  4. js-controller 2.0 ab sofort im Latest Repo
    6.3k
js-controller
1.1k Beiträge 89 Kommentatoren 436.0k Aufrufe 64 Beobachtet
  • apollon77A apollon77
    @HelmutS ja. Dazu hatte ich geschrieben das eine neue Version vom Controller, die 2.0.28, das fixen wird. ;-)
    HelmutS
    #211
    @apollon77
    Und auch mit der 2.0.29 startet ioBroker bei mir beim Aufrufen der Adapter-Seite neu
    2019-10-14 09:31:02.991  - error: host.Nathan uncaught exception: Cannot create property 'mimeType' on string 'image/png'
    2019-10-14 09:31:02.992  - error: host.Nathan TypeError: Cannot create property 'mimeType' on string 'image/png'
        at Object.checkFile (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsUtils.js:171:30)
        at ObjectsInMemoryServer.checkFile (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemFileDB.js:180:19)
        at checkFileRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsUtils.js:244:13)
        at ObjectsInMemoryServer.objects.getUserGroup (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsUtils.js:230:13)
        at ObjectsInMemoryServer.utils.getUserGroup (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemFileDB.js:226:22)
        at Object.getUserGroup (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsUtils.js:333:25)
        at ObjectsInMemoryServer.getUserGroup (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemFileDB.js:224:22)
        at Object.checkFileRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsUtils.js:226:17)
        at ObjectsInMemoryServer.checkFileRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemFileDB.js:188:22)
        at ObjectsInMemoryServer.readFile (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemFileDB.js:433:14)
    • H HelmutS
      @apollon77
      #212
      @HelmutS Grrr ... aber ne andere Stelle jetzt ... Versuchen wir mal was (damit wir nicht noch ne Stelle treffen). Ersetzte mal die /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsUtils.js Datei mit der angehängten objectsUtils.js.
      geht es jetzt oder was ist jetzt die Meldung?
      H 1 Antwort Letzte Antwort
        HelmutS
        #213
        @apollon77
        Jetzt sieht es gut aus. Läuft und auch keine Meldung im Log.
          Dann geht schlafen und morgen früh sieht die Welt bestimmt anders aus ;-)) We weiss wo da ggf noch gecached wird
          dslraserD Offline
          dslraserD Offline
          dslraser
          #214
          @apollon77 sagte in js-controller 2.0 ab sofort im Latest Repo:
          Ich habe mal direkt per npm aktualisiert, da immer noch 2.025 angeboten wird, bei mir jedenfalls.
          Scheint alles zu laufen. Ich werde beobachten.
          • dslraserD dslraser
            liv-in-skyL Offline
            liv-in-skyL Offline
            #215
            @dslraser bei mir ging es erst nach "iobroker update " und anschliessend "iobroker upgrade self" in der console
            • liv-in-skyL liv-in-sky
              crunchipC Offline
              crunchipC Offline
              #216
              @liv-in-sky musste auch ein iobroker update ausführen, danach nochmal aktualisieren, bzw repo laden
                liv-in-skyL Offline
                liv-in-skyL Offline
                #217
                @crunchip das habe ich schon weiter oben nicht verstanden - was heißt bzw. wie macht man : repo laden ?
                AlCalzoneA apollon77A 2 Antworten Letzte Antwort
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  #218
                  @liv-in-sky iobroker update oder in der Admin-Liste auf den Reload-Button drücken.
                  liv-in-skyL dslraserD 2 Antworten Letzte Antwort
                  • AlCalzoneA AlCalzone
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    #219
                    @AlCalzone danke- das habe ich ja dann eh gemacht - "iobroker update"
                    • crunchipC Offline
                      crunchipC Offline
                      #220
                      Was aber immer noch angezeigt wird, zumindest vom Handy aus, da ich nicht zu Hause bin.
                      Habe schon aktualisiert, anderen Browser verwendet
                      • H HelmutS
                        @apollon77
                        #221
                        @HelmutS Danke, dann kommt es so ins nächste Update
                          #222
                          @liv-in-sky Unter "Adapter" auf das Icon mit den zwei runden Pfeilen klicken (Reload) ...
                            dslraserD Offline
                            dslraserD Offline
                            dslraser
                            #223
                            @AlCalzone sagte in js-controller 2.0 ab sofort im Latest Repo:
                            hatte ich beides gemacht, angezeigt wird es aber noch immer nicht.
                            • FredFF Online
                              FredFF Online
                              FredF
                              Most Active Forum Testing
                              #224
                              Bei mir wird das update auf 2.0.29 auch nicht angeboten.
                              iobroker update bringt u.a.
                              Controller "js-controller" : 2.0.25 , installed 2.0.25
                              iobroker upgrade self sagt das Host is up to date
                              BBTownB apollon77A 2 Antworten Letzte Antwort
                              • FredFF FredF
                                BBTownB Online
                                BBTownB Online
                                BBTown
                                schrieb am zuletzt editiert von BBTown
                                #225
                                @FredF macht es ggf. einen Unterschied wenn die Befehle mit/als "sudo" ausgeführt werden?
                                FredFF AlCalzoneA 2 Antworten Letzte Antwort
                                • BBTownB BBTown
                                  FredFF Online
                                  FredFF Online
                                  FredF
                                  #226
                                  @BBTown sagte in js-controller 2.0 ab sofort im Latest Repo:
                                  Nein, kein Unterschied
                                  • BBTownB BBTown
                                    AlCalzoneA Offline
                                    AlCalzoneA Offline
                                    AlCalzone
                                    #227
                                    @BBTown Mittlerweile nicht mehr... Wenn es irgendwie geht, sollte sudo unter allen Umständen vermieden werden (abgesehen von sudo -H -u iobroker ...)
                                    BBTownB 1 Antwort Letzte Antwort
                                    • FredFF FredF
                                      #228
                                      @FredF Wie sehen denn bei iobroker update die ersten zeilen aus dei er ausgibt?
                                        BBTownB Online
                                        BBTownB Online
                                        BBTown
                                        #229
                                        wieder etwas gelernt! 👍
                                          mdsv
                                          #230
                                          Mich hat vor allem der Geschwindigkeitzuwachs und "VIS verliert weniger die Netzwerkverbindung" motiviert den Umstieg zu starten, Speicher habe ich. Klappte alles … super Arbeit.
                                          Naja, dann wollte ich es wissen, Umstellung von File auf REDIS durchgeführt. Leider prüft er nicht ab, ob es einen REDIS Server unten gibt. Stand auch nicht in der Anleitung, dass man einen installieren sollte. Wenn man an den Punkt ist, ist es leider zu spät. Sollte man noch einbauen oder vielleicht habe ich es auch übersehen.
                                          Hatte vorher Backup gemacht / auch vom kompletten Filesysteme … wo genau liegen die Javaskripte denn?
                                          Rekonstruiere das Ganze grad.
                                          J apollon77A 2 Antworten Letzte Antwort
