  4. Test Adapter vw-connect für VW, ID, Audi, Seat, Skoda
3.8k Beiträge 472 Kommentatoren 3.2m Aufrufe 414 Beobachtet
  • J Jaschkopf
    Servus. Bekomme seit ein paar Tagen immer wieder Warnungen im Log. Hab mal auf Debug umgestellt:
    vw-connect.0	2020-06-20 09:13:27.417	debug	(15305) {"StoredVehicleDataResponse":{"vin":"WVWZZZAUZLxxxxxxx","vehicleData":{"data":[{"id":"0x0101010001","field":[{"id":"0x0101010001","tsCarSentUtc":"2020-06-20T06:49:51Z","tsCarSent":"2020-06-20T
    vw-connect.0	2020-06-20 09:13:27.361	debug	(15305) {"dwaPushHistory":null}
    vw-connect.0	2020-06-20 09:13:27.347	debug	(15305) {"storedPositionResponse":{"parkingTimeUTC":"2020-06-20T06:49:51Z","position":{"heading":{"direction":166},"carCoordinate":{"latitude":51xxxxxx,"longitude":91xxxxx}}}}
    vw-connect.0	2020-06-20 09:13:27.341	debug	(15305) {"charger":{"settings":{"maxChargeCurrent":{"content":16,"timestamp":"2020-06-20T06:48:53Z"},"chargeModeSelection":{"modificationState":{"content":"canNotBeModified","timestamp":"2020-06-20T06
    vw-connect.0	2020-06-20 09:13:27.338	debug	(15305) {"climater":{"settings":{"targetTemperature":{"timestamp":"2020-06-20T06:48:53Z","content":2960},"climatisationWithoutHVpower":{"timestamp":"2020-06-20T06:48:53Z","content":true},"heaterSource
    vw-connect.0	2020-06-20 09:13:27.314	debug	(15305) {"timer":{"timersAndProfiles":{"timerProfileList":{"timerProfile":[{"timestamp":"2020-06-20T06:48:53Z","profileName":"Standard","profileID":"1","operationCharging":false,"operationClimatisatio
    vw-connect.0	2020-06-20 09:13:27.304	debug	(15305) {"error":{"errorCode":"RS.security.9007","description":"The service: rheating_v1 for VIN: WVWZZZAUZLxxxxxxx could not be found."}}
    vw-connect.0	2020-06-20 09:13:27.260	warn	(15305) This value will not be set in future versions. Please report this to the developer.
    vw-connect.0	2020-06-20 09:13:27.260	warn	(15305) State value to set is invalid for vw-connect.0.WVWZZZAUZLxxxxxxx.destinations.destination.POIContact: The state contains no properties! At least one property is expected!
    vw-connect.0	2020-06-20 09:13:27.252	debug	(15305) {"destinations":[{"destination":{"address":{"addressType":0,"city":"Brühl","country":"Deutschland","street":"Berggeiststraße 31-41","zipCode":"50321"},"destinationSource":"Unknown","geoCoordin
    vw-connect.0	2020-06-20 09:13:26.996	debug	(15305) {"CurrentVehicleDataResponse":{"requestId":"70962588","vin":"WVWZZZAUZLxxxxxxx"}}
    vw-connect.0	2020-06-20 09:13:26.196	debug	(15305) {"vehicleData":{"systemId":"MSG-IVWB2222-1592637206051-48981-VDE","requestId":"MSG-IVWB2222-1592637206051-48981-VDE","brand":"VW","country":"DE","vin":"WVWZZZAUZLxxxxxxx","isConnect":"true","i
    vw-connect.0	2020-06-20 09:13:25.984	debug	(15305) {"userVehicles":{"vehicle":["WVWZZZAUZLxxxxxxx"]}}
    vw-connect.0	2020-06-20 09:13:25.796	debug	(15305) {"firstName":"xxxxxx","lastName":"xxxxxxxx","salutation":"SALUTATION:MR","dateOfBirth":"xxxxxxxxx","preferredContactChannel":"MARKETING_BLOCKADES:EMAIL","nickname":"xxxxxxx","businessIdenti
    vw-connect.0	2020-06-20 09:13:25.644	debug	(15305) getData
    vw-connect.0	2020-06-20 09:13:25.643	debug	(15305) Login successful
    vw-connect.0	2020-06-20 09:13:25.191	debug	(15305) Error: Invalid protocol: carnet:
    vw-connect.0	2020-06-20 09:13:24.593	debug	(15305) {"date":"Sat, 20 Jun 2020 07:13:24 GMT","content-length":"0","connection":"close","cache-control":"no-cache, no-store, max-age=0, must-revalidate","content-language":"en","expires":"0","locati
    vw-connect.0	2020-06-20 09:13:24.592	debug	(15305) ""
    vw-connect.0	2020-06-20 09:13:24.201	debug	(15305) parsePasswordForm
    vw-connect.0	2020-06-20 09:13:23.841	debug	(15305) parseEmailForm
    vw-connect.0	2020-06-20 09:13:23.279	info	(15305) starting. Version 0.0.16 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.18.0, js-controller: 3.1.5
    vw-connect.0	2020-06-20 09:13:23.228	debug	(15305) Plugin sentry Initialize Plugin (enabled=true)
    vw-connect.0	2020-06-20 09:13:19.415	info	(28476) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    vw-connect.0	2020-06-20 09:13:19.415	info	(28476) terminating
    vw-connect.0	2020-06-20 09:13:19.414	info	(28476) cleaned everything up...
    vw-connect.0	2020-06-20 09:13:19.414	info	(28476) Got terminate signal TERMINATE_YOURSELF
    Ich hoffe das Log hilft weiter. Habe aber meine persönlichen Daten entfernt.
    Fahrzeug ist ein VW eGolf Bj 10/2019
    Gruß Jaschkopf
    T
    T
    tombox
    #251
    @Jaschkopf der log zeigt keine Auffälligkeiten kannst ihn wieder löschen. Die Fehler können ignoriert werde
    • S
      S
      Sneak-L8
      #252
      Hier mal ein Auszug per Debug:
      2020-06-20 10:28:18.449 - info: vw-connect.0 (2825) starting. Version 0.0.17 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v10.20.1
      2020-06-20 10:28:20.244 - debug: vw-connect.0 (2825) parseEmailForm
      2020-06-20 10:28:21.209 - debug: vw-connect.0 (2825) parsePasswordForm
      2020-06-20 10:28:21.578 - debug: vw-connect.0 (2825) ""
      2020-06-20 10:28:21.579 - debug: vw-connect.0 (2825) {"date":"Sat, 20 Jun 2020 08:28:21 GMT","content-length":"0","connection":"close","cache-control":"no-cache, no-store, max-age=0, must-revalidate","content-language":"en","expires":"0","location":"https://identity.vwgroup.io/oidc/v1/oauth/sso?clientId=9496332b-ea03-4091-a224-8c746b885068@apps_vw-dilab_com&relayState=7c52e086ed6d4f773d2f870126455ff7f4ec738d&userId=<xxx>&HMAC=5ac48fd0881812bce073ffd2d58d70a8e0e099a2d667f5c2ec43967d00d044c8","pragma":"no-cache","strict-transport-security":"max-age=31536000 ; includeSubDomains","x-content-type-options":"nosniff","x-frame-options":"DENY","x-vcap-request-id":"<xxx>","x-xss-protection":"1; mode=block"}
      2020-06-20 10:28:22.507 - debug: vw-connect.0 (2825) Error: Invalid protocol: carnet:
      2020-06-20 10:28:23.124 - debug: vw-connect.0 (2825) Login successful
      2020-06-20 10:28:23.127 - debug: vw-connect.0 (2825) getData
      2020-06-20 10:28:23.318 - debug: vw-connect.0 (2825) {"firstName":"Techn. User","lastName":"ioBroker","salutation":"SALUTATION:MR","preferredContactChannel":"MARKETING_BLOCKADES:EMAIL","nickname":"Techn. User i.","businessIdentifierType":"BUSINESS_IDENTIFIER_TYPE:MBB_ID","businessIdentifierValue":"<xxx>","userIsPrivateIndicator":true,"preferredLanguage":"de"}
      2020-06-20 10:28:23.615 - debug: vw-connect.0 (2825) {"userVehicles":{"vehicle":["WVWZZZ<xxx>","WVWZZZ<xxx>7"]}}
      2020-06-20 10:28:23.635 - debug: vw-connect.0 (2825) getHomeRegion
      2020-06-20 10:28:23.640 - debug: vw-connect.0 (2825) getHomeRegion
      2020-06-20 10:28:24.876 - debug: vw-connect.0 (2825) [object Object]
      2020-06-20 10:28:25.038 - debug: vw-connect.0 (2825) [object Object]
      2020-06-20 10:28:25.249 - error: vw-connect.0 (2825) 403
      2020-06-20 10:28:25.252 - error: vw-connect.0 (2825) status update Failed
      2020-06-20 10:28:25.695 - debug: vw-connect.0 (2825) {"vehicleDataDetail":{"systemId":"XID_APP_VW","requestId":"MSG-IVWB2193-1592641705154-25916-VDE","brand":"VW","country":"DE","vin":"WVWZZZ<xxx>","isConnect":"true","isConnectSorglosReady":"false","vehicleDevices":{"vehicleDevice":[{"deviceType":"INFOTAINMENT","ecuGeneration":"MIB2high"},{"deviceType":"TELEMATICS","deviceId":"WVWZZZ<xxx>@75","ecuGeneration":"OCU2","embeddedSim":{"identification":{"type":"ICCID","content":"89314404000624733177"},"imei":"<xxx>","mno":"vodafone"}}]},"carportData":{"modelCode":"BE23D1","modelName":"e-GOLF COMFO 100 E1F","modelYear":"2019","color":"LA7W","countryCode":"DE","engine":"EAZ","mmi":"7UG","transmission":"RYG"}}}
      2020-06-20 10:28:25.785 - debug: vw-connect.0 (2825) {"vehicleDataDetail":{"systemId":"XID_APP_VW","requestId":"MSG-IVWB2220-1592641705011-19521-VDE","brand":"VW","country":"DE","vin":"WVWZZZ<xxx>","isConnect":"true","isConnectSorglosReady":"false","vehicleDevices":{"vehicleDevice":[{"deviceType":"INFOTAINMENT","ecuGeneration":"MIB2high"},{"deviceType":"TELEMATICS","deviceId":"WVWZZZ<xxx>@75","ecuGeneration":"OCU2","embeddedSim":{"identification":{"type":"ICCID","content":"89314404000394039177"},"imei":"<xxx>","mno":"vodafone"}}]},"carportData":{"modelCode":"BE23D1","modelName":"e-GOLF COMFO 100 E1F","modelYear":"2018","color":"LC9A","countryCode":"DE","engine":"EAZ","mmi":"7UG","transmission":"RYG"}}}
      2020-06-20 10:28:25.856 - debug: vw-connect.0 (2825) {"CurrentVehicleDataResponse":{"requestId":"70972528","vin":"WVWZZZ<xxx>"}}
      2020-06-20 10:28:26.137 - debug: vw-connect.0 (2825) {"error":{"errorCode":"dti.ge.unknown","description":"Internal server error"}}
      2020-06-20 10:28:26.143 - debug: vw-connect.0 (2825) {"error":{"errorCode":"tripstatistics.bs.notacceptable","description":"Not Acceptable"}}
      2020-06-20 10:28:26.200 - debug: vw-connect.0 (2825) {"climater":{"settings":{"targetTemperature":{"timestamp":"2020-06-13T17:18:11Z","content":2935},"climatisationWithoutHVpower":{"timestamp":"2020-06-13T17:18:11Z","content":true},"heaterSource":{"timestamp":"2020-06-13T17:18:11Z","content":"electric"}},"status":{"climatisationStatusData":{"climatisationState":{"timestamp":"2020-06-20T07:35:45Z","content":"off"},"climatisationStateErrorCode":{"timestamp":"2020-06-20T07:35:45Z","content":0},"remainingClimatisationTime":{"timestamp":"2020-06-20T07:35:45Z","content":16},"climatisationReason":{"timestamp":"2020-06-20T07:35:45Z","content":"immediate"}},"windowHeatingStatusData":{"windowHeatingStateFront":{"timestamp":"2020-01-29T17:58:50Z","content":"off"},"windowHeatingStateRear":{"timestamp":"2020-01-29T17:58:50Z","content":"off"},"windowHeatingErrorCode":{"timestamp":"2020-01-29T17:58:50Z","content":0}},"temperatureStatusData":{"outdoorTemperature":{"timestamp":"2020-06-20T07:35:51Z","content":2926}}}}}
      2020-06-20 10:28:26.268 - debug: vw-connect.0 (2825) {"error":{"errorCode":"dwap.bs.notacceptable","description":"Not Acceptable"}}
      2020-06-20 10:28:26.308 - debug: vw-connect.0 (2825) {"error":{"errorCode":"batterycharge.bs.notacceptable","description":"Not Acceptable"}}
      2020-06-20 10:28:26.334 - debug: vw-connect.0 (2825) {"error":{"errorCode":"RS.security.9007","description":"The service: rheating_v1 for VIN: WVWZZZ<xxx> could not be found."}}
      2020-06-20 10:28:26.346 - debug: vw-connect.0 (2825) {"findCarResponse":{"Position":{"timestampCarSent":"2020-06-20T09:35:39","timestampTssReceived":"2020-06-20T07:35:51Z","carCoordinate":{"latitude":49101713,"longitude":8654078},"timestampCarSentUTC":"2020-06-20T07:35:44Z","timestampCarCaptured":"2020-06-20T09:35:39"}}}
      2020-06-20 10:28:26.363 - debug: vw-connect.0 (2825) {"StoredVehicleDataResponse":{"vin":"WVWZZZ<xxx>","vehicleData":{"data":[{"id":"0x0101010001","field":[{"id":"0x0101010001","tsCarSentUtc":"2020-06-20T08:18:04Z","tsCarSent":"2000-01-01T00:00:00","tsCarCaptured":"2000-01-01T00:00:00","tsTssReceivedUtc":"2020-06-20T08:18:11Z","milCarCaptured":0,"milCarSent":0,"value":"echo"}]},{"id":"0x0101010002","field":[{"id":"0x0101010002","tsCarSentUtc":"2020-06-20T07:35:44Z","tsCarSent":"2020-06-20T09:35:39","tsCarCaptured":"2020-06-20T09:35:39","tsTssReceivedUtc":"2020-06-20T07:35:51Z","milCarCaptured":38313,"milCarSent":38313,"value":"38313"}]},{"id":"0x0203FFFFFF","field":[{"id":"0x0203010001","tsCarSentUtc":"2020-06-20T07:35:44Z","tsCarSent":"2020-06-20T09:35:39","tsCarCaptured":"2020-06-19T17:15:01","tsTssReceivedUtc":"2020-06-20T07:35:51Z","milCarCaptured":38297,"milCarSent":38313,"value":null},{"id":"0x0203010002","tsCarSentUtc":"2020-06-20T07:35:44Z","tsCarSent":"2020-06-20T09:35:39","tsCarCaptured":"2020-06-19T17:15:01","tsTssReceivedUtc":"2020-06-20T07:35:51Z","milCarCaptured":38297,"milCarSent":38313,"value":null},{"id":"0x0203010003","tsCarSentUtc":"2020-06-20T07:35:44Z","tsCarSent":"2020-06-20T09:35:39","tsCarCaptured":"2020-06-19T17:15:01","tsTssReceivedUtc":"2020-06-20T07:35:51Z","milCarCaptured":38297,"milCarSent":38313,"value":"-22100","unit":"km","textId":"interval.inspection.distance"},
      Es geht dabei um das 2. aufgeführte Auto.
      • S Sneak-L8
        T
        T
        tombox
        #253
        @Sneak-L8 Ich habe eine neue version in github hochgeladen bitte nochmal testen
        • S
          S
          Sneak-L8
          schrieb am zuletzt editiert von Sneak-L8
          #254
          Leider weiterhin der gleiche Fehler 403.
          Auch nachdem das 2. Fahrzeug aus dem Portal gelöscht wurde.
          vw-connect.0	2020-06-21 13:09:55.990	error	(11466) status update Failed
          vw-connect.0	2020-06-21 13:09:55.988	error	(11466) 403
          • S
            S
            Sneak-L8
            #255
            Seit gestern ca. 13 Uhr sind die Fehler nun weg. Jetzt scheint der Adapter stabil zu laufen. Vielleicht hat sich das Löschen des 2. Fahrzeugs nicht gleich ausgewirkt.
            • K
              K
              kalled
              #256
              bei mir funktioniert der abruf vom Akkustand in der 0.0.17 nicht, sobald ich auf 0.0.16 zurück gehe klappt es.
              Es geht um dieses Objekt:
              vw-connect.0.<Seriennummer>.charger.status.batteryStatusData.stateOfCharge.content
              Ist das ein bekannter Fehler?
              Danke & viele Grüße
              Kalle
              • S
                S
                Sneak-L8
                #257
                Ich würde sagen, ist nicht bekannt. Bei mir wird der SoC korrekt übermittelt (gerade gepürft).
                tombox wird es helfen, wenn Du Fahrzeugmarke und Typ angibst und einen Blick ins Log wirfst, ob dort bereits (Fehler)Meldungen gechrieben wurden und Du diese dann ggfs. ebenfalls postest.
                • K
                  K
                  kalled
                  #258
                  Es ist ein VW eGolf von diesem Jahr. Im Log sehe ich nix spannendes. Habe jetzt durch hin- und herprobieren gesehen, dass bei Downgrade auf 0.0.16 sofort ein Wert für SoC kommt, bei Upgrade auf 0.0.17 nicht.
                  • K kalled
                    Danke & viele Grüße
                    Kalle
                    T
                    T
                    tombox
                    #259
                    @kalled kannst du bitte von GitHub testen und installieren und Bescheid geben ob die Version geht?
                    • J
                      J
                      Jaschkopf
                      #260
                      Servus. Habe den selben Fehler wie @kalled . Bei mir wird der Ladezustand auch nicht mehr abgerufen. Hab deswegen mal alle Objekte des Adapters gelöscht und den Adapter neu gestartet und jetzt werden sie nicht mehr angelegt bzw abgerufen. Version ist auch 0.0.17 und Fahrzeug ein 2019er eGolf.
                      Gruß Jaschkopf
                      • T tombox
                        K
                        K
                        kalled
                        #261
                        @tombox erledigt und geht! Vielen Dank
                        • K kalled
                          T
                          T
                          tombox
                          #262
                          @kalled ok dann werde ich mal eine neue Version releasen
                          • pfriedP
                            pfriedP
                            pfried
                            #263
                            Hallo, da ich neu bin, darf ich mal Fragen was man in diesem Fall falsch gemacht hat:
                            Vielen Dank schon jetzt für sachdienliche Hinweise 😊
                            • pfriedP pfried
                              T
                              T
                              tombox
                              #264
                              @pfried unvollständiges nodejs update
                              cd /opt/iobroker
                              npm install canvas --unsafe-perm --production --save --prefix
                              npm rebuild
                              pfriedP 1 Antwort Letzte Antwort
                              • T tombox
                                cd /opt/iobroker
                                npm rebuild
                                pfriedP
                                pfriedP
                                pfried
                                #265
                                @tombox Danke!
                                • pfriedP
                                  pfriedP
                                  pfried
                                  #266
                                  @tombox: Hallo, ich habe noch eine kurze Frage, bei mir kommt im LOG ab und zu:
                                  Mache ich da was falsch?
                                  Vielen Dank und liebe Grüße
                                  Paul
                                  • pfriedP pfried
                                    Paul
                                    T
                                    T
                                    tombox
                                    #267
                                    @pfried Liegt nicht an dir sondern an vw oder mir. Wie oft kam das jetzt und wie lange schon
                                    • T tombox
                                      pfriedP
                                      pfriedP
                                      pfried
                                      #268
                                      @tombox Guten Morgen, ich habe den fix von Dir am 7.7.2020 vor 12:47h eingespielt und seither habe ich circa 2 oder 3 mal beobachtet. Dachte mir aber anfangs nichts dabei, deshalb habe ich die alten Log-Einträge nicht mehr.
                                      Liebe Grüße Paul
                                      • pfriedP pfried
                                        Liebe Grüße Paul
                                        T
                                        T
                                        tombox
                                        #269
                                        @pfried Wenn es so selten ist kann es an VW liegen bitte einfach beobachten
                                        • pfriedP
                                          pfriedP
                                          pfried
                                          #270
                                          @tombox: Anbei Log Auszug von 8:00h bis 15:45h
                                          33.2k
                                          84.4k
