  4. Test Adapter lovelace v0.2.x
    6.5k
testcall for actionlovelacevisualisierung
1.1k Beiträge 131 Kommentatoren 455.0k Aufrufe 99 Beobachtet
  • W WW1983
    @WW1983 said in Test Adapter lovelace v0.2.x:
    Wenn ich Lovelace 1.2.6 installiere erhalte ich folgende Fehlermeldungen. Hat jemand eine Idee woran es liegen kann?
    zigbee.0	2020-09-05 15:40:06.762	error	at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
    zigbee.0	2020-09-05 15:40:06.762	error	at Generator.throw (<anonymous>)
    zigbee.0	2020-09-05 15:40:06.762	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:89:31)
    zigbee.0	2020-09-05 15:40:06.762	error	(29696) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    zigbee.0	2020-09-05 15:40:06.761	error	(29696) Failed to start Zigbee
    Habe gesehen das ich versehentlich den falsch Text kopiert habe. Ich habe folgende Fehlermeldung
    lovelace.0	2020-09-07 16:31:01.501	info	(2776) terminating
    lovelace.0	2020-09-07 16:31:01.475	info	(2776) cleaned everything up...
    lovelace.0	2020-09-07 16:31:01.472	error	at process._tickCallback (internal/process/next_tick.js:68:7)
    lovelace.0	2020-09-07 16:31:01.472	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    lovelace.0	2020-09-07 16:31:01.472	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    lovelace.0	2020-09-07 16:31:01.472	error	at (anonymous function).get (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93703)
    lovelace.0	2020-09-07 16:31:01.472	error	at adapterObjects.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2870:21)
    lovelace.0	2020-09-07 16:31:01.472	error	at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:2376:26)
    lovelace.0	2020-09-07 16:31:01.472	error	at replaceInvalidChars (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:107:21)
    lovelace.0	2020-09-07 16:31:01.472	error	(2776) TypeError: idPart.replace is not a function
    lovelace.0	2020-09-07 16:31:01.466	error	(2776) uncaught exception: idPart.replace is not a function
    Ich habe mal getestet den Adapter nochmal zu installieren (zweites mal). Der läuft sauber ohne Fehlermeldungen
    W Offline
    W Offline
    WW1983
    schrieb am zuletzt editiert von WW1983
    #1008
    Ich habe festgestellt, dass ich auch keine Fehlermeldung erhalte, wenn ich die Version 1.0.16 installiere. Hat irgendjemand eine Idee woran es liegen kann? Komme leider überhaupt nicht weiter.
    GarfonsoG 1 Antwort Letzte Antwort
    • S Strizz
      @Garfonso
      Ich habe noch einen alten Homematic-Rollladen-Schalter gefunden, mit dem ich auch die letzte Rolllade problemlos einbinden konnte. Trotzdem danke für deine Hinweise. Den Device-Adapter kannte ich noch nicht. Werde damit mal weiter experimentieren.
      Bei den Rollladen sind in der Elemente-Card die Pfeile für rauf und runter vertauscht. Gibt es da eine Möglichkeit, dass zu ändern?
      Ich sehe jetzt gerade, dass ich im Thread "Test Lovelace v0.2.x" geschrieben habe. Ich benutze aber die Version 1.2.6. Dennoch ein kurzer Hinweis: Wenn ich das Theme "midnight" (dunkel) verwende, bleibt die Liste der Entities unsichtbar: Hier wird dann eine weiße Schrift auf weißem Hintergrund verwendet.
      GarfonsoG Offline
      GarfonsoG Offline
      Garfonso
      #1009
      @Strizz said in Test Adapter lovelace v0.2.x:
      @Garfonso
      Es gibt in den lovelace-Instanzeinstellungen eine Checkbox, die kann man anhaken oder auslassen. Bei lovelace ist level = 100% = Rolladen ist ganz oben. Wenn man keinen Haken hat, sollten sich die Pfeile / der slider entsprechend verhalten. Wenn man einen Haken macht, dann ist level = 100% = Rolladen ist ganz unten, also alles rumgedreht.
      Wenn da was nicht passt, bitte nochmal bescheid geben (wobei ich da ggf. in der 1.2.6 noch einen Bug drin hatte).
      Ja, der 0.2.x Thread ist der historische und hier geht es gerne auch weiter. :-)
      Ab der 1.2.0 wird eine deutlich neuere Lovelace Version genutzt, dafür müssen die themes angepasst werden. In der Readme wurde das theme angepasst (es kommt meine ich eine Zeile mit Background hinzu).
      Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
      Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
      • W WW1983
        GarfonsoG Offline
        GarfonsoG Offline
        Garfonso
        schrieb am zuletzt editiert von Garfonso
        #1010
        @WW1983
        Hm... wie kann das denn passieren? grübel Also was passiert ist, dass ein manueller entity erstellt werden soll, aber der name anscheinend kein String ist... ?
        Ich versuche das abzufangen. Du kannst einmal, falls du willst, von meinem Github Repository testen (also Garfonso/iobroker.lovelace#dev als URL zum installieren verwenden).
        W 1 Antwort Letzte Antwort
        • GarfonsoG Garfonso
          @WW1983
          W Offline
          W Offline
          WW1983
          #1011
          @Garfonso
          Vielen Dank! Mit deinem Adapter hat es super funktioniert.
          Allerdings habe ich gestern angefangen die manuell angelegten Geräte über den Geräte Adapter als Alias anzulegen. Vielleicht habe ich den Fehlerhaften entity dabei entfernt.
          • W WW1983
            @Garfonso
            W Offline
            W Offline
            WW1983
            #1012
            Ich habe mir einen Homematic Rolladenenaktor eingebaut. Allerding habe ich das Problem das die 100% Anzeige falsch rum dargestellt wird. 100% = offen und 0% = geschlossen. Habe ich die Möglichkeit das zu konvertieren über ein Alias oder direkt über Homematic.
            Danke im Voraus.
              schittl
              schrieb am zuletzt editiert von schittl
              #1013
              Super Projekt!! Bevor ich alles aber einstellen möchte hätte mal noch paar kleine Fragen:
              Gibt es irgendwo die Möglichkeit (Datenpunkt o.ä.) das Thema für Tag & Nacht zeitlich anzupassen (hell/dunkel)?
              Wieso werden die LOWBAT meiner HM Fensterkontakte nicht automatisiert hinzugefügt, die der Thermostate aber schon? (Raum und Funktion sind zugeordnet)
              Gibt es die Möglichkeit die LOWBAT's in der GUI zu negieren, sprich beim false volle Batterie und true leere Batterie (glance), oder geht das nur über alias?
              Wie zeigt man am besten Datenpunkt der Art HTML in Lovelace an (z.B. Tabellen, Listen)?
              HW: Lenovo M920q (Proxmox, ioBroker, RaspMatic & Z2M), QNAP (Docker, Influx), Arduino Mega 2560 R3 (I2C DS18B20 + LED)
              SW: CT IoBroker, VM RaspMatic(v3.79.6.20241122)
              • C Offline
                Chris_104
                #1014
                @Christian kannst du mal ein Bild bzw. Code vom Xiaomi Staubsauger posten?
                Ich hänge da noch irgendwie am Type-Detector fest glaube ich :(
                Vielen Dank schon im voraus :)
                C 1 Antwort Letzte Antwort
                • J Offline
                  janhp
                  #1015
                  ich möchte gerne eine Lichtgruppe erstellen nur leider funktioniert dies nicht.
                  Ich habe diesen Guide befolgt: https://www.home-assistant.io/integrations/light.group
                  Wenn ich den light eintrag + Gruppendefinition in den RAW Editor mache, erhalte ich leider eine Fehlermeldung.
                  Danke.
                  • J janhp
                    Danke.
                    KNXbroker
                    #1016
                    @janhp das kann ich dir beantworten, beschäftigte mich gerade mit Home Assistent selbst. Lichtgruppen werden in der configuration.yaml konfiguriert, diese Datei ist nicht Bestandteil von Lovelace, sondern vom Backend von HomeAssistent ( quasi dem IOBroker). Eine Definition von Gruppen ist nicht möglich.
                    B J 2 Antworten Letzte Antwort
                    • K KNXbroker
                      Banis
                      #1017
                      ich versuche gerade meine ersten Schritte mit ioBroker und hier auch mit dem lovelace adapter. Bin bisher wirklich begeistert, man kann sich hier mir überschaubarem Aufwand ein tolle Visualisierung basteln. Vielen Dank an dieser Stelle an alle Entwickler.
                      Nun aber zu meiner Frage: Bisher hab ich noch keine Möglichkeit gefunden die farbliche Darstellung von Werten in Abhängigkeit von dem Wert hinzubekommen. Ich möchte zum Beispiel die Zimmertemperatur wenn sie unter 18 Grad ist blau darstellen, über 23 Grad rot und sonst schwarz. Hab bei meiner Suche eine solche Funktion nur für Icons gefunden. Gibt es ein Widget mit dem man das auch für Werte das realisieren kann?
                      Gruß Banis
                      • K KNXbroker
                        janhp
                        #1018
                        @KNXbroker vielen Dank für die Auskunft. Ich habe 3x Yeelight Bulbs in einer Lampe und würde diese gleichzeitig steuern können - quasi als ob es eine Lampe ist. Gibt es einen Workaround?
                        Danke schon mal!
                        • J janhp
                          Danke schon mal!
                          KNXbroker
                          #1019
                          @janhp im notfall über ein skript!
                          • Thorsten ZaiT Thorsten Zai
                            @Thorsten-Zai said in Test Adapter lovelace v0.2.x:
                            Hi zusammen,
                            hat wer von euch Homematic eingebunden ?
                            deconz klappt bei mir aber wenn ich auf dem Adapter hm-rpc z.b. einen Fensterkontakt mit Raum und Funktion definere, erscheint er nicht in lovelace :(
                            danke schonmal für eure Hilfe
                            gruss
                            thorsten
                            Hi nochmals,
                            Nun habe ich iobroker komplett neu aufgesetzt, das Problem bleibt aber weiterhin bestehen. Deconz Adapter und Milight bekomme ich eingebunden.
                            Leider aber garkeinen von Homematic. Da die anderen beiden gehen, gehe ich davon aus, dass ich erstmal grundsätzlich mit Function und Rooms alles richtig mache. Wodran könnte es noch liegen ?
                            Habe als Installation :
                            Raspmatic auf einem Raspberry3
                            Iobroker als VM unter ESX auf Basis debian
                            Iobroker selbst ist aktuell
                            Danke vorab
                            Thorsten
                            gyle
                            #1020
                            @Thorsten-Zai konntest du das lösen? Ich habe gerade das gleiche problem mit meinen Aqara Fensterkontakten...Über raum/Function taucht der Sensor nicht auf...!?
                              @Thorsten-Zai
                              Funktioniert das manuelle Zuweisen (nicht über Raum u. Funktion) auch nicht?
                              Hallo , vielen Dank für die Antwort.
                              Da muss ich mich mal kurz doof stellen, manuell zuweisen heisst über die Webseite den Entity konfigurieren ?
                              Da bin ich leider vom Kenntnisstand raus.
                              Vielleicht noch ein Hinweis, bei der alten, sowie auch komplett neuen iobroker Installation habe ich im Log immer folgendes stehen :
                              lovelace.0 2019-12-05 22:32:28.737 error (5244) Cannot find view "custom" for search "state" : null
                              Edit sagt : steht mehrmals im Log aber kein erkennbarer Rythmus
                              Danke vorab
                              Thorsten
                              gyle
                              #1021
                              @Thorsten-Zai
                              Danke vorab
                              Thorsten
                              • G gyle
                                GarfonsoG Offline
                                GarfonsoG Offline
                                Garfonso
                                #1022
                                @gyle said in Test Adapter lovelace v0.2.x:
                                Kannst du den Sensor im Geräte-Tab im Admin sehen? (ggf. devices adapter installieren bzw. den Tab aktivieren). Wenn er da nicht auftaucht, dann kann lovelace ihn auch nicht finden. Dann stimmt was mit rollen / typen oder so nicht. Da wäre dann ein alias anlegen (geht auch mit dem Geräte-Tab) die beste Option.
                                  gyle
                                  #1023
                                  @Garfonso
                                  Nein, im "Geräte" Tab taucht der Sensor nicht auf!?
                                  So sieht es unter Objekten aus:
                                  einen Alias habe ich auch versucht - ging ebenso nicht...
                                  Das einzige was geht ist, wenn ich zusätzlich über den linkedDevices Adapter einen alias erstelle und dort die Werte anpasse von "true/false" auf string "geschlossen/offen" - aber das wird dann irgendwann zu komplex, dass man selbst nicht mehr durchblickt..:-)
                                  • G gyle
                                    @Garfonso
                                    GarfonsoG Offline
                                    GarfonsoG Offline
                                    Garfonso
                                    #1024
                                    @gyle
                                    Die Rolle sollte sensor.window oder sensor.door sein. Am besten einen Alias anlegen und da die Rolle entsprechend setzen. Dann übersetzt der Adapter + Lovelace das true/false in offen/geschlossen (aber nur, wenn die automatische Erkennung über Raum & Funktion geht).
                                    Du kannst den Alias auch mit dem Geräte-Tab direkt anlegen als "Fenster" bzw. "Tür". Dann regelt der das mit der Rolle für dich.
                                      Andy_12345
                                      schrieb am zuletzt editiert von Andy_12345
                                      #1025
                                      @Garfonso
                                      Vielleicht hast Du auch einen Tipp für mich. :-)
                                      Ich in gerade dabei lovelace zu nutzen, allerdings komme ich mit meinen farbigen Tradfri Lampen über deconz/conbee nicht weiter.
                                      Die Entity wird glaube ich korrekt angelegt und kann auch in der Visualisierung genutzt werden (Ein/Aus, Dimmen), allerdings funktioniert das color-picking nicht nicht.
                                      Die Karte/lovelace scheint die Lampe immer mit dem hue-Wert (hs) steuern zu wollen - die Lampe reagiert allerdings nur auf xy Eingaben im Datenpunkt color.cie.
                                      Gibt es eine Möglichkeit das nachträglich zu konfigurieren. Ich habe auch schon versucht, das hue-Feld manuell extra wegzulassen (beim Anlegen der Entity) - das hatte aber auch keinen positiven Effekt.
                                      Wenn ja, wo müsste ich das einstellen.
                                      Danke Dir und ein schönes Wochenende
                                      Beispiel Objektbrowser:
                                        @gyle
                                        gyle
                                        #1026
                                        @Garfonso habe nun einen alias als "Türe" angelegt und er hat entsprechend die Rolle sensor.door gesetzt...
                                        Der alias wird auch von Lovelace als Entität erkannt (binary_sensor.Terrasse_Schiebetuere)...
                                        Es hat mich nur ziemlich Zeit gekostet herauszufinden, warum mein entity-filter nicht geklappt hat: ich hatte hier mit "true" & "Offen" probiert - es braucht aber 'on'....
                                        Kann mir einer den Hintergrund erklären, wann das so ist?
                                        type: entity-filter
                                        entities:
                                          - entity: binary_sensor.Terrasse_Schiebetuere
                                        state_filter:
                                          - 'on'
                                        • A Andy_12345
                                          @Garfonso
                                          GarfonsoG Offline
                                          GarfonsoG Offline
                                          Garfonso
                                          #1027
                                          @Andy_12345 said in Test Adapter lovelace v0.2.x:
                                          @Garfonso
                                          Uhhh... das ist knifflig... also die Lampe hat einen hue-State, aber lässt sich darüber nicht steuern?
                                          Ein Alias, den du anlegst, ohne den Hue-State dürfte nicht als farbige Lampe erkannt werden, oder? Denn einen xy-Lampentyp kennt der ioBroker (noch) nicht... hm. Das müsste man im type-detector hinzufügen. Ggf mal hier ein issue erstellen: https://github.com/ioBroker/ioBroker.type-detector
                                          Bis dahin wäre vermutlich das beste ein Skript zu erstellen und einen RGBSingle Datenpunkt (also einen RGB-Datenpunkt, in dem R,G,B als String ggf. mit # davor eingetragen werden). Ein Skript könnte ca. so aussehen (nicht gedebuggt):
                                          const rgbId = 'javascript.0.tadfri_rgb'; //ein Datenpunkt irgendwo, z.B. javascript.
                                          const xyId = 'tradfri-xy-datenpunkt'; //wir bauen quasi einen alias, aber das ist zu viel für read/write, fürchte ich
                                          const regExp = /#?([A-Fa-f0-9]{2})([A-Fa-f0-9]{2})([A-Fa-f0-9]{2})/g;
                                          on({id: rgbId, ack: false}, (e) => {
                                             const parts = regExp.exec(e.newState.val);
                                             const r = parseInt(parts[1], 16) / 255;
                                             const g = parseInt(parts[2], 16) / 255;
                                             const b = parseInt(parts[3], 16) / 255;
                                             const X = r * 0.649926 + g * 0.103455 + b * 0.197109;
                                             const Y = r * 0.234327 + g * 0.743075 + b * 0.022598;
                                             const Z = r * 0.0000000 + g * 0.053077 + b * 1.035763;
                                             const x = X / (X + Y + Z);
                                             const y = Y / (X + Y + Z);
                                             setState(xyId, [x, y], false); //öhm.. wie setzt man ein State mit array? Hab ich noch nie gemacht. Daher hier ggf. falsch.
                                          function numberToHexStr(n) {
                                             let str = '';
                                             if (n < 16) {
                                                str += '0';
                                             str += Number(n).toString(16);
                                             return str;
                                          //in rgb zurück lesen, sollte lovelace updaten (falls Farbe nicht von noch was anderem im xy State gesetzt werden kann, könnte man das ggf. weglassen)
                                          on({id: xyId, ack: true}, (e) => {
                                             const x = e.newState.val[0]; //geht das so?
                                             const y = e.newState.val[1];
                                             const z = 1.0 - x - y;
                                             const Y = getState('tradfri-brightness').val; //das könnte zu Problemen führen, wenn das nicht synchron gesetzt wird?? -> ggf. würde eine Transformation in hue/saturation/value helfen, aber dazu hab ich keine formel gefunden
                                             const X = (Y / y) * x;
                                             const Z = (Y / y) * z;
                                             const r = r = X * 1.4628067 - Y * 0.1840623 - Z * 0.2743606;
                                             const g = -X * 0.5217933 + Y * 1.4472381 + Z * 0.0677227;
                                             const b = X * 0.0349342 - Y * 0.0968930 + Z * 1.2884099;
                                             setState(rgbId, '#' + numberToHexStr(r) + numberToHexStr(g) + numberToHexStr(b), true);
                                          Aus dem Datenpunkt, der so umgerechnet wird und dem restlichen (an/aus, dimmen, ...) erstellst du dann ein Alias-Device. Damit müsste es dann gehen.
