  4. Adapter: DasWetter
Adapter: DasWetter
1.7k Beiträge 249 Kommentatoren 719.1k Aufrufe 133 Beobachtet
  • Rene_HMR Rene_HM
    Die vis habe ich mit einem zusätzlichen javascript erstellt.
    ! createState('WeatherSymbol0', '');
    ! createState('WindSymbol0', '');
    ! createState('WeatherSymbol1', '');
    ! createState('WindSymbol1', '');
    ! createState('WeatherSymbol2', '');
    ! createState('WindSymbol2', '');
    ! createState('WeatherSymbol3', '');
    ! createState('WindSymbol3', '');
    ! createState('WeatherSymbol4', '');
    ! createState('WindSymbol4', '');
    ! on("daswetter.0.NextDaysDetailed.0d.SymbolID", function(obj) {
    ! var symbol = parseInt(obj.newState.val, 10);
    ! var temp = 'http://192.168.DeineIP:8082/daswetter/i … /galeria3/' + symbol + '.png';
    ! log (temp);
    ! setState('WeatherSymbol0', temp );
    ! on("daswetter.0.NextDaysDetailed.0d.WindSymbolB", function(obj) {
    ! var windsymbol = parseInt(obj.newState.val, 10);
    ! var temp = 'http://192.168.DeineIP:8082/daswetter/i ... nd/galeria 2 - Beaufort/' + windsymbol + '.png';
    ! log (temp);
    ! setState('WindSymbol0', temp);
    ! on("daswetter.0.NextDaysDetailed.1d.SymbolID", function(obj) {
    ! var temp = 'http://192.168.DeineIP:8082/daswetter/i ... /galeria3/' + symbol + '.png';
    ! log (temp);
    ! setState('WeatherSymbol1', temp );
    ! on("daswetter.0.NextDaysDetailed.1d.WindSymbolB", function(obj) {
    ! log (temp);
    ! setState('WindSymbol1', temp);
    ! on("daswetter.0.NextDaysDetailed.2d.SymbolID", function(obj) {
    ! log (temp);
    ! setState('WeatherSymbol2', temp );
    ! on("daswetter.0.NextDaysDetailed.2d.WindSymbolB", function(obj) {
    ! log (temp);
    ! setState('WindSymbol2', temp);
    ! on("daswetter.0.NextDaysDetailed.3d.SymbolID", function(obj) {
    ! log (temp);
    ! setState('WeatherSymbol3', temp );
    ! on("daswetter.0.NextDaysDetailed.3d.WindSymbolB", function(obj) {
    ! log (temp);
    ! setState('WindSymbol3', temp);
    ! on("daswetter.0.NextDaysDetailed.4d.SymbolID", function(obj) {
    ! log (temp);
    ! setState('WeatherSymbol4', temp );
    ! on("daswetter.0.NextDaysDetailed.4d.WindSymbolB", function(obj) {
    ! log (temp);
    ! setState('WindSymbol4', temp);
    In dem script lege ich für jeden Tage eine Variable für WetterSymbol und WindSymbol an. Bei Änderung des Wertes im Adapter wird der link auf das entsprechende Icon auf die Variable geschrieben. Ich habe die komplette IP (muss oben im script entsprechend angepasst werden) mit drin, damit das ganze nicht nur im explorer sondern auch in der Android-App funktioniert.
    In der vis nehme ich dann ein einfaches "String Image Src"und als Quelle nehme ich die Variable aus dem javascript (siehe Bild)
    Alexxx2005
    #933
    @Rene_HM said in Adapter: DasWetter:
    ! log (temp);
    ! log (temp);
    ! log (temp);
    ! log (temp);
    ! log (temp);
    ! log (temp);
    ! log (temp);
    ! log (temp);
    ! log (temp);
    ! log (temp);
    Hallo Zusammen bekomme es einfach nicht geschafft, kann es sein das es so aktuell nicht mehr möglich ist ?
    Danke, Grüße Alex
    C 1 Antwort Letzte Antwort
    • A Alexxx2005
      ! log (temp);
      ! log (temp);
      ! log (temp);
      ! log (temp);
      ! log (temp);
      ! log (temp);
      ! log (temp);
      ! log (temp);
      ! log (temp);
      ! log (temp);
      Danke, Grüße Alex
      Coffeelover
      #934
      @Alexxx2005 Nein, kann eigentlich nicht sein - bei mir läuft das in VIS.
      • ListenpunktHast du Einträge im Log?
      • Läuft das Script?
      • Werden die Datenpunkte selbst richtig angelegt / befüllt?
      • Ändern sich die Icon, wenn du die Datenpunkte selbst veränderst? Da kann ja nichts passieren, weil das Script deine Änderung im nächsten Update eh wieder aktualisiert.
      B A 2 Antworten Letzte Antwort
      • C Coffeelover
        • Läuft das Script?
        Bastel2001
        #935
        ich habe den Adapter, den Script und das Widget installiert und alles läuft. Schonmal vorab vielen Dank dafür.
        Die Beschriftung auf der X-Achse ist nach durchprobieren %a..%z augenscheinlich englisch, ich hätte hier gern die deutsche kurze Variante also Mo,Di,Mi...
        Gibt es hierfür eine Lösung?
        Danke sehr
        • C Coffeelover
          • Läuft das Script?
          Alexxx2005
          #936
          @Coffeelover Danke nun läuft das Script.
          habe in der zwischenzeit noch den Sonnenstand installiert, Problem ist hier noch mit den icons wo finde ich die Sonnen Icon's habe alles durchblättert und finde nur die Wetter Hd oder Mond Icon's würde mich freuen wenn mir hier jemand weiter helfen kann. Grüße Alex
            Alexxx2005
            #937
            die icoc's habe ich mittlerweile gefunden .
            Problem ist nur das mein Adapter sich nicht aktualisiert, habe beim vierten Pfad die API eingetragen , jetzt die große Frage müssen oben beide Haken gesetzt sein oder nicht da bin ich mir nicht sicher.
            Grüße Alex
            • A Alexxx2005
              Grüße Alex
              sigi234S Online
              sigi234S Online
              #938
              @Alexxx2005 sagte in Adapter: DasWetter:
              Cron auf aktuelle Zeit setzen und warten
              • sigi234S sigi234
                Alexxx2005
                #939
                @sigi234 ok aber was ist mit den Haken in der Adapterkonfiguration ?
                Rene_HMR 1 Antwort Letzte Antwort
                • A Alexxx2005
                  Rene_HMR Offline
                  Rene_HMR Offline
                  Rene_HM
                  #940
                  @Alexxx2005 Es muss nur ein Haken "neue Struktur" gesetzt sein...
                  Bzgl. Aktualisierung: schau mal im log nach, ob da etwas steht...
                    Snapergy
                    #941
                    Gibt es denn eine Möglichkeit, dass die Schnittstelle auch die Regenwahrscheinlichkeit und den UV-Index mit ausgibt?
                    • S Snapergy
                      sigi234S Online
                      sigi234S Online
                      #942
                      @Snapergy sagte in Adapter: DasWetter:
                      Nein, aber Regen geht mit WU und UV mit dem Adapter
                      https://github.com/x3l4c0d3/ioBroker.openuv
                      • SMSS Offline
                        SMSS Offline
                        SMS
                        schrieb am zuletzt editiert von SMS
                        #943
                        irgendwie funktioniert das bei mir nicht:
                        Das Obere ist das weather Widget
                        Im Unteren sollten eigentlich die Daten wie hier beschrieben wird dargestellt werden.
                        Werte kommen an
                        Müsste hier nicht auch was drin stehen?
                        Steht im LOG
                        Danke!
                        NegaleinN FredFF 2 Antworten Letzte Antwort
                        • SMSS SMS
                          Werte kommen an
                          Steht im LOG
                          Danke!
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          #944
                          @SMS sagte in Adapter: DasWetter:
                          Steht im LOG
                          Stell den Adapter mal auf "Debug". Dann sieht man mehr im Log.
                          ° Fixer ---> iob fix
                          • SMSS Offline
                            SMSS Offline
                            SMS
                            #945
                            Hab cron mal kurz auf eine Minute gestellt:
                            • SMSS SMS
                              Rene_HMR Offline
                              Rene_HMR Offline
                              Rene_HM
                              schrieb am zuletzt editiert von Rene_HM
                              #946
                              @SMS Der Adapter aktualisiert Daten. Das sieht man ja auch oben im screen shot unter daswetter.0.
                              Der Adapter schreibt aber nicht auf Datenpunkte unter javascript.vis. Das müsste im script erfolgen...
                              • SMSS SMS
                                Werte kommen an
                                Steht im LOG
                                Danke!
                                FredFF Offline
                                FredFF Offline
                                FredF
                                Most Active Forum Testing
                                #947
                                @SMS
                                Wenn Daten ankommen, ist die Frage was das Skript macht und wo die Daten hinwandern. Zeig doch bitte mal dein Skript
                                • SMSS Offline
                                  SMSS Offline
                                  SMS
                                  #948
                                  var temp = 'http://192.168.178.75:8082/daswetter/i … /galeria3/' + symbol + '.png';
                                  log (temp);
                                  var temp = 'http://192.168.178.75:8082/daswetter/i ... nd/galeria 2 - Beaufort/' + windsymbol + '.png';
                                  log (temp);
                                  var temp = 'http://192.168.178.75:8082/daswetter/i ... /galeria3/' + symbol + '.png';
                                  log (temp);
                                  log (temp);
                                  log (temp);
                                  log (temp);
                                  log (temp);
                                  log (temp);
                                  log (temp);
                                  log (temp);
                                  Ist der von hier, habe lediglich die IP Adresse angepasst
                                  Das obere weather Widget hatte ich mir auch anders vorgestellt ... Zumindest wenn ich mal so vergleiche was man so sieht ...
                                  Rene_HMR 2 Antworten Letzte Antwort
                                  • SMSS SMS
                                    log (temp);
                                    log (temp);
                                    log (temp);
                                    log (temp);
                                    log (temp);
                                    log (temp);
                                    log (temp);
                                    log (temp);
                                    log (temp);
                                    log (temp);
                                    Rene_HMR Offline
                                    Rene_HMR Offline
                                    Rene_HM
                                    #949
                                    @SMS und warum nimmst du die Pfade zu den Symbolen nicht direkt aus dem Adapter?
                                    Da könntest du dir das script sparen...
                                    • SMSS SMS
                                      log (temp);
                                      log (temp);
                                      log (temp);
                                      log (temp);
                                      log (temp);
                                      log (temp);
                                      log (temp);
                                      log (temp);
                                      log (temp);
                                      log (temp);
                                      Rene_HMR Offline
                                      Rene_HMR Offline
                                      Rene_HM
                                      #950
                                      Da kannst du doch fast alles selbst einstellen. Was fehlt dir?
                                      • SMSS Offline
                                        SMSS Offline
                                        SMS
                                        #951
                                        Asso das muss alles einzeln eingestellt werden ... Dachte das wäre fertig ...
                                        • sigi234S sigi234
                                          @der-eine sagte in Adapter: DasWetter:
                                          @sigi234
                                          Was hast Du denn im CSS von container - Icon - view in jqui Dialog stehen?
                                          Das Skript von Uhula hab ich schon eingefügt.
                                          SMSS Offline
                                          SMSS Offline
                                          SMS
                                          #952
                                          Das hier sind also alles einzelne Widgets?
