  4. JavaScript
  5. Sonoff Geräte als HTML Tabelle - Vis
javascriptmonitoringtemplate
632 Beiträge 34 Kommentatoren 251.2k Aufrufe 39 Beobachtet
  • liv-in-skyL liv-in-sky
    @Meister-Mopper die sollten einfach mit erscheinen im gosund block
    Meister MopperM
    Meister MopperM
    Meister Mopper
    #280
    @liv-in-sky bzw. das:
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Timer.processTimers (timers.js:223:10)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at listOnTimeout (timers.js:263:5)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at tryOnTimeout (timers.js:300:5)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at ontimeout (timers.js:436:11)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1319:34)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Object.<anonymous> (script.js.java.sonstige.Sonoff_Test:2727:2)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at writeHTML (script.js.java.sonstige.Sonoff_Test:448:30)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at script.js.java.sonstige.Sonoff_Test:473:16
    javascript.0	2020-04-01 15:51:00.005	warn	(10408) getState "sonoff.0.kvm-switch.ENERGY_Today" not found (3)
    Proxmox und HA ...
      @liv-in-sky hab die Zeilen getauscht, allerdings bekomme ich das:
      avascript.0	2020-04-01 15:50:48.552	error	(10408) at Script.runInContext (vm.js:133:20)
      javascript.0	2020-04-01 15:50:48.552	error	(10408) at script.js.java.sonstige.Sonoff_Test:2733:2
      javascript.0	2020-04-01 15:50:48.552	error	(10408) at writeHTML (script.js.java.sonstige.Sonoff_Test:448:30)
      javascript.0	2020-04-01 15:50:48.552	error	(10408) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
      javascript.0	2020-04-01 15:50:48.552	error	(10408) at script.js.java.sonstige.Sonoff_Test:473:70
      javascript.0	2020-04-01 15:50:48.552	error	(10408) TypeError: Cannot read property 'toString' of null
      javascript.0	2020-04-01 15:50:48.552	error	(10408) ^
      javascript.0	2020-04-01 15:50:48.552	error	(10408) val6=getState(id.replace("INFO.Module","ENERGY_Today")).val.toString();
      javascript.0	2020-04-01 15:50:48.552	error	(10408) script.js.java.sonstige.Sonoff_Test: script.js.java.sonstige.Sonoff_Test:473
      javascript.0	2020-04-01 15:50:48.552	warn	(10408) at script.js.java.sonstige.Sonoff_Test:2733:2
      javascript.0	2020-04-01 15:50:48.552	warn	(10408) at writeHTML (script.js.java.sonstige.Sonoff_Test:448:30)
      javascript.0	2020-04-01 15:50:48.552	warn	(10408) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
      javascript.0	2020-04-01 15:50:48.551	warn	(10408) at script.js.java.sonstige.Sonoff_Test:473:16
      javascript.0	2020-04-01 15:50:48.551	warn	(10408) getState "sonoff.0.kvm-switch.ENERGY_Today" not found (3)
      liv-in-skyL
      liv-in-skyL
      #281
      @Meister-Mopper hbe es auch gerade gesehen - die haben keinen energy wert
      da müssen wir uns etwas anderes überlegen - vielleicht doch eine eigene kategorie
        liv-in-skyL
        liv-in-skyL
        #282
        @Meister-Mopper
        was würdest du dann als anzeige gerne sehen - energy fällt aus - was sind den die wichtigen werte - temperatur oder so
        aber bedenke bitte - die tabelle wird nur getriggert beim umschalten des POWER dp's - daher werden die werte nicht immer aktuell sein, da diese vom schedule abhängen
          liv-in-skyL
          liv-in-skyL
          #283
          @Meister-Mopper
          ich meine das hier
            @Meister-Mopper
            ich meine das hier
            Meister MopperM
            Meister MopperM
            Meister Mopper
            #284
            @liv-in-sky Das passt schon, die aktuelle Temperatur ist nicht kriegsentscheidend.
            Proxmox und HA ...
            • liv-in-skyL
              liv-in-skyL
              #285
              @Meister-Mopper
              der erste wert der beiden könnte die uptime sein (ist bei anderen auch so) und der zweite - den darfst du entscheiden - die ANALOG-Temperature ?
                liv-in-skyL
                liv-in-skyL
                #286
                @Meister-Mopper
                so ?
                  @Meister-Mopper
                  so ?
                  Meister MopperM
                  Meister MopperM
                  Meister Mopper
                  #287
                  @liv-in-sky 1.000 °C - wie geil, dann kann ich ja einen Hochofen anmelden ;-)😊
                  Proxmox und HA ...
                    liv-in-skyL
                    liv-in-skyL
                    #288
                    @Meister-Mopper mir ist nix besseres eingefallen - muss ja die states zum test schreiben , damit keine fehler kommen :-)
                    das neue script ist im ersten post - du mußt dann twoNice=true setzen oder
                    du kannst die ganzen settings (von zeile 3 bis bis zeile 113) wieder reinkopieren aber musst dann in zeile 37 das einsetzen - sonst fehlt eine variablen definition
                    Meister MopperM 2 Antworten Letzte Antwort
                      Meister MopperM
                      Meister MopperM
                      Meister Mopper
                      #289
                      @liv-in-sky Super, das ist echt ein Wahnsinn, was Du so umsetzt.
                      Recht herzlichen Dank!
                      Proxmox und HA ...
                        Meister MopperM
                        Meister MopperM
                        Meister Mopper
                        #290
                        @liv-in-sky Irgendetwas stimmt nicht, habe das Script wie beschrieben angepasst, bekomme aber Fehler:
                        javascript.0	2020-04-01 17:05:24.192	error	(1081) at Script.runInContext (vm.js:133:20)
                        javascript.0	2020-04-01 17:05:24.192	error	(1081) at script.js.java.sonstige.Sonoff:2797:2
                        javascript.0	2020-04-01 17:05:24.192	error	(1081) at writeHTML (script.js.java.sonstige.Sonoff:1301:3)
                        javascript.0	2020-04-01 17:05:24.192	error	(1081) ReferenceError: mini is not defined
                        javascript.0	2020-04-01 17:05:24.192	error	(1081) ^
                        javascript.0	2020-04-01 17:05:24.192	error	(1081) if (mini){
                        javascript.0	2020-04-01 17:05:24.192	error	(1081) script.js.java.sonstige.Sonoff: script.js.java.sonstige.Sonoff:1301
                        Proxmox und HA ...
                          liv-in-skyL
                          liv-in-skyL
                          #291
                          @Meister-Mopper normalerweise ist diese mini abfrage an einer anderen stelle - irgendwie hast du beim kopieren einen "wurm" drin
                          falls du lauter leerzeilen im script hast - nutze den chrome browser und nicht firefox beim kopieren des scriptes aus dem forum
                          • Stephan SchleichS
                            Stephan SchleichS
                            Stephan Schleich
                            schrieb am zuletzt editiert von Stephan Schleich
                            #292
                            Ich bekomm folgenden Fehler, weiß jemand was dazu?
                            • Stephan SchleichS Stephan Schleich
                              liv-in-skyL
                              liv-in-skyL
                              #293
                              @Stephan-Schleich könnte evtl ein fehler im generic teil sein - kannst du mal den generic auf false setzen und das script wieder laufen lassen ?
                              Stephan SchleichS 1 Antwort Letzte Antwort
                                Stephan SchleichS
                                Stephan SchleichS
                                Stephan Schleich
                                #294
                                @liv-in-sky du hattest recht, dann läuft's, ist das ein Fehler bei mir oder im Script?
                                  liv-in-skyL
                                  liv-in-skyL
                                  #295
                                  @Stephan-Schleich weiß ich nicht - wir könnten anydesk machen und direkt bei dir schauen oder du sendest mir einen json-export deines sonoff.0 ordners - was dir lieber ist
                                    Stephan SchleichS
                                    Stephan SchleichS
                                    Stephan Schleich
                                    #296
                                    @liv-in-sky sagte in Sonoff Geräte als HTML Tabelle - Vis - Iqontrol:
                                    anydesk
                                    hast pm :)
                                      anydesk
                                      hast pm :)
                                      liv-in-skyL
                                      liv-in-skyL
                                      #297
                                      @Stephan-Schleich ich schreib dir im chat
                                      • M
                                        M
                                        MyMeyer
                                        #298
                                        @liv-in-sky Hi habe folgenden Gosund hinzugefügt. In Info steht: SP111 v1.1
                                        Tasmota Version 8.1.0.2
                                        MyMeyer
                                        Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
                                        HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
                                        • M MyMeyer
                                          liv-in-skyL
                                          liv-in-skyL
                                          #299
                                          @MyMeyer in zeile 294 ?
                                          getState(id).val.includes("Gosund SP111 v1.1")
                                          84.2k
