  4. Fehler bei Weather Underground
weather forecastundergroundadapterwetter
96 Beiträge 15 Kommentatoren 15.4k Aufrufe 12 Beobachtet
  • GlasfaserG Glasfaser
    @sandro_gera
    Gebe mal nur zum Test , den Ort Duisburg ein .
    sandro_gera
    #71
    @Glasfaser
    host.RaspBee-II-Phoscon	2020-11-06 19:33:23.951	info	instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
    weatherunderground.0	2020-11-06 19:33:23.009	info	(31913) Terminated (NO_ERROR): Without reason
    weatherunderground.0	2020-11-06 19:33:19.777	error	(31913) No forecast data found in response
    weatherunderground.0	2020-11-06 19:33:19.776	error	(31913) No current observation data found in response
    weatherunderground.0	2020-11-06 19:33:19.770	error	(31913) Wunderground reported an error: --/Error: options.uri is a required argument
    weatherunderground.0	2020-11-06 19:33:19.766	error	(31913) Wunderground reported an error: --/Error: options.uri is a required argument
    weatherunderground.0	2020-11-06 19:33:19.762	error	(31913) no observations in response from https://api.weather.com/v3/wx/observations/current?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=0%2C0&units=m&language=de&format=json
    weatherunderground.0	2020-11-06 19:33:17.829	info	(31913) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v12.19.0, js-controller: 3.1.6
    host.RaspBee-II-Phoscon	2020-11-06 19:33:14.104	info	instance system.adapter.weatherunderground.0 started with pid 31913
    host.RaspBee-II-Phoscon	2020-11-06 19:33:14.085	info	instance scheduled system.adapter.weatherunderground.0 12 * * * *
    host.RaspBee-II-Phoscon	2020-11-06 19:33:11.069	info	stopInstance canceled schedule system.adapter.weatherunderground.0
    host.RaspBee-II-Phoscon	2020-11-06 19:33:11.068	info	stopInstance system.adapter.weatherunderground.0 (force=false, process=false)
    Master RPI4 8GB, Slave RPI3 1GB
    Node.js v18.17.1, npm: 9.6.7,
    JS-Controller: 5.0.16
    • S sandro_gera
      @Glasfaser
      GlasfaserG Offline
      GlasfaserG Offline
      #72
      @sandro_gera
      Zeige nochmal deine Adaptereinstellung dazu
        @sandro_gera
        sandro_gera
        #73
        @Glasfaser
        host.RaspBee-II-Phoscon	2020-11-06 19:34:38.590	info	instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
        weatherunderground.0	2020-11-06 19:34:37.612	info	(32717) Terminated (NO_ERROR): Without reason
        weatherunderground.0	2020-11-06 19:34:31.811	info	(32717) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v12.19.0, js-controller: 3.1.6
        host.RaspBee-II-Phoscon	2020-11-06 19:34:28.087	info	instance system.adapter.weatherunderground.0 started with pid 32717
        host.RaspBee-II-Phoscon	2020-11-06 19:34:28.072	info	instance scheduled system.adapter.weatherunderground.0 12 * * * *
        host.RaspBee-II-Phoscon	2020-11-06 19:34:25.062	info	stopInstance canceled schedule system.adapter.weatherunderground.0
        host.RaspBee-II-Phoscon	2020-11-06 19:34:25.061	info	stopInstance system.adapter.weatherunderground.0 (force=false, process=false)
        • S sandro_gera
          @Glasfaser
          GlasfaserG Offline
          GlasfaserG Offline
          #74
          @sandro_gera
          nimm mal Duisburg !!
            @sandro_gera
            sandro_gera
            #75
            @Glasfaser
            host.RaspBee-II-Phoscon	2020-11-06 19:36:35.382	info	instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
            weatherunderground.0	2020-11-06 19:36:34.438	info	(1405) Terminated (NO_ERROR): Without reason
            weatherunderground.0	2020-11-06 19:36:26.988	info	(1405) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v12.19.0, js-controller: 3.1.6
            host.RaspBee-II-Phoscon	2020-11-06 19:36:22.857	info	instance system.adapter.weatherunderground.0 started with pid 1405
            host.RaspBee-II-Phoscon	2020-11-06 19:36:22.840	info	instance scheduled system.adapter.weatherunderground.0 12 * * * *
            host.RaspBee-II-Phoscon	2020-11-06 19:36:19.830	info	stopInstance canceled schedule system.adapter.weatherunderground.0
            host.RaspBee-II-Phoscon	2020-11-06 19:36:19.829	info	stopInstance system.adapter.weatherunderground.0 (force=false, process=false)
            • S sandro_gera
              @Glasfaser
              GlasfaserG Offline
              GlasfaserG Offline
              #76
              @sandro_gera
              Ok ... sieht gut aus mit " Gera " und "Duisburg " .... in 12 Minuten werden dann die Daten abgerufen ..
              Also stimmen deine Koordinaten Eingaben nicht .
                @sandro_gera
                sandro_gera
                schrieb am zuletzt editiert von sandro_gera
                #77
                @Glasfaser
                Ok also das sind die die ioBroker ermittelt.
                Dann geb ich wieder Gera ein und lass die Messstation leer?
                • S sandro_gera
                  @Glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  #78
                  @sandro_gera sagte in Fehler bei Weather Underground:
                  Hast du dich daran gehalten , das eventuell die Koordinaten Zahlen gekürzt werden müssen .
                  https://forum.iobroker.net/topic/30346/fehler-bei-weather-underground/30
                  ... das musst du wissen , wenn es dir so reicht .
                  S 2 Antworten Letzte Antwort
                    sandro_gera
                    #79
                    @Glasfaser
                    ich hatte das schonmal 2 stellig nach dem Komma versucht aber mit dem Ort geht glaub ich besser. Ich versuch das nochmal mit der Messstation
                      sandro_gera
                      #80
                      @Glasfaser
                      host.RaspBee-II-Phoscon	2020-11-06 19:46:33.666	info	instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                      weatherunderground.0	2020-11-06 19:46:32.703	info	(7513) Terminated (NO_ERROR): Without reason
                      weatherunderground.0	2020-11-06 19:46:27.161	info	(7513) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v12.19.0, js-controller: 3.1.6
                      host.RaspBee-II-Phoscon	2020-11-06 19:46:23.089	info	instance system.adapter.weatherunderground.0 started with pid 7513
                      host.RaspBee-II-Phoscon	2020-11-06 19:46:23.067	info	instance scheduled system.adapter.weatherunderground.0 12 * * * *
                      host.RaspBee-II-Phoscon	2020-11-06 19:46:20.052	info	stopInstance canceled schedule system.adapter.weatherunderground.0
                      host.RaspBee-II-Phoscon	2020-11-06 19:46:20.050	info	stopInstance system.adapter.weatherunderground.0 (force=false, process=false)
                      • S sandro_gera
                        @Glasfaser
                        GlasfaserG Offline
                        GlasfaserG Offline
                        #81
                        @sandro_gera
                        ich weiß auch nicht woran es liegt, bei einem geht es , bei dem anderen nicht
                        ..... sieht doch erstmal gut aus dein Log
                          @sandro_gera
                          sandro_gera
                          #82
                          @Glasfaser
                          OK ich danke dir für deine Hilfe. Ich möchte die Daten nutzen um sie in einen Blocky ab einer bestimmten Tempertur die Thermostate auszuschalten und weiterhin möchte ich in iQontrol ein Widget erstellen
                          • S sandro_gera
                            @Glasfaser
                            GlasfaserG Offline
                            GlasfaserG Offline
                            #83
                            Nur mal eine Anregung dazu :
                            https://forum.iobroker.net/topic/32232/material-design-widgets-wetter-view
                              sandro_gera
                              #84
                              @Glasfaser
                              Super vielen Dank. Jetzt muß ich nur noch hinbekommen sowas in iQontrol zu integrieren.
                              • O Offline
                                O Offline
                                Olsen 0
                                #85
                                ich habe alles installiert, Skript bringt keine Fehlermeldung und Vis funktioniert auch weitestgehend. Nur steht bei dem aktuellen Wetter immer "Datenpunkt undefined existiert nicht". Siehe Screenshot.
                                Hat hier jemand eine Lösung? Habe die Foren schon durchsucht, aber bin leider nicht fündig geworden.
                                Danke vorab.
                                sigi234S GlasfaserG 2 Antworten Letzte Antwort
                                • O Olsen 0
                                  Danke vorab.
                                  sigi234S Online
                                  sigi234S Online
                                  #86
                                  @olsen-0
                                  Hallo, sind Daten drinnen unter Objekte?
                                  O 1 Antwort Letzte Antwort
                                  • O Olsen 0
                                    Danke vorab.
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    #87
                                    @olsen-0
                                    das ist kein fehler davon , sondern vom View ... material-design-widgets-wetter-view
                                    siehe dazu hier , du mußt das geänderte Projekt dazu importieren , weiteres steht im Thread:
                                    https://forum.iobroker.net/topic/32232/material-design-widgets-wetter-view/577
                                    • sigi234S sigi234
                                      @olsen-0
                                      O Offline
                                      O Offline
                                      Olsen 0
                                      schrieb am zuletzt editiert von Olsen 0
                                      #88
                                      @sigi234
                                      Super, vielen Danke für die schnelle Hilfe. Da war ich ja echt blind. :-)
                                      Kurze Frage habe ich noch. Ich möchte gern bei der Vorschau-Übersicht für Day 1 auch einen Dialog hinzufügen. Genau bei den anderen 4 Tagen. Habe den Dialog schon angelegt. Aber was muss ich noch machen? Bekomme es leider nicht hin, dass ich bei einem Klick auf Day 1 den Dialog öffnen kann.
                                      Danke vorab für den support.
                                        Stefan 1
                                        #89
                                        Moin!
                                        Funktioniert jetzt der Weather Underground Adapter grundsätzlich noch ohne API Key?
                                        Im Sommer / Herbst hat er noch einwandfrei funktioniert und ich konnte mit den Daten meine Rollladen steuern. Jetzt nach dem Update auf Node 14 ist mir aufgefallen, das die Instanz auf gelb ist. Kann natürlich schon länger der Fall sein, ist mir nur nicht aufgefallen. Alle möglichen Empfehlungen hier aus dem Thread habe ich bereits probiert. Habe auch die Instanz und den Adapter gelöscht und danach neu installiert. Bei jedem starten der Instanz haut er: "Terminated (NO_ERROR): Without reason" raus.
                                        Wie gesagt ich habe bereits den Ort geändert, die Koordinaten eingekürzt, die Station geändert bzw. raus genommen, als Ort Duisburg eingetragen. Ich bekomme ihn einfach nicht zum laufen.
                                        mfg
                                        Stefan
                                        T crunchipC 2 Antworten Letzte Antwort
                                        • S Stefan 1
                                          Moin!
                                          mfg
                                          Stefan
                                          tyros5
                                          schrieb am zuletzt editiert von tyros5
                                          #90
                                          @stefan-1 Hi Stefan, ich habe seit zwei Jahren im Adapter nichts geändert und es läuft immer noch ohne Probleme. Alles (npm, admin, node etc. auf dem aktuellsten Stand)
                                          BTW: über welchen Wert aus diesem Adapter läßt sich die Rolladensteuerung vernünftig abbilden? Danke!
