  4. js-controller 2.2 jetzt im Latest
js-controller
160 Beiträge 39 Kommentatoren 33.2k Aufrufe 31 Beobachtet
  • apollon77A apollon77
    @SBorg kommen die nur vom node-red Adapter oder wie? Zeig mal log bitte.
    SBorgS Offline
    SBorgS Offline
    SBorg
    #94
    @apollon77 sagte in js-controller 2.2 jetzt im Latest:
    Ne, von so ziemlich allem. Während des startens sind es 28 Stück, danach wird es besser. Mich stört es nicht, ist halt nur eine Feststellung (ebenso wie NodeRED):
    2020-01-26 03:09:54.459  - info: host.Ubuntu iobroker.js-controller version 2.2.8 js-controller starting
    2020-01-26 03:09:54.474  - info: host.Ubuntu Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
    2020-01-26 03:09:54.476  - info: host.Ubuntu hostname: Ubuntu, node: v10.18.1
    2020-01-26 03:09:54.480  - info: host.Ubuntu ip addresses: 192.168.1.30 2001:xxx...
    2020-01-26 03:09:56.844  - info: host.Ubuntu connected to Objects and States
    2020-01-26 03:10:03.676  - info: host.Ubuntu 85 instances found
    2020-01-26 03:10:03.961  - info: host.Ubuntu starting 49 instances
    2020-01-26 03:10:04.064  - info: host.Ubuntu instance system.adapter.admin.0 started with pid 20829
    2020-01-26 03:10:07.985  - info: host.Ubuntu instance system.adapter.alexa2.0 started with pid 20842
    2020-01-26 03:10:15.537  - info: host.Ubuntu instance system.adapter.backitup.0 started with pid 20855
    2020-01-26 03:10:16.123  - warn: alexa2.0 (20842) no connection to objects DB
    2020-01-26 03:10:16.173  - info: host.Ubuntu instance system.adapter.broadlink2.0 started with pid 20863
    2020-01-26 03:10:16.201  - info: admin.0 (20829) starting. Version 3.7.7 in /opt/iobroker/node_modules/iobroker.admin, node: v10.18.1
    2020-01-26 03:10:16.496  - info: admin.0 (20829) requesting all states
    2020-01-26 03:10:16.501  - info: admin.0 (20829) requesting all objects
    2020-01-26 03:10:24.999  - info: host.Ubuntu instance system.adapter.countdown.0 started with pid 20881
    2020-01-26 03:10:25.444  - warn: broadlink2.0 (20863) no connection to objects DB
    2020-01-26 03:10:25.599  - info: host.Ubuntu instance scheduled system.adapter.daswetter.0 16,46 * * * *
    2020-01-26 03:10:26.152  - info: alexa2.0 (20842) starting. Version 3.0.7 in /opt/iobroker/node_modules/iobroker.alexa2, node: v10.18.1
    2020-01-26 03:10:28.076  - info: host.Ubuntu instance scheduled system.adapter.dwd.0 */20 * * * *
    2020-01-26 03:10:28.100  - info: host.Ubuntu instance system.adapter.dwd.0 started with pid 20894
    2020-01-26 03:10:28.419  - warn: backitup.0 (20855) no connection to objects DB
    2020-01-26 03:10:30.625  - info: admin.0 (20829) received all objects
    2020-01-26 03:10:31.434  - info: admin.0 (20829) http server listening on port 8081
    2020-01-26 03:10:31.435  - info: admin.0 (20829) Use link "http://localhost:8081" to configure.
    2020-01-26 03:10:32.787  - info: alexa2.0 (20842) Alexa-Push-Connection established. Disable Polling
    2020-01-26 03:10:36.971  - info: host.Ubuntu instance system.adapter.email.0 started with pid 20922
    2020-01-26 03:10:37.680  - info: host.Ubuntu instance system.adapter.fb-checkpresence.0 started with pid 20929
    2020-01-26 03:10:37.788  - info: broadlink2.0 (20863) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.18.1
    2020-01-26 03:10:38.324  - warn: dwd.0 (20894) no connection to objects DB
    2020-01-26 03:10:44.480  - info: host.Ubuntu instance scheduled system.adapter.feiertage.0 0 0 * * *
    2020-01-26 03:10:44.501  - info: host.Ubuntu instance system.adapter.feiertage.0 started with pid 20947
    2020-01-26 03:10:45.181  - info: host.Ubuntu instance system.adapter.fritzbox.0 started with pid 20956
    2020-01-26 03:10:45.302  - warn: email.0 (20922) no connection to objects DB
    2020-01-26 03:10:45.435  - info: countdown.0 (20881) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.countdown, node: v10.18.1
    2020-01-26 03:10:46.775  - info: broadlink2.0 (20863) broadlink2 initialization started...
    2020-01-26 03:10:46.785  - info: broadlink2.0 (20863) Devices to add:
    2020-01-26 03:10:46.799  - info: broadlink2.0 (20863) Devices to rename: RM:RMMINI-xxx=RM3-Mini_WoZi
    2020-01-26 03:10:46.945  - info: broadlink2.0 (20863) UDP socket listening on 0.0.0.0:15001
    2020-01-26 03:10:46.946  - info: broadlink2.0 (20863) Discover Broadlink devices for 10sec on broadlink2.0
    2020-01-26 03:10:47.662  - info: broadlink2.0 (20863) Device RM:0x2737xxx...
    2020-01-26 03:10:53.460  - info: host.Ubuntu instance system.adapter.history.0 started with pid 20974
    2020-01-26 03:10:54.020  - info: host.Ubuntu instance scheduled system.adapter.ical.0 0,30 * * * *
    2020-01-26 03:10:54.049  - info: host.Ubuntu instance system.adapter.ical.0 started with pid 20983
    2020-01-26 03:10:54.150  - info: backitup.0 (20855) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.18.1
    2020-01-26 03:10:54.409  - warn: fritzbox.0 (20956) no connection to objects DB
    2020-01-26 03:10:54.498  - info: backitup.0 (20855) [iobroker] backup was activated at 02:08 every 1 day(s)
    2020-01-26 03:11:01.466  - info: host.Ubuntu instance scheduled system.adapter.ical.1 0 */6 * * *
    2020-01-26 03:11:01.882  - warn: history.0 (20974) no connection to objects DB
    2020-01-26 03:11:01.487  - info: host.Ubuntu instance system.adapter.ical.1 started with pid 21003
    2020-01-26 03:11:02.717  - info: host.Ubuntu instance system.adapter.info.0 started with pid 21058
    2020-01-26 03:11:03.596  - warn: ical.0 (20983) no connection to objects DB
    2020-01-26 03:11:09.562  - info: host.Ubuntu instance system.adapter.iot.0 started with pid 21108
    2020-01-26 03:11:10.332  - info: host.Ubuntu instance system.adapter.javascript.0 started with pid 21115
    2020-01-26 03:11:10.391  - info: fb-checkpresence.0 (20929) starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v10.18.1
    2020-01-26 03:11:10.615  - info: email.0 (20922) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.email, node: v10.18.1
    2020-01-26 03:11:10.877  - info: fb-checkpresence.0 (20929) start fb-checkpresence: ip-address: 192.168.1.1 polling interval: 1 (*/1 * * * *)
    2020-01-26 03:11:10.887  - warn: ical.1 (21003) no connection to objects DB
    2020-01-26 03:11:11.000  - info: broadlink2.0 (20863) broadlink2.0 started and found 1 devices named 'RM:0x27xxx...'.
    2020-01-26 03:11:11.337  - info: fb-checkpresence.0 (20929) service GetHostNumberOfEntries is supported
    2020-01-26 03:11:11.738  - info: fb-checkpresence.0 (20929) service X_AVM-DE_GetHostListPath is supported
    2020-01-26 03:11:11.914  - info: fb-checkpresence.0 (20929) service GetSpecificHostEntry is supported
    2020-01-26 03:11:12.041  - info: host.Ubuntu instance system.adapter.lgtv11.0 started with pid 21126
    2020-01-26 03:11:12.300  - info: fb-checkpresence.0 (20929) service X_AVM-DE_GetSpecificHostEntryByIP is supported
    2020-01-26 03:11:12.463  - info: fb-checkpresence.0 (20929) service GetSecurityPort is supported
    2020-01-26 03:11:21.335  - info: host.Ubuntu instance system.adapter.linkeddevices.0 started with pid 21149
    2020-01-26 03:11:21.349  - info: host.Ubuntu instance scheduled system.adapter.luftdaten.0 */5 * * * *
    2020-01-26 03:11:21.378  - info: host.Ubuntu instance system.adapter.luftdaten.0 started with pid 21157
    2020-01-26 03:11:21.421  - info: dwd.0 (20894) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.18.1
    2020-01-26 03:11:24.733  - info: dwd.0 (20894) Terminated (NO_ERROR): Without reason
    2020-01-26 03:11:30.501  - info: host.Ubuntu instance scheduled system.adapter.meteoalarm.0 43 */30 * * * *
    2020-01-26 03:11:31.179  - info: host.Ubuntu instance system.adapter.mqtt.0 started with pid 21179
    2020-01-26 03:11:31.280  - info: host.Ubuntu instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
    2020-01-26 03:11:32.039  - info: host.Ubuntu instance system.adapter.nina.0 started with pid 21188
    2020-01-26 03:11:40.479  - info: host.Ubuntu instance system.adapter.node-red.0 started with pid 21207
    2020-01-26 03:11:40.721  - warn: mqtt.0 (21179) no connection to objects DB
    2020-01-26 03:11:41.494  - info: host.Ubuntu instance scheduled system.adapter.odl.0 30 * * * *
    2020-01-26 03:11:41.575  - info: host.Ubuntu instance system.adapter.odl.0 started with pid 21214
    2020-01-26 03:11:41.652  - info: javascript.0 (21115) starting. Version 4.3.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v10.18.1
    2020-01-26 03:11:41.788  - warn: nina.0 (21188) no connection to objects DB
    2020-01-26 03:11:41.969  - info: javascript.0 (21115) npm install request --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
    2020-01-26 03:11:45.126  - warn: nina.0 (21188) no connection to states DB
    2020-01-26 03:11:45.127  - warn: mqtt.0 (21179) no connection to states DB
    2020-01-26 03:11:50.899  - warn: node-red.0 (21207) no connection to objects DB
    2020-01-26 03:11:51.317  - info: host.Ubuntu instance scheduled system.adapter.openweathermap.0 46 * * * *
    2020-01-26 03:11:51.341  - info: host.Ubuntu instance system.adapter.openweathermap.0 started with pid 21247
    2020-01-26 03:11:52.547  - info: host.Ubuntu instance system.adapter.pi-hole.0 started with pid 21260
    2020-01-26 03:11:52.594  - info: host.Ubuntu instance system.adapter.ping.0 started with pid 21262
    2020-01-26 03:11:52.892  - warn: odl.0 (21214) no connection to objects DB
    2020-01-26 03:12:03.448  - warn: openweathermap.0 (21247) no connection to objects DB
    2020-01-26 03:12:03.528  - warn: ping.0 (21262) no connection to objects DB
    2020-01-26 03:12:02.551  - info: host.Ubuntu instance system.adapter.pollenflug.0 started with pid 21295
    2020-01-26 03:12:03.792  - info: host.Ubuntu instance system.adapter.radar2.0 started with pid 21302
    2020-01-26 03:12:03.848  - info: ical.0 (20983) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.ical, node: v10.18.1
    2020-01-26 03:12:04.200  - warn: pi-hole.0 (21260) no connection to objects DB
    2020-01-26 03:12:04.354  - info: host.Ubuntu instance system.adapter.sayit.0 started with pid 21319
    2020-01-26 03:12:04.400  - info: feiertage.0 (20947) starting. Version 1.0.17 in /opt/iobroker/node_modules/iobroker.feiertage, node: v10.18.1
    2020-01-26 03:12:15.116  - info: host.Ubuntu instance system.adapter.scenes.0 started with pid 21357
    2020-01-26 03:12:15.221  - warn: pollenflug.0 (21295) no connection to objects DB
    2020-01-26 03:12:15.438  - warn: sayit.0 (21319) no connection to objects DB
    2020-01-26 03:12:15.740  - warn: radar2.0 (21302) no connection to objects DB
    2020-01-26 03:12:16.818  - info: host.Ubuntu instance system.adapter.simple-api.0 started with pid 21371
    2020-01-26 03:12:16.860  - info: host.Ubuntu instance system.adapter.sonoff.0 started with pid 21372
    2020-01-26 03:12:17.148  - info: feiertage.0 (20947) Next holiday: Valentinstag is in 19 days on 14.02.2020
    2020-01-26 03:12:17.166  - info: feiertage.0 (20947) adapter feiertage objects written
    2020-01-26 03:12:18.006  - info: ical.1 (21003) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.ical, node: v10.18.1
    2020-01-26 03:12:20.567  - info: host.Ubuntu instance system.adapter.sourceanalytix.0 started with pid 21387
    2020-01-26 03:12:21.219  - warn: node-red.0 (21207) no connection to states DB
    2020-01-26 03:12:21.257  - warn: odl.0 (21214) no connection to states DB
    2020-01-26 03:12:21.937  - warn: pi-hole.0 (21260) no connection to states DB
    2020-01-26 03:12:21.943  - warn: openweathermap.0 (21247) no connection to states DB
    2020-01-26 03:12:21.948  - warn: ping.0 (21262) no connection to states DB
    2020-01-26 03:12:22.167  - info: feiertage.0 (20947) Terminated (NO_ERROR): Without reason
    2020-01-26 03:12:23.159  - info: ical.1 (21003) processing URL: Abfall http://192.168.1.30:32500/abfuhrtermine_bis_2020-12-31.ics
    2020-01-26 03:12:23.319  - info: host.Ubuntu instance system.adapter.feiertage.0 terminated with code 0 (NO_ERROR)
    2020-01-26 03:12:24.886  - warn: pollenflug.0 (21295) no connection to states DB
    2020-01-26 03:12:24.889  - warn: sayit.0 (21319) no connection to states DB
    2020-01-26 03:12:25.247  - warn: radar2.0 (21302) no connection to states DB
    2020-01-26 03:12:25.615  - info: host.Ubuntu instance system.adapter.statistics.0 started with pid 21406
    2020-01-26 03:12:25.792  - info: javascript.0 (21115) + request@2.88.0
    added 76 packages from 98 contributors and audited 116 packages in 37.479s
    2020-01-26 03:12:26.994  - info: javascript.0 (21115)
    1 package is looking for funding
      run `npm fund` for details
    2020-01-26 03:12:27.027  - info: javascript.0 (21115) found 0 vulnerabilities
    2020-01-26 03:12:27.747  - info: javascript.0 (21115) requesting all states
    2020-01-26 03:12:27.771  - info: javascript.0 (21115) requesting all objects
    2020-01-26 03:12:28.177  - info: host.Ubuntu instance system.adapter.tankerkoenig.0 started with pid 21419
    2020-01-26 03:12:29.610  - warn: sonoff.0 (21372) no connection to states DB
    2020-01-26 03:12:31.307  - info: ical.0 (20983) processing URL: Google https://calendar.google.com/xxx...
    2020-01-26 03:12:32.862  - info: ical.1 (21003) Terminated (NO_ERROR): Without reason
    2020-01-26 03:12:33.444  - info: host.Ubuntu instance system.adapter.terminal.0 started with pid 21433
    2020-01-26 03:12:34.260  - warn: sourceanalytix.0 (21387) no connection to objects DB
    2020-01-26 03:12:35.117  - info: host.Ubuntu instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
    2020-01-26 03:12:37.848  - warn: statistics.0 (21406) no connection to objects DB
    2020-01-26 03:12:37.895  - info: javascript.0 (21115) received all objects
    2020-01-26 03:12:38.295  - info: javascript.0 (21115) received all states
    2020-01-26 03:12:40.752  - warn: tankerkoenig.0 (21419) no connection to objects DB
    2020-01-26 03:12:42.263  - info: host.Ubuntu instance system.adapter.trashschedule.0 started with pid 21450
    2020-01-26 03:12:42.319  - info: host.Ubuntu instance system.adapter.tuya.0 started with pid 21457
    2020-01-26 03:12:43.576  - info: luftdaten.0 (21157) starting. Version 0.0.11 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v10.18.1
    2020-01-26 03:12:44.239  - info: host.Ubuntu instance system.adapter.upnp.0 started with pid 21469
    2020-01-26 03:12:44.244  - warn: terminal.0 (21433) no connection to objects DB
    2020-01-26 03:12:45.812  - warn: sourceanalytix.0 (21387) no connection to states DB
    2020-01-26 03:12:46.951  - warn: statistics.0 (21406) no connection to states DB
    2020-01-26 03:12:47.883  - warn: tankerkoenig.0 (21419) no connection to states DB
    2020-01-26 03:12:47.923  - warn: terminal.0 (21433) no connection to states DB
    2020-01-26 03:12:50.261  - info: ical.0 (20983) Terminated (NO_ERROR): Without reason
    2020-01-26 03:12:52.476  - warn: trashschedule.0 (21450) no connection to objects DB
    2020-01-26 03:12:55.028  - warn: tuya.0 (21457) no connection to objects DB
    2020-01-26 03:12:55.380  - info: luftdaten.0 (21157) Terminated (NO_ERROR): Without reason
    2020-01-26 03:12:57.833  - info: host.Ubuntu instance system.adapter.web.0 started with pid 21505
    2020-01-26 03:12:58.424  - warn: upnp.0 (21469) no connection to objects DB
    2020-01-26 03:12:58.436  - info: host.Ubuntu instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2020-01-26 03:12:58.437  - info: host.Ubuntu instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    2020-01-26 03:12:58.501  - info: linkeddevices.0 (21149) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.linkeddevices, node: v10.18.1
    2020-01-26 03:12:58.677  - info: linkeddevices.0 (21149) [initialObjects] started...
    2020-01-26 03:13:00.421  - info: host.Ubuntu instance scheduled system.adapter.youtube.0 21 18 * * * *
    2020-01-26 03:13:00.455  - info: host.Ubuntu instance system.adapter.youtube.0 started with pid 21517
    2020-01-26 03:13:02.071  - warn: tuya.0 (21457) no connection to states DB
    2020-01-26 03:13:02.151  - warn: upnp.0 (21469) no connection to states DB
    2020-01-26 03:13:05.520  - info: host.Ubuntu instance scheduled system.adapter.yr.0 33 * * * *
    2020-01-26 03:13:05.627  - info: host.Ubuntu instance system.adapter.yr.0 started with pid 21537
    2020-01-26 03:13:07.940  - warn: vis-google-fonts.0 (21492) no connection to states DB
    2020-01-26 03:13:11.287  - warn: vis.0 (21499) no connection to objects DB
    2020-01-26 03:13:12.313  - warn: web.0 (21505) no connection to objects DB
    2020-01-26 03:13:14.405  - warn: youtube.0 (21517) no connection to objects DB
    2020-01-26 03:13:14.434  - info: host.Ubuntu instance system.adapter.enigma2.0 started with pid 21553
    2020-01-26 03:13:15.207  - info: host.Ubuntu instance system.adapter.influxdb.0 started with pid 21562
    2020-01-26 03:13:15.950  - info: iot.0 (21108) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.iot, node: v10.18.1
    2020-01-26 03:13:16.137  - info: iot.0 (21108) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    2020-01-26 03:13:16.265  - warn: yr.0 (21537) no connection to objects DB
    2020-01-26 03:13:16.704  - warn: host.Ubuntu startInstance cannot find adapter "tr-064@3.1.0". Try to install it... 1 attempt
    2020-01-26 03:13:16.705  - info: host.Ubuntu iobroker install tr-064@3.1.0 using installedFrom
    2020-01-26 03:13:17.944  - info: javascript.0 (21115) Start javascript script.js.common.Alexa.Anrufmonitor
    2020-01-26 03:13:18.076  - info: javascript.0 (21115) script.js.common.Alexa.Anrufmonitor: registered 1 subscription and 0 schedules
    2020-01-26 03:13:18.077  - info: javascript.0 (21115) Start javascript script.js.common.Alexa.Tabletten
    2020-01-26 03:13:18.116  - info: javascript.0 (21115) script.js.common.Alexa.Tabletten: registered 1 subscription and 0 schedules
    2020-01-26 03:13:18.117  - info: javascript.0 (21115) Start javascript script.js.common.Alexa.Temperatur_Arbeitszimmer
    2020-01-26 03:13:18.133  - info: javascript.0 (21115) script.js.common.Alexa.Temperatur_Arbeitszimmer: registered 1 subscription and 0 schedules
    2020-01-26 03:13:18.142  - info: javascript.0 (21115) Start javascript script.js.common.Alexa.Temperatur_Wohnzimmer
    2020-01-26 03:13:18.150  - info: javascript.0 (21115) script.js.common.Alexa.Temperatur_Wohnzimmer: registered 1 subscription and 0 schedules
    2020-01-26 03:13:18.159  - info: javascript.0 (21115) Start javascript script.js.common.Allgemein.LG-TV
    2020-01-26 03:13:18.171  - info: javascript.0 (21115) script.js.common.Allgemein.LG-TV: registered 1 subscription and 0 schedules
    2020-01-26 03:13:18.173  - info: javascript.0 (21115) Start javascript script.js.common.Allgemein.Reset_Router-Reconnect
    2020-01-26 03:13:18.234  - info: javascript.0 (21115) script.js.common.Allgemein.Reset_Router-Reconnect: registered 1 subscription and 0 schedules
    2020-01-26 03:13:18.235  - info: javascript.0 (21115) Start javascript script.js.common.Allgemein.Reset_Tagesaufgaben
    2020-01-26 03:13:18.354  - info: javascript.0 (21115) script.js.common.Allgemein.Reset_Tagesaufgaben: registered 1 subscription and 1 schedule
    2020-01-26 03:13:18.356  - info: javascript.0 (21115) Start javascript script.js.common.Data_extern.Lebensmittelwarnung
    2020-01-26 03:13:19.692  - info: javascript.0 (21115) script.js.common.Data_extern.Lebensmittelwarnung: Hole Daten...
    2020-01-26 03:13:19.718  - info: javascript.0 (21115) script.js.common.Data_extern.Lebensmittelwarnung: registered 1 subscription and 1 schedule
    2020-01-26 03:13:19.719  - info: javascript.0 (21115) Start javascript script.js.common.Data_extern.LuftfeuchteAbfrage
    2020-01-26 03:13:19.746  - info: javascript.0 (21115) script.js.common.Data_extern.LuftfeuchteAbfrage: registered 0 subscriptions and 1 schedule
    2020-01-26 03:13:19.747  - info: javascript.0 (21115) Start javascript script.js.common.Data_extern.Prognose_Ozon_Farbe
    2020-01-26 03:13:19.788  - info: javascript.0 (21115) script.js.common.Data_extern.Prognose_Ozon_Farbe: registered 1 subscription and 0 schedules
    2020-01-26 03:13:19.789  - info: javascript.0 (21115) Start javascript script.js.common.Daten.Muellabfuhr
    2020-01-26 03:13:19.864  - info: javascript.0 (21115) script.js.common.Daten.Muellabfuhr: registered 1 subscription and 0 schedules
    2020-01-26 03:13:19.865  - info: javascript.0 (21115) Start javascript script.js.common.Daten.Tabletten
    2020-01-26 03:13:19.908  - info: javascript.0 (21115) script.js.common.Daten.Tabletten: registered 0 subscriptions and 1 schedule
    2020-01-26 03:13:19.909  - info: javascript.0 (21115) Start javascript script.js.common.Daten.TaupunktAbfrage
    2020-01-26 03:13:19.933  - info: javascript.0 (21115) script.js.common.Daten.TaupunktAbfrage: registered 0 subscriptions and 1 schedule
    2020-01-26 03:13:19.934  - info: javascript.0 (21115) Start javascript script.js.common.Daten.TemperaturAbfrage
    2020-01-26 03:13:19.963  - info: javascript.0 (21115) script.js.common.Daten.TemperaturAbfrage: registered 0 subscriptions and 1 schedule
    2020-01-26 03:13:19.964  - info: javascript.0 (21115) Start javascript script.js.common.Daten.Verbrauchsmaterialien
    2020-01-26 03:13:19.990  - info: javascript.0 (21115) script.js.common.Daten.Verbrauchsmaterialien: registered 0 subscriptions and 1 schedule
    2020-01-26 03:13:19.996  - info: javascript.0 (21115) Start javascript script.js.common.Daten.View_Watcher
    2020-01-26 03:13:20.024  - info: javascript.0 (21115) script.js.common.Daten.View_Watcher: registered 2 subscriptions and 0 schedules
    2020-01-26 03:13:20.025  - info: javascript.0 (21115) Start javascript script.js.common.Daten.Wetterdaten
    2020-01-26 03:13:20.079  - info: javascript.0 (21115) script.js.common.Daten.Wetterdaten: registered 0 subscriptions and 2 schedules
    2020-01-26 03:13:20.081  - info: javascript.0 (21115) Start javascript script.js.common.Heizung.WW_Zirkulation
    2020-01-26 03:13:20.122  - info: javascript.0 (21115) script.js.common.Heizung.WW_Zirkulation: registered 1 subscription and 0 schedules
    2020-01-26 03:13:20.123  - info: javascript.0 (21115) Start javascript script.js.common.Rechner.DreamboxAlexa
    2020-01-26 03:13:20.147  - info: javascript.0 (21115) script.js.common.Rechner.DreamboxAlexa: registered 1 subscription and 0 schedules
    2020-01-26 03:13:20.147  - info: javascript.0 (21115) Start javascript script.js.common.Rechner.Dreambox_AUS(1)
    2020-01-26 03:13:20.185  - info: javascript.0 (21115) script.js.common.Rechner.Dreambox_AUS(1): registered 1 subscription and 0 schedules
    2020-01-26 03:13:20.186  - info: javascript.0 (21115) Start javascript script.js.common.Rechner.Dreambox_Button
    2020-01-26 03:13:20.206  - info: javascript.0 (21115) script.js.common.Rechner.Dreambox_Button: WEBIF_VERSION = Dream webif
    2020-01-26 03:13:20.216  - info: javascript.0 (21115) script.js.common.Rechner.Dreambox_Button: registered 21 subscriptions and 0 schedules
    2020-01-26 03:13:20.217  - info: javascript.0 (21115) Start javascript script.js.common.Rechner.Dreambox_VIS
    2020-01-26 03:13:20.236  - info: javascript.0 (21115) script.js.common.Rechner.Dreambox_VIS: registered 3 subscriptions and 0 schedules
    2020-01-26 03:13:20.237  - info: javascript.0 (21115) Start javascript script.js.common.Rechner.NAS-Server_AN
    2020-01-26 03:13:20.265  - info: javascript.0 (21115) script.js.common.Rechner.NAS-Server_AN: registered 1 subscription and 0 schedules
    2020-01-26 03:13:20.267  - info: javascript.0 (21115) Start javascript script.js.common.System.Servicemeldungen
    2020-01-26 03:13:20.304  - info: javascript.0 (21115) script.js.common.System.Servicemeldungen: registered 1 subscription and 0 schedules
    2020-01-26 03:13:20.305  - info: javascript.0 (21115) Start javascript script.js.common.System.eventList
    2020-01-26 03:13:20.399  - info: javascript.0 (21115) script.js.common.System.eventList: registered 0 subscriptions and 1 schedule
    2020-01-26 03:13:20.400  - info: javascript.0 (21115) Start javascript script.js.common.Systeminfos.MinMax_Statistik
    2020-01-26 03:13:20.464  - info: javascript.0 (21115) script.js.common.Systeminfos.MinMax_Statistik: registered 0 subscriptions and 1 schedule
    2020-01-26 03:13:20.465  - info: javascript.0 (21115) Start javascript script.js.common.Systeminfos.MinMax_per_30Days
    2020-01-26 03:13:20.516  - info: javascript.0 (21115) script.js.common.Systeminfos.MinMax_per_30Days: Datenwerte berechnet...
    2020-01-26 03:13:20.517  - info: javascript.0 (21115) script.js.common.Systeminfos.MinMax_per_30Days: registered 0 subscriptions and 1 schedule
    2020-01-26 03:13:20.523  - info: javascript.0 (21115) Start javascript script.js.common.Systeminfos.MinMax_per_7Days
    2020-01-26 03:13:20.580  - info: javascript.0 (21115) script.js.common.Systeminfos.MinMax_per_7Days: Datenwerte berechnet...
    2020-01-26 03:13:20.580  - info: javascript.0 (21115) script.js.common.Systeminfos.MinMax_per_7Days: registered 0 subscriptions and 1 schedule
    2020-01-26 03:13:20.602  - info: javascript.0 (21115) Start javascript script.js.common.Test.Telefonnummernsuche
    2020-01-26 03:13:20.623  - info: javascript.0 (21115) script.js.common.Test.Telefonnummernsuche: registered 1 subscription and 0 schedules
    2020-01-26 03:13:20.624  - info: javascript.0 (21115) Start javascript script.js.common.Test.Test_LogSkript1
    2020-01-26 03:13:20.762  - info: javascript.0 (21115) script.js.common.Test.Test_LogSkript1: registered 0 subscriptions and 0 schedules
    2020-01-26 03:13:20.764  - info: javascript.0 (21115) Start javascript script.js.common.System.NodeRED_Commander
    2020-01-26 03:13:20.774  - info: javascript.0 (21115) script.js.common.System.NodeRED_Commander: registered 1 subscription and 0 schedules
    2020-01-26 03:13:20.775  - info: javascript.0 (21115) Start javascript script.js.common.Test.Luftdaten
    2020-01-26 03:13:20.816  - info: javascript.0 (21115) script.js.common.Test.Luftdaten: registered 1 subscription and 1 schedule
    2020-01-26 03:13:20.817  - info: javascript.0 (21115) Start javascript script.js.common.Test.Luftdaten_1
    2020-01-26 03:13:20.843  - info: javascript.0 (21115) script.js.common.Test.Luftdaten_1: registered 0 subscriptions and 1 schedule
    2020-01-26 03:13:23.198  - info: javascript.0 (21115) script.js.common.Data_extern.Lebensmittelwarnung: Daten aktualisiert...
    2020-01-26 03:13:23.241  - info: javascript.0 (21115) script.js.common.Test.Luftdaten: Luftdaten aktualisiert
    2020-01-26 03:13:23.265  - info: javascript.0 (21115) script.js.common.Test.Test_LogSkript1: Start monitoring of the ioBroker log...
    2020-01-26 03:13:25.976  - warn: enigma2.0 (21553) no connection to objects DB
    2020-01-26 03:13:27.604  - warn: influxdb.0 (21562) no connection to objects DB
    2020-01-26 03:13:29.067  - info: mqtt.0 (21179) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mqtt, node: v10.18.1
    2020-01-26 03:13:31.327  - info: host.Ubuntu iobroker npm-install: NPM version: 6.13.4npm install iobroker.tr-064@3.1.0 --loglevel error --prefix "/opt/iobroker" (System call)
    2020-01-26 03:13:31.915  - warn: youtube.0 (21517) no connection to states DB
    2020-01-26 03:13:33.387  - warn: vis.0 (21499) no connection to states DB
    2020-01-26 03:13:33.427  - warn: web.0 (21505) no connection to states DB
    2020-01-26 03:13:42.056  - info: nina.0 (21188) starting. Version 0.0.15 in /opt/iobroker/node_modules/iobroker.nina, node: v10.18.1
    2020-01-26 03:13:44.071  - warn: yr.0 (21537) no connection to states DB
    2020-01-26 03:13:57.003  - info: ping.0 (21262) starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.ping, node: v10.18.1
    2020-01-26 03:13:57.678  - info: odl.0 (21214) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.odl, node: v10.18.1
    2020-01-26 03:13:58.201  - info: mqtt.0 (21179) Starting MQTT ' authenticated  server on port 1883
    2020-01-26 03:13:59.110  - warn: enigma2.0 (21553) no connection to states DB
    2020-01-26 03:13:59.116  - warn: influxdb.0 (21562) no connection to states DB
    2020-01-26 03:13:59.506  - info: iot.0 (21108) Connection changed: connect
    2020-01-26 03:14:07.726  - info: pollenflug.0 (21295) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.pollenflug, node: v10.18.1
    2020-01-26 03:14:07.878  - info: pollenflug.0 (21295) Starting Adapter pollenflug.0 in version 1.0.4
    2020-01-26 03:14:22.224  - info: node-red.0 (21207) starting. Version 1.13.0 in /opt/iobroker/node_modules/iobroker.node-red, node: v10.18.1
    2020-01-26 03:14:22.677  - info: vis-google-fonts.0 (21492) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v10.18.1
    2020-01-26 03:14:22.743  - info: pollenflug.0 (21295) Requesting DWD pollen information now.
    2020-01-26 03:14:23.032  - info: javascript.0 (21115) script.js.common.Test.Luftdaten: Luftdaten aktualisiert
    2020-01-26 03:14:30.757  - info: fritzbox.0 (20956) starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.fritzbox, node: v10.18.1
    2020-01-26 03:14:30.959  - info: fritzbox.0 (20956) try to connect: 192.168.1.1
    2020-01-26 03:14:31.033  - info: fritzbox.0 (20956) adapter connected to fritzbox: 192.168.1.1
    2020-01-26 03:14:31.458  - warn: ping.0 (21262) please update js-controller to at least 1.2.0
    2020-01-26 03:14:32.460  - warn: ping.0 (21262) please update js-controller to at least 1.2.0
    2020-01-26 03:14:33.461  - warn: ping.0 (21262) please update js-controller to at least 1.2.0
    2020-01-26 03:14:34.462  - warn: ping.0 (21262) please update js-controller to at least 1.2.0
    2020-01-26 03:14:35.463  - warn: ping.0 (21262) please update js-controller to at least 1.2.0
    2020-01-26 03:14:36.465  - warn: ping.0 (21262) please update js-controller to at least 1.2.0
    2020-01-26 03:14:37.465  - warn: ping.0 (21262) please update js-controller to at least 1.2.0
    2020-01-26 03:14:38.468  - warn: ping.0 (21262) please update js-controller to at least 1.2.0
    2020-01-26 03:14:46.603  - info: pi-hole.0 (21260) starting. Version 1.2.2 in /opt/iobroker/node_modules/iobroker.pi-hole, node: v10.18.1
    2020-01-26 03:14:47.092  - info: lgtv11.0 (21126) starting. Version 1.0.5 in /opt/iobroker/node_modules/iobroker.lgtv11, node: v10.18.1
    2020-01-26 03:14:47.224  - info: lgtv11.0 (21126) Ready. Configured LG TV IP: 192.168.1.221, Port: 8080, Pairing Key: xxx
    2020-01-26 03:15:12.413  - info: host.Ubuntu instance system.adapter.luftdaten.0 started with pid 21804
    2020-01-26 03:15:13.084  - info: scenes.0 (21357) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.scenes, node: v10.18.1
    2020-01-26 03:15:14.179  - info: radar2.0 (21302) starting. Version 1.0.9 in /opt/iobroker/node_modules/iobroker.radar2, node: v10.18.1
    2020-01-26 03:15:14.232  - info: simple-api.0 (21371) starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.18.1
    2020-01-26 03:15:14.490  - info: simple-api.0 (21371) simpleAPI server listening on port 8087
    2020-01-26 03:15:14.491  - info: simple-api.0 (21371) Allow states only when user is owner: false
    2020-01-26 03:15:14.502  - info: simple-api.0 (21371) http server listening on port 8087
    2020-01-26 03:15:20.883  - info: host.Ubuntu iobroker npm-install: host.Ubuntu install adapter tr-064@3.1.0upload [3] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascriptupload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/pngupload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/htmlupload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index.html index.html text/htmlhost.Ubuntu object system.adapter.tr-064 created/updated
    2020-01-26 03:15:20.894  - error: host.Ubuntu iobroker npm-install: Some packets could not be installed. Please install them manually
    2020-01-26 03:15:24.051  - info: host.Ubuntu iobroker npm-install: exit 0
    2020-01-26 03:15:24.082  - info: host.Ubuntu instance system.adapter.tr-064.0 started with pid 21830
    2020-01-26 03:15:25.012  - info: vis-google-fonts.0 (21492) Terminated (NO_ERROR): Without reason
    2020-01-26 03:15:26.479  - info: node-red.0 (21207) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2020-01-26 03:15:26.923  - warn: luftdaten.0 (21804) no connection to states DB
    2020-01-26 03:15:34.134  - info: host.Ubuntu instance system.adapter.vis-google-fonts.0 terminated while should be started once
    2020-01-26 03:15:34.155  - info: sonoff.0 (21372) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.sonoff, node: v10.18.1
    2020-01-26 03:15:34.308  - info: linkeddevices.0 (21149) [createLinkedObject] linked object 'alexa2.0.Echo-Devices.xxxRRG.Commands.speak' to 'linkeddevices.0.speak'
    2020-01-26 03:15:34.920  - warn: tr-064.0 (21830) no connection to objects DB
    2020-01-26 03:15:35.471  - info: radar2.0 (21302) radar2 initialization started...
    2020-01-26 03:15:35.548  - info: sonoff.0 (21372) Starting MQTT authenticated  server on port 1885
    2020-01-26 03:15:36.027  - info: radar2.0 (21302) Connected with '0.0.0.0' for DHCP Scan
    2020-01-26 03:15:37.165  - info: radar2.0 (21302) found '@abandonware/noble'
    2020-01-26 03:15:37.349  - info: radar2.0 (21302) found 'node-bluetooth'
    2020-01-26 03:15:37.350  - info: radar2.0 (21302) radar2 set to flag items away if they are not seen for 3 minutes
    2020-01-26 03:15:37.352  - info: radar2.0 (21302) use known BT list: []
    2020-01-26 03:15:37.353  - info: radar2.0 (21302) use known IP list: []
    2020-01-26 03:15:37.354  - info: radar2.0 (21302) Remove name end for host names: .fritz.box
    2020-01-26 03:15:37.358  - info: radar2.0 (21302) arp-scan will use the following interfaces: [ 'enp2s0', 'enp1s0', 'enp1s0' ]
    2020-01-26 03:15:37.359  - info: radar2.0 (21302) radar2 set to scan every 20 seconds and printers every 720 minutes.
    2020-01-26 03:15:37.723  - info: radar2.0 (21302) Will try to scan BT devices: false
    2020-01-26 03:15:43.522  - info: sonoff.0 (21372) Client [Wohnzimmer-Nebler] connected with secret xxx
    2020-01-26 03:15:45.261  - info: sourceanalytix.0 (21387) starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.sourceanalytix, node: v10.18.1
    2020-01-26 03:15:45.442  - info: sourceanalytix.0 (21387) Adapter SourceAnalytix startet :-)
    2020-01-26 03:15:45.448  - info: sourceanalytix.0 (21387) Initializing all enabled states for SourceAnalytix
    2020-01-26 03:15:48.163  - info: mqtt.0 (21179) Client [ioBroker] connected with secret xxx
    2020-01-26 03:15:50.492  - warn: node-red.0 (21855) no connection to objects DB
    2020-01-26 03:15:52.803  - info: statistics.0 (21406) starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.statistics, node: v10.18.1
    2020-01-26 03:15:52.985  - info: mqtt.0 (21179) Client [ioBroker] subscribes on topic "/stat/HeizCon/PowerUP"
    2020-01-26 03:15:54.983  - warn: node-red.0 (21207) 26 Jan 03:15:54 - [warn] [moment:f25fb7f2.bf8ab8] The input property was NOT a recognisable date. Output will be a blank string
    2020-01-26 03:15:55.016  - warn: tr-064.0 (21830) no connection to states DB
    2020-01-26 03:16:01.697  - info: host.Ubuntu instance system.adapter.daswetter.0 started with pid 21961
    2020-01-26 03:16:08.069  - info: vis.0 (21499) starting. Version 1.2.3 in /opt/iobroker/node_modules/iobroker.vis, node: v10.18.1
    2020-01-26 03:16:08.364  - info: statistics.0 (21406) [CREATION] enabled statistics for MyOwnData.0.Wetter.Ozon.Ozonwert
    2020-01-26 03:16:08.373  - info: terminal.0 (21433) starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.terminal, node: v10.18.1
    2020-01-26 03:16:08.409  - info: statistics.0 (21406) [INFO] statistics observes 1 values after startup
    2020-01-26 03:16:08.428  - info: statistics.0 (21406) [INFO] monitor "MyOwnData.0.Wetter.Ozon.Ozonwert" as avg
    2020-01-26 03:16:08.430  - info: statistics.0 (21406) [INFO] monitor "MyOwnData.0.Wetter.Ozon.Ozonwert" as minmax
    2020-01-26 03:16:10.614  - warn: daswetter.0 (21961) no connection to objects DB
    2020-01-26 03:16:10.668  - warn: node-red.0 (21855) no connection to states DB
    2020-01-26 03:16:16.145  - info: vis.0 (21499) vis license is OK.
    2020-01-26 03:16:17.103  - info: sayit.0 (21319) starting. Version 1.8.2 in /opt/iobroker/node_modules/iobroker.sayit, node: v10.18.1
    2020-01-26 03:16:17.293  - info: sayit.0 (21319) Upload announce mp3 files
    2020-01-26 03:16:18.553  - info: terminal.0 (21433) http server listening on port 8090
    2020-01-26 03:16:20.979  - info: linkeddevices.0 (21149) [createLinkedObject] linked object 'luftdaten.0.xxx.SDS_P1' to 'linkeddevices.0.SDS_P1'
    2020-01-26 03:16:21.174  - info: radar2.0 (21302) Init item Fritzbox with { name: 'Fritzbox',id: 'Fritzbox',type: 'IP',rip: [ '192.168.1.1' ],hasMAC: [ 'xxx' ],lasthere: '2020-01-26T02:06:17.713Z',anwesend: false }
    2020-01-26 03:16:22.712  - warn: daswetter.0 (21961) no connection to states DB
    2020-01-26 03:16:34.066  - info: upnp.0 (21469) starting. Version 1.0.15 in /opt/iobroker/node_modules/iobroker.upnp, node: v10.18.1
    2020-01-26 03:16:34.221  - info: upnp.0 (21469) Auto discover: false
    2020-01-26 03:16:36.626  - info: sayit.0 (21319) All files uploaded
    2020-01-26 03:16:43.504  - info: tuya.0 (21457) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.tuya, node: v10.18.1
    2020-01-26 03:16:45.593  - info: linkeddevices.0 (21149) [createLinkedObject] linked object 'luftdaten.0.xxx.SDS_P2' to 'linkeddevices.0.SDS_P2'
    2020-01-26 03:16:45.611  - info: linkeddevices.0 (21149) [createAllLinkedObjects] count of active linkedObjects: 3
    2020-01-26 03:16:46.105  - info: linkeddevices.0 (21149) [initialObjects] finished
    2020-01-26 03:16:46.283  - info: radar2.0 (21302) Init item Ubuntu with { name: 'Ubuntu',id: 'Ubuntu',type: 'IP',hasMAC: [ 'xxx' ],ipVendor: 'MITAC INTERNATIONAL CORP.',rip: [ '192.168.1.30' ],lasthere: '2020-01-26T02:06:17.851Z',anwesend: false }
    2020-01-26 03:16:47.317  - info: vis.0 (21499) Terminated (NO_ERROR): Without reason
    2020-01-26 03:16:47.329  - info: linkeddevices.0 (21149) [onObjectChange] parentObject 'alexa2.0.Echo-Devices.xxx.Commands.speak' properties changed
    2020-01-26 03:16:54.014  - info: host.Ubuntu instance system.adapter.vis.0 terminated while should be started once
    2020-01-26 03:16:54.052  - info: youtube.0 (21517) starting. Version 0.0.6 in /opt/iobroker/node_modules/iobroker.youtube, node: v10.18.1
    2020-01-26 03:17:01.434  - info: web.0 (21505) starting. Version 2.4.10 in /opt/iobroker/node_modules/iobroker.web, node: v10.18.1
    2020-01-26 03:17:03.906  - info: radar2.0 (21302) Init item DM920UHD with { name: 'DM920UHD',id: 'DM920UHD',type: 'IP',rip: [ '192.168.1.120' ],lasthere: '2020-01-25T22:57:10.696Z',anwesend: false }
    2020-01-26 03:17:05.178  - info: web.0 (21505) socket.io server listening on port 8082
    2020-01-26 03:17:05.205  - info: web.0 (21505) simpleAPI server listening on port 8082
    2020-01-26 03:17:05.206  - info: web.0 (21505) Allow states only when user is owner: false
    2020-01-26 03:17:05.216  - info: web.0 (21505) http server listening on port 8082
    2020-01-26 03:17:11.116  - info: influxdb.0 (21562) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.influxdb, node: v10.18.1
    2020-01-26 03:17:11.408  - info: linkeddevices.0 (21149) [createLinkedObject] linked object 'alexa2.0.Echo-Devices.xxx.Commands.speak' to 'linkeddevices.0.speak'
    2020-01-26 03:17:11.409  - info: linkeddevices.0 (21149) [onObjectChange] count of active linkedObjects: 3
    2020-01-26 03:17:11.207  - info: influxdb.0 (21562) Buffer initialized with data for 3 points and 0 conflicts from last exit
    2020-01-26 03:17:11.224  - info: influxdb.0 (21562) Connecting http://localhost:8086 ...
    2020-01-26 03:17:11.503  - info: influxdb.0 (21562) Connected!
    2020-01-26 03:17:19.736  - info: trashschedule.0 (21450) starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v10.18.1
    2020-01-26 03:17:19.883  - info: influxdb.0 (21562) enabled logging of Ozonwert, Alias=true, 1 points now activated
    2020-01-26 03:17:19.925  - info: influxdb.0 (21562) enabled logging of PM10, Alias=true, 2 points now activated
    2020-01-26 03:17:19.927  - info: influxdb.0 (21562) enabled logging of PM2.5, Alias=true, 3 points now activated
    2020-01-26 03:17:19.929  - info: influxdb.0 (21562) enabled logging of Strahlendosis, Alias=true, 4 points now activated
    2020-01-26 03:17:21.493  - info: radar2.0 (21302) Init item Windows-VM with { name: 'Windows-VM',id: 'Windows-VM',type: 'IP',rip: [ '192.168.1.140' ],lasthere: '2020-01-25T18:36:51.384Z',anwesend: false }
    2020-01-26 03:17:24.180  - info: youtube.0 (21517) cleaned everything up...
    2020-01-26 03:17:25.684  - info: youtube.0 (21517) Terminated (NO_ERROR): Without reason
    2020-01-26 03:17:28.159  - info: host.Ubuntu instance system.adapter.youtube.0 terminated with code 0 (NO_ERROR)
    2020-01-26 03:17:28.176  - info: luftdaten.0 (21804) starting. Version 0.0.11 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v10.18.1
    2020-01-26 03:17:37.328  - info: tr-064.0 (21830) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.18.1
    2020-01-26 03:17:38.756  - info: radar2.0 (21302) Init item Acer-Laptop with { name: 'Acer-Laptop',id: 'Acer-Laptop',type: 'IP',rip: [ '192.168.1.142' ],lasthere: '2020-01-26T00:00:43.679Z',anwesend: false }
    2020-01-26 03:17:38.815  - info: luftdaten.0 (21804) Terminated (NO_ERROR): Without reason
    2020-01-26 03:17:45.570  - info: host.Ubuntu instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    2020-01-26 03:17:45.668  - info: daswetter.0 (21961) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.18.1
    2020-01-26 03:17:49.046  - info: radar2.0 (21302) Init item NAS-Server with { name: 'NAS-Server',id: 'NAS-Server',type: 'IP',rip: [ '192.168.1.143' ],lasthere: '2020-01-25T18:36:56.991Z',anwesend: false }
    2020-01-26 03:17:56.174  - info: openweathermap.0 (21247) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v10.18.1
    2020-01-26 03:17:59.322  - info: radar2.0 (21302) Init item S20-Wohnzimmer-Nebler with { name: 'S20-Wohnzimmer-Nebler',id: 'S20-Wohnzimmer-Nebler',type: 'IP',hasMAC: [ 'xxx' ],ipVendor: 'Espressif Inc.',rip: [ '192.168.1.152' ],lasthere: '2020-01-26T02:06:17.722Z',anwesend: false }
    2020-01-26 03:17:59.664  - info: tuya.0 (21457) xxx Init with IP=192.168.1.20, Key=xxx, Version=3.1
    2020-01-26 03:17:59.672  - info: tuya.0 (21457) Existing devices initialized
    2020-01-26 03:17:59.733  - info: tuya.0 (21457) Listen for local Tuya devices on port 6666
    2020-01-26 03:17:59.736  - info: tuya.0 (21457) Listen for encrypted local Tuya devices on port 6667
    2020-01-26 03:17:59.967  - info: radar2.0 (21302) Init item LED-Stripe_WoZi-Schrankwand with { name: 'LED-Stripe_WoZi-Schrankwand',id: 'LED-Stripe_WoZi-Schrankwand',type: 'IP',hasMAC: [ 'xxx' ],ipVendor: 'Espressif Inc.',rip: [ '192.168.1.20' ],lasthere: '2020-01-26T02:06:17.714Z',anwesend: false }
    2020-01-26 03:18:09.059  - info: info.0 (21058) starting. Version 1.5.7 in /opt/iobroker/node_modules/iobroker.info, node: v10.18.1
    2020-01-26 03:18:10.550  - info: radar2.0 (21302) Init item LG-TV with { name: 'LG-TV',id: 'LG-TV',type: 'IP',hasMAC: [ 'xxx' ],ipVendor: 'Vendor N/A',rip: [ '192.168.1.221' ],lasthere: '2020-01-25T18:37:15.617Z',anwesend: false }
    2020-01-26 03:18:13.669  - info: info.0 (21058) Reading CPU current speed every 3 seconds.
    2020-01-26 03:18:13.711  - info: info.0 (21058) Reading CPU data every 3 seconds.
    2020-01-26 03:18:14.294  - info: info.0 (21058) Reading disk data every 8 seconds.
    2020-01-26 03:18:15.379  - info: info.0 (21058) Reading memory data every 3 seconds.
    2020-01-26 03:18:15.413  - info: info.0 (21058) Reading CPU temp data every 3 seconds.
    2020-01-26 03:18:16.045  - info: info.0 (21058) Reading user data every 8 seconds.
    2020-01-26 03:18:16.216  - info: info.0 (21058) Reading battery data every 8 seconds.
    2020-01-26 03:18:16.666  - info: info.0 (21058) Popup news was read...
    2020-01-26 03:18:17.943  - info: info.0 (21058) Reading process data every 8 seconds.
    2020-01-26 03:18:21.100  - info: host.Ubuntu instance system.adapter.youtube.0 started with pid 22731
    2020-01-26 03:18:29.364  - info: enigma2.0 (21553) starting. Version 1.2.9 in /opt/iobroker/node_modules/iobroker.enigma2, node: v10.18.1
    2020-01-26 03:18:29.457  - info: enigma2.0 (21553) starting Polling every 30000 ms
    2020-01-26 03:18:29.479  - info: radar2.0 (21302) Init item Broadlink-RM-MINI-3 with { name: 'Broadlink-RM-MINI-3',id: 'Broadlink-RM-MINI-3',type: 'IP',hasMAC: [ 'xxx' ],ipVendor: 'HangZhou Gubei Electronics Technology Co.,Ltd',rip: [ '192.168.1.223' ],lasthere: '2020-01-26T02:06:17.715Z',anwesend: false }
    2020-01-26 03:18:30.304  - warn: youtube.0 (22731) no connection to objects DB
    2020-01-26 03:18:42.043  - info: yr.0 (21537) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v10.18.1
    2020-01-26 03:18:43.017  - info: yr.0 (21537) got weather data from yr.no
    2020-01-26 03:18:46.739  - info: radar2.0 (21302) Init item Wohnzimmer-EchoDot with { name: 'Wohnzimmer-EchoDot',id: 'Wohnzimmer-EchoDot',type: 'IP',hasMAC: [ 'xxx' ],ipVendor: 'Amazon Technologies Inc.',rip: [ '192.168.1.230' ],lasthere: '2020-01-26T02:06:17.717Z',anwesend: false }
    2020-01-26 03:18:55.479  - info: host.Ubuntu instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
    2020-01-26 03:18:55.514  - info: youtube.0 (22731) starting. Version 0.0.6 in /opt/iobroker/node_modules/iobroker.youtube, node: v10.18.1
    2020-01-26 03:18:58.122  - info: radar2.0 (21302) Init item UleFone-Power-3S with { name: 'UleFone-Power-3S',id: 'UleFone-Power-3S',type: 'IP',hasMAC: [ 'xxx' ],ipVendor: 'Tellabs',rip: [ '192.168.1.231' ],lasthere: '2020-01-26T00:01:29.587Z',anwesend: false }
    2020-01-26 03:18:59.999  - info: radar2.0 (21302) Init item RaspberryPi with { name: 'RaspberryPi',id: 'RaspberryPi',type: 'IP',rip: [ '192.168.1.31' ],hasMAC: [ 'xxx' ],lasthere: '2020-01-26T02:06:17.713Z',anwesend: false }
    2020-01-26 03:19:01.755  - info: radar2.0 (21302) Init item Dell-Multifunktionsgerät with { name: 'Dell-Multifunktionsgerät',id: 'Dell-Multifunktionsgerät',type: 'IP',rip: [ '192.168.2.10' ],hasMAC: [ 'xxx' ],lasthere: '2020-01-26T02:06:17.765Z',anwesend: false }
    2020-01-26 03:19:02.604  - info: enigma2.0 (21553) enigma2: 192.168.1.120:80 ist nicht erreichbar!
    2020-01-26 03:19:05.490  - info: openweathermap.0 (21247) Terminated (NO_ERROR): Without reason
    2020-01-26 03:19:06.062  - info: host.Ubuntu instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
    2020-01-26 03:19:13.462  - info: pollenflug.0 (21295) Next DWD pollen request starts on Sun Jan 26 2020 11:00:00 GMT+0100 (GMT+01:00)
    2020-01-26 03:19:15.799  - info: alexa2.0 (20842) Subscribing to states...
    2020-01-26 03:19:23.469  - info: tankerkoenig.0 (21419) starting. Version 2.0.6 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v10.18.1
    2020-01-26 03:19:23.646  - info: tankerkoenig.0 (21419) Sync time set to 16 minutes or 960000 ms
    2020-01-26 03:19:24.665  - warn: tankerkoenig.0 (21419) Please update js-controller to at least 1.2.0
    2020-01-26 03:19:24.683  - info: tankerkoenig.0 (21419) Reading data from tankerkoenig ...
    2020-01-26 03:19:25.631  - info: youtube.0 (22731) cleaned everything up...
    2020-01-26 03:19:27.137  - info: youtube.0 (22731) Terminated (NO_ERROR): Without reason
    2020-01-26 03:19:27.724  - info: host.Ubuntu instance system.adapter.youtube.0 terminated with code 0 (NO_ERROR)
    2020-01-26 03:19:54.918  - info: daswetter.0 (21961) Terminated (NO_ERROR): Without reason
    2020-01-26 03:19:55.460  - info: host.Ubuntu instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2020-01-26 03:20:00.405  - info: host.Ubuntu instance system.adapter.luftdaten.0 started with pid 25620
    2020-01-26 03:20:04.430  - info: host.Ubuntu instance system.adapter.dwd.0 started with pid 25882
    2020-01-26 03:20:12.714  - info: luftdaten.0 (25620) starting. Version 0.0.11 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v10.18.1
    2020-01-26 03:20:12.969  - warn: dwd.0 (25882) no connection to objects DB
    2020-01-26 03:20:17.846  - warn: luftdaten.0 (25620) Error: ESOCKETTIMEDOUT
    2020-01-26 03:20:24.421  - info: luftdaten.0 (25620) Terminated (NO_ERROR): Without reason
    2020-01-26 03:20:24.545  - info: dwd.0 (25882) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.18.1
    2020-01-26 03:20:25.572  - info: host.Ubuntu instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    2020-01-26 03:20:28.916  - info: dwd.0 (25882) Terminated (NO_ERROR): Without reason
    2020-01-26 03:20:29.440  - info: host.Ubuntu instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
    2020-01-26 03:22:06.675  - info: radar2.0 (21302) MyIP Error Error: Request Failed. Status Code: 522at ClientRequest.fun (/opt/iobroker/node_modules/@apollon/frankjoke-myadapter/myAdapter.js:985:35)at Object.onceWrapper (events.js:286:20)at ClientRequest.emit (events.js:198:13)at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:556:21)at HTTPParser.parserOnHeadersComplete (_http_common.js:109:17)at Socket.socketOnData (_http_client.js:442:20)at Socket.emit (events.js:198:13)at addChunk (_stream_readable.js:288:12)at readableAddChunk (_stream_readable.js:269:11)at Socket.Readable.push (_stream_readable.js:224:10)
    2020-01-26 03:22:07.100  - info: radar2.0 (21302) New external IP address 0
    2020-01-26 03:22:07.147  - info: radar2.0 (21302) Adapter identified macs: (xxx...), bts: ()
    2020-01-26 03:22:13.098  - info: radar2.0 (21302) will scan UWZ with code UWZDExxx every 120 minutes
    2020-01-26 03:22:13.118  - info: radar2.0 (21302) radar2 found 14 devices in config (Fritzbox,Ubuntu,DM920UHD,Windows-VM,Acer-Laptop,NAS-Server,S20-Wohnzimmer-Nebler,LED-Stripe_WoZi-Schrankwand,LG-TV,Broadlink-RM-MINI-3,Wohnzimmer-EchoDot,UleFone-Power-3S,RaspberryPi,Dell-Multifunktionsgerät)
    2020-01-26 03:22:13.122  - info: radar2.0 (21302) radar2 set use of noble(true), doArp("-lgq --retry=7 --timeout=600" on enp2s0,enp1s0,enp1s0), btid(0) and doUwz(UWZDExxx,120,0,de,true).
    2020-01-26 03:22:13.376  - info: radar2.0 (21302) UWZ found the following (changed) warnings: No warnings
    2020-01-26 03:23:07.229  - info: radar2.0 (21302) first scan took 53.938 seconds
    2020-01-26 03:23:07.230  - warn: radar2.0 (21302) scanDelay increased to 55.938 seconds!
    2020-01-26 03:23:07.232  - info: radar2.0 (21302) will scan external network every  60  minutes
    Danach läuft er "rund" und NodeRED/DashBoard sind erreichbar/funktionieren.
    LG SBorg ( SBorg auf GitHub)
    • SBorgS SBorg
      @apollon77 Aktuell sind die ganzen Warnings bzgl. "no connection to objects DB" wieder da (ev. erinnerst du dich noch an die 2er Beta-Testphase). So 20-30 Stück beim starten. Der Rest dann die normalen Meldungen der Adapter/Skripte, bis dann nach rund 8 Minuten die Meldung kommt dass der NodeRED startet. ~3 Minuten später ist er dann alive. An der CPU-Last/Speicherauslastung ist auch nix zu erkennen, die bleibt relativ konstant (der benötigte RAM nimmt natürlich zu ;) )
      crunchipC Offline
      crunchipC Offline
      #95
      @SBorg sagte in js-controller 2.2 jetzt im Latest:
      ist nun auch wieder vorhanden
      • DasWetter
      • DWD
      • weatherunderground
        • DasWetter
        • DWD
        #96
        @crunchip ok .... hm ... welche cpu Auslastung hat der js-Controller? Was steht so grob bei system.host.name.evenLoopLag ... vor allem wenn so ein Adapter startet?
          crunchipC Offline
          crunchipC Offline
          #97
          @apollon77
          hab ich ne Zeitlang beobachtet...liegt so zwischen 1 und 21ms, in der Regel jedoch bei 1-2ms
          cpu host schwankt zwischen 24 und 45%, in der Regel bei rund 27%
          neustart der instanz weather...lag die cpu bei 82%
          bei wetter und dwd blieb alles unaufällig
          die "no connection to objects DB" kommen bei diesen drei Adaptern nicht beim starten, sondern im laufe des Tages mittendrin mal, aufgefallen ist es mir seit paar Tagen beim DWD,
          seit js-controller aktualisierung, kamen dann daswetter und weatherunderground dazu
            @apollon77
            #98
            @crunchip Also nur manchmal? Kann sein das die drei Adapter (die übrigens alle sehr viele Objekte und Daten durch die Gegend schubsen) zeitlich ungefähr gleich laufen? Dann kann es sein das js-controller zu dem zeitpunkt einfach sehr viel zu tun hat und daher neue Adapter mehr Zeit brauchen um zu starten.
            Ich würde es aber aktuell mal solassen - ich kann nur die Wartezeit erhöhen ... aber ich sage es mal so: Wenn das auftritt dann ist das ein Zeichen das das System an gewisse grenzen stösst ... und man muss überlegen was man daran verbessert (oder ob man es so lässt)
            • apollon77A Offline
              #99
              So und passend zu dem kommenden Stable Release hier ist jetzt Admin 3.7.8 da was final die Custom-Probleme mit Material behebe sollte und auch noch das Download von Javascript exports fixt :-)
              Kommt denke über Nacht ins Latest ... also Thema für morgen früh liebe Tester @Diginix
              DiginixD Archimedeus AA 2 Antworten Letzte Antwort
                DiginixD Offline
                DiginixD Offline
                Diginix
                #100
                @apollon77 JA, Problem mit den eliminierten MaterialUI Einstellungen ist mit admin 3.7.8 gelöst 👍 😁
                ..:: So long! Tom ::..
                  Archimedeus AA Offline
                  Archimedeus A
                  #101
                  @apollon77
                  Update geht nicht. Habe nach Anleitung iobroker stop und update self gemacht.
                  Problem: Ich kann nicht auf den Admin-Update-Kringel klicken.
                  Was mach ich falsch?
                  GlasfaserG DiginixD 2 Antworten Letzte Antwort
                  • Archimedeus AA Offline
                    Archimedeus A
                    #102
                    Hab todesmutig npm install iobroker.admin gemacht, keine Änderung.
                    • Archimedeus AA Archimedeus A
                      @apollon77
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #103
                      @Archimedeus-A sagte in js-controller 2.2 jetzt im Latest:
                      • E Offline
                        Einstein67
                        schrieb am zuletzt editiert von Einstein67
                        #104
                        @apollon77
                        ~~Hab gerade eine frische IOBroker Installation gemacht. Mit JS-2.2.8 und Admin 3.7.8 ohne Update/Upgrade
                        Jetzt lassen sie bei laufenden IOBroker wieder keine Instanzen/Adapter löschen. Über Konsole kein Problem.
                        Das hatten wir doch schon mal ....~~
                        EDIT! SORRY Falscher Alarm nach einem Neustart funktioniert das löschen auch über die GUI!
                          @apollon77
                          DiginixD Offline
                          DiginixD Offline
                          Diginix
                          #105
                          @Archimedeus-A Du bist hier im Thread JS-Controller 2.2 und hast aber selbst noch einen 1.x laufen.
                          Neuere Adapter verlangen den JS-Controller 2.x, wie zB der Admin ab 3.7.8. Du musst also mal dein JS-Controller aktualisieren und falls es beim Admin dann immer noch Probleme gibt, wäre der Thread zum admin Adapter der richtige.
                          Archimedeus AA 1 Antwort Letzte Antwort
                            #106
                            Ach übrigens ... js-Controller 2.2.8 ist dann jetzt im stable genauso wie Admin 3.7.8. Ich bedanke mich bei Euch allen wieder einmal für den grandiosen Test Support !!
                            Aber nach dem Update ist ja bekanntlich vordem Update ... Die 2.3 vom Controller sollte ca. Ende März dann für erste Tests bereitstehen ;-)
                            • DiginixD Diginix
                              Archimedeus A
                              #107
                              @Diginix Ja wenn ich nur wüsste, wie. Habe genau gemacht was oben steht. Zusätzlich den installationsfixer laufen gelassen und dann
                              sudo -H -u iobroker npm install iobroker.js-controller
                              mit diesem Output:
                                  Your installation was fixed successfully
                                  Run iobroker start to start ioBroker again!
                              pi@ioBroker-Pi:~ $
                              pi@ioBroker-Pi:~ $ sudo -H -u iobroker npm install iobroker.js-controller
                              npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
                              npm WARN checkPermissions Missing write access to /home/pi/node_modules/@types
                              npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                              npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
                              npm WARN pi No description
                              npm WARN pi No repository field.
                              npm WARN pi No README data
                              npm WARN pi No license field.
                              npm ERR! code EACCES
                              npm ERR! syscall access
                              npm ERR! path /home/pi/node_modules/@types
                              npm ERR! errno -13
                              npm ERR! Error: EACCES: permission denied, access '/home/pi/node_modules/@types'
                              npm ERR!  { [Error: EACCES: permission denied, access '/home/pi/node_modules/@types']
                              npm ERR!   stack:
                              npm ERR!    'Error: EACCES: permission denied, access \'/home/pi/node_modules/@types\'',
                              npm ERR!   errno: -13,
                              npm ERR!   code: 'EACCES',
                              npm ERR!   syscall: 'access',
                              npm ERR!   path: '/home/pi/node_modules/@types' }
                              npm ERR!
                              npm ERR! The operation was rejected by your operating system.
                              npm ERR! It is likely you do not have the permissions to access this file as the current user
                              npm ERR!
                              npm ERR! If you believe this might be a permissions issue, please double-check the
                              npm ERR! permissions of the file and its containing directories, or try running
                              npm ERR! the command again as root/Administrator.
                              npm ERR!     /home/iobroker/.npm/_logs/2020-01-27T19_09_18_211Z-debug.log
                                Archimedeus A
                                #108
                                @Diginix Oh wunder, der iobroker upgrade self hat was gemacht, konnte jetzt den admin updaten. Cool!
                                • crunchipC Offline
                                  crunchipC Offline
                                  #109
                                  wenn ich den js-controller update, sollte doch node.js auch mit aktualisiert werden, oder irre ich mich jetzt?
                                  J apollon77A 2 Antworten Letzte Antwort
                                    Jan1
                                    #110
                                    @crunchip
                                    Ja weil das eine mit dem anderen nichts zu tun hat. Node wird über System Update aktualisiert und wenn man z.B auf 12 hoch will muss das manuell erledigt werden.
                                      mit diesem Output:
                                      pi@ioBroker-Pi:~ $
                                      npm ERR! errno -13
                                      npm ERR!   stack:
                                      npm ERR!
                                      npm ERR!
                                      #111
                                      @Archimedeus-A Naja wer per npm installiert sollte dies in /opt/iobroker tun und nicht im home vom pi User :-)
                                        #112
                                        @crunchip Nur wenn es mit dem neuen Windows-Installer gemacht wird ist das so ... Linux ist nodejs getrennt
                                          #113
                                          Hi All,
                                          aus gegebenem Anlass (eine Sub-Dependency Library hat es geschafft Ihre Nodejs kompatibilität nicht sauber zu halten und somit kann der controller 2.2.8 mit nodejs 8 ggf crashen) habe ich soeben eine 2.2.9 des js-controller auf npm und es sollte damit in den nächsten Stunden im Latest Repository auftauchen. Zur Installation gilt die Anleitung von oben weiterhin.
                                          Neben dem Downgrade dieser Library habe ich noch ein paar Fixes reingenommen die sich seitdem angesammelt haben.
                                          Changelog:
                                          2.2.9 (2020-02-12) Release Dina
                                          • (Apollon77) fix pot. crash for edge cases
                                          • (Apollon77) allow to deactivate logfile zipping by iobroker.json (for non-windows systems)
                                          • (Apollon77) make sure sigKill state only handles number values (fixes #638)
                                          • (bluefox) add better checks for file CLI commands
                                          • (Apollon77) make sure directly is created before writing meta data and send redis error correctly, prevent controller crash (fixes #644)
                                          • (foxriver76) optimize package manager handling (fixes #631)
                                          • (Apollon77) make sure deleting running instances does not crash js-controller (fixes #658)
                                          • (Apollon77) Downgrade semver to stay compatible with nodejs 8
                                          Die nächste Version des js-controller (vorauss. Ende März) wird aus dem Grund die Version 3.0 werden und nodejs 8 nicht mehr untersützen können.
                                          Viel Spass,
                                          Ingo
