alles aus ?
                                • M mtaxer
                                  SG
                                  Mario
                                  DutchmanD Offline
                                  DutchmanD Offline
                                  Dutchman
                                  Mario
                                  falls es mal jemand gebrauchen kan, RGB > HEX und HEX > RGB :
                                  (baue es morgen im adapter ein....)
                                      const shorthandRegex = /^#?([a-f\d])([a-f\d])([a-f\d])$/i;
                                      hex = hex.replace(shorthandRegex, function (m, r, g, b) {
                                      const result = /^#?([a-f\d]{2})([a-f\d]{2})([a-f\d]{2})$/i.exec(hex);
                                      return result ? {
                                          red: parseInt(result[1], 16),
                                          green: parseInt(result[2], 16),
                                          blue: parseInt(result[3], 16)
                                      } : null;
                                      function componentToHex(color) {
                                          const hex = color.toString(16);
                                          return hex.length == 1 ? '0' + hex : hex;
                                      const hex = '#' + componentToHex(r) + componentToHex(g) + componentToHex(b);
                                      return hex;
                                  const rgb = hexToRgb(`ff4000`)
                                  console.log(rgb)
                                  const hex = rgbToHex(rgb.red,rgb.blue,rgb.green)
                                  console.log(hex)
                                    mtaxer
                                    Guten Morgen, in der Regel wird die Anzahl der Kanäle in ESPHome in der Light Komponente definiert. Über die Config Objekte in den States könnte man den Typ abfangen. Bei RGBW müsste dann false stehen. In diesen Fall müsste man die Funktion deaktivieren. Komme leider erst heute Abend zum Testen. Screenshots reiche ich dann nach ...
                                    SG
                                    Mario
                                    • M mtaxer
                                      SG
                                      Mario
                                      DutchmanD Offline
                                      DutchmanD Offline
                                      Dutchman
                                      Moin!
                                      Super danke dir genau was ich brauche dafür!
                                      Ich habe nicht alle Typen in Betrieb da hilft es sehr die Infos zu bekommen man kan nicht alles selber testen 😂👍
                                        Moin!
                                        mtaxer
                                        @dutchman Hier mal die verschiedenen Licht Plattformen ...
                                        monochromatic (1 Kanal - Welche Funktionen unterstützt werden sieht man schön in den Config States)
                                        cwww ( 2 Kanal - Hier ist die ColorTemperature und Brightness relevant, keine RGB Farben, mireds --> 153 ww --> 500 cw)
                                        rgb (3 Kanal - Welche Funktionen unterstützt werden sieht man schön in den Config States)
                                        rgbw (4 Kanal - Welche Funktionen unterstützt werden sieht man schön in den Config States)
                                        rgbww (5 Kanal - Welche Funktionen unterstützt werden sieht man schön in den Config States)
                                        Es gäbe dann noch Neopixel. Aber da verwenden wir ja WLED 😀
                                        Die neue Version wird heute Abend getestet, danke.
                                        SG
                                        Mario
                                          mtaxer
                                          ... doch früher dazu gekommen ...
                                          Zusammenfassung (Ich teste mit einem RGBW Stripe, also colorTemperature nicht relevant, ersichtlich in den Config States):
                                          • In dieser Version ist die Value Range 0-100? Ich denke 0-255 wäre besser, weil weiter verbreitet und hex kompatibel.
                                          • Egal welche Werte ich bei RGB setze, der Stripe bleibt immer auf weiss. Also alle 3 Farben voll ein.
                                          • Der "white" State funktioniert, zumindest für Ein/Aus also 0/1
                                          • Brightness reagiert nicht. Weder bei "RGB", noch bei "white", keine Veränderung.
                                          • Schalte ich den Power "state" auf false, geht der Stripe aus. Beim einschalten gehen alle Werte auf 100. Die letzte Einstellung wird also nicht gespeichert.
                                          Nachtrag:
                                          Egal welchen State ich ändere, im Log kommt folgender Fehler ...
                                          [onStateChange] ReferenceError: writevalue is not defined
                                          SG
                                          Mario
