  4. [neuer Adapter] smartgarden adapter for Gardena smart system
gardena smart systemsmartgarden
1.1k Beiträge 109 Kommentatoren 518.6k Aufrufe 102 Beobachtet
  • JohGreJ JohGre
    Hatte heute wieder ein Problem mit dem Internet :-(
    Hier der Logauszug.
    2020-04-29 09:21:18.512 - error: gardena.0 (25951) Could not retrieve locations.
    2020-04-29 09:21:18.515 - error: gardena.0 (25951) Error retrieving the locations.
    2020-04-29 09:21:18.516 - error: gardena.0 (25951) Could not get device from location.
    2020-04-29 09:23:48.509 - error: gardena.0 (25951) Could not retrieve locations.
    2020-04-29 09:23:48.509 - error: gardena.0 (25951) Error retrieving the locations.
    2020-04-29 09:23:48.520 - error: gardena.0 (25951) Could not get device from location.
    2020-04-29 09:26:18.524 - error: gardena.0 (25951) uncaught exception: gardena_config is not defined
    2020-04-29 09:26:18.525 - error: gardena.0 (25951) ReferenceError: gardena_config is not defined
    at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.gardena/lib/gardenaCloudConnector.js:209:5)
    at listOnTimeout (internal/timers.js:549:17)
    at processTimers (internal/timers.js:492:7)
    2020-04-29 09:26:18.527 - error: gardena.0 (25951) uncaught exception: gardena_config is not defined
    2020-04-29 09:26:18.527 - error: gardena.0 (25951) ReferenceError: gardena_config is not defined
    2020-04-29 09:26:19.047 - error: host.vm-iobroker Caught by controller[0]: ReferenceError: gardena_config is not defined
    2020-04-29 09:26:19.049 - error: host.vm-iobroker Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.gardena/lib/gardenaCloudConnector.js:209:5)
    2020-04-29 09:26:19.049 - error: host.vm-iobroker Caught by controller[0]: at listOnTimeout (internal/timers.js:549:17)
    2020-04-29 09:26:19.050 - error: host.vm-iobroker Caught by controller[0]: at processTimers (internal/timers.js:492:7)
    2020-04-29 09:26:19.050 - error: host.vm-iobroker Caught by controller[1]: ReferenceError: gardena_config is not defined
    2020-04-29 09:26:19.050 - error: host.vm-iobroker Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.gardena/lib/gardenaCloudConnector.js:209:5)
    2020-04-29 09:26:19.050 - error: host.vm-iobroker Caught by controller[1]: at listOnTimeout (internal/timers.js:549:17)
    2020-04-29 09:26:19.050 - error: host.vm-iobroker Caught by controller[1]: at processTimers (internal/timers.js:492:7)
    --Neustart Adapter
    2020-04-29 09:26:19.051 - info: host.vm-iobroker instance system.adapter.gardena.0 terminated with code 0 (NO_ERROR)
    2020-04-29 09:26:19.051 - info: host.vm-iobroker Restart adapter system.adapter.gardena.0 because enabled
    2020-04-29 09:26:29.952 - info: host.vm-iobroker instance system.adapter.gardena.0 started with pid 28050
    2020-04-29 09:26:46.570 - info: host.vm-iobroker stopInstance system.adapter.smartgarden.0 (force=false, process=true)
    2020-04-29 09:26:46.572 - info: host.vm-iobroker stopInstance system.adapter.smartgarden.0 send kill signal
    2020-04-29 09:26:47.093 - info: host.vm-iobroker instance system.adapter.smartgarden.0 terminated with code 156 (156)
    2020-04-29 09:26:49.088 - info: host.vm-iobroker instance system.adapter.smartgarden.0 started with pid 28140
    2020-04-29 09:26:52.598 - info: javascript.1 (10798) script.js.Energie.SmartGardenState: SmartGarden: ACTIVITY_VALUE: PARKED_PARK_SELECTED
    jpgorganizerJ
    jpgorganizerJ
    jpgorganizer
    #299
    @JohGre sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
    werde ich mir ansehen, aber eins nach dem anderen. Für mich hat das niedrige Prio
    jpgorganizer
    smartgarden Adapter für GARDENA smart system
    JohGreJ 1 Antwort Letzte Antwort
    • jpgorganizerJ jpgorganizer
      jpgorganizer
      JohGreJ
      JohGreJ
      JohGre
      #300
      @jpgorganizer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
      Für mich auch, weiß mir ja zu helfen ;-)
      nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
      jpgorganizerJ 1 Antwort Letzte Antwort
      • JohGreJ JohGre
        jpgorganizerJ
        jpgorganizerJ
        jpgorganizer
        #301
        @JohGre
        https://github.com/jpgorganizer/ioBroker.smartgarden/issues/9
        VG jpgorganizer
          @muckel sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
          2.) Händisch einen Haken setzen. Gardena lässt die Ventile leider nur für eine bestimmte Zeit abschalten, dann kommt die Automatik wieder und bewässert. Ventil abklemmen ist momentan "SmartGardena"
          hmm, da hab ich eine Idee --- erinnere mich daran, wenn ich das "keine Bewässerung wenn gemäht wird" veröffentlicht habe.
          VG jpgorganizer
          jpgorganizerJ
          jpgorganizerJ
          jpgorganizer
          #302
          VG jpgorganizer
          achso, ich habe dafür übrigens banale Kugelhähne in jeder Leitung - sicher ist sicher :-)
          Grüße jpgorganizer
            @JohGre
            VG jpgorganizer
            JohGreJ
            JohGreJ
            JohGre
            #303
              VG jpgorganizer
              Grüße jpgorganizer
              M
              M
              muckel
              #304
              VG jpgorganizer
              Grüße jpgorganizer
              Da hast schon recht, aber ich hab den Platz nicht für zusätzliche Kugelhähne.
              ... und wenn Oma im Garten Unkraut jätet, muss schon mal eine Leitung dran glauben. :-)
              Im Prinzip müsste der Adapter nur kontrollieren, ob wieder auf Automatik geschaltet wird und dann sofort wieder auf PAUSE stellen. 🎓
              LG Erich
                ich habe soeben eine Version 0.5.0 des Adapters in github (https://github.com/jpgorganizer/ioBroker.smartgarden) und npm eingestellt.
                Die Version bietet nun:
                • MOWER: forecast for remaining charging time and remaining mowing time
                  integrated
                  Beschreibung im readme.
                  Bitte einfach mal ausprobieren. Bin gespannt, was Ihr berichtet. Ich habe festgestellt, dass
                  mein Mäher durchaus seltsame Dinge tut. Ich dachte zuerst, das liegt an meiner Implementierung,
                  weshalb ich noch weitere Tests durchgeführt habe und es somit länger als geplant gedauert hat,
                  bis ich es hier eingestellt habe.
                • IMPORTANT CHANGE for existing users: the id for LOCATION, all
                  DEVICE's and all SERVICE's has changed due to support of History adapter.
                  (History adapter cannot handle id's with % (percent) character within id's,
                  although the % is not forbidden in id's in ioBroker),
                  e.g. Issue 8.
                  So you must delete all states of the adapter instance to
                  install this release and please check your application carefully for
                  necessary adjustments regarding the change of the id names.
                  Mit dieser Änderung habe ich lange gerungen. Aber ich sehe keine andere Möglichkeit,
                  damit man den History-Adapter mit den Ventilen (VALVE) nutzen kann. Das Problem ist ein
                  %-Zeichen in der Id. Das %-Zeichen habe ich mir nicht ausgedacht, sondern es kommt daher,
                  dass in der Id, die von Gardena kommt ein Doppelpunkt enthalten ist, der mit Bindings
                  in VIS Probleme macht. Deshalb wird die Id im Adapter codiert, wodurch ein %-Zeichen
                  eingefügt wird, was nun mit dem History-Adapter wiederum Probleme bereitet.
                  Nun wurde die Codierung so angepasst, dass (hoffentlich) nur noch unkritische Zeichen in der Id
                  enthalten sind.
                  Falls es jemanden interessiert, hier ein Vergleich einer Id
                  Die Leerzeichen in der alten Id muss man sich wegdenken, aber dann sieht man den Unterschied
                  besser.
                  Alt: smartgarden.0.LOCATION_12345678-  1234-  1234-  1234-  123456789abc.DEVICE_12345678-  1234-  1234-  1234-  123456789abc.SERVICE_VALVE_12345678-  1234-  1234-  1234-  123456789abc%3A1
                  Neu: smartgarden.0.LOCATION_12345678-2D1234-2D1234-2D1234-2D123456789abc.DEVICE_12345678-2D1234-2D1234-2D1234-2D123456789abc.SERVICE_VALVE_12345678-2D1234-2D1234-2D1234-2D123456789abc-3A1
                • devices Water Control and Smart Pump tested (many thanks to user
                  gammler2003 and xengosam at
                  ioBroker Forum for testing)
                • some code rework and improvement of documentation
                • dependency corrected, important for js-controller v3
                • dependency corrected, important for js-controller v3,
                  e.g. Issue 7
                  Bitte diesen Punkt testen! Ich habe keine
                  js-c3 Plattform, somit ist dies von mir ungetestet. Bitte Rückmeldung geben.
                  @gammler2003 and @xengosam at
                • adapter now available at npm
                jpgorganizer
                T
                T
                tinkertom
                #305
                @jpgorganizer Bei Nutzung der forecast-Funktion sagt mir mein log: "
                (20456) forecast: .batteryLevel_value but no mower" und legt also auch den DP nicht an. Kurz vorher kommt aber die Meldung: "(20456) parseMessage: MOWER found". Passt das irgendwie zusammen? Alle anderen Werte werden korrekt dargestellt. Insgesamt aber tolle Arbeit, die vielen Nutzern hilft. Danke dafür!
                • T tinkertom
                  jpgorganizerJ
                  jpgorganizerJ
                  jpgorganizer
                  schrieb am zuletzt editiert von jpgorganizer
                  #306
                  @tinkertom sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                  Ich fass mal zusammen, was ich verstanden habe, korrigiere mich bitte falls falsch:
                  • du hast einen Mäher
                  • die Forecastwerte werden auch angezeigt
                  • aber im Log stehen Angaben, die widersprüchlich sind
                  Frage:
                  hast du ein anderes batteriebetriebenes Gerät? Sensor, WaterControl ? Wenn ja welche?
                  Edit: ich habe ein paar Worte durchgestrichen, weil vmtl. nicht relevant. Und eine Frage ergänzt.
                  VG jpgorganizer
                  • Uli977U
                    Uli977U
                    Uli977
                    #307
                    Hallo!
                    Ich bekomme irgendwie keine Verbindung zustande.
                    Kann mir jemand helfen?
                    Danke & Gruß!
                    • Uli977U Uli977
                      Hallo!
                      Danke & Gruß!
                      dslraserD
                      dslraserD
                      dslraser
                      #308
                      @Uli977
                      403 deutet auf falsche Zugangsdaten hin.
                      Sicher das Du die richtigen Zugangsdaten, so wie in der App angegeben hast ?
                      Uli977U jpgorganizerJ 2 Antworten Letzte Antwort
                      • dslraserD dslraser
                        @Uli977
                        Uli977U
                        Uli977U
                        Uli977
                        #309
                        @dslraser
                        Ja.
                        • Uli977U Uli977
                          @dslraser
                          Ja.
                          dslraserD
                          dslraserD
                          dslraser
                          #310
                          @Uli977
                          hast Du im Adapter mal die Logstufe auf 3 gestellt (unter Verschiedenes), dann sollte mehr im Log stehen.
                          Uli977U 1 Antwort Letzte Antwort
                            @Uli977
                            Uli977U
                            Uli977U
                            Uli977
                            #311
                            @dslraser
                              Frage:
                              VG jpgorganizer
                              T
                              T
                              tinkertom
                              schrieb am zuletzt editiert von tinkertom
                              #312
                              @jpgorganizer Ich fass mal zusammen, was ich verstanden habe, korrigiere mich bitte falls falsch:
                              du hast einen Mäher
                              Frage:
                              Ja. Ich habe ein "Smart Water Control", den Bewässerungscomputer. Und ja - ich habe (nur) einen Smart Sileno Life-Mäher. In meinen Einstellungen habe ich die Verwendung der forecast-Anzeige aktiviert. Es werden aber keine Werte in den vorhandenen Datenpunkten unter Objekte angezeigt.
                              • Uli977U Uli977
                                @dslraser
                                dslraserD
                                dslraserD
                                dslraser
                                #313
                                @Uli977
                                das muß sich dann @jpgorganizer mal ansehen. (token)
                                  @Uli977
                                  Uli977U
                                  Uli977U
                                  Uli977
                                  schrieb am zuletzt editiert von Uli977
                                  #314
                                  @dslraser ok....Danke
                                    @Uli977
                                    jpgorganizerJ
                                    jpgorganizerJ
                                    jpgorganizer
                                    #315
                                    @dslraser sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                    da schließe ich mich an. beim ersten Connect werden Username und Passwort und API Key übergeben. Und es kommt dieser Fehler zurück.
                                    Username und Passwort und API Key prüfen!
                                    VG jpgorganizer
                                    • T tinkertom
                                      du hast einen Mäher
                                      Frage:
                                      jpgorganizerJ
                                      jpgorganizerJ
                                      jpgorganizer
                                      #316
                                      gar keine Werte??? Jetzt bin ich verwirrt. Was geht jetzt und was geht jetzt nicht?
                                      Bitte Fehler nochmals genau beschreiben.
                                      Gruß jpgorganizer
                                        VG jpgorganizer
                                        Uli977U
                                        Uli977U
                                        Uli977
                                        #317
                                        @jpgorganizer
                                        bekomme es nicht hin....
                                        • Uli977U Uli977
                                          @jpgorganizer
                                          jpgorganizerJ
                                          jpgorganizerJ
                                          jpgorganizer
                                          #318
                                          @Uli977 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                          @jpgorganizer
                                          wenn die o.a. daten stimmen, dann kann ich auch nicht helfen.
                                          Evtl. liegt es am Gardena Service - es gibt einen anderen User der immer "Bad Gateway" bekommt und das ist ein Fehler den Gardena sogar zugibt - soll jetzt keine Ausrede sein oder Problem wegschieben, aber ich kann es nicht ändern.
                                          Öfter mal probieren, Gardena will ein Update rausbringen
                                          VG jpgorganizer
                                          33.2k
                                          84.3k
