  4. Test js-controller v2.0.x (GitHub)
js-controller
1.0k Beiträge 48 Kommentatoren 429.8k Aufrufe 35 Beobachtet
  • SBorgS SBorg
    @apollon77 nein, weil es im silly/debug-Modus problemlos läuft:
    2019-11-10 20:33:13.435 - info: host.Ubuntu instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
    2019-11-10 20:35:00.105 - info: host.Ubuntu instance system.adapter.luftdaten.0 started with pid 28937
    2019-11-10 20:35:03.705 - debug: luftdaten.0 (28937) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2019-11-10 20:35:05.065 - debug: luftdaten.0 (28937) Objects connected to redis: 127.0.0.1:9001
    2019-11-10 20:35:05.094 - debug: luftdaten.0 (28937) objectDB connected
    2019-11-10 20:35:05.099 - debug: luftdaten.0 (28937) Redis States: Use Redis connection: 127.0.0.1:9000
    2019-11-10 20:35:05.123 - debug: luftdaten.0 (28937) statesDB connected
    2019-11-10 20:35:05.182 - debug: luftdaten.0 (28937) States connected to redis: 127.0.0.1:9000
    2019-11-10 20:35:06.135 - info: luftdaten.0 (28937) starting. Version 0.0.9 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v8.16.2
    2019-11-10 20:35:06.232 - debug: luftdaten.0 (28937) sensor type: remote, sensor identifier: XXX, sensor name: XXX
    2019-11-10 20:35:06.243 - debug: luftdaten.0 (28937) remote request started
    2019-11-10 20:35:06.424 - silly: luftdaten.0 (28937) States redis pmessage system.adapter.luftdaten.0.logLevel/system.adapter.luftdaten.0.logLevel:{"val":"silly","ack":true,"ts":1573414506361,"q":0,"from":"system.adapter.luftdaten.0","lc":1573400109996}
    2019-11-10 20:35:07.298 - debug: luftdaten.0 (28937) remote request done
    2019-11-10 20:35:07.299 - debug: luftdaten.0 (28937) received data (200): [{"sensor":{"id": --- langer JSON-String mit Daten --- ":null,"timestamp":"2019-11-10 19:29:54"}]
    2019-11-10 20:35:16.294 - debug: luftdaten.0 (28937) cleaned everything up...
    2019-11-10 20:35:16.413 - info: luftdaten.0 (28937) Terminated (NO_ERROR): Without reason
    2019-11-10 20:35:16.934 - info: host.Ubuntu instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    2019-11-10 20:40:00.056 - info: host.Ubuntu instance system.adapter.luftdaten.0 started with pid 6119
    2019-11-10 20:40:04.292 - info: host.Ubuntu instance system.adapter.dwd.0 started with pid 6347
    2019-11-10 20:40:04.435 - debug: luftdaten.0 (6119) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2019-11-10 20:40:05.878 - debug: luftdaten.0 (6119) Objects connected to redis: 127.0.0.1:9001
    2019-11-10 20:40:05.922 - debug: luftdaten.0 (6119) objectDB connected
    2019-11-10 20:40:05.931 - debug: luftdaten.0 (6119) Redis States: Use Redis connection: 127.0.0.1:9000
    #1030
    @SBorg Zeig mal bitte aus der /opt/iobroker/iobroker-data/iobroker.json den "objects" Abschnitt. Da ist ein Feld "connectTimeout" ... was steht da bei Dir?
    • apollon77A apollon77
      SBorgS Offline
      SBorgS Offline
      SBorg
      #1031
      @apollon77 Zwei Sekunden:
       "objects": {
          "type": "file",
          "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].",
          "host": "127.0.0.1",
          "port": 9001,
          "user": "",
          "pass": "",
          "noFileCache": false,
          "connectTimeout": 2000,
          "options": {
            "auth_pass": null,
            "retry_max_delay": 5000
      LG SBorg ( SBorg auf GitHub)
      • SBorgS SBorg
         "objects": {
            "type": "file",
            "port": 9001,
            "user": "",
            "pass": "",
            "options": {
              "auth_pass": null,
        #1032
        @SBorg Ok, was auch default ist. Da wir beim Objects init jetzt einiges mehr tun reicht die Zeit vllt manchmal nicht, ich erhöhe das dann in der nächsten Version mal
        • apollon77A Offline
          #1033
          Hallo liebe tester!!
          Ich habe heute nochmal ein bissl Stopping mit Disconnects und sowas getestet und da war noch ein Bug drin. Weil wir dennoch gern morgen in Stable wollen brauche ich Dringe Eure Hilfe (nochmal).
          Bitte 2.0.44 vom GitHub testen. Ich packe die nach positiven Feedback von Euch nachher noch ins Latest.
          Gern auch wieder master/Slave Fälle testen ... alsoSlaves wenn master weg und so ... das wäre extrem super!!
          BBTownB 1 Antwort Letzte Antwort
            BBTownB Offline
            BBTownB Offline
            BBTown
            schrieb am zuletzt editiert von BBTown
            #1034
            @apollon77 die v2.0.44 bekomme ich leider nicht (system is up to date)
            • BBTownB BBTown
              #1035
              @BBTown sagte in Test js-controller v2.0.x (GitHub):
              @apollon77 die v2.0.44 bekomm eich leider nicht (system is up to date)
              musst du mit npm install ioBroker/ioBroker.js-controller direkt von git ziehen. (erst in iobroker-verzeichnis..)
                #1036
                Und nochmal ich ... Wer die 2.0.44 VOR 19:19 installiert hat bitte nochmal ... da war noch ein Bug :-(
                Aber jetzt schaut es bnei mir ok aus
                BBTownB dslraserD ? 3 Antworten Letzte Antwort
                  BBTownB Offline
                  BBTownB Offline
                  BBTown
                  #1037
                  @apollon77
                  bei mir sieht alles unauffällig aus .... aber eben auch ein einfaches System (kein slave, file/file)
                    dslraserD Offline
                    dslraserD Offline
                    dslraser
                    #1038
                    @apollon77
                    Edit.....jetzt ging es doch weiter....
                      #1039
                      @apollon77 hier alles ohne Probleme - habe nachdem alles auf der 44 war, nochmal die Clienthosts rebootet, um zu sehen, was der iobroker macht, aber er wartet und die clients haben sich sehr schnell connected.
                      Andersrum auch getestet, die clients warten schön bis der Masterhost wieder da ist.
                        #1040
                        perfekt Danke!
                        • SBorgS Offline
                          SBorgS Offline
                          SBorg
                          #1041
                          Bis jetzt sieht es top aus, nicht mal beim hochfahren einen "objects-DB"-Fehler 👍 8)
                          • BBTownB BBTown
                            @apollon77
                            dslraserD Offline
                            dslraserD Offline
                            dslraser
                            #1042
                            @apollon77
                            Dito.
                              #1043
                              Perfekt dann kommt es auf npm sobald die Kids im Bett sind. ;-)
                                #1044
                                SO, HIER IST ERST MAL SCHLUSS ....
                                --> https://forum.iobroker.net/topic/26759/js-controller-2-jetzt-für-alle-im-stable
                                mega Dank an alle Mitwirkenden !! War eine Super Zusammenarbeit.
                                Ich lasse mal noch 1-2 Tage den Thread offen falls Fixes nötig sind ...
                                  #1045
                                  An alle fleissigen Tester der 2.0 "damals" ... jetzt kommt die 2.2 und Eure hilfe wäre wieder super ... ---> https://forum.iobroker.net/topic/28139/beta-test-js-controller-2-2-x-github
                                  • MathiasJM Offline
                                    MathiasJM Offline
                                    MathiasJ
                                    schrieb am zuletzt editiert von MathiasJ
                                    #1046
                                    Hi, Radar2 wird kurz grün, dann wieder rot.
                                    bin auf der Version 2.2.2
                                    radar2.0	2019-12-28 06:36:52.079	error	at process._tickCallback (internal/process/next_tick.js:63:19)
                                    radar2.0	2019-12-28 06:36:52.079	error	at state.handle.lookup (dgram.js:242:18)
                                    radar2.0	2019-12-28 06:36:52.079	error	(12861) Error: bind EACCES 0.0.0.0:67
                                    radar2.0	2019-12-28 06:36:52.078	error	(12861) uncaught exception: bind EACCES 0.0.0.0:67
                                    und
                                    host.ioBroker-RasPi4	2019-12-28 06:43:01.923	error	Caught by controller[0]: port: 67 }
                                    host.ioBroker-RasPi4	2019-12-28 06:43:01.923	error	Caught by controller[0]: address: '0.0.0.0',
                                    host.ioBroker-RasPi4	2019-12-28 06:43:01.923	error	Caught by controller[0]: syscall: 'bind',
                                    host.ioBroker-RasPi4	2019-12-28 06:43:01.923	error	Caught by controller[0]: code: 'EACCES',
                                    host.ioBroker-RasPi4	2019-12-28 06:43:01.923	error	Caught by controller[0]: errno: 'EACCES',
                                    host.ioBroker-RasPi4	2019-12-28 06:43:01.922	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:63:19)
                                    host.ioBroker-RasPi4	2019-12-28 06:43:01.922	error	Caught by controller[0]: at state.handle.lookup (dgram.js:242:18)
                                    host.ioBroker-RasPi4	2019-12-28 06:43:01.921	error	Caught by controller[0]: { Error: bind EACCES 0.0.0.0:67
                                    ble ist nur noch gelb, im LOG wwird aber nichts angezeigt. Alles natürlich im debug.
                                    Gruß,
                                    Mathias
                                    IObroker auf dem NUC als VM.
                                    • MathiasJM MathiasJ
                                      und
                                      Gruß,
                                      Mathias
                                      #1047
                                      @MathiasJ falscher thread!! Bitte nutze den 2.2.x thread. Fixer laufen lassen. Irgendwas verbietet das der Prozess auf Port 67 bindet.
