  4. js-controller 2.2 jetzt für Alle im Stable
js-controller
142 Beiträge 28 Kommentatoren 30.2k Aufrufe 27 Beobachtet
    den js-controller hatte ich bereits am 25.1. installiert und läuft, Admin 3.7.9.
    Heute aufgrund eines Proxmox updates musste der Rechner neugestartet werden.
    Jedoch erhielt ich folgende Fehlermeldung
    host.IoBroker	2020-01-29 17:40:43.190	info	Restart adapter system.adapter.simple-api.0 because enabled
    host.IoBroker	2020-01-29 17:40:43.189	info	instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
    host.IoBroker	2020-01-29 17:40:43.189	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
    host.IoBroker	2020-01-29 17:40:43.189	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    host.IoBroker	2020-01-29 17:40:43.189	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    host.IoBroker	2020-01-29 17:40:43.188	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
    host.IoBroker	2020-01-29 17:40:43.188	error	Caught by controller[0]: TypeError: Cannot read property 'common' of null
    alexa2.0	2020-01-29 17:40:42.731	info	(1119) Subscribing to states...
    simple-api.0	2020-01-29 17:40:42.598	info	(2016) Terminated (NO_ERROR): Without reason
    simple-api.0	2020-01-29 17:40:42.596	info	(2016) terminating
    simple-api.0	2020-01-29 17:40:42.513	info	(2016) terminating http server on port 8087
    simple-api.0	2020-01-29 17:40:42.511	error	(2016) TypeError: Cannot read property 'common' of null at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068) at tryCatcher (/opt/
    simple-api.0	2020-01-29 17:40:42.510	error	(2016) uncaught exception: Cannot read property 'common' of null
    kann es sein, das die Datenbank noch nicht erreichbar war, oder wie soll ich den Fehler deuten?
    @crunchip interessant. Kannst du es mit einem
    Weiteren Neustart von iobroker nachstellen? Ist auch nur simple-api ... hat sichbdanach neu gestartet und alles war gut. Korrekt ?!
      @crunchip ps: bissl mehr log von davor wäre auch interessant gewesen.
      • apollon77A apollon77
        crunchipC Offline
        crunchipC Offline
        @apollon77 sonst gab es im log nichts unauffälliges
        ausser das noch:
        shelly.0	2020-01-29 17:39:44.359	warn	(1869) no connection to objects DB
        info.0	2020-01-29 17:38:59.890	warn	(1316) no connection to states DB
        2020-01-29 17:38:09.773 - warn: backitup.0 (1042) no connection to states DB
        2020-01-29 17:38:11.815 - warn: broadlink2.0 (1096) no connection to objects DB
        2020-01-29 17:38:49.514 - warn: ical.0 (1265) no connection to states DB
        2020-01-29 17:38:49.921 - warn: ical.1 (1276) no connection to states DB
        ansonsten lief dann auch alles wieder ganz normal
        Ich kann es dann nochmal versuchen, nachzustellen
        das ist das komplette simple-api log,von vorhin
        simple-api.0	2020-01-29 17:41:15.404	info	(2481) http server listening on port 8087
        simple-api.0	2020-01-29 17:41:15.398	info	(2481) Allow states only when user is owner: false
        simple-api.0	2020-01-29 17:41:15.397	info	(2481) simpleAPI server listening on port 8087
        simple-api.0	2020-01-29 17:41:15.323	info	(2481) starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.18.0
        simple-api.0	2020-01-29 17:40:42.511	error	at process._tickCallback (internal/process/next_tick.js:68:7)
        simple-api.0	2020-01-29 17:40:42.511	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        simple-api.0	2020-01-29 17:40:42.511	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        simple-api.0	2020-01-29 17:40:42.511	error	at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
        simple-api.0	2020-01-29 17:39:53.624	info	(2016) http server listening on port 8087
        simple-api.0	2020-01-29 17:39:53.617	info	(2016) Allow states only when user is owner: false
        simple-api.0	2020-01-29 17:39:53.616	info	(2016) simpleAPI server listening on port 8087
        simple-api.0	2020-01-29 17:39:53.520	info	(2016) starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.18.0
          crunchipC Offline
          crunchipC Offline
          @apollon77 bei dem Versuch es nachzustellen, trat der Fehler (leider) nicht mehr auf
          was jedoch noch aufgefallen ist
          alexa2.0, socketio, wiffi-wz, tuya,
          allesamt ---terminated with code 156
          2020-01-29 19:09:24.623 - warn: host.IoBroker instance system.adapter.email.0 terminated due to SIGTERM
          2020-01-29 19:09:24.623 - info: host.IoBroker instance system.adapter.email.0 terminated with code null ()
          2020-01-29 19:09:24.625 - warn: host.IoBroker instance system.adapter.milight.0 terminated due to SIGTERM
          2020-01-29 19:09:24.625 - info: host.IoBroker instance system.adapter.milight.0 terminated with code null ()
          2020-01-29 19:09:24.627 - warn: host.IoBroker instance system.adapter.onkyo.0 terminated due to SIGTERM
          2020-01-29 19:09:24.628 - info: host.IoBroker instance system.adapter.onkyo.0 terminated with code null ()
          2020-01-29 19:09:24.629 - warn: host.IoBroker instance system.adapter.roadtraffic.0 terminated due to SIGTERM
          2020-01-29 19:09:24.630 - info: host.IoBroker instance system.adapter.roadtraffic.0 terminated with code null ()
          2020-01-29 19:09:24.632 - warn: host.IoBroker instance system.adapter.admin.0 terminated due to SIGTERM
          2020-01-29 19:09:24.632 - info: host.IoBroker instance system.adapter.admin.0 terminated with code null ()
          2020-01-29 19:09:24.634 - warn: host.IoBroker instance system.adapter.amazon-dash.0 terminated due to SIGTERM
          2020-01-29 19:09:24.635 - info: host.IoBroker instance system.adapter.amazon-dash.0 terminated with code null ()
          2020-01-29 19:09:24.637 - warn: host.IoBroker instance system.adapter.backitup.0 terminated due to SIGTERM
          2020-01-29 19:09:24.637 - info: host.IoBroker instance system.adapter.backitup.0 terminated with code null ()
          2020-01-29 19:09:24.639 - warn: host.IoBroker instance system.adapter.ble.0 terminated due to SIGTERM
          2020-01-29 19:09:24.639 - info: host.IoBroker instance system.adapter.ble.0 terminated with code null ()
          2020-01-29 19:09:24.641 - warn: host.IoBroker instance system.adapter.broadlink2.0 terminated due to SIGTERM
          2020-01-29 19:09:24.641 - info: host.IoBroker instance system.adapter.broadlink2.0 terminated with code null ()
          2020-01-29 19:09:24.643 - info: host.IoBroker instance system.adapter.alexa2.0 terminated with code 156 (156)
          2020-01-29 19:09:24.646 - warn: host.IoBroker instance system.adapter.discovery.0 terminated due to SIGTERM
          2020-01-29 19:09:24.646 - info: host.IoBroker instance system.adapter.discovery.0 terminated with code null ()
          2020-01-29 19:09:24.648 - warn: host.IoBroker instance system.adapter.fullybrowser.0 terminated due to SIGTERM
          2020-01-29 19:09:24.648 - info: host.IoBroker instance system.adapter.fullybrowser.0 terminated with code null ()
          2020-01-29 19:09:24.650 - warn: host.IoBroker instance system.adapter.info.0 terminated due to SIGTERM
          2020-01-29 19:09:24.650 - info: host.IoBroker instance system.adapter.info.0 terminated with code null ()
          2020-01-29 19:09:24.653 - warn: host.IoBroker instance system.adapter.iogo.0 terminated due to SIGTERM
          2020-01-29 19:09:24.653 - info: host.IoBroker instance system.adapter.iogo.0 terminated with code null ()
          2020-01-29 19:09:24.655 - warn: host.IoBroker instance system.adapter.iot.0 terminated due to SIGTERM
          2020-01-29 19:09:24.655 - info: host.IoBroker instance system.adapter.iot.0 terminated with code null ()
          2020-01-29 19:09:24.657 - warn: host.IoBroker instance system.adapter.mihome.0 terminated due to SIGTERM
          2020-01-29 19:09:24.657 - info: host.IoBroker instance system.adapter.mihome.0 terminated with code null ()
          2020-01-29 19:09:24.659 - warn: host.IoBroker instance system.adapter.pollenflug.0 terminated due to SIGTERM
          2020-01-29 19:09:24.660 - info: host.IoBroker instance system.adapter.pollenflug.0 terminated with code null ()
          2020-01-29 19:09:24.662 - warn: host.IoBroker instance system.adapter.radar2.0 terminated due to SIGTERM
          2020-01-29 19:09:24.662 - info: host.IoBroker instance system.adapter.radar2.0 terminated with code null ()
          2020-01-29 19:09:24.664 - warn: host.IoBroker instance system.adapter.shelly.0 terminated due to SIGTERM
          2020-01-29 19:09:24.664 - info: host.IoBroker instance system.adapter.shelly.0 terminated with code null ()
          2020-01-29 19:09:24.667 - info: host.IoBroker instance system.adapter.socketio.0 terminated with code 156 (156)
          2020-01-29 19:09:24.669 - warn: host.IoBroker instance system.adapter.sonoff.0 terminated due to SIGTERM
          2020-01-29 19:09:24.669 - info: host.IoBroker instance system.adapter.sonoff.0 terminated with code null ()
          2020-01-29 19:09:24.671 - warn: host.IoBroker instance system.adapter.sourceanalytix.0 terminated due to SIGTERM
          2020-01-29 19:09:24.671 - info: host.IoBroker instance system.adapter.sourceanalytix.0 terminated with code null ()
          2020-01-29 19:09:24.674 - warn: host.IoBroker instance system.adapter.tankerkoenig.0 terminated due to SIGTERM
          2020-01-29 19:09:24.674 - info: host.IoBroker instance system.adapter.tankerkoenig.0 terminated with code null ()
          2020-01-29 19:09:24.676 - warn: host.IoBroker instance system.adapter.telegram.0 terminated due to SIGTERM
          2020-01-29 19:09:24.676 - info: host.IoBroker instance system.adapter.telegram.0 terminated with code null ()
          2020-01-29 19:09:24.678 - warn: host.IoBroker instance system.adapter.telegram.1 terminated due to SIGTERM
          2020-01-29 19:09:24.678 - info: host.IoBroker instance system.adapter.telegram.1 terminated with code null ()
          2020-01-29 19:09:24.681 - warn: host.IoBroker instance system.adapter.text2command.0 terminated due to SIGTERM
          2020-01-29 19:09:24.681 - info: host.IoBroker instance system.adapter.text2command.0 terminated with code null ()
          2020-01-29 19:09:24.683 - warn: host.IoBroker instance system.adapter.upnp.0 terminated due to SIGTERM
          2020-01-29 19:09:24.683 - info: host.IoBroker instance system.adapter.upnp.0 terminated with code null ()
          2020-01-29 19:09:24.685 - warn: host.IoBroker instance system.adapter.virtualpowermeter.0 terminated due to SIGTERM
          2020-01-29 19:09:24.686 - info: host.IoBroker instance system.adapter.virtualpowermeter.0 terminated with code null ()
          2020-01-29 19:09:24.688 - warn: host.IoBroker instance system.adapter.web.0 terminated due to SIGTERM
          2020-01-29 19:09:24.688 - info: host.IoBroker instance system.adapter.web.0 terminated with code null ()
          2020-01-29 19:09:24.690 - info: host.IoBroker instance system.adapter.wiffi-wz.0 terminated with code 156 (156)
          2020-01-29 19:09:24.692 - warn: host.IoBroker instance system.adapter.fullcalendar.0 terminated due to SIGTERM
          2020-01-29 19:09:24.693 - info: host.IoBroker instance system.adapter.fullcalendar.0 terminated with code null ()
          2020-01-29 19:09:24.695 - warn: host.IoBroker instance system.adapter.chromecast.0 terminated due to SIGTERM
          2020-01-29 19:09:24.695 - info: host.IoBroker instance system.adapter.chromecast.0 terminated with code null ()
          2020-01-29 19:09:24.698 - warn: host.IoBroker instance system.adapter.tr-064.0 terminated due to SIGTERM
          2020-01-29 19:09:24.698 - info: host.IoBroker instance system.adapter.tr-064.0 terminated with code null ()
          2020-01-29 19:09:24.700 - warn: host.IoBroker instance system.adapter.simple-api.0 terminated due to SIGTERM
          2020-01-29 19:09:24.701 - info: host.IoBroker instance system.adapter.simple-api.0 terminated with code null ()
          2020-01-29 19:09:24.703 - warn: host.IoBroker instance system.adapter.javascript.0 terminated due to SIGTERM
          2020-01-29 19:09:24.704 - info: host.IoBroker instance system.adapter.javascript.0 terminated with code null ()
          2020-01-29 19:09:24.706 - warn: host.IoBroker instance system.adapter.javascript.1 terminated due to SIGTERM
          2020-01-29 19:09:24.706 - info: host.IoBroker instance system.adapter.javascript.1 terminated with code null ()
          2020-01-29 19:09:25.742 - info: tuya.0 (2167) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2020-01-29 19:09:26.270 - info: host.IoBroker instance system.adapter.tuya.0 terminated with code 156 (156)
            @crunchip bei was kam Das? Beim
            Stoppen? Da wurden die Prozesse gekillt.
              ausser das noch:
              @crunchip zu simple api ist bei mir eher die Frage was ggf für ein Zugriff über die api reinkam. Der Fehler kommt einige Zeit nachdem der Adapter Gestartet wurde. wenn du es nachstellen kannst können wir tiefer reinschauen wines genau knallt. Vllt hilft dir das ne Idee zu kriegen ? Was könnte es gewesen sein? Vllt anhand des zeitstempels?
                crunchipC Offline
                crunchipC Offline
                @apollon77 ja das war das stoppen.
                Leider kenn ich die einzelnen codes und ihre Bedeutung nicht. Da alle mit sigterm ...code null beendet wurden, bis auf die 4 genannten
                  @crunchip der Unterschied ist nur bissl wie schnell sie stoppen und so. Also alles ok.
                    crunchipC Offline
                    crunchipC Offline
                    @apollon77 wie schon geschrieben, konnte es leider nicht nachstellen,
                    ich wüsste auch gar nicht wo, wie und nach was ich suchen sollte.
                      @crunchip also meine Vermutung ist das es mit dem Start nichts zu tun hatte sondern irgendein api request an den Adapter das verursacht hat.
                        crunchipC Offline
                        crunchipC Offline
                        @apollon77 einzige was ich die letzte Zeit installiert habe, ist das Projekt https://github.com/SBorg2014/WLAN-Wetterstation/wiki/Installation---Teil-2
                        • umbmU Offline
                          umbmU Offline
                          umbm
                          Ich habe seit dem Update ständige Neustarts ca alle 2 Minuten
                          im Log:
                          admin.0	2020-01-29 20:24:33.044	info	(6054) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                          admin.0	2020-01-29 20:24:33.043	info	(6054) terminating
                          admin.0	2020-01-29 20:24:33.043	info	(6054) terminating http server on port 8081
                          admin.0	2020-01-29 20:24:33.041	warn	(6054) Got terminate signal. Checking desired PID: vs own PID 6054
                          habe schon alle Schritte aus Post 1 versucht, ohne Erfolg.
                          • umbmU umbm
                            im Log:
                            @umbm stoppe Info mal. Lass paar mins aus und aktiviere ihn wieder.
                            • umbmU Offline
                              umbmU Offline
                              umbm
                              schrieb am zuletzt editiert von umbm
                              Leider keine Änderung nach 5 Minuten ohne info-adapter
                              Aufgefallen ist es mir nach dem Update eigentlich nur, weil das Tablet mit dem VIS regelmäßig weiß wurde.
                              Nachtrag:
                              Kann ich eigentlich ohne weiteres auf die Vorversion zurück gehen?
                              • umbmU Offline
                                umbmU Offline
                                umbm
                                @apollon77 sagte in js-controller 2.2 jetzt für Alle im Stable:
                                Moment, oben steht:
                                iqontrol 0.2.15
                                Mir wird aber bisher nur iqontrol 0.2.14 angeboten.
                                Kann das die Ursache sein?
                                • umbmU umbm
                                  Nachtrag:
                                  @umbm mal js-Controller neu gestartet bzw rebootet?
                                  umbmU 1 Antwort Letzte Antwort
                                    umbmU Offline
                                    umbmU Offline
                                    umbm
                                    Ja, natürlich.
                                    Habe jetzt aus dem Latest iqontrol 0.2.16 installiert.
                                    Der Fehler besteht aber auch damit weiterhin.
                                    • umbmU umbm
                                      Moment, oben steht:
                                      iqontrol 0.2.15
                                      @umbm nein das kann es nicht sein.
                                      Also bei Dir wird in den "sigKill" Datenpunkt scheinbar ein leerer Wert geschrieben ... das Thema ist: Das sollte niemand tun. Da sollten nur Zahlen drin landen. Die Frage ist halt wer und warum da diese Werte reinschreibt. Du hast kein Script was da irgendwas tut?
                                      Ich hätte jetzt gesagt aktiviere mal history adater für system.adapter.admin.0 (sorry war ja admin und nicht info) und zeig mal was da so geloggt wird.
                                      An sich wird da zum Adapterstart eine Zahl reingschrieben und ggf spöter auf 0 gesetzt oder -1 ... aber das sollte es gewesen sein.
                                        umbmU Offline
                                        umbmU Offline
                                        umbm
                                        Stimmt!
                                        Durch deinen Tipp habe ich das gefunden:
                                        Ich habe aber keine Ahnung, woher mqtt das bekommen könnte, ein script darauf gibt es definitiv nicht.
                                        Vor dem Update des js-controllers ist es nie aufgetreten. 😕
                                        • umbmU umbm
                                          Stimmt!
                                          @umbm Also alle system.adapter.* States sollten nur sehr mit vorsicht beschrieben werden. Aber das ist mal mindestens der Grund warum es passiert. Vor allem was macht da ein Leerzeichen drin :-)
