  4. Test Adapter Linux Control v1.x.x
    apollon77A
adaptercontrolhardwarelinuxsteuern
718 Beiträge 74 Kommentatoren 296.4k Aufrufe 67 Beobachtet
  • ScroungerS Scrounger
    @liv-in-sky
    So neue Version 0.2.7 ist auf github.
    @Homoran
    Bitte die auch nochmal testen, hab da noch was eingebaut, was deinen fehler hoffentlich jetzt löst.
    @Scrounger sagte in Test Adapter Linux Control v0.x.x:
    @Homoran
    Bin nicht mehr an den PC gekommen.
    habe es vom tablet versucht
    2020-08-17 21:19:29.989 - info: linux-control.0 (10867) getting data from RasPi4 (192.168.138.139:22)
    2020-08-17 21:19:30.021 - debug: linux-control.0 (10867) [getConnection] Host 'RasPi4' (192.168.138.139:22): using sudo for authentification
    2020-08-17 21:19:30.207 - debug: linux-control.0 (10867) [distributionInfo] RasPi4 (192.168.138.139:22): send command: 'cat /etc/os-release'
    2020-08-17 21:19:30.564 - debug: linux-control.0 (10867) [distributionInfo] RasPi4 (192.168.138.139:22): response stdout: PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    2020-08-17 21:19:30.601 - debug: linux-control.0 (10867) [distributionInfo] RasPi4 (192.168.138.139:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Raspbian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Raspbian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"raspbian"},{"prop":"ID_LIKE","val":"debian"},{"prop":"HOME_URL","val":"http://www.raspbian.org/"},{"prop":"SUPPORT_URL","val":"http://www.raspbian.org/RaspbianForums"},{"prop":"BUG_REPORT_URL","val":"http://www.raspbian.org/RaspbianBugs"}]
    2020-08-17 21:19:30.616 - debug: linux-control.0 (10867) [cmdAptUpdate] RasPi4 (192.168.138.139:22): no datapoints selected -> removing existing datapoints
    2020-08-17 21:19:30.622 - debug: linux-control.0 (10867) [servicesInfo] RasPi4 (192.168.138.139:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
    2020-08-17 21:19:30.646 - debug: linux-control.0 (10867) [servicesInfo] RasPi4 (192.168.138.139:22): response stdout: alsa-restore.service,loaded,active,exited, Save/Restore Sound Card State
    alsa-state.service,loaded,active,running, Manage Sound Card State (restore and store)
    apparmor.service,not-found,inactive,dead, apparmor.service
    apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities
    apt-daily.service,loaded,inactive,dead, Daily apt download activities
    auditd.service,not-found,inactive,dead, auditd.service
    auth-rpcgss-module.service,loaded,inactive,dead, Kernel Module supporting RPCSEC_GSS
    avahi-daemon.service,loaded,active,running, Avahi mDNS/DNS-SD Stack
    bluetooth.service,loaded,active,running, Bluetooth service
    bthelper@hci0.service,loaded,inactive,dead, Raspberry Pi bluetooth helper
    connman.service,not-found,inactive,dead, connman.service
    console-screen.service,not-found,inactive,dead, console-screen.service
    console-setup.service,loaded,active,exited, Set console font and keymap
    cron.service,loaded,active,running, Regular background program processing daemon
    dbus.service,loaded,active,running, D-Bus System Message Bus
    dhcpcd.service,loaded,active,running, dhcpcd on all interfaces
    display-manager.service,not-found,inactive,dead, display-manager.service
    dphys-swapfile.service,loaded,active,exited, dphys-swapfile - set up, mount/unmount, and delete a swap file
    emergency.service,loaded,inactive,dead, Emergency Shell
    fake-hwclock.service,loaded,active,exited, Restore / save the current clock
    getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available
    getty@tty1.service,loaded,active,running, Getty on tty1
    gssproxy.service,not-found,inactive,dead, gssproxy.service
    hciuart.service,loaded,active,running, Configure Bluetooth Modems connected by UART
    ifupdown-pre.service,loaded,active,exited, Helper to synchronize boot up for ifupdown
    influxdb.service,not-found,inactive,dead, influxdb.service
    iobroker.service,loaded,active,running, ioBroker Server
    kbd.service,not-found,inactive,dead, kbd.service
    keyboard-setup.service,loaded,active,exited, Set the console keyboard layout
    kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel
    logrotate.service,loaded,inactive,dead, Rotate log files
    man-db.service,loaded,inactive,dead, Daily man-db regeneration
    mariadb-server.service,not-found,inactive,dead, mariadb-server.service
    mountkernfs.service,masked,inactive,dead, mountkernfs.service
    mysql-server.service,not-found,inactive,dead, mysql-server.service
    networking.service,loaded,active,exited, Raise network interfaces
    NetworkManager.service,not-found,inactive,dead, NetworkManager.service
    nfs-blkmap.service,not-found,inactive,dead, nfs-blkmap.service
    nfs-config.service,loaded,inactive,dead, Preprocess NFS configuration
    nfs-server.service,not-found,inactive,dead, nfs-server.service
    nfs-utils.service,loaded,inactive,dead, NFS server and client services
    plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service
    plymouth-start.service,not-found,inactive,dead, plymouth-start.service
    raspberrypi-net-mods.service,loaded,inactive,dead, Copy user wpa_supplicant.conf
    raspi-config.service,loaded,active,exited, LSB: Switch to ondemand cpu governor (unless shift key is pressed)
    rc-local.service,loaded,active,exited, /etc/rc.local Compatibility
    redis.service,not-found,inactive,dead, redis.service
    regenerate_ssh_host_keys.service,loaded,inactive,dead, Regenerate SSH host keys
    rescue.service,loaded,inactive,dead, Rescue Shell
    rng-tools.service,loaded,active,running, rng-tools.service
    rpc-gssd.service,loaded,inactive,dead, RPC security service for NFS client and server
    rpc-svcgssd.service,loaded,inactive,dead, RPC security service for NFS server
    rpi-eeprom-update.service,loaded,active,exited, Check for Raspberry Pi EEPROM updates
    rsync.service,loaded,inactive,dead, fast remote file copy program daemon
    rsyslog.service,loaded,active,running, System Logging Service
    ssh.service,loaded,active,running, OpenBSD Secure Shell server
    sshswitch.service,loaded,inactive,dead, Turn on SSH if /boot/ssh is present
    systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console
    systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall
    systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats
    systemd-fsck-root.service,loaded,active,exited, File System Check on Root Device
    systemd-fsck@dev-disk-by\x2dpartuuid-50fbae26\x2d01.service,loaded,active,exited, File System Check on /dev/disk/by-partuuid/50fbae26-01
    systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status
    systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database
    systemd-initctl.service,loaded,inactive,dead, initctl Compatibility Daemon
    systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage
    systemd-journald.service,loaded,active,running, Journal Service
    systemd-logind.service,loaded,active,running, Login Service
    systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk
    systemd-modules-load.service,loaded,active,exited, Load Kernel Modules
    systemd-networkd.service,loaded,inactive,dead, Network Service
    systemd-quotacheck.service,loaded,inactive,dead, File System Quota Check
    systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed
    systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems
    systemd-rfkill.service,loaded,inactive,dead, Load/Save RF Kill Switch Status
    systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables
    systemd-sysusers.service,loaded,active,exited, Create System Users
    systemd-timesyncd.service,loaded,active,running, Network Time Synchronization
    systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories
    systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev
    systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories
    systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices
    systemd-udevd.service,loaded,active,running, udev Kernel Device Manager
    systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service
    systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes
    systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown
    systemd-user-sessions.service,loaded,active,exited, Permit User Sessions
    systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service
    triggerhappy.service,loaded,active,running, triggerhappy global hotkey daemon
    user-runtime-dir@1000.service,loaded,active,exited, User Runtime Directory /run/user/1000
    user@1000.service,loaded,active,running, User Manager for UID 1000
    wpa_supplicant.service,loaded,active,running, WPA supplicant
    2020-08-17 21:19:30.651 - debug: linux-control.0 (10867) [servicesInfo] RasPi4 (192.168.138.139:22): csvToJson result: [{"id":"alsa-restore.service","load":"loaded","active":"active","running":"exited","description":"Save/Restore Sound Card State"},{"id":"alsa-state.service","load":"loaded","active":"active","running":"running","description":"Manage Sound Card State (restore and store)"},{"id":"apparmor.service","load":"not-found","active":"inactive","running":"dead","description":"apparmor.service"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"avahi-daemon.service","load":"loaded","active":"active","running":"running","description":"Avahi mDNS/DNS-SD Stack"},{"id":"bluetooth.service","load":"loaded","active":"active","running":"running","description":"Bluetooth service"},{"id":"bthelper@hci0.service","load":"loaded","active":"inactive","running":"dead","description":"Raspberry Pi bluetooth helper"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"dhcpcd.service","load":"loaded","active":"active","running":"running","description":"dhcpcd on all interfaces"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"dphys-swapfile.service","load":"loaded","active":"active","running":"exited","description":"dphys-swapfile - set up","field6":"mount/unmount","field7":"and delete a swap file"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"fake-hwclock.service","load":"loaded","active":"active","running":"exited","description":"Restore / save the current clock"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"hciuart.service","load":"loaded","active":"active","running":"running","description":"Configure Bluetooth Modems connected by UART"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mountkernfs.service","load":"masked","active":"inactive","running":"dead","description":"mountkernfs.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"raspberrypi-net-mods.service","load":"loaded","active":"inactive","running":"dead","description":"Copy user wpa_supplicant.conf"},{"id":"raspi-config.service","load":"loaded","active":"active","running":"exited","description":"LSB: Switch to ondemand cpu governor (unless shift key is pressed)"},{"id":"rc-local.service","load":"loaded","active":"active","running":"exited","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"regenerate_ssh_host_keys.service","load":"loaded","active":"inactive","running":"dead","description":"Regenerate SSH host keys"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rng-tools.service","load":"loaded","active":"active","running":"running","description":"rng-tools.service"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpi-eeprom-update.service","load":"loaded","active":"active","running":"exited","description":"Check for Raspberry Pi EEPROM updates"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"sshswitch.service","load":"loaded","active":"inactive","running":"dead","description":"Turn on SSH if /boot/ssh is present"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"active","running":"exited","description":"File System Check on Root Device"},{"id":"systemd-fsck@dev-disk-by\\x2dpartuuid-50fbae26\\x2d01.service","load":"loaded","active":"active","running":"exited","description":"File System Check on /dev/disk/by-partuuid/50fbae26-01"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-quotacheck.service","load":"loaded","active":"inactive","running":"dead","description":"File System Quota Check"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"triggerhappy.service","load":"loaded","active":"active","running":"running","description":"triggerhappy global hotkey daemon"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"},{"id":"wpa_supplicant.service","load":"loaded","active":"active","running":"running","description":"WPA supplicant"}]
    2020-08-17 21:19:31.867 - debug: linux-control.0 (10867) system.adapter.admin.0: logging true
    2020-08-17 21:19:31.991 - debug: linux-control.0 (10867) [needrestart] RasPi4 (192.168.138.139:22): no datapoints selected -> removing existing datapoints
    2020-08-17 21:19:32.011 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'sudo -S du -sk /opt/iobroker/iobroker-data/history | awk '{ print $1 /1024 }''
    2020-08-17 21:19:32.211 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
    197.395
    2020-08-17 21:19:32.213 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.size: 197.4 MB
    2020-08-17 21:19:32.218 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'sudo -S find /opt/iobroker/iobroker-data/history -name "*" | wc -l'
    2020-08-17 21:19:32.398 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
    22422
    2020-08-17 21:19:32.399 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.files: 22422 Dateien
    2020-08-17 21:19:32.458 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'tmp=$(sudo -S find /opt/iobroker/iobroker-data/history -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
    2020-08-17 21:20:00.035 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 18243
    2020-08-17 21:20:07.066 - info: dwd.0 (18243) starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.21.0, js-controller: 3.1.4
    2020-08-17 21:20:08.634 - info: dwd.0 (18243) Terminated (NO_ERROR): Without reason
    2020-08-17 21:20:09.148 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
    2020-08-17 21:20:40.652 - info: hm-rpc.1 (21580) xmlrpc <- listDevices ["hm-rpc.1"]
    2020-08-17 21:20:40.820 - info: hm-rpc.1 (21580) xmlrpc -> 0 devices
    2020-08-17 21:20:41.396 - info: hm-rpc.1 (21580) xmlrpc <- newDevices 167
    2020-08-17 21:20:41.593 - info: hm-rpc.1 (21580) new HmIP devices/channels after filter: 0
    2020-08-17 21:21:10.975 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
    1597691863
    2020-08-17 21:21:10.979 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.lastChange: 1597691863000 -> 17.08.2020 21:17
    2020-08-17 21:21:11.029 - debug: linux-control.0 (10867) [userCommand] RasPi4 (192.168.138.139:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
    2020-08-17 21:21:11.056 - debug: linux-control.0 (10867) [userCommand] RasPi4 (192.168.138.139:22, id: root, description: ): response stdout: 19
    2020-08-17 21:21:11.061 - debug: linux-control.0 (10867) [userCommand] RasPi4 (192.168.138.139:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1'
    2020-08-17 21:21:11.080 - debug: linux-control.0 (10867) [userCommand] RasPi4 (192.168.138.139:22, id: ip, description: ): response stdout: 192.168.138.139
    2020-08-17 21:21:11.089 - debug: linux-control.0 (10867) [userCommand] RasPi4 (192.168.138.139:22, id: cpu-temp, description: ): send command: 'vcgencmd measure_temp | awk '{print substr($1, length($0)-5,4)}''
    2020-08-17 21:21:11.106 - debug: linux-control.0 (10867) [userCommand] RasPi4 (192.168.138.139:22, id: cpu-temp, description: ): response stdout: 55.0
    2020-08-17 21:21:11.112 - info: linux-control.0 (10867) successful received data from RasPi4 (192.168.138.139:22)
    2020-08-17 21:21:11.113 - info: linux-control.0 (10867) getting data from NUC_VM (192.168.138.123:22)
    2020-08-17 21:21:11.145 - debug: linux-control.0 (10867) [getConnection] Host 'NUC_VM' (192.168.138.123:22): using sudo for authentification
    2020-08-17 21:21:11.204 - debug: linux-control.0 (10867) [distributionInfo] NUC_VM (192.168.138.123:22): send command: 'cat /etc/os-release'
    2020-08-17 21:21:11.265 - debug: linux-control.0 (10867) [distributionInfo] NUC_VM (192.168.138.123:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
    NAME="Debian GNU/Linux"
    VERSION_ID="10"
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    2020-08-17 21:21:11.267 - debug: linux-control.0 (10867) [distributionInfo] NUC_VM (192.168.138.123:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
    2020-08-17 21:21:11.334 - debug: linux-control.0 (10867) [cmdAptUpdate] NUC_VM (192.168.138.123:22): no datapoints selected -> removing existing datapoints
    2020-08-17 21:21:11.338 - debug: linux-control.0 (10867) [servicesInfo] NUC_VM (192.168.138.123:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
    2020-08-17 21:21:11.351 - debug: linux-control.0 (10867) [servicesInfo] NUC_VM (192.168.138.123:22): response stdout: apache2.service,loaded,active,running, The Apache HTTP Server
    apparmor.service,loaded,active,exited, Load AppArmor profiles
    clamav-daemon.service,not-found,inactive,dead, clamav-daemon.service
    cups-browsed.service,loaded,failed,failed, Make remote CUPS printers available locally
    cups.service,loaded,active,running, CUPS Scheduler
    exim4.service,loaded,active,running, LSB: exim Mail Transport Agent
    greylist.service,not-found,inactive,dead, greylist.service
    ifup@ens18.service,loaded,active,exited, ifup for ens18
    irqbalance.service,loaded,active,running, irqbalance daemon
    mysql.service,not-found,inactive,dead, mysql.service
    ntp.service,loaded,active,running, Network Time Service
    postgresql.service,not-found,inactive,dead, postgresql.service
    rc-local.service,loaded,inactive,dead, /etc/rc.local Compatibility
    rpcbind.service,loaded,active,running, RPC bind portmap service
    spamassassin.service,not-found,inactive,dead, spamassassin.service
    systemd-fsck-root.service,loaded,inactive,dead, File System Check on Root Device
    systemd-timesyncd.service,loaded,inactive,dead, Network Time Synchronization
    2020-08-17 21:21:11.358 - debug: linux-control.0 (10867) [servicesInfo] NUC_VM (192.168.138.123:22): csvToJson result: [{"id":"apache2.service","load":"loaded","active":"active","running":"running","description":"The Apache HTTP Server"},{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"avahi-daemon.service","load":"loaded","active":"active","running":"running","description":"Avahi mDNS/DNS-SD Stack"},{"id":"clamav-daemon.service","load":"not-found","active":"inactive","running":"dead","description":"clamav-daemon.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"cups-browsed.service","load":"loaded","active":"failed","running":"failed","description":"Make remote CUPS printers available locally"},{"id":"cups.service","load":"loaded","active":"active","running":"running","description":"CUPS Scheduler"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"exim4.service","load":"loaded","active":"active","running":"running","description":"LSB: exim Mail Transport Agent"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"greylist.service","load":"not-found","active":"inactive","running":"dead","description":"greylist.service"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"irqbalance.service","load":"loaded","active":"active","running":"running","description":"irqbalance daemon"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"mysql.service","load":"not-found","active":"inactive","running":"dead","description":"mysql.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"ntp.service","load":"loaded","active":"active","running":"running","description":"Network Time Service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"postgresql.service","load":"not-found","active":"inactive","running":"dead","description":"postgresql.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpcbind.service","load":"loaded","active":"active","running":"running","description":"RPC bind portmap service"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"spamassassin.service","load":"not-found","active":"inactive","running":"dead","description":"spamassassin.service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}]
    2020-08-17 21:21:11.811 - debug: linux-control.0 (10867) [needrestart] NUC_VM (192.168.138.123:22): no datapoints selected -> removing existing datapoints
    2020-08-17 21:21:11.829 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'sudo -S du -sk /opt/iobroker/iobroker-data/history | awk '{ print $1 /1024 }''
    2020-08-17 21:21:12.177 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): response stdout:
    13598.2
    2020-08-17 21:21:12.181 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.size: 13598.2 MB
    2020-08-17 21:21:12.229 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'sudo -S find /opt/iobroker/iobroker-data/history -name "*" | wc -l'
    2020-08-17 21:21:12.452 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): response stdout:
    113112
    2020-08-17 21:21:12.456 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.files: 113112 Dateien
    2020-08-17 21:21:12.509 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'tmp=$(sudo -S find /opt/iobroker/iobroker-data/history -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
    2020-08-17 21:21:29.454 - info: info.0 (779) Popup news was read...
    2020-08-17 21:23:30.505 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): response stdout:
    1597692206
    2020-08-17 21:23:30.509 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.lastChange: 1597692206000 -> 17.08.2020 21:23
    2020-08-17 21:23:30.559 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
    2020-08-17 21:23:30.573 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22, id: root, description: ): response stdout: 56
    2020-08-17 21:23:30.632 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1'
    2020-08-17 21:23:30.641 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22, id: ip, description: ): response stdout: 192.168.138.123
    2020-08-17 21:23:30.648 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22): datapoint-id: 'cpu-temp', description: '' -> is not enabled!
    2020-08-17 21:23:30.649 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22, id: Ordner, description: ): send command: 'du -c /opt/iobroker/iobroker-data/history | tail -1 | awk '{printf $1MB}''
    2020-08-17 21:23:30.947 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22, id: Ordner, description: ): response stdout: 13924604
    2020-08-17 21:23:30.952 - info: linux-control.0 (10867) successful received data from NUC_VM (192.168.138.123:22)
    2020-08-17 21:23:30.952 - info: linux-control.0 (10867) getting data from Tinker (192.168.138.74:22)
    2020-08-17 21:23:30.972 - debug: linux-control.0 (10867) [getConnection] Host 'Tinker' (192.168.138.74:22): using sudo for authentification
    2020-08-17 21:23:31.183 - debug: linux-control.0 (10867) [distributionInfo] Tinker (192.168.138.74:22): send command: 'cat /etc/os-release'
    2020-08-17 21:23:31.458 - debug: linux-control.0 (10867) [distributionInfo] Tinker (192.168.138.74:22): response stdout: NAME="Ubuntu"
    VERSION="18.04.4 LTS (Bionic Beaver)"
    ID=ubuntu
    ID_LIKE=debian
    PRETTY_NAME="Ubuntu 18.04.4 LTS"
    VERSION_ID="18.04"
    HOME_URL="https://www.ubuntu.com/"
    SUPPORT_URL="https://help.ubuntu.com/"
    BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
    PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
    VERSION_CODENAME=bionic
    UBUNTU_CODENAME=bionic
    2020-08-17 21:23:31.462 - debug: linux-control.0 (10867) [distributionInfo] Tinker (192.168.138.74:22): csvToJson result: [{"prop":"NAME","val":"Ubuntu"},{"prop":"VERSION","val":"18.04.4 LTS (Bionic Beaver)"},{"prop":"ID","val":"ubuntu"},{"prop":"ID_LIKE","val":"debian"},{"prop":"PRETTY_NAME","val":"Ubuntu 18.04.4 LTS"},{"prop":"VERSION_ID","val":"18.04"},{"prop":"HOME_URL","val":"https://www.ubuntu.com/"},{"prop":"SUPPORT_URL","val":"https://help.ubuntu.com/"},{"prop":"BUG_REPORT_URL","val":"https://bugs.launchpad.net/ubuntu/"},{"prop":"PRIVACY_POLICY_URL","val":"https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"},{"prop":"VERSION_CODENAME","val":"bionic"},{"prop":"UBUNTU_CODENAME","val":"bionic"}]
    2020-08-17 21:23:31.527 - debug: linux-control.0 (10867) [cmdAptUpdate] Tinker (192.168.138.74:22): no datapoints selected -> removing existing datapoints
    2020-08-17 21:23:31.532 - debug: linux-control.0 (10867) [servicesInfo] Tinker (192.168.138.74:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
    2020-08-17 21:23:31.555 - debug: linux-control.0 (10867) [servicesInfo] Tinker (192.168.138.74:22): response stdout: alsa-restore.service,loaded,active,exited, Save/Restore Sound Card State
    alsa-state.service,loaded,inactive,dead, Manage Sound Card State (restore and store)
    armbian-firstrun-config.service,loaded,inactive,dead, Armbian first run optional user configuration
    armbian-hardware-monitor.service,loaded,active,exited, Armbian hardware monitoring
    armbian-hardware-optimize.service,loaded,active,exited, Armbian hardware optimization
    armbian-ramlog.service,loaded,active,exited, Armbian memory supported logging
    armbian-zram-config.service,loaded,active,exited, Armbian ZRAM config
    armian-ramlog.service,not-found,inactive,dead, armian-ramlog.service
    chrony.service,loaded,active,running, chrony, an NTP client/server
    cpufrequtils.service,loaded,active,exited, LSB: set CPUFreq kernel parameters
    fstrim.service,loaded,inactive,dead, Discard unused blocks
    haveged.service,loaded,active,running, Entropy daemon using the HAVEGE algorithm
    hostapd.service,loaded,active,exited, LSB: Advanced IEEE 802.11 management daemon
    loadcpufreq.service,loaded,active,exited, LSB: Load kernel modules needed to enable cpufreq scaling
    motd-news.service,loaded,inactive,dead, Message of the Day
    networkd-dispatcher.service,loaded,active,running, Dispatcher daemon for systemd-networkd
    NetworkManager-wait-online.service,loaded,active,exited, Network Manager Wait Online
    NetworkManager.service,loaded,active,running, Network Manager
    ondemand.service,masked,inactive,dead, ondemand.service
    openntpd.service,not-found,inactive,dead, openntpd.service
    polkit.service,loaded,active,running, Authorization Manager
    resolvconf-pull-resolved.service,loaded,inactive,dead, resolvconf-pull-resolved.service
    resolvconf.service,loaded,active,exited, Nameserver information manager
    serial-getty@ttyS2.service,loaded,active,running, Serial Getty on ttyS2
    setvtrgb.service,loaded,active,exited, Set console scheme
    sysfsutils.service,loaded,active,exited, LSB: Set sysfs variables from /etc/sysfs.conf
    sysstat.service,loaded,active,exited, Resets System Activity Data Collector
    systemd-initctl.service,loaded,inactive,dead, /dev/initctl Compatibility Daemon
    systemd-resolved.service,loaded,active,running, Network Name Resolution
    systemd-sysusers.service,not-found,inactive,dead, systemd-sysusers.service
    tinker-bluetooth.service,loaded,active,running, Realtek H5 bluetooth support
    unattended-upgrades.service,loaded,active,running, Unattended Upgrades Shutdown
    user@1002.service,loaded,active,running, User Manager for UID 1002
    2020-08-17 21:23:31.564 - debug: linux-control.0 (10867) [servicesInfo] Tinker (192.168.138.74:22): csvToJson result: [{"id":"alsa-restore.service","load":"loaded","active":"active","running":"exited","description":"Save/Restore Sound Card State"},{"id":"alsa-state.service","load":"loaded","active":"inactive","running":"dead","description":"Manage Sound Card State (restore and store)"},{"id":"apparmor.service","load":"not-found","active":"inactive","running":"dead","description":"apparmor.service"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"armbian-firstrun-config.service","load":"loaded","active":"inactive","running":"dead","description":"Armbian first run optional user configuration"},{"id":"armbian-hardware-monitor.service","load":"loaded","active":"active","running":"exited","description":"Armbian hardware monitoring"},{"id":"armbian-hardware-optimize.service","load":"loaded","active":"active","running":"exited","description":"Armbian hardware optimization"},{"id":"armbian-ramlog.service","load":"loaded","active":"active","running":"exited","description":"Armbian memory supported logging"},{"id":"armbian-zram-config.service","load":"loaded","active":"active","running":"exited","description":"Armbian ZRAM config"},{"id":"armian-ramlog.service","load":"not-found","active":"inactive","running":"dead","description":"armian-ramlog.service"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"bluetooth.service","load":"loaded","active":"active","running":"running","description":"Bluetooth service"},{"id":"chrony.service","load":"loaded","active":"active","running":"running","description":"chrony","field6":"an NTP client/server"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cpufrequtils.service","load":"loaded","active":"active","running":"exited","description":"LSB: set CPUFreq kernel parameters"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"fake-hwclock.service","load":"loaded","active":"active","running":"exited","description":"Restore / save the current clock"},{"id":"fstrim.service","load":"loaded","active":"inactive","running":"dead","description":"Discard unused blocks"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"haveged.service","load":"loaded","active":"active","running":"running","description":"Entropy daemon using the HAVEGE algorithm"},{"id":"hostapd.service","load":"loaded","active":"active","running":"exited","description":"LSB: Advanced IEEE 802.11 management daemon"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"loadcpufreq.service","load":"loaded","active":"active","running":"exited","description":"LSB: Load kernel modules needed to enable cpufreq scaling"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"motd-news.service","load":"loaded","active":"inactive","running":"dead","description":"Message of the Day"},{"id":"mountkernfs.service","load":"masked","active":"inactive","running":"dead","description":"mountkernfs.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networkd-dispatcher.service","load":"loaded","active":"active","running":"running","description":"Dispatcher daemon for systemd-networkd"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager-wait-online.service","load":"loaded","active":"active","running":"exited","description":"Network Manager Wait Online"},{"id":"NetworkManager.service","load":"loaded","active":"active","running":"running","description":"Network Manager"},{"id":"ondemand.service","load":"masked","active":"inactive","running":"dead","description":"ondemand.service"},{"id":"openntpd.service","load":"not-found","active":"inactive","running":"dead","description":"openntpd.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"polkit.service","load":"loaded","active":"active","running":"running","description":"Authorization Manager"},{"id":"rc-local.service","load":"loaded","active":"active","running":"exited","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"resolvconf-pull-resolved.service","load":"loaded","active":"inactive","running":"dead","description":"resolvconf-pull-resolved.service"},{"id":"resolvconf.service","load":"loaded","active":"active","running":"exited","description":"Nameserver information manager"},{"id":"rng-tools.service","load":"loaded","active":"active","running":"running","description":"rng-tools.service"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"serial-getty@ttyS2.service","load":"loaded","active":"active","running":"running","description":"Serial Getty on ttyS2"},{"id":"setvtrgb.service","load":"loaded","active":"active","running":"exited","description":"Set console scheme"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"sysfsutils.service","load":"loaded","active":"active","running":"exited","description":"LSB: Set sysfs variables from /etc/sysfs.conf"},{"id":"sysstat.service","load":"loaded","active":"active","running":"exited","description":"Resets System Activity Data Collector"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"/dev/initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-resolved.service","load":"loaded","active":"active","running":"running","description":"Network Name Resolution"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-sysusers.service"},{"id":"systemd-timesyncd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"tinker-bluetooth.service","load":"loaded","active":"active","running":"running","description":"Realtek H5 bluetooth support"},{"id":"unattended-upgrades.service","load":"loaded","active":"active","running":"running","description":"Unattended Upgrades Shutdown"},{"id":"user@1002.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1002"},{"id":"wpa_supplicant.service","load":"loaded","active":"active","running":"running","description":"WPA supplicant"}]
    2020-08-17 21:23:31.975 - debug: linux-control.0 (10867) [needrestart] Tinker (192.168.138.74:22): no datapoints selected -> removing existing datapoints
    2020-08-17 21:23:31.993 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): send command: 'sudo -S du -sk /opt/iobroker/iobroker-data | awk '{ print $1 /1024 }''
    2020-08-17 21:23:32.097 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): response stdout:
    Sorry, user pi is not allowed to execute '/usr/bin/du -sk /opt/iobroker/iobroker-data' as root on localhost.
    2020-08-17 21:23:32.098 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.size: NaN MB
    2020-08-17 21:23:32.148 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): send command: 'sudo -S find /opt/iobroker/iobroker-data -name "*" | wc -l'
    2020-08-17 21:23:32.253 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): response stdout:
    Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name *' as root on localhost.
    2020-08-17 21:23:32.255 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.files: NaN Dateien
    2020-08-17 21:23:32.259 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): send command: 'tmp=$(sudo -S find /opt/iobroker/iobroker-data -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
    2020-08-17 21:23:32.328 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): response stdout:
    Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name * -type f -exec stat -c %Y %n -- {} ;' as root on localhost.
    date: option requires an argument -- 'r'
    Try 'date --help' for more information.
    2020-08-17 21:23:32.330 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.lastChange: NaN ->
    2020-08-17 21:23:32.378 - debug: linux-control.0 (10867) [userCommand] Tinker (192.168.138.74:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
    2020-08-17 21:23:32.422 - debug: linux-control.0 (10867) [userCommand] Tinker (192.168.138.74:22, id: root, description: ): response stdout: 5
    2020-08-17 21:23:32.428 - debug: linux-control.0 (10867) [userCommand] Tinker (192.168.138.74:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1'
    2020-08-17 21:23:32.472 - debug: linux-control.0 (10867) [userCommand] Tinker (192.168.138.74:22, id: ip, description: ): response stdout: 192.168.138.74
    2020-08-17 21:23:32.484 - debug: linux-control.0 (10867) [userCommand] Tinker (192.168.138.74:22, id: cpu-temp, description: ): send command: 'cat /sys/devices/virtual/thermal/thermal_zone0/temp | awk '{print substr($1, length($0)-5,3)}''
    2020-08-17 21:23:32.526 - debug: linux-control.0 (10867) [userCommand] Tinker (192.168.138.74:22, id: cpu-temp, description: ): response stdout: 46
    2020-08-17 21:23:32.532 - info: linux-control.0 (10867) successful received data from Tinker (192.168.138.74:22)
    Bleibt beim Tinker wohl dabei
    Thomas BraunT ScroungerS 2 Antworten Letzte Antwort
      @Scrounger sagte in Test Adapter Linux Control v0.x.x:
      @Homoran
      Bitte die auch nochmal testen, hab da noch was eingebaut, was deinen fehler hoffentlich jetzt löst
      Bin nicht mehr an den PC gekommen.
      habe es vom tablet versucht
      2020-08-17 21:19:29.989 - info: linux-control.0 (10867) getting data from RasPi4 (192.168.138.139:22)
      2020-08-17 21:19:30.021 - debug: linux-control.0 (10867) [getConnection] Host 'RasPi4' (192.168.138.139:22): using sudo for authentification
      2020-08-17 21:19:30.207 - debug: linux-control.0 (10867) [distributionInfo] RasPi4 (192.168.138.139:22): send command: 'cat /etc/os-release'
      2020-08-17 21:19:30.564 - debug: linux-control.0 (10867) [distributionInfo] RasPi4 (192.168.138.139:22): response stdout: PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="10"
      VERSION="10 (buster)"
      VERSION_CODENAME=buster
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      2020-08-17 21:19:30.601 - debug: linux-control.0 (10867) [distributionInfo] RasPi4 (192.168.138.139:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Raspbian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Raspbian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"raspbian"},{"prop":"ID_LIKE","val":"debian"},{"prop":"HOME_URL","val":"http://www.raspbian.org/"},{"prop":"SUPPORT_URL","val":"http://www.raspbian.org/RaspbianForums"},{"prop":"BUG_REPORT_URL","val":"http://www.raspbian.org/RaspbianBugs"}]
      2020-08-17 21:19:30.616 - debug: linux-control.0 (10867) [cmdAptUpdate] RasPi4 (192.168.138.139:22): no datapoints selected -> removing existing datapoints
      2020-08-17 21:19:30.622 - debug: linux-control.0 (10867) [servicesInfo] RasPi4 (192.168.138.139:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
      2020-08-17 21:19:30.646 - debug: linux-control.0 (10867) [servicesInfo] RasPi4 (192.168.138.139:22): response stdout: alsa-restore.service,loaded,active,exited, Save/Restore Sound Card State
      alsa-state.service,loaded,active,running, Manage Sound Card State (restore and store)
      apparmor.service,not-found,inactive,dead, apparmor.service
      apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities
      apt-daily.service,loaded,inactive,dead, Daily apt download activities
      auditd.service,not-found,inactive,dead, auditd.service
      auth-rpcgss-module.service,loaded,inactive,dead, Kernel Module supporting RPCSEC_GSS
      avahi-daemon.service,loaded,active,running, Avahi mDNS/DNS-SD Stack
      bluetooth.service,loaded,active,running, Bluetooth service
      bthelper@hci0.service,loaded,inactive,dead, Raspberry Pi bluetooth helper
      connman.service,not-found,inactive,dead, connman.service
      console-screen.service,not-found,inactive,dead, console-screen.service
      console-setup.service,loaded,active,exited, Set console font and keymap
      cron.service,loaded,active,running, Regular background program processing daemon
      dbus.service,loaded,active,running, D-Bus System Message Bus
      dhcpcd.service,loaded,active,running, dhcpcd on all interfaces
      display-manager.service,not-found,inactive,dead, display-manager.service
      dphys-swapfile.service,loaded,active,exited, dphys-swapfile - set up, mount/unmount, and delete a swap file
      emergency.service,loaded,inactive,dead, Emergency Shell
      fake-hwclock.service,loaded,active,exited, Restore / save the current clock
      getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available
      getty@tty1.service,loaded,active,running, Getty on tty1
      gssproxy.service,not-found,inactive,dead, gssproxy.service
      hciuart.service,loaded,active,running, Configure Bluetooth Modems connected by UART
      ifupdown-pre.service,loaded,active,exited, Helper to synchronize boot up for ifupdown
      influxdb.service,not-found,inactive,dead, influxdb.service
      iobroker.service,loaded,active,running, ioBroker Server
      kbd.service,not-found,inactive,dead, kbd.service
      keyboard-setup.service,loaded,active,exited, Set the console keyboard layout
      kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel
      logrotate.service,loaded,inactive,dead, Rotate log files
      man-db.service,loaded,inactive,dead, Daily man-db regeneration
      mariadb-server.service,not-found,inactive,dead, mariadb-server.service
      mountkernfs.service,masked,inactive,dead, mountkernfs.service
      mysql-server.service,not-found,inactive,dead, mysql-server.service
      networking.service,loaded,active,exited, Raise network interfaces
      NetworkManager.service,not-found,inactive,dead, NetworkManager.service
      nfs-blkmap.service,not-found,inactive,dead, nfs-blkmap.service
      nfs-config.service,loaded,inactive,dead, Preprocess NFS configuration
      nfs-server.service,not-found,inactive,dead, nfs-server.service
      nfs-utils.service,loaded,inactive,dead, NFS server and client services
      plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service
      plymouth-start.service,not-found,inactive,dead, plymouth-start.service
      raspberrypi-net-mods.service,loaded,inactive,dead, Copy user wpa_supplicant.conf
      raspi-config.service,loaded,active,exited, LSB: Switch to ondemand cpu governor (unless shift key is pressed)
      rc-local.service,loaded,active,exited, /etc/rc.local Compatibility
      redis.service,not-found,inactive,dead, redis.service
      regenerate_ssh_host_keys.service,loaded,inactive,dead, Regenerate SSH host keys
      rescue.service,loaded,inactive,dead, Rescue Shell
      rng-tools.service,loaded,active,running, rng-tools.service
      rpc-gssd.service,loaded,inactive,dead, RPC security service for NFS client and server
      rpc-svcgssd.service,loaded,inactive,dead, RPC security service for NFS server
      rpi-eeprom-update.service,loaded,active,exited, Check for Raspberry Pi EEPROM updates
      rsync.service,loaded,inactive,dead, fast remote file copy program daemon
      rsyslog.service,loaded,active,running, System Logging Service
      ssh.service,loaded,active,running, OpenBSD Secure Shell server
      sshswitch.service,loaded,inactive,dead, Turn on SSH if /boot/ssh is present
      systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console
      systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall
      systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats
      systemd-fsck-root.service,loaded,active,exited, File System Check on Root Device
      systemd-fsck@dev-disk-by\x2dpartuuid-50fbae26\x2d01.service,loaded,active,exited, File System Check on /dev/disk/by-partuuid/50fbae26-01
      systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status
      systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database
      systemd-initctl.service,loaded,inactive,dead, initctl Compatibility Daemon
      systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage
      systemd-journald.service,loaded,active,running, Journal Service
      systemd-logind.service,loaded,active,running, Login Service
      systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk
      systemd-modules-load.service,loaded,active,exited, Load Kernel Modules
      systemd-networkd.service,loaded,inactive,dead, Network Service
      systemd-quotacheck.service,loaded,inactive,dead, File System Quota Check
      systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed
      systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems
      systemd-rfkill.service,loaded,inactive,dead, Load/Save RF Kill Switch Status
      systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables
      systemd-sysusers.service,loaded,active,exited, Create System Users
      systemd-timesyncd.service,loaded,active,running, Network Time Synchronization
      systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories
      systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev
      systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories
      systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices
      systemd-udevd.service,loaded,active,running, udev Kernel Device Manager
      systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service
      systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes
      systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown
      systemd-user-sessions.service,loaded,active,exited, Permit User Sessions
      systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service
      triggerhappy.service,loaded,active,running, triggerhappy global hotkey daemon
      user-runtime-dir@1000.service,loaded,active,exited, User Runtime Directory /run/user/1000
      user@1000.service,loaded,active,running, User Manager for UID 1000
      wpa_supplicant.service,loaded,active,running, WPA supplicant
      2020-08-17 21:19:30.651 - debug: linux-control.0 (10867) [servicesInfo] RasPi4 (192.168.138.139:22): csvToJson result: [{"id":"alsa-restore.service","load":"loaded","active":"active","running":"exited","description":"Save/Restore Sound Card State"},{"id":"alsa-state.service","load":"loaded","active":"active","running":"running","description":"Manage Sound Card State (restore and store)"},{"id":"apparmor.service","load":"not-found","active":"inactive","running":"dead","description":"apparmor.service"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"avahi-daemon.service","load":"loaded","active":"active","running":"running","description":"Avahi mDNS/DNS-SD Stack"},{"id":"bluetooth.service","load":"loaded","active":"active","running":"running","description":"Bluetooth service"},{"id":"bthelper@hci0.service","load":"loaded","active":"inactive","running":"dead","description":"Raspberry Pi bluetooth helper"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"dhcpcd.service","load":"loaded","active":"active","running":"running","description":"dhcpcd on all interfaces"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"dphys-swapfile.service","load":"loaded","active":"active","running":"exited","description":"dphys-swapfile - set up","field6":"mount/unmount","field7":"and delete a swap file"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"fake-hwclock.service","load":"loaded","active":"active","running":"exited","description":"Restore / save the current clock"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"hciuart.service","load":"loaded","active":"active","running":"running","description":"Configure Bluetooth Modems connected by UART"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mountkernfs.service","load":"masked","active":"inactive","running":"dead","description":"mountkernfs.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"raspberrypi-net-mods.service","load":"loaded","active":"inactive","running":"dead","description":"Copy user wpa_supplicant.conf"},{"id":"raspi-config.service","load":"loaded","active":"active","running":"exited","description":"LSB: Switch to ondemand cpu governor (unless shift key is pressed)"},{"id":"rc-local.service","load":"loaded","active":"active","running":"exited","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"regenerate_ssh_host_keys.service","load":"loaded","active":"inactive","running":"dead","description":"Regenerate SSH host keys"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rng-tools.service","load":"loaded","active":"active","running":"running","description":"rng-tools.service"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpi-eeprom-update.service","load":"loaded","active":"active","running":"exited","description":"Check for Raspberry Pi EEPROM updates"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"sshswitch.service","load":"loaded","active":"inactive","running":"dead","description":"Turn on SSH if /boot/ssh is present"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"active","running":"exited","description":"File System Check on Root Device"},{"id":"systemd-fsck@dev-disk-by\\x2dpartuuid-50fbae26\\x2d01.service","load":"loaded","active":"active","running":"exited","description":"File System Check on /dev/disk/by-partuuid/50fbae26-01"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-quotacheck.service","load":"loaded","active":"inactive","running":"dead","description":"File System Quota Check"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"triggerhappy.service","load":"loaded","active":"active","running":"running","description":"triggerhappy global hotkey daemon"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"},{"id":"wpa_supplicant.service","load":"loaded","active":"active","running":"running","description":"WPA supplicant"}]
      2020-08-17 21:19:31.867 - debug: linux-control.0 (10867) system.adapter.admin.0: logging true
      2020-08-17 21:19:31.991 - debug: linux-control.0 (10867) [needrestart] RasPi4 (192.168.138.139:22): no datapoints selected -> removing existing datapoints
      2020-08-17 21:19:32.011 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'sudo -S du -sk /opt/iobroker/iobroker-data/history | awk '{ print $1 /1024 }''
      2020-08-17 21:19:32.211 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
      197.395
      2020-08-17 21:19:32.213 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.size: 197.4 MB
      2020-08-17 21:19:32.218 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'sudo -S find /opt/iobroker/iobroker-data/history -name "*" | wc -l'
      2020-08-17 21:19:32.398 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
      22422
      2020-08-17 21:19:32.399 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.files: 22422 Dateien
      2020-08-17 21:19:32.458 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'tmp=$(sudo -S find /opt/iobroker/iobroker-data/history -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
      2020-08-17 21:20:00.035 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 18243
      2020-08-17 21:20:07.066 - info: dwd.0 (18243) starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.21.0, js-controller: 3.1.4
      2020-08-17 21:20:08.634 - info: dwd.0 (18243) Terminated (NO_ERROR): Without reason
      2020-08-17 21:20:09.148 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
      2020-08-17 21:20:40.652 - info: hm-rpc.1 (21580) xmlrpc <- listDevices ["hm-rpc.1"]
      2020-08-17 21:20:40.820 - info: hm-rpc.1 (21580) xmlrpc -> 0 devices
      2020-08-17 21:20:41.396 - info: hm-rpc.1 (21580) xmlrpc <- newDevices 167
      2020-08-17 21:20:41.593 - info: hm-rpc.1 (21580) new HmIP devices/channels after filter: 0
      2020-08-17 21:21:10.975 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
      1597691863
      2020-08-17 21:21:10.979 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.lastChange: 1597691863000 -> 17.08.2020 21:17
      2020-08-17 21:21:11.029 - debug: linux-control.0 (10867) [userCommand] RasPi4 (192.168.138.139:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
      2020-08-17 21:21:11.056 - debug: linux-control.0 (10867) [userCommand] RasPi4 (192.168.138.139:22, id: root, description: ): response stdout: 19
      2020-08-17 21:21:11.061 - debug: linux-control.0 (10867) [userCommand] RasPi4 (192.168.138.139:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1'
      2020-08-17 21:21:11.080 - debug: linux-control.0 (10867) [userCommand] RasPi4 (192.168.138.139:22, id: ip, description: ): response stdout: 192.168.138.139
      2020-08-17 21:21:11.089 - debug: linux-control.0 (10867) [userCommand] RasPi4 (192.168.138.139:22, id: cpu-temp, description: ): send command: 'vcgencmd measure_temp | awk '{print substr($1, length($0)-5,4)}''
      2020-08-17 21:21:11.106 - debug: linux-control.0 (10867) [userCommand] RasPi4 (192.168.138.139:22, id: cpu-temp, description: ): response stdout: 55.0
      2020-08-17 21:21:11.112 - info: linux-control.0 (10867) successful received data from RasPi4 (192.168.138.139:22)
      2020-08-17 21:21:11.113 - info: linux-control.0 (10867) getting data from NUC_VM (192.168.138.123:22)
      2020-08-17 21:21:11.145 - debug: linux-control.0 (10867) [getConnection] Host 'NUC_VM' (192.168.138.123:22): using sudo for authentification
      2020-08-17 21:21:11.204 - debug: linux-control.0 (10867) [distributionInfo] NUC_VM (192.168.138.123:22): send command: 'cat /etc/os-release'
      2020-08-17 21:21:11.265 - debug: linux-control.0 (10867) [distributionInfo] NUC_VM (192.168.138.123:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
      NAME="Debian GNU/Linux"
      VERSION_ID="10"
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      2020-08-17 21:21:11.267 - debug: linux-control.0 (10867) [distributionInfo] NUC_VM (192.168.138.123:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
      2020-08-17 21:21:11.334 - debug: linux-control.0 (10867) [cmdAptUpdate] NUC_VM (192.168.138.123:22): no datapoints selected -> removing existing datapoints
      2020-08-17 21:21:11.338 - debug: linux-control.0 (10867) [servicesInfo] NUC_VM (192.168.138.123:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
      2020-08-17 21:21:11.351 - debug: linux-control.0 (10867) [servicesInfo] NUC_VM (192.168.138.123:22): response stdout: apache2.service,loaded,active,running, The Apache HTTP Server
      apparmor.service,loaded,active,exited, Load AppArmor profiles
      clamav-daemon.service,not-found,inactive,dead, clamav-daemon.service
      cups-browsed.service,loaded,failed,failed, Make remote CUPS printers available locally
      cups.service,loaded,active,running, CUPS Scheduler
      exim4.service,loaded,active,running, LSB: exim Mail Transport Agent
      greylist.service,not-found,inactive,dead, greylist.service
      ifup@ens18.service,loaded,active,exited, ifup for ens18
      irqbalance.service,loaded,active,running, irqbalance daemon
      mysql.service,not-found,inactive,dead, mysql.service
      ntp.service,loaded,active,running, Network Time Service
      postgresql.service,not-found,inactive,dead, postgresql.service
      rc-local.service,loaded,inactive,dead, /etc/rc.local Compatibility
      rpcbind.service,loaded,active,running, RPC bind portmap service
      spamassassin.service,not-found,inactive,dead, spamassassin.service
      systemd-fsck-root.service,loaded,inactive,dead, File System Check on Root Device
      systemd-timesyncd.service,loaded,inactive,dead, Network Time Synchronization
      2020-08-17 21:21:11.358 - debug: linux-control.0 (10867) [servicesInfo] NUC_VM (192.168.138.123:22): csvToJson result: [{"id":"apache2.service","load":"loaded","active":"active","running":"running","description":"The Apache HTTP Server"},{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"avahi-daemon.service","load":"loaded","active":"active","running":"running","description":"Avahi mDNS/DNS-SD Stack"},{"id":"clamav-daemon.service","load":"not-found","active":"inactive","running":"dead","description":"clamav-daemon.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"cups-browsed.service","load":"loaded","active":"failed","running":"failed","description":"Make remote CUPS printers available locally"},{"id":"cups.service","load":"loaded","active":"active","running":"running","description":"CUPS Scheduler"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"exim4.service","load":"loaded","active":"active","running":"running","description":"LSB: exim Mail Transport Agent"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"greylist.service","load":"not-found","active":"inactive","running":"dead","description":"greylist.service"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"irqbalance.service","load":"loaded","active":"active","running":"running","description":"irqbalance daemon"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"mysql.service","load":"not-found","active":"inactive","running":"dead","description":"mysql.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"ntp.service","load":"loaded","active":"active","running":"running","description":"Network Time Service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"postgresql.service","load":"not-found","active":"inactive","running":"dead","description":"postgresql.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpcbind.service","load":"loaded","active":"active","running":"running","description":"RPC bind portmap service"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"spamassassin.service","load":"not-found","active":"inactive","running":"dead","description":"spamassassin.service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}]
      2020-08-17 21:21:11.811 - debug: linux-control.0 (10867) [needrestart] NUC_VM (192.168.138.123:22): no datapoints selected -> removing existing datapoints
      2020-08-17 21:21:11.829 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'sudo -S du -sk /opt/iobroker/iobroker-data/history | awk '{ print $1 /1024 }''
      2020-08-17 21:21:12.177 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): response stdout:
      13598.2
      2020-08-17 21:21:12.181 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.size: 13598.2 MB
      2020-08-17 21:21:12.229 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'sudo -S find /opt/iobroker/iobroker-data/history -name "*" | wc -l'
      2020-08-17 21:21:12.452 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): response stdout:
      113112
      2020-08-17 21:21:12.456 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.files: 113112 Dateien
      2020-08-17 21:21:12.509 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'tmp=$(sudo -S find /opt/iobroker/iobroker-data/history -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
      2020-08-17 21:21:29.454 - info: info.0 (779) Popup news was read...
      2020-08-17 21:23:30.505 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): response stdout:
      1597692206
      2020-08-17 21:23:30.509 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.lastChange: 1597692206000 -> 17.08.2020 21:23
      2020-08-17 21:23:30.559 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
      2020-08-17 21:23:30.573 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22, id: root, description: ): response stdout: 56
      2020-08-17 21:23:30.632 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1'
      2020-08-17 21:23:30.641 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22, id: ip, description: ): response stdout: 192.168.138.123
      2020-08-17 21:23:30.648 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22): datapoint-id: 'cpu-temp', description: '' -> is not enabled!
      2020-08-17 21:23:30.649 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22, id: Ordner, description: ): send command: 'du -c /opt/iobroker/iobroker-data/history | tail -1 | awk '{printf $1MB}''
      2020-08-17 21:23:30.947 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22, id: Ordner, description: ): response stdout: 13924604
      2020-08-17 21:23:30.952 - info: linux-control.0 (10867) successful received data from NUC_VM (192.168.138.123:22)
      2020-08-17 21:23:30.952 - info: linux-control.0 (10867) getting data from Tinker (192.168.138.74:22)
      2020-08-17 21:23:30.972 - debug: linux-control.0 (10867) [getConnection] Host 'Tinker' (192.168.138.74:22): using sudo for authentification
      2020-08-17 21:23:31.183 - debug: linux-control.0 (10867) [distributionInfo] Tinker (192.168.138.74:22): send command: 'cat /etc/os-release'
      2020-08-17 21:23:31.458 - debug: linux-control.0 (10867) [distributionInfo] Tinker (192.168.138.74:22): response stdout: NAME="Ubuntu"
      VERSION="18.04.4 LTS (Bionic Beaver)"
      ID=ubuntu
      ID_LIKE=debian
      PRETTY_NAME="Ubuntu 18.04.4 LTS"
      VERSION_ID="18.04"
      HOME_URL="https://www.ubuntu.com/"
      SUPPORT_URL="https://help.ubuntu.com/"
      BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
      PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
      VERSION_CODENAME=bionic
      UBUNTU_CODENAME=bionic
      2020-08-17 21:23:31.462 - debug: linux-control.0 (10867) [distributionInfo] Tinker (192.168.138.74:22): csvToJson result: [{"prop":"NAME","val":"Ubuntu"},{"prop":"VERSION","val":"18.04.4 LTS (Bionic Beaver)"},{"prop":"ID","val":"ubuntu"},{"prop":"ID_LIKE","val":"debian"},{"prop":"PRETTY_NAME","val":"Ubuntu 18.04.4 LTS"},{"prop":"VERSION_ID","val":"18.04"},{"prop":"HOME_URL","val":"https://www.ubuntu.com/"},{"prop":"SUPPORT_URL","val":"https://help.ubuntu.com/"},{"prop":"BUG_REPORT_URL","val":"https://bugs.launchpad.net/ubuntu/"},{"prop":"PRIVACY_POLICY_URL","val":"https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"},{"prop":"VERSION_CODENAME","val":"bionic"},{"prop":"UBUNTU_CODENAME","val":"bionic"}]
      2020-08-17 21:23:31.527 - debug: linux-control.0 (10867) [cmdAptUpdate] Tinker (192.168.138.74:22): no datapoints selected -> removing existing datapoints
      2020-08-17 21:23:31.532 - debug: linux-control.0 (10867) [servicesInfo] Tinker (192.168.138.74:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
      2020-08-17 21:23:31.555 - debug: linux-control.0 (10867) [servicesInfo] Tinker (192.168.138.74:22): response stdout: alsa-restore.service,loaded,active,exited, Save/Restore Sound Card State
      alsa-state.service,loaded,inactive,dead, Manage Sound Card State (restore and store)
      armbian-firstrun-config.service,loaded,inactive,dead, Armbian first run optional user configuration
      armbian-hardware-monitor.service,loaded,active,exited, Armbian hardware monitoring
      armbian-hardware-optimize.service,loaded,active,exited, Armbian hardware optimization
      armbian-ramlog.service,loaded,active,exited, Armbian memory supported logging
      armbian-zram-config.service,loaded,active,exited, Armbian ZRAM config
      armian-ramlog.service,not-found,inactive,dead, armian-ramlog.service
      chrony.service,loaded,active,running, chrony, an NTP client/server
      cpufrequtils.service,loaded,active,exited, LSB: set CPUFreq kernel parameters
      fstrim.service,loaded,inactive,dead, Discard unused blocks
      haveged.service,loaded,active,running, Entropy daemon using the HAVEGE algorithm
      hostapd.service,loaded,active,exited, LSB: Advanced IEEE 802.11 management daemon
      loadcpufreq.service,loaded,active,exited, LSB: Load kernel modules needed to enable cpufreq scaling
      motd-news.service,loaded,inactive,dead, Message of the Day
      networkd-dispatcher.service,loaded,active,running, Dispatcher daemon for systemd-networkd
      NetworkManager-wait-online.service,loaded,active,exited, Network Manager Wait Online
      NetworkManager.service,loaded,active,running, Network Manager
      ondemand.service,masked,inactive,dead, ondemand.service
      openntpd.service,not-found,inactive,dead, openntpd.service
      polkit.service,loaded,active,running, Authorization Manager
      resolvconf-pull-resolved.service,loaded,inactive,dead, resolvconf-pull-resolved.service
      resolvconf.service,loaded,active,exited, Nameserver information manager
      serial-getty@ttyS2.service,loaded,active,running, Serial Getty on ttyS2
      setvtrgb.service,loaded,active,exited, Set console scheme
      sysfsutils.service,loaded,active,exited, LSB: Set sysfs variables from /etc/sysfs.conf
      sysstat.service,loaded,active,exited, Resets System Activity Data Collector
      systemd-initctl.service,loaded,inactive,dead, /dev/initctl Compatibility Daemon
      systemd-resolved.service,loaded,active,running, Network Name Resolution
      systemd-sysusers.service,not-found,inactive,dead, systemd-sysusers.service
      tinker-bluetooth.service,loaded,active,running, Realtek H5 bluetooth support
      unattended-upgrades.service,loaded,active,running, Unattended Upgrades Shutdown
      user@1002.service,loaded,active,running, User Manager for UID 1002
      2020-08-17 21:23:31.564 - debug: linux-control.0 (10867) [servicesInfo] Tinker (192.168.138.74:22): csvToJson result: [{"id":"alsa-restore.service","load":"loaded","active":"active","running":"exited","description":"Save/Restore Sound Card State"},{"id":"alsa-state.service","load":"loaded","active":"inactive","running":"dead","description":"Manage Sound Card State (restore and store)"},{"id":"apparmor.service","load":"not-found","active":"inactive","running":"dead","description":"apparmor.service"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"armbian-firstrun-config.service","load":"loaded","active":"inactive","running":"dead","description":"Armbian first run optional user configuration"},{"id":"armbian-hardware-monitor.service","load":"loaded","active":"active","running":"exited","description":"Armbian hardware monitoring"},{"id":"armbian-hardware-optimize.service","load":"loaded","active":"active","running":"exited","description":"Armbian hardware optimization"},{"id":"armbian-ramlog.service","load":"loaded","active":"active","running":"exited","description":"Armbian memory supported logging"},{"id":"armbian-zram-config.service","load":"loaded","active":"active","running":"exited","description":"Armbian ZRAM config"},{"id":"armian-ramlog.service","load":"not-found","active":"inactive","running":"dead","description":"armian-ramlog.service"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"bluetooth.service","load":"loaded","active":"active","running":"running","description":"Bluetooth service"},{"id":"chrony.service","load":"loaded","active":"active","running":"running","description":"chrony","field6":"an NTP client/server"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cpufrequtils.service","load":"loaded","active":"active","running":"exited","description":"LSB: set CPUFreq kernel parameters"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"fake-hwclock.service","load":"loaded","active":"active","running":"exited","description":"Restore / save the current clock"},{"id":"fstrim.service","load":"loaded","active":"inactive","running":"dead","description":"Discard unused blocks"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"haveged.service","load":"loaded","active":"active","running":"running","description":"Entropy daemon using the HAVEGE algorithm"},{"id":"hostapd.service","load":"loaded","active":"active","running":"exited","description":"LSB: Advanced IEEE 802.11 management daemon"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"loadcpufreq.service","load":"loaded","active":"active","running":"exited","description":"LSB: Load kernel modules needed to enable cpufreq scaling"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"motd-news.service","load":"loaded","active":"inactive","running":"dead","description":"Message of the Day"},{"id":"mountkernfs.service","load":"masked","active":"inactive","running":"dead","description":"mountkernfs.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networkd-dispatcher.service","load":"loaded","active":"active","running":"running","description":"Dispatcher daemon for systemd-networkd"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager-wait-online.service","load":"loaded","active":"active","running":"exited","description":"Network Manager Wait Online"},{"id":"NetworkManager.service","load":"loaded","active":"active","running":"running","description":"Network Manager"},{"id":"ondemand.service","load":"masked","active":"inactive","running":"dead","description":"ondemand.service"},{"id":"openntpd.service","load":"not-found","active":"inactive","running":"dead","description":"openntpd.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"polkit.service","load":"loaded","active":"active","running":"running","description":"Authorization Manager"},{"id":"rc-local.service","load":"loaded","active":"active","running":"exited","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"resolvconf-pull-resolved.service","load":"loaded","active":"inactive","running":"dead","description":"resolvconf-pull-resolved.service"},{"id":"resolvconf.service","load":"loaded","active":"active","running":"exited","description":"Nameserver information manager"},{"id":"rng-tools.service","load":"loaded","active":"active","running":"running","description":"rng-tools.service"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"serial-getty@ttyS2.service","load":"loaded","active":"active","running":"running","description":"Serial Getty on ttyS2"},{"id":"setvtrgb.service","load":"loaded","active":"active","running":"exited","description":"Set console scheme"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"sysfsutils.service","load":"loaded","active":"active","running":"exited","description":"LSB: Set sysfs variables from /etc/sysfs.conf"},{"id":"sysstat.service","load":"loaded","active":"active","running":"exited","description":"Resets System Activity Data Collector"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"/dev/initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-resolved.service","load":"loaded","active":"active","running":"running","description":"Network Name Resolution"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-sysusers.service"},{"id":"systemd-timesyncd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"tinker-bluetooth.service","load":"loaded","active":"active","running":"running","description":"Realtek H5 bluetooth support"},{"id":"unattended-upgrades.service","load":"loaded","active":"active","running":"running","description":"Unattended Upgrades Shutdown"},{"id":"user@1002.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1002"},{"id":"wpa_supplicant.service","load":"loaded","active":"active","running":"running","description":"WPA supplicant"}]
      2020-08-17 21:23:31.975 - debug: linux-control.0 (10867) [needrestart] Tinker (192.168.138.74:22): no datapoints selected -> removing existing datapoints
      2020-08-17 21:23:31.993 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): send command: 'sudo -S du -sk /opt/iobroker/iobroker-data | awk '{ print $1 /1024 }''
      2020-08-17 21:23:32.097 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): response stdout:
      Sorry, user pi is not allowed to execute '/usr/bin/du -sk /opt/iobroker/iobroker-data' as root on localhost.
      2020-08-17 21:23:32.098 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.size: NaN MB
      2020-08-17 21:23:32.148 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): send command: 'sudo -S find /opt/iobroker/iobroker-data -name "*" | wc -l'
      2020-08-17 21:23:32.253 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): response stdout:
      Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name *' as root on localhost.
      2020-08-17 21:23:32.255 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.files: NaN Dateien
      2020-08-17 21:23:32.259 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): send command: 'tmp=$(sudo -S find /opt/iobroker/iobroker-data -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
      2020-08-17 21:23:32.328 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): response stdout:
      Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name * -type f -exec stat -c %Y %n -- {} ;' as root on localhost.
      date: option requires an argument -- 'r'
      Try 'date --help' for more information.
      2020-08-17 21:23:32.330 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.lastChange: NaN ->
      2020-08-17 21:23:32.378 - debug: linux-control.0 (10867) [userCommand] Tinker (192.168.138.74:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
      2020-08-17 21:23:32.422 - debug: linux-control.0 (10867) [userCommand] Tinker (192.168.138.74:22, id: root, description: ): response stdout: 5
      2020-08-17 21:23:32.428 - debug: linux-control.0 (10867) [userCommand] Tinker (192.168.138.74:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1'
      2020-08-17 21:23:32.472 - debug: linux-control.0 (10867) [userCommand] Tinker (192.168.138.74:22, id: ip, description: ): response stdout: 192.168.138.74
      2020-08-17 21:23:32.484 - debug: linux-control.0 (10867) [userCommand] Tinker (192.168.138.74:22, id: cpu-temp, description: ): send command: 'cat /sys/devices/virtual/thermal/thermal_zone0/temp | awk '{print substr($1, length($0)-5,3)}''
      2020-08-17 21:23:32.526 - debug: linux-control.0 (10867) [userCommand] Tinker (192.168.138.74:22, id: cpu-temp, description: ): response stdout: 46
      2020-08-17 21:23:32.532 - info: linux-control.0 (10867) successful received data from Tinker (192.168.138.74:22)
      Bleibt beim Tinker wohl dabei
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      @Homoran Ist bei find das setui Bit gesetzt?
        @Thomas-Braun sagte in Test Adapter Linux Control v0.x.x:
        Wie meinen?
        Bin jetzt im Bett, würde ich morgen prüfen, wenn du mir sagst wie.
          @liv-in-sky Vielleicht geht auch was mit dem sticky bit.
          [Edit:] Ich meinte natürlich setuid, nicht sticky bit.
          liv-in-skyL
          liv-in-skyL
          hatte mich schon gewundert, wie das zusammenhängen sollte - habe keinen tinker und kann nicht mittesten - da kann nur @Homoran was machen - ist aber gut, wenn ein linux profi dabei ist
          • liv-in-skyL liv-in-sky
            @liv-in-sky ich kann morgen auch meinen pivccu-Tinker und den Reserve-Tinker noch einbinden ;-)
            Wenn ich die Zugangsdaten finde 😂
              Thomas BraunT
              Thomas BraunT
              @Homoran
              ls -la /usr/bin/find
              Je nachdem kann man dann halt ein setuid bit setzen (siehe Wikipedia)
              Ausführbare Programme, bei denen dieses Bit gesetzt ist, werden zusätzlich zu den Rechten desjenigen Benutzers, der die Datei ausführt, auch mit den Rechten des Benutzers ausgeführt, dem die Datei gehört (das heißt mit den Rechten des Besitzers der Datei, des "Owners"). Auf den meisten Systemen funktioniert dies nur für ausführbare Binärdateien, nicht jedoch für interpretierte Scripts.
              Dieses Vorgehen ermöglicht unprivilegierten Benutzern und Prozessen einen kontrollierten Zugriff auf privilegierte Ressourcen.
              Das könnte bei deinem Problem der Fall sein, wenn die Meldung nicht in die Irre führt.
                @Homoran
                @Thomas-Braun Danke,
                teste ich morgen.
                gibt der Befehl auch den Status aus?
                Habe da aber nix selbst gebastelt.
                Wäre da Armbian oder der Installer dran "schuld"?
                Warum hab ich mich da bloß ausnahmsweise für Ubuntu entschieden? 😢
                  teste ich morgen.
                  Thomas BraunT
                  Thomas BraunT
                  @Homoran Der Befehl ls listet die derzeitigen Rechte an der Datei auf.
                    @Scrounger sagte in Test Adapter Linux Control v0.x.x:
                    @Homoran
                    Bitte die auch nochmal testen, hab da noch was eingebaut, was deinen fehler hoffentlich jetzt löst
                    Bin nicht mehr an den PC gekommen.
                    habe es vom tablet versucht
                    2020-08-17 21:19:29.989 - info: linux-control.0 (10867) getting data from RasPi4 (192.168.138.139:22)
                    2020-08-17 21:19:30.021 - debug: linux-control.0 (10867) [getConnection] Host 'RasPi4' (192.168.138.139:22): using sudo for authentification
                    2020-08-17 21:19:30.207 - debug: linux-control.0 (10867) [distributionInfo] RasPi4 (192.168.138.139:22): send command: 'cat /etc/os-release'
                    2020-08-17 21:19:30.564 - debug: linux-control.0 (10867) [distributionInfo] RasPi4 (192.168.138.139:22): response stdout: PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                    NAME="Raspbian GNU/Linux"
                    VERSION_ID="10"
                    VERSION="10 (buster)"
                    VERSION_CODENAME=buster
                    ID=raspbian
                    ID_LIKE=debian
                    HOME_URL="http://www.raspbian.org/"
                    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                    2020-08-17 21:19:30.601 - debug: linux-control.0 (10867) [distributionInfo] RasPi4 (192.168.138.139:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Raspbian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Raspbian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"raspbian"},{"prop":"ID_LIKE","val":"debian"},{"prop":"HOME_URL","val":"http://www.raspbian.org/"},{"prop":"SUPPORT_URL","val":"http://www.raspbian.org/RaspbianForums"},{"prop":"BUG_REPORT_URL","val":"http://www.raspbian.org/RaspbianBugs"}]
                    2020-08-17 21:19:30.616 - debug: linux-control.0 (10867) [cmdAptUpdate] RasPi4 (192.168.138.139:22): no datapoints selected -> removing existing datapoints
                    2020-08-17 21:19:30.622 - debug: linux-control.0 (10867) [servicesInfo] RasPi4 (192.168.138.139:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
                    2020-08-17 21:19:30.646 - debug: linux-control.0 (10867) [servicesInfo] RasPi4 (192.168.138.139:22): response stdout: alsa-restore.service,loaded,active,exited, Save/Restore Sound Card State
                    alsa-state.service,loaded,active,running, Manage Sound Card State (restore and store)
                    apparmor.service,not-found,inactive,dead, apparmor.service
                    apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities
                    apt-daily.service,loaded,inactive,dead, Daily apt download activities
                    auditd.service,not-found,inactive,dead, auditd.service
                    auth-rpcgss-module.service,loaded,inactive,dead, Kernel Module supporting RPCSEC_GSS
                    avahi-daemon.service,loaded,active,running, Avahi mDNS/DNS-SD Stack
                    bluetooth.service,loaded,active,running, Bluetooth service
                    bthelper@hci0.service,loaded,inactive,dead, Raspberry Pi bluetooth helper
                    connman.service,not-found,inactive,dead, connman.service
                    console-screen.service,not-found,inactive,dead, console-screen.service
                    console-setup.service,loaded,active,exited, Set console font and keymap
                    cron.service,loaded,active,running, Regular background program processing daemon
                    dbus.service,loaded,active,running, D-Bus System Message Bus
                    dhcpcd.service,loaded,active,running, dhcpcd on all interfaces
                    display-manager.service,not-found,inactive,dead, display-manager.service
                    dphys-swapfile.service,loaded,active,exited, dphys-swapfile - set up, mount/unmount, and delete a swap file
                    emergency.service,loaded,inactive,dead, Emergency Shell
                    fake-hwclock.service,loaded,active,exited, Restore / save the current clock
                    getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available
                    getty@tty1.service,loaded,active,running, Getty on tty1
                    gssproxy.service,not-found,inactive,dead, gssproxy.service
                    hciuart.service,loaded,active,running, Configure Bluetooth Modems connected by UART
                    ifupdown-pre.service,loaded,active,exited, Helper to synchronize boot up for ifupdown
                    influxdb.service,not-found,inactive,dead, influxdb.service
                    iobroker.service,loaded,active,running, ioBroker Server
                    kbd.service,not-found,inactive,dead, kbd.service
                    keyboard-setup.service,loaded,active,exited, Set the console keyboard layout
                    kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel
                    logrotate.service,loaded,inactive,dead, Rotate log files
                    man-db.service,loaded,inactive,dead, Daily man-db regeneration
                    mariadb-server.service,not-found,inactive,dead, mariadb-server.service
                    mountkernfs.service,masked,inactive,dead, mountkernfs.service
                    mysql-server.service,not-found,inactive,dead, mysql-server.service
                    networking.service,loaded,active,exited, Raise network interfaces
                    NetworkManager.service,not-found,inactive,dead, NetworkManager.service
                    nfs-blkmap.service,not-found,inactive,dead, nfs-blkmap.service
                    nfs-config.service,loaded,inactive,dead, Preprocess NFS configuration
                    nfs-server.service,not-found,inactive,dead, nfs-server.service
                    nfs-utils.service,loaded,inactive,dead, NFS server and client services
                    plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service
                    plymouth-start.service,not-found,inactive,dead, plymouth-start.service
                    raspberrypi-net-mods.service,loaded,inactive,dead, Copy user wpa_supplicant.conf
                    raspi-config.service,loaded,active,exited, LSB: Switch to ondemand cpu governor (unless shift key is pressed)
                    rc-local.service,loaded,active,exited, /etc/rc.local Compatibility
                    redis.service,not-found,inactive,dead, redis.service
                    regenerate_ssh_host_keys.service,loaded,inactive,dead, Regenerate SSH host keys
                    rescue.service,loaded,inactive,dead, Rescue Shell
                    rng-tools.service,loaded,active,running, rng-tools.service
                    rpc-gssd.service,loaded,inactive,dead, RPC security service for NFS client and server
                    rpc-svcgssd.service,loaded,inactive,dead, RPC security service for NFS server
                    rpi-eeprom-update.service,loaded,active,exited, Check for Raspberry Pi EEPROM updates
                    rsync.service,loaded,inactive,dead, fast remote file copy program daemon
                    rsyslog.service,loaded,active,running, System Logging Service
                    ssh.service,loaded,active,running, OpenBSD Secure Shell server
                    sshswitch.service,loaded,inactive,dead, Turn on SSH if /boot/ssh is present
                    systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console
                    systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall
                    systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats
                    systemd-fsck-root.service,loaded,active,exited, File System Check on Root Device
                    systemd-fsck@dev-disk-by\x2dpartuuid-50fbae26\x2d01.service,loaded,active,exited, File System Check on /dev/disk/by-partuuid/50fbae26-01
                    systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status
                    systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database
                    systemd-initctl.service,loaded,inactive,dead, initctl Compatibility Daemon
                    systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage
                    systemd-journald.service,loaded,active,running, Journal Service
                    systemd-logind.service,loaded,active,running, Login Service
                    systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk
                    systemd-modules-load.service,loaded,active,exited, Load Kernel Modules
                    systemd-networkd.service,loaded,inactive,dead, Network Service
                    systemd-quotacheck.service,loaded,inactive,dead, File System Quota Check
                    systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed
                    systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems
                    systemd-rfkill.service,loaded,inactive,dead, Load/Save RF Kill Switch Status
                    systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables
                    systemd-sysusers.service,loaded,active,exited, Create System Users
                    systemd-timesyncd.service,loaded,active,running, Network Time Synchronization
                    systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories
                    systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev
                    systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories
                    systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices
                    systemd-udevd.service,loaded,active,running, udev Kernel Device Manager
                    systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service
                    systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes
                    systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown
                    systemd-user-sessions.service,loaded,active,exited, Permit User Sessions
                    systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service
                    triggerhappy.service,loaded,active,running, triggerhappy global hotkey daemon
                    user-runtime-dir@1000.service,loaded,active,exited, User Runtime Directory /run/user/1000
                    user@1000.service,loaded,active,running, User Manager for UID 1000
                    wpa_supplicant.service,loaded,active,running, WPA supplicant
                    2020-08-17 21:19:30.651 - debug: linux-control.0 (10867) [servicesInfo] RasPi4 (192.168.138.139:22): csvToJson result: [{"id":"alsa-restore.service","load":"loaded","active":"active","running":"exited","description":"Save/Restore Sound Card State"},{"id":"alsa-state.service","load":"loaded","active":"active","running":"running","description":"Manage Sound Card State (restore and store)"},{"id":"apparmor.service","load":"not-found","active":"inactive","running":"dead","description":"apparmor.service"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"avahi-daemon.service","load":"loaded","active":"active","running":"running","description":"Avahi mDNS/DNS-SD Stack"},{"id":"bluetooth.service","load":"loaded","active":"active","running":"running","description":"Bluetooth service"},{"id":"bthelper@hci0.service","load":"loaded","active":"inactive","running":"dead","description":"Raspberry Pi bluetooth helper"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"dhcpcd.service","load":"loaded","active":"active","running":"running","description":"dhcpcd on all interfaces"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"dphys-swapfile.service","load":"loaded","active":"active","running":"exited","description":"dphys-swapfile - set up","field6":"mount/unmount","field7":"and delete a swap file"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"fake-hwclock.service","load":"loaded","active":"active","running":"exited","description":"Restore / save the current clock"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"hciuart.service","load":"loaded","active":"active","running":"running","description":"Configure Bluetooth Modems connected by UART"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mountkernfs.service","load":"masked","active":"inactive","running":"dead","description":"mountkernfs.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"raspberrypi-net-mods.service","load":"loaded","active":"inactive","running":"dead","description":"Copy user wpa_supplicant.conf"},{"id":"raspi-config.service","load":"loaded","active":"active","running":"exited","description":"LSB: Switch to ondemand cpu governor (unless shift key is pressed)"},{"id":"rc-local.service","load":"loaded","active":"active","running":"exited","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"regenerate_ssh_host_keys.service","load":"loaded","active":"inactive","running":"dead","description":"Regenerate SSH host keys"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rng-tools.service","load":"loaded","active":"active","running":"running","description":"rng-tools.service"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpi-eeprom-update.service","load":"loaded","active":"active","running":"exited","description":"Check for Raspberry Pi EEPROM updates"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"sshswitch.service","load":"loaded","active":"inactive","running":"dead","description":"Turn on SSH if /boot/ssh is present"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"active","running":"exited","description":"File System Check on Root Device"},{"id":"systemd-fsck@dev-disk-by\\x2dpartuuid-50fbae26\\x2d01.service","load":"loaded","active":"active","running":"exited","description":"File System Check on /dev/disk/by-partuuid/50fbae26-01"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-quotacheck.service","load":"loaded","active":"inactive","running":"dead","description":"File System Quota Check"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"triggerhappy.service","load":"loaded","active":"active","running":"running","description":"triggerhappy global hotkey daemon"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"},{"id":"wpa_supplicant.service","load":"loaded","active":"active","running":"running","description":"WPA supplicant"}]
                    2020-08-17 21:19:31.867 - debug: linux-control.0 (10867) system.adapter.admin.0: logging true
                    2020-08-17 21:19:31.991 - debug: linux-control.0 (10867) [needrestart] RasPi4 (192.168.138.139:22): no datapoints selected -> removing existing datapoints
                    2020-08-17 21:19:32.011 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'sudo -S du -sk /opt/iobroker/iobroker-data/history | awk '{ print $1 /1024 }''
                    2020-08-17 21:19:32.211 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
                    197.395
                    2020-08-17 21:19:32.213 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.size: 197.4 MB
                    2020-08-17 21:19:32.218 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'sudo -S find /opt/iobroker/iobroker-data/history -name "*" | wc -l'
                    2020-08-17 21:19:32.398 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
                    22422
                    2020-08-17 21:19:32.399 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.files: 22422 Dateien
                    2020-08-17 21:19:32.458 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'tmp=$(sudo -S find /opt/iobroker/iobroker-data/history -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
                    2020-08-17 21:20:00.035 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 18243
                    2020-08-17 21:20:07.066 - info: dwd.0 (18243) starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.21.0, js-controller: 3.1.4
                    2020-08-17 21:20:08.634 - info: dwd.0 (18243) Terminated (NO_ERROR): Without reason
                    2020-08-17 21:20:09.148 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
                    2020-08-17 21:20:40.652 - info: hm-rpc.1 (21580) xmlrpc <- listDevices ["hm-rpc.1"]
                    2020-08-17 21:20:40.820 - info: hm-rpc.1 (21580) xmlrpc -> 0 devices
                    2020-08-17 21:20:41.396 - info: hm-rpc.1 (21580) xmlrpc <- newDevices 167
                    2020-08-17 21:20:41.593 - info: hm-rpc.1 (21580) new HmIP devices/channels after filter: 0
                    2020-08-17 21:21:10.975 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
                    1597691863
                    2020-08-17 21:21:10.979 - debug: linux-control.0 (10867) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.lastChange: 1597691863000 -> 17.08.2020 21:17
                    2020-08-17 21:21:11.029 - debug: linux-control.0 (10867) [userCommand] RasPi4 (192.168.138.139:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
                    2020-08-17 21:21:11.056 - debug: linux-control.0 (10867) [userCommand] RasPi4 (192.168.138.139:22, id: root, description: ): response stdout: 19
                    2020-08-17 21:21:11.061 - debug: linux-control.0 (10867) [userCommand] RasPi4 (192.168.138.139:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1'
                    2020-08-17 21:21:11.080 - debug: linux-control.0 (10867) [userCommand] RasPi4 (192.168.138.139:22, id: ip, description: ): response stdout: 192.168.138.139
                    2020-08-17 21:21:11.089 - debug: linux-control.0 (10867) [userCommand] RasPi4 (192.168.138.139:22, id: cpu-temp, description: ): send command: 'vcgencmd measure_temp | awk '{print substr($1, length($0)-5,4)}''
                    2020-08-17 21:21:11.106 - debug: linux-control.0 (10867) [userCommand] RasPi4 (192.168.138.139:22, id: cpu-temp, description: ): response stdout: 55.0
                    2020-08-17 21:21:11.112 - info: linux-control.0 (10867) successful received data from RasPi4 (192.168.138.139:22)
                    2020-08-17 21:21:11.113 - info: linux-control.0 (10867) getting data from NUC_VM (192.168.138.123:22)
                    2020-08-17 21:21:11.145 - debug: linux-control.0 (10867) [getConnection] Host 'NUC_VM' (192.168.138.123:22): using sudo for authentification
                    2020-08-17 21:21:11.204 - debug: linux-control.0 (10867) [distributionInfo] NUC_VM (192.168.138.123:22): send command: 'cat /etc/os-release'
                    2020-08-17 21:21:11.265 - debug: linux-control.0 (10867) [distributionInfo] NUC_VM (192.168.138.123:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
                    NAME="Debian GNU/Linux"
                    VERSION_ID="10"
                    ID=debian
                    HOME_URL="https://www.debian.org/"
                    SUPPORT_URL="https://www.debian.org/support"
                    BUG_REPORT_URL="https://bugs.debian.org/"
                    2020-08-17 21:21:11.267 - debug: linux-control.0 (10867) [distributionInfo] NUC_VM (192.168.138.123:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
                    2020-08-17 21:21:11.334 - debug: linux-control.0 (10867) [cmdAptUpdate] NUC_VM (192.168.138.123:22): no datapoints selected -> removing existing datapoints
                    2020-08-17 21:21:11.338 - debug: linux-control.0 (10867) [servicesInfo] NUC_VM (192.168.138.123:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
                    2020-08-17 21:21:11.351 - debug: linux-control.0 (10867) [servicesInfo] NUC_VM (192.168.138.123:22): response stdout: apache2.service,loaded,active,running, The Apache HTTP Server
                    apparmor.service,loaded,active,exited, Load AppArmor profiles
                    clamav-daemon.service,not-found,inactive,dead, clamav-daemon.service
                    cups-browsed.service,loaded,failed,failed, Make remote CUPS printers available locally
                    cups.service,loaded,active,running, CUPS Scheduler
                    exim4.service,loaded,active,running, LSB: exim Mail Transport Agent
                    greylist.service,not-found,inactive,dead, greylist.service
                    ifup@ens18.service,loaded,active,exited, ifup for ens18
                    irqbalance.service,loaded,active,running, irqbalance daemon
                    mysql.service,not-found,inactive,dead, mysql.service
                    ntp.service,loaded,active,running, Network Time Service
                    postgresql.service,not-found,inactive,dead, postgresql.service
                    rc-local.service,loaded,inactive,dead, /etc/rc.local Compatibility
                    rpcbind.service,loaded,active,running, RPC bind portmap service
                    spamassassin.service,not-found,inactive,dead, spamassassin.service
                    systemd-fsck-root.service,loaded,inactive,dead, File System Check on Root Device
                    systemd-timesyncd.service,loaded,inactive,dead, Network Time Synchronization
                    2020-08-17 21:21:11.358 - debug: linux-control.0 (10867) [servicesInfo] NUC_VM (192.168.138.123:22): csvToJson result: [{"id":"apache2.service","load":"loaded","active":"active","running":"running","description":"The Apache HTTP Server"},{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"avahi-daemon.service","load":"loaded","active":"active","running":"running","description":"Avahi mDNS/DNS-SD Stack"},{"id":"clamav-daemon.service","load":"not-found","active":"inactive","running":"dead","description":"clamav-daemon.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"cups-browsed.service","load":"loaded","active":"failed","running":"failed","description":"Make remote CUPS printers available locally"},{"id":"cups.service","load":"loaded","active":"active","running":"running","description":"CUPS Scheduler"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"exim4.service","load":"loaded","active":"active","running":"running","description":"LSB: exim Mail Transport Agent"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"greylist.service","load":"not-found","active":"inactive","running":"dead","description":"greylist.service"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"irqbalance.service","load":"loaded","active":"active","running":"running","description":"irqbalance daemon"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"mysql.service","load":"not-found","active":"inactive","running":"dead","description":"mysql.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"ntp.service","load":"loaded","active":"active","running":"running","description":"Network Time Service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"postgresql.service","load":"not-found","active":"inactive","running":"dead","description":"postgresql.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpcbind.service","load":"loaded","active":"active","running":"running","description":"RPC bind portmap service"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"spamassassin.service","load":"not-found","active":"inactive","running":"dead","description":"spamassassin.service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}]
                    2020-08-17 21:21:11.811 - debug: linux-control.0 (10867) [needrestart] NUC_VM (192.168.138.123:22): no datapoints selected -> removing existing datapoints
                    2020-08-17 21:21:11.829 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'sudo -S du -sk /opt/iobroker/iobroker-data/history | awk '{ print $1 /1024 }''
                    2020-08-17 21:21:12.177 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): response stdout:
                    13598.2
                    2020-08-17 21:21:12.181 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.size: 13598.2 MB
                    2020-08-17 21:21:12.229 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'sudo -S find /opt/iobroker/iobroker-data/history -name "*" | wc -l'
                    2020-08-17 21:21:12.452 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): response stdout:
                    113112
                    2020-08-17 21:21:12.456 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.files: 113112 Dateien
                    2020-08-17 21:21:12.509 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'tmp=$(sudo -S find /opt/iobroker/iobroker-data/history -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
                    2020-08-17 21:21:29.454 - info: info.0 (779) Popup news was read...
                    2020-08-17 21:23:30.505 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): response stdout:
                    1597692206
                    2020-08-17 21:23:30.509 - debug: linux-control.0 (10867) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.lastChange: 1597692206000 -> 17.08.2020 21:23
                    2020-08-17 21:23:30.559 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
                    2020-08-17 21:23:30.573 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22, id: root, description: ): response stdout: 56
                    2020-08-17 21:23:30.632 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1'
                    2020-08-17 21:23:30.641 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22, id: ip, description: ): response stdout: 192.168.138.123
                    2020-08-17 21:23:30.648 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22): datapoint-id: 'cpu-temp', description: '' -> is not enabled!
                    2020-08-17 21:23:30.649 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22, id: Ordner, description: ): send command: 'du -c /opt/iobroker/iobroker-data/history | tail -1 | awk '{printf $1MB}''
                    2020-08-17 21:23:30.947 - debug: linux-control.0 (10867) [userCommand] NUC_VM (192.168.138.123:22, id: Ordner, description: ): response stdout: 13924604
                    2020-08-17 21:23:30.952 - info: linux-control.0 (10867) successful received data from NUC_VM (192.168.138.123:22)
                    2020-08-17 21:23:30.952 - info: linux-control.0 (10867) getting data from Tinker (192.168.138.74:22)
                    2020-08-17 21:23:30.972 - debug: linux-control.0 (10867) [getConnection] Host 'Tinker' (192.168.138.74:22): using sudo for authentification
                    2020-08-17 21:23:31.183 - debug: linux-control.0 (10867) [distributionInfo] Tinker (192.168.138.74:22): send command: 'cat /etc/os-release'
                    2020-08-17 21:23:31.458 - debug: linux-control.0 (10867) [distributionInfo] Tinker (192.168.138.74:22): response stdout: NAME="Ubuntu"
                    VERSION="18.04.4 LTS (Bionic Beaver)"
                    ID=ubuntu
                    ID_LIKE=debian
                    PRETTY_NAME="Ubuntu 18.04.4 LTS"
                    VERSION_ID="18.04"
                    HOME_URL="https://www.ubuntu.com/"
                    SUPPORT_URL="https://help.ubuntu.com/"
                    BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
                    PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
                    VERSION_CODENAME=bionic
                    UBUNTU_CODENAME=bionic
                    2020-08-17 21:23:31.462 - debug: linux-control.0 (10867) [distributionInfo] Tinker (192.168.138.74:22): csvToJson result: [{"prop":"NAME","val":"Ubuntu"},{"prop":"VERSION","val":"18.04.4 LTS (Bionic Beaver)"},{"prop":"ID","val":"ubuntu"},{"prop":"ID_LIKE","val":"debian"},{"prop":"PRETTY_NAME","val":"Ubuntu 18.04.4 LTS"},{"prop":"VERSION_ID","val":"18.04"},{"prop":"HOME_URL","val":"https://www.ubuntu.com/"},{"prop":"SUPPORT_URL","val":"https://help.ubuntu.com/"},{"prop":"BUG_REPORT_URL","val":"https://bugs.launchpad.net/ubuntu/"},{"prop":"PRIVACY_POLICY_URL","val":"https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"},{"prop":"VERSION_CODENAME","val":"bionic"},{"prop":"UBUNTU_CODENAME","val":"bionic"}]
                    2020-08-17 21:23:31.527 - debug: linux-control.0 (10867) [cmdAptUpdate] Tinker (192.168.138.74:22): no datapoints selected -> removing existing datapoints
                    2020-08-17 21:23:31.532 - debug: linux-control.0 (10867) [servicesInfo] Tinker (192.168.138.74:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
                    2020-08-17 21:23:31.555 - debug: linux-control.0 (10867) [servicesInfo] Tinker (192.168.138.74:22): response stdout: alsa-restore.service,loaded,active,exited, Save/Restore Sound Card State
                    alsa-state.service,loaded,inactive,dead, Manage Sound Card State (restore and store)
                    armbian-firstrun-config.service,loaded,inactive,dead, Armbian first run optional user configuration
                    armbian-hardware-monitor.service,loaded,active,exited, Armbian hardware monitoring
                    armbian-hardware-optimize.service,loaded,active,exited, Armbian hardware optimization
                    armbian-ramlog.service,loaded,active,exited, Armbian memory supported logging
                    armbian-zram-config.service,loaded,active,exited, Armbian ZRAM config
                    armian-ramlog.service,not-found,inactive,dead, armian-ramlog.service
                    chrony.service,loaded,active,running, chrony, an NTP client/server
                    cpufrequtils.service,loaded,active,exited, LSB: set CPUFreq kernel parameters
                    fstrim.service,loaded,inactive,dead, Discard unused blocks
                    haveged.service,loaded,active,running, Entropy daemon using the HAVEGE algorithm
                    hostapd.service,loaded,active,exited, LSB: Advanced IEEE 802.11 management daemon
                    loadcpufreq.service,loaded,active,exited, LSB: Load kernel modules needed to enable cpufreq scaling
                    motd-news.service,loaded,inactive,dead, Message of the Day
                    networkd-dispatcher.service,loaded,active,running, Dispatcher daemon for systemd-networkd
                    NetworkManager-wait-online.service,loaded,active,exited, Network Manager Wait Online
                    NetworkManager.service,loaded,active,running, Network Manager
                    ondemand.service,masked,inactive,dead, ondemand.service
                    openntpd.service,not-found,inactive,dead, openntpd.service
                    polkit.service,loaded,active,running, Authorization Manager
                    resolvconf-pull-resolved.service,loaded,inactive,dead, resolvconf-pull-resolved.service
                    resolvconf.service,loaded,active,exited, Nameserver information manager
                    serial-getty@ttyS2.service,loaded,active,running, Serial Getty on ttyS2
                    setvtrgb.service,loaded,active,exited, Set console scheme
                    sysfsutils.service,loaded,active,exited, LSB: Set sysfs variables from /etc/sysfs.conf
                    sysstat.service,loaded,active,exited, Resets System Activity Data Collector
                    systemd-initctl.service,loaded,inactive,dead, /dev/initctl Compatibility Daemon
                    systemd-resolved.service,loaded,active,running, Network Name Resolution
                    systemd-sysusers.service,not-found,inactive,dead, systemd-sysusers.service
                    tinker-bluetooth.service,loaded,active,running, Realtek H5 bluetooth support
                    unattended-upgrades.service,loaded,active,running, Unattended Upgrades Shutdown
                    user@1002.service,loaded,active,running, User Manager for UID 1002
                    2020-08-17 21:23:31.564 - debug: linux-control.0 (10867) [servicesInfo] Tinker (192.168.138.74:22): csvToJson result: [{"id":"alsa-restore.service","load":"loaded","active":"active","running":"exited","description":"Save/Restore Sound Card State"},{"id":"alsa-state.service","load":"loaded","active":"inactive","running":"dead","description":"Manage Sound Card State (restore and store)"},{"id":"apparmor.service","load":"not-found","active":"inactive","running":"dead","description":"apparmor.service"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"armbian-firstrun-config.service","load":"loaded","active":"inactive","running":"dead","description":"Armbian first run optional user configuration"},{"id":"armbian-hardware-monitor.service","load":"loaded","active":"active","running":"exited","description":"Armbian hardware monitoring"},{"id":"armbian-hardware-optimize.service","load":"loaded","active":"active","running":"exited","description":"Armbian hardware optimization"},{"id":"armbian-ramlog.service","load":"loaded","active":"active","running":"exited","description":"Armbian memory supported logging"},{"id":"armbian-zram-config.service","load":"loaded","active":"active","running":"exited","description":"Armbian ZRAM config"},{"id":"armian-ramlog.service","load":"not-found","active":"inactive","running":"dead","description":"armian-ramlog.service"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"bluetooth.service","load":"loaded","active":"active","running":"running","description":"Bluetooth service"},{"id":"chrony.service","load":"loaded","active":"active","running":"running","description":"chrony","field6":"an NTP client/server"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cpufrequtils.service","load":"loaded","active":"active","running":"exited","description":"LSB: set CPUFreq kernel parameters"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"fake-hwclock.service","load":"loaded","active":"active","running":"exited","description":"Restore / save the current clock"},{"id":"fstrim.service","load":"loaded","active":"inactive","running":"dead","description":"Discard unused blocks"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"haveged.service","load":"loaded","active":"active","running":"running","description":"Entropy daemon using the HAVEGE algorithm"},{"id":"hostapd.service","load":"loaded","active":"active","running":"exited","description":"LSB: Advanced IEEE 802.11 management daemon"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"loadcpufreq.service","load":"loaded","active":"active","running":"exited","description":"LSB: Load kernel modules needed to enable cpufreq scaling"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"motd-news.service","load":"loaded","active":"inactive","running":"dead","description":"Message of the Day"},{"id":"mountkernfs.service","load":"masked","active":"inactive","running":"dead","description":"mountkernfs.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networkd-dispatcher.service","load":"loaded","active":"active","running":"running","description":"Dispatcher daemon for systemd-networkd"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager-wait-online.service","load":"loaded","active":"active","running":"exited","description":"Network Manager Wait Online"},{"id":"NetworkManager.service","load":"loaded","active":"active","running":"running","description":"Network Manager"},{"id":"ondemand.service","load":"masked","active":"inactive","running":"dead","description":"ondemand.service"},{"id":"openntpd.service","load":"not-found","active":"inactive","running":"dead","description":"openntpd.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"polkit.service","load":"loaded","active":"active","running":"running","description":"Authorization Manager"},{"id":"rc-local.service","load":"loaded","active":"active","running":"exited","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"resolvconf-pull-resolved.service","load":"loaded","active":"inactive","running":"dead","description":"resolvconf-pull-resolved.service"},{"id":"resolvconf.service","load":"loaded","active":"active","running":"exited","description":"Nameserver information manager"},{"id":"rng-tools.service","load":"loaded","active":"active","running":"running","description":"rng-tools.service"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"serial-getty@ttyS2.service","load":"loaded","active":"active","running":"running","description":"Serial Getty on ttyS2"},{"id":"setvtrgb.service","load":"loaded","active":"active","running":"exited","description":"Set console scheme"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"sysfsutils.service","load":"loaded","active":"active","running":"exited","description":"LSB: Set sysfs variables from /etc/sysfs.conf"},{"id":"sysstat.service","load":"loaded","active":"active","running":"exited","description":"Resets System Activity Data Collector"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"/dev/initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-resolved.service","load":"loaded","active":"active","running":"running","description":"Network Name Resolution"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-sysusers.service"},{"id":"systemd-timesyncd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"tinker-bluetooth.service","load":"loaded","active":"active","running":"running","description":"Realtek H5 bluetooth support"},{"id":"unattended-upgrades.service","load":"loaded","active":"active","running":"running","description":"Unattended Upgrades Shutdown"},{"id":"user@1002.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1002"},{"id":"wpa_supplicant.service","load":"loaded","active":"active","running":"running","description":"WPA supplicant"}]
                    2020-08-17 21:23:31.975 - debug: linux-control.0 (10867) [needrestart] Tinker (192.168.138.74:22): no datapoints selected -> removing existing datapoints
                    2020-08-17 21:23:31.993 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): send command: 'sudo -S du -sk /opt/iobroker/iobroker-data | awk '{ print $1 /1024 }''
                    2020-08-17 21:23:32.097 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): response stdout:
                    Sorry, user pi is not allowed to execute '/usr/bin/du -sk /opt/iobroker/iobroker-data' as root on localhost.
                    2020-08-17 21:23:32.098 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.size: NaN MB
                    2020-08-17 21:23:32.148 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): send command: 'sudo -S find /opt/iobroker/iobroker-data -name "*" | wc -l'
                    2020-08-17 21:23:32.253 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): response stdout:
                    Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name *' as root on localhost.
                    2020-08-17 21:23:32.255 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.files: NaN Dateien
                    2020-08-17 21:23:32.259 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): send command: 'tmp=$(sudo -S find /opt/iobroker/iobroker-data -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
                    2020-08-17 21:23:32.328 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): response stdout:
                    Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name * -type f -exec stat -c %Y %n -- {} ;' as root on localhost.
                    date: option requires an argument -- 'r'
                    Try 'date --help' for more information.
                    2020-08-17 21:23:32.330 - debug: linux-control.0 (10867) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.lastChange: NaN ->
                    2020-08-17 21:23:32.378 - debug: linux-control.0 (10867) [userCommand] Tinker (192.168.138.74:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
                    2020-08-17 21:23:32.422 - debug: linux-control.0 (10867) [userCommand] Tinker (192.168.138.74:22, id: root, description: ): response stdout: 5
                    2020-08-17 21:23:32.428 - debug: linux-control.0 (10867) [userCommand] Tinker (192.168.138.74:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1'
                    2020-08-17 21:23:32.472 - debug: linux-control.0 (10867) [userCommand] Tinker (192.168.138.74:22, id: ip, description: ): response stdout: 192.168.138.74
                    2020-08-17 21:23:32.484 - debug: linux-control.0 (10867) [userCommand] Tinker (192.168.138.74:22, id: cpu-temp, description: ): send command: 'cat /sys/devices/virtual/thermal/thermal_zone0/temp | awk '{print substr($1, length($0)-5,3)}''
                    2020-08-17 21:23:32.526 - debug: linux-control.0 (10867) [userCommand] Tinker (192.168.138.74:22, id: cpu-temp, description: ): response stdout: 46
                    2020-08-17 21:23:32.532 - info: linux-control.0 (10867) successful received data from Tinker (192.168.138.74:22)
                    Bleibt beim Tinker wohl dabei
                    ScroungerS
                    ScroungerS
                    Scrounger
                    schrieb am zuletzt editiert von Scrounger
                    @liv-in-sky sagte in Test Adapter Linux Control v0.x.x:
                    @Scrounger
                    frage - denkst du es wäre möglich, wenn ein befehl (button) ausgeführt wird, das man dann die datenpunkte des betreffenden servers aktualisieren (poll) könnte ?
                    momentan , wenn der server alle 5 minuten abgefragt wird, wird das ergebnis ( z.b service ist gestoppt) erst (wenn es dumm läuft) nach 5 minuten im dp gezeigt
                    Bei den update / upgrade commands ist das schon so umgestezt, das nach Ausführen des Befehls die DPs aktualisiert werden. Für die Services Commands könnte ich das auch einbauen.
                    Für eigene Commands geht das nicht.
                    Schreib bitte nen Issue dafür bei github, danke!
                    @Homoran sagte in Test Adapter Linux Control v0.x.x:
                    Laut log funktioniert es jetzt auch bei deinem RasPi4 & NUC_VM.
                    Tinker ist nen Berechtigungsthema.
                    HomoranH liv-in-skyL 2 Antworten Letzte Antwort
                    • ScroungerS Scrounger
                      @Scrounger
                      #66
                      @Scrounger sagte in Test Adapter Linux Control v0.x.x:
                      sehe ich auch so. Nur seltsam, dass es als eigener Befehl funktioniert.
                      Ich hoffe ich komme heute mal endlich dazu mich an den PC zu setzen.
                      Werde dann einen weiteren Tinker einbinden und mal den Befehl von @Thomas-Braun testen
                        @Scrounger
                        liv-in-skyL
                        liv-in-skyL
                        #67
                        done und vielen dank
                          @Homoran
                          ls -la /usr/bin/find
                          Je nachdem kann man dann halt ein setuid bit setzen (siehe Wikipedia)
                          Ausführbare Programme, bei denen dieses Bit gesetzt ist, werden zusätzlich zu den Rechten desjenigen Benutzers, der die Datei ausführt, auch mit den Rechten des Benutzers ausgeführt, dem die Datei gehört (das heißt mit den Rechten des Besitzers der Datei, des "Owners"). Auf den meisten Systemen funktioniert dies nur für ausführbare Binärdateien, nicht jedoch für interpretierte Scripts.
                          Dieses Vorgehen ermöglicht unprivilegierten Benutzern und Prozessen einen kontrollierten Zugriff auf privilegierte Ressourcen.
                          Das könnte bei deinem Problem der Fall sein, wenn die Meldung nicht in die Irre führt.
                          #68
                          @Thomas-Braun sagte in Test Adapter Linux Control v0.x.x:
                          pi@tinkerboard:~$ ls -la /usr/bin/find
                          -rwxr-xr-x 1 root root 158456 Nov  5  2017 /usr/bin/find
                          habe das ganze dann mit sudo su mal als root ausführen wollen, um zu sehen, ob ich damals vielleicht unter root installiert hatte 😳 dabei kam das hier:
                          pi@tinkerboard:~$ sudo su
                          [sudo] password for pi:
                          Sorry, user pi is not allowed to execute '/bin/su' as root on localhost.
                          vielleicht hilft das
                            Thomas BraunT
                            Thomas BraunT
                            Most Active Developer
                            #69
                            @Homoran Setz das setuid bit mal auf die Datei:
                            sudo chmod u+x /usr/bin/find
                            Die Rechte müssten danach so aussehen:
                            -rwSr-xr-x 1 root root 158456 Nov  5  2017 /usr/bin/find
                              #70
                              W+ürde ich ja gerne, aber:
                              Sorry, user pi is not allowed to execute '/bin/chmod u+x /usr/bin/find' as root on localhost.
                              Darf ich da ausnahmsweise mal als root ran?
                              PS hatte ich schon mal irgendwo erwähnt, dass ich Ubuntu hasse?
                              liv-in-skyL Thomas BraunT 2 Antworten Letzte Antwort
                                liv-in-skyL
                                liv-in-skyL
                                #71
                                @Homoran uuuhhhh - heikles thema :-)
                                • liv-in-skyL liv-in-sky
                                  #72
                                  @liv-in-sky ich weiß, deswegen frag ich ja gaaaanz vorsichtig an ;-)
                                  Aber:
                                  Die Farbe wird sich hoffentlich im nächsten Zyklus ändern, ich hatte die Datenpunkte für den Header vergessen
                                  Der Charly-Tinker hat ein Armbian auf Debian-Basis!
                                    Thomas BraunT
                                    Thomas BraunT
                                    #73
                                    Versuch mal aus einer root-shell heraus.
                                    Aber eigentlich wundert es mich, dass das nicht mit sudo geht.
                                      #74
                                      da scheint dann auch der Wurm mit den Rechten dran zu hängen
                                      über root gesetzt und über pi abgefragt:
                                        Thomas BraunT
                                        Thomas BraunT
                                        #75
                                        @Homoran
                                        Kannst du mal die komplette Ein- und Ausgabe zeigen? Also inkl. prompt?
                                          @Homoran
                                          #76
                                          @Homoran
                                          klar:
                                          root:
                                          root@tinkerboard:~# chmod u+x /usr/bin/find
                                          root@tinkerboard:~#
                                          pi
                                          84.1k
