  4. js-controller 2.0 ab sofort im Latest Repo
js-controller
1.1k Beiträge 89 Kommentatoren 527.5k Aufrufe 64 Beobachtet
  • H HelmutS
    @apollon77
    Und auch mit der 2.0.29 startet ioBroker bei mir beim Aufrufen der Adapter-Seite neu
    2019-10-14 09:31:02.991  - error: host.Nathan uncaught exception: Cannot create property 'mimeType' on string 'image/png'
    2019-10-14 09:31:02.992  - error: host.Nathan TypeError: Cannot create property 'mimeType' on string 'image/png'
        at Object.checkFile (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsUtils.js:171:30)
        at ObjectsInMemoryServer.checkFile (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemFileDB.js:180:19)
        at checkFileRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsUtils.js:244:13)
        at ObjectsInMemoryServer.objects.getUserGroup (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsUtils.js:230:13)
        at ObjectsInMemoryServer.utils.getUserGroup (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemFileDB.js:226:22)
        at Object.getUserGroup (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsUtils.js:333:25)
        at ObjectsInMemoryServer.getUserGroup (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemFileDB.js:224:22)
        at Object.checkFileRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsUtils.js:226:17)
        at ObjectsInMemoryServer.checkFileRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemFileDB.js:188:22)
        at ObjectsInMemoryServer.readFile (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemFileDB.js:433:14)
    apollon77A
    apollon77A
    #212
    @HelmutS Grrr ... aber ne andere Stelle jetzt ... Versuchen wir mal was (damit wir nicht noch ne Stelle treffen). Ersetzte mal die /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsUtils.js Datei mit der angehängten objectsUtils.js.
    geht es jetzt oder was ist jetzt die Meldung?
    H 1 Antwort Letzte Antwort
    • apollon77A apollon77
      H
      H
      HelmutS
      #213
      @apollon77
      Jetzt sieht es gut aus. Läuft und auch keine Meldung im Log.
        Dann geht schlafen und morgen früh sieht die Welt bestimmt anders aus ;-)) We weiss wo da ggf noch gecached wird
        dslraserD
        dslraserD
        dslraser
        #214
        @apollon77 sagte in js-controller 2.0 ab sofort im Latest Repo:
        Ich habe mal direkt per npm aktualisiert, da immer noch 2.025 angeboten wird, bei mir jedenfalls.
        Scheint alles zu laufen. Ich werde beobachten.
        • dslraserD dslraser
          liv-in-skyL
          liv-in-skyL
          #215
          @dslraser bei mir ging es erst nach "iobroker update " und anschliessend "iobroker upgrade self" in der console
          • liv-in-skyL liv-in-sky
            crunchipC
            crunchipC
            Developer Global Moderator Most Active Forum Testing
            #216
            @liv-in-sky musste auch ein iobroker update ausführen, danach nochmal aktualisieren, bzw repo laden
              liv-in-skyL
              liv-in-skyL
              #217
              @crunchip das habe ich schon weiter oben nicht verstanden - was heißt bzw. wie macht man : repo laden ?
              AlCalzoneA apollon77A 2 Antworten Letzte Antwort
                AlCalzoneA
                AlCalzoneA
                AlCalzone
                #218
                @liv-in-sky iobroker update oder in der Admin-Liste auf den Reload-Button drücken.
                liv-in-skyL dslraserD 2 Antworten Letzte Antwort
                • AlCalzoneA AlCalzone
                  liv-in-skyL
                  liv-in-skyL
                  #219
                  @AlCalzone danke- das habe ich ja dann eh gemacht - "iobroker update"
                  • crunchipC
                    crunchipC
                    #220
                    Was aber immer noch angezeigt wird, zumindest vom Handy aus, da ich nicht zu Hause bin.
                    Habe schon aktualisiert, anderen Browser verwendet
                    • H HelmutS
                      @apollon77
                      apollon77A
                      apollon77A
                      #221
                      @HelmutS Danke, dann kommt es so ins nächste Update
                        apollon77A
                        apollon77A
                        #222
                        @liv-in-sky Unter "Adapter" auf das Icon mit den zwei runden Pfeilen klicken (Reload) ...
                          dslraserD
                          dslraserD
                          dslraser
                          #223
                          @AlCalzone sagte in js-controller 2.0 ab sofort im Latest Repo:
                          hatte ich beides gemacht, angezeigt wird es aber noch immer nicht.
                          • FredFF
                            FredFF
                            FredF
                            #224
                            Bei mir wird das update auf 2.0.29 auch nicht angeboten.
                            iobroker update bringt u.a.
                            Controller "js-controller" : 2.0.25 , installed 2.0.25
                            iobroker upgrade self sagt das Host is up to date
                            BBTownB apollon77A 2 Antworten Letzte Antwort
                            • FredFF FredF
                              BBTownB
                              BBTownB
                              BBTown
                              schrieb am zuletzt editiert von BBTown
                              #225
                              @FredF macht es ggf. einen Unterschied wenn die Befehle mit/als "sudo" ausgeführt werden?
                              ioBroker auf NUC (VM debian v13 (Trixie ), node v24.22.2 npm v11.19.0, js-controller v7.2.5 jsonl/jsonl / HomeMatic CCU-2 (Wired und Funk) / Philips HUE / echo.DOT / Broadlink RM pro / SONOS
                              FredFF AlCalzoneA 2 Antworten Letzte Antwort
                              • BBTownB BBTown
                                FredFF
                                FredFF
                                FredF
                                #226
                                @BBTown sagte in js-controller 2.0 ab sofort im Latest Repo:
                                Nein, kein Unterschied
                                • BBTownB BBTown
                                  AlCalzoneA
                                  AlCalzoneA
                                  AlCalzone
                                  #227
                                  @BBTown Mittlerweile nicht mehr... Wenn es irgendwie geht, sollte sudo unter allen Umständen vermieden werden (abgesehen von sudo -H -u iobroker ...)
                                  BBTownB 1 Antwort Letzte Antwort
                                  • FredFF FredF
                                    apollon77A
                                    apollon77A
                                    #228
                                    @FredF Wie sehen denn bei iobroker update die ersten zeilen aus dei er ausgibt?
                                      BBTownB
                                      BBTownB
                                      BBTown
                                      #229
                                      wieder etwas gelernt! 👍
                                      • M
                                        M
                                        mdsv
                                        #230
                                        Mich hat vor allem der Geschwindigkeitzuwachs und "VIS verliert weniger die Netzwerkverbindung" motiviert den Umstieg zu starten, Speicher habe ich. Klappte alles … super Arbeit.
                                        Naja, dann wollte ich es wissen, Umstellung von File auf REDIS durchgeführt. Leider prüft er nicht ab, ob es einen REDIS Server unten gibt. Stand auch nicht in der Anleitung, dass man einen installieren sollte. Wenn man an den Punkt ist, ist es leider zu spät. Sollte man noch einbauen oder vielleicht habe ich es auch übersehen.
                                        Hatte vorher Backup gemacht / auch vom kompletten Filesysteme … wo genau liegen die Javaskripte denn?
                                        Rekonstruiere das Ganze grad.
                                        J apollon77A 2 Antworten Letzte Antwort
                                        • M mdsv
                                          J
                                          J
                                          Jan1
                                          #231
                                          @mdsv
                                          na wie willst den auf REDIS wechseln, wenn kein REDIS installiert ist?
                                          33.2k
                                          84.3k
