  4. Fehler bei Weather Underground
weather forecastundergroundadapterwetter
96 Beiträge 15 Kommentatoren 15.4k Aufrufe 12 Beobachtet
  • S sandro_gera
    @Glasfaser
    host.RaspBee-II-Phoscon	2020-11-06 19:34:38.590	info	instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
    weatherunderground.0	2020-11-06 19:34:37.612	info	(32717) Terminated (NO_ERROR): Without reason
    weatherunderground.0	2020-11-06 19:34:31.811	info	(32717) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v12.19.0, js-controller: 3.1.6
    host.RaspBee-II-Phoscon	2020-11-06 19:34:28.087	info	instance system.adapter.weatherunderground.0 started with pid 32717
    host.RaspBee-II-Phoscon	2020-11-06 19:34:28.072	info	instance scheduled system.adapter.weatherunderground.0 12 * * * *
    host.RaspBee-II-Phoscon	2020-11-06 19:34:25.062	info	stopInstance canceled schedule system.adapter.weatherunderground.0
    host.RaspBee-II-Phoscon	2020-11-06 19:34:25.061	info	stopInstance system.adapter.weatherunderground.0 (force=false, process=false)
    GlasfaserG Offline
    GlasfaserG Offline
    #74
    @sandro_gera
    nimm mal Duisburg !!
    • GlasfaserG Glasfaser
      @sandro_gera
      sandro_gera
      #75
      @Glasfaser
      host.RaspBee-II-Phoscon	2020-11-06 19:36:35.382	info	instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
      weatherunderground.0	2020-11-06 19:36:34.438	info	(1405) Terminated (NO_ERROR): Without reason
      weatherunderground.0	2020-11-06 19:36:26.988	info	(1405) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v12.19.0, js-controller: 3.1.6
      host.RaspBee-II-Phoscon	2020-11-06 19:36:22.857	info	instance system.adapter.weatherunderground.0 started with pid 1405
      host.RaspBee-II-Phoscon	2020-11-06 19:36:22.840	info	instance scheduled system.adapter.weatherunderground.0 12 * * * *
      host.RaspBee-II-Phoscon	2020-11-06 19:36:19.830	info	stopInstance canceled schedule system.adapter.weatherunderground.0
      host.RaspBee-II-Phoscon	2020-11-06 19:36:19.829	info	stopInstance system.adapter.weatherunderground.0 (force=false, process=false)
      Master RPI4 8GB, Slave RPI3 1GB
      Node.js v18.17.1, npm: 9.6.7,
      JS-Controller: 5.0.16
      • S sandro_gera
        @Glasfaser
        GlasfaserG Offline
        GlasfaserG Offline
        #76
        @sandro_gera
        Ok ... sieht gut aus mit " Gera " und "Duisburg " .... in 12 Minuten werden dann die Daten abgerufen ..
        Also stimmen deine Koordinaten Eingaben nicht .
          @sandro_gera
          sandro_gera
          schrieb am zuletzt editiert von sandro_gera
          #77
          @Glasfaser
          Ok also das sind die die ioBroker ermittelt.
          Dann geb ich wieder Gera ein und lass die Messstation leer?
          • S sandro_gera
            @Glasfaser
            GlasfaserG Offline
            GlasfaserG Offline
            #78
            @sandro_gera sagte in Fehler bei Weather Underground:
            Hast du dich daran gehalten , das eventuell die Koordinaten Zahlen gekürzt werden müssen .
            https://forum.iobroker.net/topic/30346/fehler-bei-weather-underground/30
            ... das musst du wissen , wenn es dir so reicht .
            S 2 Antworten Letzte Antwort
              sandro_gera
              #79
              @Glasfaser
              ich hatte das schonmal 2 stellig nach dem Komma versucht aber mit dem Ort geht glaub ich besser. Ich versuch das nochmal mit der Messstation
                sandro_gera
                #80
                @Glasfaser
                host.RaspBee-II-Phoscon	2020-11-06 19:46:33.666	info	instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                weatherunderground.0	2020-11-06 19:46:32.703	info	(7513) Terminated (NO_ERROR): Without reason
                weatherunderground.0	2020-11-06 19:46:27.161	info	(7513) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v12.19.0, js-controller: 3.1.6
                host.RaspBee-II-Phoscon	2020-11-06 19:46:23.089	info	instance system.adapter.weatherunderground.0 started with pid 7513
                host.RaspBee-II-Phoscon	2020-11-06 19:46:23.067	info	instance scheduled system.adapter.weatherunderground.0 12 * * * *
                host.RaspBee-II-Phoscon	2020-11-06 19:46:20.052	info	stopInstance canceled schedule system.adapter.weatherunderground.0
                host.RaspBee-II-Phoscon	2020-11-06 19:46:20.050	info	stopInstance system.adapter.weatherunderground.0 (force=false, process=false)
                • S sandro_gera
                  @Glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  #81
                  @sandro_gera
                  ich weiß auch nicht woran es liegt, bei einem geht es , bei dem anderen nicht
                  ..... sieht doch erstmal gut aus dein Log
                    @sandro_gera
                    sandro_gera
                    #82
                    @Glasfaser
                    OK ich danke dir für deine Hilfe. Ich möchte die Daten nutzen um sie in einen Blocky ab einer bestimmten Tempertur die Thermostate auszuschalten und weiterhin möchte ich in iQontrol ein Widget erstellen
                    • S sandro_gera
                      @Glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #83
                      Nur mal eine Anregung dazu :
                      https://forum.iobroker.net/topic/32232/material-design-widgets-wetter-view
                        sandro_gera
                        #84
                        @Glasfaser
                        Super vielen Dank. Jetzt muß ich nur noch hinbekommen sowas in iQontrol zu integrieren.
                        • O Offline
                          O Offline
                          Olsen 0
                          #85
                          ich habe alles installiert, Skript bringt keine Fehlermeldung und Vis funktioniert auch weitestgehend. Nur steht bei dem aktuellen Wetter immer "Datenpunkt undefined existiert nicht". Siehe Screenshot.
                          Hat hier jemand eine Lösung? Habe die Foren schon durchsucht, aber bin leider nicht fündig geworden.
                          Danke vorab.
                          sigi234S GlasfaserG 2 Antworten Letzte Antwort
                          • O Olsen 0
                            Danke vorab.
                            sigi234S Online
                            sigi234S Online
                            #86
                            @olsen-0
                            Hallo, sind Daten drinnen unter Objekte?
                            O 1 Antwort Letzte Antwort
                            • O Olsen 0
                              Danke vorab.
                              GlasfaserG Offline
                              GlasfaserG Offline
                              #87
                              @olsen-0
                              das ist kein fehler davon , sondern vom View ... material-design-widgets-wetter-view
                              siehe dazu hier , du mußt das geänderte Projekt dazu importieren , weiteres steht im Thread:
                              https://forum.iobroker.net/topic/32232/material-design-widgets-wetter-view/577
                              • sigi234S sigi234
                                @olsen-0
                                O Offline
                                O Offline
                                Olsen 0
                                schrieb am zuletzt editiert von Olsen 0
                                #88
                                @sigi234
                                Super, vielen Danke für die schnelle Hilfe. Da war ich ja echt blind. :-)
                                Kurze Frage habe ich noch. Ich möchte gern bei der Vorschau-Übersicht für Day 1 auch einen Dialog hinzufügen. Genau bei den anderen 4 Tagen. Habe den Dialog schon angelegt. Aber was muss ich noch machen? Bekomme es leider nicht hin, dass ich bei einem Klick auf Day 1 den Dialog öffnen kann.
                                Danke vorab für den support.
                                  Stefan 1
                                  #89
                                  Moin!
                                  Funktioniert jetzt der Weather Underground Adapter grundsätzlich noch ohne API Key?
                                  Im Sommer / Herbst hat er noch einwandfrei funktioniert und ich konnte mit den Daten meine Rollladen steuern. Jetzt nach dem Update auf Node 14 ist mir aufgefallen, das die Instanz auf gelb ist. Kann natürlich schon länger der Fall sein, ist mir nur nicht aufgefallen. Alle möglichen Empfehlungen hier aus dem Thread habe ich bereits probiert. Habe auch die Instanz und den Adapter gelöscht und danach neu installiert. Bei jedem starten der Instanz haut er: "Terminated (NO_ERROR): Without reason" raus.
                                  Wie gesagt ich habe bereits den Ort geändert, die Koordinaten eingekürzt, die Station geändert bzw. raus genommen, als Ort Duisburg eingetragen. Ich bekomme ihn einfach nicht zum laufen.
                                  mfg
                                  Stefan
                                  T crunchipC 2 Antworten Letzte Antwort
                                  • S Stefan 1
                                    Moin!
                                    mfg
                                    Stefan
                                    tyros5
                                    schrieb am zuletzt editiert von tyros5
                                    #90
                                    @stefan-1 Hi Stefan, ich habe seit zwei Jahren im Adapter nichts geändert und es läuft immer noch ohne Probleme. Alles (npm, admin, node etc. auf dem aktuellsten Stand)
                                    BTW: über welchen Wert aus diesem Adapter läßt sich die Rolladensteuerung vernünftig abbilden? Danke!
                                    • S Stefan 1
                                      Moin!
                                      mfg
                                      Stefan
                                      crunchipC Offline
                                      crunchipC Offline
                                      #91
                                      @stefan-1 Adapter mal im debug modus starten um zu gucken was bemängelt wird
                                      • T tyros5
                                        Stefan 1
                                        #92
                                        @tyros5
                                        Ich mache es aus einer Kombination von Uhrzeit(Sonnenstand), Temperatur und Bewölkung. Bin letztes Jahr ganz gut damit gefahren.
                                          Stefan 1
                                          schrieb am zuletzt editiert von Stefan 1
                                          #93
                                          @crunchip
                                          hab ich gemacht. ich konnte jetzt keinen Fehler finden. Soll ich dir die Log Datei schicken?
                                          Edit: Mir ist doch etwas aufgefallen. Bevor er Terminated raushaut macht er: Plugin sentry destroyed
