  4. JavaScript
  5. Sonoff Geräte als HTML Tabelle - Vis
    6.6k
javascriptmonitoringtemplate
632 Beiträge 34 Kommentatoren 202.5k Aufrufe 39 Beobachtet
    @liv-in-sky bzw. das:
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Timer.processTimers (timers.js:223:10)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at listOnTimeout (timers.js:263:5)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at tryOnTimeout (timers.js:300:5)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at ontimeout (timers.js:436:11)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1319:34)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Object.<anonymous> (script.js.java.sonstige.Sonoff_Test:2727:2)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at writeHTML (script.js.java.sonstige.Sonoff_Test:448:30)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at script.js.java.sonstige.Sonoff_Test:473:16
    javascript.0	2020-04-01 15:51:00.005	warn	(10408) getState "sonoff.0.kvm-switch.ENERGY_Today" not found (3)
    liv-in-skyL Offline
    liv-in-skyL Offline
    #282
    @Meister-Mopper
    was würdest du dann als anzeige gerne sehen - energy fällt aus - was sind den die wichtigen werte - temperatur oder so
    aber bedenke bitte - die tabelle wird nur getriggert beim umschalten des POWER dp's - daher werden die werte nicht immer aktuell sein, da diese vom schedule abhängen
      liv-in-skyL Offline
      liv-in-skyL Offline
      #283
      @Meister-Mopper
      ich meine das hier
      • liv-in-skyL liv-in-sky
        @Meister-Mopper
        ich meine das hier
        Meister MopperM Offline
        Meister Mopper
        #284
        @liv-in-sky Das passt schon, die aktuelle Temperatur ist nicht kriegsentscheidend.
        Proxmox und HA ...
        • liv-in-skyL Offline
          liv-in-skyL Offline
          #285
          @Meister-Mopper
          der erste wert der beiden könnte die uptime sein (ist bei anderen auch so) und der zweite - den darfst du entscheiden - die ANALOG-Temperature ?
            liv-in-skyL Offline
            liv-in-skyL Offline
            #286
            @Meister-Mopper
            so ?
              @Meister-Mopper
              so ?
              Meister Mopper
              #287
              @liv-in-sky 1.000 °C - wie geil, dann kann ich ja einen Hochofen anmelden ;-)😊
              Proxmox und HA ...
                liv-in-skyL Offline
                liv-in-skyL Offline
                #288
                @Meister-Mopper mir ist nix besseres eingefallen - muss ja die states zum test schreiben , damit keine fehler kommen :-)
                das neue script ist im ersten post - du mußt dann twoNice=true setzen oder
                du kannst die ganzen settings (von zeile 3 bis bis zeile 113) wieder reinkopieren aber musst dann in zeile 37 das einsetzen - sonst fehlt eine variablen definition
                Meister MopperM 2 Antworten Letzte Antwort
                  Meister Mopper
                  #289
                  @liv-in-sky Super, das ist echt ein Wahnsinn, was Du so umsetzt.
                  Recht herzlichen Dank!
                  Proxmox und HA ...
                    Meister Mopper
                    #290
                    @liv-in-sky Irgendetwas stimmt nicht, habe das Script wie beschrieben angepasst, bekomme aber Fehler:
                    javascript.0	2020-04-01 17:05:24.192	error	(1081) at Script.runInContext (vm.js:133:20)
                    javascript.0	2020-04-01 17:05:24.192	error	(1081) at script.js.java.sonstige.Sonoff:2797:2
                    javascript.0	2020-04-01 17:05:24.192	error	(1081) at writeHTML (script.js.java.sonstige.Sonoff:1301:3)
                    javascript.0	2020-04-01 17:05:24.192	error	(1081) ReferenceError: mini is not defined
                    javascript.0	2020-04-01 17:05:24.192	error	(1081) ^
                    javascript.0	2020-04-01 17:05:24.192	error	(1081) if (mini){
                    javascript.0	2020-04-01 17:05:24.192	error	(1081) script.js.java.sonstige.Sonoff: script.js.java.sonstige.Sonoff:1301
                    Proxmox und HA ...
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      #291
                      @Meister-Mopper normalerweise ist diese mini abfrage an einer anderen stelle - irgendwie hast du beim kopieren einen "wurm" drin
                      falls du lauter leerzeilen im script hast - nutze den chrome browser und nicht firefox beim kopieren des scriptes aus dem forum
                      • Stephan SchleichS Offline
                        Stephan Schleich
                        schrieb am zuletzt editiert von Stephan Schleich
                        #292
                        Ich bekomm folgenden Fehler, weiß jemand was dazu?
                        • Stephan SchleichS Stephan Schleich
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          #293
                          @Stephan-Schleich könnte evtl ein fehler im generic teil sein - kannst du mal den generic auf false setzen und das script wieder laufen lassen ?
                          Stephan SchleichS 1 Antwort Letzte Antwort
                            Stephan Schleich
                            #294
                            @liv-in-sky du hattest recht, dann läuft's, ist das ein Fehler bei mir oder im Script?
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              #295
                              @Stephan-Schleich weiß ich nicht - wir könnten anydesk machen und direkt bei dir schauen oder du sendest mir einen json-export deines sonoff.0 ordners - was dir lieber ist
                                Stephan Schleich
                                #296
                                @liv-in-sky sagte in Sonoff Geräte als HTML Tabelle - Vis - Iqontrol:
                                anydesk
                                hast pm :)
                                  anydesk
                                  hast pm :)
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #297
                                  @Stephan-Schleich ich schreib dir im chat
                                    MyMeyer
                                    #298
                                    @liv-in-sky Hi habe folgenden Gosund hinzugefügt. In Info steht: SP111 v1.1
                                    Tasmota Version 8.1.0.2
                                    MyMeyer
                                    >>> Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
                                    >>> HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
                                    • M MyMeyer
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      #299
                                      @MyMeyer in zeile 294 ?
                                      getState(id).val.includes("Gosund SP111 v1.1")
                                        MyMeyer
                                        #300
                                        Ja und werden nun angezeigt.
                                        MyMeyer
                                        • M MyMeyer
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          #301
                                          @MyMeyer vielen dank - dann füge ich das hinzu bei dem hauptscript
