  4. Nodejs-Update - ioBroker Installation via cURL nicht möglich
    apollon77A
node.js updatecurliobroker neuinstallation
87 Beiträge 4 Kommentatoren 15.5k Aufrufe 4 Beobachtet
    @maxsc
    Probier mal
    traceroute6 ports.ubuntu.com
    traceroute ports.ubuntu.com
    Vermutlich kommst du beim ersten Befehl raus und der zweite wird nicht aufgelöst.
    M
    M
    maxsc
    @Thomas-Braun said in Nodejs-Update - ioBroker Installation via cURL nicht möglich:
    @maxsc
    Probier mal
    anders herum
    max@LinuxServer:~$ traceroute6 ports.ubuntu.com
    -bash: traceroute6: command not found
    max@LinuxServer:~$ traceroute ports.ubuntu.com
    traceroute to ports.ubuntu.com (91.189.88.142), 64 hops max
      1   *  192.168.1.100  74.456ms !H  0.011ms !H
    • M maxsc
      @maxsc
      Probier mal
      anders herum
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      @maxsc
      sudo apt install traceroute
        @maxsc
        M
        M
        maxsc
        @Thomas-Braun
        max@LinuxServer:~$ sudo apt install traceroute
        [sudo] password for max:
        Reading package lists... Done
        Building dependency tree
        The following NEW packages will be installed:
          traceroute
        0 upgraded, 1 newly installed, 0 to remove and 105 not upgraded.
        Need to get 41.9 kB of archives.
        After this operation, 150 kB of additional disk space will be used.
        Get:1 http://ports.ubuntu.com/ubuntu-ports bionic/universe arm64 traceroute arm64 1:2.1.0-2 [41.9 kB]
        Fetched 41.9 kB in 0s (426 kB/s)
        Selecting previously unselected package traceroute.
        (Reading database ... 161849 files and directories currently installed.)
        Preparing to unpack .../traceroute_1%3a2.1.0-2_arm64.deb ...
        Unpacking traceroute (1:2.1.0-2) ...
        Setting up traceroute (1:2.1.0-2) ...
        update-alternatives: using /usr/bin/traceroute6.db to provide /usr/bin/traceroute6 (traceroute6) in auto mode
        update-alternatives: using /usr/bin/lft.db to provide /usr/bin/lft (lft) in auto mode
        update-alternatives: using /usr/bin/traceproto.db to provide /usr/bin/traceproto (traceproto) in auto mode
        update-alternatives: using /usr/sbin/tcptraceroute.db to provide /usr/sbin/tcptraceroute (tcptraceroute) in auto mode
        Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
        danach kommt auch eine Antwort
        traceroute to ports.ubuntu.com (2001:67c:1360:8001::23), 30 hops max, 80 byte packets
         1  fritz.box (2a01:c22:d061:8e00:2e3a:fdff:fee8:8bea)  1.448 ms  2.340 ms  3.003 ms
         2  2a02:3001::12f (2a02:3001::12f)  22.378 ms  22.816 ms  22.750 ms
         3  2a02:3001::26a (2a02:3001::26a)  12.562 ms  12.833 ms *
         4  * * *
         5  as6939.fra.ecix.net (2001:7f8:8:20:0:1b1b:0:1)  14.041 ms ipv6.decix-frankfurt.core1.fra1.he.net (2001:7f8::1b1b:0:1)  14.911 ms  15.452 ms
         6  * 100ge11-1.core1.fra2.he.net (2001:470:0:404::2)  7.590 ms *
         7  100ge8-1.core1.lon3.he.net (2001:470:0:227::1)  20.692 ms e0-54.core1.ams2.he.net (2001:470:0:489::2)  20.943 ms  22.981 ms
         8  100ge8-1.core1.lon3.he.net (2001:470:0:227::1)  20.809 ms  21.429 ms  21.365 ms
         9  vlan943.annegrit.canonical.com (2001:67c:1360:1::19)  23.136 ms  23.741 ms actiontoad.canonical.com (2001:67c:1360:8001::23)  24.384 ms
        traceroute to ports.ubuntu.com (91.189.88.152), 64 hops max
          1   *  192.168.1.100  61.357ms !H  0.010ms !H
        • M maxsc
          @Thomas-Braun
            traceroute
           4  * * *
          Thomas BraunT
          Thomas BraunT
          @maxsc
          traceroute6 iobroker.net
          traceroute iobroker.net
            @maxsc
            M
            M
            maxsc
            @Thomas-Braun
            max@LinuxServer:~$ traceroute6 iobroker.net
            iobroker.net: No address associated with hostname
            Cannot handle "host" cmdline arg `iobroker.net' on position 1 (argc 1)
            max@LinuxServer:~$ traceroute iobroker.net
            traceroute to iobroker.net (82.165.135.239), 64 hops max
              1   *  192.168.1.100  77.762ms !H  0.013ms !H
            • M maxsc
              @Thomas-Braun
              Thomas BraunT
              Thomas BraunT
              @maxsc
              Das war alles? Das reißt nach dem ersten Hop auf die FritzBox ab?
                @maxsc
                M
                M
                maxsc
                @Thomas-Braun ja, mehr kommt da nicht
                • M maxsc
                  Thomas BraunT
                  Thomas BraunT
                  @maxsc
                  Dann ist die Sache klar.
                  Du erreichst keine Server, die nur per IPv4 angebunden sind. Wie iobroker.net oder deb.odroid.in z. B.
                  Die mit beiden Protokollen ausgestatteten Server bekommst du denn über IPv6. Deswegen kannst du dein OS update und nodeJS aktualisieren.
                  Ich weiß nur nicht was man da ggf. in der FritzBox einstellen kann/muss.
                    @maxsc
                    M
                    M
                    maxsc
                    @Thomas-Braun
                    vielen Dank für die Fehlersuche, das hilft sehr weiter.
                    Meinst du das ist ein Problem vom Provider oder von der Fritzbox? Wäre es eine Lösung ipv6 (evtl auch nur vorübergehend) zu deaktivieren?
                    • M maxsc
                      @Thomas-Braun
                      Thomas BraunT
                      Thomas BraunT
                      @maxsc sagte in Nodejs-Update - ioBroker Installation via cURL nicht möglich:
                      Probieren kannst du das mal. In deinem eigenen Netz kommst du ja auch per IPv4 auf die FratzBox drauf. Scheint nur nach draußen nicht geroutet zu werden.
                      M 2 Antworten Letzte Antwort
                      • M maxsc
                        @Thomas-Braun
                        Thomas BraunT
                        Thomas BraunT
                        @maxsc Wie sieht eigentlich der Reiter 'Online-Monitor' auf der Fritzbox aus?
                          M
                          M
                          maxsc
                          @Thomas-Braun
                          jetzt bin ich ein bisschen verwirrt. Laut http://test-ipv6.com/ habe ich keine ipv6 Adresse.
                            M
                            M
                            maxsc
                            • M maxsc
                              @Thomas-Braun
                              Thomas BraunT
                              Thomas BraunT
                              @maxsc Das heißt nix. Sieht bei mir auch so aus.
                                M
                                M
                                maxsc
                                Deaktivieren von ipv6 scheint das Problem auf jeden Fall nicht zu lösen. Schade!
                                • M maxsc
                                  Thomas BraunT
                                  Thomas BraunT
                                  @maxsc
                                  Stell mal in der Fritz!Box auf Tunnelprotokoll um:
                                    @maxsc
                                    M
                                    M
                                    maxsc
                                    @Thomas-Braun leider ist keine Änderung zu erkennen. Unter Heimnetz > Netzwerk > Netzwerkeinstellung gibt es noch diverse ipv4 und ipv6 Optionen, aber ich habe keine Ahnung, ob das das Richtige ist.
                                    • M maxsc
                                      Thomas BraunT
                                      Thomas BraunT
                                      @maxsc
                                      Das weiß ich auch nicht.
                                      • M maxsc
                                        crunchipC
                                        crunchipC
                                        Developer Global Moderator Most Active Forum Testing
                                        wenn du IPv6 wirklich deaktiviert hast, unter Internet-->Zugangsdaten-->IPv6,
                                        gibt es doch nur noch Ipv4 unter Netzwerkeinstellung als Option.
                                        Ich kann bei mir leider nicht nachsehen, da ich die Fritzbox nicht mehr als Router/Modem nutze
                                        gibt es da ein Problem? Ich dachte, die alte Verstion (2.2.9 glaube ich) aktualisiert sich bei der Neuinstallation (aktuell sollte ja die 3.1 sein).
                                        weiss ich nicht, ich bin nur davon ausgegangen, das die Installation älteren Semesters ist, (JS-Controller 1.5.x) und die Installation noch zu root Zeiten installiert wurde, als es das (Fixer) Script noch nicht gab.
                                        • M maxsc
                                          nach dem (meiner Meinung nach erfolgreichen) Update von node.js von Version 8.X auf v12.18.4 mit npm 6.14.6 wollte ich ioBroker entsprechend dem Punkt "e) Neuinstallation mit Restore" gemäß https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten/2 aktualisieren.
                                          curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
                                          sudo apt-get install -y nodejs
                                          max@LinuxServer:~$ node -v
                                          v12.18.4
                                          max@LinuxServer:~$ nodejs -v
                                          v12.18.4
                                          max@LinuxServer:~$ npm -v
                                          6.14.6
                                          Leider funktioniert weder der ioBroker-Installationsfixer über
                                          max@LinuxServer:~$ curl -sL -v https://iobroker.net/fix.sh | bash -
                                          *   Trying 82.165.135.239...
                                          * TCP_NODELAY set
                                          * connect to 82.165.135.239 port 443 failed: No route to host
                                          * Failed to connect to iobroker.net port 443: No route to host
                                          * Closing connection 0
                                          noch später die Neuinstallation von ioBroker (e) Neuinstallation mit Restore) über
                                          cp -r /opt/iobroker/iobroker-data <Pfad_zum_sicheren_Ort>
                                          sudo rm -r /opt/iobroker/
                                          sudo mkdir /opt/iobroker
                                          cd /opt/iobroker
                                          curl -sL https://iobroker.net/install.sh | bash -
                                          mit folgender Fehlermeldung
                                          max@LinuxServer:~$ curl -sL -v https://iobroker.net/install.sh | bash -
                                          * TCP_NODELAY set
                                          Die Lösungen aus dem vorherigen Thread https://forum.iobroker.net/topic/23219/iobroker-installation-via-curl-nicht-möglich haben mir leider nicht weitergeholfen.
                                          Ich bin leider noch ziemlicher Neuling (habe das System beim Hauskauf übernommen) und komme nicht weiter. Vielen Dank für Tipps und Hinweise!
                                          ElzersharkE
                                          ElzersharkE
                                          Elzershark
                                          @maxsc
                                          sudo iptables -F
                                          sudo reboot
                                          https://www.youtube.com/c/Elzershark
                                          https://t.me/joinchat/BD87n3xMU0QzYmUy
                                          https://www.facebook.com/elzershark
                                          84.1k
