  4. Beta-Test js-controller 2.2.x GitHub
js-controllerbetagithub
169 Beiträge 18 Kommentatoren 36.2k Aufrufe 22 Beobachtet
  • apollon77A apollon77
    @crunchip Dann bitte Admin Issue afuf machen
    crunchipC Offline
    crunchipC Offline
    #142
    @apollon77 js-controller angehoben auf 2.2.7
    erst mal Frage 1, ist das so ok?
     iobroker.js-controller@2.2.7 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.13.4
    > iobroker.js-controller@2.2.7 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    The following notifications happened during sync:
    - Ignoring Directory "cloud.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "icons-material-svg" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "icons-material-svg.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "icons-mfd-svg" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "icons-mfd-svg.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "iobroker.admin.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "iobroker.discovery.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "multicast.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "nightscout.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "sayit.0" because officially not created as meta object. Please remove directory!
    npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    + iobroker.js-controller@2.2.7
    added 112 packages from 485 contributors, removed 1 package and updated 6 packages in 502.517s
    2 packages are looking for funding
      run `npm fund` for details
    root@IoBroker:/opt/iobroker# iobroker start
    root@IoBroker:/opt/iobroker# npm fund
    iobroker.inst@2.0.3
    ├─┬ ansi-styles@4.2.1
    │ └── url: https://github.com/chalk/ansi-styles?sponsor=1
    └─┬ sinon@8.0.2
      ├── type: opencollective
      └── url: https://opencollective.com/sinon
    zum Problem, nach iobroker start
    ein Auszug aus dem log
    2020-01-04 23:16:46.889 - info: radar2.0 (15100) radar2 initialization started...
    2020-01-04 23:16:46.891 - info: radar2.0 (15100) radar2 starting main...
    2020-01-04 23:16:46.912 - info: radar2.0 (15100) found and will use 'node-bluetooth scan'
    2020-01-04 23:16:47.124 - info: radar2.0 (15100) found and will use '@abandonware/noble'
    2020-01-04 23:16:47.147 - info: radar2.0 (15100) net-ping not available! Will try to use normal ping!
    2020-01-04 23:16:47.155 - info: radar2.0 (15100) radar2 set to flag items away if they are not seen for 2 minutes
    2020-01-04 23:16:47.161 - info: radar2.0 (15100) use known BT list: [ 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx' ]
    2020-01-04 23:16:47.162 - info: radar2.0 (15100) use known IP list: []
    2020-01-04 23:16:47.163 - info: radar2.0 (15100) arp-scan will use the following interfaces: [ 'ens18' ]
    2020-01-04 23:16:47.163 - info: radar2.0 (15100) radar2 set to scan every 30 seconds and printers every 720 minutes.
    2020-01-04 23:16:47.195 - error: radar2.0 (15100) uncaught exception: bind EACCES 0.0.0.0:67
    2020-01-04 23:16:47.196 - error: radar2.0 (15100) Error: bind EACCES 0.0.0.0:67
    at state.handle.lookup (dgram.js:242:18)
    at process._tickCallback (internal/process/next_tick.js:63:19)
    2020-01-04 23:16:47.198 - info: radar2.0 (15100) Adapter disconnected and stopped with dostop(false) and callback(true)
    2020-01-04 23:16:47.213 - warn: radar2.0 (15100) Adapter will exit in latest 1 sec with code false!
    2020-01-04 23:16:47.308 - info: radar2.0 (15100) Will try to scan BT devices: true
    2020-01-04 23:16:47.329 - info: radar2.0 (15100) terminating
    2020-01-04 23:16:47.331 - info: radar2.0 (15100) Terminated (NO_ERROR): Without reason
    2020-01-04 23:16:47.725 - info: roadtraffic.0 (15116) starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.roadtraffic, node: v10.18.0
    2020-01-04 23:16:47.881 - error: host.IoBroker Caught by controller[0]: { Error: bind EACCES 0.0.0.0:67
    2020-01-04 23:16:47.882 - error: host.IoBroker Caught by controller[0]: at state.handle.lookup (dgram.js:242:18)
    2020-01-04 23:16:47.882 - error: host.IoBroker Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:63:19)
    2020-01-04 23:16:47.882 - error: host.IoBroker Caught by controller[0]: errno: 'EACCES',
    2020-01-04 23:16:47.882 - error: host.IoBroker Caught by controller[0]: code: 'EACCES',
    2020-01-04 23:16:47.883 - error: host.IoBroker Caught by controller[0]: syscall: 'bind',
    2020-01-04 23:16:47.883 - error: host.IoBroker Caught by controller[0]: address: '0.0.0.0',
    2020-01-04 23:16:47.883 - error: host.IoBroker Caught by controller[0]: port: 67 }
    2020-01-04 23:16:47.883 - info: host.IoBroker instance system.adapter.radar2.0 terminated with code 0 (NO_ERROR)
    2020-01-04 23:16:47.883 - info: host.IoBroker Restart adapter system.adapter.radar2.0 because enabled
    2020-01-04 23:16:54.594 - info: amazon-dash.0 (15158) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v10.18.0
    2020-01-04 23:16:54.627 - info: amazon-dash.0 (15158) starting pcap session on default interface
    2020-01-04 23:16:54.642 - error: amazon-dash.0 (15158) uncaught exception: socket: Operation not permitted
    2020-01-04 23:16:54.642 - error: amazon-dash.0 (15158) Error: socket: Operation not permitted
    at new PcapSession (/opt/iobroker/node_modules/pcap/pcap.js:49:39)
    at Object.exports.createSession (/opt/iobroker/node_modules/pcap/pcap.js:123:12)
    at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:78:29)
    at Adapter. (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:43:5)
    2020-01-04 23:16:54.994 - info: radar2.0 (15147) radar2 initialization started...
    2020-01-04 23:16:54.996 - info: radar2.0 (15147) radar2 starting main...
    2020-01-04 23:16:55.016 - info: radar2.0 (15147) found and will use 'node-bluetooth scan'
    2020-01-04 23:16:55.302 - info: radar2.0 (15147) found and will use '@abandonware/noble'
    2020-01-04 23:16:55.322 - info: radar2.0 (15147) net-ping not available! Will try to use normal ping!
    2020-01-04 23:16:55.331 - info: radar2.0 (15147) radar2 set to flag items away if they are not seen for 2 minutes
    2020-01-04 23:16:55.340 - info: radar2.0 (15147) use known BT list: [ 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx' ]
    2020-01-04 23:16:55.340 - info: radar2.0 (15147) use known IP list: []
    2020-01-04 23:16:55.342 - info: radar2.0 (15147) arp-scan will use the following interfaces: [ 'ens18' ]
    2020-01-04 23:16:55.342 - info: radar2.0 (15147) radar2 set to scan every 30 seconds and printers every 720 minutes.
    2020-01-04 23:16:55.419 - error: radar2.0 (15147) uncaught exception: bind EACCES 0.0.0.0:67
    2020-01-04 23:16:55.420 - error: radar2.0 (15147) Error: bind EACCES 0.0.0.0:67
    2020-01-04 23:16:55.422 - info: radar2.0 (15147) Adapter disconnected and stopped with dostop(false) and callback(true)
    2020-01-04 23:16:55.434 - warn: radar2.0 (15147) Adapter will exit in latest 1 sec with code false!
    2020-01-04 23:16:55.524 - info: radar2.0 (15147) Will try to scan BT devices: true
    2020-01-04 23:16:55.570 - error: host.IoBroker Caught by controller[0]: Error: socket: Operation not permitted
    2020-01-04 23:16:55.580 - info: simple-api.0 (15177) starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.18.0
    2020-01-04 23:16:55.571 - error: host.IoBroker Caught by controller[0]: at new PcapSession (/opt/iobroker/node_modules/pcap/pcap.js:49:39)
    2020-01-04 23:16:55.571 - error: host.IoBroker Caught by controller[0]: at Object.exports.createSession (/opt/iobroker/node_modules/pcap/pcap.js:123:12)
    2020-01-04 23:16:55.571 - error: host.IoBroker Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:78:29)
    2020-01-04 23:16:55.571 - error: host.IoBroker Caught by controller[0]: at Adapter. (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:43:5)
    2020-01-04 23:16:55.572 - error: host.IoBroker Caught by controller[0]: at Adapter.emit (events.js:198:13)
    2020-01-04 23:16:55.572 - error: host.IoBroker Caught by controller[0]: at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7115:22)
    2020-01-04 23:16:55.572 - error: host.IoBroker Caught by controller[0]: at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6812:25)
    2020-01-04 23:16:55.572 - error: host.IoBroker Caught by controller[0]: at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:685:17)
    2020-01-04 23:16:55.572 - error: host.IoBroker Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    2020-01-04 23:16:55.572 - error: host.IoBroker Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    2020-01-04 23:16:55.573 - info: host.IoBroker instance system.adapter.amazon-dash.0 terminated with code 0 (NO_ERROR)
    2020-01-04 23:16:55.573 - info: host.IoBroker Restart adapter system.adapter.amazon-dash.0 because enabled
    2020-01-04 23:16:55.674 - info: simple-api.0 (15177) simpleAPI server listening on port 8087
    2020-01-04 23:16:55.676 - info: simple-api.0 (15177) Allow states only when user is owner: false
    2020-01-04 23:16:55.687 - info: simple-api.0 (15177) http server listening on port 8087
    2020-01-04 23:16:55.796 - info: radar2.0 (15147) terminating
    2020-01-04 23:16:55.799 - info: radar2.0 (15147) Terminated (NO_ERROR): Without reason
    2020-01-04 23:16:56.347 - error: host.IoBroker Caught by controller[0]: { Error: bind EACCES 0.0.0.0:67
    2020-01-04 23:16:56.348 - error: host.IoBroker Caught by controller[0]: at state.handle.lookup (dgram.js:242:18)
    2020-01-04 23:16:56.348 - error: host.IoBroker Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:63:19)
    2020-01-04 23:16:56.348 - error: host.IoBroker Caught by controller[0]: errno: 'EACCES',
    2020-01-04 23:16:56.349 - error: host.IoBroker Caught by controller[0]: code: 'EACCES',
    2020-01-04 23:16:56.349 - error: host.IoBroker Caught by controller[0]: syscall: 'bind',
    2020-01-04 23:16:56.349 - error: host.IoBroker Caught by controller[0]: address: '0.0.0.0',
    2020-01-04 23:16:56.349 - error: host.IoBroker Caught by controller[0]: port: 67 }
    2020-01-04 23:16:56.349 - info: host.IoBroker instance system.adapter.radar2.0 terminated with code 0 (NO_ERROR)
    2020-01-04 23:16:56.349 - info: host.IoBroker Restart adapter system.adapter.radar2.0 because enabled
    2020-01-04 23:17:39.364 - info: radar2.0 (15452) radar2 initialization started...
    2020-01-04 23:17:39.367 - info: radar2.0 (15452) radar2 starting main...
    2020-01-04 23:17:39.384 - info: radar2.0 (15452) found and will use 'node-bluetooth scan'
    2020-01-04 23:17:39.655 - info: radar2.0 (15452) found and will use '@abandonware/noble'
    2020-01-04 23:17:39.673 - info: radar2.0 (15452) net-ping not available! Will try to use normal ping!
    2020-01-04 23:17:39.680 - info: radar2.0 (15452) radar2 set to flag items away if they are not seen for 2 minutes
    2020-01-04 23:17:39.686 - info: radar2.0 (15452) use known BT list: [ 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx' ]
    2020-01-04 23:17:39.687 - info: radar2.0 (15452) use known IP list: []
    2020-01-04 23:17:39.688 - info: radar2.0 (15452) arp-scan will use the following interfaces: [ 'ens18' ]
    2020-01-04 23:17:39.689 - info: radar2.0 (15452) radar2 set to scan every 30 seconds and printers every 720 minutes.
    2020-01-04 23:17:39.722 - error: radar2.0 (15452) uncaught exception: bind EACCES 0.0.0.0:67
    2020-01-04 23:17:39.723 - error: radar2.0 (15452) Error: bind EACCES 0.0.0.0:67
    2020-01-04 23:17:39.724 - info: radar2.0 (15452) Adapter disconnected and stopped with dostop(false) and callback(true)
    2020-01-04 23:17:39.739 - warn: radar2.0 (15452) Adapter will exit in latest 1 sec with code false!
    2020-01-04 23:17:39.834 - info: radar2.0 (15452) Will try to scan BT devices: true
    2020-01-04 23:17:40.647 - info: radar2.0 (15452) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2020-01-04 23:17:41.274 - error: host.IoBroker instance system.adapter.radar2.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2020-01-04 23:17:41.276 - info: host.IoBroker Do not restart adapter system.adapter.radar2.0 because desired by instance
    2020-01-04 23:18:00.474 - info: host.IoBroker instance system.adapter.amazon-dash.0 started with pid 15591
    2020-01-04 23:18:00.882 - info: host.IoBroker instance system.adapter.fullcalendar.0 started with pid 15598
    2020-01-04 23:18:03.556 - info: amazon-dash.0 (15591) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v10.18.0
    2020-01-04 23:18:03.606 - info: amazon-dash.0 (15591) starting pcap session on default interface
    2020-01-04 23:18:03.621 - error: amazon-dash.0 (15591) uncaught exception: socket: Operation not permitted
    2020-01-04 23:18:03.621 - error: amazon-dash.0 (15591) Error: socket: Operation not permitted
    2020-01-04 23:18:03.623 - info: amazon-dash.0 (15591) cleaned everything up...
    2020-01-04 23:18:03.696 - info: amazon-dash.0 (15591) terminating
    2020-01-04 23:18:03.698 - info: amazon-dash.0 (15591) Terminated (NO_ERROR): Without reason
    2020-01-04 23:18:04.118 - info: web.0 (15560) ==>Connected system.user.admin from ::ffff:10.1.1.97
    2020-01-04 23:18:04.312 - info: web.0 (15560) <==Disconnect system.user.admin from ::ffff:10.1.1.97 vis.0
    2020-01-04 23:18:04.321 - error: host.IoBroker Caught by controller[0]: Error: socket: Operation not permitted
    2020-01-04 23:18:04.322 - error: host.IoBroker Caught by controller[0]: at new PcapSession (/opt/iobroker/node_modules/pcap/pcap.js:49:39)
    2020-01-04 23:18:04.322 - error: host.IoBroker Caught by controller[0]: at Object.exports.createSession (/opt/iobroker/node_modules/pcap/pcap.js:123:12)
    2020-01-04 23:18:04.322 - error: host.IoBroker Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:78:29)
    2020-01-04 23:18:04.322 - error: host.IoBroker Caught by controller[0]: at Adapter. (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:43:5)
    2020-01-04 23:18:04.322 - error: host.IoBroker Caught by controller[0]: at Adapter.emit (events.js:198:13)
    2020-01-04 23:18:04.323 - error: host.IoBroker Caught by controller[0]: at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7115:22)
    2020-01-04 23:18:04.323 - error: host.IoBroker Caught by controller[0]: at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6812:25)
    2020-01-04 23:18:04.323 - error: host.IoBroker Caught by controller[0]: at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:685:17)
    2020-01-04 23:18:04.323 - error: host.IoBroker Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    2020-01-04 23:18:04.323 - error: host.IoBroker Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    2020-01-04 23:18:04.323 - info: host.IoBroker instance system.adapter.amazon-dash.0 terminated with code 0 (NO_ERROR)
    2020-01-04 23:18:04.324 - info: host.IoBroker Restart adapter system.adapter.amazon-dash.0 because enabled
      NPM version: 6.13.4
      iobroker.inst@2.0.3
      └─┬ sinon@8.0.2
      apollon77A Online
      apollon77A Online
      #143
      @crunchip 1.) Die Anmerkungen beim installieren zu "file storage Verzeichnisse" die bei Dir existieren aber nicht offiziell bekannt sind. Kannst Du ignorieren oder überlegen woher es kommt.
      Rest sind "permission" Probleme. Installation FIxer laufen lassen
        crunchipC Offline
        crunchipC Offline
        #144
        @apollon77
        zu 1.
        nightscout, multicast und cloud, waren kürzlich installiert, sind aber eigentlich deinstalliert, der Rest ist am laufen(auch der sayit, discovery)
        hast du noch ne Idee was es mit dem auf sich hat? kann damit nix anfangen
        iobroker.inst@2.0.3
        └─┬ sinon@8.0.2
        der Rest läuft erstmal wieder, dann teste ich nun den Admin
          @apollon77
          zu 1.
          iobroker.inst@2.0.3
          └─┬ sinon@8.0.2
          apollon77A Online
          apollon77A Online
          #145
          @crunchip sagte in Beta-Test js-controller 2.2.x GitHub:
          1.) Mag sein das die Ihre FOlder nicht klar definiert angelegt haben. Kannst Du erstmal ignorieren
          2.)
          run npm fund for details
          fundig = Spenden ...
            2.)
            crunchipC Offline
            crunchipC Offline
            #146
            @apollon77 ok, danke für die Rückmeldung
            hab auch etwas positives zu vermelden
            Admin funktioniert nun👍
              crunchipC Offline
              crunchipC Offline
              #147
              @apollon77 kann/soll ichs schliessen?
                apollon77A Online
                apollon77A Online
                #148
                @crunchip ja bitte
                • apollon77A Online
                  apollon77A Online
                  #149
                  Wenn keiner etwas einzuwenden hat kommt die 2.2.7 heute Abend ins Stable. Gibt keine weitern Änderungen.
                  • apollon77A Online
                    apollon77A Online
                    #150
                    Es gibt gerade noch ein Admin Update was Dinge in de 3.7.6 fixt. Please check.
                      crunchipC Offline
                      crunchipC Offline
                      #151
                      @apollon77 läuft 👍
                      • apollon77A Online
                        apollon77A Online
                        #152
                        So, ab ins Latest :-)
                        --> https://forum.iobroker.net/topic/28557/js-controller-2-2-jetzt-im-latest
                        Die 2.2.7 im Latest Repo entspricht der 2.2.7 vom GitHub von vor ein paar Tagen.
                        Ich lasse den Thread hier noch ein paar Tage offen ...
                        • sentinelS Offline
                          sentinelS Offline
                          sentinel
                          #153
                          Admin Update und Controller Update laufen sauber durch. Alle Scripte funktionieren.
                          Vielen Dank.
                          • E Einstein67
                            @apollon77 said in Beta-Test js-controller 2.2.x GitHub:
                            So krasses hätte ich keine Idee
                            Auch bei mir waren es nach dem Update von Admin und JS-Controller, über 300MB weniger.
                            Seither steigt der Verbrauch wieder leicht an. Ich vermute als Ursache den IOBroker Neustart. Werde morgen früh nochmal nachsehen, ob ich wieder bei 800MB bin.
                            crunchipC Offline
                            crunchipC Offline
                            #154
                            @Einstein67 von Reduzierung ist bei mir nicht die Rede, mein Ram ist deutlich gestiegen und auch CPU minimal
                            Redis wird zur Zeit nicht genutzt, steht auf file/file
                              darkiop
                              schrieb am zuletzt editiert von darkiop
                              #155
                              @apollon77 Guten Morgen, heute Morgen hatte ich zum zweiten Mal einen nicht erreichbaren ioBroker mit der 2.2.7. Siehe Log. Auslöser war wohl die Log-Rotation:
                              2020-01-19 00:00:00.036  - info: host.iobroker-master instance system.adapter.tvspielfilm.0 started with pid 12449
                              2020-01-19 00:00:00.010  - info: bring.0 (20403) Scheduled restart.
                              2020-01-19 00:00:00.051  - info: bring.0 (20403) [END] Stopping Bring! adapter...
                              2020-01-19 00:00:00.089  - info: bring.0 (20403) terminating
                              2020-01-19 00:00:00.090  - info: bring.0 (20403) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:00.141  - error: host.iobroker-master uncaught exception: ENOENT: no such file or directory, unlink '/opt/iobroker/log/iobroker.2020-01-18.log'
                              2020-01-19 00:00:00.176  - info: javascript.0 (1993) script.js.PRODUKTIV.Energie.Stromzaehler.stromzaehler_statistik_waermepumpe_bezug: Aus: 18200.66 - 18199.49 = 1169.9999999982538
                              2020-01-19 00:00:00.195  - info: javascript.0 (1993) script.js.PRODUKTIV.Energie.Stromzaehler.stromzaehler_statistik_pv_wechselrichter: Aus: 77002 - 77002 = 0
                              2020-01-19 00:00:00.200  - info: javascript.0 (1993) script.js.PRODUKTIV.Energie.Stromzaehler.stromzaehler_statistik_hausstrom_einspeisung: Aus: 68797.25 - 68797.25 = 0
                              2020-01-19 00:00:00.209  - info: javascript.0 (1993) script.js.PRODUKTIV.Energie.Stromzaehler.stromzaehler_statistik_hausstrom_bezug: Aus: 10596.74 - 10596.46 = 280.00000000029104
                              2020-01-19 00:00:00.142  - error: host.iobroker-master Error: ENOENT: no such file or directory, unlink '/opt/iobroker/log/iobroker.2020-01-18.log'
                                  at Object.unlinkSync (fs.js:956:3)
                                  at WriteStream.<anonymous> (/opt/iobroker/node_modules/winston-daily-rotate-file/daily-rotate-file.js:128:24)
                                  at WriteStream.emit (events.js:203:15)
                                  at finishMaybe (_stream_writable.js:646:14)
                                  at stream._final (_stream_writable.js:624:5)
                                  at WriteStream._final (internal/fs/streams.js:268:3)
                                  at callFinal (_stream_writable.js:617:10)
                              2020-01-19 00:00:00.144  - info: host.iobroker-master stopInstance system.adapter.admin.0 (force=false, process=true)
                              2020-01-19 00:00:00.145  - info: host.iobroker-master stopInstance system.adapter.backitup.0 (force=false, process=true)
                              2020-01-19 00:00:00.145  - info: host.iobroker-master stopInstance system.adapter.bring.0 (force=false, process=true)
                              2020-01-19 00:00:00.146  - info: host.iobroker-master stopInstance system.adapter.daswetter.0 (force=false, process=false)
                              2020-01-19 00:00:00.147  - info: host.iobroker-master stopInstance canceled schedule system.adapter.daswetter.0
                              2020-01-19 00:00:00.148  - info: host.iobroker-master stopInstance system.adapter.discovery.0 (force=false, process=false)
                              2020-01-19 00:00:00.149  - info: host.iobroker-master stopInstance system.adapter.dwd.0 (force=false, process=false)
                              2020-01-19 00:00:00.150  - info: host.iobroker-master stopInstance canceled schedule system.adapter.dwd.0
                              2020-01-19 00:00:00.151  - info: host.iobroker-master stopInstance system.adapter.feiertage.0 (force=false, process=false)
                              2020-01-19 00:00:00.152  - info: host.iobroker-master stopInstance canceled schedule system.adapter.feiertage.0
                              2020-01-19 00:00:00.152  - info: host.iobroker-master stopInstance system.adapter.habpanel.0 (force=false, process=false)
                              2020-01-19 00:00:00.152  - info: host.iobroker-master stopInstance system.adapter.harmony.0 (force=false, process=true)
                              2020-01-19 00:00:00.153  - info: host.iobroker-master stopInstance system.adapter.hm-rega.0 (force=false, process=true)
                              2020-01-19 00:00:00.154  - info: host.iobroker-master stopInstance system.adapter.hm-rpc.0 (force=false, process=false)
                              2020-01-19 00:00:00.154  - info: host.iobroker-master stopInstance system.adapter.hm-rpc.1 (force=false, process=true)
                              2020-01-19 00:00:00.157  - info: host.iobroker-master stopInstance system.adapter.hm-rpc.2 (force=false, process=true)
                              2020-01-19 00:00:00.158  - info: host.iobroker-master stopInstance system.adapter.hs100.0 (force=false, process=true)
                              2020-01-19 00:00:00.159  - info: host.iobroker-master stopInstance system.adapter.hue.0 (force=false, process=true)
                              2020-01-19 00:00:00.159  - info: host.iobroker-master stopInstance system.adapter.ical.0 (force=false, process=false)
                              2020-01-19 00:00:00.160  - info: host.iobroker-master stopInstance canceled schedule system.adapter.ical.0
                              2020-01-19 00:00:00.160  - info: host.iobroker-master stopInstance system.adapter.ical.1 (force=false, process=false)
                              2020-01-19 00:00:00.161  - info: host.iobroker-master stopInstance canceled schedule system.adapter.ical.1
                              2020-01-19 00:00:00.161  - info: host.iobroker-master stopInstance system.adapter.ical.2 (force=false, process=false)
                              2020-01-19 00:00:00.162  - info: host.iobroker-master stopInstance canceled schedule system.adapter.ical.2
                              2020-01-19 00:00:00.162  - info: host.iobroker-master stopInstance system.adapter.ical.3 (force=false, process=false)
                              2020-01-19 00:00:00.164  - info: host.iobroker-master stopInstance canceled schedule system.adapter.ical.3
                              2020-01-19 00:00:00.164  - info: host.iobroker-master stopInstance system.adapter.ical.4 (force=false, process=false)
                              2020-01-19 00:00:00.165  - info: host.iobroker-master stopInstance canceled schedule system.adapter.ical.4
                              2020-01-19 00:00:00.165  - info: host.iobroker-master stopInstance system.adapter.ical.5 (force=false, process=false)
                              2020-01-19 00:00:00.166  - info: host.iobroker-master stopInstance canceled schedule system.adapter.ical.5
                              2020-01-19 00:00:00.166  - info: host.iobroker-master stopInstance system.adapter.javascript.0 (force=false, process=true)
                              2020-01-19 00:00:00.167  - info: host.iobroker-master stopInstance system.adapter.linkeddevices.0 (force=false, process=true)
                              2020-01-19 00:00:00.168  - info: host.iobroker-master stopInstance system.adapter.mercedesme.0 (force=false, process=true)
                              2020-01-19 00:00:00.169  - info: host.iobroker-master stopInstance system.adapter.moma.0 (force=false, process=true)
                              2020-01-19 00:00:00.169  - info: host.iobroker-master stopInstance system.adapter.mqtt.0 (force=false, process=false)
                              2020-01-19 00:00:00.170  - info: host.iobroker-master stopInstance system.adapter.nina.0 (force=false, process=false)
                              2020-01-19 00:00:00.170  - info: host.iobroker-master stopInstance system.adapter.onkyo.0 (force=false, process=false)
                              2020-01-19 00:00:00.171  - info: host.iobroker-master stopInstance system.adapter.openweathermap.0 (force=false, process=false)
                              2020-01-19 00:00:00.171  - info: host.iobroker-master stopInstance system.adapter.ping.0 (force=false, process=true)
                              2020-01-19 00:00:00.172  - info: host.iobroker-master stopInstance system.adapter.robonect.0 (force=false, process=false)
                              2020-01-19 00:00:00.172  - info: host.iobroker-master stopInstance system.adapter.scenes.0 (force=false, process=true)
                              2020-01-19 00:00:00.173  - info: host.iobroker-master stopInstance system.adapter.simple-api.0 (force=false, process=true)
                              2020-01-19 00:00:00.174  - info: host.iobroker-master stopInstance system.adapter.sql.0 (force=false, process=true)
                              2020-01-19 00:00:00.176  - info: host.iobroker-master stopInstance system.adapter.statistics.0 (force=false, process=true)
                              2020-01-19 00:00:00.176  - info: host.iobroker-master stopInstance system.adapter.stiebel-isg.0 (force=false, process=true)
                              2020-01-19 00:00:00.177  - info: host.iobroker-master stopInstance system.adapter.tankerkoenig.0 (force=false, process=true)
                              2020-01-19 00:00:00.178  - info: host.iobroker-master stopInstance system.adapter.telegram.0 (force=false, process=true)
                              2020-01-19 00:00:00.179  - info: host.iobroker-master stopInstance system.adapter.text2command.0 (force=false, process=true)
                              2020-01-19 00:00:00.180  - info: host.iobroker-master stopInstance system.adapter.tr-064-community.0 (force=false, process=true)
                              2020-01-19 00:00:00.181  - info: host.iobroker-master stopInstance system.adapter.tvspielfilm.0 (force=false, process=true)
                              2020-01-19 00:00:00.182  - info: host.iobroker-master stopInstance canceled schedule system.adapter.tvspielfilm.0
                              2020-01-19 00:00:00.182  - info: host.iobroker-master stopInstance system.adapter.vis-canvas-gauges.0 (force=false, process=false)
                              2020-01-19 00:00:00.183  - info: host.iobroker-master stopInstance system.adapter.vis-colorpicker.0 (force=false, process=false)
                              2020-01-19 00:00:00.184  - info: host.iobroker-master stopInstance system.adapter.vis-google-fonts.0 (force=false, process=false)
                              2020-01-19 00:00:00.184  - info: host.iobroker-master stopInstance system.adapter.vis-history.0 (force=false, process=false)
                              2020-01-19 00:00:00.185  - info: host.iobroker-master stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
                              2020-01-19 00:00:00.186  - info: host.iobroker-master stopInstance system.adapter.vis-jqui-mfd.0 (force=false, process=false)
                              2020-01-19 00:00:00.186  - info: host.iobroker-master stopInstance system.adapter.vis-justgage.0 (force=false, process=false)
                              2020-01-19 00:00:00.187  - info: host.iobroker-master stopInstance system.adapter.vis-rgraph.0 (force=false, process=false)
                              2020-01-19 00:00:00.188  - info: host.iobroker-master stopInstance system.adapter.vis-weather.0 (force=false, process=false)
                              2020-01-19 00:00:00.188  - info: host.iobroker-master stopInstance system.adapter.vis.0 (force=false, process=false)
                              2020-01-19 00:00:00.195  - info: host.iobroker-master stopInstance system.adapter.web.0 (force=false, process=true)
                              2020-01-19 00:00:00.199  - info: host.iobroker-master stopInstance system.adapter.wlanthermo-nano.0 (force=false, process=false)
                              2020-01-19 00:00:00.201  - info: host.iobroker-master stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                              2020-01-19 00:00:00.201  - info: host.iobroker-master stopInstance system.adapter.shelly.0 (force=false, process=true)
                              2020-01-19 00:00:00.202  - info: host.iobroker-master stopInstance system.adapter.spotify-premium.0 (force=false, process=true)
                              2020-01-19 00:00:00.203  - info: host.iobroker-master stopInstance system.adapter.alexa2.0 (force=false, process=true)
                              2020-01-19 00:00:00.204  - info: host.iobroker-master stopInstance system.adapter.trashschedule.0 (force=false, process=true)
                              2020-01-19 00:00:00.205  - info: host.iobroker-master stopInstance system.adapter.vis-map.0 (force=false, process=false)
                              2020-01-19 00:00:00.206  - info: host.iobroker-master stopInstance system.adapter.iot.0 (force=false, process=true)
                              2020-01-19 00:00:00.206  - info: host.iobroker-master stopInstance system.adapter.countdown.0 (force=false, process=false)
                              2020-01-19 00:00:00.207  - info: host.iobroker-master stopInstance system.adapter.meteoalarm.0 (force=false, process=false)
                              2020-01-19 00:00:00.207  - info: host.iobroker-master stopInstance canceled schedule system.adapter.meteoalarm.0
                              2020-01-19 00:00:00.207  - info: host.iobroker-master stopInstance system.adapter.info.0 (force=false, process=true)
                              2020-01-19 00:00:00.208  - info: host.iobroker-master stopInstance system.adapter.pollenflug.0 (force=false, process=true)
                              2020-01-19 00:00:00.209  - info: host.iobroker-master stopInstance system.adapter.hue-extended.0 (force=false, process=false)
                              2020-01-19 00:00:00.210  - info: host.iobroker-master iobroker _restart
                              2020-01-19 00:00:00.285  - info: host.iobroker-master stopInstance system.adapter.admin.0 send kill signal
                              2020-01-19 00:00:00.293  - info: bring.0 (20403) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.288  - info: backitup.0 (1753) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.298  - info: javascript.0 (1993) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.296  - info: hue.0 (26780) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.305  - info: hue.0 (26780) cleaned everything up...
                              2020-01-19 00:00:00.316  - info: hue.0 (26780) terminating
                              2020-01-19 00:00:00.317  - info: hue.0 (26780) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:00.271  - error: sql.0 (23505) uncaught exception: Cannot read property 'return' of null
                              2020-01-19 00:00:00.279  - error: sql.0 (23505) TypeError: Cannot read property 'return' of null
                                  at Query.<anonymous> (/opt/iobroker/node_modules/iobroker.sql/main.js:1246:24)
                                  at Query.<anonymous> (/opt/iobroker/node_modules/mysql/lib/Connection.js:525:10)
                                  at Query._callback (/opt/iobroker/node_modules/mysql/lib/Connection.js:491:16)
                                  at Query.Sequence.end (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Sequence.js:83:24)
                                  at Query._handleFinalResultPacket (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Query.js:139:8)
                                  at Query.OkPacket (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Query.js:72:10)
                                  at Protocol._parsePacket (/opt/iobroker/node_modules/mysql/lib/protocol/Protocol.js:291:23)
                                  at Parser._parsePacket (/opt/iobroker/node_modules/mysql/lib/protocol/Parser.js:433:10)
                                  at Parser.write (/opt/iobroker/node_modules/mysql/lib/protocol/Parser.js:43:10)
                                  at Protocol.write (/opt/iobroker/node_modules/mysql/lib/protocol/Protocol.js:38:16)
                              2020-01-19 00:00:00.285  - warn: sql.0 (23505) Exception: TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:00.309  - error: sql.0 (23505) uncaught exception: Cannot read property 'return' of null
                              2020-01-19 00:00:00.310  - error: sql.0 (23505) TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:00.310  - warn: sql.0 (23505) Exception: TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:00.312  - error: sql.0 (23505) uncaught exception: Cannot read property 'return' of null
                              2020-01-19 00:00:00.312  - error: sql.0 (23505) TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:00.313  - warn: sql.0 (23505) Exception: TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:00.314  - error: sql.0 (23505) uncaught exception: Cannot read property 'return' of null
                              2020-01-19 00:00:00.314  - error: sql.0 (23505) TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:00.315  - warn: sql.0 (23505) Exception: TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:00.323  - error: sql.0 (23505) uncaught exception: Cannot read property 'return' of null
                              2020-01-19 00:00:00.323  - error: sql.0 (23505) TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:00.324  - warn: sql.0 (23505) Exception: TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:00.325  - error: sql.0 (23505) uncaught exception: Cannot read property 'return' of null
                              2020-01-19 00:00:00.326  - error: sql.0 (23505) TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:00.326  - warn: sql.0 (23505) Exception: TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:00.327  - error: sql.0 (23505) uncaught exception: Cannot read property 'return' of null
                              2020-01-19 00:00:00.328  - error: sql.0 (23505) TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:00.328  - warn: sql.0 (23505) Exception: TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:00.329  - error: sql.0 (23505) uncaught exception: Cannot read property 'return' of null
                              2020-01-19 00:00:00.330  - error: sql.0 (23505) TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:00.330  - warn: sql.0 (23505) Exception: TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:00.361  - info: sql.0 (23505) terminating
                              2020-01-19 00:00:00.362  - info: sql.0 (23505) Terminated (NO_ERROR): Without reason
                              2020-01-19 00:00:00.344  - info: moma.0 (2038) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.300  - info: linkeddevices.0 (2008) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.357  - info: moma.0 (2038) cleaned everything up...
                              2020-01-19 00:00:00.359  - info: moma.0 (2038) terminating
                              2020-01-19 00:00:00.363  - info: moma.0 (2038) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:00.305  - info: hs100.0 (1873) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.332  - info: hs100.0 (1873) terminating
                              2020-01-19 00:00:00.338  - info: hs100.0 (1873) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:00.389  - info: tankerkoenig.0 (2903) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.387  - info: stiebel-isg.0 (2756) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.411  - info: shelly.0 (4413) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.403  - info: stiebel-isg.0 (2756) cleaned everything up...
                              2020-01-19 00:00:00.405  - info: stiebel-isg.0 (2756) terminating
                              2020-01-19 00:00:00.407  - info: stiebel-isg.0 (2756) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:00.376  - info: ping.0 (2117) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.415  - info: shelly.0 (4413) Closing Adapter
                              2020-01-19 00:00:00.416  - info: shelly.0 (4413) terminating
                              2020-01-19 00:00:00.417  - info: shelly.0 (4413) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:00.333  - info: linkeddevices.0 (2008) cleaned everything up...
                              2020-01-19 00:00:00.334  - info: linkeddevices.0 (2008) terminating
                              2020-01-19 00:00:00.335  - info: linkeddevices.0 (2008) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:00.377  - info: scenes.0 (2243) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.344  - info: mercedesme.0 (1689) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.400  - info: mihome-vacuum.0 (719) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.367  - info: mercedesme.0 (1689) terminating
                              2020-01-19 00:00:00.368  - info: mercedesme.0 (1689) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:00.393  - info: text2command.0 (3181) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.409  - info: mihome-vacuum.0 (719) terminating
                              2020-01-19 00:00:00.410  - info: mihome-vacuum.0 (719) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:00.415  - info: spotify-premium.0 (4595) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.444  - info: spotify-premium.0 (4595) terminating
                              2020-01-19 00:00:00.446  - info: spotify-premium.0 (4595) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:00.434  - info: alexa2.0 (5247) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.444  - info: alexa2.0 (5247) terminating
                              2020-01-19 00:00:00.445  - info: alexa2.0 (5247) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:00.445  - info: pollenflug.0 (5667) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.459  - info: pollenflug.0 (5667) Closing Adapter
                              2020-01-19 00:00:00.465  - info: pollenflug.0 (5667) terminating
                              2020-01-19 00:00:00.471  - info: pollenflug.0 (5667) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:00.441  - info: info.0 (5489) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.461  - info: info.0 (5489) cleaned everything up...
                              2020-01-19 00:00:00.472  - info: info.0 (5489) terminating
                              2020-01-19 00:00:00.473  - info: info.0 (5489) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:00.439  - info: iot.0 (5100) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.478  - info: iot.0 (5100) terminating
                              2020-01-19 00:00:00.480  - info: iot.0 (5100) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:00.287  - info: host.iobroker-master stopInstance system.adapter.backitup.0 send kill signal
                              2020-01-19 00:00:00.288  - info: host.iobroker-master stopInstance system.adapter.bring.0 send kill signal
                              2020-01-19 00:00:00.289  - info: host.iobroker-master stopInstance system.adapter.harmony.0 send kill signal
                              2020-01-19 00:00:00.290  - info: host.iobroker-master stopInstance system.adapter.hm-rega.0 send kill signal
                              2020-01-19 00:00:00.290  - info: host.iobroker-master stopInstance system.adapter.hs100.0 send kill signal
                              2020-01-19 00:00:00.291  - info: host.iobroker-master stopInstance system.adapter.hue.0 send kill signal
                              2020-01-19 00:00:00.292  - info: host.iobroker-master stopInstance system.adapter.javascript.0 send kill signal
                              2020-01-19 00:00:00.293  - info: host.iobroker-master stopInstance system.adapter.linkeddevices.0 send kill signal
                              2020-01-19 00:00:00.341  - info: host.iobroker-master stopInstance system.adapter.mercedesme.0 send kill signal
                              2020-01-19 00:00:00.342  - info: host.iobroker-master stopInstance system.adapter.moma.0 send kill signal
                              2020-01-19 00:00:00.376  - info: host.iobroker-master stopInstance system.adapter.ping.0 send kill signal
                              2020-01-19 00:00:00.376  - info: host.iobroker-master stopInstance system.adapter.scenes.0 send kill signal
                              2020-01-19 00:00:00.377  - info: host.iobroker-master stopInstance system.adapter.simple-api.0 send kill signal
                              2020-01-19 00:00:00.385  - info: host.iobroker-master stopInstance system.adapter.statistics.0 send kill signal
                              2020-01-19 00:00:00.386  - info: host.iobroker-master stopInstance system.adapter.stiebel-isg.0 send kill signal
                              2020-01-19 00:00:00.388  - info: host.iobroker-master stopInstance system.adapter.tankerkoenig.0 send kill signal
                              2020-01-19 00:00:00.389  - info: host.iobroker-master stopInstance system.adapter.telegram.0 send kill signal
                              2020-01-19 00:00:00.389  - info: host.iobroker-master stopInstance system.adapter.text2command.0 send kill signal
                              2020-01-19 00:00:00.393  - info: host.iobroker-master stopInstance system.adapter.tr-064-community.0 send kill signal
                              2020-01-19 00:00:00.398  - info: host.iobroker-master stopInstance system.adapter.web.0 send kill signal
                              2020-01-19 00:00:00.399  - info: host.iobroker-master stopInstance system.adapter.mihome-vacuum.0 send kill signal
                              2020-01-19 00:00:00.413  - info: host.iobroker-master stopInstance system.adapter.shelly.0 send kill signal
                              2020-01-19 00:00:00.430  - info: host.iobroker-master stopInstance system.adapter.spotify-premium.0 send kill signal
                              2020-01-19 00:00:00.434  - info: host.iobroker-master stopInstance system.adapter.alexa2.0 send kill signal
                              2020-01-19 00:00:00.434  - info: host.iobroker-master stopInstance system.adapter.trashschedule.0 send kill signal
                              2020-01-19 00:00:00.439  - info: host.iobroker-master stopInstance system.adapter.iot.0 send kill signal
                              2020-01-19 00:00:00.441  - info: host.iobroker-master stopInstance system.adapter.info.0 send kill signal
                              2020-01-19 00:00:00.446  - info: host.iobroker-master stopInstance system.adapter.pollenflug.0 send kill signal
                              2020-01-19 00:00:00.435  - info: trashschedule.0 (4935) Got terminate signal TERMINATE_YOURSELF
                              2020-01-19 00:00:00.478  - info: trashschedule.0 (4935) cleaned everything up...
                              2020-01-19 00:00:00.484  - info: trashschedule.0 (4935) terminating
                              2020-01-19 00:00:00.488  - info: trashschedule.0 (4935) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:00.300  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Beleuchtung.01_Bewegungsmelder_Flur
                              2020-01-19 00:00:00.303  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Beleuchtung.04_Licht_Straeucher
                              2020-01-19 00:00:00.304  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Beschattung.Automatik.02_Halbautomatik
                              2020-01-19 00:00:00.306  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Beschattung.Automatik.03_Berechnung_Schaltzeiten
                              2020-01-19 00:00:00.307  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Beschattung.Automatik.04_Berechnung_Minuten_bis_zum_Schalten
                              2020-01-19 00:00:00.309  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Beschattung.Automatik.05_Nachts_reset_manuell_geschlossen
                              2020-01-19 00:00:00.310  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Beschattung.Sturmautomatik.01_Sturmpruefung
                              2020-01-19 00:00:00.312  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Beschattung.Sturmautomatik.02_Markise_hoch_bei_Sturm
                              2020-01-19 00:00:00.313  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Energie.01_Stromverbrauchs_Berechnungen
                              2020-01-19 00:00:00.314  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Energie.02_Summe_Strom-Mess-Steckdosen
                              2020-01-19 00:00:00.315  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Energie.03_Summe_Strom-Mess-Steckdosen_Netzwerkkomponenten
                              2020-01-19 00:00:00.317  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Energie.04_Statis_diverser_StromMessSteckdosen_ueberpruefen
                              2020-01-19 00:00:00.318  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Energie.Stromzaehler.stromzaehler_statistik_hausstrom_bezug
                              2020-01-19 00:00:00.331  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Energie.Stromzaehler.stromzaehler_statistik_hausstrom_einspeisung
                              2020-01-19 00:00:00.333  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Energie.Stromzaehler.stromzaehler_statistik_pv_wechselrichter
                              2020-01-19 00:00:00.335  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Energie.Stromzaehler.stromzaehler_statistik_waermepumpe_bezug
                              2020-01-19 00:00:00.348  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Garage.Garagentor
                              2020-01-19 00:00:00.350  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Garten.Bewaesserung.01_Bewaesserung_Manuell
                              2020-01-19 00:00:00.352  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Garten.Rasenmaeher.01_Status_Auslesen_fuer_VIS
                              2020-01-19 00:00:00.355  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Klima.01_Zirkulationspumpe
                              2020-01-19 00:00:00.357  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Sicherheit.Wassersensoren
                              2020-01-19 00:00:00.361  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Telegram.00_Telegram_Hauptmenue
                              2020-01-19 00:00:00.364  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Telegram.Telegram_Spritkostenabfrage_Benzin
                              2020-01-19 00:00:00.366  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Telegram.Telegram_Spritkostenabfrage_Diesel
                              2020-01-19 00:00:00.370  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Telegram.Telegram_wenn_Alarm_(un)scharf
                              2020-01-19 00:00:00.371  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Telegram.Telegram_wenn_Alarm_ausgeloest
                              2020-01-19 00:00:00.371  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Telegram.Telegram_wenn_Beschattung
                              2020-01-19 00:00:00.372  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Telegram.Telegram_wenn_Beschattung_Sturm
                              2020-01-19 00:00:00.373  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Telegram.Telegram_wenn_CCU_reboot_abgeschlossen
                              2020-01-19 00:00:00.374  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Telegram.Telegram_wenn_DC_groeßer_als
                              2020-01-19 00:00:00.375  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Telegram.Telegram_wenn_Garagentor_Toggle
                              2020-01-19 00:00:00.408  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Telegram.Telegram_wenn_Gartenbewaesserung
                              2020-01-19 00:00:00.426  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Telegram.Telegram_wenn_Rasenmaehroboter
                              2020-01-19 00:00:00.449  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Telegram.Telegram_wenn_Rasenmaehroboter_Fehler
                              2020-01-19 00:00:00.453  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Telegram.Telegram_wenn_Zirkulation_(in)aktiv
                              2020-01-19 00:00:00.457  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Wetter.01_Wetterstation_Tagesmengen
                              2020-01-19 00:00:00.458  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Wetter.02_Sonnenstand
                              2020-01-19 00:00:00.459  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Wetter.03_Mondphasen
                              2020-01-19 00:00:00.460  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Zeiten.01_Minuten_vor_Sonnenauf_und_untergang
                              2020-01-19 00:00:00.461  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Klima.03_ISG_Ueberwachung_NE
                              2020-01-19 00:00:00.462  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Klima.02_ISG_Logge_HEIZEN_WW_WRG_pro_Tag
                              2020-01-19 00:00:00.463  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Klima.03_Lueftung_Temperatur_Automatik
                              2020-01-19 00:00:00.464  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Energie.Photovoltaik.01_PV_auslesen
                              2020-01-19 00:00:00.465  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Energie.Photovoltaik.02_PV_Tageswerte_speichern
                              2020-01-19 00:00:00.466  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Zeiten.02_Berechne_Tageszeiten
                              2020-01-19 00:00:00.467  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Beleuchtung.02_Bewegungsmelder_Garage
                              2020-01-19 00:00:00.468  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Beschattung.Automatik.01_Automatik_mit_Zielzustand
                              2020-01-19 00:00:00.470  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Taster.01_Taster_Flur
                              2020-01-19 00:00:00.471  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Taster.02_Taster_Wohnzimmer
                              2020-01-19 00:00:00.479  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Taster.03_Taster_OG_Flur
                              2020-01-19 00:00:00.480  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Taster.04_Schluesselanhaenger
                              2020-01-19 00:00:00.481  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.VIS.05_Tabelle_Tanken
                              2020-01-19 00:00:00.482  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.VIS.01_Lebensmittelwarnungen_v0-8
                              2020-01-19 00:00:00.483  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.VIS.05_Tabelle_Kalender_Muell
                              2020-01-19 00:00:00.485  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.System.05_ioBroker_Logfile_VIS_v3-1-1
                              2020-01-19 00:00:00.487  - info: javascript.0 (1993) script.js.PRODUKTIV.System.05_ioBroker_Logfile_VIS_v3-1-1: Unsubscribed to Log Handler.
                              2020-01-19 00:00:00.487  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Hausgeraete.01_Mercedes_gefahrene_km_Vortag
                              2020-01-19 00:00:00.488  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Hausgeraete.02_Roborock_Wochenplan
                              2020-01-19 00:00:00.489  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Hausgeraete.03_Roborock_Zonenreinigung
                              2020-01-19 00:00:00.490  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.System.03_Homematic_DeviceCounter
                              2020-01-19 00:00:00.493  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.System.04_Homematic_Servicemeldungen
                              2020-01-19 00:00:00.496  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.System.01_Automatisch_Start_Stop_Adapter_und_Skripte
                              2020-01-19 00:00:00.497  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.VIS.02_TopAppBar_Index_zu_Titel
                              2020-01-19 00:00:00.498  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Alexa.01_Steuerung_Stimme
                              2020-01-19 00:00:00.499  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Alexa.03_Ansage_Aussentemperatur
                              2020-01-19 00:00:00.500  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Alexa.03_Ansage_Fenster
                              2020-01-19 00:00:00.501  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Alexa.04_Roborock_Fehlermeldungen
                              2020-01-19 00:00:00.502  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Alexa.04_Roborock_Statustext
                              2020-01-19 00:00:00.502  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Alexa.02_Ansage_Allgemein
                              2020-01-19 00:00:00.503  - info: javascript.0 (1993) Stop script script.js.TEST.json
                              2020-01-19 00:00:00.504  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Daten.02_Klima_Charts
                              2020-01-19 00:00:00.505  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Daten.01_DB_Statistiken
                              2020-01-19 00:00:00.506  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Beschattung.Automatik.03_Confirm_Working_State
                              2020-01-19 00:00:00.510  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.VIS.06_Infotexte_Startseite
                              2020-01-19 00:00:00.511  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Sicherheit.Alarmanlage.03_Alamieren_Sirene
                              2020-01-19 00:00:00.511  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Sicherheit.Alarmanlage.02_Sensoren_ueberwachen
                              2020-01-19 00:00:00.513  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Sicherheit.Alarmanlage.01_Scharf_schalten
                              2020-01-19 00:00:00.514  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Sicherheit.Alarmanlage.03_PIN_Reset_View_Widget_Kopieren
                              2020-01-19 00:00:00.514  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.Sicherheit.Alarmanlage.03_PIN_Sperre_Sicherheit
                              2020-01-19 00:00:00.515  - info: javascript.0 (1993) Stop script script.js.PRODUKTIV.00_Datenpunkte
                              2020-01-19 00:00:00.518  - info: javascript.0 (1993) terminating
                              2020-01-19 00:00:00.518  - info: javascript.0 (1993) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:00.533  - info: iot.0 (5100) Connection changed: disconnect
                              2020-01-19 00:00:00.533  - info: iot.0 (5100) Connection lost
                              2020-01-19 00:00:00.628  - info: host.iobroker-master instance system.adapter.bring.0 terminated with code 156 (156)
                              2020-01-19 00:00:00.794  - info: backitup.0 (1753) terminating
                              2020-01-19 00:00:00.795  - info: backitup.0 (1753) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:00.894  - info: host.iobroker-master instance system.adapter.hm-rega.0 terminated with code 156 (156)
                              2020-01-19 00:00:00.902  - info: tankerkoenig.0 (2903) terminating
                              2020-01-19 00:00:00.903  - info: tankerkoenig.0 (2903) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:00.913  - info: scenes.0 (2243) terminating
                              2020-01-19 00:00:00.914  - info: scenes.0 (2243) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:00.918  - info: ping.0 (2117) terminating
                              2020-01-19 00:00:00.921  - info: text2command.0 (3181) terminating
                              2020-01-19 00:00:00.923  - info: text2command.0 (3181) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:00.919  - info: ping.0 (2117) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-19 00:00:01.411  - info: host.iobroker-master instance system.adapter.admin.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.412  - info: host.iobroker-master instance system.adapter.harmony.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.412  - info: host.iobroker-master instance system.adapter.hs100.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.413  - info: host.iobroker-master instance system.adapter.linkeddevices.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.414  - info: host.iobroker-master instance system.adapter.moma.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.414  - info: host.iobroker-master instance system.adapter.simple-api.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.415  - error: host.iobroker-master Caught by controller[0]: TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:01.415  - error: host.iobroker-master Caught by controller[0]:     at Query.<anonymous> (/opt/iobroker/node_modules/iobroker.sql/main.js:1246:24)
                              2020-01-19 00:00:01.415  - error: host.iobroker-master Caught by controller[0]:     at Query.<anonymous> (/opt/iobroker/node_modules/mysql/lib/Connection.js:525:10)
                              2020-01-19 00:00:01.415  - error: host.iobroker-master Caught by controller[0]:     at Query._callback (/opt/iobroker/node_modules/mysql/lib/Connection.js:491:16)
                              2020-01-19 00:00:01.435  - error: host.iobroker-master Caught by controller[0]:     at Query.Sequence.end (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Sequence.js:83:24)
                              2020-01-19 00:00:01.435  - error: host.iobroker-master Caught by controller[0]:     at Query._handleFinalResultPacket (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Query.js:139:8)
                              2020-01-19 00:00:01.435  - error: host.iobroker-master Caught by controller[0]:     at Query.OkPacket (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Query.js:72:10)
                              2020-01-19 00:00:01.436  - error: host.iobroker-master Caught by controller[0]:     at Protocol._parsePacket (/opt/iobroker/node_modules/mysql/lib/protocol/Protocol.js:291:23)
                              2020-01-19 00:00:01.436  - error: host.iobroker-master Caught by controller[0]:     at Parser._parsePacket (/opt/iobroker/node_modules/mysql/lib/protocol/Parser.js:433:10)
                              2020-01-19 00:00:01.436  - error: host.iobroker-master Caught by controller[0]:     at Parser.write (/opt/iobroker/node_modules/mysql/lib/protocol/Parser.js:43:10)
                              2020-01-19 00:00:01.436  - error: host.iobroker-master Caught by controller[0]:     at Protocol.write (/opt/iobroker/node_modules/mysql/lib/protocol/Protocol.js:38:16)
                              2020-01-19 00:00:01.436  - error: host.iobroker-master Caught by controller[1]: TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:01.437  - error: host.iobroker-master Caught by controller[1]:     at Query.<anonymous> (/opt/iobroker/node_modules/iobroker.sql/main.js:1246:24)
                              2020-01-19 00:00:01.437  - error: host.iobroker-master Caught by controller[1]:     at Query.<anonymous> (/opt/iobroker/node_modules/mysql/lib/Connection.js:525:10)
                              2020-01-19 00:00:01.437  - error: host.iobroker-master Caught by controller[1]:     at Query._callback (/opt/iobroker/node_modules/mysql/lib/Connection.js:491:16)
                              2020-01-19 00:00:01.437  - error: host.iobroker-master Caught by controller[1]:     at Query.Sequence.end (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Sequence.js:83:24)
                              2020-01-19 00:00:01.438  - error: host.iobroker-master Caught by controller[1]:     at Query._handleFinalResultPacket (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Query.js:139:8)
                              2020-01-19 00:00:01.438  - error: host.iobroker-master Caught by controller[1]:     at Query.OkPacket (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Query.js:72:10)
                              2020-01-19 00:00:01.438  - error: host.iobroker-master Caught by controller[1]:     at Protocol._parsePacket (/opt/iobroker/node_modules/mysql/lib/protocol/Protocol.js:291:23)
                              2020-01-19 00:00:01.438  - error: host.iobroker-master Caught by controller[1]:     at Parser._parsePacket (/opt/iobroker/node_modules/mysql/lib/protocol/Parser.js:433:10)
                              2020-01-19 00:00:01.438  - error: host.iobroker-master Caught by controller[1]:     at Parser.write (/opt/iobroker/node_modules/mysql/lib/protocol/Parser.js:43:10)
                              2020-01-19 00:00:01.439  - error: host.iobroker-master Caught by controller[1]:     at Protocol.write (/opt/iobroker/node_modules/mysql/lib/protocol/Protocol.js:38:16)
                              2020-01-19 00:00:01.439  - error: host.iobroker-master Caught by controller[1]: TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:01.439  - error: host.iobroker-master Caught by controller[1]:     at Query.<anonymous> (/opt/iobroker/node_modules/iobroker.sql/main.js:1246:24)
                              2020-01-19 00:00:01.439  - error: host.iobroker-master Caught by controller[1]:     at Query.<anonymous> (/opt/iobroker/node_modules/mysql/lib/Connection.js:525:10)
                              2020-01-19 00:00:01.440  - error: host.iobroker-master Caught by controller[1]:     at Query._callback (/opt/iobroker/node_modules/mysql/lib/Connection.js:491:16)
                              2020-01-19 00:00:01.440  - error: host.iobroker-master Caught by controller[1]:     at Query.Sequence.end (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Sequence.js:83:24)
                              2020-01-19 00:00:01.440  - error: host.iobroker-master Caught by controller[1]:     at Query._handleFinalResultPacket (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Query.js:139:8)
                              2020-01-19 00:00:01.440  - error: host.iobroker-master Caught by controller[1]:     at Query.OkPacket (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Query.js:72:10)
                              2020-01-19 00:00:01.440  - error: host.iobroker-master Caught by controller[1]:     at Protocol._parsePacket (/opt/iobroker/node_modules/mysql/lib/protocol/Protocol.js:291:23)
                              2020-01-19 00:00:01.441  - error: host.iobroker-master Caught by controller[1]:     at Parser._parsePacket (/opt/iobroker/node_modules/mysql/lib/protocol/Parser.js:433:10)
                              2020-01-19 00:00:01.441  - error: host.iobroker-master Caught by controller[1]:     at Parser.write (/opt/iobroker/node_modules/mysql/lib/protocol/Parser.js:43:10)
                              2020-01-19 00:00:01.441  - error: host.iobroker-master Caught by controller[1]:     at Protocol.write (/opt/iobroker/node_modules/mysql/lib/protocol/Protocol.js:38:16)
                              2020-01-19 00:00:01.442  - error: host.iobroker-master Caught by controller[1]: TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:01.442  - error: host.iobroker-master Caught by controller[1]:     at Query.<anonymous> (/opt/iobroker/node_modules/iobroker.sql/main.js:1246:24)
                              2020-01-19 00:00:01.442  - error: host.iobroker-master Caught by controller[1]:     at Query.<anonymous> (/opt/iobroker/node_modules/mysql/lib/Connection.js:525:10)
                              2020-01-19 00:00:01.442  - error: host.iobroker-master Caught by controller[1]:     at Query._callback (/opt/iobroker/node_modules/mysql/lib/Connection.js:491:16)
                              2020-01-19 00:00:01.443  - error: host.iobroker-master Caught by controller[1]:     at Query.Sequence.end (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Sequence.js:83:24)
                              2020-01-19 00:00:01.443  - error: host.iobroker-master Caught by controller[1]:     at Query._handleFinalResultPacket (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Query.js:139:8)
                              2020-01-19 00:00:01.443  - error: host.iobroker-master Caught by controller[1]:     at Query.OkPacket (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Query.js:72:10)
                              2020-01-19 00:00:01.443  - error: host.iobroker-master Caught by controller[1]:     at Protocol._parsePacket (/opt/iobroker/node_modules/mysql/lib/protocol/Protocol.js:291:23)
                              2020-01-19 00:00:01.444  - error: host.iobroker-master Caught by controller[1]:     at Parser._parsePacket (/opt/iobroker/node_modules/mysql/lib/protocol/Parser.js:433:10)
                              2020-01-19 00:00:01.444  - error: host.iobroker-master Caught by controller[1]:     at Parser.write (/opt/iobroker/node_modules/mysql/lib/protocol/Parser.js:43:10)
                              2020-01-19 00:00:01.444  - error: host.iobroker-master Caught by controller[1]:     at Protocol.write (/opt/iobroker/node_modules/mysql/lib/protocol/Protocol.js:38:16)
                              2020-01-19 00:00:01.445  - error: host.iobroker-master Caught by controller[1]: TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:01.445  - error: host.iobroker-master Caught by controller[1]:     at Query.<anonymous> (/opt/iobroker/node_modules/iobroker.sql/main.js:1246:24)
                              2020-01-19 00:00:01.445  - error: host.iobroker-master Caught by controller[1]:     at Query.<anonymous> (/opt/iobroker/node_modules/mysql/lib/Connection.js:525:10)
                              2020-01-19 00:00:01.445  - error: host.iobroker-master Caught by controller[1]:     at Query._callback (/opt/iobroker/node_modules/mysql/lib/Connection.js:491:16)
                              2020-01-19 00:00:01.445  - error: host.iobroker-master Caught by controller[1]:     at Query.Sequence.end (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Sequence.js:83:24)
                              2020-01-19 00:00:01.446  - error: host.iobroker-master Caught by controller[1]:     at Query._handleFinalResultPacket (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Query.js:139:8)
                              2020-01-19 00:00:01.446  - error: host.iobroker-master Caught by controller[1]:     at Query.OkPacket (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Query.js:72:10)
                              2020-01-19 00:00:01.446  - error: host.iobroker-master Caught by controller[1]:     at Protocol._parsePacket (/opt/iobroker/node_modules/mysql/lib/protocol/Protocol.js:291:23)
                              2020-01-19 00:00:01.446  - error: host.iobroker-master Caught by controller[1]:     at Parser._parsePacket (/opt/iobroker/node_modules/mysql/lib/protocol/Parser.js:433:10)
                              2020-01-19 00:00:01.446  - error: host.iobroker-master Caught by controller[1]:     at Parser.write (/opt/iobroker/node_modules/mysql/lib/protocol/Parser.js:43:10)
                              2020-01-19 00:00:01.447  - error: host.iobroker-master Caught by controller[1]:     at Protocol.write (/opt/iobroker/node_modules/mysql/lib/protocol/Protocol.js:38:16)
                              2020-01-19 00:00:01.447  - error: host.iobroker-master Caught by controller[1]: TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:01.447  - error: host.iobroker-master Caught by controller[1]:     at Query.<anonymous> (/opt/iobroker/node_modules/iobroker.sql/main.js:1246:24)
                              2020-01-19 00:00:01.447  - error: host.iobroker-master Caught by controller[1]:     at Query.<anonymous> (/opt/iobroker/node_modules/mysql/lib/Connection.js:525:10)
                              2020-01-19 00:00:01.447  - error: host.iobroker-master Caught by controller[1]:     at Query._callback (/opt/iobroker/node_modules/mysql/lib/Connection.js:491:16)
                              2020-01-19 00:00:01.448  - error: host.iobroker-master Caught by controller[1]:     at Query.Sequence.end (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Sequence.js:83:24)
                              2020-01-19 00:00:01.448  - error: host.iobroker-master Caught by controller[1]:     at Query._handleFinalResultPacket (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Query.js:139:8)
                              2020-01-19 00:00:01.448  - error: host.iobroker-master Caught by controller[1]:     at Query.OkPacket (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Query.js:72:10)
                              2020-01-19 00:00:01.448  - error: host.iobroker-master Caught by controller[1]:     at Protocol._parsePacket (/opt/iobroker/node_modules/mysql/lib/protocol/Protocol.js:291:23)
                              2020-01-19 00:00:01.449  - error: host.iobroker-master Caught by controller[1]:     at Parser._parsePacket (/opt/iobroker/node_modules/mysql/lib/protocol/Parser.js:433:10)
                              2020-01-19 00:00:01.449  - error: host.iobroker-master Caught by controller[1]:     at Parser.write (/opt/iobroker/node_modules/mysql/lib/protocol/Parser.js:43:10)
                              2020-01-19 00:00:01.449  - error: host.iobroker-master Caught by controller[1]:     at Protocol.write (/opt/iobroker/node_modules/mysql/lib/protocol/Protocol.js:38:16)
                              2020-01-19 00:00:01.451  - error: host.iobroker-master Caught by controller[1]: TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:01.452  - error: host.iobroker-master Caught by controller[1]:     at Query.<anonymous> (/opt/iobroker/node_modules/iobroker.sql/main.js:1246:24)
                              2020-01-19 00:00:01.452  - error: host.iobroker-master Caught by controller[1]:     at Query.<anonymous> (/opt/iobroker/node_modules/mysql/lib/Connection.js:525:10)
                              2020-01-19 00:00:01.452  - error: host.iobroker-master Caught by controller[1]:     at Query._callback (/opt/iobroker/node_modules/mysql/lib/Connection.js:491:16)
                              2020-01-19 00:00:01.452  - error: host.iobroker-master Caught by controller[1]:     at Query.Sequence.end (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Sequence.js:83:24)
                              2020-01-19 00:00:01.453  - error: host.iobroker-master Caught by controller[1]:     at Query._handleFinalResultPacket (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Query.js:139:8)
                              2020-01-19 00:00:01.453  - error: host.iobroker-master Caught by controller[1]:     at Query.OkPacket (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Query.js:72:10)
                              2020-01-19 00:00:01.453  - error: host.iobroker-master Caught by controller[1]:     at Protocol._parsePacket (/opt/iobroker/node_modules/mysql/lib/protocol/Protocol.js:291:23)
                              2020-01-19 00:00:01.453  - error: host.iobroker-master Caught by controller[1]:     at Parser._parsePacket (/opt/iobroker/node_modules/mysql/lib/protocol/Parser.js:433:10)
                              2020-01-19 00:00:01.453  - error: host.iobroker-master Caught by controller[1]:     at Parser.write (/opt/iobroker/node_modules/mysql/lib/protocol/Parser.js:43:10)
                              2020-01-19 00:00:01.454  - error: host.iobroker-master Caught by controller[1]:     at Protocol.write (/opt/iobroker/node_modules/mysql/lib/protocol/Protocol.js:38:16)
                              2020-01-19 00:00:01.454  - error: host.iobroker-master Caught by controller[1]: TypeError: Cannot read property 'return' of null
                              2020-01-19 00:00:01.454  - error: host.iobroker-master Caught by controller[1]:     at Query.<anonymous> (/opt/iobroker/node_modules/iobroker.sql/main.js:1246:24)
                              2020-01-19 00:00:01.454  - error: host.iobroker-master Caught by controller[1]:     at Query.<anonymous> (/opt/iobroker/node_modules/mysql/lib/Connection.js:525:10)
                              2020-01-19 00:00:01.454  - error: host.iobroker-master Caught by controller[1]:     at Query._callback (/opt/iobroker/node_modules/mysql/lib/Connection.js:491:16)
                              2020-01-19 00:00:01.455  - error: host.iobroker-master Caught by controller[1]:     at Query.Sequence.end (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Sequence.js:83:24)
                              2020-01-19 00:00:01.455  - error: host.iobroker-master Caught by controller[1]:     at Query._handleFinalResultPacket (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Query.js:139:8)
                              2020-01-19 00:00:01.455  - error: host.iobroker-master Caught by controller[1]:     at Query.OkPacket (/opt/iobroker/node_modules/mysql/lib/protocol/sequences/Query.js:72:10)
                              2020-01-19 00:00:01.455  - error: host.iobroker-master Caught by controller[1]:     at Protocol._parsePacket (/opt/iobroker/node_modules/mysql/lib/protocol/Protocol.js:291:23)
                              2020-01-19 00:00:01.455  - error: host.iobroker-master Caught by controller[1]:     at Parser._parsePacket (/opt/iobroker/node_modules/mysql/lib/protocol/Parser.js:433:10)
                              2020-01-19 00:00:01.456  - error: host.iobroker-master Caught by controller[1]:     at Parser.write (/opt/iobroker/node_modules/mysql/lib/protocol/Parser.js:43:10)
                              2020-01-19 00:00:01.456  - error: host.iobroker-master Caught by controller[1]:     at Protocol.write (/opt/iobroker/node_modules/mysql/lib/protocol/Protocol.js:38:16)
                              2020-01-19 00:00:01.456  - info: host.iobroker-master instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
                              2020-01-19 00:00:01.457  - info: host.iobroker-master instance system.adapter.hue.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.457  - info: host.iobroker-master instance system.adapter.mercedesme.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.457  - info: host.iobroker-master instance system.adapter.statistics.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.458  - info: host.iobroker-master instance system.adapter.stiebel-isg.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.458  - info: host.iobroker-master instance system.adapter.shelly.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.459  - info: host.iobroker-master instance system.adapter.spotify-premium.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.459  - info: host.iobroker-master instance system.adapter.trashschedule.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.460  - info: host.iobroker-master instance system.adapter.iot.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.461  - info: host.iobroker-master instance system.adapter.alexa2.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.461  - info: host.iobroker-master instance system.adapter.info.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.462  - info: host.iobroker-master instance system.adapter.pollenflug.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.462  - info: host.iobroker-master instance system.adapter.web.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.463  - info: host.iobroker-master instance system.adapter.mihome-vacuum.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.464  - info: host.iobroker-master instance system.adapter.backitup.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.466  - info: host.iobroker-master stopInstance timeout 1000 system.adapter.hm-rpc.1 killing pid  1843
                              2020-01-19 00:00:01.469  - info: host.iobroker-master stopInstance timeout 1000 system.adapter.hm-rpc.2 killing pid  1858
                              2020-01-19 00:00:01.470  - info: host.iobroker-master stopInstance system.adapter.javascript.0 killing pid 1993
                              2020-01-19 00:00:01.477  - info: host.iobroker-master stopInstance system.adapter.ping.0 killing pid 2117
                              2020-01-19 00:00:01.478  - info: host.iobroker-master stopInstance system.adapter.scenes.0 killing pid 2243
                              2020-01-19 00:00:01.478  - info: host.iobroker-master stopInstance system.adapter.tankerkoenig.0 killing pid 2903
                              2020-01-19 00:00:01.479  - info: host.iobroker-master stopInstance system.adapter.telegram.0 killing pid 4879
                              2020-01-19 00:00:01.479  - info: host.iobroker-master stopInstance system.adapter.text2command.0 killing pid 3181
                              2020-01-19 00:00:01.480  - info: host.iobroker-master stopInstance system.adapter.tr-064-community.0 killing pid 3302
                              2020-01-19 00:00:01.493  - info: host.iobroker-master iobroker Starting node restart.js
                              2020-01-19 00:00:01.608  - info: host.iobroker-master instance system.adapter.ping.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.609  - info: host.iobroker-master instance system.adapter.scenes.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.609  - info: host.iobroker-master instance system.adapter.tankerkoenig.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.610  - info: host.iobroker-master instance system.adapter.text2command.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.610  - info: host.iobroker-master instance system.adapter.telegram.0 terminated with code 156 (156)
                              2020-01-19 00:00:01.851  - info: host.iobroker-master instance system.adapter.javascript.0 terminated with code 156 (156)
                              2020-01-19 00:00:02.019  - info: host.iobroker-master instance system.adapter.tr-064-community.0 terminated with code 156 (156)
                              2020-01-19 00:00:02.054  - info: host.iobroker-master iobroker exit 0
                              2020-01-19 00:00:02.055  - info: host.iobroker-master instance system.adapter.hm-rpc.1 terminated with code 156 (156)
                              2020-01-19 00:00:02.056  - info: host.iobroker-master instance system.adapter.hm-rpc.2 terminated with code 156 (156)
                              2020-01-19 00:00:02.583  - info: tvspielfilm.0 (12449) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v10.18.1
                              2020-01-19 00:00:02.636  - info: tvspielfilm.0 (12449) objects written
                              2020-01-19 00:00:04.109  - info: host.iobroker-master instance system.adapter.daswetter.0 started with pid 12478
                              2020-01-19 00:00:05.268  - warn: host.iobroker-master Multihost discovery server: service started on 0.0.0.0:50005
                              2020-01-19 00:00:08.140  - info: host.iobroker-master instance system.adapter.dwd.0 started with pid 12493
                              2020-01-19 00:00:11.803  - info: host.iobroker-master instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
                              2020-01-19 00:00:12.171  - info: host.iobroker-master instance system.adapter.meteoalarm.0 started with pid 12508
                              2020-01-19 00:00:12.339  - info: host.iobroker-master instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                              2020-01-19 00:00:13.821  - info: meteoalarm.0 (12508) starting. Version 1.0.8 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v10.18.1
                              2020-01-19 00:00:13.898  - info: meteoalarm.0 (12508) Requesting data from https://meteoalarm.eu/documents/rss/de/DE153.rss
                              2020-01-19 00:00:14.297  - info: meteoalarm.0 (12508) Received data for "Kreis Germersheim"
                              2020-01-19 00:00:15.215  - info: host.iobroker-master force terminating
                              2020-01-19 00:00:15.216  - info: host.iobroker-master Adapter tvspielfilm still running
                              2020-01-19 00:00:15.216  - info: host.iobroker-master Adapter meteoalarm still running
                              2020-01-19 00:00:16.202  - info: host.iobroker-master instance system.adapter.ical.5 started with pid 12523
                              2020-01-19 00:00:20.217  - error: tvspielfilm.0 (12449) connect ECONNREFUSED 0.0.0.0:9001
                              2020-01-19 00:00:20.218  - error: meteoalarm.0 (12508) connect ECONNREFUSED 0.0.0.0:9001
                              2020-01-19 00:00:21.293  - warn: ical.5 (12523) no connection to objects DB
                              2020-01-19 00:00:22.325  - info: meteoalarm.0 (12508) Terminated (NO_ERROR): Without reason
                              2020-01-19 00:00:25.220  - error: tvspielfilm.0 (12449) connect ECONNREFUSED 0.0.0.0:9001
                              2020-01-19 00:00:30.223  - error: tvspielfilm.0 (12449) connect ECONNREFUSED 0.0.0.0:9001
                              2020-01-19 00:00:35.225  - error: tvspielfilm.0 (12449) connect ECONNREFUSED 0.0.0.0:9001
                              2020-01-19 00:00:40.226  - error: tvspielfilm.0 (12449) connect ECONNREFUSED 0.0.0.0:9001
                              2020-01-19 00:00:45.228  - error: tvspielfilm.0 (12449) connect ECONNREFUSED 0.0.0.0:9001
                              2020-01-19 00:00:50.229  - error: tvspielfilm.0 (12449) connect ECONNREFUSED 0.0.0.0:9001
                              2020-01-19 00:00:55.231  - error: tvspielfilm.0 (12449) connect ECONNREFUSED 0.0.0.0:9001
                              2020-01-19 00:01:00.232  - error: tvspielfilm.0 (12449) connect ECONNREFUSED 0.0.0.0:9001
                              2020-01-19 00:01:02.636  - info: tvspielfilm.0 (12449) force terminating adapter after 1 minute
                              2020-01-19 00:01:03.140  - info: tvspielfilm.0 (12449) Terminated (NO_ERROR): Without reason
                              2020-01-19 07:24:08.101  - info: host.iobroker-master iobroker.js-controller version 2.2.7 js-controller starting
                              2020-01-19 07:24:08.111  - info: host.iobroker-master Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                              Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                              apollon77A 2 Antworten Letzte Antwort
                              • D darkiop
                                    at process._tickCallback (internal/process/next_tick.js:63:19)
                                apollon77A Online
                                apollon77A Online
                                #156
                                @darkiop checke ich. Die 2.2.8 wartet eh gerade noch auf einen anderen bugfix aus dieser lib. Packe das dazu.
                                • D darkiop
                                  apollon77A Online
                                  apollon77A Online
                                  #157
                                  @darkiop ps: aber warum nicht erreichbar? Er restarted den Controller an sich ja erfolgreich oder bleibt er da hängen und im log kommt dann nix mehr? Master oder Slave?
                                  • apollon77A apollon77
                                    darkiop
                                    #158
                                    @apollon77 Das Log oben war vom Master. Hier der Slave. Das Log ist auch vollständig - Fehler um 0 Uhr und um 7 Uhr wurde von mir manuell neu gestartet. Der Slave konnte dann bis heut Morgen den Master nicht erreichen.
                                    Ich habe leider direkt den Container neu gestartet, hätte vorher ggf. ps -ef prüfen sollen. Ich vermute mal der js-controller hatte sich verabschiedet nach dem Versuch das Log zu rotieren.
                                    ┌2020-01-19 00:00:20.228  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:00:20.227  - error: smartmeter.0 (4382) connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:00:20.239  - error: smartmeter.1 (4397) connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:00:20.301  - error: smartmeter.0 (4382) uncaught exception: ENOENT: no such file or directory, unlink '/opt/iobroker/log/iobroker.2020-01-17.log'        │
                                    │2020-01-19 00:00:20.302  - error: smartmeter.0 (4382) Error: ENOENT: no such file or directory, unlink '/opt/iobroker/log/iobroker.2020-01-17.log'        │
                                    │    at Object.unlinkSync (fs.js:956:3)        │
                                    │    at WriteStream.<anonymous> (/opt/iobroker/node_modules/winston-daily-rotate-file/daily-rotate-file.js:128:24)        │
                                    │    at WriteStream.emit (events.js:203:15)        │
                                    │    at WriteStream.EventEmitter.emit (domain.js:448:20)        │
                                    │    at finishMaybe (_stream_writable.js:646:14)        │
                                    │    at stream._final (_stream_writable.js:624:5)        │
                                    │    at WriteStream._final (internal/fs/streams.js:268:3)        │
                                    │    at callFinal (_stream_writable.js:617:10)        │
                                    │    at process._tickCallback (internal/process/next_tick.js:63:19)        │
                                    │2020-01-19 00:00:25.258  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:00:25.265  - error: smartmeter.1 (4397) connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:00:30.261  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:00:30.267  - error: smartmeter.1 (4397) connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:00:35.263  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:00:35.271  - error: smartmeter.1 (4397) connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:00:40.267  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:00:40.276  - error: smartmeter.1 (4397) connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:00:45.269  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:00:45.279  - error: smartmeter.1 (4397) connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:00:50.272  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:00:50.285  - error: smartmeter.1 (4397) connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:00:55.275  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:00:55.287  - error: smartmeter.1 (4397) connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:01:00.277  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:01:00.289  - error: smartmeter.1 (4397) connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:01:05.279  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:01:05.292  - error: smartmeter.1 (4397) connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:01:10.281  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:01:10.294  - error: smartmeter.1 (4397) connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:01:15.284  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:01:15.297  - error: smartmeter.1 (4397) connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:01:20.286  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:01:20.299  - error: smartmeter.1 (4397) connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:01:25.289  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:01:25.301  - error: smartmeter.1 (4397) connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:01:30.291  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:01:30.304  - error: smartmeter.1 (4397) connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:01:35.293  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:01:35.307  - error: smartmeter.1 (4397) connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:01:40.295  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:01:40.309  - error: smartmeter.1 (4397) connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:01:45.297  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001        │
                                    │2020-01-19 00:01:45.299  - error: host.iobroker-hwr Cannot find view "system" for search "instance" : Error: Connection is closed.        │
                                    │2020-01-19 00:01:45.303  - info: host.iobroker-hwr instance system.adapter.smartmeter.0 terminated with code 0 (NO_ERROR)        │
                                    │2020-01-19 00:01:45.304  - info: host.iobroker-hwr Restart adapter system.adapter.smartmeter.0 because enabled
                                    │2020-01-19 00:02:29.975  - info: host.iobroker-hwr iobroker _restart        │
                                    │2020-01-19 00:02:30.521  - info: host.iobroker-hwr iobroker Starting node restart.js        │
                                    │2020-01-19 00:02:32.199  - info: host.iobroker-hwr iobroker.js-controller version 2.2.7 js-controller starting        │
                                    │2020-01-19 00:02:32.206  - info: host.iobroker-hwr Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker        │
                                    │2020-01-19 00:02:32.207  - info: host.iobroker-hwr hostname: iobroker-hwr, node: v10.18.0        │
                                    │2020-01-19 00:02:32.209  - info: host.iobroker-hwr ip addresses: 10.3.1.22 fe80::561e:8619:1900:f27        │
                                    │2020-01-19 00:03:02.220  - error: host.iobroker-hwr No connection to databases possible, restart        │
                                    │2020-01-19 00:03:02.228  - info: host.iobroker-hwr iobroker _restart        │
                                    │2020-01-19 00:03:02.779  - info: host.iobroker-hwr iobroker Starting node restart.js        │
                                    │2020-01-19 00:03:04.453  - info: host.iobroker-hwr iobroker.js-controller version 2.2.7 js-controller starting        │
                                    │2020-01-19 00:03:04.460  - info: host.iobroker-hwr Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker        │
                                    │2020-01-19 00:03:04.461  - info: host.iobroker-hwr hostname: iobroker-hwr, node: v10.18.0        │
                                    │2020-01-19 00:03:04.463  - info: host.iobroker-hwr ip addresses: 10.3.1.22 fe80::561e:8619:1900:f27        │
                                    │2020-01-19 00:03:34.473  - error: host.iobroker-hwr No connection to databases possible, restart        │
                                    │2020-01-19 00:03:34.481  - info: host.iobroker-hwr iobroker _restart        │
                                    │2020-01-19 00:03:35.059  - info: host.iobroker-hwr iobroker Starting node restart.js        │
                                    │2020-01-19 00:03:36.698  - info: host.iobroker-hwr iobroker.js-controller version 2.2.7 js-controller starting        │
                                    │2020-01-19 00:03:36.705  - info: host.iobroker-hwr Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker        │
                                    │2020-01-19 00:03:36.706  - info: host.iobroker-hwr hostname: iobroker-hwr, node: v10.18.0        │
                                    │2020-01-19 00:03:36.707  - info: host.iobroker-hwr ip addresses: 10.3.1.22 fe80::561e:8619:1900:f27        │
                                    │2020-01-19 00:04:06.718  - error: host.iobroker-hwr No connection to databases possible, restart        │
                                    │2020-01-19 00:04:06.726  - info: host.iobroker-hwr iobroker _restart        │
                                    │2020-01-19 00:04:07.278  - info: host.iobroker-hwr iobroker Starting node restart.js        │
                                    │2020-01-19 00:04:08.952  - info: host.iobroker-hwr iobroker.js-controller version 2.2.7 js-controller starting        │
                                    │2020-01-19 00:04:08.959  - info: host.iobroker-hwr Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker        │
                                    │2020-01-19 00:04:08.960  - info: host.iobroker-hwr hostname: iobroker-hwr, node: v10.18.0        │
                                    │2020-01-19 00:04:08.962  - info: host.iobroker-hwr ip addresses: 10.3.1.22 fe80::561e:8619:1900:f27        │
                                    │2020-01-19 00:04:38.973  - error: host.iobroker-hwr No connection to databases possible, restart        │
                                    │2020-01-19 00:04:38.981  - info: host.iobroker-hwr iobroker _restart        │
                                    │2020-01-19 00:04:39.553  - info: host.iobroker-hwr iobroker Starting node restart.js        │
                                    │2020-01-19 00:04:41.202  - info: host.iobroker-hwr iobroker.js-controller version 2.2.7 js-controller starting        │
                                    │2020-01-19 00:04:41.209  - info: host.iobroker-hwr Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker        │
                                    │2020-01-19 00:04:41.210  - info: host.iobroker-hwr hostname: iobroker-hwr, node: v10.18.0        │
                                    │2020-01-19 00:04:41.212  - info: host.iobroker-hwr ip addresses: 10.3.1.22 fe80::561e:8619:1900:f27        │
                                    │2020-01-19 00:05:11.223  - error: host.iobroker-hwr No connection to databases possible, restart        │
                                    │2020-01-19 00:05:11.230  - info: host.iobroker-hwr iobroker _restart        │
                                    │2020-01-19 00:05:11.784  - info: host.iobroker-hwr iobroker Starting node restart.js        │
                                    │2020-01-19 00:05:13.453  - info: host.iobroker-hwr iobroker.js-controller version 2.2.7 js-controller starting        │
                                    │2020-01-19 00:05:13.461  - info: host.iobroker-hwr Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker        │
                                    │2020-01-19 00:05:13.462  - info: host.iobroker-hwr hostname: iobroker-hwr, node: v10.18.0        │
                                    │2020-01-19 00:05:13.463  - info: host.iobroker-hwr ip addresses: 10.3.1.22 fe80::561e:8619:1900:f27        │
                                    │2020-01-19 00:05:43.475  - error: host.iobroker-hwr No connection to databases possible, restart        │
                                    │2020-01-19 00:05:43.483  - info: host.iobroker-hwr iobroker _restart        │
                                    │2020-01-19 00:05:44.039  - info: host.iobroker-hwr iobroker Starting node restart.js        │
                                    │2020-01-19 00:05:45.706  - info: host.iobroker-hwr iobroker.js-controller version 2.2.7 js-controller starting        │
                                    │2020-01-19 00:05:45.713  - info: host.iobroker-hwr Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker        │
                                    │2020-01-19 00:05:45.714  - info: host.iobroker-hwr hostname: iobroker-hwr, node: v10.18.0        │
                                    │2020-01-19 00:05:45.715  - info: host.iobroker-hwr ip addresses: 10.3.1.22 fe80::561e:8619:1900:f27
                                    • apollon77A Online
                                      apollon77A Online
                                      #159
                                      Also ich sehe im Log das er an sich versucht den Restart auszuführen ... jetzt ist nur die Frage ob/wie der im Container tut. Wäre ggf mal ein Issue bei buanet wert das man das mal anschaut
                                      • apollon77A Online
                                        apollon77A Online
                                        #160
                                        @darkiop sagte in Beta-Test js-controller 2.2.x GitHub:
                                        Aber ich hab zwei andere Dinge gesehen die ich noch fixe ... eins davon könnte der Grund sein, Mal schauen.
                                        • D darkiop
                                          apollon77A Online
                                          apollon77A Online
                                          #161
                                          @darkiop tu mir bitte mal einen Gefallen: Schau bitte mal ob das .gz logfile auf dem Master wo es gecrasht ist ok ist. Also keine log Blöcke doppelt oder generell kaputt und so.
                                          Scheinbar ist das Rotieren quasi doppelt gelaufen und da ganze so das die checks die dafür drin sind nicht schnell genug waren.
