  4. Adapter: ebus
Adapter: ebus
ebus adapter
713 Beiträge 73 Kommentatoren 386.8k Aufrufe 60 Beobachtet
  • M
    M
    markus397
    #128
    Also das ist in der tat sehr wenig.
    Markus
    • KnallochseK Knallochse
      @markus397 Ja, hatte mir mir die json Daten im Browser (ip:8890/data) angeschaut.
      Kommt halt durch die fehlende Zuordnung der dazugehörigen *.csv Daten.
      So sehen die Json Daten aus:
       "broadcast": {
        "messages": {
         "datetime": {
          "name": "datetime",
          "passive": true,
          "write": false,
          "lastup": 1578671548,
          "zz": 254,
          "fields": {
           "outsidetemp": {"value": null},
           "time": {"value": "17:03:10"},
           "date": {"value": "10.01.2020"}
         "error": {
          "name": "error",
          "passive": true,
          "write": false,
          "lastup": 1578671358,
          "zz": 254,
          "fields": {
           "error": {"value": "E000 17:00"}
         "id-u": {
          "name": "id",
          "passive": true,
          "write": false,
          "lastup": 1578671238,
          "zz": 254,
          "fields": {
           "manufacturer": {"value": "Kromschröder"},
           "id": {"value": "  "},
           "software": {"value": "0204"},
           "hardware": {"value": null}
         "signoflife": {
          "name": "signoflife",
          "passive": true,
          "write": false,
          "lastup": 0
       "scan.04": {
        "messages": {
          "name": "",
          "passive": false,
          "write": false,
          "lastup": 0
       "scan.08": {
        "messages": {
          "name": "",
          "passive": false,
          "write": false,
          "lastup": 0
       "scan.15": {
        "messages": {
          "name": "",
          "passive": false,
          "write": false,
          "lastup": 0
       "scan.1c": {
        "messages": {
          "name": "",
          "passive": false,
          "write": false,
          "lastup": 0
       "scan.35": {
        "messages": {
          "name": "",
          "passive": false,
          "write": false,
          "lastup": 0
       "scan.3c": {
        "messages": {
          "name": "",
          "passive": false,
          "write": false,
          "lastup": 1578647958,
          "zz": 60,
          "fields": {
           "MF": {"value": "Kromschroeder"},
           "ID": {"value": "  "},
           "SW": {"value": "0208"},
           "HW": {"value": null}
       "scan.51": {
        "messages": {
          "name": "",
          "passive": false,
          "write": false,
          "lastup": 0
       "scan.54": {
        "messages": {
          "name": "",
          "passive": false,
          "write": false,
          "lastup": 0
       "scan.75": {
        "messages": {
          "name": "",
          "passive": false,
          "write": false,
          "lastup": 1578648678,
          "zz": 117,
          "fields": {
       "scan.76": {
        "messages": {
          "name": "",
          "passive": false,
          "write": false,
          "lastup": 0
       "scan.f5": {
        "messages": {
          "name": "",
          "passive": false,
          "write": false,
          "lastup": 0
       "scan.f6": {
        "messages": {
          "name": "",
          "passive": false,
          "write": false,
          "lastup": 0
       "global": {
        "version": "3.4.v3.4-8-g177568c",
        "updatecheck": "revision v3.4 available",
        "signal": true,
        "symbolrate": 35,
        "maxsymbolrate": 142,
        "reconnects": 0,
        "masters": 10,
        "messages": 23,
      Rene_HMR
      Rene_HMR
      Rene_HM
      #129
      @Knallochse für mich sieht das so aus, als ob die csv's zur ebusd-Konfiguration nicht zum Gerät passen...
      KnallochseK 1 Antwort Letzte Antwort
      • Rene_HMR Rene_HM
        KnallochseK
        KnallochseK
        Knallochse
        #130
        @Rene_HM kann ich daran was ändern. Ich bin mit meiner eigenen Suche nicht weiter vorangekommen. Ich hatte auch versucht, die csv Dateien herunterzuladen und aus dem Raspi zu laden. Dabei stützt aber der ebusd service ab.
        Rene_HMR 1 Antwort Letzte Antwort
          Rene_HMR
          Rene_HMR
          Rene_HM
          #131
          @Knallochse Ich würde direkt auf den ebusd von john30 verweisen:
          https://github.com/john30/ebusd/wiki
          bzw.
          https://github.com/john30/ebusd-configuration
          Ich selbst habe zu wenig Erfahrung mit den csv...
          • S
            S
            Sandmanyz
            #132
            Ich komme gerade nicht weiter. Entweder funktioniert das was ich möchte nicht oder ich habe ein Brett vorm Kopf 🙄
            Der EBUS-Adapter läuft prima und ich habe 100derte Werte in der Objektübersicht, welche ich teilweise über VIS darstelle. Bis hier hin alles schick.
            Nun gibt es bei meiner Vaillant Therme u.a. den Modus "Stoßlüften", welchen ich gelegentlich nutze. Nur wie kann ich den Modus über den Ebus realisieren? Um herauszufinden was sich ändert, habe ich die Werte vor dem Aktivieren und nach dem Deaktivieren des Modus Stoßlüften verglichen. Prinzipiell würde ich vermuten, dass die Sollvorlauftemperatur (flowtempdesired) auf 0 Grad gesetzt wird. Mit "disablehc" wird dann wahrscheinlich der Heizkreis 1 aktiviert oder deaktiviert.
            Stoßlüften inaktiv
            ebus.0.bai.messages.SetMode.fields.flowtempdesired.value = 30.0
            ebus.0.bai.messages.SetMode.fields.disablehc.value = 0
            Stoßlüften aktiv
            ebus.0.bai.messages.SetMode.fields.flowtempdesired.value = 0.0
            ebus.0.bai.messages.SetMode.fields.disablehc.value = 1
            Ist es iiiirgendwie möglich das Stoßlüften zu aktivieren?
            • S Sandmanyz
              Stoßlüften inaktiv
              Stoßlüften aktiv
              M
              M
              mameier1234
              #133
              @Sandmanyz melde dich mal mit telnet auf dem ebusd an...
              da gibt es dann die read (das macht der iobroker adapter) und vor allem auch write kommandos..
              Nicht alle Parameter sind beschreibbar.. ausprobieren...
              find -c bai dann kommen alle parameter von bai ... und dann versuchen diese gezielt mit write -c bai "paramter" 1 (Beispiel !!!) zu beschreiben..
              Wenn Du dann den richtigen Befehl (write) gefunden hast, dann kannst Du den per Script in den Datenpunkt cmd vom ioBroker ebus Adapter schreiben.. der wird einmal pro Minute an den ebusd geschickt..
              Grüße,
              Martin
              • M mameier1234
                S
                S
                Sandmanyz
                #134
                @mameier1234
                Ich habe die Werte die ich schreiben möchte ja prinzipiell gefunden....
                Also habe ich....
                read -c bai SetMode
                ...eingegeben und dieses Ergebnis erhalten...
                auto;0.0;-;-;1;0;0;0;0;0  /Stoßlüften aktiv
                auto;27.5;-;-;0;0;0;0;0;0 /Stoßlüften nicht aktiv
                Da Stoßlüften gerade nicht aktiv war, habe ich...
                write -c bai SetMode auto;0.0;-;-;1;0;0;0;0;0
                ...ausgeführt. Das Ergebnis ist...
                ERR: element not found
                • S Sandmanyz
                  @mameier1234
                  Also habe ich....
                  read -c bai SetMode
                  M
                  M
                  mameier1234
                  #135
                  @Sandmanyz ich sag ja... die richtigen Werte finden... ist irgendwie eine Sysiphus-Arbeit..
                  ich mache das mit
                  write -c mc setmode auto
                  oder
                  write -c mc setmode off
                  ein read -c mc setmode bringt auch:
                  read -c mc Status
                  0;off;49.19;23
                  Rausbekommen habe ich das, indem ich im telnet "listen" eingeschaltet habe.. Da sieht man dann die Meldungen die kommen... Dann eben an der Heizung direkt den entsprechenden Wert geändert und dann kam z.B. die Meldung..
                  mc Status set to auto
                  Um zum Beispiel von Winter auf Sommerbetrieb umzuschalten...
                  Grüße,
                  Martin
                  • MassiveAttackM
                    MassiveAttackM
                    MassiveAttack
                    #136
                    hallo,
                    ich habe heute den ebus adapter (esera) installiert, am iobroker läuft der ebus adapter. wenn ich im browser ip:port/data eingebe, bekomme ich nur verschlüsselte daten. jemand eine ahnung warum?
                    nur das ich das richtig verstehe, ebus koppler an die vaillant anhängen, und mit dem ebus adapter die werte empfangen. oder brauche ich noch einen extra ebusd??
                    • MassiveAttackM
                      MassiveAttackM
                      MassiveAttack
                      #137
                      noch eine frage, woher bekomme ich die liste der datenpunkte?
                      • MassiveAttackM
                        MassiveAttackM
                        MassiveAttack
                        #138
                        ebus.0 2020-04-17 21:40:01.885 error (2453) exception in ebusd_ReceiveData [TypeError: Cannot read property 'statusCode' of undefined]
                        sind die daten verschlüsselt? oder was bedeutet der error
                        • MassiveAttackM MassiveAttack
                          hallo,
                          S
                          S
                          Sandmanyz
                          schrieb am zuletzt editiert von Sandmanyz
                          #139
                          @MassiveAttack sagte in Adapter: ebus:
                          hallo,
                          Du siehst jetzt vermutlich nur die Rohdaten auf dem Bus.
                          Du benötigst den ebus Daemon weil der die Daten vom Bus in, für dich lesbare, Daten umwandelt.
                          MassiveAttackM 1 Antwort Letzte Antwort
                          • S Sandmanyz
                            hallo,
                            MassiveAttackM
                            MassiveAttackM
                            MassiveAttack
                            #140
                            @Sandmanyz
                            ich verstehe, danke!
                            hab mir mal den ebusd von john als docker installiert. was muss ich da jetzt noch konfigurieren?
                            • MassiveAttackM
                              MassiveAttackM
                              MassiveAttack
                              #141
                              kann mir da bitte jemand helfen? ich komme nicht weiter...
                              am ebus koppler habe ich nun eingestellt, tcp server mit 192.168.0.65:8888
                              ebusd hat 192.168.0.87 (default port ist 8888)
                              ebus client: ziel ip ist die vom ebusd (87) oder? target http port = 8888 /telnet port auch?
                              wie bekomme ich die vaillant konfig auf den ebusd? muss ich da noch was konfigurieren? bitte um hilfe für newbies :)
                                M
                                M
                                mameier1234
                                #142
                                @MassiveAttack Zeig mal, wie du den ebusd aurufts.. komplette config-zeile !
                                http Port ist was ganz anderes als der Telnet Port.. Muss beim ebusd konfiguriert werden...
                                bei mir steht in der /etc/default/ebusd das hier drin:
                                EBUSD_OPTS="--configpath=/etc/ebusd -d /dev/ttyebus -p 8888  --latency=0 --recei
                                vetimeout=100000 -l /var/log/ebusd.log  --scanconfig=full  --httpport=8889 --htm
                                lpath=/var/www/"
                                Also Port 8888, http-Port = 8889
                                Im Ebus Adapter:
                                Grüße,
                                Martin
                                • M mameier1234
                                  lpath=/var/www/"
                                  Im Ebus Adapter:
                                  MassiveAttackM
                                  MassiveAttackM
                                  MassiveAttack
                                  #143
                                  @mameier1234
                                  ich hab den ebusd grad mal als docker installiert, ohne irgendeine config zu ändern. um ehrlich zu sein, hab ich mich noch nicht eingelesen bzw auf die schnelle nix gefunden.
                                  wie komme ich zu dieser ausgabe? was muss ich alles konfigurieren, und wie?
                                  möchte dann damit meine vaillant vwf 87/4 steuern, wie bekomme ich die datenpunktliste?
                                    @mameier1234
                                    M
                                    M
                                    mameier1234
                                    #144
                                    @MassiveAttack Sorry, das ich das so hart sage... aber ohne einlesen geht es nicht. Das Thema ist komplex und es lohnt sich im Thread vorne anzufangen.
                                    Grüße,
                                    Martin
                                    • MassiveAttackM
                                      MassiveAttackM
                                      MassiveAttack
                                      #145
                                      bei mir ist die config leer. ich brauch ja nur mehr die richtige config und die DP-liste, wäre nett wenn du mir dabei behilflich sein könntest
                                        M
                                        M
                                        mameier1234
                                        #146
                                        @MassiveAttack die datenpunkte kommen von alleine, wenn der ebusd sauber läuft. Da hab ich dir meine config geschickt....im tread wird das sehr ausführlich diskutiert. Und die config hängt ja auch von deiner Hardware ab...
                                        Grüße,
                                        Martin
                                        MassiveAttackM 2 Antworten Letzte Antwort
                                        • M mameier1234
                                          MassiveAttackM
                                          MassiveAttackM
                                          MassiveAttack
                                          #147
                                          @mameier1234
                                          ok, ich schaue mir das morgen mal genauer an. danke erstmal für die hilfe, werde mich gegebenfalls nochmals an euch wenden ;)
                                          84.2k
