  4. Bedienung und Fehler im Discovery-Adapter
    6.7k
discovery
17 Beiträge 4 Kommentatoren 4.4k Aufrufe 3 Beobachtet
  • Jey CeeJ Online
    Jey CeeJ Online
    Jey Cee
    Mobile Adapter ist ja schon lange outdated, der sollte aus der Liste entfernt werden.
    Persönlicher Support
    Spenden -> paypal.me/J3YC33
    • Jey CeeJ Jey Cee
      @Jey-Cee Danke!
      war auch meine Idee
        Habe eben nochmal meinen Onkyo angeschaltet und Discovery suchen lassen. Auf einmal ging nichts mehr.
        eben sehe ich im Log:
        2020-08-28 16:31:19.313 - info: discovery.0 (4362) Found 68 addresses
        2020-08-28 16:31:59.585 - error: discovery.0 (4362) uncaught exception: Not running
        2020-08-28 16:31:59.588 - error: discovery.0 (4362) Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
        at healthCheck (dgram.js:888:11)
        at Socket.close (dgram.js:710:3)
        at NodeMndp.stop (/opt/iobroker/node_modules/iobroker.discovery/node_modules/node-mndp/dist/index.js:34:25)
        at Socket. (/opt/iobroker/node_modules/iobroker.discovery/node_modules/node-mndp/dist/index.js:49:18)
        at Socket.emit (events.js:315:20)
        at Socket.EventEmitter.emit (domain.js:483:12)
        at dgram.js:340:14
        at processTicksAndRejections (internal/process/task_queues.js:85:21)
        2020-08-28 16:32:00.028 - error: host.ioBroker-Pi2-OG Caught by controller[0]: Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
        2020-08-28 16:32:00.064 - error: host.ioBroker-Pi2-OG Caught by controller[0]: at healthCheck (dgram.js:888:11)
        2020-08-28 16:32:00.065 - error: host.ioBroker-Pi2-OG Caught by controller[0]: at Socket.close (dgram.js:710:3)
        2020-08-28 16:32:00.066 - error: host.ioBroker-Pi2-OG Caught by controller[0]: at NodeMndp.stop (/opt/iobroker/node_modules/iobroker.discovery/node_modules/node-mndp/dist/index.js:34:25)
        2020-08-28 16:32:00.067 - error: host.ioBroker-Pi2-OG Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/iobroker.discovery/node_modules/node-mndp/dist/index.js:49:18)
        2020-08-28 16:32:00.068 - error: host.ioBroker-Pi2-OG Caught by controller[0]: at Socket.emit (events.js:315:20)
        2020-08-28 16:32:00.069 - error: host.ioBroker-Pi2-OG Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:483:12)
        2020-08-28 16:32:00.070 - error: host.ioBroker-Pi2-OG Caught by controller[0]: at dgram.js:340:14
        2020-08-28 16:32:00.071 - error: host.ioBroker-Pi2-OG Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:85:21)
        2020-08-28 16:32:00.073 - error: host.ioBroker-Pi2-OG instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        Der nächste Lauf ging dann durch. Allerdings auch noch was:
        2020-08-28 16:45:28.448 - info: discovery.0 (6714) Found 70 addresses
        2020-08-28 16:46:19.754 - error: discovery.0 (6714) Cannot detect "sonos" on "192.168.138.59": TypeError: Cannot convert undefined or null to object
        2020-08-28 16:46:20.001 - error: discovery.0 (6714) Cannot detect "sonos" on "192.168.138.80": TypeError: Cannot convert undefined or null to object
        2020-08-28 16:46:20.103 - error: discovery.0 (6714) Cannot detect "sonos" on "192.168.138.81": TypeError: Cannot convert undefined or null to object
        2020-08-28 16:46:20.201 - info: discovery.0 (6714) Discovery finished. Found new or modified 23 instances
        Was auch die Meldung ohne IP bei SONOS erklärt, wobei ich aber 4 PLAY:1 im Netz hätte
          @crunchip
          Habe jetzt eine zusätzliche Tabelle mit den anzulegenden Issues im vorigen Post erstellt..
          Was ist mit Onkyo und Chromcast?
          Hatte meinen Onkyo gestern nicht an, und den Chromcast habe ich (vorübergehend) stillgelegt, weil der andauernd wieder sein offenes Start-Netzwerk gestartet hatte, so dass theoretisch jeder Nachbar sich hätte darauf einloggen können :-(
          Meintest du dass nicht cloud, sondern iot für Alexa angegeben werden sollte?
          @crunchip sagte in Bedienung und Fehler im Discovery-Adapter:
          Empfohlene wird einem sozusagen "aufgeschwatzt"
          das schrieb ich ja auch, dass Einsteiger davon irregeleitet werden, wobei das schon bei der ersten Liste so ist, "empfohlen" sind ja sogar noch weitergehende Adapter.
          wie aber @apollon77 auch schrieb: Was soll man noch an text hinzufügen, damit das Hirn des users aktiviert wird und nicht blind alles angehakt wird.
          crunchipC Offline
          crunchipC Offline
          @Homoran sagte in Bedienung und Fehler im Discovery-Adapter:
          ich würde das ganz weg lassen, derjenige, der entsprechend iobroker nutzen möchte, kann sich seine Adapter selbst nach seinen Bedürfnissen suchen. Nicht jeder erstellt ne Vis, auch nicht jeder verwendet cloud/iot.
          Es sollten nur vorhandenen Gerätschaften erkannt werden, so ist zumindest meine Auffassung.
          bei beiden ist in deinm Screenshot eine IP hionterlegt. Bei Chromcast sieht es fast so aus als ob da auch gerade wieder der login-Screen offen ist - die IP passt überhaupt nicht in deinen üblichen Range!
          ich hatte früher noch diese IP Range(Fritzbox) mittlerweile UniFi, keine Ahnung warum der Chromecast noch mit seiner alten IP angezeigt wird, hatte den ins neue Wlan eingebunden und isst auch laut Netzwerk und APP im richtigen 10.1.1.x Netz
          ist das bei Onkyo der konfigurierte Receiver?
          wie oben gezeigt und beschrieben -- autodiscovery/ leer gelassen beim Onkyo
          ich meinte damit, warum wird mir cloud empfohlen, wenn IoT schon vorhanden ist
            ohne es zu wissen, behaupte ich mal, dass die s ein alter allgemeiner Satz ist, bevor es iot gab.
            das war er bei mir auch. trotzdem öffnete er immer mal wieder sein Anmelde-Portal
            das sehe ich ähnlich. Zumindest sollte dann eine etwas umfangreichere Info darüberstehen, wenn möglich in einer "Trennzeile" so etwas wie: für die weitere Nutzung von ioBroker können bei entsprechendem Interesse folgende Adapter empfohlen werden:
              crunchipC Offline
              crunchipC Offline
              blöd gefragt, wie überprüfe ich das am einfachsten, denn sollte es so sein, ist mir das bisher noch nicht aufgefallen
                Ich hatte damals massive Probleme mit dem Fritz mesh und immer wieder mit der Fritz!WLAN app überprüft.
                Die zeigte mir dann immer wieder den chromecast als verfügbares WLAN an.
                  at dgram.js:340:14
                  apollon77A Online
                  apollon77A Online
                  Das ist in der aktuellsten Discovery gefixt ... ist denke nur noch nicht im Stable
                  • apollon77A apollon77
                    @apollon77 sagte in Bedienung und Fehler im Discovery-Adapter:
                    Danke!
                    habe mal ganz frech aus github installiert: v2-3-11 (vorher 2.3.7) der Fehler tart (bisher) nicht wieder auf.
                    Habe dann noch etwas bemerkt und daher das log auf debug gestellt und es hat mich erschlagen ;-)
                    passt hier gar nicht rein, deswegen als txt im Anhang
                    Der hm-rpc hat zwar meinen CuxD, hm und hmip rf gefunden , aber nicht mein hm-wired
                    Das Gateway wird zwar gefunden und auf hm-rpc getestet aber nada:
                    2020-08-29 17:04:51.419 - debug: discovery.0 (9591) Test ip 192.168.138.75 hm-rpc
                    Ebenso weiterhin die fehlende Identifikation der Sonos-Boxen
                    alle 4 IPs werden gefinden (.59,.80,.81 und .152), aber nur die 81 wird identifiziert
                    1.
                    Dann kam aber der Fehler:
                    2020-08-29 17:05:06.189 - error: discovery.0 (9591) Cannot detect "sonos" on "192.168.138.81": TypeError: Cannot convert undefined or null to object
                    in einem anderen Durchlauf war es die .59
                    @apollon77
                    Wo müssen die ISuues hin?
                    alle (einzeln natürlich) bei discovery oder bei den entsprechenden Adaptern?
                    Hier der log
                    disco_log.txt
                      Danke!
                      1.
                      @apollon77
                      Hier der log
                      disco_log.txt
                      apollon77A Online
                      apollon77A Online
                      in Discovery
