  4. [ESPHome] Beta release
    6.8k
591 Beiträge 48 Kommentatoren 234.0k Aufrufe 39 Beobachtet
  • M Markus_
    @liv-in-sky @Dutchman
    Ich kann das Problem Bestätigen. Bei mir werden auch 2 Amazon Geräte gefunden
    esphome.0	2021-02-28 19:59:03.324	error	(21729) ESPHome client 192.168.0.229 Error: connect ECONNREFUSED 127.0.0.1:6053
    esphome.0	2021-02-28 19:59:03.322	error	(21729) ESPHome client 192.168.0.166 Error: connect ECONNREFUSED 127.0.0.1:6053
    esphome.0	2021-02-28 19:59:03.320	info	(21729) Initiate 192.168.0.229
    esphome.0	2021-02-28 19:59:03.318	info	(21729) Initiate 192.168.0.166
    esphome.0	2021-02-28 19:58:33.322	error	(21729) ESPHome client 192.168.0.229 Error: connect ECONNREFUSED 127.0.0.1:6053
    esphome.0	2021-02-28 19:58:33.320	error	(21729) ESPHome client 192.168.0.166 Error: connect ECONNREFUSED 127.0.0.1:6053
    esphome.0	2021-02-28 19:58:33.316	info	(21729) Initiate 192.168.0.229
    esphome.0	2021-02-28 19:58:33.315	info	(21729) Initiate 192.168.0.166
    esphome.0	2021-02-28 19:58:03.322	error	(21729) ESPHome client 192.168.0.229 Error: connect ECONNREFUSED 127.0.0.1:6053
    esphome.0	2021-02-28 19:58:03.317	error	(21729) ESPHome client 192.168.0.166 Error: connect ECONNREFUSED 127.0.0.1:6053
    esphome.0	2021-02-28 19:58:03.311	info	(21729) Initiate 192.168.0.229
    esphome.0	2021-02-28 19:58:03.303	info	(21729) Initiate 192.168.0.166
    esphome.0	2021-02-28 19:57:33.498	error	(21729) ESPHome client 192.168.0.229 Error: connect ECONNREFUSED 192.168.0.229:6053
    esphome.0	2021-02-28 19:57:33.487	info	(21729) Initiate 192.168.0.229
    esphome.0	2021-02-28 19:57:33.486	info	(21729) [AutoDiscovery] New ESPHome device found at IP 192.168.0.229
    esphome.0	2021-02-28 19:57:33.480	info	(21729) ESPHome client test on ip 192.168.0.179 initialized
    esphome.0	2021-02-28 19:57:33.398	info	(21729) ESPHome Device info received for test
    esphome.0	2021-02-28 19:57:33.386	error	(21729) ESPHome client 192.168.0.166 Error: connect ECONNREFUSED 192.168.0.166:6053
    esphome.0	2021-02-28 19:57:33.382	info	(21729) ESPHome client 192.168.0.179 connected
    esphome.0	2021-02-28 19:57:33.375	info	(21729) Initiate 192.168.0.166
    esphome.0	2021-02-28 19:57:33.373	info	(21729) [AutoDiscovery] New ESPHome device found at IP 192.168.0.166
    esphome.0	2021-02-28 19:57:33.296	info	(21729) Initiate 192.168.0.179
    esphome.0	2021-02-28 19:57:33.183	info	(21729) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.esphome, node: v12.20.2, js-controller: 3.2.16
    esphome.0	2021-02-28 19:57:22.693	warn	(6761) ESPHome client 192.168.0.179 disconnected
    esphome.0	2021-02-28 19:57:22.692	warn	(6761) ESPHome client 192.168.0.179 disconnected
    esphome.0	2021-02-28 19:57:22.683	info	(6761) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    esphome.0	2021-02-28 19:57:22.681	info	(6761) terminating
    esphome.0	2021-02-28 19:57:22.675	info	(6761) Got terminate signal TERMINATE_YOURSELF
    esphome.0	2021-02-28 19:50:09.656	info	(6761) ESPHome client test on ip 192.168.0.179 initialized
    esphome.0	2021-02-28 19:50:09.604	info	(6761) ESPHome Device info received for test
    esphome.0	2021-02-28 19:50:09.586	info	(6761) ESPHome client 192.168.0.179 connected
    esphome.0	2021-02-28 19:50:09.467	info	(6761) Initiate 192.168.0.179
    esphome.0	2021-02-28 19:50:09.449	info	(6761) [AutoDiscovery] New ESPHome device found at IP 192.168.0.179
    DutchmanD Offline
    DutchmanD Offline
    Dutchman
    @markus_ sagte in [ESPHome] Beta release:
    ok thanks kan es reproduzieren und beheben
    • DutchmanD Dutchman
      @apollon77 sagte in [ESPHome] Beta release:
      @dutchman Was ist die Frage? Install läuft ja durch, dann crasht der Adapter ...
      ging hierum :
      @malaus sagte in [ESPHome] Beta release:
      Bei mir kommt ebenfalls die Fehlermeldung 25:
      $ ./iobroker url "https://github.com/iobroker-community-adapters/ioBroker.esphome"
      Info: Can not get current GitHub commit, we remember master branch only. Status: 422 (No commit found for SHA: master)
      install https://github.com/iobroker-community-adapters/ioBroker.esphome/tarball/master
      NPM version: 6.14.11
      npm install https://github.com/iobroker-community-adapters/ioBroker.esphome/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
      npm
       ERR! code E404
      npm
       ERR!
      404 Not Found - GET https://codeload.github.com/iobroker-community-adapters/ioBroker.esphome/legacy.tar.gz/master
      npm ERR!
       404
      npm ERR!
       404  'https://github.com/iobroker-community-adapters/ioBroker.esphome/tarball/master' is not in the npm registry.
      npm ERR!
       404 Your package name is not valid, because
      npm ERR!
      404  1. name can only contain URL-friendly charactersnpm ERR! 404  2. name can no longer contain capital lettersnpm ERR! 404 npm ERR! 404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-02-28T11_14_11_035Z-debug.log
      ERROR: host.raspberrypi Cannot install https://github.com/iobroker-community-adapters/ioBroker.esphome/tarball/master: 1
      @dutchman js-controller 3.2??
      • apollon77A apollon77
        FredFF Online
        FredFF Online
        FredF
        Most Active Forum Testing
        @apollon77 Ja.
        https://forum.iobroker.net/topic/42741/esphome-beta-release/28?_=1614580980648
        • FredFF FredF
          @apollon77 Ja.
          @fredf Dann bitte dafürmal js.controller issue anlegen. müssen wir da ansehen.
            mtaxer
            @dutchman Vielen Dank für die Integration. Ist geplant die "Light" Komponente mit einzubauen?
            SG
            Mario
            • M mtaxer
              SG
              Mario
              DutchmanD Offline
              DutchmanD Offline
              Dutchman
              schrieb am zuletzt editiert von Dutchman
              @bigd-73 sagte in [ESPHome] Beta release:
              SG
              Mario
              Kan ich einbauen sobald ich ein Beispiel dafür bekomme.
              Der Adapter sollte ne Meldung geben “type Not supporters. Und Dan Informationen geben die dem Entwickler geschickt werden müssen
                mtaxer
                schrieb am zuletzt editiert von mtaxer
                @dutchman Danke für die schnelle Antwort ...
                Hier ein Link für einige Beispielkonfigurationen: QuinLED-Quad
                Für mich persönlich wäre die "1x RGBW" Led Strip Variante aus diesen Beispielen interessant.
                Log kann ich erst später analysieren ...
                SG
                Mario
                  mtaxer
                  @dutchman "Not supported" kann ich im Log leider nicht finden. Ist auf "debug" gestellt.
                  Die Config der Licht Komponente wird bereits richtig in den Objekten angezeigt.
                  SG
                  Mario
                  • M mtaxer
                    SG
                    Mario
                    DutchmanD Offline
                    DutchmanD Offline
                    Dutchman
                    SG
                    Mario
                    jup config ja aber states fehlen :)
                    Starte mal bitte den adapter neu, es sollte dan eine warn melding kommen (debug nicht noetig, zuviel info !)
                    DeviceType >TypenName< not yet supported
                    Please submit git issue with all information from next line
                    DeviceType >TypenName< | State-Keys >ArrayOfKey< | [entityStateConfig] >informationen<
                    ich brauchte mal die komplette warn log Ausgabe was da kommt, bitte dafuer nicht aus dem admin kopieren (Zeile ist abgeschnitten) sondern log runterladen
                    Thanks !
                      SG
                      Mario
                      Thanks !
                      mtaxer
                      @dutchman ... hier der Auszug aus dem Log für RGBW
                      2021-03-01 15:53:06.241 - warn: esphome.0 (11603) DeviceType Light not yet supported
                      2021-03-01 15:53:06.241 - warn: esphome.0 (11603) Please submit git issue with all information from next line
                      2021-03-01 15:53:06.241 - warn: esphome.0 (11603) DeviceType Light | State-Keys {"key":3048698813,"state":false,"brightness":1,"red":1,"green":1,"blue":1,"white":1,"colorTemperature":0,"effect":"None"} | [entityStateConfig] {"config":{"objectId":"quinled_quad","key":3048698813,"name":"QuinLED_Quad","uniqueId":"esphome_developer_qlquad_dev4lightquinled_quad","supportsBrightness":true,"supportsRgb":true,"supportsWhiteValue":true,"supportsColorTemperature":false,"minMireds":0,"maxMireds":0,"effectsList":["None","My Slow Random Effect","My Fast Random Effect","My Insane Random Effect","Totally loco","Strobe Effect With Custom Values"]},"name":"Light","type":"Light","unit":""}
                      SG
                      Mario
                      • M mtaxer
                        SG
                        Mario
                        DutchmanD Offline
                        DutchmanD Offline
                        Dutchman
                        SG
                        Mario
                        danke fuer die Details und git issue :), na dan probier mal 0.1.1
                        0.1.1 (2021-03-02)
                        • (DutchmanNL) Type Fan added
                        • (DutchmanNL) Type Light added
                        • (DutchmanNL) Error messages optimized
                        • (DutchmanNL) Device reconnect handling improved
                        • (DutchmanNL) [Breaking!] Change state name to default "state" for type BinarySensor / Climate / Sensor / TextSensor & Switch
                        • (DutchmanNL) Autodiscovery improved, non-ESPHome devices excluded
                          SG
                          Mario
                          0.1.1 (2021-03-02)
                          mtaxer
                          @dutchman Danke für die Einbindung. Die Licht Komponente konnte ich schon mal testen.
                          In den Objekten erscheint ein "state". Dieser nimmt den richtigen Wert des Stripes an, true oder false (ein/aus).
                          Allerdings nur wenn ich den Stripes von der ESPHome Weboberfläche schalte. Der State selber ist in den Objekten
                          nicht "setzbar/schreibbar". Einen State für die Farbe, Helligkeit und Farbtemperatur konnte ich noch nicht finden.
                          SG
                          Mario
                          • M mtaxer
                            SG
                            Mario
                            DutchmanD Offline
                            DutchmanD Offline
                            Dutchman
                            danke ! Tippfehler, bitte nochmal neu von git ziehen jetzt sollte alles kommen :)
                              DutchmanD Offline
                              DutchmanD Offline
                              Dutchman
                              @dutchman sagte in [ESPHome] Beta release:
                              ist jetzt auch behoben ;)
                                mtaxer
                                @dutchman Alle States erscheinen jetzt in den Objekten, sehr gut.
                                Kurz zusammengefasst:
                                • state (true/false - Ein/Aus) - funktioniert
                                • brightness - es kann nur der Wert 0 und 1 eingegeben werden, sollte aber 0 bis 255 sein
                                • blue - es kann nur der Wert 0 und 1 eingegeben werden, sollte aber 0 bis 255 sein
                                • green - es kann nur der Wert 0 und 1 eingegeben werden, sollte aber 0 bis 255 sein
                                • red - es kann nur der Wert 0 und 1 eingegeben werden, sollte aber 0 bis 255 sein
                                • colorTemperature - es kann nur der Wert 0 und 1 eingegeben werden, sollte aber 153 bis 500 sein (Mired)
                                Ich sehe gerade Kommawerte funktionieren (0 bis 0.99). Allerdings ist diese Eingabe eher untypisch bei Helligkeits- und Farbangaben, denke ich zumindest.
                                Optimal wäre noch ein zusätzlicher State der Hex Werte entgegen nimmt, also z.B. #00ff00. Eine Funktion im Adapter zerlegt den Wert in die RGB Werte und gibt es an ESPHome weiter. Ich habe das bis jetzt immer extern mit einem Skript gelöst.
                                function hexToRgb(hex) {
                                  // Expand shorthand form (e.g. "03F") to full form (e.g. "0033FF")
                                  var shorthandRegex = /^#?([a-f\d])([a-f\d])([a-f\d])$/i;
                                  hex = hex.replace(shorthandRegex, function(m, r, g, b) {
                                    return r + r + g + g + b + b;
                                  var result = /^#?([a-f\d]{2})([a-f\d]{2})([a-f\d]{2})$/i.exec(hex);
                                  return result ? {
                                    r: parseInt(result[1], 16),
                                    g: parseInt(result[2], 16),
                                    b: parseInt(result[3], 16)
                                  } : null;
                                return (hexToRgb(hex).r) + "," + (hexToRgb(hex).g) + "," + (hexToRgb(hex).b);
                                Vielen Dank nochmal ...
                                SG
                                Mario
                                DutchmanD 3 Antworten Letzte Antwort
                                • M mtaxer
                                    return result ? {
                                    } : null;
                                  SG
                                  Mario
                                  DutchmanD Offline
                                  DutchmanD Offline
                                  Dutchman
                                  cool ! dan hab ich ja doch nicht al zuviel mist gebaut im framework :)
                                  hmm ok ich muss mal sehe wie das reinkommt, kannste mal bitte den adapter auf debug stellen.
                                  Ich brauche dan fuer die device alles hinter log Eintrag "entityStateData".
                                  Vermute mal muss einfach die Sachen * 100 machen, wen du 0.5 einstellst geht zb die brightness auch auf 50% ?
                                  Ich habe etwas vergleichbares im WLED adapter drin, ist bissl komplizierte dafuer bitte git issue :)
                                  M 2 Antworten Letzte Antwort
                                  • M mtaxer
                                      return result ? {
                                      } : null;
                                    SG
                                    Mario
                                    DutchmanD Offline
                                    DutchmanD Offline
                                    Dutchman
                                    hast du die function zufällig auch andersrum, RGB to hex ?
                                    Edit : hab schon das war ja noch einfacher :/, baue ich heut abend ein :)
                                    function rgbToHex(r, g, b) {
                                      return "#" + componentToHex(r) + componentToHex(g) + componentToHex(b);
                                      mtaxer
                                      @dutchman jetzt warst du schneller 😁
                                      das hätte ich gefunden ...
                                      function componentToHex(c) {
                                      var hex = c.toString(16);
                                      return hex.length == 1 ? "0" + hex : hex;
                                      SG
                                      Mario
                                        mtaxer
                                        Diesen Befehl sende ich via mqtt (so löste/löse ich die Sache bevor du begonnen hast den Adapter zu entwickeln)
                                        Stripe ein, Helligkeit 100% (255), Farbe grün, kein Effekt
                                        {"effect":"None","state":"ON","brightness":255,"color":{"r":0,"g":255,"b":0},"white_value":0}
                                        Das kommt im Log rein
                                        [entityStateData] {"key":801952849,"state":true,"brightness":1,"red":0,"green":1,"blue":0,"white":0,"colorTemperature":0,"effect":"None"}
                                        weiteres Beispiel (mqtt):
                                        Stripe ein, Helligkeit ca. 50% (127), Farbe lila, kein Effekt
                                        {"effect":"None","state":"ON","brightness":127,"color":{"r":136,"g":0,"b":255},"white_value":0}
                                        [entityStateData] {"key":801952849,"state":true,"brightness":0.49803921580314636,"red":0.5333333611488342,"green":0,"blue":1,"white":0,"colorTemperature":0,"effect":"None"}
                                        SG
                                        Mario
                                          mtaxer
                                          genau ...
                                          EDIT:
                                          ich denke die Umrechnung lautet so: Value (Dezimalwert für ESPHome = x (Hex Value für eine Grundfarbe)/255 ---> zB.: 136/255 = 0.5333333611488342 (für obiges Beispiel aus dem Log)
                                          Gilt natürlich auch für die Helligkeit ...
                                          SG
                                          Mario
