  4. Test js-controller v2.0.x (GitHub)
js-controller
1.0k Beiträge 48 Kommentatoren 506.4k Aufrufe 35 Beobachtet
  • coyoteC
    coyoteC
    coyote
    #736
    @apollon77 kannst du mir vllt da weiterhelfen? Habe diese "node-hue-api" gerade nochmal neu in die javascript instanz hinzugefügt, dann kommt folgendes:
    host.debian	2019-10-10 22:53:54.042	info	instance system.adapter.javascript.0 terminated with code 156 (156)
    host.debian	2019-10-10 22:53:54.042	error	Caught by controller[9]: (node:20588) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
    host.debian	2019-10-10 22:53:54.042	error	Caught by controller[8]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
    host.debian	2019-10-10 22:53:54.042	error	Caught by controller[8]: (node:20588) UnhandledPromiseRejectionWarning: Error: connect ECONNREFUSED 192.168.66.31:443
    host.debian	2019-10-10 22:53:54.042	error	Caught by controller[7]: (node:20588) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
    host.debian	2019-10-10 22:53:54.041	error	Caught by controller[6]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
    host.debian	2019-10-10 22:53:54.041	error	Caught by controller[6]: (node:20588) UnhandledPromiseRejectionWarning: Error: connect ECONNREFUSED 192.168.66.31:443
    host.debian	2019-10-10 22:53:54.041	error	Caught by controller[5]: (node:20588) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
    host.debian	2019-10-10 22:53:54.041	error	Caught by controller[4]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
    host.debian	2019-10-10 22:53:54.041	error	Caught by controller[4]: (node:20588) UnhandledPromiseRejectionWarning: Error: connect ECONNREFUSED 192.168.66.31:443
    host.debian	2019-10-10 22:53:54.041	error	Caught by controller[3]: (node:20588) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js proc
    host.debian	2019-10-10 22:53:54.041	error	Caught by controller[2]: (node:20588) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
    host.debian	2019-10-10 22:53:54.041	error	Caught by controller[1]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
    host.debian	2019-10-10 22:53:54.040	error	Caught by controller[1]: (node:20588) UnhandledPromiseRejectionWarning: Error: connect ECONNREFUSED 192.168.66.31:443
    host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: ********************************************************************************
    host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: Please consult the documentation at https://github.com/peter-murray/node-hue-api for the documentation on the new API.
    host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: require("node-hue-api").v3
    host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: You need to migrate your code to use the new API available via import
    host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: This will be removed in v4.x of node-hue-api.
    host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: This shim provides a limited backporting of the features available in the updated API in v3.x.
    host.debian	2019-10-10 22:53:54.039	error	Caught by controller[0]: Backwards compatibility shim for node-hue-api.
    host.debian	2019-10-10 22:53:54.035	error	Caught by controller[0]: ********************************************************************************
    javascript.0	2019-10-10 22:53:52.981	info	(20588) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    javascript.0	2019-10-10 22:53:52.432	info	(20588) Got terminate signal TERMINATE_YOURSELF
    Vorher hatte das ohne Probleme funktioniert
    • coyoteC coyote
      apollon77A
      apollon77A
      #737
      @coyote sagte in [Aufruf] js-controller 2.0 Beta Test:
      192.168.66.31:443
      Also einmal 192.168.66.31:443 ECONREFUSED heist Connection Refused. DU kannst dich da nicht hin verbinden oder sowas. Da sist aber jetzt 100% Offtopic hier
      coyoteC 1 Antwort Letzte Antwort
      • apollon77A apollon77
        192.168.66.31:443
        coyoteC
        coyoteC
        coyote
        schrieb am zuletzt editiert von coyote
        #738
        @apollon77 ja das ist mir eigentlich schon klar, die HueBridge ist aber erreichbar, also eigentlich kann es da nicht dran liegen und der Fehler kam ja erst als ich den node-hue-api in der Javascript Instanz nochmal hinzugefügt hab, deshalb dachte ich es könnte was mit dem js-controller zu tun haben, da es vorher ohne Probleme lief.
        Es geht mir eher um die unteren Zeilen
        • coyoteC coyote
          apollon77A
          apollon77A
          #739
          @coyote Docker? Netzwerk? Firewall? SOwas vllt? Kannst Du von dem ioBroker Host die seite mit curl oder so erreichen? Owas ... aber anderer Thread Bitte!
            coyoteC
            coyoteC
            coyote
            #740
            @apollon77 weder noch und ja ich kann auch über die iobroker objekte von hue, direkt meine lampen schalten, also ist die Bridge ja erreichbar. Hat damit nichts zu tun. Mir geht es nur um diese node-hue-api, das funktioniert nicht mehr. Gestern mit der 2.0.24 ging das ja noch ohne Probleme, sonst noch ne Idee?
            • coyoteC coyote
              apollon77A
              apollon77A
              #741
              @coyote keine ohne jetzt tief rein zu schauen. Die Änderungen 24->25 sind diesbezüglich auch an sich irrelevant.
                coyoteC
                coyoteC
                coyote
                #742
                @apollon77 hm ok, naja könnte auch schon vorher ein Problem gewesen sein und ich hab es nicht gemerkt, erst als ich heute die Objekte neu synchronisieren wollte. Naja, dann weiß ich es momentan erst auch mal nicht, muss ich weiter suchen. Keine Ahnung was er jetzt für ein Problem mit dem node-hue-api hat, da bin ich nicht tief genug drin in der Materie.
                • coyoteC
                  coyoteC
                  coyote
                  #743
                  @apollon77 falls du irgendwann Zeit hast kannst du vllt mal kurz in die Log Datei schauen. Habe gerade die Javascript Instanz auf 4.3.0 upgedatet und Fehler im Log, weiß aber jetzt nicht, ob das mit dem js-controller zusammenhängt. Wenn nicht mach ich nen neuen Beitrag dazu.
                  Hier:Log.txt
                  • coyoteC coyote
                    Hier:Log.txt
                    apollon77A
                    apollon77A
                    #744
                    @coyote der eine teil mir Write permissives ist mal wieder npm beim Paket Update wegen irgendwelchen rechten. Am besten install fiyer laufen lassen um sowas zu fixen.
                    Ansonsten
                    1. TypeError: Cannot read property 'Tail' of undefined
                    Ist ggf folgefehler weil die tail library nicht installiert wurde korrekt.
                    Also beides nicht Controller. Fixe die permission Fehler dann weiterschauen
                    • apollon77A
                      apollon77A
                      #745
                      So, ich mache hier heute Abend zu. Weiter geht es --> https://forum.iobroker.net/topic/25692/js-controller-2-0-ab-sofort-im-latest-repo
                      Ich bedanke mich bei Euch allen für die Super Zusammenarbeit. Zusammen haben wir glaube ich eine super getestete Version für "die Allgemeinheit" bekommen die jetzt, falls noch was drin ist, im Latest Repo final "reifen" kann :-)
                      Ich melde mich um Weihnachten rum dann zur 2.1 wieder ;-)
                        @darkiop
                        Okay, da ist es V 0.11.4
                        Bis jetzt geht es. melde mich morgen noch einmal.
                        #746
                        @Nuggelbeb
                        Alles iO!!!
                        SUPER
                        • apollon77A
                          apollon77A
                          #747
                          Hallo nochmals,
                          Falls jemand noch Zeit und Lust hat. Auf Github ist die 2.0.26 mit den Kleinigkeiten die aufgefallen sind. Release im Latest geplant für heute abend/morgen.
                          Installation wie bisher hier üblich direkt per npm.
                          2.0.26 Release Bella
                          • (Apollon77) Make sure Logs are only streamed to admin for selected loglevel
                          • (Apollon77) Fix "iobroker file write"
                          • (Apollon77) Make sure invalid ids are handled correctly without throwing errors
                          • (bluefox) Add alias.0 as object to be added
                          • (bluefox) Allow Arrays as state values
                          • (bluefox) Translate object names
                            Hallo nochmals,
                            sigi234S
                            sigi234S
                            #748
                            @apollon77
                            Screenshot (258).png 😀
                            • D
                              D
                              darkiop
                              #749
                              Habs eben installiert und check heut Abend wann wir wieder zuhause sind das Log :)
                              ioBroker Object Explorer: https://forum.iobroker.net/topic/84117/iobroker-object-explorer-dashboard-zum-verwalten-von-dps?_=1789113045261 | Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                              • liv-in-skyL
                                liv-in-skyL
                                #750
                                js-controller 2.0.25 startet - bisher keine fehler
                                • BBTownB
                                  BBTownB
                                  BBTown
                                  #751
                                  @apollon77 hast Du gleich noch eine v2.0.27 nachgeschoben?
                                  ioBroker auf NUC (VM debian v13 (Trixie ), node v24.21.0 npm v11.19.0, js-controller v7.2.5 jsonl/jsonl / HomeMatic CCU-2 (Wired und Funk) / Philips HUE / echo.DOT / Broadlink RM pro / SONOS
                                  • apollon77A
                                    apollon77A
                                    #752
                                    Ja und gerade noch 2.0.28. sind jetzt bei den echten Edge cases angelangt ;-)
                                    L E 2 Antworten Letzte Antwort
                                    • BBTownB
                                      BBTownB
                                      BBTown
                                      #753
                                      @apollon77
                                      Respekt ... Privatleben wird auch total überschätzt 😎
                                      • crunchipC
                                        crunchipC
                                        Developer Global Moderator Most Active Forum Testing
                                        #754
                                        @apollon77 also dann hier nochmal wegen dem log
                                        da ja vorher diverse Adapter nicht mit der entsprechenden Logstufe funktionierten, habe ich nun mal bei sämtlichen Adaptern, die auf warn/error standen wieder auf Info gestellt.
                                        Betroffen waren der Web, Chromcast, virtualpowermeter, die das log "zugemüllt" hatten
                                        desweiteren, wurde z.b beim virtualpowermeter in der .25 Version trotz ändern der logstufe das log zugemüllt.
                                        in der .28 stehen nun bei mir alle Adapter auf Logstufe Info und log verhält sich sehr, sehr ruhig,
                                        fast nur noch Meldungen, wenn z.b. Adapter per cron aktualisieren
                                          L
                                          L
                                          lonsimbt
                                          #755
                                          @apollon77
                                          2.0.28 konnte ich problemlos installieren. Ich musste allerdings anschließend den Installations-Fixer drüberlaufen lassen wegen einiger Berechtigungsprobleme. Danach startet das System ohne Auffälligkeiten im Log.
                                          Gruß Marco
                                          iobroker im Container (debian Bullseye) unter proxmox 7.1
                                          debmatic in VM (debian Buster) unter proxmox 7.1 mit HB-RF-USB und RPI-RF-MOD
                                          40 HomeMatic Geräte, Phillips Hue, Ikea Tradfri, Logitech Harmony Hub, Botvac Connected, Robonect
                                          84.1k
