  4. JavaScript
  5. Sonoff Geräte als HTML Tabelle - Vis
javascriptmonitoringtemplate
632 Beiträge 34 Kommentatoren 245.8k Aufrufe 39 Beobachtet
    @liv-in-sky bzw. das:
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Timer.processTimers (timers.js:223:10)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at listOnTimeout (timers.js:263:5)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at tryOnTimeout (timers.js:300:5)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at ontimeout (timers.js:436:11)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1319:34)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Object.<anonymous> (script.js.java.sonstige.Sonoff_Test:2727:2)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at writeHTML (script.js.java.sonstige.Sonoff_Test:448:30)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
    javascript.0	2020-04-01 15:51:00.006	warn	(10408) at script.js.java.sonstige.Sonoff_Test:473:16
    javascript.0	2020-04-01 15:51:00.005	warn	(10408) getState "sonoff.0.kvm-switch.ENERGY_Today" not found (3)
    liv-in-skyL
    liv-in-skyL
    #283
    @Meister-Mopper
    ich meine das hier
    • liv-in-skyL liv-in-sky
      @Meister-Mopper
      ich meine das hier
      Meister MopperM
      Meister MopperM
      Meister Mopper
      #284
      @liv-in-sky Das passt schon, die aktuelle Temperatur ist nicht kriegsentscheidend.
      Proxmox und HA ...
      • liv-in-skyL
        liv-in-skyL
        #285
        @Meister-Mopper
        der erste wert der beiden könnte die uptime sein (ist bei anderen auch so) und der zweite - den darfst du entscheiden - die ANALOG-Temperature ?
          liv-in-skyL
          liv-in-skyL
          #286
          @Meister-Mopper
          so ?
            @Meister-Mopper
            so ?
            Meister MopperM
            Meister MopperM
            Meister Mopper
            #287
            @liv-in-sky 1.000 °C - wie geil, dann kann ich ja einen Hochofen anmelden ;-)😊
            Proxmox und HA ...
              liv-in-skyL
              liv-in-skyL
              #288
              @Meister-Mopper mir ist nix besseres eingefallen - muss ja die states zum test schreiben , damit keine fehler kommen :-)
              das neue script ist im ersten post - du mußt dann twoNice=true setzen oder
              du kannst die ganzen settings (von zeile 3 bis bis zeile 113) wieder reinkopieren aber musst dann in zeile 37 das einsetzen - sonst fehlt eine variablen definition
              Meister MopperM 2 Antworten Letzte Antwort
                Meister MopperM
                Meister MopperM
                Meister Mopper
                #289
                @liv-in-sky Super, das ist echt ein Wahnsinn, was Du so umsetzt.
                Recht herzlichen Dank!
                Proxmox und HA ...
                  Meister MopperM
                  Meister MopperM
                  Meister Mopper
                  #290
                  @liv-in-sky Irgendetwas stimmt nicht, habe das Script wie beschrieben angepasst, bekomme aber Fehler:
                  javascript.0	2020-04-01 17:05:24.192	error	(1081) at Script.runInContext (vm.js:133:20)
                  javascript.0	2020-04-01 17:05:24.192	error	(1081) at script.js.java.sonstige.Sonoff:2797:2
                  javascript.0	2020-04-01 17:05:24.192	error	(1081) at writeHTML (script.js.java.sonstige.Sonoff:1301:3)
                  javascript.0	2020-04-01 17:05:24.192	error	(1081) ReferenceError: mini is not defined
                  javascript.0	2020-04-01 17:05:24.192	error	(1081) ^
                  javascript.0	2020-04-01 17:05:24.192	error	(1081) if (mini){
                  javascript.0	2020-04-01 17:05:24.192	error	(1081) script.js.java.sonstige.Sonoff: script.js.java.sonstige.Sonoff:1301
                  Proxmox und HA ...
                    liv-in-skyL
                    liv-in-skyL
                    #291
                    @Meister-Mopper normalerweise ist diese mini abfrage an einer anderen stelle - irgendwie hast du beim kopieren einen "wurm" drin
                    falls du lauter leerzeilen im script hast - nutze den chrome browser und nicht firefox beim kopieren des scriptes aus dem forum
                    • Stephan SchleichS
                      Stephan SchleichS
                      Stephan Schleich
                      schrieb am zuletzt editiert von Stephan Schleich
                      #292
                      Ich bekomm folgenden Fehler, weiß jemand was dazu?
                      • Stephan SchleichS Stephan Schleich
                        liv-in-skyL
                        liv-in-skyL
                        #293
                        @Stephan-Schleich könnte evtl ein fehler im generic teil sein - kannst du mal den generic auf false setzen und das script wieder laufen lassen ?
                        Stephan SchleichS 1 Antwort Letzte Antwort
                          Stephan SchleichS
                          Stephan SchleichS
                          Stephan Schleich
                          #294
                          @liv-in-sky du hattest recht, dann läuft's, ist das ein Fehler bei mir oder im Script?
                            liv-in-skyL
                            liv-in-skyL
                            #295
                            @Stephan-Schleich weiß ich nicht - wir könnten anydesk machen und direkt bei dir schauen oder du sendest mir einen json-export deines sonoff.0 ordners - was dir lieber ist
                              Stephan SchleichS
                              Stephan SchleichS
                              Stephan Schleich
                              #296
                              @liv-in-sky sagte in Sonoff Geräte als HTML Tabelle - Vis - Iqontrol:
                              anydesk
                              hast pm :)
                                anydesk
                                hast pm :)
                                liv-in-skyL
                                liv-in-skyL
                                #297
                                @Stephan-Schleich ich schreib dir im chat
                                • M
                                  M
                                  MyMeyer
                                  #298
                                  @liv-in-sky Hi habe folgenden Gosund hinzugefügt. In Info steht: SP111 v1.1
                                  Tasmota Version 8.1.0.2
                                  MyMeyer
                                  Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
                                  HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
                                  • M MyMeyer
                                    liv-in-skyL
                                    liv-in-skyL
                                    #299
                                    @MyMeyer in zeile 294 ?
                                    getState(id).val.includes("Gosund SP111 v1.1")
                                      M
                                      M
                                      MyMeyer
                                      #300
                                      Ja und werden nun angezeigt.
                                      MyMeyer
                                      • M MyMeyer
                                        liv-in-skyL
                                        liv-in-skyL
                                        #301
                                        @MyMeyer vielen dank - dann füge ich das hinzu bei dem hauptscript
                                          Meister MopperM
                                          Meister MopperM
                                          Meister Mopper
                                          #302
                                          @liv-in-sky Moin,
                                          habe mal wieder ein neues Teil - Teckin-Doppeldose für draußen sonoff.0.Terrassendose.json. Wäre furchbar nett, wenn Du diese integrieren könntest. Unter Teckin taucht sie nicht auf, ist ja auch eine andere Architektur.
                                          Vielen Dank!
                                          Proxmox und HA ...
                                          84.2k
