  4. [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen
adapateradapterneu hiertesttestentesterwled
655 Beiträge 73 Kommentatoren 276.8k Aufrufe 79 Beobachtet
  • E e-s
    @Dutchman
    Done
    Dankeschön
    DutchmanD
    DutchmanD
    Dutchman
    #229
    @e-s sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
    @Dutchman
    Done
    Dankeschön
    @Chaot sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
    @Dutchman Ich habe gerade den JS-Controler in der V3.0.x am Testen. Dabei schmeißt der Adapter folgende Warnung:
    wled.0	2020-04-13 09:57:17.397	warn	(25893) This value will not be set in future versions. Please report this to the developer.
    wled.0	2020-04-13 09:57:17.397	warn	(25893) State value to set is invalid for wled.0.cc50e304f753.seg.0.col.0: The state is missing the required property val!
    wled.0	2020-04-13 09:57:17.394	warn	(25893) This value will not be set in future versions. Please report this to the developer.
    wled.0	2020-04-13 09:57:17.393	warn	(25893) State value to set is invalid for wled.0.cc50e304f753.seg.0.ix: The state is missing the required property val!
    Die beiden Werte werden von mir per Script beschrieben.
    bitte 0.5.1 von git testen
    • DutchmanD Dutchman
      @Dutchman
      Done
      Dankeschön
      ChaotC
      ChaotC
      Chaot
      #230
      @Dutchman Warnung scheint weg zu sein.
      Danke dir.
      • ChaotC
        ChaotC
        Chaot
        schrieb am zuletzt editiert von Chaot
        #231
        @Dutchman Mist:
        wled.0	2020-04-21 12:22:25.935	warn	(5597) This value will not be set in future versions. Please report this to the developer.
        wled.0	2020-04-21 12:22:25.934	warn	(5597) State value to set is invalid for wled.0.cc50e304f753.seg.0.col.0: The state is missing the required property val!
        wled.0	2020-04-21 12:22:25.928	warn	(5597) This value will not be set in future versions. Please report this to the developer.
        wled.0	2020-04-21 12:22:25.928	warn	(5597) State value to set is invalid for wled.0.cc50e304f753.seg.0.ix: The state is missing the required property val!
        Kam erst nachdem ich mein Script zum schreiben der Werte wieder laufen hatte.
        • ChaotC Chaot
          @Dutchman Mist:
          DutchmanD
          DutchmanD
          Dutchman
          #232
          euh und kommt das dan aus meinem adapter oder deinem script :)
          ich kan es nicht so Nachstellen da ich den wert immer schreibe, was macht dein script ?
            ChaotC
            ChaotC
            Chaot
            #233
            @Dutchman
            Das Script ist eine Temperaturanzeige.
            on({id: "sonoff.0.Eingang.BME280_Temperature"/*Eingang BME280  Temperature*/, change: "any"}, function (obj) {
             var value = obj.state.val;
             if (getState("sonoff.0.Eingang.BME280_Temperature").val <= -23) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 16);
               setState("wled.0.cc50e304f753.seg.0.col.0"/*Primary Color RGB*/, '102,0,204');
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val >= -22 && getState("sonoff.0.Eingang.BME280_Temperature").val <= -21) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 18);
               setState("wled.0.cc50e304f753.seg.0.col.0"/*Primary Color RGB*/, '127,0,255');
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val >= -20 && getState("sonoff.0.Eingang.BME280_Temperature").val <= -19) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 20);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val >= -18 && getState("sonoff.0.Eingang.BME280_Temperature").val <= -17) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 22);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val >= -16 && getState("sonoff.0.Eingang.BME280_Temperature").val <= -15) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 24);
               setState("wled.0.cc50e304f753.seg.0.col.0"/*Primary Color RGB*/, '0,0,255');
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val >= -14 && getState("sonoff.0.Eingang.BME280_Temperature").val <= -13) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 26);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val >= -12 && getState("sonoff.0.Eingang.BME280_Temperature").val <= -11) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 28);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val >= -10 && getState("sonoff.0.Eingang.BME280_Temperature").val <= -9) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 30);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val >= -8 && getState("sonoff.0.Eingang.BME280_Temperature").val <= -7) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 32);
               setState("wled.0.cc50e304f753.seg.0.col.0"/*Primary Color RGB*/, '0,128,255');
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val >= -6 && getState("sonoff.0.Eingang.BME280_Temperature").val <= -5) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 34);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val >= -4 && getState("sonoff.0.Eingang.BME280_Temperature").val <= -3) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 36);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > -2 && getState("sonoff.0.Eingang.BME280_Temperature").val <= -1) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 38);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 0 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 1) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 40);
               setState("wled.0.cc50e304f753.seg.0.col.0"/*Primary Color RGB*/, '0,255,255');
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 2 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 3) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 42);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 4 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 5) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 44);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 6 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 7) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 46);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 8 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 9) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 48);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 10 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 11) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 50);
               setState("wled.0.cc50e304f753.seg.0.col.0"/*Primary Color RGB*/, '0,255,128');
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 12 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 13) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 52);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 14 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 15) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 54);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 16 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 17) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 56);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 18 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 19) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 58);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 20 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 21) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 60);
               setState("wled.0.cc50e304f753.seg.0.col.0"/*Primary Color RGB*/, '0,255,0');
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 22 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 23) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 62);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 24 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 25) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 64);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 26 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 27) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 66);
               setState("wled.0.cc50e304f753.seg.0.col.0"/*Primary Color RGB*/, '128,255,0');
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 28 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 29) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 68);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 30 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 31) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 70);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 32 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 33) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 72);
               setState("wled.0.cc50e304f753.seg.0.col.0"/*Primary Color RGB*/, '255,255,0');
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 34 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 35) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 74);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 36 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 37) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 76);
               setState("wled.0.cc50e304f753.seg.0.col.0"/*Primary Color RGB*/, '255,128,0');
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 38 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 39) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 78);
             } else if (getState("sonoff.0.Eingang.BME280_Temperature").val > 40 && getState("sonoff.0.Eingang.BME280_Temperature").val <= 42) {
               setState("wled.0.cc50e304f753.seg.0.ix"/*Effect intensity*/, 80);
               setState("wled.0.cc50e304f753.seg.0.col.0"/*Primary Color RGB*/, '255,0,0');
            Original in Blockly geschrieben, aber zur schnelleren Konntrolle hier mal in JS aufgeführt.
            • ChaotC Chaot
              @Dutchman
              DutchmanD
              DutchmanD
              Dutchman
              #234
              Spoiler
              muss das mal in ruhe bei mir nachspielen mit dem script habe selber die Fehler nicht bekommen ...
              bin gerade noch an ein par anderen issue dran melde mich, bitte git issue reopenen
                Spoiler
                ChaotC
                ChaotC
                Chaot
                #235
                @Dutchman Ich gehe jetzt in die Ecke zum weinen. Ich kann das issue nicht wieder öffnen.....
                ... ist heute nicht mein Tag....
                • joergeliJ joergeli
                  @bigd-73
                  Hallo Mario,
                  ich habe Dein Script ein wenig "aufgebohrt" und noch ein paar Funktionen eingebaut (Farbe, WLED-Effekt, Geschwindigkeit, Effekt-Intensität, Helligkeit, An/Aus).
                  Dazu habe ich auch einen Beispiel-View gebastelt:
                  wled-view.zip
                  Das Script legt automatisch die benötigten Datenpunkt für die Hilfsvariablen an.
                  Achtung: Im Script muß die Variable WLED-ID auf die eigene WLED-ID angepasst werden!
                  // WLED-Steuerung / Hex to RGB
                  var WLED_ID = 'a020a61bbd2c'; // Hinweis: die Zeichenfolge "a020a61bbd2c" muss durch die eigene WLED-ID ersetzt werden!
                  //____________________________
                  createState('javascript.0.wled.effekt', { name: 'WLED Effekt', desc: 'Hilfsvariable', type: 'number', def: 9 });
                  createState('javascript.0.wled.farbe',  { name: 'WLED Farbauswahl', desc: 'Hilfsvariable', type: 'string', def: '#6a6cf6' });
                  createState('javascript.0.wled.speed',  { name: 'Effekt Geschwindigkeit', desc: 'Hilfsvariable', type: 'number', def: 200 });
                  createState('javascript.0.wled.intensity', { name: 'Effekt Intensität', desc: 'Hilfsvariable', type: 'number', def: 128 });
                  createState('javascript.0.wled.brightness', { name: 'Helligkeit', desc: 'Hilfsvariable', type: 'number', def: 128 });
                  createState('javascript.0.wled.toggle', { name: 'An / Aus', desc: 'Hilfsvariable', type: 'boolean', def: true });
                  function hexToRgb(hex) {
                    var result = /^#?([a-f\d]{2})([a-f\d]{2})([a-f\d]{2})$/i.exec(hex);
                    return result ? {
                      r: parseInt(result[1], 16),
                      g: parseInt(result[2], 16),
                      b: parseInt(result[3], 16)
                    } : null;
                  // Hilfsvariable wird durch den Vis Color Picker überwacht, dann wird WLED-Farbe als HEX-Wert gesetzt
                  on({id: "javascript.0.wled.farbe", change: "ne"}, function (obj) {
                     setState("wled.0." + WLED_ID + ".seg.0.col.0",
                     hexToRgb(getState("javascript.0.wled.farbe").val).r + ',' +
                     hexToRgb(getState("javascript.0.wled.farbe").val).g + ',' +
                     hexToRgb(getState("javascript.0.wled.farbe").val).b);
                  // Hilfsvariable wird durch VIS jqui - SelectValueList überwacht, bei Änderung wird WLED-Effekt gesetzt.
                  on({id: "javascript.0.wled.effekt", change: "any"}, function (obj) {
                      var effekt = getState("javascript.0.wled.effekt").val ;
                      //log ("effekt: " + effekt);
                      setState("wled.0." + WLED_ID + ".seg.0.fx", effekt);
                  // Hilfsvariable wird durch VIS metro Slider horizontal überwacht, bei Änderung wird Geschwindigkeit gesetzt.
                  on({id: "javascript.0.wled.speed", change: "any"}, function (obj) {
                      var speed = getState("javascript.0.wled.speed").val ;
                      setState("wled.0." + WLED_ID + ".seg.0.sx", speed);
                  // Hilfsvariable wird durch VIS metro Slider horizontal überwacht, bei Änderung wird Effekt-Intensität gesetzt.
                  on({id: "javascript.0.wled.intensity", change: "any"}, function (obj) {
                      var intens = getState("javascript.0.wled.intensity").val ;
                      setState("wled.0." + WLED_ID + ".seg.0.ix", intens);
                  // Hilfsvariable wird durch VIS metro Slider horizontal überwacht, bei Änderung wird Helligkeit gesetzt.
                  on({id: "javascript.0.wled.brightness", change: "any"}, function (obj) {
                      var bright = getState("javascript.0.wled.brightness").val ;
                      setState("wled.0." + WLED_ID + ".bri", bright);
                  // Hilfsvariable wird durch VIS fancyswitch überwacht, bei Änderung wird An/Aus geschaltet.
                  on({id: "javascript.0.wled.toggle", change: "any"}, function (obj) {
                      var on = getState("javascript.0.wled.toggle").val ;
                      setState("wled.0." + WLED_ID + ".on", on);
                  Vielleicht kann es ja jemand gebrauchen?
                  Jörg
                  H
                  H
                  hollerbachr
                  #236
                  @joergeli
                  Hallo Hab gerade Dein Script und das Widgets eingebaut mir fehlt noch der Teil für die Preset.
                  Kannst du das aktuelle posten
                  Raimund
                  joergeliJ 1 Antwort Letzte Antwort
                  • H hollerbachr
                    @joergeli
                    Raimund
                    joergeliJ
                    joergeliJ
                    joergeli
                    #237
                    @hollerbachr
                    Hallo Raimund,
                    ich habe den WLED-Adapter zwischenzeitlich bei mir entfernt, da ich das Gefühl hatte, daß er ioBroker mit der Zeit immer mehr auslastet. Ich kann es aber nicht mit Gewißheit sagen.
                    Mein altes WLED-JS habe ich aber noch gefunden:
                    createState('javascript.0.wled.palette', { name: 'WLED Palette', desc: 'Hilfsvariable', type: 'number', def: 10 });
                    createState('javascript.0.wled.preset', { name: 'Preset', desc: 'Hilfsvariable', type: 'number', def: 1 });
                      return result ? {
                      } : null;
                    // Farbe-Hilfsvariable wird durch den Vis Color Picker überwacht, dann wird WLED-Farbe als HEX-Wert gesetzt
                    // Preset-Hilfsvariable wird durch VIS-Buttons überwacht, bei Änderung wird WLED-Preset gesetzt.
                    on({id: "javascript.0.wled.preset", change: "any"}, function (obj) {
                        var preset = getState("javascript.0.wled.preset").val ;
                        //log ("preset: " + preset);
                        setState("wled.0." + WLED_ID + ".ps", preset);
                    // Effekt-Hilfsvariable wird durch VIS jqui - SelectValueList überwacht, bei Änderung wird WLED-Effekt gesetzt.
                    // Palette-Hilfsvariable wird durch VIS jqui - SelectValueList überwacht, bei Änderung wird WLED-Palette gesetzt.
                    on({id: "javascript.0.wled.palette", change: "any"}, function (obj) {
                        var palette = getState("javascript.0.wled.palette").val ;
                        //log ("palette: " + palette);
                        setState("wled.0." + WLED_ID + ".seg.0.pal", palette);
                    // Geschwindigkeit-Hilfsvariable wird durch VIS metro Slider horizontal überwacht, bei Änderung wird Geschwindigkeit gesetzt.
                    // Intensität-Hilfsvariable wird durch VIS metro Slider horizontal überwacht, bei Änderung wird Effekt-Intensität gesetzt.
                    // Helligkeit-Hilfsvariable wird durch VIS metro Slider horizontal überwacht, bei Änderung wird Helligkeit gesetzt.
                    // On/Off-Hilfsvariable wird durch VIS fancyswitch überwacht, bei Änderung wird An/Aus geschaltet.
                    Das Script ist aber wohl mit der neuesten Version des Adapters überholt, da die entspr. Datenpunkte jetzt über den Adapter direkt gesetzt werden können und meine Hilfs-Datenpunkte nicht mehr notwendig sind.
                    Sollte aber dennoch funktionieren, ich kann es aus o.a. Gründen aber nicht mehr prüfen.
                    Jörg
                      @hollerbachr
                      Hallo Raimund,
                        return result ? {
                        } : null;
                      Jörg
                      DutchmanD
                      DutchmanD
                      Dutchman
                      #238
                      @joergeli sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                      jup ist überflüssig das ist alles im adapter drin
                      wen er bei dir das system überlastet, hast du die neueste version drauf es gab ein memory leak ?
                      Allgemein wuerde ich mich freuen wen sowas gemeldet wird damit man es auch fuer anderen analysieren/beheben kan anstatt Vorschlaghammer Methode :)
                        joergeliJ
                        joergeliJ
                        joergeli
                        #239
                        @Dutchman
                        Ja, ich hatte die neueste Version installiert.
                        Ich selbst hatte ja vorher auf die hohe Speicherauslastung (Memory Leak) aufmerksam gemacht.
                        Wie bereits erwähnt, kann ich aber nicht mit Gewißheit sagen, ob meine ioBroker-Probleme ( hoher avg-load ) vom WLED-Adapter kamen und da ich den Adapter nur mal so zum Ausprobieren installiert hatte, habe ich ihn jetzt halt wieder gelöscht.
                        Jörg
                          @Dutchman
                          Jörg
                          DutchmanD
                          DutchmanD
                          Dutchman
                          #240
                          ah ok, der load mit mem (memory leak) is behoben weiter würde es mich sehr wundern das diese adapter load verursacht wen doch höre ich es gerne :)
                          • TTBerlinT
                            TTBerlinT
                            TTBerlin
                            schrieb am zuletzt editiert von TTBerlin
                            #241
                            ich nutze den Adapter in der Version 0.5.1 vom Github. In einem Blockly-Script rufe ich das Preset 16 auf, ändere die Brightness und speichere das Preset wieder. Auszug:
                            Das funktioniert soweit. Im Log bekomme ich aber folgende Warnmeldung:
                            javascript.0	2020-05-11 12:35:06.020	warn	(9339) at Timer.processTimers (timers.js:223:10)
                            javascript.0	2020-05-11 12:35:06.020	warn	(9339) at listOnTimeout (timers.js:263:5)
                            javascript.0	2020-05-11 12:35:06.019	warn	(9339) at tryOnTimeout (timers.js:300:5)
                            javascript.0	2020-05-11 12:35:06.019	warn	(9339) at ontimeout (timers.js:438:13)
                            javascript.0	2020-05-11 12:35:06.019	warn	(9339) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2015:34)
                            javascript.0	2020-05-11 12:35:06.019	warn	(9339) at Object.<anonymous> (script.js.Cololight-WLED-TEST:13:9)
                            javascript.0	2020-05-11 12:35:06.018	warn	(9339) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1354:20)
                            javascript.0	2020-05-11 12:35:06.012	warn	(9339) You are assigning a number to the state
                             "wled.0.cc50e3e84635.psave" which expects a object.
                             Please fix your code to use a object or change the state type to number. This warning might
                             become an error in future versions
                            Ja, der Datenpunkt ist vom Typ "object" und ich schreibe "number" in den Datenpunkt. Mit welchem Typ muss ich den Wert 16 in den Datenpunkt schreiben?
                            Vielen Dank im Voraus!!
                            iobroker unter Debian Trixiea uf Dell Optiplex 9020 micro
                            Node.js v22.19.0
                            NPM 10.9.3
                            js-controller 7.07
                            JavaScript 8.9.2
                            Admin 7.7.2
                            • W
                              W
                              wohlstandskind2711
                              #242
                              Tagchen,
                              kurze Frage, die Warnmeldungen, an was könnten die liegen?
                                <variables>
                                  <variable type="timeout" id="timeout3">timeout3</variable>
                                  <variable type="timeout" id="timeout2">timeout2</variable>
                                </variables>
                                <block type="on_ext" id="zBkZB8ijuy}8jed3+y8+" x="-437" y="-37">
                                  <value name="OID0">
                                    <shadow type="field_oid" id="tO[d(C?x:r{3EYzS8*|I">
                                      <field name="oid">mihome.0.devices.sensor_motion_aq2_158d00036bbd98.state</field>
                                    </shadow>
                                  </value>
                                  <statement name="STATEMENT">
                                    <block type="controls_if" id="wwvZ)s15f{%;m:==HXFA">
                                      <value name="IF0">
                                        <block type="logic_operation" id="_4}YMQSQ6H[uz1|Lw(Xn">
                                          <field name="OP">AND</field>
                                          <value name="A">
                                            <block type="on_source" id="Y?XmA,;V28H09y;1)gkh">
                                            </block>
                                          </value>
                                          <value name="B">
                                            <block type="time_compare_ex" id="^_fIR)Qlq}h{`-9DpUoo">
                                              <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
                                              <field name="USE_ACTUAL_TIME">TRUE</field>
                                              <field name="OPTION">between</field>
                                              <value name="START_TIME">
                                                <shadow type="text" id="=FU+U_5kf-$n%{gJRbH)">
                                                  <field name="TEXT">19:45</field>
                                                </shadow>
                                              </value>
                                              <value name="END_TIME">
                                                <shadow type="text" id="(E+]CA2n]?H?6#Y1$|?-">
                                                  <field name="TEXT">08:00</field>
                                                </shadow>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <statement name="DO0">
                                        <block type="timeouts_cleartimeout" id="YihiGR+F6WhCE^yaUqWi">
                                          <field name="NAME">timeout3</field>
                                          <next>
                                            <block type="control" id="rfS#FPojQg-yU0e:;dIy">
                                              <field name="OID">wled.0.cc50e3e8493b.seg.0.on</field>
                                              <value name="VALUE">
                                                <block type="logic_boolean" id="REEAcX?9l/:{F0_qO+K3">
                                                </block>
                                              </value>
                                              <next>
                                                <block type="control" id="Y?=TY%#k2W2yloXp65x*">
                                                  <field name="OID">wled.0.cc50e3e8493b.seg.0.fx</field>
                                                    <block type="math_number" id="ZYZyhnBx2@ASCThm#GnN">
                                                      <field name="NUM">3</field>
                                                    </block>
                                                  </value>
                                                  <next>
                                                    <block type="timeouts_settimeout" id="T,.y/6aghV;.@eWE;|b9">
                                                      <field name="NAME">timeout2</field>
                                                      <field name="DELAY">6000</field>
                                                      <field name="UNIT">ms</field>
                                                        <block type="control" id=";gTd,VswrRG6wc=b7+h%">
                                                            <block type="math_number" id=")kZU}V46r.52;Nv~tQJ3">
                                                              <field name="NUM">0</field>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </statement>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                      <value name="IF1">
                                        <block type="on_source" id="YHY~m6oT%%`!hVZq-Lvd">
                                        </block>
                                      </value>
                                      <statement name="DO1">
                                        <block type="timeouts_settimeout" id="X)k@Ge?HDqIF`8.oO)My">
                                          <field name="DELAY">1</field>
                                          <field name="UNIT">min</field>
                                            <block type="control" id="i~T7Y8=JV%VQG|Eu},?X">
                                                <block type="logic_boolean" id="J2MMkOK@[5v48$:e[sab">
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                        </block>
                                      </statement>
                                    </block>
                                  </statement>
                                </block>
                              </xml>![javascript - ioBroker.png](/assets/uploads/files/1591121367468-javascript-iobroker.png)
                              2020-06-02 19:56:48.472 - warn: wled.0 (25234) State attribute definition missing for + lm
                              2020-06-02 19:56:48.479 - warn: wled.0 (25234) State attribute definition missing for + lip
                              2020-06-02 19:56:48.681 - warn: wled.0 (25234) State attribute definition missing for + lor
                              2020-06-02 19:57:19.326 - warn: wled.0 (25234) State attribute definition missing for + lm
                              2020-06-02 19:57:19.332 - warn: wled.0 (25234) State attribute definition missing for + lip
                              2020-06-02 19:57:19.538 - warn: wled.0 (25234) State attribute definition missing for + lor
                              2020-06-02 19:57:50.060 - warn: wled.0 (25234) State attribute definition missing for + lm
                              2020-06-02 19:57:50.068 - warn: wled.0 (25234) State attribute definition missing for + lip
                              2020-06-02 19:57:50.279 - warn: wled.0 (25234) State attribute definition missing for + lor
                              TTBerlinT 1 Antwort Letzte Antwort
                              • W wohlstandskind2711
                                Tagchen,
                                  <variables>
                                  </variables>
                                    <value name="OID0">
                                      </shadow>
                                    </value>
                                        <value name="IF0">
                                            <value name="A">
                                              </block>
                                            </value>
                                            <value name="B">
                                                  </shadow>
                                                </value>
                                                  </shadow>
                                                </value>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                            <next>
                                                  </block>
                                                </value>
                                                <next>
                                                      </block>
                                                    </value>
                                                    <next>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </statement>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </statement>
                                        <value name="IF1">
                                          </block>
                                        </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </statement>
                                          </block>
                                        </statement>
                                      </block>
                                    </statement>
                                  </block>
                                TTBerlinT
                                TTBerlinT
                                TTBerlin
                                #243
                                @wohlstandskind2711 meines Erachtens gibt es dazu schon ein Issue auf github DutchmanNL ist wahrscheinlich noch nicht dazu gekommen, den Adapter zu bearbeiten.
                                Node.js v22.19.0
                                NPM 10.9.3
                                js-controller 7.07
                                JavaScript 8.9.2
                                Admin 7.7.2
                                • Basti97B
                                  Basti97B
                                  Basti97
                                  #244
                                  Weiß einer von euch ob man über Wled und mit dessen Adapter auch zusätzlich weiße LEDs steuern kann. Als Zusatz für die ws2812 LEDs.
                                  Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
                                  • Basti97B Basti97
                                    #245
                                    @Basti97 sollte gehen. Siehe gelb markiertes im Bild.
                                    Basti97B 1 Antwort Letzte Antwort
                                      Basti97B
                                      Basti97B
                                      Basti97
                                      #246
                                      @Beliar_666 Danke für deine Hilfe dann werde ich mich mal an das Projekt Wagen.😀
                                      • Basti97B
                                        Basti97B
                                        Basti97
                                        schrieb am zuletzt editiert von Basti97
                                        #247
                                        Kann man an Wled bzw in den Adapter ein zusätzlichen Kanal noch einfügen? Zum Beispiel für weiße LEds.
                                          Hi Leute,
                                          Da ich mit anderen Baustellen (SourceAnalytix) nicht voran kam brauchte ich mal ein Erfolgserlebnis, daraus ist WLED entstanden und Energie die anderen weiter zu machen :).
                                          WLED - Github Project by @Aircoookie
                                          Was ist WLED : Firmware die es ermöglicht LED-stripes (z.b. ws2812b) an zu steuern.
                                          Ich benutze diese z.b. als deco fur meine Bilder, als Treppenbeleuchtung oder auch Ambi-Light am Fernseher.
                                          Aktuelle Test Version 0.6.5
                                          Veröffentlichungsdatum 04-06-2022
                                          Github Link https://github.com/iobroker-community-adapters/ioBroker.wled
                                          Der adapter ermoeglicht es (fast) alles funktionalitaeten die in WLED integriert sind auch per iobroker. zu steuern.
                                          Dazu gehört :
                                          • Autodetect der devices
                                          • An/Aus
                                          • dimmen
                                          • Farben steuern in RGB (auch per segment unterschiedlich)
                                          • Effekte an/aus (auch per segment unterschiedlich)
                                          Ich würde mich über feedback freuen !
                                          Momentan muss er nog per GitHub link (oder npm i iobroker.wled) installiert werden, innerhalb der naesten Tagen auch per admin.
                                          Sollte die auto discovery nicht gehen, ich werden auch noch manuelles eintragen einbauen siehe dazu github
                                          (issue bitte auch auf GitHub hinterlegen)
                                          S
                                          S
                                          stefande
                                          #248
                                          @Dutchman
                                          Mit der WLED Version 0.10.0 wurde die Api geändert und der Adapter läuft nicht mehr.
                                          Dieses Issue wurde schon mehrfach auf Github gemeldet.
                                          Könntest du dich bitte der Sache mal annehmen?
                                          Danke im Voraus
                                          84.1k
