  4. [Projekt] Material Design CSS für ioBroker.vis
650 Beiträge 111 Kommentatoren 278.3k Aufrufe 68 Beobachtet
  • D DJNick134
    @tempestas said in [Projekt] Material Design CSS für ioBroker.vis:
    var idCal = "ical.X"; // hier deine ical instanz (x ersetzen) var idCalTrigger = idCal + ".data.trigger"; var idCalTable = idCal + ".data.table"; var idCalHTML = idCal + ".data.html"; var idCalHTMLtable = idCal + ".html"; ! createState(idCalHTMLtable, " "); ! function iCalToHTMLTable() { var html = ""; var calTable = getState(idCalTable); var inst = getObject("system.adapter."+idCal); var instopt = inst.native; var calendar = {}; ! for (var i = 0; i < calTable.val.length; i++) { var entry = calTable.val[i]; if ( entry._calName != calendar.name ) { calendar = {}; for (var c = 0; c < instopt.calendars.length; c++ ) { if (entry._calName == instopt.calendars[c].name ) { calendar = instopt.calendars[c]; break; } } } if (calendar.color !== "") html+=""; else html+=""; html+/ html+/ html+/ html+=""; } html+=" ! | Zeit | Text | Kalendar | | --- | --- | --- | | "+entry.date+" | "+entry.event+" | "+entry._calName+" | ! "; setState(idCalHTMLtable, html); //dump( html ); } ! on({id: idCalTable, change: "ne"}, function (obj) { iCalToHTMLTable(); }); ! iCalToHTMLTable();
    Wenn ich das Skript bei mir starte kommen immer folgende Fehler im log:
    javascript.0	2019-10-14 18:32:16.658	error	(12704) at process._tickCallback (internal/process/next_tick.js:189:7)
    javascript.0	2019-10-14 18:32:16.658	error	(12704) at <anonymous>:null:null
    javascript.0	2019-10-14 18:32:16.658	error	(12704) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    javascript.0	2019-10-14 18:32:16.658	error	(12704) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0	2019-10-14 18:32:16.658	error	(12704) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:434:21)
    javascript.0	2019-10-14 18:32:16.657	error	(12704) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:828:17)
    javascript.0	2019-10-14 18:32:16.657	error	(12704) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1237:17)
    javascript.0	2019-10-14 18:32:16.657	error	(12704) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1184:37)
    javascript.0	2019-10-14 18:32:16.656	error	(12704) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:961:28)
    javascript.0	2019-10-14 18:32:16.655	error	(12704) at Object.createScript (vm.js:80:10)
    javascript.0	2019-10-14 18:32:16.655	error	(12704) SyntaxError: Invalid or unexpected token
    javascript.0	2019-10-14 18:32:16.654	error	(12704) ^
    javascript.0	2019-10-14 18:32:16.654	error	(12704) var html = "
    javascript.0	2019-10-14 18:32:16.654	error	(12704) script.js.common.Kalender.iCal_to_HTML compile failed: at script.js.common.Kalender.iCal_to_HTML:8
    Weiß jemand wo der Fehler im Skript ist? Komme nicht weiter :/
    sigi234S Online
    sigi234S Online
    #384
    @DJNick134
    Das fehlt was beim Skript. Von wo hat du es und was soll es machen?
    • sigi234S sigi234
      @DJNick134
      DJNick134
      #385
      @sigi234 Habs hier aus dem Forum kopiert. Mit dem Skript sollen die iCal Daten in eine HTML Datei gepackt werden, damit diese später in der Vis als Tabelle (Cards) angezeigt werden können
      • D DJNick134
        GlasfaserG Offline
        GlasfaserG Offline
        #386
        @DJNick134
        Wurde zerstückelt , bei der Forum´s Umstellung
        hier was funktioniert:
        // Posting von Uhula, 17.12. 11:52h
        var idCal = "ical.x";						// hier deine ical instanz (x ersetzen)
            var html     = "<table style='font-size:1.0em;'><thead><tr><th style='text-align:left;'>Zeit</th><th style='text-align:left;'>Text</th><th style='text-align:left;'>Kalendar</th></tr></thead><tbody>";
            var calendar = {};
                    calendar = {};
                            break;
                    html+="<tr style='background:transparent; background-image: linear-gradient("+calendar.color+","+calendar.color+"); background-size: 4px 90%; background-repeat: no-repeat;'>";
                else
                    html+="<tr>";
                html+="<td style='font-size:1.0em;'>"+entry.date+"</td>"
                html+="<td>"+entry.event+"</td>"
                html+="<td>"+entry._calName+"</td>"
                html+="</tr>";
            html+="</body></table>";
        //dump( html );
            iCalToHTMLTable();
        iCalToHTMLTable();
        • O ok1
          @Uhula
          Hallo, ich nutze ja schon länger Dein MD CSS Framework. Mittlerweile hat sich darauf ein umfangreiches Projekt entwickelt.
          Das Problem ist nur, dass die Ladezeiten auf dem Samsung Tablet A10 immer länger werden - im Moment vom Reload der Seite bis zur Anzeige im Browser 20-30sec. Solange ist die Seite weiss. Im PC-Browser (Chrome wie auch auf dem A10 Tablet) lädt die Seite in ca. 3-5 sec.
          Auffällig ist beim Debuggen im Browser das Auftreten vieler jquery-Meldungen in der Browser-Console:
          jquery-1.11.2.min.js:3 [Violation] Added non-passive event listener to a scroll-blocking 'touchmove' event. Consider marking event handler as 'passive' to make the page more responsive. See https://www.chromestatus.com/feature/5745543795965952
          In Deinen MD_Demo Projekt sind das ca. 50 Meldungen und die Seite lädt in ca.3 sec, was gefühlt ok ist.
          In meinem größeren Projekt laufen derzeit 300 Meldungen auf, und die Ladezeit geht wie oben beschrieben gegen eine halbe Minute.
          Meine Frage ist, ob Du diese Meldungen evtl. kennst, ob diese kritisch für die Performance sind und ggf. einen Tipp hast, wie man sie weg bekommt.
          Ich habe zum Vergleich mal andere jquery-Seiten im Debugger mitlaufen lassen, da tauchen die o.g. Meldungen nicht auf und laden auch als jquery-Seiten schnell im Mobile-Chrome.
          Ich bin für jeden Tipp dankbar, VG ok
          O Offline
          O Offline
          ok1
          #387
          @ok1 sagte in [Projekt] Material Design CSS für ioBroker.vis:
          Ich habe die Meldungen nun mit folgendem jquery- Code in VIS- Scripte wegbekommen:
          jQuery.event.special.touchstart = {
            setup: function( _, ns, handle ){
              if ( ns.includes("noPreventDefault") ) {
                this.addEventListener("touchstart", handle, { passive: false });
              } else {
                this.addEventListener("touchstart", handle, { passive: true });
          jQuery.event.special.touchmove = {
                this.addEventListener("touchmove", handle, { passive: false });
              } else {
                this.addEventListener("touchmove", handle, { passive: true });
          Leider hat sich dadurch an der schlechten Performance des Projekts insgesamt nichts geändert. Das Problem sind scheinbar die vielen
          [Violation] 'setTimeout' handler took 101ms
          zu sein. Auf dem Desktop-PC sind es jeweils nur 10-100ms pro 'setTimeout' handler, auf dem Tablet A9.7 (SM-T555) sind es 500 - 2000 ms. Diese timeouts addieren sich dann zu Gesamtladezeiten von 20-30 sec.
          Auslöser der Timeouts ist die setTimeout- Funktion in Zeile 938 in vis.js:
          if (!wait) {
                         if (!hidden) $view.show();
                         setTimeout(function () {
                             $('#visview_' + viewDiv).trigger('rendered');
                             if (callback) callback(viewDiv, view);
                         }, 0);
          Die Ladezeit der gleichen Seite auf einem neueren Sony Mobile halbierte sich z.B. auf 10 sec. Andere Sites mit viel mehr zu ladenden Elementen lassen sich gut und schnell auf dem Tablet absurfen. Es scheint somit am speziellen Aufbau der Material Design Frameworkseite und an der CPU/RAM-Leistung des Tablets zu liegen.
          • GlasfaserG Glasfaser
            @DJNick134
                var calendar = {};
                        calendar = {};
                                break;
                    else
                        html+="<tr>";
                    html+="</tr>";
            //dump( html );
                iCalToHTMLTable();
            iCalToHTMLTable();
            DJNick134
            #388
            @Glasfaser Super, vielen dank!
              davimas
              #389
              Danke für das Projekt - ich habe mir sogar die Anleitung ausgedruckt und lese immer wieder in der Mittagspause.
              Zwei Einsteigerfragen, wie ändere ich die Farbe der lnav?
              Bei der abar geht es mit "mdui-black-bg" Zugabe auf der Startpage, jedoch bekomm ich es nicht bei der lnav hin.
              Desweiteren sind die Farben ja festgelegt - und hätte gerne die abar in plüschrosa ;-))) Also habe ich in der CSS Klasse das "mdui-abar" weggemacht und so den Hintergrund farblich angepasst. Macht es jetzt was aus wenn die "abar" nicht als solche "festgelegt" ist?
              by,
              David
              P 1 Antwort Letzte Antwort
              • D davimas
                by,
                David
                Pittini
                #390
                @davimas Wenn Du die vordefinierten Farben nicht magst, dann dort ändern wo se definiert sind und nicht iwelche Verrenkungen machen welche iwann zu Problemen führen (können) Definiert sind se im CSS Bereich.
                • P Pittini
                  davimas
                  #391
                  @Pittini
                  Perfekt - Danke hat funktioniert. Und die Schriftfarbe der Textes/Menü in der lnav?
                  • D davimas
                    @Pittini
                    Pittini
                    #392
                    @davimas said in [Projekt] Material Design CSS für ioBroker.vis:
                    Jedes mdui-blabla hat eine Entsprechung in der CSS Datei, mußt halt dort nach dem gewünschten mdui-xxx suchen.
                    • UhulaU Uhula
                      Vorab-Info:
                      Ich habe das Material Design CSS/Script bei mir etwas erweitert, es kann nun auch "Chips" darstellen (Alternative zu Radio-Buttons). Wenn ich es auf Github aktualisiert habe, gibt es einen Hinweis hier im Forum.
                      davimas
                      #393
                      @Uhula said in [Projekt] Material Design CSS für ioBroker.vis:
                      Vorab-Info:
                      Hey,
                      sind die schon irgendwo verfügbar? Die CSS Klasse habe ich nicht gefunden in der Demo......
                      by,
                      David
                        Snapergy
                        #394
                        @Uhula
                        erst einmal vielen Dank für das schöne Design via CSS. Ich habe mir den Switch und den Slider für meine Visualisierung "rausgepickt". Jetzt habe ich eine Frage bzgl. der Machbarkeit an dich. Ich hätte gern beim Slider ein Label, welcher mit dem Knopf beim Vertical Slider mitläuft und den aktuellen Wert darstellt (siehe Discrete Slider vom Google Material Design). Ich hatte dazu auch schon einen Thread eröffnet, aber dort konnte mir keiner weiterhelfen.
                        Aktuell behelfe ich mir mit einer Krücke, welche den Wert in einem statischen HTML aus einem Datenobjekt ausliest. Dies ist aber immer mit einem kleinen Delay verbunden, welches sich als unschön und nicht gerade Userfreundlich darstellt.
                        • D davimas
                          Vorab-Info:
                          Hey,
                          by,
                          David
                          K_o_bold
                          #395
                          @davimas ,
                          @Uhula , das wäre echt super, wenn auch Chips zur Verfügung gestellt werden.
                          • S Snapergy
                            @Uhula
                            dos1973
                            #396
                            @Snapergy
                            Nimm doch einfach den DiscreteSlider aus dem MaterialDesign Adapter...?!
                            • D dos1973
                              @Snapergy
                              Snapergy
                              #397
                              @dos1973
                              den gibt es leider nicht als vertikalen slider :(
                              • nukleuzN Offline
                                nukleuzN Offline
                                nukleuz
                                #398
                                Gibt es schon das Update für die Chips?
                                Intel NUC -> ProxMox -> Debian -> ioBroker (Master)| RPI3B+ -> rtl_433 (Slave) | CCU2
                                  K_o_bold
                                  schrieb am zuletzt editiert von K_o_bold
                                  #399
                                  So wie es aussieht, ist Uhula in diesem Forum nicht mehr so aktiv. Schade, denn die Chips sehen echt gut aus...
                                  • UhulaU Offline
                                    UhulaU Offline
                                    Uhula
                                    #400
                                    Stimmt, bin im Moment nicht aktiv im Forum, dafür aber umso aktiver beim Erstellen der Material Design for ioBroker 2.0 CSS Styles ;-) - dann natürlich inkl. der Chips.
                                    • Basis ist dann ein helles Design, das dunkle ist dann optional, auch jederzeit umschaltbar (wenn denn eigene Komponenten das auch mitmachen, die mdui- können es)
                                    • optionales Setzen der Farben für abar, tnav, lnav, rnav, bnav und content, inkl. automatischer Anpassung der Schriftfarbe (wenn Kontrast zu "schwarz" zu gering, dann "weiß") über mdui-config Elemente
                                    • die linke Navigation (lnav) kann als feste Site-Navigation arbeiten (optional ab x-Pixel Breite des Screens). Also auf dem Smartphone weiterhin als modale, sich öffnende Nav, auf dem Tablett dann als feste Nav, aber auch wegblendbar
                                    • Unterstützung des material-icons Fonts - d.h. images braucht man eigentlich nicht mehr. Vorteile: Sehr gute Skalierung und automatische Anpassung an die Schriftfarbe
                                    • alle material design Farben werden nun namentlich unterstützt
                                    • Anpassung der MD_Demo und MD_Simple Projekte
                                    • Anpassung der Dokumentation
                                    Dauert alles noch etwas, schaut aber schon gut aus, eben wie 2019 und nicht mehr wie 2017. Screenshots liefere ich mal nach.
                                    Schöne Adventszeit noch!
                                    Uhula - Leise und Weise
                                    Ex: ioBroker on Gigabyte NUC Proxmox
                                    Z D blauholstenB S frieda99F 5 Antworten Letzte Antwort
                                      Schrauberheld
                                      schrieb am zuletzt editiert von Schrauberheld
                                      #401
                                      Finde ich Mega das du noch an dem ganzen arbeitest 👍
                                      • UhulaU Uhula
                                        Z Abwesend
                                        Z Abwesend
                                        zahnheinrich
                                        #402
                                        @Uhula
                                        Da warte ich aber SEHR gespannt!
                                        Ich glaube da spreche ich für eine größere Gemeinde, als du ahnst!
                                        MfG Ulrich
                                        • Z zahnheinrich
                                          @Uhula
                                          davimas
                                          schrieb am zuletzt editiert von davimas
                                          #403
                                          @zahnheinrich
                                          Die Meisten nutzen mittlerweile den neuen Adapter mit Material Style - da es hier still wurde in der Weiterentwicklung.....
                                          https://forum.iobroker.net/topic/26925/test-adapter-material-design-widgets-v0-2-x
                                          MeistertrM D 2 Antworten Letzte Antwort
