  4. Adapter: DasWetter
Adapter: DasWetter
1.7k Beiträge 249 Kommentatoren 719.1k Aufrufe 133 Beobachtet
  • hg6806H hg6806
    OK, wo finde ich das Verzeichnis "docs"
    Rene_HMR Offline
    Rene_HMR Offline
    Rene_HM
    #932
    @hg6806 siehe hier:
    oder auch bei DasWetter unter
    https://www.daswetter.com/api/#/board/hilfe
    • Rene_HMR Rene_HM
      Die vis habe ich mit einem zusätzlichen javascript erstellt.
      ! createState('WeatherSymbol0', '');
      ! createState('WindSymbol0', '');
      ! createState('WeatherSymbol1', '');
      ! createState('WindSymbol1', '');
      ! createState('WeatherSymbol2', '');
      ! createState('WindSymbol2', '');
      ! createState('WeatherSymbol3', '');
      ! createState('WindSymbol3', '');
      ! createState('WeatherSymbol4', '');
      ! createState('WindSymbol4', '');
      ! on("daswetter.0.NextDaysDetailed.0d.SymbolID", function(obj) {
      ! var symbol = parseInt(obj.newState.val, 10);
      ! var temp = 'http://192.168.DeineIP:8082/daswetter/i … /galeria3/' + symbol + '.png';
      ! log (temp);
      ! setState('WeatherSymbol0', temp );
      ! on("daswetter.0.NextDaysDetailed.0d.WindSymbolB", function(obj) {
      ! var windsymbol = parseInt(obj.newState.val, 10);
      ! var temp = 'http://192.168.DeineIP:8082/daswetter/i ... nd/galeria 2 - Beaufort/' + windsymbol + '.png';
      ! log (temp);
      ! setState('WindSymbol0', temp);
      ! on("daswetter.0.NextDaysDetailed.1d.SymbolID", function(obj) {
      ! var temp = 'http://192.168.DeineIP:8082/daswetter/i ... /galeria3/' + symbol + '.png';
      ! log (temp);
      ! setState('WeatherSymbol1', temp );
      ! on("daswetter.0.NextDaysDetailed.1d.WindSymbolB", function(obj) {
      ! log (temp);
      ! setState('WindSymbol1', temp);
      ! on("daswetter.0.NextDaysDetailed.2d.SymbolID", function(obj) {
      ! log (temp);
      ! setState('WeatherSymbol2', temp );
      ! on("daswetter.0.NextDaysDetailed.2d.WindSymbolB", function(obj) {
      ! log (temp);
      ! setState('WindSymbol2', temp);
      ! on("daswetter.0.NextDaysDetailed.3d.SymbolID", function(obj) {
      ! log (temp);
      ! setState('WeatherSymbol3', temp );
      ! on("daswetter.0.NextDaysDetailed.3d.WindSymbolB", function(obj) {
      ! log (temp);
      ! setState('WindSymbol3', temp);
      ! on("daswetter.0.NextDaysDetailed.4d.SymbolID", function(obj) {
      ! log (temp);
      ! setState('WeatherSymbol4', temp );
      ! on("daswetter.0.NextDaysDetailed.4d.WindSymbolB", function(obj) {
      ! log (temp);
      ! setState('WindSymbol4', temp);
      In dem script lege ich für jeden Tage eine Variable für WetterSymbol und WindSymbol an. Bei Änderung des Wertes im Adapter wird der link auf das entsprechende Icon auf die Variable geschrieben. Ich habe die komplette IP (muss oben im script entsprechend angepasst werden) mit drin, damit das ganze nicht nur im explorer sondern auch in der Android-App funktioniert.
      In der vis nehme ich dann ein einfaches "String Image Src"und als Quelle nehme ich die Variable aus dem javascript (siehe Bild)
      Alexxx2005
      #933
      @Rene_HM said in Adapter: DasWetter:
      ! log (temp);
      ! log (temp);
      ! log (temp);
      ! log (temp);
      ! log (temp);
      ! log (temp);
      ! log (temp);
      ! log (temp);
      ! log (temp);
      ! log (temp);
      Hallo Zusammen bekomme es einfach nicht geschafft, kann es sein das es so aktuell nicht mehr möglich ist ?
      Danke, Grüße Alex
      C 1 Antwort Letzte Antwort
      • A Alexxx2005
        ! log (temp);
        ! log (temp);
        ! log (temp);
        ! log (temp);
        ! log (temp);
        ! log (temp);
        ! log (temp);
        ! log (temp);
        ! log (temp);
        ! log (temp);
        Danke, Grüße Alex
        Coffeelover
        #934
        @Alexxx2005 Nein, kann eigentlich nicht sein - bei mir läuft das in VIS.
        • ListenpunktHast du Einträge im Log?
        • Läuft das Script?
        • Werden die Datenpunkte selbst richtig angelegt / befüllt?
        • Ändern sich die Icon, wenn du die Datenpunkte selbst veränderst? Da kann ja nichts passieren, weil das Script deine Änderung im nächsten Update eh wieder aktualisiert.
        B A 2 Antworten Letzte Antwort
        • C Coffeelover
          • Läuft das Script?
          Bastel2001
          #935
          ich habe den Adapter, den Script und das Widget installiert und alles läuft. Schonmal vorab vielen Dank dafür.
          Die Beschriftung auf der X-Achse ist nach durchprobieren %a..%z augenscheinlich englisch, ich hätte hier gern die deutsche kurze Variante also Mo,Di,Mi...
          Gibt es hierfür eine Lösung?
          Danke sehr
          • C Coffeelover
            • Läuft das Script?
            Alexxx2005
            #936
            @Coffeelover Danke nun läuft das Script.
            habe in der zwischenzeit noch den Sonnenstand installiert, Problem ist hier noch mit den icons wo finde ich die Sonnen Icon's habe alles durchblättert und finde nur die Wetter Hd oder Mond Icon's würde mich freuen wenn mir hier jemand weiter helfen kann. Grüße Alex
              Alexxx2005
              #937
              die icoc's habe ich mittlerweile gefunden .
              Problem ist nur das mein Adapter sich nicht aktualisiert, habe beim vierten Pfad die API eingetragen , jetzt die große Frage müssen oben beide Haken gesetzt sein oder nicht da bin ich mir nicht sicher.
              Grüße Alex
              • A Alexxx2005
                Grüße Alex
                sigi234S Online
                sigi234S Online
                #938
                @Alexxx2005 sagte in Adapter: DasWetter:
                Cron auf aktuelle Zeit setzen und warten
                • sigi234S sigi234
                  Alexxx2005
                  #939
                  @sigi234 ok aber was ist mit den Haken in der Adapterkonfiguration ?
                  Rene_HMR 1 Antwort Letzte Antwort
                  • A Alexxx2005
                    Rene_HMR Offline
                    Rene_HMR Offline
                    Rene_HM
                    #940
                    @Alexxx2005 Es muss nur ein Haken "neue Struktur" gesetzt sein...
                    Bzgl. Aktualisierung: schau mal im log nach, ob da etwas steht...
                      Snapergy
                      #941
                      Gibt es denn eine Möglichkeit, dass die Schnittstelle auch die Regenwahrscheinlichkeit und den UV-Index mit ausgibt?
                      • S Snapergy
                        sigi234S Online
                        sigi234S Online
                        #942
                        @Snapergy sagte in Adapter: DasWetter:
                        Nein, aber Regen geht mit WU und UV mit dem Adapter
                        https://github.com/x3l4c0d3/ioBroker.openuv
                        • SMSS Offline
                          SMSS Offline
                          SMS
                          schrieb am zuletzt editiert von SMS
                          #943
                          irgendwie funktioniert das bei mir nicht:
                          Das Obere ist das weather Widget
                          Im Unteren sollten eigentlich die Daten wie hier beschrieben wird dargestellt werden.
                          Werte kommen an
                          Müsste hier nicht auch was drin stehen?
                          Steht im LOG
                          Danke!
                          NegaleinN FredFF 2 Antworten Letzte Antwort
                          • SMSS SMS
                            Werte kommen an
                            Steht im LOG
                            Danke!
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            #944
                            @SMS sagte in Adapter: DasWetter:
                            Steht im LOG
                            Stell den Adapter mal auf "Debug". Dann sieht man mehr im Log.
                            ° Fixer ---> iob fix
                            • SMSS Offline
                              SMSS Offline
                              SMS
                              #945
                              Hab cron mal kurz auf eine Minute gestellt:
                              • SMSS SMS
                                Rene_HMR Offline
                                Rene_HMR Offline
                                Rene_HM
                                schrieb am zuletzt editiert von Rene_HM
                                #946
                                @SMS Der Adapter aktualisiert Daten. Das sieht man ja auch oben im screen shot unter daswetter.0.
                                Der Adapter schreibt aber nicht auf Datenpunkte unter javascript.vis. Das müsste im script erfolgen...
                                • SMSS SMS
                                  Werte kommen an
                                  Steht im LOG
                                  Danke!
                                  FredFF Offline
                                  FredFF Offline
                                  FredF
                                  Most Active Forum Testing
                                  #947
                                  @SMS
                                  Wenn Daten ankommen, ist die Frage was das Skript macht und wo die Daten hinwandern. Zeig doch bitte mal dein Skript
                                  • SMSS Offline
                                    SMSS Offline
                                    SMS
                                    #948
                                    var temp = 'http://192.168.178.75:8082/daswetter/i … /galeria3/' + symbol + '.png';
                                    log (temp);
                                    var temp = 'http://192.168.178.75:8082/daswetter/i ... nd/galeria 2 - Beaufort/' + windsymbol + '.png';
                                    log (temp);
                                    var temp = 'http://192.168.178.75:8082/daswetter/i ... /galeria3/' + symbol + '.png';
                                    log (temp);
                                    log (temp);
                                    log (temp);
                                    log (temp);
                                    log (temp);
                                    log (temp);
                                    log (temp);
                                    log (temp);
                                    Ist der von hier, habe lediglich die IP Adresse angepasst
                                    Das obere weather Widget hatte ich mir auch anders vorgestellt ... Zumindest wenn ich mal so vergleiche was man so sieht ...
                                    Rene_HMR 2 Antworten Letzte Antwort
                                    • SMSS SMS
                                      log (temp);
                                      log (temp);
                                      log (temp);
                                      log (temp);
                                      log (temp);
                                      log (temp);
                                      log (temp);
                                      log (temp);
                                      log (temp);
                                      log (temp);
                                      Rene_HMR Offline
                                      Rene_HMR Offline
                                      Rene_HM
                                      #949
                                      @SMS und warum nimmst du die Pfade zu den Symbolen nicht direkt aus dem Adapter?
                                      Da könntest du dir das script sparen...
                                      • SMSS SMS
                                        log (temp);
                                        log (temp);
                                        log (temp);
                                        log (temp);
                                        log (temp);
                                        log (temp);
                                        log (temp);
                                        log (temp);
                                        log (temp);
                                        log (temp);
                                        Rene_HMR Offline
                                        Rene_HMR Offline
                                        Rene_HM
                                        #950
                                        Da kannst du doch fast alles selbst einstellen. Was fehlt dir?
                                        • SMSS Offline
                                          SMSS Offline
                                          SMS
                                          #951
                                          Asso das muss alles einzeln eingestellt werden ... Dachte das wäre fertig ...
