  4. JavaScript
  5. [Vorlage] Alias per Skript erzeugen
319 Beiträge 40 Kommentatoren 112.5k Aufrufe 66 Beobachtet
    @Segway sagte:
    read = "!val";
    Das erzeugt einen booleschen Wert und invertiert gleichzeitig. Richtig:
    read = "val == 'true' ? 1 : 0";
    SegwayS
    SegwayS
    Segway
    #209
    @paul53 sagte in [Vorlage] Alias per Skript erzeugen:
    Ja das habe ich auch schon probiert ABER trotzdem wird in dem Aliaswert dann FALSE reingeschrieben warum auch immer:
      "type": "state",
      "common": {
        "name": "VM Influx",
        "desc": "per Script erstellt",
        "type": "boolean",
        "read": true,
        "write": false,
        "role": "value",
        "custom": {
          "influxdb.0": {
            "enabled": true,
            "changesOnly": true,
            "debounce": "",
            "maxLength": 10,
            "retention": 0,
            "changesRelogInterval": "",
            "changesMinDelta": "",
            "storageType": "Boolean",
            "aliasId": ""
          "linkeddevices.0": {
            "enabled": true,
            "number_unit": "",
            "linkedId": "InfluxDB_.is_online",
            "name": "",
            "role": "",
            "mergeSettingsOnRestart": false,
            "expertSettings": false,
            "number_convertTo": "",
            "number_maxDecimal": "",
            "number_min": "",
            "number_max": "",
            "number_calculation": "",
            "number_calculation_readOnly": "",
            "number_to_boolean_condition": "",
            "number_to_boolean_value_true": "",
            "number_to_boolean_value_false": "",
            "number_to_string_condition": "",
            "number_to_duration_convert_seconds": "",
            "number_to_duration_format": "",
            "number_to_datetime_convert_seconds": "",
            "number_to_datetime_format": "",
            "number_to_multi_condition": "",
            "boolean_convertTo": "",
            "boolean_to_string_value_true": "",
            "boolean_to_string_value_false": "",
            "string_convertTo": "",
            "string_prefix": "",
            "string_suffix": "",
            "string_to_boolean_value_true": "",
            "string_to_boolean_value_false": "",
            "string_to_number_unit": "",
            "string_to_number_maxDecimal": "",
            "string_to_number_calculation": "",
            "string_to_number_calculation_readOnly": "",
            "string_to_duration_format": "",
            "string_to_datetime_parser": "",
            "string_to_datetime_format": ""
        "alias": {
          "id": "linux-control.0.VM_Influx.info.is_online",
          "read": "val == 'true' ? 1 : 0"
      "native": {},
      "from": "system.adapter.javascript.0",
      "user": "system.user.admin",
      "ts": 1608034784675,
      "_id": "alias.0.linux-control.0.VM_Influx.info.is_online_InfluxDB",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
    Gruß Dirk
    • SegwayS Segway
        "type": "state",
        "common": {
          "type": "boolean",
          "read": true,
          "write": false,
          "role": "value",
          "custom": {
            "influxdb.0": {
              "enabled": true,
              "debounce": "",
              "maxLength": 10,
              "retention": 0,
              "aliasId": ""
              "enabled": true,
              "number_unit": "",
              "name": "",
              "role": "",
              "number_min": "",
              "number_max": "",
          "alias": {
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
      paul53P
      paul53P
      #210
      @Segway sagte:
      Ich lese
          "type": "boolean",
      ist wirklich vom Typ "string" ? Kann ich mir nicht vorstellen. Falls Typ "boolean", dann
      read = "val ? 1 : 0"
      EDIT:
      log('typ: ' + typeof getState("linux-control.0.Ubuntu_18.info.is_online").val);
      liefert bei mir 'boolean'.
      SegwayS 1 Antwort Letzte Antwort
        @Segway sagte:
        Ich lese
            "type": "boolean",
        EDIT:
        SegwayS
        SegwayS
        Segway
        schrieb am zuletzt editiert von Segway
        #211
        Tja ich sollte nicht zig Dinge auf einmal ändern. Es stand mitllerweile wieder auf boolean. Habe jetzt auf number umgestellt und es klappt. Es landet auch eine 0 im Datenpunkt !
        Allerdings landet bei true eine 0 im Punkt; das müsste ja eine 1 sein oder ?
        Edit:
        Also doch auf boolean stellen ?
        Gruß Dirk
        • SegwayS Segway
          Edit:
          paul53P
          paul53P
          #212
          @Segway sagte:
          Siehe meinen letzten Beitrag:
            @Segway sagte:
            SegwayS
            SegwayS
            Segway
            #213
            @Segway sagte:
            Mhhh, nun hab ich es auf:
            typeAlias = 'boolean'; // oder 'number'
            read = "val ? 1 : 0"; // Erkennung "Aus" --> false erfolgt automatisch
            geändert und es kommt wieder nur TRUE rein :-( anstatt 1
            Gruß Dirk
            • SegwayS Segway
              @Segway sagte:
              paul53P
              paul53P
              #214
              @Segway sagte:
              Das ist falsch !! Lesen !!!
                @Segway sagte:
                SegwayS
                SegwayS
                Segway
                #215
                Ja das weiss ich. Ich habs nun nochmal komplett neu gemacht, allerdings wird mir in der Übersicht angezeigt "1" aber in der datenbank landet true ?????
                iobroker Übersicht:
                iobroker InfluxDB:
                raw-Format:
                  "type": "state",
                  "common": {
                    "type": "number",
                    "read": true,
                    "write": false,
                    "role": "value",
                    "custom": {
                      "influxdb.0": {
                        "enabled": true,
                        "debounce": "",
                        "maxLength": 10,
                        "retention": 0,
                        "aliasId": ""
                        "enabled": true,
                        "number_unit": "",
                        "name": "",
                        "role": "",
                        "number_min": "",
                        "number_max": "",
                    "alias": {
                      "read": "val ? 1 : 0"
                  "native": {},
                  "ts": 1608037099330,
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                Gruß Dirk
                • SegwayS Segway
                  iobroker Übersicht:
                  iobroker InfluxDB:
                  raw-Format:
                    "type": "state",
                    "common": {
                      "type": "number",
                      "read": true,
                      "write": false,
                      "role": "value",
                      "custom": {
                        "influxdb.0": {
                          "enabled": true,
                          "debounce": "",
                          "maxLength": 10,
                          "retention": 0,
                          "aliasId": ""
                          "enabled": true,
                          "number_unit": "",
                          "name": "",
                          "role": "",
                          "number_min": "",
                          "number_max": "",
                      "alias": {
                    "native": {},
                    "acl": {
                      "object": 1636,
                      "state": 1636,
                  paul53P
                  paul53P
                  #216
                  @Segway sagte:
                  • SegwayS Segway
                    Mal eine Frage zu deinem Skript:
                    Ich habe einen Datenpunkt true / false --> type = string
                    Ich möchte nun einen Alias erzeugen der bei true dann 1 liefert und bei false 0 (dürfte dann type = number sein?)
                    Wie mache ich das ?
                    paul53P
                    paul53P
                    #217
                    @Segway sagte:
                    type = "string" ist falsch. Habe PR auf Github erstellt.
                      @Segway sagte:
                      SegwayS
                      SegwayS
                      Segway
                      #218
                      @Segway sagte:
                      Du überforderst mich gerade.
                      Anscheinend liegt hier ein Fehler vor ? Ich habe diesen noch nicht erkannt :-(
                      Gruß Dirk
                      • SegwayS Segway
                        @Segway sagte:
                        paul53P
                        paul53P
                        #219
                        @Segway sagte in:
                        type = "string" ist zwar falsch, hat aber auf die Reaktion des Alias keinen Einfluss, wenn man es weiß. Das Problem ist eher, dass Anwender (wie Du) glauben, was sie an der Stelle lesen.
                        Das Problem mit der DB ist eher der "storageType".
                        SegwayS 2 Antworten Letzte Antwort
                          @Segway sagte in:
                          SegwayS
                          SegwayS
                          Segway
                          #220
                          Ja das hatte ich auch gelesen und habe es einfach per Hand geändert unter RAW aber dann schreibt die Influx nicht mehr da sie den Datentyp nicht kennt :-(
                          Also warte ich mal :-(
                          Gruß Dirk
                            @Segway sagte in:
                            SegwayS
                            SegwayS
                            Segway
                            #221
                            Kann ich das irgendwie auch manuell lösen, dass die 0 und 1 in den Wert geschrieben wird?
                            Gruß Dirk
                            • SegwayS Segway
                              crunchipC
                              crunchipC
                              Developer Global Moderator Most Active Forum Testing
                              #222
                              @Segway nur so nebenbei, wenn du schon einen Datenpunkt in die Influx DB schreibst, auf (auto/boolean) gestellt hattest und änderst es nachträglich auf (number) musst du diesen erst aus der Influx löschen, sofern der DP die gleiche Bezeichnung hat, sonst funktioniert Influx/Grafana nicht mehr und dir wird "no data" angezeigt.
                              PS: mit nem blockly wärst schneller und einfacher gewesen😜
                              hab oben dein RAW nochmal angesehen,
                              ist das nicht doppelt gemoppelt, alias und linkeddevices für den DP zu verwenden oder hab ich nen Denkfehler??
                                SegwayS
                                SegwayS
                                Segway
                                #223
                                @crunchip sagte in [Vorlage] Alias per Skript erzeugen:
                                Ja da hast du vollkommen Recht und genau das ist ja mein problem.
                                Ich habe das Skript genutzt und umgestellt (wie oben gepostet) und durch die Hilfe von @paul53 scheint es so, dass ich alles nach number deklariert habe aber das Skript anscheinend den "storgaeType: Boolean" trotzdem setzt und NICHT auf number !
                                Wenn ich das richtig verstanden habe, gibt es da einen Fehler und er hat das schon als PR auf Github gepostet.
                                Somit kann ich es nicht durch das Skript richtig anlegen - ist jedenfalls meine Schlussfolgerung daraus.
                                Daher die Frage ob ich da manuell irgendwie Hand anlegen kann.
                                Gruß Dirk
                                • SegwayS Segway
                                  paul53P
                                  paul53P
                                  #224
                                  @Segway sagte:
                                  Das macht nicht das Skript, sondern muss eine Einstellung für die DB sein.
                                  @Segway sagte in [Vorlage] Alias per Skript erzeugen:
                                  Der PR hat nichts mit Influx zu tun, sondern betrifft iobroker.linux-control.
                                    @Segway sagte:
                                    SegwayS
                                    SegwayS
                                    Segway
                                    #225
                                    @Segway sagte:
                                    Ja dann weiss ich es auch nicht mehr wo hier das problem liegt. Ich blicke als Laie nunmal da nicht durch.
                                    Fakt ist, ich habe das Skript genutzt und es entsprechend angepasst und es funktioniert auch, dass der Wert in iobroker mit 0 und 1 landet. In Influx landet aber nunmal true / false.
                                    Ich kann nicht mehr erkennen wo nun das Problem liegt.
                                    Zu deiner Aussage
                                    soll mir das jetzt sagen, dass ich nur Boolean Werte in die Influx schreiben kann ?
                                    Ich weiss es einfach nicht und bisher, so leid es mir tut, habe ich noch nirgends eine Lösung gelesen --> mag sein dass sie irgendwo steht und auf meine Dummheit zurückzuführen ist, dass ich Sie nicht erkannt habe.
                                    Nicht falsch verstehen aber so kommt es für mich als Laie halt rüber.
                                    Gruß Dirk
                                    paul53P crunchipC 2 Antworten Letzte Antwort
                                    • SegwayS Segway
                                      @Segway sagte:
                                      Zu deiner Aussage
                                      paul53P
                                      paul53P
                                      #226
                                      @Segway sagte:
                                      Ich verwende Influx nicht, kenne mich also auch nicht aus.
                                      • SegwayS Segway
                                        @Segway sagte:
                                        Zu deiner Aussage
                                        crunchipC
                                        crunchipC
                                        #227
                                        @Segway wenn 1 und 0 im Datenpunkt geschrieben wird, passt es doch.
                                        Klick doch rechts mal auf den Schraubenschlüssel beim Datenpunkt und guck unter influx nach, was da angegeben ist. Da muss number angegeben sein. Wenn nicht, erst deaktivieren, dann in der influx den DP löschen, dann das loggen (Number) wieder aktivieren.
                                          @Segway sagte:
                                          SegwayS
                                          SegwayS
                                          Segway
                                          #228
                                          ICH habe nichts auf Auto/boolean gestellt.
                                          Ich habe das Skript genutzt und der Datenpunkt wird genauso angelegt, da habe ich anscheinend keinen Einfluss drauf.
                                          Es ist halt so, dass der type = number ist ABER der storagetype = boolean
                                          In dem Skript sehe ich nirgends wo der storagetype gesetzt wird.
                                          Und genau das ist ja meineFrage.
                                          Gruß Dirk
                                          83.9k
