  4. Nodejs-Update - ioBroker Installation via cURL nicht möglich
node.js updatecurliobroker neuinstallation
87 Beiträge 4 Kommentatoren 15.6k Aufrufe 4 Beobachtet
  • M maxsc
    @Thomas-Braun said in Nodejs-Update - ioBroker Installation via cURL nicht möglich:
    @maxsc
    Probier mal
    traceroute6 ports.ubuntu.com
    traceroute ports.ubuntu.com
    Vermutlich kommst du beim ersten Befehl raus und der zweite wird nicht aufgelöst.
    anders herum
    max@LinuxServer:~$ traceroute6 ports.ubuntu.com
    -bash: traceroute6: command not found
    max@LinuxServer:~$ traceroute ports.ubuntu.com
    traceroute to ports.ubuntu.com (91.189.88.142), 64 hops max
      1   *  192.168.1.100  74.456ms !H  0.011ms !H
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    @maxsc
    sudo apt install traceroute
      @maxsc
      M
      M
      maxsc
      @Thomas-Braun
      max@LinuxServer:~$ sudo apt install traceroute
      [sudo] password for max:
      Reading package lists... Done
      Building dependency tree
      The following NEW packages will be installed:
        traceroute
      0 upgraded, 1 newly installed, 0 to remove and 105 not upgraded.
      Need to get 41.9 kB of archives.
      After this operation, 150 kB of additional disk space will be used.
      Get:1 http://ports.ubuntu.com/ubuntu-ports bionic/universe arm64 traceroute arm64 1:2.1.0-2 [41.9 kB]
      Fetched 41.9 kB in 0s (426 kB/s)
      Selecting previously unselected package traceroute.
      (Reading database ... 161849 files and directories currently installed.)
      Preparing to unpack .../traceroute_1%3a2.1.0-2_arm64.deb ...
      Unpacking traceroute (1:2.1.0-2) ...
      Setting up traceroute (1:2.1.0-2) ...
      update-alternatives: using /usr/bin/traceroute6.db to provide /usr/bin/traceroute6 (traceroute6) in auto mode
      update-alternatives: using /usr/bin/lft.db to provide /usr/bin/lft (lft) in auto mode
      update-alternatives: using /usr/bin/traceproto.db to provide /usr/bin/traceproto (traceproto) in auto mode
      update-alternatives: using /usr/sbin/tcptraceroute.db to provide /usr/sbin/tcptraceroute (tcptraceroute) in auto mode
      Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
      danach kommt auch eine Antwort
      traceroute to ports.ubuntu.com (2001:67c:1360:8001::23), 30 hops max, 80 byte packets
       1  fritz.box (2a01:c22:d061:8e00:2e3a:fdff:fee8:8bea)  1.448 ms  2.340 ms  3.003 ms
       2  2a02:3001::12f (2a02:3001::12f)  22.378 ms  22.816 ms  22.750 ms
       3  2a02:3001::26a (2a02:3001::26a)  12.562 ms  12.833 ms *
       4  * * *
       5  as6939.fra.ecix.net (2001:7f8:8:20:0:1b1b:0:1)  14.041 ms ipv6.decix-frankfurt.core1.fra1.he.net (2001:7f8::1b1b:0:1)  14.911 ms  15.452 ms
       6  * 100ge11-1.core1.fra2.he.net (2001:470:0:404::2)  7.590 ms *
       7  100ge8-1.core1.lon3.he.net (2001:470:0:227::1)  20.692 ms e0-54.core1.ams2.he.net (2001:470:0:489::2)  20.943 ms  22.981 ms
       8  100ge8-1.core1.lon3.he.net (2001:470:0:227::1)  20.809 ms  21.429 ms  21.365 ms
       9  vlan943.annegrit.canonical.com (2001:67c:1360:1::19)  23.136 ms  23.741 ms actiontoad.canonical.com (2001:67c:1360:8001::23)  24.384 ms
      traceroute to ports.ubuntu.com (91.189.88.152), 64 hops max
        1   *  192.168.1.100  61.357ms !H  0.010ms !H
      • M maxsc
        @Thomas-Braun
          traceroute
         4  * * *
        Thomas BraunT
        Thomas BraunT
        @maxsc
        traceroute6 iobroker.net
        traceroute iobroker.net
          @maxsc
          M
          M
          maxsc
          @Thomas-Braun
          max@LinuxServer:~$ traceroute6 iobroker.net
          iobroker.net: No address associated with hostname
          Cannot handle "host" cmdline arg `iobroker.net' on position 1 (argc 1)
          max@LinuxServer:~$ traceroute iobroker.net
          traceroute to iobroker.net (82.165.135.239), 64 hops max
            1   *  192.168.1.100  77.762ms !H  0.013ms !H
          • M maxsc
            @Thomas-Braun
            Thomas BraunT
            Thomas BraunT
            @maxsc
            Das war alles? Das reißt nach dem ersten Hop auf die FritzBox ab?
              @maxsc
              M
              M
              maxsc
              @Thomas-Braun ja, mehr kommt da nicht
              • M maxsc
                Thomas BraunT
                Thomas BraunT
                @maxsc
                Dann ist die Sache klar.
                Du erreichst keine Server, die nur per IPv4 angebunden sind. Wie iobroker.net oder deb.odroid.in z. B.
                Die mit beiden Protokollen ausgestatteten Server bekommst du denn über IPv6. Deswegen kannst du dein OS update und nodeJS aktualisieren.
                Ich weiß nur nicht was man da ggf. in der FritzBox einstellen kann/muss.
                  @maxsc
                  M
                  M
                  maxsc
                  @Thomas-Braun
                  vielen Dank für die Fehlersuche, das hilft sehr weiter.
                  Meinst du das ist ein Problem vom Provider oder von der Fritzbox? Wäre es eine Lösung ipv6 (evtl auch nur vorübergehend) zu deaktivieren?
                  • M maxsc
                    @Thomas-Braun
                    Thomas BraunT
                    Thomas BraunT
                    @maxsc sagte in Nodejs-Update - ioBroker Installation via cURL nicht möglich:
                    Probieren kannst du das mal. In deinem eigenen Netz kommst du ja auch per IPv4 auf die FratzBox drauf. Scheint nur nach draußen nicht geroutet zu werden.
                    M 2 Antworten Letzte Antwort
                    • M maxsc
                      @Thomas-Braun
                      Thomas BraunT
                      Thomas BraunT
                      @maxsc Wie sieht eigentlich der Reiter 'Online-Monitor' auf der Fritzbox aus?
                        M
                        M
                        maxsc
                        @Thomas-Braun
                        jetzt bin ich ein bisschen verwirrt. Laut http://test-ipv6.com/ habe ich keine ipv6 Adresse.
                          M
                          M
                          maxsc
                          • M maxsc
                            @Thomas-Braun
                            Thomas BraunT
                            Thomas BraunT
                            @maxsc Das heißt nix. Sieht bei mir auch so aus.
                              M
                              M
                              maxsc
                              Deaktivieren von ipv6 scheint das Problem auf jeden Fall nicht zu lösen. Schade!
                              • M maxsc
                                Thomas BraunT
                                Thomas BraunT
                                @maxsc
                                Stell mal in der Fritz!Box auf Tunnelprotokoll um:
                                  @maxsc
                                  M
                                  M
                                  maxsc
                                  @Thomas-Braun leider ist keine Änderung zu erkennen. Unter Heimnetz > Netzwerk > Netzwerkeinstellung gibt es noch diverse ipv4 und ipv6 Optionen, aber ich habe keine Ahnung, ob das das Richtige ist.
                                  • M maxsc
                                    Thomas BraunT
                                    Thomas BraunT
                                    @maxsc
                                    Das weiß ich auch nicht.
                                    • M maxsc
                                      crunchipC
                                      crunchipC
                                      Developer Global Moderator Most Active Forum Testing
                                      wenn du IPv6 wirklich deaktiviert hast, unter Internet-->Zugangsdaten-->IPv6,
                                      gibt es doch nur noch Ipv4 unter Netzwerkeinstellung als Option.
                                      Ich kann bei mir leider nicht nachsehen, da ich die Fritzbox nicht mehr als Router/Modem nutze
                                      gibt es da ein Problem? Ich dachte, die alte Verstion (2.2.9 glaube ich) aktualisiert sich bei der Neuinstallation (aktuell sollte ja die 3.1 sein).
                                      weiss ich nicht, ich bin nur davon ausgegangen, das die Installation älteren Semesters ist, (JS-Controller 1.5.x) und die Installation noch zu root Zeiten installiert wurde, als es das (Fixer) Script noch nicht gab.
                                      • M maxsc
                                        nach dem (meiner Meinung nach erfolgreichen) Update von node.js von Version 8.X auf v12.18.4 mit npm 6.14.6 wollte ich ioBroker entsprechend dem Punkt "e) Neuinstallation mit Restore" gemäß https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten/2 aktualisieren.
                                        curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
                                        sudo apt-get install -y nodejs
                                        max@LinuxServer:~$ node -v
                                        v12.18.4
                                        max@LinuxServer:~$ nodejs -v
                                        v12.18.4
                                        max@LinuxServer:~$ npm -v
                                        6.14.6
                                        Leider funktioniert weder der ioBroker-Installationsfixer über
                                        max@LinuxServer:~$ curl -sL -v https://iobroker.net/fix.sh | bash -
                                        *   Trying 82.165.135.239...
                                        * TCP_NODELAY set
                                        * connect to 82.165.135.239 port 443 failed: No route to host
                                        * Failed to connect to iobroker.net port 443: No route to host
                                        * Closing connection 0
                                        noch später die Neuinstallation von ioBroker (e) Neuinstallation mit Restore) über
                                        cp -r /opt/iobroker/iobroker-data <Pfad_zum_sicheren_Ort>
                                        sudo rm -r /opt/iobroker/
                                        sudo mkdir /opt/iobroker
                                        cd /opt/iobroker
                                        curl -sL https://iobroker.net/install.sh | bash -
                                        mit folgender Fehlermeldung
                                        max@LinuxServer:~$ curl -sL -v https://iobroker.net/install.sh | bash -
                                        * TCP_NODELAY set
                                        Die Lösungen aus dem vorherigen Thread https://forum.iobroker.net/topic/23219/iobroker-installation-via-curl-nicht-möglich haben mir leider nicht weitergeholfen.
                                        Ich bin leider noch ziemlicher Neuling (habe das System beim Hauskauf übernommen) und komme nicht weiter. Vielen Dank für Tipps und Hinweise!
                                        ElzersharkE
                                        ElzersharkE
                                        Elzershark
                                        @maxsc
                                        sudo iptables -F
                                        sudo reboot
                                        https://www.youtube.com/c/Elzershark
                                        https://t.me/joinchat/BD87n3xMU0QzYmUy
                                        https://www.facebook.com/elzershark
                                          M
                                          M
                                          maxsc
                                          @crunchip said in Nodejs-Update - ioBroker Installation via cURL nicht möglich:
                                          ich werde es später noch einmal probieren, ich hatte zunächst noch einmal den Tipp von @Thomas-Braun mit dem ipv6 Tunnelprotokoll getestet.
                                          Das System wurde im Januar noch einmal komplett neu aufgesetzt. Leider aber auf nodejs 8.x
                                          84.1k
