  4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    6.4k
3.8k Beiträge 462 Kommentatoren 2.2m Aufrufe 410 Beobachtet
  • S Sneak-L8
    Gerade instaliert und leider wieder
    vw-connect.0	2020-06-19 23:19:43.017	error	(11592) status update Failed
    vw-connect.0	2020-06-19 23:19:43.015	error	(11592) 403
    tombox
    #249
    @Sneak-L8 ich bräuchte mehr log im debug mode
    • J Offline
      Jaschkopf
      schrieb am zuletzt editiert von Jaschkopf
      #250
      Servus. Bekomme seit ein paar Tagen immer wieder Warnungen im Log. Hab mal auf Debug umgestellt:
      vw-connect.0	2020-06-20 09:13:27.417	debug	(15305) {"StoredVehicleDataResponse":{"vin":"WVWZZZAUZLxxxxxxx","vehicleData":{"data":[{"id":"0x0101010001","field":[{"id":"0x0101010001","tsCarSentUtc":"2020-06-20T06:49:51Z","tsCarSent":"2020-06-20T
      vw-connect.0	2020-06-20 09:13:27.361	debug	(15305) {"dwaPushHistory":null}
      vw-connect.0	2020-06-20 09:13:27.347	debug	(15305) {"storedPositionResponse":{"parkingTimeUTC":"2020-06-20T06:49:51Z","position":{"heading":{"direction":166},"carCoordinate":{"latitude":51xxxxxx,"longitude":91xxxxx}}}}
      vw-connect.0	2020-06-20 09:13:27.341	debug	(15305) {"charger":{"settings":{"maxChargeCurrent":{"content":16,"timestamp":"2020-06-20T06:48:53Z"},"chargeModeSelection":{"modificationState":{"content":"canNotBeModified","timestamp":"2020-06-20T06
      vw-connect.0	2020-06-20 09:13:27.338	debug	(15305) {"climater":{"settings":{"targetTemperature":{"timestamp":"2020-06-20T06:48:53Z","content":2960},"climatisationWithoutHVpower":{"timestamp":"2020-06-20T06:48:53Z","content":true},"heaterSource
      vw-connect.0	2020-06-20 09:13:27.314	debug	(15305) {"timer":{"timersAndProfiles":{"timerProfileList":{"timerProfile":[{"timestamp":"2020-06-20T06:48:53Z","profileName":"Standard","profileID":"1","operationCharging":false,"operationClimatisatio
      vw-connect.0	2020-06-20 09:13:27.304	debug	(15305) {"error":{"errorCode":"RS.security.9007","description":"The service: rheating_v1 for VIN: WVWZZZAUZLxxxxxxx could not be found."}}
      vw-connect.0	2020-06-20 09:13:27.260	warn	(15305) This value will not be set in future versions. Please report this to the developer.
      vw-connect.0	2020-06-20 09:13:27.260	warn	(15305) State value to set is invalid for vw-connect.0.WVWZZZAUZLxxxxxxx.destinations.destination.POIContact: The state contains no properties! At least one property is expected!
      vw-connect.0	2020-06-20 09:13:27.252	debug	(15305) {"destinations":[{"destination":{"address":{"addressType":0,"city":"Brühl","country":"Deutschland","street":"Berggeiststraße 31-41","zipCode":"50321"},"destinationSource":"Unknown","geoCoordin
      vw-connect.0	2020-06-20 09:13:26.996	debug	(15305) {"CurrentVehicleDataResponse":{"requestId":"70962588","vin":"WVWZZZAUZLxxxxxxx"}}
      vw-connect.0	2020-06-20 09:13:26.196	debug	(15305) {"vehicleData":{"systemId":"MSG-IVWB2222-1592637206051-48981-VDE","requestId":"MSG-IVWB2222-1592637206051-48981-VDE","brand":"VW","country":"DE","vin":"WVWZZZAUZLxxxxxxx","isConnect":"true","i
      vw-connect.0	2020-06-20 09:13:25.984	debug	(15305) {"userVehicles":{"vehicle":["WVWZZZAUZLxxxxxxx"]}}
      vw-connect.0	2020-06-20 09:13:25.796	debug	(15305) {"firstName":"xxxxxx","lastName":"xxxxxxxx","salutation":"SALUTATION:MR","dateOfBirth":"xxxxxxxxx","preferredContactChannel":"MARKETING_BLOCKADES:EMAIL","nickname":"xxxxxxx","businessIdenti
      vw-connect.0	2020-06-20 09:13:25.644	debug	(15305) getData
      vw-connect.0	2020-06-20 09:13:25.643	debug	(15305) Login successful
      vw-connect.0	2020-06-20 09:13:25.191	debug	(15305) Error: Invalid protocol: carnet:
      vw-connect.0	2020-06-20 09:13:24.593	debug	(15305) {"date":"Sat, 20 Jun 2020 07:13:24 GMT","content-length":"0","connection":"close","cache-control":"no-cache, no-store, max-age=0, must-revalidate","content-language":"en","expires":"0","locati
      vw-connect.0	2020-06-20 09:13:24.592	debug	(15305) ""
      vw-connect.0	2020-06-20 09:13:24.201	debug	(15305) parsePasswordForm
      vw-connect.0	2020-06-20 09:13:23.841	debug	(15305) parseEmailForm
      vw-connect.0	2020-06-20 09:13:23.279	info	(15305) starting. Version 0.0.16 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.18.0, js-controller: 3.1.5
      vw-connect.0	2020-06-20 09:13:23.228	debug	(15305) Plugin sentry Initialize Plugin (enabled=true)
      vw-connect.0	2020-06-20 09:13:19.415	info	(28476) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      vw-connect.0	2020-06-20 09:13:19.415	info	(28476) terminating
      vw-connect.0	2020-06-20 09:13:19.414	info	(28476) cleaned everything up...
      vw-connect.0	2020-06-20 09:13:19.414	info	(28476) Got terminate signal TERMINATE_YOURSELF
      Ich hoffe das Log hilft weiter. Habe aber meine persönlichen Daten entfernt.
      Fahrzeug ist ein VW eGolf Bj 10/2019
      Gruß Jaschkopf
      • J Jaschkopf
        Gruß Jaschkopf
        tombox
        #251
        @Jaschkopf der log zeigt keine Auffälligkeiten kannst ihn wieder löschen. Die Fehler können ignoriert werde
          Sneak-L8
          #252
          Hier mal ein Auszug per Debug:
          2020-06-20 10:28:18.449 - info: vw-connect.0 (2825) starting. Version 0.0.17 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v10.20.1
          2020-06-20 10:28:20.244 - debug: vw-connect.0 (2825) parseEmailForm
          2020-06-20 10:28:21.209 - debug: vw-connect.0 (2825) parsePasswordForm
          2020-06-20 10:28:21.578 - debug: vw-connect.0 (2825) ""
          2020-06-20 10:28:21.579 - debug: vw-connect.0 (2825) {"date":"Sat, 20 Jun 2020 08:28:21 GMT","content-length":"0","connection":"close","cache-control":"no-cache, no-store, max-age=0, must-revalidate","content-language":"en","expires":"0","location":"https://identity.vwgroup.io/oidc/v1/oauth/sso?clientId=9496332b-ea03-4091-a224-8c746b885068@apps_vw-dilab_com&relayState=7c52e086ed6d4f773d2f870126455ff7f4ec738d&userId=<xxx>&HMAC=5ac48fd0881812bce073ffd2d58d70a8e0e099a2d667f5c2ec43967d00d044c8","pragma":"no-cache","strict-transport-security":"max-age=31536000 ; includeSubDomains","x-content-type-options":"nosniff","x-frame-options":"DENY","x-vcap-request-id":"<xxx>","x-xss-protection":"1; mode=block"}
          2020-06-20 10:28:22.507 - debug: vw-connect.0 (2825) Error: Invalid protocol: carnet:
          2020-06-20 10:28:23.124 - debug: vw-connect.0 (2825) Login successful
          2020-06-20 10:28:23.127 - debug: vw-connect.0 (2825) getData
          2020-06-20 10:28:23.318 - debug: vw-connect.0 (2825) {"firstName":"Techn. User","lastName":"ioBroker","salutation":"SALUTATION:MR","preferredContactChannel":"MARKETING_BLOCKADES:EMAIL","nickname":"Techn. User i.","businessIdentifierType":"BUSINESS_IDENTIFIER_TYPE:MBB_ID","businessIdentifierValue":"<xxx>","userIsPrivateIndicator":true,"preferredLanguage":"de"}
          2020-06-20 10:28:23.615 - debug: vw-connect.0 (2825) {"userVehicles":{"vehicle":["WVWZZZ<xxx>","WVWZZZ<xxx>7"]}}
          2020-06-20 10:28:23.635 - debug: vw-connect.0 (2825) getHomeRegion
          2020-06-20 10:28:23.640 - debug: vw-connect.0 (2825) getHomeRegion
          2020-06-20 10:28:24.876 - debug: vw-connect.0 (2825) [object Object]
          2020-06-20 10:28:25.038 - debug: vw-connect.0 (2825) [object Object]
          2020-06-20 10:28:25.249 - error: vw-connect.0 (2825) 403
          2020-06-20 10:28:25.252 - error: vw-connect.0 (2825) status update Failed
          2020-06-20 10:28:25.695 - debug: vw-connect.0 (2825) {"vehicleDataDetail":{"systemId":"XID_APP_VW","requestId":"MSG-IVWB2193-1592641705154-25916-VDE","brand":"VW","country":"DE","vin":"WVWZZZ<xxx>","isConnect":"true","isConnectSorglosReady":"false","vehicleDevices":{"vehicleDevice":[{"deviceType":"INFOTAINMENT","ecuGeneration":"MIB2high"},{"deviceType":"TELEMATICS","deviceId":"WVWZZZ<xxx>@75","ecuGeneration":"OCU2","embeddedSim":{"identification":{"type":"ICCID","content":"89314404000624733177"},"imei":"<xxx>","mno":"vodafone"}}]},"carportData":{"modelCode":"BE23D1","modelName":"e-GOLF COMFO 100 E1F","modelYear":"2019","color":"LA7W","countryCode":"DE","engine":"EAZ","mmi":"7UG","transmission":"RYG"}}}
          2020-06-20 10:28:25.785 - debug: vw-connect.0 (2825) {"vehicleDataDetail":{"systemId":"XID_APP_VW","requestId":"MSG-IVWB2220-1592641705011-19521-VDE","brand":"VW","country":"DE","vin":"WVWZZZ<xxx>","isConnect":"true","isConnectSorglosReady":"false","vehicleDevices":{"vehicleDevice":[{"deviceType":"INFOTAINMENT","ecuGeneration":"MIB2high"},{"deviceType":"TELEMATICS","deviceId":"WVWZZZ<xxx>@75","ecuGeneration":"OCU2","embeddedSim":{"identification":{"type":"ICCID","content":"89314404000394039177"},"imei":"<xxx>","mno":"vodafone"}}]},"carportData":{"modelCode":"BE23D1","modelName":"e-GOLF COMFO 100 E1F","modelYear":"2018","color":"LC9A","countryCode":"DE","engine":"EAZ","mmi":"7UG","transmission":"RYG"}}}
          2020-06-20 10:28:25.856 - debug: vw-connect.0 (2825) {"CurrentVehicleDataResponse":{"requestId":"70972528","vin":"WVWZZZ<xxx>"}}
          2020-06-20 10:28:26.137 - debug: vw-connect.0 (2825) {"error":{"errorCode":"dti.ge.unknown","description":"Internal server error"}}
          2020-06-20 10:28:26.143 - debug: vw-connect.0 (2825) {"error":{"errorCode":"tripstatistics.bs.notacceptable","description":"Not Acceptable"}}
          2020-06-20 10:28:26.200 - debug: vw-connect.0 (2825) {"climater":{"settings":{"targetTemperature":{"timestamp":"2020-06-13T17:18:11Z","content":2935},"climatisationWithoutHVpower":{"timestamp":"2020-06-13T17:18:11Z","content":true},"heaterSource":{"timestamp":"2020-06-13T17:18:11Z","content":"electric"}},"status":{"climatisationStatusData":{"climatisationState":{"timestamp":"2020-06-20T07:35:45Z","content":"off"},"climatisationStateErrorCode":{"timestamp":"2020-06-20T07:35:45Z","content":0},"remainingClimatisationTime":{"timestamp":"2020-06-20T07:35:45Z","content":16},"climatisationReason":{"timestamp":"2020-06-20T07:35:45Z","content":"immediate"}},"windowHeatingStatusData":{"windowHeatingStateFront":{"timestamp":"2020-01-29T17:58:50Z","content":"off"},"windowHeatingStateRear":{"timestamp":"2020-01-29T17:58:50Z","content":"off"},"windowHeatingErrorCode":{"timestamp":"2020-01-29T17:58:50Z","content":0}},"temperatureStatusData":{"outdoorTemperature":{"timestamp":"2020-06-20T07:35:51Z","content":2926}}}}}
          2020-06-20 10:28:26.268 - debug: vw-connect.0 (2825) {"error":{"errorCode":"dwap.bs.notacceptable","description":"Not Acceptable"}}
          2020-06-20 10:28:26.308 - debug: vw-connect.0 (2825) {"error":{"errorCode":"batterycharge.bs.notacceptable","description":"Not Acceptable"}}
          2020-06-20 10:28:26.334 - debug: vw-connect.0 (2825) {"error":{"errorCode":"RS.security.9007","description":"The service: rheating_v1 for VIN: WVWZZZ<xxx> could not be found."}}
          2020-06-20 10:28:26.346 - debug: vw-connect.0 (2825) {"findCarResponse":{"Position":{"timestampCarSent":"2020-06-20T09:35:39","timestampTssReceived":"2020-06-20T07:35:51Z","carCoordinate":{"latitude":49101713,"longitude":8654078},"timestampCarSentUTC":"2020-06-20T07:35:44Z","timestampCarCaptured":"2020-06-20T09:35:39"}}}
          2020-06-20 10:28:26.363 - debug: vw-connect.0 (2825) {"StoredVehicleDataResponse":{"vin":"WVWZZZ<xxx>","vehicleData":{"data":[{"id":"0x0101010001","field":[{"id":"0x0101010001","tsCarSentUtc":"2020-06-20T08:18:04Z","tsCarSent":"2000-01-01T00:00:00","tsCarCaptured":"2000-01-01T00:00:00","tsTssReceivedUtc":"2020-06-20T08:18:11Z","milCarCaptured":0,"milCarSent":0,"value":"echo"}]},{"id":"0x0101010002","field":[{"id":"0x0101010002","tsCarSentUtc":"2020-06-20T07:35:44Z","tsCarSent":"2020-06-20T09:35:39","tsCarCaptured":"2020-06-20T09:35:39","tsTssReceivedUtc":"2020-06-20T07:35:51Z","milCarCaptured":38313,"milCarSent":38313,"value":"38313"}]},{"id":"0x0203FFFFFF","field":[{"id":"0x0203010001","tsCarSentUtc":"2020-06-20T07:35:44Z","tsCarSent":"2020-06-20T09:35:39","tsCarCaptured":"2020-06-19T17:15:01","tsTssReceivedUtc":"2020-06-20T07:35:51Z","milCarCaptured":38297,"milCarSent":38313,"value":null},{"id":"0x0203010002","tsCarSentUtc":"2020-06-20T07:35:44Z","tsCarSent":"2020-06-20T09:35:39","tsCarCaptured":"2020-06-19T17:15:01","tsTssReceivedUtc":"2020-06-20T07:35:51Z","milCarCaptured":38297,"milCarSent":38313,"value":null},{"id":"0x0203010003","tsCarSentUtc":"2020-06-20T07:35:44Z","tsCarSent":"2020-06-20T09:35:39","tsCarCaptured":"2020-06-19T17:15:01","tsTssReceivedUtc":"2020-06-20T07:35:51Z","milCarCaptured":38297,"milCarSent":38313,"value":"-22100","unit":"km","textId":"interval.inspection.distance"},
          Es geht dabei um das 2. aufgeführte Auto.
          • S Sneak-L8
            tombox
            #253
            @Sneak-L8 Ich habe eine neue version in github hochgeladen bitte nochmal testen
              Sneak-L8
              schrieb am zuletzt editiert von Sneak-L8
              #254
              Leider weiterhin der gleiche Fehler 403.
              Auch nachdem das 2. Fahrzeug aus dem Portal gelöscht wurde.
              vw-connect.0	2020-06-21 13:09:55.990	error	(11466) status update Failed
              vw-connect.0	2020-06-21 13:09:55.988	error	(11466) 403
                Sneak-L8
                #255
                Seit gestern ca. 13 Uhr sind die Fehler nun weg. Jetzt scheint der Adapter stabil zu laufen. Vielleicht hat sich das Löschen des 2. Fahrzeugs nicht gleich ausgewirkt.
                  kalled
                  #256
                  bei mir funktioniert der abruf vom Akkustand in der 0.0.17 nicht, sobald ich auf 0.0.16 zurück gehe klappt es.
                  Es geht um dieses Objekt:
                  vw-connect.0.<Seriennummer>.charger.status.batteryStatusData.stateOfCharge.content
                  Ist das ein bekannter Fehler?
                  Danke & viele Grüße
                  Kalle
                    Sneak-L8
                    #257
                    Ich würde sagen, ist nicht bekannt. Bei mir wird der SoC korrekt übermittelt (gerade gepürft).
                    tombox wird es helfen, wenn Du Fahrzeugmarke und Typ angibst und einen Blick ins Log wirfst, ob dort bereits (Fehler)Meldungen gechrieben wurden und Du diese dann ggfs. ebenfalls postest.
                      kalled
                      #258
                      Es ist ein VW eGolf von diesem Jahr. Im Log sehe ich nix spannendes. Habe jetzt durch hin- und herprobieren gesehen, dass bei Downgrade auf 0.0.16 sofort ein Wert für SoC kommt, bei Upgrade auf 0.0.17 nicht.
                      • K kalled
                        Danke & viele Grüße
                        Kalle
                        tombox
                        #259
                        @kalled kannst du bitte von GitHub testen und installieren und Bescheid geben ob die Version geht?
                        • J Offline
                          Jaschkopf
                          #260
                          Servus. Habe den selben Fehler wie @kalled . Bei mir wird der Ladezustand auch nicht mehr abgerufen. Hab deswegen mal alle Objekte des Adapters gelöscht und den Adapter neu gestartet und jetzt werden sie nicht mehr angelegt bzw abgerufen. Version ist auch 0.0.17 und Fahrzeug ein 2019er eGolf.
                          Gruß Jaschkopf
                          • T tombox
                            kalled
                            #261
                            @tombox erledigt und geht! Vielen Dank
                            • K kalled
                              tombox
                              #262
                              @kalled ok dann werde ich mal eine neue Version releasen
                              • pfriedP Offline
                                pfriedP Offline
                                pfried
                                #263
                                Hallo, da ich neu bin, darf ich mal Fragen was man in diesem Fall falsch gemacht hat:
                                Vielen Dank schon jetzt für sachdienliche Hinweise 😊
                                • pfriedP pfried
                                  tombox
                                  #264
                                  @pfried unvollständiges nodejs update
                                  cd /opt/iobroker
                                  npm install canvas --unsafe-perm --production --save --prefix
                                  npm rebuild
                                  pfriedP 1 Antwort Letzte Antwort
                                  • T tombox
                                    cd /opt/iobroker
                                    npm rebuild
                                    pfriedP Offline
                                    pfriedP Offline
                                    pfried
                                    #265
                                    @tombox Danke!
                                    • pfriedP Offline
                                      pfriedP Offline
                                      pfried
                                      #266
                                      @tombox: Hallo, ich habe noch eine kurze Frage, bei mir kommt im LOG ab und zu:
                                      Mache ich da was falsch?
                                      Vielen Dank und liebe Grüße
                                      Paul
                                      • pfriedP pfried
                                        Paul
                                        tombox
                                        #267
                                        @pfried Liegt nicht an dir sondern an vw oder mir. Wie oft kam das jetzt und wie lange schon
                                        • T tombox
                                          pfriedP Offline
                                          pfriedP Offline
                                          pfried
                                          #268
                                          @tombox Guten Morgen, ich habe den fix von Dir am 7.7.2020 vor 12:47h eingespielt und seither habe ich circa 2 oder 3 mal beobachtet. Dachte mir aber anfangs nichts dabei, deshalb habe ich die alten Log-Einträge nicht mehr.
                                          Liebe Grüße Paul
