  4. Fehler bei der Installation des Zigbee Adapters
zigbee
24 Beiträge 5 Kommentatoren 3.7k Aufrufe 4 Beobachtet
  • Achim WeisA Offline
    Achim WeisA Offline
    Achim Weis
    schrieb am zuletzt editiert von Achim Weis
    gleiches Problem
    habe 1.0.2 und 1.0.3 von der Oberfläche aus installiert. (bzw probiert)
    Node: 10.19.0
    host.IObroker	2020-02-14 13:21:51.846	error	iobroker events.js:174 throw er; // Unhandled 'error' event ^Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/admin/img/osram_a60_rgbw.png'Emitted
    host.IObroker	2020-02-14 13:21:49.136	info	iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/trust_zpir_8000.png img/trust_zpir_8000.png image/png
    host.IObroker	2020-02-14 13:21:47.853	error	iobroker Some packets could not be installed. Please install them manually
    host.IObroker	2020-02-14 13:21:47.769	info	iobroker ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_AfterGet(uv_work_t*)’:../src/macros.h:112:60: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::L
    host.IObroker	2020-02-14 13:21:47.755	info	iobroker In file included from ../src/statement.cc:6:../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginGet(node_sqlite3::Statement::Baton*)’:../src/macros
    host.IObroker	2020-02-14 13:21:47.751	info	iobroker ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_AfterBind(uv_work_t*)’:../src/macros.h:112:60: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::
    host.IObroker	2020-02-14 13:21:47.748	info	iobroker In file included from ../src/statement.cc:6:../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginBind(node_sqlite3::Statement::Baton*)’:../src/macro
    host.IObroker	2020-02-14 13:21:47.735	info	iobroker In file included from ../src/statement.cc:6:../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_AfterPrepare(uv_work_t*)’:../src/macros.h:112:60: warnin
    host.IObroker	2020-02-14 13:21:47.727	info	iobroker ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginPrepare(node_sqlite3::Database::Baton*)’:../src/statement.cc:119:58: warning: cast between inco
    host.IObroker	2020-02-14 13:21:47.721	info	iobroker ../src/statement.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE node_sqlite3::Statement::New(Nan::NAN_METHOD_ARGS_TYPE)’:../src/statement.cc:103:10: warning: ‘Nan::Maybe<b
    host.IObroker	2020-02-14 13:21:47.719	info	iobroker In file included from ../src/statement.cc:6:../src/macros.h:112:60: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>
    host.IObroker	2020-02-14 13:21:47.717	info	iobroker In file included from ../src/statement.cc:6:../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Error(T*)’:../src/macros.h:112:60: warning: ‘v8::Local<v8::Va
    host.IObroker	2020-02-14 13:21:47.609	info	iobroker In file included from ../src/database.h:10, from ../src/statement.cc:7:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2298:62: w
    host.IObroker	2020-02-14 13:21:45.306	info	iobroker /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with
    host.IObroker	2020-02-14 13:21:45.282	info	iobroker In file included from /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/database.h:10, from
    host.IObroker	2020-02-14 13:21:45.220	info	iobroker In file included from ../../nan/nan.h:54, from ../src/database.h:10, from ../src/node_sqlite3.cc:8:../src/node_sqlite3.cc: At global scope:/home/iobroker/.cac
    ```[debug.txt](/assets/uploads/files/1581684900624-debug.txt)
      Achim WeisA Offline
      Achim Weis
      debug.rar
      anbei das komplette log file. leider zu groß um als text zu posten
      • Achim WeisA Achim Weis
        debug.rar
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @Achim-Weis
        Das muss ich mir zu hause anschauen - ich habe das Problem (bisher) nicht.
        A.
        • mickymM Offline
          mickymM Offline
          mickym
          Ich habe bei der Installation seit Version 1.0.1 Probleme - Ich habe den Adapter aber nicht über die Kommandozeile sondern normal über die GUI installiert. Endet immer mit Error Code 1 und das angeblich einen Menge *.png fehlen. Das gleiche Phänomen mit Version 1.0.2. . Ich habe mir bislang - da der Adapter schon in der Version 0.x. installiert war - damit beholfen, dass ich eine zusätzliche Instanz eingerichtet habe, die ich anschließend wieder gelöscht habe. Dabei hat sich der Adapter irgendwie selbst repariert und fehlende Dateien nachinstalliert. Auf die Version 1.0.3 werde ich wohl nicht updaten bis die Installationsprobleme nicht behoben sind - zudem die Version 1.0.2 bei mir nun stabil läuft und meine Zigbee Geräte nun alle laufen.
          Mein System ist Raspberry 4 mit 4 MB und wurde sonst auch vor 2 Wochen auf den neuesten Stand gebracht: Node.js 10.19.0
            Achim WeisA Offline
            Achim Weis
            da läuft es dem geübten admin vermutlich kalt den Rücken runter...
            auf der Console:
            sudo su
            dann "npm install iobroker.zigbee"
            ein einfaches sudo npm install hat nicht gereicht.
            dann "iobroker upload all"
            iobroker restart
            danach konnte die Instanz hinzugefügt werden.
            Sorry, ich habe so viel "rumprobiert" - kann leider kein komplettes try&error protokoll abgeben.
            Danke für die schnellen Antworten!
            • W Offline
              W Offline
              Wolfi
              Habe es so probiert wie @Achim-Weis
              leider bei mir ohne Erfog.
              Fertig mit Fehler: events.js:174 throw er; // Unhandled 'error' event ^Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/admin/img/lightify-par16.png'Emitted 'error' event at: at lazyFs.open (internal/fs/streams.js:115:12) at FSReqWrap.args [as oncomplete] (fs.js:140:20)
              • W Wolfi
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @Wolfi
                ich hab es bei mir probiert, es ging ohne Probleme. Kannst du bitte mal das Fixer-Skript drüber laufen lassen, nicht das wir ein problem mit Zugriffsrechten haben ?
                A.
                W 1 Antwort Letzte Antwort
                • AsgothianA Asgothian
                  @Wolfi
                  A.
                  W Offline
                  W Offline
                  Wolfi
                  schrieb am zuletzt editiert von Wolfi
                  @Asgothian
                  Fixer skript?
                  Was wo wie?
                  Da musst du mir helfen. Bin iobroker Neuling bzw. Umsteiger von FHEM.
                  • W Wolfi
                    @Asgothian
                    Fixer skript?
                    Was wo wie?
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @Wolfi sagte in Fehler bei der Installation des Zigbee Adapters:
                    @Asgothian
                    Fixer skript?
                    Was wo wie?
                    Siehe hier
                    A.
                      @Asgothian
                      Fixer skript?
                      Was wo wie?
                      Siehe hier
                      A.
                      W Offline
                      W Offline
                      Wolfi
                      @Asgothian
                      Ich probiere es mal.
                      Aber so wie ich das gelesen habe ist der Fixer nur für ältere installationen.
                      Meine ist gerade mal 2-3Monate alt.
                      • W Wolfi
                        @Asgothian
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @Wolfi
                        So war es mal gedacht. Inzwischen ist es das standard Werkzeug um sicher zu gehen das notwendige Verzeichnisse vorhanden und beschreibbar sind.
                        A.
                          @Wolfi
                          A.
                          W Offline
                          W Offline
                          Wolfi
                          @Asgothian
                          Skript ist gelaufen.
                          Hat leider nicht geholfen.
                          • W Offline
                            W Offline
                            Wolfi
                            Habe nochmals rumprobiert leider ohne erfolg.
                            Test mit anderem Adapter Installation funktionierte .
                            Keine mehr eine Idee?
                            • W Offline
                              W Offline
                              Wolfi
                              @Asgothian
                              Sollte man mal eine ältere Version z. B < VERSION 1 probieren?
                              Wenn Ja woher und wie?
                              • W Wolfi
                                @Asgothian
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                @Wolfi
                                Du kannst wenn der Adapter installiert ist im Admin interface auf eine niedrigere Version runter gehen. Dazu die adapter liste in Experten Ansicht öffnen. Hinter dem + verstecken sich die anderen Versionen.
                                Bevor du das machst, kannst du mal schauen ob diese Datei existiert:
                                '/opt/iobroker/node_modules/iobroker.zigbee/admin/img/lightify-par16.png' und welche Rechte sie hat ?
                                  @Wolfi
                                  W Offline
                                  W Offline
                                  Wolfi
                                  @Asgothian sagte in Fehler bei der Installation des Zigbee Adapters:
                                  iobroker.zigbee
                                  Denn Ordner gibts bei mir gar nicht die Installation scheint nicht soweit zu kommen?
                                  Das andere was du zuvor geschrieben hast nützt ja nichts wenn der Adapter nicht installiert wurde.
                                  • W Wolfi
                                    iobroker.zigbee
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    @Wolfi Doch - das ist in der adapter liste, nicht in der Instanz liste.
                                    A.
                                      A.
                                      W Offline
                                      W Offline
                                      Wolfi
                                      @Asgothian
                                      Schon klar aber dieses zusätzliche (im Experten M.) "+" erscheint bei mir nur bei bereits installierten Adaptern!
                                      Und meine Zigbee installation funzt ja nicht.
                                        auf der Console:
                                        sudo su
                                        iobroker restart
                                        Malaus
                                        Habe auch Schwierigkeiten mit der Installation. Bei mir kommt der Fehler
                                        Fertig mit Fehler: events.js:174 throw er; // Unhandled 'error' event ^Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/admin/img/osram_4058075816718.png'Emitted 'error' event at: at lazyFs.open (internal/fs/streams.js:115:12) at FSReqWrap.args [as oncomplete] (fs.js:140:20)
                                        Das hier hab ich ebenfalls ausprobiert und leider ohne Erfolg.
                                        @Achim-Weis sagte in Fehler bei der Installation des Zigbee Adapters:
                                        auf der Console:
                                        sudo su
                                        iobroker restart
                                        • W Offline
                                          W Offline
                                          Wolfi
                                          So habe es geschafft das Adapter zu installieren!
                                          Was habe ich gemacht?
                                          Zuerst die alte Version 1.0.0 Manuel installiert.
                                          cd /opt/iobroker
                                          npm install iobroker.zigbee@1.0.0
                                          iobroker upload all
                                          iobroker restart
                                          Dann direkt im iobroker das jetzt vorhandene Adapter (1.0.0) wieder deinstalliert und die aktuelle Version installieren.
                                          Und siehe da es hat funktioniert.
                                          Nach meiner Meinung hat die aktuelle Version einen Bug bezüglich Adapter Neu Installation.
                                          Also auf einem System wo Zigbee noch nie installiert war.
                                          So jetzt der nächste schritt mit den Geräten usw.
